RTEMS  5.1
tasksetup_general.h
1 /******************************************************************************
2 *
3 * Copyright (c) 2004 Freescale Semiconductor, Inc.
4 *
5 * Permission is hereby granted, free of charge, to any person obtaining a
6 * copy of this software and associated documentation files (the "Software"),
7 * to deal in the Software without restriction, including without limitation
8 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
9 * and/or sell copies of the Software, and to permit persons to whom the
10 * Software is furnished to do so, subject to the following conditions:
11 *
12 * The above copyright notice and this permission notice shall be included
13 * in all copies or substantial portions of the Software.
14 *
15 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
16 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
17 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
18 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR
19 * OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
20 * ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
21 * OTHER DEALINGS IN THE SOFTWARE.
22 *
23 ******************************************************************************/
24
25 /*
26  * Task builder generates a set #defines per configured task to
27  * condition this templete file.
28  */
29
30 /**********************************************************
31  *
32  * Required #defines:
33  * ------------------
34  * TASKSETUP_NAME:
35  * TaskSetup function name, set to TaskSetup_<TASK_NAME>
36  * TASK_API:
37  * task API defined in dma_image.h
38  * MAX_BD:
39  * <=0 : non-BD task
40  * else: number of BD in BD table
41  * BD_FLAG:
42  * 0 : no flag implemented for BD
43  * else: flags can be passed on a per BD basis
44  * MISALIGNED:
45  * 0 : task API supports Bytes%IncrBytes==0
46  * else: task API supports any parameter settings
47  * AUTO_START:
48  * <-1 : do not start a task after task completion
49  * -1 : auto start the task after task completion
50  * <MAX_TASKS: auto start task with the TaskID = AUTO_START
51  * else : do not start a task after task completion
52  * INITIATOR_DATA:
53  * <0 : runtime configurable
54  * else: assume INITATOR_DATA equal hard-coded task initiator
55  * TYPE_SRC: (needs to be consistent with Task API)
56  * FLEX_T : Task API TYPE_SRC = flex, SzSrc defines size
57  * UINT8_T : Task API TYPE_SRC = char
58  * UINT16_T: Task API TASK_SRC = short
59  * UINT32_T: Task API TASK_SRC = int
60  * INCR_TYPE_SRC:
61  * 0 : FIFO address, do not implement data pointer
62  * 1 : automatic, set INCR_SRC based on SzSrc parameter
63  * 2 : runtime, set INCR_SRC to IncrSrc parameter
64  * else: used hard-coded INCR_SRC
65  * INCR_SRC:
66  * INCR_TYPE_SRC=0: force INCR_SRC=0
67  * else : use for src pointer increment
68  * TYPE_DST: (needs to be consistent with Task API)
69  * FLEX_T : Task API TYPE_DST = flex, SzDst defines size
70  * UINT8_T : Task API TYPE_DST = char
71  * UINT16_T: Task API TASK_DST = short
72  * UINT32_T: Task API TASK_DST = int
73  * INCR_TYPE_DST:
74  * 0 : FIFO address, do not implement data pointer
75  * 1 : automatic, set INCR_DST based on SzDst parameter
76  * 2 : runtime, set INCR_DST to IncrDst parameter
77  * else: used hard-coded INCR_DST
78  * INCR_DST:
79  * INCR_TYPE_DST=0: force INCR_DST=0
80  * else : use for dst pointer increment
81  * PRECISE_INCREMENT:
82  * 0 : increment when possible
83  * else: increment at end of iteration
84  * NO_ERROR_RESET:
85  * 0 : reset error flags on task enable
86  * else: leave error flags unmodified on task enable
87  * PACK_DATA:
88  * 0 : do not pack data
89  * else: pack data based on data type
90  * INTEGER_MODE:
91  * 0 : type conversions handle as fixed point numbers
92  * else: type conversions handle as integers
93  * WRITE_LINE_BUFFER:
94  * 0 : do not use write line buffers
95  * else: enable write line buffers
96  * READ_LINE_BUFFER:
97  * 0 : do not use read line buffers
98  * else: enable read line buffers
99  * SPEC_READS:
100  * 0 : do not speculatively read
101  * else: speculatively read data ahead of DMA engine
102  *
103  * Optional #defines:
104  * ------------------
105  * MAX_TASKS:
106  * 1 : #define MAX_TASKS>0
107  * else: 16
108  * ITERATIONS:
109  * 1 : #define ITERATIONS>0
110  * else: 1
111  * INCR_BYTES:
112  * This macro is defined based on following priority:
113  * 1 : INCR_SRC != 0
114  * 2 : DST_TYPE != 0
115  * 3 : #defined INCR_BYTES<0
116  * else: -4 (SZ_UINT32)
117  * DEBUG_BESTCOMM_API:
118  * >0 : print basic debug messages
119  * >=10: also print C-API interface variables
120  * >=20: also print task API interface variables
121  * else: do nothing
122  *
123  **********************************************************/
124
125 #if defined(__rtems__) || defined(MPC5200_BAPI_LIBC_HEADERS)
126 #include <stdlib.h>
127 #endif
128
129 #include "../dma_image.h"
130
131 #include "../bestcomm_api.h"
132 #include "tasksetup_bdtable.h"
133
134 #include "bestcomm_api_mem.h"
135 #include "bestcomm_cntrl.h"
136
137 #ifndef DEBUG_BESTCOMM_API
138  #define DEBUG_BESTCOMM_API 0
139 #endif
140
141 #ifdef FLEX_T
142  #undef FLEX_T
143 #endif
144 #define FLEX_T SZ_FLEX
145
146 #ifdef UINT8_T
147  #undef UINT8_T
148 #endif
149 #define UINT8_T SZ_UINT8
150
151 #ifdef UINT16_T
152  #undef UINT16_T
153 #endif
154 #define UINT16_T SZ_UINT16
155
156 #ifdef UINT32_T
157  #undef UINT32_T
158 #endif
159 #define UINT32_T SZ_UINT32
160
161 #if (INCR_TYPE_SRC==0) /* FIFO address, no data pointer */
162  #undef INCR_SRC
163  #define INCR_SRC 0
164 #endif
165
166 #if (INCR_TYPE_DST==0) /* FIFO address, no data pointer */
167  #undef INCR_DST
168  #define INCR_DST 0
169 #endif
170
171 #ifndef MAX_TASKS
172  #define MAX_TASKS 16
173 #else
174  #if (MAX_TASKS<=0)
175  #undef MAX_TASKS
176  #define MAX_TASKS 16
177  #endif
178 #endif
179
180 #ifndef ITERATIONS
181  #define ITERATIONS 1
182 #else
183  #if (ITERATIONS<=0)
184  #undef ITERATIONS
185  #define ITERATIONS 1
186  #endif
187 #endif
188
189 #ifndef INCR_BYTES
190  #define INCR_BYTES -4
191 #else
192  #if (INCR_BYTES>=0)
193  #undef INCR_BYTES
194  #define INCR_BYTES -4
195  #endif
196 #endif
197
198 /*
199  * These ifndefs will go away when support in task_capi wrappers
200  * in the image directories
201  */
202 #ifndef PRECISE_INCREMENT
203  #define PRECISE_INCREMENT 0 /* bit=6 SAS->1, increment 0=when possible, 1=at the end of interation */
204 #endif
205 #ifndef NO_ERROR_RESET
206  #define NO_ERROR_RESET 0 /* bit=5 SAS->0, do not reset error codes on task enable */
207 #endif
208 #ifndef PACK_DATA
209  #define PACK_DATA 0 /* bit=4 SAS->0, pack data enable */
210 #endif
211 #ifndef INTEGER_MODE
212  #define INTEGER_MODE 0 /* bit=3 SAS->0, 0=fractional(msb aligned), 1=integer(lsb aligned) */
213 #endif
214 #ifndef SPEC_READS
215  #define SPEC_READS 1 /* bit=2 SAS->0, XLB speculative read enable */
216 #endif
217 #ifndef WRITE_LINE_BUFFER
218  #define WRITE_LINE_BUFFER 1 /* bit=1 SAS->0, write line buffer enable */
219 #endif
220 #ifndef READ_LINE_BUFFER
221  #define READ_LINE_BUFFER 1 /* bit=0 SAS->0, read line buffer enable */
222 #endif
223 #define SDMA_PRAGMA (0 <<SDMA_PRAGMA_BIT_RSV ) | \
224  (PRECISE_INCREMENT<<SDMA_PRAGMA_BIT_PRECISE_INC ) | \
225  (NO_ERROR_RESET <<SDMA_PRAGMA_BIT_RST_ERROR_NO) | \
226  (PACK_DATA <<SDMA_PRAGMA_BIT_PACK ) | \
227  (INTEGER_MODE <<SDMA_PRAGMA_BIT_INTEGER ) | \
228  (SPEC_READS <<SDMA_PRAGMA_BIT_SPECREAD ) | \
229  (WRITE_LINE_BUFFER<<SDMA_PRAGMA_BIT_CW ) | \
230  (READ_LINE_BUFFER <<SDMA_PRAGMA_BIT_RL )
231
232 #ifndef TASKSETUP_NAME
233  #define PREPEND_TASKSETUP(name) TaskSetup_ ## name
234  #define FUNC_PREPEND_TASKSETUP(name) PREPEND_TASKSETUP(name)
235  #define TASKSETUP_NAME FUNC_PREPEND_TASKSETUP(TASK_BASE)
236 #endif
237
238 #ifndef TASK_API
239  #define APPEND_API(name) name ## _api_t
240  #define FUNC_APPEND_API(name) APPEND_API(name)
241  #define TASK_API FUNC_APPEND_API(TASK_BASE)
242 #endif
243
244 #ifndef INIT_DMA_IMAGE
245  #define PREPEND_INITDMA(name) init_dma_image_ ## name
246  #define FUNC_PREPEND_INITDMA(name) PREPEND_INITDMA(name)
247  #define INIT_DMA_IMAGE FUNC_PREPEND_INITDMA(TASK_BASE)
248 #endif
249
250 #define DRD_INIT_MASK 0xfc1fffff
251 #define DRD_EXT_FLAG 0x40000000
252 #define DRD_INIT_OFFSET 21
253
254 TaskId TASKSETUP_NAME(TASK_API *TaskAPI,
255  TaskSetupParamSet_t *TaskSetupParams)
256 {
257  TaskId TaskNum;
258 #if ((MAX_BD>0)||(DEBUG_BESTCOMM_API>0))
259  uint32 Status = 0;
260 #endif
261 #if ((MAX_BD>0)&&((INCR_TYPE_SRC!=0)||(INCR_TYPE_DST!=0))||(DEBUG_BESTCOMM_API>0))
262  uint8 NumPtr = 0;
263 #endif
264 #if (INITIATOR_DATA<0) /* runtime configurable */
265  uint32 i, ext;
266 #endif
267
268  INIT_DMA_IMAGE((uint8 *)(((sdma_regs *)(SDMA_TASK_BAR))->taskBar), MBarPhysOffsetGlobal);
269
270  TaskNum = (TaskId)SDMA_TASKNUM_EXT(TaskAPI->TaskNum);
271
272  TaskRunning[TaskNum] = 0;
273
274 #if (DEBUG_BESTCOMM_API>0)
275  printf("\nBestComm API Debug Display Mode Enabled\n\n");
276  printf("TaskSetup: TaskID=%d\n", TaskNum);
277  if (Status!=0) {
278  printf("TaskSetup: Rx task\n");
279  } else {
280  printf("TaskSetup: Tx or DP task\n");
281  }
282 #endif
283
284  /* Set the task pragma settings */
285  *(TaskAPI->TaskPragma)= (uint8) SDMA_PRAGMA;
286
287 #if (MAX_BD>0) /* Buffer Descriptors */
288
289  #if (INCR_TYPE_SRC!=0)
290  ++NumPtr;
291  #endif
292  #if (INCR_TYPE_DST!=0)
293  ++NumPtr;
294  #endif
295
296  #if (DEBUG_BESTCOMM_API>0)
297  printf("TaskSetup: Using %d buffer descriptors, each with %d data pointers\n", MAX_BD, NumPtr);
298  #endif
299
300  /* Allocate BD table SRAM storage,
301  * and pass addresses to task API */
302
303  TaskSetup_BDTable(TaskAPI->BDTableBase,
304  TaskAPI->BDTableLast,
305  TaskAPI->BDTableStart,
306  TaskNum,
307  TaskSetupParams->NumBD,
308  MAX_BD, NumPtr,
309  BD_FLAG, Status);
310
311  *TaskAPI->AddrEnable = (uint32)((uint32)(((uint16 *)SDMA_TCR)+TaskNum) + MBarPhysOffsetGlobal);
312
313  #if BD_FLAG
314
315  #if (DEBUG_BESTCOMM_API>0)
316  printf("TaskSetup: Buffer descriptor flags are enabled\n");
317  #endif
318
319  /* always assume 2nd to last DRD */
320  *((TaskAPI->AddrDRD)) = (uint32)((uint32)TaskAPI->DRD[TaskAPI->AddrDRDIdx] + MBarPhysOffsetGlobal);
321  #endif /* #if BD_FLAG */
322
323 #else /* No Buffer Descriptors */
324
325 /* #error ATA should not be non-BD */
326
327  #if (DEBUG_BESTCOMM_API>0)
328  printf("TaskSetup: Task will complete %d iterations before disabling\n");
329  #endif
330
331  *((TaskAPI->IterExtra)) = (uint32)(ITERATIONS-1);
332 #endif /* #if (MAX_BD>0) */
333
334 /* Setup auto start */
335 #if (AUTO_START <= -2 ) /* do not start a task */
336  #if (DEBUG_BESTCOMM_API>0)
337  printf("TaskSetup: Auto task start disabled\n");
338  #endif
339  SDMA_TASK_CFG(SDMA_TCR, TaskNum, 0, TaskNum);
340 #elif (AUTO_START <= -1 ) /* restart task */
341  #if (DEBUG_BESTCOMM_API>0)
342  printf("TaskSetup: Auto start task\n");
343  #endif
344  SDMA_TASK_CFG(SDMA_TCR, TaskNum, 1, TaskNum);
345 #elif (AUTO_START < MAX_TASKS) /* start specific task */
346  #if (DEBUG_BESTCOMM_API>0)
347  printf("TaskSetup: Auto start task with TaskID=%d\n", AUTO_START);
348  #endif
349  SDMA_TASK_CFG(SDMA_TCR, TaskNum, 1, AUTO_START);
350 #else /* do not start a task */
351  #if (DEBUG_BESTCOMM_API>0)
352  printf("TaskSetup: Auto task start disabled\n");
353  #endif
354  SDMA_TASK_CFG(SDMA_TCR, TaskNum, 0, TaskNum);
355 #endif
356
357 #if (INITIATOR_DATA<0) /* runtime configurable */
358  SDMA_SET_INIT(SDMA_TCR, TaskNum, TaskSetupParams->Initiator);
359
360  /*
361  * Hard-code the task initiator in the DRD to avoid a problem w/ the
362  * hold initiator bit in the TCR.
363  */
364  ext = 0;
365  for (i = 0; i < TaskAPI->NumDRD; i++) {
366  if (ext == 0)
367  {
368 #if (DEBUG_BESTCOMM_API>=10)
369  printf("TaskSetup: DRD[%d] initiator = %d\n", i, ((*(TaskAPI->DRD[i]) & ~DRD_INIT_MASK) >> DRD_INIT_OFFSET));
370 #endif
371  if (((*(TaskAPI->DRD[i]) & ~DRD_INIT_MASK) >> DRD_INIT_OFFSET) != INITIATOR_ALWAYS) {
372 #if (DEBUG_BESTCOMM_API>=10)
373  printf("TaskSetup: Replacing DRD[%d] initiator with %d\n", i, TaskSetupParams->Initiator);
374 #endif
375  *(TaskAPI->DRD[i]) = (*(TaskAPI->DRD[i]) & DRD_INIT_MASK)
376  | (TaskSetupParams->Initiator << DRD_INIT_OFFSET);
377  }
378
379  if ((*(TaskAPI->DRD[i]) & DRD_EXT_FLAG) != 0)
380  {
381  ext = 1;
382  }
383  }
384  else
385  {
386  if ((*(TaskAPI->DRD[i]) & DRD_EXT_FLAG) == 0)
387  {
388  ext = 0;
389  }
390  }
391  }
392
393 #else /* INITIATOR_DATA >= 0 */
394  TaskSetupParams->Initiator = INITIATOR_DATA;
395 #endif
396
397 #if (DEBUG_BESTCOMM_API>=10)
398  printf("\nTaskSetup: C-API Parameter Settings Passed to TaskSetup:\n");
399  printf("TaskSetup: NumBD = %d\n", TaskSetupParams->NumBD);
400  #if (MAX_BD>0)
401  printf("TaskSetup: MaxBuf = %d\n", TaskSetupParams->Size.MaxBuf);
402  #else
403  printf("TaskSetup: NumBytes = %d\n", TaskSetupParams->Size.NumBytes);
404  #endif
405  printf("TaskSetup: Initiator = %d\n", TaskSetupParams->Initiator);
406  printf("TaskSetup: StartAddrSrc = 0x%08X\n", TaskSetupParams->StartAddrSrc);
407  printf("TaskSetup: IncrSrc = %d\n", TaskSetupParams->IncrSrc);
408  printf("TaskSetup: SzSrc = %d\n", TaskSetupParams->SzSrc);
409  printf("TaskSetup: StartAddrDst = 0x%08X\n", TaskSetupParams->StartAddrDst);
410  printf("TaskSetup: IncrDst = %d\n", TaskSetupParams->IncrDst);
411  printf("TaskSetup: SzDst = %d\n", TaskSetupParams->SzDst);
412 #endif
413
414 #if (DEBUG_BESTCOMM_API>=20)
415  printf("\nTaskSetup: Task-API Parameter Settings Before TaskSetup Initialization:\n");
416  printf("TaskSetup: TaskNum = %d\n", (TaskAPI->TaskNum));
417  printf("TaskSetup: TaskPragma = 0x%02X\n", *((TaskAPI->TaskPragma)));
418  printf("TaskSetup: TCR = 0x%04x\n", SDMA_TASK_STATUS(SDMA_TCR, TaskNum));
419
420  #if (MAX_BD>0)
421  printf("TaskSetup: BDTableBase = 0x%08X\n", *((TaskAPI->BDTableBase)));
422  printf("TaskSetup: BDTableLast = 0x%08X\n", *((TaskAPI->BDTableLast)));
423  printf("TaskSetup: BDTableStart = 0x%08X\n", *((TaskAPI->BDTableStart)));
424  printf("TaskSetup: AddrEnable = 0x%08X\n", *((TaskAPI->AddrEnable)));
425  #if (INCR_TYPE_SRC==0)
426  printf("TaskSetup: AddrSrcFIFO = 0x%08X\n", *((TaskAPI->AddrSrcFIFO)));
427  #endif
428  #if (INCR_TYPE_DST==0)
429  printf("TaskSetup: AddrDstFIFO = 0x%08X\n", *((TaskAPI->AddrDstFIFO)));
430  #endif
431  #if (BD_FLAG)
432  printf("TaskSetup: AddrDRD = 0x%08X\n", *((TaskAPI->AddrDRD)));
433  printf("TaskSetup: AddrDRDIdx = %d\n", ((TaskAPI->AddrDRDIdx)));
434  #endif
435  #else
436  printf("TaskSetup: IterExtra = %d\n", *((TaskAPI->IterExtra)));
437  #if (INCR_TYPE_SRC==0)
438  printf("TaskSetup: AddrSrcFIFO = 0x%08X\n", *((TaskAPI->AddrSrcFIFO)));
439  #else
440  printf("TaskSetup: StartAddrSrc = 0x%08X\n", *((TaskAPI->StartAddrSrc)));
441  #endif
442  #if (INCR_TYPE_DST==0)
443  printf("TaskSetup: AddrDstFIFO = 0x%08X\n", *((TaskAPI->AddrDstFIFO)));
444  #else
445  printf("TaskSetup: StartAddrDst = 0x%08X\n", *((TaskAPI->StartAddrDst)));
446  #endif
447  #endif
448  #if (INCR_TYPE_SRC!=0)
449  printf("TaskSetup: IncrSrc = 0x%04X\n", *((TaskAPI->IncrSrc)));
450  #if (MISALIGNED | MISALIGNED_START)
451  printf("TaskSetup: IncrSrcMA = 0x%04X\n", *((TaskAPI->IncrSrcMA)));
452  #endif
453  #endif
454  #if (INCR_TYPE_DST!=0)
455  printf("TaskSetup: IncrDst = 0x%04X\n", *((TaskAPI->IncrDst)));
456  #if (MISALIGNED | MISALIGNED_START)
457  printf("TaskSetup: IncrDstMA = 0x%04X\n", *((TaskAPI->IncrDstMA)));
458  #endif
459  #endif
460  printf("TaskSetup: Bytes = %d\n", *((TaskAPI->Bytes)));
461  printf("TaskSetup: IncrBytes = %d\n", *((TaskAPI->IncrBytes)));
462 #endif
463
464
465  *((TaskAPI->Bytes)) = (uint32)TaskSetupParams->Size.MaxBuf;
466
467
468 #if (TYPE_SRC!=FLEX_T) /* size fixed in task code */
469  TaskSetupParams->SzSrc = TYPE_SRC;
470 #endif
471
472 #if (INCR_TYPE_SRC==0) /* no data pointer */
473  TaskSetupParams->IncrSrc = (sint16)0;
474  *((TaskAPI->AddrSrcFIFO)) = (uint32)TaskSetupParams->StartAddrSrc;
475 #else
476
477  #if (INCR_TYPE_SRC==1) /* automatic */
478  if (TaskSetupParams->IncrSrc!=0) {
479  TaskSetupParams->IncrSrc = (sint16)+TaskSetupParams->SzSrc;
480  } else {
481  TaskSetupParams->IncrSrc = (sint16)+TaskSetupParams->IncrSrc;
482  }
483  #elif (INCR_TYPE_SRC!=2) /* hard-coded */
484  TaskSetupParams->IncrSrc = (sint16)INCR_SRC;
485  #endif
486  *((TaskAPI->IncrSrc)) = (sint16)TaskSetupParams->IncrSrc;
487
488  #if (MAX_BD>0) /* pointer in BD Table */
489  /* pass back address of first BD */
490  TaskSetupParams->StartAddrSrc = (uint32)TaskGetBDRing(TaskNum);
491  #else
492  *((TaskAPI->StartAddrSrc)) = (uint32)TaskSetupParams->StartAddrSrc;
493  #endif
494
495  #if MISALIGNED | MISALIGNED_START
496  if (TaskSetupParams->IncrSrc < 0) {
497  *((TaskAPI->IncrSrcMA)) = (sint16)-1;
498  } else if (TaskSetupParams->IncrSrc > 0) {
499  *((TaskAPI->IncrSrcMA)) = (sint16)+1;
500  } else {
501  *((TaskAPI->IncrSrcMA)) = (sint16)0;
502  }
503  #endif
504 #endif
505
506
507 #if (TYPE_DST!=FLEX_T) /* size fixed in task code */
508  TaskSetupParams->SzDst = TYPE_DST;
509 #endif
510
511 #if (INCR_TYPE_DST==0) /* no data pointer */
512  TaskSetupParams->IncrDst = (sint16)0;
513  *((TaskAPI->AddrDstFIFO)) = (uint32)TaskSetupParams->StartAddrDst;
514 #else
515  #if (INCR_TYPE_DST==1) /* automatic */
516  if (TaskSetupParams->IncrDst!=0) {
517  TaskSetupParams->IncrDst = (sint16)+TaskSetupParams->SzDst;
518  } else {
519  TaskSetupParams->IncrDst = (sint16)+TaskSetupParams->IncrDst;
520  }
521  #elif (INCR_TYPE_DST!=2) /* hard-coded */
522  TaskSetupParams->IncrDst = (sint16)INCR_DST;
523  #endif
524  *((TaskAPI->IncrDst)) = (sint16)TaskSetupParams->IncrDst;
525
526  #if (MAX_BD>0)
527  /* pass back address of first BD */
528  TaskSetupParams->StartAddrDst = (uint32)TaskGetBDRing(TaskNum);
529  #else
530  *((TaskAPI->StartAddrDst)) = (uint32)TaskSetupParams->StartAddrDst;
531  #endif
532
533  #if MISALIGNED | MISALIGNED_START
534  if (TaskSetupParams->IncrDst < 0) {
535  *((TaskAPI->IncrDstMA)) = (sint16)-1;
536  } else if (TaskSetupParams->IncrDst > 0) {
537  *((TaskAPI->IncrDstMA)) = (sint16)+1;
538  } else {
539  *((TaskAPI->IncrDstMA)) = (sint16)0;
540  }
541  #endif
542 #endif
543
544 /* always use macro, only affect code with #define TYPE_? flex */
545  SDMA_SET_SIZE(SDMA_TASK_SIZE, TaskNum, TaskSetupParams->SzSrc, TaskSetupParams->SzDst);
546
547
548  if (TaskSetupParams->IncrSrc != 0) {
549  *((TaskAPI->IncrBytes)) = (sint16)-abs(TaskSetupParams->IncrSrc);
550  } else if (TaskSetupParams->IncrDst != 0) {
551  *((TaskAPI->IncrBytes)) = (sint16)-abs(TaskSetupParams->IncrDst);
552  } else {
553  *((TaskAPI->IncrBytes)) = (sint16)-abs(INCR_BYTES);
554  }
555
556
557 #if (DEBUG_BESTCOMM_API>=10)
558  printf("\nTaskSetup: C-API Parameter Settings Returned from TaskSetup:\n");
559  printf("TaskSetup: NumBD = %d\n", TaskSetupParams->NumBD);
560  #if (MAX_BD>0)
561  printf("TaskSetup: MaxBuf = %d\n", TaskSetupParams->Size.MaxBuf);
562  #else
563  printf("TaskSetup: NumBytes = %d\n", TaskSetupParams->Size.NumBytes);
564  #endif
565  printf("TaskSetup: Initiator = %d\n", TaskSetupParams->Initiator);
566  printf("TaskSetup: StartAddrSrc = 0x%08X\n", TaskSetupParams->StartAddrSrc);
567  printf("TaskSetup: IncrSrc = %d\n", TaskSetupParams->IncrSrc);
568  printf("TaskSetup: SzSrc = %d\n", TaskSetupParams->SzSrc);
569  printf("TaskSetup: StartAddrDst = 0x%08X\n", TaskSetupParams->StartAddrDst);
570  printf("TaskSetup: IncrDst = %d\n", TaskSetupParams->IncrDst);
571  printf("TaskSetup: SzDst = %d\n", TaskSetupParams->SzDst);
572 #endif
573
574 #if (DEBUG_BESTCOMM_API>=20)
575  printf("\nTaskSetup: Task-API Parameter Settings After TaskSetup Initialization:\n");
576  printf("TaskSetup: TaskNum = %d\n", ((TaskAPI->TaskNum)));
577  printf("TaskSetup: TaskPragma = 0x%02X\n", *((TaskAPI->TaskPragma)));
578
579  #if (MAX_BD>0)
580  printf("TaskSetup: BDTableBase = 0x%08X\n", *((TaskAPI->BDTableBase)));
581  printf("TaskSetup: BDTableLast = 0x%08X\n", *((TaskAPI->BDTableLast)));
582  printf("TaskSetup: BDTableStart = 0x%08X\n", *((TaskAPI->BDTableStart)));
583  printf("TaskSetup: AddrEnable = 0x%08X\n", *((TaskAPI->AddrEnable)));
584  #if (INCR_TYPE_SRC==0)
585  printf("TaskSetup: AddrSrcFIFO = 0x%08X\n", *((TaskAPI->AddrSrcFIFO)));
586  #endif
587  #if (INCR_TYPE_DST==0)
588  printf("TaskSetup: AddrDstFIFO = 0x%08X\n", *((TaskAPI->AddrDstFIFO)));
589  #endif
590  #if (BD_FLAG)
591  printf("TaskSetup: AddrDRD = 0x%08X\n", *((TaskAPI->AddrDRD)));
592  printf("TaskSetup: AddrDRDIdx = %d\n", ((TaskAPI->AddrDRDIdx)));
593  #endif
594  #else
595  printf("TaskSetup: IterExtra = %d\n", *((TaskAPI->IterExtra)));
596  #if (INCR_TYPE_SRC==0)
597  printf("TaskSetup: AddrSrcFIFO = 0x%08X\n", *((TaskAPI->AddrSrcFIFO)));
598  #else
599  printf("TaskSetup: StartAddrSrc = 0x%08X\n", *((TaskAPI->StartAddrSrc)));
600  #endif
601  #if (INCR_TYPE_DST==0)
602  printf("TaskSetup: AddrDstFIFO = 0x%08X\n", *((TaskAPI->AddrDstFIFO)));
603  #else
604  printf("TaskSetup: StartAddrDst = 0x%08X\n", *((TaskAPI->StartAddrDst)));
605  #endif
606  #endif
607  #if (INCR_TYPE_SRC!=0)
608  printf("TaskSetup: IncrSrc = 0x%04X\n", *((TaskAPI->IncrSrc)));
609  #if (MISALIGNED | MISALIGNED_START)
610  printf("TaskSetup: IncrSrcMA = 0x%04X\n", *((TaskAPI->IncrSrcMA)));
611  #endif
612  #endif
613  #if (INCR_TYPE_DST!=0)
614  printf("TaskSetup: IncrDst = 0x%04X\n", *((TaskAPI->IncrDst)));
615  #if (MISALIGNED | MISALIGNED_START)
616  printf("TaskSetup: IncrDstMA = 0x%04X\n", *((TaskAPI->IncrDstMA)));
617  #endif
618  #endif
619  printf("TaskSetup: Bytes = %d\n", *((TaskAPI->Bytes)));
620  printf("TaskSetup: IncrBytes = %d\n", *((TaskAPI->IncrBytes)));
621 #endif
622
623  return TaskNum;
624 }
uint32 StartAddrSrc
Definition: bestcomm_api.h:204
sint16 IncrDst
Definition: bestcomm_api.h:208
MPC5200Initiator_t Initiator
Definition: bestcomm_api.h:203
Sz_t SzDst
Definition: bestcomm_api.h:209
uint32 StartAddrDst
Definition: bestcomm_api.h:207
uint32 NumBytes
Definition: bestcomm_api.h:199
uint32 NumBD
Definition: bestcomm_api.h:195
Parameters for TaskSetup()
Definition: bestcomm_api.h:194
union TaskSetupParamSet_t::@187 Size
sint16 IncrSrc
Definition: bestcomm_api.h:205
Definition: sdma.h:28
Sz_t SzSrc
Definition: bestcomm_api.h:206
uint32 MaxBuf
Definition: bestcomm_api.h:198
