RTEMS  5.1
t.h
1 /*
2  * SPDX-License-Identifier: BSD-2-Clause
3  *
4  * Copyright (C) 2018, 2019 embedded brains GmbH
5  *
6  * Redistribution and use in source and binary forms, with or without
7  * modification, are permitted provided that the following conditions
8  * are met:
9  * 1. Redistributions of source code must retain the above copyright
10  * notice, this list of conditions and the following disclaimer.
11  * 2. Redistributions in binary form must reproduce the above copyright
12  * notice, this list of conditions and the following disclaimer in the
13  * documentation and/or other materials provided with the distribution.
14  *
15  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25  * POSSIBILITY OF SUCH DAMAGE.
26  */
27
28 #ifndef THE_T_TEST_FRAMEWORK_H
29 #define THE_T_TEST_FRAMEWORK_H
30
31 #include <stdarg.h>
32 #include <stdbool.h>
33 #include <stddef.h>
34 #include <stdint.h>
35 #include <string.h>
36
37 #ifdef __rtems__
38 #include <rtems/score/cpu.h>
39 #endif
40
41 #ifdef __cplusplus
42 extern "C" {
43 #endif /* __cplusplus */
44
55 typedef enum {
56  T_QUIET,
57  T_NORMAL,
58  T_VERBOSE
59 } T_verbosity;
60
61 typedef struct T_fixture {
62  void (*setup)(void *);
63  void (*stop)(void *);
64  void (*teardown)(void *);
65  void *initial_context;
66 } T_fixture;
67
68 #define T_ARRAY_SIZE(array) (sizeof(array) / sizeof((array)[0]))
69
70 /*
71  * The __FILE__ includes the full file path from the command line. Enable the
72  * build system to give a sorter file name via a command line define.
73  */
74 #ifndef T_FILE_NAME
75 #define T_FILE_NAME __FILE__
76 #endif
77
90 typedef struct T_case_context {
91  const char *name;
92  void (*body)(void);
93  const T_fixture *fixture;
94  const struct T_case_context *next;
96
97 void T_case_register(T_case_context *);
98
99 #define T_CHECK_STOP 1U
100
101 #define T_CHECK_QUIET 2U
102
103 #define T_CHECK_STEP_FLAG 4U
104
105 #define T_CHECK_STEP_TO_FLAGS(step) ((unsigned int)(step) << 8)
106
107 #define T_CHECK_STEP_FROM_FLAGS(flags) ((flags) >> 8)
108
109 #define T_CHECK_STEP(step) (T_CHECK_STEP_TO_FLAGS(step) | T_CHECK_STEP_FLAG)
110
111 typedef struct {
112  const char *file;
113  int line;
114  unsigned int flags;
116
117 typedef struct {
118  T_check_context base;
119  const char *msg;
121
122 void T_check_true(bool, const T_check_context *, const char *, ...);
123
124 #define T_flags_true(a, flags, ...) \
125 { \
126  static const T_check_context T_check_instance = { \
127  T_FILE_NAME, __LINE__, flags }; \
128  T_check_true(a, &T_check_instance, __VA_ARGS__); \
129 }
130
131 #define T_flags_eq(a, e, flags, ...) \
132  T_flags_true((a) == (e), flags, __VA_ARGS__)
133
134 #define T_flags_ne(a, e, flags, ...) \
135  T_flags_true((a) != (e), flags, __VA_ARGS__)
136
137 void T_check_eq_ptr(const void *, const T_check_context_msg *, const void *);
138
139 #define T_flags_eq_ptr(a, e, flags, sa, se) \
140 { \
141  static const T_check_context_msg T_check_instance = { \
142  { T_FILE_NAME, __LINE__, flags }, sa " == " se }; \
143  T_check_eq_ptr(a, &T_check_instance, e); \
144 }
145
146 void T_check_ne_ptr(const void *, const T_check_context_msg *, const void *);
147
148 #define T_flags_ne_ptr(a, e, flags, sa, se) \
149 { \
150  static const T_check_context_msg T_check_instance = { \
151  { T_FILE_NAME, __LINE__, flags }, sa " != " se }; \
152  T_check_ne_ptr(a, &T_check_instance, e); \
153 }
154
155 void T_check_null(const void *, const T_check_context_msg *);
156
157 #define T_flags_null(a, flags, sa) \
158 { \
159  static const T_check_context_msg T_check_instance = { \
160  { T_FILE_NAME, __LINE__, flags }, sa }; \
161  T_check_null(a, &T_check_instance); \
162 }
163
164 void T_check_not_null(const void *, const T_check_context_msg *);
165
166 #define T_flags_not_null(a, flags, sa) \
167 { \
168  static const T_check_context_msg T_check_instance = { \
169  { T_FILE_NAME, __LINE__, flags }, sa }; \
170  T_check_not_null(a, &T_check_instance); \
171 }
172
173 void T_check_eq_mem(const void *, const T_check_context_msg *, const void *,
174  size_t);
175
176 #define T_flags_eq_mem(a, e, n, flags, sa, se, sn) \
177 { \
178  static const T_check_context_msg T_check_instance = { \
179  { T_FILE_NAME, __LINE__, flags }, \
180  "memcmp(" sa ", " se ", " sn ") == 0" }; \
181  T_check_eq_mem(a, &T_check_instance, e, n); \
182 }
183
184 void T_check_ne_mem(const void *, const T_check_context_msg *, const void *,
185  size_t);
186
187 #define T_flags_ne_mem(a, e, n, flags, sa, se, sn) \
188 { \
189  static const T_check_context_msg T_check_instance = { \
190  { T_FILE_NAME, __LINE__, flags }, \
191  "memcmp(" sa ", " se ", " sn ") != 0" }; \
192  T_check_ne_mem(a, &T_check_instance, e, n); \
193 }
194
195 void T_check_eq_str(const char *, const T_check_context *, const char *);
196
197 #define T_flags_eq_str(a, e, flags) \
198 { \
199  static const T_check_context T_check_instance = { \
200  T_FILE_NAME, __LINE__, flags }; \
201  T_check_eq_str(a, &T_check_instance, e); \
202 }
203
204 void T_check_ne_str(const char *, const T_check_context *, const char *);
205
206 #define T_flags_ne_str(a, e, flags) \
207 { \
208  static const T_check_context T_check_instance = { \
209  T_FILE_NAME, __LINE__, flags }; \
210  T_check_ne_str(a, &T_check_instance, e); \
211 }
212
213 void T_check_eq_nstr(const char *, const T_check_context *, const char *,
214  size_t);
215
216 #define T_flags_eq_nstr(a, e, n, flags) \
217 { \
218  static const T_check_context T_check_instance = { \
219  T_FILE_NAME, __LINE__, flags }; \
220  T_check_eq_nstr(a, &T_check_instance, e, n); \
221 }
222
223 void T_check_ne_nstr(const char *, const T_check_context *, const char *,
224  size_t);
225
226 #define T_flags_ne_nstr(a, e, n, flags) \
227 { \
228  static const T_check_context T_check_instance = { \
229  T_FILE_NAME, __LINE__, flags }; \
230  T_check_ne_nstr(a, &T_check_instance, e, n); \
231 }
232
233 void T_check_eq_char(char, const T_check_context *, char);
234
235 #define T_flags_eq_char(a, e, flags) \
236 { \
237  static const T_check_context T_check_instance = { \
238  T_FILE_NAME, __LINE__, flags }; \
239  T_check_eq_char(a, &T_check_instance, e); \
240 }
241
242 void T_check_ne_char(char, const T_check_context *, char);
243
244 #define T_flags_ne_char(a, e, flags) \
245 { \
246  static const T_check_context T_check_instance = { \
247  T_FILE_NAME, __LINE__, flags }; \
248  T_check_ne_char(a, &T_check_instance, e); \
249 }
250
251 void T_check_eq_int(int, const T_check_context *, int);
252
253 #define T_flags_eq_int(a, e, flags) \
254 { \
255  static const T_check_context T_check_instance = { \
256  T_FILE_NAME, __LINE__, flags }; \
257  T_check_eq_int(a, &T_check_instance, e); \
258 }
259
260 void T_check_ne_int(int, const T_check_context *, int);
261
262 #define T_flags_ne_int(a, e, flags) \
263 { \
264  static const T_check_context T_check_instance = { \
265  T_FILE_NAME, __LINE__, flags }; \
266  T_check_ne_int(a, &T_check_instance, e); \
267 }
268
269 void T_check_ge_int(int, const T_check_context *, int);
270
271 #define T_flags_ge_int(a, e, flags) \
272 { \
273  static const T_check_context T_check_instance = { \
274  T_FILE_NAME, __LINE__, flags }; \
275  T_check_ge_int(a, &T_check_instance, e); \
276 }
277
278 void T_check_gt_int(int, const T_check_context *, int);
279
280 #define T_flags_gt_int(a, e, flags) \
281 { \
282  static const T_check_context T_check_instance = { \
283  T_FILE_NAME, __LINE__, flags }; \
284  T_check_gt_int(a, &T_check_instance, e); \
285 }
286
287 void T_check_le_int(int, const T_check_context *, int);
288
289 #define T_flags_le_int(a, e, flags) \
290 { \
291  static const T_check_context T_check_instance = { \
292  T_FILE_NAME, __LINE__, flags }; \
293  T_check_le_int(a, &T_check_instance, e); \
294 }
295
296 void T_check_lt_int(int, const T_check_context *, int);
297
298 #define T_flags_lt_int(a, e, flags) \
299 { \
300  static const T_check_context T_check_instance = { \
301  T_FILE_NAME, __LINE__, flags }; \
302  T_check_lt_int(a, &T_check_instance, e); \
303 }
304
305 void T_check_eq_uint(unsigned int, const T_check_context *, unsigned int);
306
307 #define T_flags_eq_uint(a, e, flags) \
308 { \
309  static const T_check_context T_check_instance = { \
310  T_FILE_NAME, __LINE__, flags }; \
311  T_check_eq_uint(a, &T_check_instance, e); \
312 }
313
314 void T_check_ne_uint(unsigned int, const T_check_context *, unsigned int);
315
316 #define T_flags_ne_uint(a, e, flags) \
317 { \
318  static const T_check_context T_check_instance = { \
319  T_FILE_NAME, __LINE__, flags }; \
320  T_check_ne_uint(a, &T_check_instance, e); \
321 }
322
323 void T_check_ge_uint(unsigned int, const T_check_context *, unsigned int);
324
325 #define T_flags_ge_uint(a, e, flags) \
326 { \
327  static const T_check_context T_check_instance = { \
328  T_FILE_NAME, __LINE__, flags }; \
329  T_check_ge_uint(a, &T_check_instance, e); \
330 }
331
332 void T_check_gt_uint(unsigned int, const T_check_context *, unsigned int);
333
334 #define T_flags_gt_uint(a, e, flags) \
335 { \
336  static const T_check_context T_check_instance = { \
337  T_FILE_NAME, __LINE__, flags }; \
338  T_check_gt_uint(a, &T_check_instance, e); \
339 }
340
341 void T_check_le_uint(unsigned int, const T_check_context *, unsigned int);
342
343 #define T_flags_le_uint(a, e, flags) \
344 { \
345  static const T_check_context T_check_instance = { \
346  T_FILE_NAME, __LINE__, flags }; \
347  T_check_le_uint(a, &T_check_instance, e); \
348 }
349
350 void T_check_lt_uint(unsigned int, const T_check_context *, unsigned int);
351
352 #define T_flags_lt_uint(a, e, flags) \
353 { \
354  static const T_check_context T_check_instance = { \
355  T_FILE_NAME, __LINE__, flags }; \
356  T_check_lt_uint(a, &T_check_instance, e); \
357 }
358
359 void T_check_eq_long(long, const T_check_context *, long);
360
361 #define T_flags_eq_long(a, e, flags) \
362 { \
363  static const T_check_context T_check_instance = { \
364  T_FILE_NAME, __LINE__, flags }; \
365  T_check_eq_long(a, &T_check_instance, e); \
366 }
367
368 void T_check_ne_long(long, const T_check_context *, long);
369
370 #define T_flags_ne_long(a, e, flags) \
371 { \
372  static const T_check_context T_check_instance = { \
373  T_FILE_NAME, __LINE__, flags }; \
374  T_check_ne_long(a, &T_check_instance, e); \
375 }
376
377 void T_check_ge_long(long, const T_check_context *, long);
378
379 #define T_flags_ge_long(a, e, flags) \
380 { \
381  static const T_check_context T_check_instance = { \
382  T_FILE_NAME, __LINE__, flags }; \
383  T_check_ge_long(a, &T_check_instance, e); \
384 }
385
386 void T_check_gt_long(long, const T_check_context *, long);
387
388 #define T_flags_gt_long(a, e, flags) \
389 { \
390  static const T_check_context T_check_instance = { \
391  T_FILE_NAME, __LINE__, flags }; \
392  T_check_gt_long(a, &T_check_instance, e); \
393 }
394
395 void T_check_le_long(long, const T_check_context *, long);
396
397 #define T_flags_le_long(a, e, flags) \
398 { \
399  static const T_check_context T_check_instance = { \
400  T_FILE_NAME, __LINE__, flags }; \
401  T_check_le_long(a, &T_check_instance, e); \
402 }
403
404 void T_check_lt_long(long, const T_check_context *, long);
405
406 #define T_flags_lt_long(a, e, flags) \
407 { \
408  static const T_check_context T_check_instance = { \
409  T_FILE_NAME, __LINE__, flags }; \
410  T_check_lt_long(a, &T_check_instance, e); \
411 }
412
413 void T_check_eq_ulong(unsigned long, const T_check_context *, unsigned long);
414
415 #define T_flags_eq_ulong(a, e, flags) \
416 { \
417  static const T_check_context T_check_instance = { \
418  T_FILE_NAME, __LINE__, flags }; \
419  T_check_eq_ulong(a, &T_check_instance, e); \
420 }
421
422 void T_check_ne_ulong(unsigned long, const T_check_context *, unsigned long);
423
424 #define T_flags_ne_ulong(a, e, flags) \
425 { \
426  static const T_check_context T_check_instance = { \
427  T_FILE_NAME, __LINE__, flags }; \
428  T_check_ne_ulong(a, &T_check_instance, e); \
429 }
430
431 void T_check_ge_ulong(unsigned long, const T_check_context *, unsigned long);
432
433 #define T_flags_ge_ulong(a, e, flags) \
434 { \
435  static const T_check_context T_check_instance = { \
436  T_FILE_NAME, __LINE__, flags }; \
437  T_check_ge_ulong(a, &T_check_instance, e); \
438 }
439
440 void T_check_gt_ulong(unsigned long, const T_check_context *, unsigned long);
441
442 #define T_flags_gt_ulong(a, e, flags) \
443 { \
444  static const T_check_context T_check_instance = { \
445  T_FILE_NAME, __LINE__, flags }; \
446  T_check_gt_ulong(a, &T_check_instance, e); \
447 }
448
449 void T_check_le_ulong(unsigned long, const T_check_context *, unsigned long);
450
451 #define T_flags_le_ulong(a, e, flags) \
452 { \
453  static const T_check_context T_check_instance = { \
454  T_FILE_NAME, __LINE__, flags }; \
455  T_check_le_ulong(a, &T_check_instance, e); \
456 }
457
458 void T_check_lt_ulong(unsigned long, const T_check_context *, unsigned long);
459
460 #define T_flags_lt_ulong(a, e, flags) \
461 { \
462  static const T_check_context T_check_instance = { \
463  T_FILE_NAME, __LINE__, flags }; \
464  T_check_lt_ulong(a, &T_check_instance, e); \
465 }
466
467 void T_check_eq_ll(long long, const T_check_context *, long long);
468
469 #define T_flags_eq_ll(a, e, flags) \
470 { \
471  static const T_check_context T_check_instance = { \
472  T_FILE_NAME, __LINE__, flags }; \
473  T_check_eq_ll(a, &T_check_instance, e); \
474 }
475
476 void T_check_ne_ll(long long, const T_check_context *, long long);
477
478 #define T_flags_ne_ll(a, e, flags) \
479 { \
480  static const T_check_context T_check_instance = { \
481  T_FILE_NAME, __LINE__, flags }; \
482  T_check_ne_ll(a, &T_check_instance, e); \
483 }
484
485 void T_check_ge_ll(long long, const T_check_context *, long long);
486
487 #define T_flags_ge_ll(a, e, flags) \
488 { \
489  static const T_check_context T_check_instance = { \
490  T_FILE_NAME, __LINE__, flags }; \
491  T_check_ge_ll(a, &T_check_instance, e); \
492 }
493
494 void T_check_gt_ll(long long, const T_check_context *, long long);
495
496 #define T_flags_gt_ll(a, e, flags) \
497 { \
498  static const T_check_context T_check_instance = { \
499  T_FILE_NAME, __LINE__, flags }; \
500  T_check_gt_ll(a, &T_check_instance, e); \
501 }
502
503 void T_check_le_ll(long long, const T_check_context *, long long);
504
505 #define T_flags_le_ll(a, e, flags) \
506 { \
507  static const T_check_context T_check_instance = { \
508  T_FILE_NAME, __LINE__, flags }; \
509  T_check_le_ll(a, &T_check_instance, e); \
510 }
511
512 void T_check_lt_ll(long long, const T_check_context *, long long);
513
514 #define T_flags_lt_ll(a, e, flags) \
515 { \
516  static const T_check_context T_check_instance = { \
517  T_FILE_NAME, __LINE__, flags }; \
518  T_check_lt_ll(a, &T_check_instance, e); \
519 }
520
521 void T_check_eq_ull(unsigned long long, const T_check_context *,
522  unsigned long long);
523
524 #define T_flags_eq_ull(a, e, flags) \
525 { \
526  static const T_check_context T_check_instance = { \
527  T_FILE_NAME, __LINE__, flags }; \
528  T_check_eq_ull(a, &T_check_instance, e); \
529 }
530
531 void T_check_ne_ull(unsigned long long, const T_check_context *,
532  unsigned long long);
533
534 #define T_flags_ne_ull(a, e, flags) \
535 { \
536  static const T_check_context T_check_instance = { \
537  T_FILE_NAME, __LINE__, flags }; \
538  T_check_ne_ull(a, &T_check_instance, e); \
539 }
540
541 void T_check_ge_ull(unsigned long long, const T_check_context *,
542  unsigned long long);
543
544 #define T_flags_ge_ull(a, e, flags) \
545 { \
546  static const T_check_context T_check_instance = { \
547  T_FILE_NAME, __LINE__, flags }; \
548  T_check_ge_ull(a, &T_check_instance, e); \
549 }
550
551 void T_check_gt_ull(unsigned long long, const T_check_context *,
552  unsigned long long);
553
554 #define T_flags_gt_ull(a, e, flags) \
555 { \
556  static const T_check_context T_check_instance = { \
557  T_FILE_NAME, __LINE__, flags }; \
558  T_check_gt_ull(a, &T_check_instance, e); \
559 }
560
561 void T_check_le_ull(unsigned long long, const T_check_context *,
562  unsigned long long);
563
564 #define T_flags_le_ull(a, e, flags) \
565 { \
566  static const T_check_context T_check_instance = { \
567  T_FILE_NAME, __LINE__, flags }; \
568  T_check_le_ull(a, &T_check_instance, e); \
569 }
570
571 void T_check_lt_ull(unsigned long long, const T_check_context *,
572  unsigned long long);
573
574 #define T_flags_lt_ull(a, e, flags) \
575 { \
576  static const T_check_context T_check_instance = { \
577  T_FILE_NAME, __LINE__, flags }; \
578  T_check_lt_ull(a, &T_check_instance, e); \
579 }
580
581 void T_check_eno(int, const T_check_context *, int);
582
583 #define T_flags_eno(a, e, flags) \
584 { \
585  static const T_check_context T_check_instance = { \
586  T_FILE_NAME, __LINE__, flags }; \
587  T_check_eno(a, &T_check_instance, e); \
588 }
589
590 void T_check_eno_success(int, const T_check_context *);
591
592 #define T_flags_eno_success(a, flags) \
593 { \
594  static const T_check_context T_check_instance = { \
595  T_FILE_NAME, __LINE__, flags }; \
596  T_check_eno_success(a, &T_check_instance); \
597 }
598
599 void T_check_psx_error(int, const T_check_context *, int);
600
601 #define T_flags_psx_error(a, eno, flags) \
602 { \
603  static const T_check_context T_check_instance = { \
604  T_FILE_NAME, __LINE__, flags }; \
605  T_check_psx_error(a, &T_check_instance, eno); \
606 }
607
608 void T_check_psx_success(int, const T_check_context *);
609
610 #define T_flags_psx_success(a, flags) \
611 { \
612  static const T_check_context T_check_instance = { \
613  T_FILE_NAME, __LINE__, flags }; \
614  T_check_psx_success(a, &T_check_instance); \
615 }
616
619 int T_printf(char const *, ...);
620
621 int T_vprintf(char const *, va_list);
622
623 int T_snprintf(char *, size_t, const char *, ...);
624
625 void T_log(T_verbosity, char const *, ...);
626
627 const char *T_case_name(void);
628
629 T_verbosity T_set_verbosity(T_verbosity);
630
641 #define T_true(a, ...) T_flags_true(a, 0, __VA_ARGS__)
642 #define T_assert_true(a, ...) T_flags_true(a, T_CHECK_STOP, __VA_ARGS__)
643 #define T_quiet_true(a, ...) T_flags_true(a, T_CHECK_QUIET, __VA_ARGS__)
644 #define T_step_true(s, a, ...) T_flags_true(a, T_CHECK_STEP(s), __VA_ARGS__)
645 #define T_step_assert_true(s, a, ...) \
646  T_flags_true(a, T_CHECK_STEP(s) | T_CHECK_STOP, __VA_ARGS__)
647
648 #define T_false(a, ...) T_flags_true(!(a), 0, __VA_ARGS__)
649 #define T_assert_false(a, ...) T_flags_true(!(a), T_CHECK_STOP, __VA_ARGS__)
650 #define T_quiet_false(a, ...) T_flags_true(!(a), T_CHECK_QUIET, __VA_ARGS__)
651 #define T_step_false(s, a, ...) T_flags_true(!(a), T_CHECK_STEP(s), __VA_ARGS__)
652 #define T_step_assert_false(s, a, ...) \
653  T_flags_true(!(a), T_CHECK_STEP(s) | T_CHECK_STOP, __VA_ARGS__)
654
667 #define T_eq(a, e, ...) T_flags_eq(a, e, 0, __VA_ARGS__)
668 #define T_assert_eq(a, e, ...) T_flags_eq(a, e, T_CHECK_STOP, __VA_ARGS__)
669 #define T_quiet_eq(a, e, ...) T_flags_eq(a, e, T_CHECK_QUIET, __VA_ARGS__)
670 #define T_step_eq(s, a, e, ...) T_flags_eq(a, e, T_CHECK_STEP(s), __VA_ARGS__)
671 #define T_step_assert_eq(s, a, e, ...) \
672  T_flags_eq(a, e, T_CHECK_STEP(s) | T_CHECK_STOP, __VA_ARGS__)
673
674 #define T_ne(a, e, ...) T_flags_ne(a, e, 0, __VA_ARGS__)
675 #define T_assert_ne(a, e, ...) T_flags_ne(a, e, T_CHECK_STOP, __VA_ARGS__)
676 #define T_quiet_ne(a, e, ...) T_flags_ne(a, e, T_CHECK_QUIET, __VA_ARGS__)
677 #define T_step_ne(s, a, e, ...) T_flags_ne(a, e, T_CHECK_STEP(s), __VA_ARGS__)
678 #define T_step_assert_ne(s, a, e, ...) \
679  T_flags_ne(a, e, T_CHECK_STEP(s) | T_CHECK_STOP, __VA_ARGS__)
680
693 #define T_eq_ptr(a, e) T_flags_eq_ptr(a, e, 0, #a, #e)
694 #define T_assert_eq_ptr(a, e) T_flags_eq_ptr(a, e, T_CHECK_STOP, #a, #e)
695 #define T_quiet_eq_ptr(a, e) T_flags_eq_ptr(a, e, T_CHECK_QUIET, #a, #e)
696 #define T_step_eq_ptr(s, a, e) T_flags_eq_ptr(a, e, T_CHECK_STEP(s), #a, #e)
697 #define T_step_assert_eq_ptr(s, a, e) \
698  T_flags_eq_ptr(a, e, T_CHECK_STEP(s) | T_CHECK_STOP, #a, #e)
699
700 #define T_ne_ptr(a, e) T_flags_ne_ptr(a, e, 0, #a, #e)
701 #define T_assert_ne_ptr(a, e) T_flags_ne_ptr(a, e, T_CHECK_STOP, #a, #e)
702 #define T_quiet_ne_ptr(a, e) T_flags_ne_ptr(a, e, T_CHECK_QUIET, #a, #e)
703 #define T_step_ne_ptr(s, a, e) T_flags_ne_ptr(a, e, T_CHECK_STEP(s), #a, #e)
704 #define T_step_assert_ne_ptr(s, a, e) \
705  T_flags_ne_ptr(a, e, T_CHECK_STEP(s) | T_CHECK_STOP, #a, #e)
706
707 #define T_null(a) T_flags_null(a, 0, #a)
708 #define T_assert_null(a) T_flags_null(a, T_CHECK_STOP, #a)
709 #define T_quiet_null(a) T_flags_null(a, T_CHECK_QUIET, #a)
710 #define T_step_null(s, a) T_flags_null(a, T_CHECK_STEP(s), #a)
711 #define T_step_assert_null(s, a) \
712  T_flags_null(a, T_CHECK_STEP(s) | T_CHECK_STOP, #a)
713
714 #define T_not_null(a) T_flags_not_null(a, 0, #a)
715 #define T_assert_not_null(a) T_flags_not_null(a, T_CHECK_STOP, #a)
716 #define T_quiet_not_null(a) T_flags_not_null(a, T_CHECK_QUIET, #a)
717 #define T_step_not_null(s, a) T_flags_not_null(a, T_CHECK_STEP(s), #a)
718 #define T_step_assert_not_null(s, a) \
719  T_flags_not_null(a, T_CHECK_STEP(s) | T_CHECK_STOP, #a)
720
733 #define T_eq_mem(a, e, n) T_flags_eq_mem(a, e, n, 0, #a, #e, #n)
734 #define T_assert_eq_mem(a, e, n) \
735  T_flags_eq_mem(a, e, n, T_CHECK_STOP, #a, #e, #n)
736 #define T_quiet_eq_mem(a, e, n) \
737  T_flags_eq_mem(a, e, n, T_CHECK_QUIET, #a, #e, #n)
738 #define T_step_eq_mem(s, a, e, n) \
739  T_flags_eq_mem(a, e, n, T_CHECK_STEP(s), #a, #e, #n)
740 #define T_step_assert_eq_mem(s, a, e, n) \
741  T_flags_eq_mem(a, e, n, T_CHECK_STEP(s) | T_CHECK_STOP, #a, #e, #n)
742
743 #define T_ne_mem(a, e, n) T_flags_ne_mem(a, e, n, 0, #a, #e, #n)
744 #define T_assert_ne_mem(a, e, n) \
745  T_flags_ne_mem(a, e, n, T_CHECK_STOP, #a, #e, #n)
746 #define T_quiet_ne_mem(a, e, n) \
747  T_flags_ne_mem(a, e, n, T_CHECK_QUIET, #a, #e, #n)
748 #define T_step_ne_mem(s, a, e, n) \
749  T_flags_ne_mem(a, e, n, T_CHECK_STEP(s), #a, #e, #n)
750 #define T_step_assert_ne_mem(s, a, e, n) \
751  T_flags_ne_mem(a, e, n, T_CHECK_STEP(s) | T_CHECK_STOP, #a, #e, #n)
752
766 #define T_eq_str(a, e) T_flags_eq_str(a, e, 0)
767 #define T_assert_eq_str(a, e) T_flags_eq_str(a, e, T_CHECK_STOP)
768 #define T_quiet_eq_str(a, e) T_flags_eq_str(a, e, T_CHECK_QUIET)
769 #define T_step_eq_str(s, a, e) T_flags_eq_str(a, e, T_CHECK_STEP(s))
770 #define T_step_assert_eq_str(s, a, e) \
771  T_flags_eq_str(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
772
773 #define T_ne_str(a, e) T_flags_ne_str(a, e, 0)
774 #define T_assert_ne_str(a, e) T_flags_ne_str(a, e, T_CHECK_STOP)
775 #define T_quiet_ne_str(a, e) T_flags_ne_str(a, e, T_CHECK_QUIET)
776 #define T_step_ne_str(s, a, e) T_flags_ne_str(a, e, T_CHECK_STEP(s))
777 #define T_step_assert_ne_str(s, a, e) \
778  T_flags_ne_str(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
779
780 #define T_eq_nstr(a, e, n) T_flags_eq_nstr(a, e, n, 0)
781 #define T_assert_eq_nstr(a, e, n) T_flags_eq_nstr(a, e, n, T_CHECK_STOP)
782 #define T_quiet_eq_nstr(a, e, n) T_flags_eq_nstr(a, e, n, T_CHECK_QUIET)
783 #define T_step_eq_nstr(s, a, e, n) T_flags_eq_nstr(a, e, n, T_CHECK_STEP(s))
784 #define T_step_assert_eq_nstr(s, a, e, n) \
785  T_flags_eq_nstr(a, e, n, T_CHECK_STEP(s) | T_CHECK_STOP)
786
787 #define T_ne_nstr(a, e, n) T_flags_ne_nstr(a, e, n, 0)
788 #define T_assert_ne_nstr(a, e, n) T_flags_ne_nstr(a, e, n, T_CHECK_STOP)
789 #define T_quiet_ne_nstr(a, e, n) T_flags_ne_nstr(a, e, n, T_CHECK_QUIET)
790 #define T_step_ne_nstr(s, a, e, n) T_flags_ne_nstr(a, e, n, T_CHECK_STEP(s))
791 #define T_step_assert_ne_nstr(s, a, e, n) \
792  T_flags_ne_nstr(a, e, n, T_CHECK_STEP(s) | T_CHECK_STOP)
793
806 #define T_eq_char(a, e) T_flags_eq_char(a, e, 0)
807 #define T_assert_eq_char(a, e) T_flags_eq_char(a, e, T_CHECK_STOP)
808 #define T_quiet_eq_char(a, e) T_flags_eq_char(a, e, T_CHECK_QUIET)
809 #define T_step_eq_char(s, a, e) T_flags_eq_char(a, e, T_CHECK_STEP(s))
810 #define T_step_assert_eq_char(s, a, e) \
811  T_flags_eq_char(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
812
813 #define T_ne_char(a, e) T_flags_ne_char(a, e, 0)
814 #define T_assert_ne_char(a, e) T_flags_ne_char(a, e, T_CHECK_STOP)
815 #define T_quiet_ne_char(a, e) T_flags_ne_char(a, e, T_CHECK_QUIET)
816 #define T_step_ne_char(s, a, e) T_flags_ne_char(a, e, T_CHECK_STEP(s))
817 #define T_step_assert_ne_char(s, a, e) \
818  T_flags_ne_char(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
819
832 #define T_eq_schar(a, e) T_flags_eq_int(a, e, 0)
833 #define T_assert_eq_schar(a, e) T_flags_eq_int(a, e, T_CHECK_STOP)
834 #define T_quiet_eq_schar(a, e) T_flags_eq_int(a, e, T_CHECK_QUIET)
835 #define T_step_eq_schar(s, a, e) T_flags_eq_int(a, e, T_CHECK_STEP(s))
836 #define T_step_assert_eq_schar(s, a, e) \
837  T_flags_eq_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
838
839 #define T_ne_schar(a, e) T_flags_ne_int(a, e, 0)
840 #define T_assert_ne_schar(a, e) T_flags_ne_int(a, e, T_CHECK_STOP)
841 #define T_quiet_ne_schar(a, e) T_flags_ne_int(a, e, T_CHECK_QUIET)
842 #define T_step_ne_schar(s, a, e) T_flags_ne_int(a, e, T_CHECK_STEP(s))
843 #define T_step_assert_ne_schar(s, a, e) \
844  T_flags_ne_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
845
846 #define T_ge_schar(a, e) T_flags_ge_int(a, e, 0)
847 #define T_assert_ge_schar(a, e) T_flags_ge_int(a, e, T_CHECK_STOP)
848 #define T_quiet_ge_schar(a, e) T_flags_ge_int(a, e, T_CHECK_QUIET)
849 #define T_step_ge_schar(s, a, e) T_flags_ge_int(a, e, T_CHECK_STEP(s))
850 #define T_step_assert_ge_schar(s, a, e) \
851  T_flags_ge_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
852
853 #define T_gt_schar(a, e) T_flags_gt_int(a, e, 0)
854 #define T_assert_gt_schar(a, e) T_flags_gt_int(a, e, T_CHECK_STOP)
855 #define T_quiet_gt_schar(a, e) T_flags_gt_int(a, e, T_CHECK_QUIET)
856 #define T_step_gt_schar(s, a, e) T_flags_gt_int(a, e, T_CHECK_STEP(s))
857 #define T_step_assert_gt_schar(s, a, e) \
858  T_flags_gt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
859
860 #define T_le_schar(a, e) T_flags_le_int(a, e, 0)
861 #define T_assert_le_schar(a, e) T_flags_le_int(a, e, T_CHECK_STOP)
862 #define T_quiet_le_schar(a, e) T_flags_le_int(a, e, T_CHECK_QUIET)
863 #define T_step_le_schar(s, a, e) T_flags_le_int(a, e, T_CHECK_STEP(s))
864 #define T_step_assert_le_schar(s, a, e) \
865  T_flags_le_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
866
867 #define T_lt_schar(a, e) T_flags_lt_int(a, e, 0)
868 #define T_assert_lt_schar(a, e) T_flags_lt_int(a, e, T_CHECK_STOP)
869 #define T_quiet_lt_schar(a, e) T_flags_lt_int(a, e, T_CHECK_QUIET)
870 #define T_step_lt_schar(s, a, e) T_flags_lt_int(a, e, T_CHECK_STEP(s))
871 #define T_step_assert_lt_schar(s, a, e) \
872  T_flags_lt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
873
886 #define T_eq_uchar(a, e) T_flags_eq_uint(a, e, 0)
887 #define T_assert_eq_uchar(a, e) T_flags_eq_uint(a, e, T_CHECK_STOP)
888 #define T_quiet_eq_uchar(a, e) T_flags_eq_uint(a, e, T_CHECK_QUIET)
889 #define T_step_eq_uchar(s, a, e) T_flags_eq_uint(a, e, T_CHECK_STEP(s))
890 #define T_step_assert_eq_uchar(s, a, e) \
891  T_flags_eq_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
892
893 #define T_ne_uchar(a, e) T_flags_ne_uint(a, e, 0)
894 #define T_assert_ne_uchar(a, e) T_flags_ne_uint(a, e, T_CHECK_STOP)
895 #define T_quiet_ne_uchar(a, e) T_flags_ne_uint(a, e, T_CHECK_QUIET)
896 #define T_step_ne_uchar(s, a, e) T_flags_ne_uint(a, e, T_CHECK_STEP(s))
897 #define T_step_assert_ne_uchar(s, a, e) \
898  T_flags_ne_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
899
900 #define T_ge_uchar(a, e) T_flags_ge_uint(a, e, 0)
901 #define T_assert_ge_uchar(a, e) T_flags_ge_uint(a, e, T_CHECK_STOP)
902 #define T_quiet_ge_uchar(a, e) T_flags_ge_uint(a, e, T_CHECK_QUIET)
903 #define T_step_ge_uchar(s, a, e) T_flags_ge_uint(a, e, T_CHECK_STEP(s))
904 #define T_step_assert_ge_uchar(s, a, e) \
905  T_flags_ge_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
906
907 #define T_gt_uchar(a, e) T_flags_gt_uint(a, e, 0)
908 #define T_assert_gt_uchar(a, e) T_flags_gt_uint(a, e, T_CHECK_STOP)
909 #define T_quiet_gt_uchar(a, e) T_flags_gt_uint(a, e, T_CHECK_QUIET)
910 #define T_step_gt_uchar(s, a, e) T_flags_gt_uint(a, e, T_CHECK_STEP(s))
911 #define T_step_assert_gt_uchar(s, a, e) \
912  T_flags_gt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
913
914 #define T_le_uchar(a, e) T_flags_le_uint(a, e, 0)
915 #define T_assert_le_uchar(a, e) T_flags_le_uint(a, e, T_CHECK_STOP)
916 #define T_quiet_le_uchar(a, e) T_flags_le_uint(a, e, T_CHECK_QUIET)
917 #define T_step_le_uchar(s, a, e) T_flags_le_uint(a, e, T_CHECK_STEP(s))
918 #define T_step_assert_le_uchar(s, a, e) \
919  T_flags_le_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
920
921 #define T_lt_uchar(a, e) T_flags_lt_uint(a, e, 0)
922 #define T_assert_lt_uchar(a, e) T_flags_lt_uint(a, e, T_CHECK_STOP)
923 #define T_quiet_lt_uchar(a, e) T_flags_lt_uint(a, e, T_CHECK_QUIET)
924 #define T_step_lt_uchar(s, a, e) T_flags_lt_uint(a, e, T_CHECK_STEP(s))
925 #define T_step_assert_lt_uchar(s, a, e) \
926  T_flags_lt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
927
940 #define T_eq_short(a, e) T_flags_eq_int(a, e, 0)
941 #define T_assert_eq_short(a, e) T_flags_eq_int(a, e, T_CHECK_STOP)
942 #define T_quiet_eq_short(a, e) T_flags_eq_int(a, e, T_CHECK_QUIET)
943 #define T_step_eq_short(s, a, e) T_flags_eq_int(a, e, T_CHECK_STEP(s))
944 #define T_step_assert_eq_short(s, a, e) \
945  T_flags_eq_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
946
947 #define T_ne_short(a, e) T_flags_ne_int(a, e, 0)
948 #define T_assert_ne_short(a, e) T_flags_ne_int(a, e, T_CHECK_STOP)
949 #define T_quiet_ne_short(a, e) T_flags_ne_int(a, e, T_CHECK_QUIET)
950 #define T_step_ne_short(s, a, e) T_flags_ne_int(a, e, T_CHECK_STEP(s))
951 #define T_step_assert_ne_short(s, a, e) \
952  T_flags_ne_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
953
954 #define T_ge_short(a, e) T_flags_ge_int(a, e, 0)
955 #define T_assert_ge_short(a, e) T_flags_ge_int(a, e, T_CHECK_STOP)
956 #define T_quiet_ge_short(a, e) T_flags_ge_int(a, e, T_CHECK_QUIET)
957 #define T_step_ge_short(s, a, e) T_flags_ge_int(a, e, T_CHECK_STEP(s))
958 #define T_step_assert_ge_short(s, a, e) \
959  T_flags_ge_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
960
961 #define T_gt_short(a, e) T_flags_gt_int(a, e, 0)
962 #define T_assert_gt_short(a, e) T_flags_gt_int(a, e, T_CHECK_STOP)
963 #define T_quiet_gt_short(a, e) T_flags_gt_int(a, e, T_CHECK_QUIET)
964 #define T_step_gt_short(s, a, e) T_flags_gt_int(a, e, T_CHECK_STEP(s))
965 #define T_step_assert_gt_short(s, a, e) \
966  T_flags_gt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
967
968 #define T_le_short(a, e) T_flags_le_int(a, e, 0)
969 #define T_assert_le_short(a, e) T_flags_le_int(a, e, T_CHECK_STOP)
970 #define T_quiet_le_short(a, e) T_flags_le_int(a, e, T_CHECK_QUIET)
971 #define T_step_le_short(s, a, e) T_flags_le_int(a, e, T_CHECK_STEP(s))
972 #define T_step_assert_le_short(s, a, e) \
973  T_flags_le_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
974
975 #define T_lt_short(a, e) T_flags_lt_int(a, e, 0)
976 #define T_assert_lt_short(a, e) T_flags_lt_int(a, e, T_CHECK_STOP)
977 #define T_quiet_lt_short(a, e) T_flags_lt_int(a, e, T_CHECK_QUIET)
978 #define T_step_lt_short(s, a, e) T_flags_lt_int(a, e, T_CHECK_STEP(s))
979 #define T_step_assert_lt_short(s, a, e) \
980  T_flags_lt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
981
994 #define T_eq_ushort(a, e) T_flags_eq_uint(a, e, 0)
995 #define T_assert_eq_ushort(a, e) T_flags_eq_uint(a, e, T_CHECK_STOP)
996 #define T_quiet_eq_ushort(a, e) T_flags_eq_uint(a, e, T_CHECK_QUIET)
997 #define T_step_eq_ushort(s, a, e) T_flags_eq_uint(a, e, T_CHECK_STEP(s))
998 #define T_step_assert_eq_ushort(s, a, e) \
999  T_flags_eq_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1000
1001 #define T_ne_ushort(a, e) T_flags_ne_uint(a, e, 0)
1002 #define T_assert_ne_ushort(a, e) T_flags_ne_uint(a, e, T_CHECK_STOP)
1003 #define T_quiet_ne_ushort(a, e) T_flags_ne_uint(a, e, T_CHECK_QUIET)
1004 #define T_step_ne_ushort(s, a, e) T_flags_ne_uint(a, e, T_CHECK_STEP(s))
1005 #define T_step_assert_ne_ushort(s, a, e) \
1006  T_flags_ne_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1007
1008 #define T_ge_ushort(a, e) T_flags_ge_uint(a, e, 0)
1009 #define T_assert_ge_ushort(a, e) T_flags_ge_uint(a, e, T_CHECK_STOP)
1010 #define T_quiet_ge_ushort(a, e) T_flags_ge_uint(a, e, T_CHECK_QUIET)
1011 #define T_step_ge_ushort(s, a, e) T_flags_ge_uint(a, e, T_CHECK_STEP(s))
1012 #define T_step_assert_ge_ushort(s, a, e) \
1013  T_flags_ge_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1014
1015 #define T_gt_ushort(a, e) T_flags_gt_uint(a, e, 0)
1016 #define T_assert_gt_ushort(a, e) T_flags_gt_uint(a, e, T_CHECK_STOP)
1017 #define T_quiet_gt_ushort(a, e) T_flags_gt_uint(a, e, T_CHECK_QUIET)
1018 #define T_step_gt_ushort(s, a, e) T_flags_gt_uint(a, e, T_CHECK_STEP(s))
1019 #define T_step_assert_gt_ushort(s, a, e) \
1020  T_flags_gt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1021
1022 #define T_le_ushort(a, e) T_flags_le_uint(a, e, 0)
1023 #define T_assert_le_ushort(a, e) T_flags_le_uint(a, e, T_CHECK_STOP)
1024 #define T_quiet_le_ushort(a, e) T_flags_le_uint(a, e, T_CHECK_QUIET)
1025 #define T_step_le_ushort(s, a, e) T_flags_le_uint(a, e, T_CHECK_STEP(s))
1026 #define T_step_assert_le_ushort(s, a, e) \
1027  T_flags_le_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1028
1029 #define T_lt_ushort(a, e) T_flags_lt_uint(a, e, 0)
1030 #define T_assert_lt_ushort(a, e) T_flags_lt_uint(a, e, T_CHECK_STOP)
1031 #define T_quiet_lt_ushort(a, e) T_flags_lt_uint(a, e, T_CHECK_QUIET)
1032 #define T_step_lt_ushort(s, a, e) T_flags_lt_uint(a, e, T_CHECK_STEP(s))
1033 #define T_step_assert_lt_ushort(s, a, e) \
1034  T_flags_lt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1035
1048 #define T_eq_int(a, e) T_flags_eq_int(a, e, 0)
1049 #define T_assert_eq_int(a, e) T_flags_eq_int(a, e, T_CHECK_STOP)
1050 #define T_quiet_eq_int(a, e) T_flags_eq_int(a, e, T_CHECK_QUIET)
1051 #define T_step_eq_int(s, a, e) T_flags_eq_int(a, e, T_CHECK_STEP(s))
1052 #define T_step_assert_eq_int(s, a, e) \
1053  T_flags_eq_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1054
1055 #define T_ne_int(a, e) T_flags_ne_int(a, e, 0)
1056 #define T_assert_ne_int(a, e) T_flags_ne_int(a, e, T_CHECK_STOP)
1057 #define T_quiet_ne_int(a, e) T_flags_ne_int(a, e, T_CHECK_QUIET)
1058 #define T_step_ne_int(s, a, e) T_flags_ne_int(a, e, T_CHECK_STEP(s))
1059 #define T_step_assert_ne_int(s, a, e) \
1060  T_flags_ne_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1061
1062 #define T_ge_int(a, e) T_flags_ge_int(a, e, 0)
1063 #define T_assert_ge_int(a, e) T_flags_ge_int(a, e, T_CHECK_STOP)
1064 #define T_quiet_ge_int(a, e) T_flags_ge_int(a, e, T_CHECK_QUIET)
1065 #define T_step_ge_int(s, a, e) T_flags_ge_int(a, e, T_CHECK_STEP(s))
1066 #define T_step_assert_ge_int(s, a, e) \
1067  T_flags_ge_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1068
1069 #define T_gt_int(a, e) T_flags_gt_int(a, e, 0)
1070 #define T_assert_gt_int(a, e) T_flags_gt_int(a, e, T_CHECK_STOP)
1071 #define T_quiet_gt_int(a, e) T_flags_gt_int(a, e, T_CHECK_QUIET)
1072 #define T_step_gt_int(s, a, e) T_flags_gt_int(a, e, T_CHECK_STEP(s))
1073 #define T_step_assert_gt_int(s, a, e) \
1074  T_flags_gt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1075
1076 #define T_le_int(a, e) T_flags_le_int(a, e, 0)
1077 #define T_assert_le_int(a, e) T_flags_le_int(a, e, T_CHECK_STOP)
1078 #define T_quiet_le_int(a, e) T_flags_le_int(a, e, T_CHECK_QUIET)
1079 #define T_step_le_int(s, a, e) T_flags_le_int(a, e, T_CHECK_STEP(s))
1080 #define T_step_assert_le_int(s, a, e) \
1081  T_flags_le_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1082
1083 #define T_lt_int(a, e) T_flags_lt_int(a, e, 0)
1084 #define T_assert_lt_int(a, e) T_flags_lt_int(a, e, T_CHECK_STOP)
1085 #define T_quiet_lt_int(a, e) T_flags_lt_int(a, e, T_CHECK_QUIET)
1086 #define T_step_lt_int(s, a, e) T_flags_lt_int(a, e, T_CHECK_STEP(s))
1087 #define T_step_assert_lt_int(s, a, e) \
1088  T_flags_lt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1089
1102 #define T_eq_uint(a, e) T_flags_eq_uint(a, e, 0)
1103 #define T_assert_eq_uint(a, e) T_flags_eq_uint(a, e, T_CHECK_STOP)
1104 #define T_quiet_eq_uint(a, e) T_flags_eq_uint(a, e, T_CHECK_QUIET)
1105 #define T_step_eq_uint(s, a, e) T_flags_eq_uint(a, e, T_CHECK_STEP(s))
1106 #define T_step_assert_eq_uint(s, a, e) \
1107  T_flags_eq_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1108
1109 #define T_ne_uint(a, e) T_flags_ne_uint(a, e, 0)
1110 #define T_assert_ne_uint(a, e) T_flags_ne_uint(a, e, T_CHECK_STOP)
1111 #define T_quiet_ne_uint(a, e) T_flags_ne_uint(a, e, T_CHECK_QUIET)
1112 #define T_step_ne_uint(s, a, e) T_flags_ne_uint(a, e, T_CHECK_STEP(s))
1113 #define T_step_assert_ne_uint(s, a, e) \
1114  T_flags_ne_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1115
1116 #define T_ge_uint(a, e) T_flags_ge_uint(a, e, 0)
1117 #define T_assert_ge_uint(a, e) T_flags_ge_uint(a, e, T_CHECK_STOP)
1118 #define T_quiet_ge_uint(a, e) T_flags_ge_uint(a, e, T_CHECK_QUIET)
1119 #define T_step_ge_uint(s, a, e) T_flags_ge_uint(a, e, T_CHECK_STEP(s))
1120 #define T_step_assert_ge_uint(s, a, e) \
1121  T_flags_ge_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1122
1123 #define T_gt_uint(a, e) T_flags_gt_uint(a, e, 0)
1124 #define T_assert_gt_uint(a, e) T_flags_gt_uint(a, e, T_CHECK_STOP)
1125 #define T_quiet_gt_uint(a, e) T_flags_gt_uint(a, e, T_CHECK_QUIET)
1126 #define T_step_gt_uint(s, a, e) T_flags_gt_uint(a, e, T_CHECK_STEP(s))
1127 #define T_step_assert_gt_uint(s, a, e) \
1128  T_flags_gt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1129
1130 #define T_le_uint(a, e) T_flags_le_uint(a, e, 0)
1131 #define T_assert_le_uint(a, e) T_flags_le_uint(a, e, T_CHECK_STOP)
1132 #define T_quiet_le_uint(a, e) T_flags_le_uint(a, e, T_CHECK_QUIET)
1133 #define T_step_le_uint(s, a, e) T_flags_le_uint(a, e, T_CHECK_STEP(s))
1134 #define T_step_assert_le_uint(s, a, e) \
1135  T_flags_le_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1136
1137 #define T_lt_uint(a, e) T_flags_lt_uint(a, e, 0)
1138 #define T_assert_lt_uint(a, e) T_flags_lt_uint(a, e, T_CHECK_STOP)
1139 #define T_quiet_lt_uint(a, e) T_flags_lt_uint(a, e, T_CHECK_QUIET)
1140 #define T_step_lt_uint(s, a, e) T_flags_lt_uint(a, e, T_CHECK_STEP(s))
1141 #define T_step_assert_lt_uint(s, a, e) \
1142  T_flags_lt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1143
1156 #define T_eq_long(a, e) T_flags_eq_long(a, e, 0)
1157 #define T_assert_eq_long(a, e) T_flags_eq_long(a, e, T_CHECK_STOP)
1158 #define T_quiet_eq_long(a, e) T_flags_eq_long(a, e, T_CHECK_QUIET)
1159 #define T_step_eq_long(s, a, e) T_flags_eq_long(a, e, T_CHECK_STEP(s))
1160 #define T_step_assert_eq_long(s, a, e) \
1161  T_flags_eq_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1162
1163 #define T_ne_long(a, e) T_flags_ne_long(a, e, 0)
1164 #define T_assert_ne_long(a, e) T_flags_ne_long(a, e, T_CHECK_STOP)
1165 #define T_quiet_ne_long(a, e) T_flags_ne_long(a, e, T_CHECK_QUIET)
1166 #define T_step_ne_long(s, a, e) T_flags_ne_long(a, e, T_CHECK_STEP(s))
1167 #define T_step_assert_ne_long(s, a, e) \
1168  T_flags_ne_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1169
1170 #define T_ge_long(a, e) T_flags_ge_long(a, e, 0)
1171 #define T_assert_ge_long(a, e) T_flags_ge_long(a, e, T_CHECK_STOP)
1172 #define T_quiet_ge_long(a, e) T_flags_ge_long(a, e, T_CHECK_QUIET)
1173 #define T_step_ge_long(s, a, e) T_flags_ge_long(a, e, T_CHECK_STEP(s))
1174 #define T_step_assert_ge_long(s, a, e) \
1175  T_flags_ge_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1176
1177 #define T_gt_long(a, e) T_flags_gt_long(a, e, 0)
1178 #define T_assert_gt_long(a, e) T_flags_gt_long(a, e, T_CHECK_STOP)
1179 #define T_quiet_gt_long(a, e) T_flags_gt_long(a, e, T_CHECK_QUIET)
1180 #define T_step_gt_long(s, a, e) T_flags_gt_long(a, e, T_CHECK_STEP(s))
1181 #define T_step_assert_gt_long(s, a, e) \
1182  T_flags_gt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1183
1184 #define T_le_long(a, e) T_flags_le_long(a, e, 0)
1185 #define T_assert_le_long(a, e) T_flags_le_long(a, e, T_CHECK_STOP)
1186 #define T_quiet_le_long(a, e) T_flags_le_long(a, e, T_CHECK_QUIET)
1187 #define T_step_le_long(s, a, e) T_flags_le_long(a, e, T_CHECK_STEP(s))
1188 #define T_step_assert_le_long(s, a, e) \
1189  T_flags_le_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1190
1191 #define T_lt_long(a, e) T_flags_lt_long(a, e, 0)
1192 #define T_assert_lt_long(a, e) T_flags_lt_long(a, e, T_CHECK_STOP)
1193 #define T_quiet_lt_long(a, e) T_flags_lt_long(a, e, T_CHECK_QUIET)
1194 #define T_step_lt_long(s, a, e) T_flags_lt_long(a, e, T_CHECK_STEP(s))
1195 #define T_step_assert_lt_long(s, a, e) \
1196  T_flags_lt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1197
1210 #define T_eq_ulong(a, e) T_flags_eq_ulong(a, e, 0)
1211 #define T_assert_eq_ulong(a, e) T_flags_eq_ulong(a, e, T_CHECK_STOP)
1212 #define T_quiet_eq_ulong(a, e) T_flags_eq_ulong(a, e, T_CHECK_QUIET)
1213 #define T_step_eq_ulong(s, a, e) T_flags_eq_ulong(a, e, T_CHECK_STEP(s))
1214 #define T_step_assert_eq_ulong(s, a, e) \
1215  T_flags_eq_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1216
1217 #define T_ne_ulong(a, e) T_flags_ne_ulong(a, e, 0)
1218 #define T_assert_ne_ulong(a, e) T_flags_ne_ulong(a, e, T_CHECK_STOP)
1219 #define T_quiet_ne_ulong(a, e) T_flags_ne_ulong(a, e, T_CHECK_QUIET)
1220 #define T_step_ne_ulong(s, a, e) T_flags_ne_ulong(a, e, T_CHECK_STEP(s))
1221 #define T_step_assert_ne_ulong(s, a, e) \
1222  T_flags_ne_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1223
1224 #define T_ge_ulong(a, e) T_flags_ge_ulong(a, e, 0)
1225 #define T_assert_ge_ulong(a, e) T_flags_ge_ulong(a, e, T_CHECK_STOP)
1226 #define T_quiet_ge_ulong(a, e) T_flags_ge_ulong(a, e, T_CHECK_QUIET)
1227 #define T_step_ge_ulong(s, a, e) T_flags_ge_ulong(a, e, T_CHECK_STEP(s))
1228 #define T_step_assert_ge_ulong(s, a, e) \
1229  T_flags_ge_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1230
1231 #define T_gt_ulong(a, e) T_flags_gt_ulong(a, e, 0)
1232 #define T_assert_gt_ulong(a, e) T_flags_gt_ulong(a, e, T_CHECK_STOP)
1233 #define T_quiet_gt_ulong(a, e) T_flags_gt_ulong(a, e, T_CHECK_QUIET)
1234 #define T_step_gt_ulong(s, a, e) T_flags_gt_ulong(a, e, T_CHECK_STEP(s))
1235 #define T_step_assert_gt_ulong(s, a, e) \
1236  T_flags_gt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1237
1238 #define T_le_ulong(a, e) T_flags_le_ulong(a, e, 0)
1239 #define T_assert_le_ulong(a, e) T_flags_le_ulong(a, e, T_CHECK_STOP)
1240 #define T_quiet_le_ulong(a, e) T_flags_le_ulong(a, e, T_CHECK_QUIET)
1241 #define T_step_le_ulong(s, a, e) T_flags_le_ulong(a, e, T_CHECK_STEP(s))
1242 #define T_step_assert_le_ulong(s, a, e) \
1243  T_flags_le_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1244
1245 #define T_lt_ulong(a, e) T_flags_lt_ulong(a, e, 0)
1246 #define T_assert_lt_ulong(a, e) T_flags_lt_ulong(a, e, T_CHECK_STOP)
1247 #define T_quiet_lt_ulong(a, e) T_flags_lt_ulong(a, e, T_CHECK_QUIET)
1248 #define T_step_lt_ulong(s, a, e) T_flags_lt_ulong(a, e, T_CHECK_STEP(s))
1249 #define T_step_assert_lt_ulong(s, a, e) \
1250  T_flags_lt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1251
1264 #define T_eq_ll(a, e) T_flags_eq_ll(a, e, 0)
1265 #define T_assert_eq_ll(a, e) T_flags_eq_ll(a, e, T_CHECK_STOP)
1266 #define T_quiet_eq_ll(a, e) T_flags_eq_ll(a, e, T_CHECK_QUIET)
1267 #define T_step_eq_ll(s, a, e) T_flags_eq_ll(a, e, T_CHECK_STEP(s))
1268 #define T_step_assert_eq_ll(s, a, e) \
1269  T_flags_eq_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1270
1271 #define T_ne_ll(a, e) T_flags_ne_ll(a, e, 0)
1272 #define T_assert_ne_ll(a, e) T_flags_ne_ll(a, e, T_CHECK_STOP)
1273 #define T_quiet_ne_ll(a, e) T_flags_ne_ll(a, e, T_CHECK_QUIET)
1274 #define T_step_ne_ll(s, a, e) T_flags_ne_ll(a, e, T_CHECK_STEP(s))
1275 #define T_step_assert_ne_ll(s, a, e) \
1276  T_flags_ne_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1277
1278 #define T_ge_ll(a, e) T_flags_ge_ll(a, e, 0)
1279 #define T_assert_ge_ll(a, e) T_flags_ge_ll(a, e, T_CHECK_STOP)
1280 #define T_quiet_ge_ll(a, e) T_flags_ge_ll(a, e, T_CHECK_QUIET)
1281 #define T_step_ge_ll(s, a, e) T_flags_ge_ll(a, e, T_CHECK_STEP(s))
1282 #define T_step_assert_ge_ll(s, a, e) \
1283  T_flags_ge_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1284
1285 #define T_gt_ll(a, e) T_flags_gt_ll(a, e, 0)
1286 #define T_assert_gt_ll(a, e) T_flags_gt_ll(a, e, T_CHECK_STOP)
1287 #define T_quiet_gt_ll(a, e) T_flags_gt_ll(a, e, T_CHECK_QUIET)
1288 #define T_step_gt_ll(s, a, e) T_flags_gt_ll(a, e, T_CHECK_STEP(s))
1289 #define T_step_assert_gt_ll(s, a, e) \
1290  T_flags_gt_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1291
1292 #define T_le_ll(a, e) T_flags_le_ll(a, e, 0)
1293 #define T_assert_le_ll(a, e) T_flags_le_ll(a, e, T_CHECK_STOP)
1294 #define T_quiet_le_ll(a, e) T_flags_le_ll(a, e, T_CHECK_QUIET)
1295 #define T_step_le_ll(s, a, e) T_flags_le_ll(a, e, T_CHECK_STEP(s))
1296 #define T_step_assert_le_ll(s, a, e) \
1297  T_flags_le_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1298
1299 #define T_lt_ll(a, e) T_flags_lt_ll(a, e, 0)
1300 #define T_assert_lt_ll(a, e) T_flags_lt_ll(a, e, T_CHECK_STOP)
1301 #define T_quiet_lt_ll(a, e) T_flags_lt_ll(a, e, T_CHECK_QUIET)
1302 #define T_step_lt_ll(s, a, e) T_flags_lt_ll(a, e, T_CHECK_STEP(s))
1303 #define T_step_assert_lt_ll(s, a, e) \
1304  T_flags_lt_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1305
1318 #define T_eq_ull(a, e) T_flags_eq_ull(a, e, 0)
1319 #define T_assert_eq_ull(a, e) T_flags_eq_ull(a, e, T_CHECK_STOP)
1320 #define T_quiet_eq_ull(a, e) T_flags_eq_ull(a, e, T_CHECK_QUIET)
1321 #define T_step_eq_ull(s, a, e) T_flags_eq_ull(a, e, T_CHECK_STEP(s))
1322 #define T_step_assert_eq_ull(s, a, e) \
1323  T_flags_eq_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1324
1325 #define T_ne_ull(a, e) T_flags_ne_ull(a, e, 0)
1326 #define T_assert_ne_ull(a, e) T_flags_ne_ull(a, e, T_CHECK_STOP)
1327 #define T_quiet_ne_ull(a, e) T_flags_ne_ull(a, e, T_CHECK_QUIET)
1328 #define T_step_ne_ull(s, a, e) T_flags_ne_ull(a, e, T_CHECK_STEP(s))
1329 #define T_step_assert_ne_ull(s, a, e) \
1330  T_flags_ne_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1331
1332 #define T_ge_ull(a, e) T_flags_ge_ull(a, e, 0)
1333 #define T_assert_ge_ull(a, e) T_flags_ge_ull(a, e, T_CHECK_STOP)
1334 #define T_quiet_ge_ull(a, e) T_flags_ge_ull(a, e, T_CHECK_QUIET)
1335 #define T_step_ge_ull(s, a, e) T_flags_ge_ull(a, e, T_CHECK_STEP(s))
1336 #define T_step_assert_ge_ull(s, a, e) \
1337  T_flags_ge_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1338
1339 #define T_gt_ull(a, e) T_flags_gt_ull(a, e, 0)
1340 #define T_assert_gt_ull(a, e) T_flags_gt_ull(a, e, T_CHECK_STOP)
1341 #define T_quiet_gt_ull(a, e) T_flags_gt_ull(a, e, T_CHECK_QUIET)
1342 #define T_step_gt_ull(s, a, e) T_flags_gt_ull(a, e, T_CHECK_STEP(s))
1343 #define T_step_assert_gt_ull(s, a, e) \
1344  T_flags_gt_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1345
1346 #define T_le_ull(a, e) T_flags_le_ull(a, e, 0)
1347 #define T_assert_le_ull(a, e) T_flags_le_ull(a, e, T_CHECK_STOP)
1348 #define T_quiet_le_ull(a, e) T_flags_le_ull(a, e, T_CHECK_QUIET)
1349 #define T_step_le_ull(s, a, e) T_flags_le_ull(a, e, T_CHECK_STEP(s))
1350 #define T_step_assert_le_ull(s, a, e) \
1351  T_flags_le_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1352
1353 #define T_lt_ull(a, e) T_flags_lt_ull(a, e, 0)
1354 #define T_assert_lt_ull(a, e) T_flags_lt_ull(a, e, T_CHECK_STOP)
1355 #define T_quiet_lt_ull(a, e) T_flags_lt_ull(a, e, T_CHECK_QUIET)
1356 #define T_step_lt_ull(s, a, e) T_flags_lt_ull(a, e, T_CHECK_STEP(s))
1357 #define T_step_assert_lt_ull(s, a, e) \
1358  T_flags_lt_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1359
1372 #define T_eq_i8(a, e) T_flags_eq_int(a, e, 0)
1373 #define T_assert_eq_i8(a, e) T_flags_eq_int(a, e, T_CHECK_STOP)
1374 #define T_quiet_eq_i8(a, e) T_flags_eq_int(a, e, T_CHECK_QUIET)
1375 #define T_step_eq_i8(s, a, e) T_flags_eq_int(a, e, T_CHECK_STEP(s))
1376 #define T_step_assert_eq_i8(s, a, e) \
1377  T_flags_eq_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1378
1379 #define T_ne_i8(a, e) T_flags_ne_int(a, e, 0)
1380 #define T_assert_ne_i8(a, e) T_flags_ne_int(a, e, T_CHECK_STOP)
1381 #define T_quiet_ne_i8(a, e) T_flags_ne_int(a, e, T_CHECK_QUIET)
1382 #define T_step_ne_i8(s, a, e) T_flags_ne_int(a, e, T_CHECK_STEP(s))
1383 #define T_step_assert_ne_i8(s, a, e) \
1384  T_flags_ne_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1385
1386 #define T_ge_i8(a, e) T_flags_ge_int(a, e, 0)
1387 #define T_assert_ge_i8(a, e) T_flags_ge_int(a, e, T_CHECK_STOP)
1388 #define T_quiet_ge_i8(a, e) T_flags_ge_int(a, e, T_CHECK_QUIET)
1389 #define T_step_ge_i8(s, a, e) T_flags_ge_int(a, e, T_CHECK_STEP(s))
1390 #define T_step_assert_ge_i8(s, a, e) \
1391  T_flags_ge_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1392
1393 #define T_gt_i8(a, e) T_flags_gt_int(a, e, 0)
1394 #define T_assert_gt_i8(a, e) T_flags_gt_int(a, e, T_CHECK_STOP)
1395 #define T_quiet_gt_i8(a, e) T_flags_gt_int(a, e, T_CHECK_QUIET)
1396 #define T_step_gt_i8(s, a, e) T_flags_gt_int(a, e, T_CHECK_STEP(s))
1397 #define T_step_assert_gt_i8(s, a, e) \
1398  T_flags_gt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1399
1400 #define T_le_i8(a, e) T_flags_le_int(a, e, 0)
1401 #define T_assert_le_i8(a, e) T_flags_le_int(a, e, T_CHECK_STOP)
1402 #define T_quiet_le_i8(a, e) T_flags_le_int(a, e, T_CHECK_QUIET)
1403 #define T_step_le_i8(s, a, e) T_flags_le_int(a, e, T_CHECK_STEP(s))
1404 #define T_step_assert_le_i8(s, a, e) \
1405  T_flags_le_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1406
1407 #define T_lt_i8(a, e) T_flags_lt_int(a, e, 0)
1408 #define T_assert_lt_i8(a, e) T_flags_lt_int(a, e, T_CHECK_STOP)
1409 #define T_quiet_lt_i8(a, e) T_flags_lt_int(a, e, T_CHECK_QUIET)
1410 #define T_step_lt_i8(s, a, e) T_flags_lt_int(a, e, T_CHECK_STEP(s))
1411 #define T_step_assert_lt_i8(s, a, e) \
1412  T_flags_lt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1413
1426 #define T_eq_u8(a, e) T_flags_eq_uint(a, e, 0)
1427 #define T_assert_eq_u8(a, e) T_flags_eq_uint(a, e, T_CHECK_STOP)
1428 #define T_quiet_eq_u8(a, e) T_flags_eq_uint(a, e, T_CHECK_QUIET)
1429 #define T_step_eq_u8(s, a, e) T_flags_eq_uint(a, e, T_CHECK_STEP(s))
1430 #define T_step_assert_eq_u8(s, a, e) \
1431  T_flags_eq_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1432
1433 #define T_ne_u8(a, e) T_flags_ne_uint(a, e, 0)
1434 #define T_assert_ne_u8(a, e) T_flags_ne_uint(a, e, T_CHECK_STOP)
1435 #define T_quiet_ne_u8(a, e) T_flags_ne_uint(a, e, T_CHECK_QUIET)
1436 #define T_step_ne_u8(s, a, e) T_flags_ne_uint(a, e, T_CHECK_STEP(s))
1437 #define T_step_assert_ne_u8(s, a, e) \
1438  T_flags_ne_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1439
1440 #define T_ge_u8(a, e) T_flags_ge_uint(a, e, 0)
1441 #define T_assert_ge_u8(a, e) T_flags_ge_uint(a, e, T_CHECK_STOP)
1442 #define T_quiet_ge_u8(a, e) T_flags_ge_uint(a, e, T_CHECK_QUIET)
1443 #define T_step_ge_u8(s, a, e) T_flags_ge_uint(a, e, T_CHECK_STEP(s))
1444 #define T_step_assert_ge_u8(s, a, e) \
1445  T_flags_ge_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1446
1447 #define T_gt_u8(a, e) T_flags_gt_uint(a, e, 0)
1448 #define T_assert_gt_u8(a, e) T_flags_gt_uint(a, e, T_CHECK_STOP)
1449 #define T_quiet_gt_u8(a, e) T_flags_gt_uint(a, e, T_CHECK_QUIET)
1450 #define T_step_gt_u8(s, a, e) T_flags_gt_uint(a, e, T_CHECK_STEP(s))
1451 #define T_step_assert_gt_u8(s, a, e) \
1452  T_flags_gt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1453
1454 #define T_le_u8(a, e) T_flags_le_uint(a, e, 0)
1455 #define T_assert_le_u8(a, e) T_flags_le_uint(a, e, T_CHECK_STOP)
1456 #define T_quiet_le_u8(a, e) T_flags_le_uint(a, e, T_CHECK_QUIET)
1457 #define T_step_le_u8(s, a, e) T_flags_le_uint(a, e, T_CHECK_STEP(s))
1458 #define T_step_assert_le_u8(s, a, e) \
1459  T_flags_le_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1460
1461 #define T_lt_u8(a, e) T_flags_lt_uint(a, e, 0)
1462 #define T_assert_lt_u8(a, e) T_flags_lt_uint(a, e, T_CHECK_STOP)
1463 #define T_quiet_lt_u8(a, e) T_flags_lt_uint(a, e, T_CHECK_QUIET)
1464 #define T_step_lt_u8(s, a, e) T_flags_lt_uint(a, e, T_CHECK_STEP(s))
1465 #define T_step_assert_lt_u8(s, a, e) \
1466  T_flags_lt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1467
1480 #define T_eq_i16(a, e) T_flags_eq_int(a, e, 0)
1481 #define T_assert_eq_i16(a, e) T_flags_eq_int(a, e, T_CHECK_STOP)
1482 #define T_quiet_eq_i16(a, e) T_flags_eq_int(a, e, T_CHECK_QUIET)
1483 #define T_step_eq_i16(s, a, e) T_flags_eq_int(a, e, T_CHECK_STEP(s))
1484 #define T_step_assert_eq_i16(s, a, e) \
1485  T_flags_eq_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1486
1487 #define T_ne_i16(a, e) T_flags_ne_int(a, e, 0)
1488 #define T_assert_ne_i16(a, e) T_flags_ne_int(a, e, T_CHECK_STOP)
1489 #define T_quiet_ne_i16(a, e) T_flags_ne_int(a, e, T_CHECK_QUIET)
1490 #define T_step_ne_i16(s, a, e) T_flags_ne_int(a, e, T_CHECK_STEP(s))
1491 #define T_step_assert_ne_i16(s, a, e) \
1492  T_flags_ne_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1493
1494 #define T_ge_i16(a, e) T_flags_ge_int(a, e, 0)
1495 #define T_assert_ge_i16(a, e) T_flags_ge_int(a, e, T_CHECK_STOP)
1496 #define T_quiet_ge_i16(a, e) T_flags_ge_int(a, e, T_CHECK_QUIET)
1497 #define T_step_ge_i16(s, a, e) T_flags_ge_int(a, e, T_CHECK_STEP(s))
1498 #define T_step_assert_ge_i16(s, a, e) \
1499  T_flags_ge_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1500
1501 #define T_gt_i16(a, e) T_flags_gt_int(a, e, 0)
1502 #define T_assert_gt_i16(a, e) T_flags_gt_int(a, e, T_CHECK_STOP)
1503 #define T_quiet_gt_i16(a, e) T_flags_gt_int(a, e, T_CHECK_QUIET)
1504 #define T_step_gt_i16(s, a, e) T_flags_gt_int(a, e, T_CHECK_STEP(s))
1505 #define T_step_assert_gt_i16(s, a, e) \
1506  T_flags_gt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1507
1508 #define T_le_i16(a, e) T_flags_le_int(a, e, 0)
1509 #define T_assert_le_i16(a, e) T_flags_le_int(a, e, T_CHECK_STOP)
1510 #define T_quiet_le_i16(a, e) T_flags_le_int(a, e, T_CHECK_QUIET)
1511 #define T_step_le_i16(s, a, e) T_flags_le_int(a, e, T_CHECK_STEP(s))
1512 #define T_step_assert_le_i16(s, a, e) \
1513  T_flags_le_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1514
1515 #define T_lt_i16(a, e) T_flags_lt_int(a, e, 0)
1516 #define T_assert_lt_i16(a, e) T_flags_lt_int(a, e, T_CHECK_STOP)
1517 #define T_quiet_lt_i16(a, e) T_flags_lt_int(a, e, T_CHECK_QUIET)
1518 #define T_step_lt_i16(s, a, e) T_flags_lt_int(a, e, T_CHECK_STEP(s))
1519 #define T_step_assert_lt_i16(s, a, e) \
1520  T_flags_lt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1521
1534 #define T_eq_u16(a, e) T_flags_eq_uint(a, e, 0)
1535 #define T_assert_eq_u16(a, e) T_flags_eq_uint(a, e, T_CHECK_STOP)
1536 #define T_quiet_eq_u16(a, e) T_flags_eq_uint(a, e, T_CHECK_QUIET)
1537 #define T_step_eq_u16(s, a, e) T_flags_eq_uint(a, e, T_CHECK_STEP(s))
1538 #define T_step_assert_eq_u16(s, a, e) \
1539  T_flags_eq_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1540
1541 #define T_ne_u16(a, e) T_flags_ne_uint(a, e, 0)
1542 #define T_assert_ne_u16(a, e) T_flags_ne_uint(a, e, T_CHECK_STOP)
1543 #define T_quiet_ne_u16(a, e) T_flags_ne_uint(a, e, T_CHECK_QUIET)
1544 #define T_step_ne_u16(s, a, e) T_flags_ne_uint(a, e, T_CHECK_STEP(s))
1545 #define T_step_assert_ne_u16(s, a, e) \
1546  T_flags_ne_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1547
1548 #define T_ge_u16(a, e) T_flags_ge_uint(a, e, 0)
1549 #define T_assert_ge_u16(a, e) T_flags_ge_uint(a, e, T_CHECK_STOP)
1550 #define T_quiet_ge_u16(a, e) T_flags_ge_uint(a, e, T_CHECK_QUIET)
1551 #define T_step_ge_u16(s, a, e) T_flags_ge_uint(a, e, T_CHECK_STEP(s))
1552 #define T_step_assert_ge_u16(s, a, e) \
1553  T_flags_ge_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1554
1555 #define T_gt_u16(a, e) T_flags_gt_uint(a, e, 0)
1556 #define T_assert_gt_u16(a, e) T_flags_gt_uint(a, e, T_CHECK_STOP)
1557 #define T_quiet_gt_u16(a, e) T_flags_gt_uint(a, e, T_CHECK_QUIET)
1558 #define T_step_gt_u16(s, a, e) T_flags_gt_uint(a, e, T_CHECK_STEP(s))
1559 #define T_step_assert_gt_u16(s, a, e) \
1560  T_flags_gt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1561
1562 #define T_le_u16(a, e) T_flags_le_uint(a, e, 0)
1563 #define T_assert_le_u16(a, e) T_flags_le_uint(a, e, T_CHECK_STOP)
1564 #define T_quiet_le_u16(a, e) T_flags_le_uint(a, e, T_CHECK_QUIET)
1565 #define T_step_le_u16(s, a, e) T_flags_le_uint(a, e, T_CHECK_STEP(s))
1566 #define T_step_assert_le_u16(s, a, e) \
1567  T_flags_le_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1568
1569 #define T_lt_u16(a, e) T_flags_lt_uint(a, e, 0)
1570 #define T_assert_lt_u16(a, e) T_flags_lt_uint(a, e, T_CHECK_STOP)
1571 #define T_quiet_lt_u16(a, e) T_flags_lt_uint(a, e, T_CHECK_QUIET)
1572 #define T_step_lt_u16(s, a, e) T_flags_lt_uint(a, e, T_CHECK_STEP(s))
1573 #define T_step_assert_lt_u16(s, a, e) \
1574  T_flags_lt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1575
1588 #define T_eq_i32(a, e) T_flags_eq_long(a, e, 0)
1589 #define T_assert_eq_i32(a, e) T_flags_eq_long(a, e, T_CHECK_STOP)
1590 #define T_quiet_eq_i32(a, e) T_flags_eq_long(a, e, T_CHECK_QUIET)
1591 #define T_step_eq_i32(s, a, e) T_flags_eq_long(a, e, T_CHECK_STEP(s))
1592 #define T_step_assert_eq_i32(s, a, e) \
1593  T_flags_eq_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1594
1595 #define T_ne_i32(a, e) T_flags_ne_long(a, e, 0)
1596 #define T_assert_ne_i32(a, e) T_flags_ne_long(a, e, T_CHECK_STOP)
1597 #define T_quiet_ne_i32(a, e) T_flags_ne_long(a, e, T_CHECK_QUIET)
1598 #define T_step_ne_i32(s, a, e) T_flags_ne_long(a, e, T_CHECK_STEP(s))
1599 #define T_step_assert_ne_i32(s, a, e) \
1600  T_flags_ne_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1601
1602 #define T_ge_i32(a, e) T_flags_ge_long(a, e, 0)
1603 #define T_assert_ge_i32(a, e) T_flags_ge_long(a, e, T_CHECK_STOP)
1604 #define T_quiet_ge_i32(a, e) T_flags_ge_long(a, e, T_CHECK_QUIET)
1605 #define T_step_ge_i32(s, a, e) T_flags_ge_long(a, e, T_CHECK_STEP(s))
1606 #define T_step_assert_ge_i32(s, a, e) \
1607  T_flags_ge_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1608
1609 #define T_gt_i32(a, e) T_flags_gt_long(a, e, 0)
1610 #define T_assert_gt_i32(a, e) T_flags_gt_long(a, e, T_CHECK_STOP)
1611 #define T_quiet_gt_i32(a, e) T_flags_gt_long(a, e, T_CHECK_QUIET)
1612 #define T_step_gt_i32(s, a, e) T_flags_gt_long(a, e, T_CHECK_STEP(s))
1613 #define T_step_assert_gt_i32(s, a, e) \
1614  T_flags_gt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1615
1616 #define T_le_i32(a, e) T_flags_le_long(a, e, 0)
1617 #define T_assert_le_i32(a, e) T_flags_le_long(a, e, T_CHECK_STOP)
1618 #define T_quiet_le_i32(a, e) T_flags_le_long(a, e, T_CHECK_QUIET)
1619 #define T_step_le_i32(s, a, e) T_flags_le_long(a, e, T_CHECK_STEP(s))
1620 #define T_step_assert_le_i32(s, a, e) \
1621  T_flags_le_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1622
1623 #define T_lt_i32(a, e) T_flags_lt_long(a, e, 0)
1624 #define T_assert_lt_i32(a, e) T_flags_lt_long(a, e, T_CHECK_STOP)
1625 #define T_quiet_lt_i32(a, e) T_flags_lt_long(a, e, T_CHECK_QUIET)
1626 #define T_step_lt_i32(s, a, e) T_flags_lt_long(a, e, T_CHECK_STEP(s))
1627 #define T_step_assert_lt_i32(s, a, e) \
1628  T_flags_lt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1629
1642 #define T_eq_u32(a, e) T_flags_eq_ulong(a, e, 0)
1643 #define T_assert_eq_u32(a, e) T_flags_eq_ulong(a, e, T_CHECK_STOP)
1644 #define T_quiet_eq_u32(a, e) T_flags_eq_ulong(a, e, T_CHECK_QUIET)
1645 #define T_step_eq_u32(s, a, e) T_flags_eq_ulong(a, e, T_CHECK_STEP(s))
1646 #define T_step_assert_eq_u32(s, a, e) \
1647  T_flags_eq_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1648
1649 #define T_ne_u32(a, e) T_flags_ne_ulong(a, e, 0)
1650 #define T_assert_ne_u32(a, e) T_flags_ne_ulong(a, e, T_CHECK_STOP)
1651 #define T_quiet_ne_u32(a, e) T_flags_ne_ulong(a, e, T_CHECK_QUIET)
1652 #define T_step_ne_u32(s, a, e) T_flags_ne_ulong(a, e, T_CHECK_STEP(s))
1653 #define T_step_assert_ne_u32(s, a, e) \
1654  T_flags_ne_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1655
1656 #define T_ge_u32(a, e) T_flags_ge_ulong(a, e, 0)
1657 #define T_assert_ge_u32(a, e) T_flags_ge_ulong(a, e, T_CHECK_STOP)
1658 #define T_quiet_ge_u32(a, e) T_flags_ge_ulong(a, e, T_CHECK_QUIET)
1659 #define T_step_ge_u32(s, a, e) T_flags_ge_ulong(a, e, T_CHECK_STEP(s))
1660 #define T_step_assert_ge_u32(s, a, e) \
1661  T_flags_ge_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1662
1663 #define T_gt_u32(a, e) T_flags_gt_ulong(a, e, 0)
1664 #define T_assert_gt_u32(a, e) T_flags_gt_ulong(a, e, T_CHECK_STOP)
1665 #define T_quiet_gt_u32(a, e) T_flags_gt_ulong(a, e, T_CHECK_QUIET)
1666 #define T_step_gt_u32(s, a, e) T_flags_gt_ulong(a, e, T_CHECK_STEP(s))
1667 #define T_step_assert_gt_u32(s, a, e) \
1668  T_flags_gt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1669
1670 #define T_le_u32(a, e) T_flags_le_ulong(a, e, 0)
1671 #define T_assert_le_u32(a, e) T_flags_le_ulong(a, e, T_CHECK_STOP)
1672 #define T_quiet_le_u32(a, e) T_flags_le_ulong(a, e, T_CHECK_QUIET)
1673 #define T_step_le_u32(s, a, e) T_flags_le_ulong(a, e, T_CHECK_STEP(s))
1674 #define T_step_assert_le_u32(s, a, e) \
1675  T_flags_le_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1676
1677 #define T_lt_u32(a, e) T_flags_lt_ulong(a, e, 0)
1678 #define T_assert_lt_u32(a, e) T_flags_lt_ulong(a, e, T_CHECK_STOP)
1679 #define T_quiet_lt_u32(a, e) T_flags_lt_ulong(a, e, T_CHECK_QUIET)
1680 #define T_step_lt_u32(s, a, e) T_flags_lt_ulong(a, e, T_CHECK_STEP(s))
1681 #define T_step_assert_lt_u32(s, a, e) \
1682  T_flags_lt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1683
1696 #define T_eq_i64(a, e) T_flags_eq_ll(a, e, 0)
1697 #define T_assert_eq_i64(a, e) T_flags_eq_ll(a, e, T_CHECK_STOP)
1698 #define T_quiet_eq_i64(a, e) T_flags_eq_ll(a, e, T_CHECK_QUIET)
1699 #define T_step_eq_i64(s, a, e) T_flags_eq_ll(a, e, T_CHECK_STEP(s))
1700 #define T_step_assert_eq_i64(s, a, e) \
1701  T_flags_eq_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1702
1703 #define T_ne_i64(a, e) T_flags_ne_ll(a, e, 0)
1704 #define T_assert_ne_i64(a, e) T_flags_ne_ll(a, e, T_CHECK_STOP)
1705 #define T_quiet_ne_i64(a, e) T_flags_ne_ll(a, e, T_CHECK_QUIET)
1706 #define T_step_ne_i64(s, a, e) T_flags_ne_ll(a, e, T_CHECK_STEP(s))
1707 #define T_step_assert_ne_i64(s, a, e) \
1708  T_flags_ne_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1709
1710 #define T_ge_i64(a, e) T_flags_ge_ll(a, e, 0)
1711 #define T_assert_ge_i64(a, e) T_flags_ge_ll(a, e, T_CHECK_STOP)
1712 #define T_quiet_ge_i64(a, e) T_flags_ge_ll(a, e, T_CHECK_QUIET)
1713 #define T_step_ge_i64(s, a, e) T_flags_ge_ll(a, e, T_CHECK_STEP(s))
1714 #define T_step_assert_ge_i64(s, a, e) \
1715  T_flags_ge_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1716
1717 #define T_gt_i64(a, e) T_flags_gt_ll(a, e, 0)
1718 #define T_assert_gt_i64(a, e) T_flags_gt_ll(a, e, T_CHECK_STOP)
1719 #define T_quiet_gt_i64(a, e) T_flags_gt_ll(a, e, T_CHECK_QUIET)
1720 #define T_step_gt_i64(s, a, e) T_flags_gt_ll(a, e, T_CHECK_STEP(s))
1721 #define T_step_assert_gt_i64(s, a, e) \
1722  T_flags_gt_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1723
1724 #define T_le_i64(a, e) T_flags_le_ll(a, e, 0)
1725 #define T_assert_le_i64(a, e) T_flags_le_ll(a, e, T_CHECK_STOP)
1726 #define T_quiet_le_i64(a, e) T_flags_le_ll(a, e, T_CHECK_QUIET)
1727 #define T_step_le_i64(s, a, e) T_flags_le_ll(a, e, T_CHECK_STEP(s))
1728 #define T_step_assert_le_i64(s, a, e) \
1729  T_flags_le_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1730
1731 #define T_lt_i64(a, e) T_flags_lt_ll(a, e, 0)
1732 #define T_assert_lt_i64(a, e) T_flags_lt_ll(a, e, T_CHECK_STOP)
1733 #define T_quiet_lt_i64(a, e) T_flags_lt_ll(a, e, T_CHECK_QUIET)
1734 #define T_step_lt_i64(s, a, e) T_flags_lt_ll(a, e, T_CHECK_STEP(s))
1735 #define T_step_assert_lt_i64(s, a, e) \
1736  T_flags_lt_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1737
1750 #define T_eq_u64(a, e) T_flags_eq_ull(a, e, 0)
1751 #define T_assert_eq_u64(a, e) T_flags_eq_ull(a, e, T_CHECK_STOP)
1752 #define T_quiet_eq_u64(a, e) T_flags_eq_ull(a, e, T_CHECK_QUIET)
1753 #define T_step_eq_u64(s, a, e) T_flags_eq_ull(a, e, T_CHECK_STEP(s))
1754 #define T_step_assert_eq_u64(s, a, e) \
1755  T_flags_eq_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1756
1757 #define T_ne_u64(a, e) T_flags_ne_ull(a, e, 0)
1758 #define T_assert_ne_u64(a, e) T_flags_ne_ull(a, e, T_CHECK_STOP)
1759 #define T_quiet_ne_u64(a, e) T_flags_ne_ull(a, e, T_CHECK_QUIET)
1760 #define T_step_ne_u64(s, a, e) T_flags_ne_ull(a, e, T_CHECK_STEP(s))
1761 #define T_step_assert_ne_u64(s, a, e) \
1762  T_flags_ne_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1763
1764 #define T_ge_u64(a, e) T_flags_ge_ull(a, e, 0)
1765 #define T_assert_ge_u64(a, e) T_flags_ge_ull(a, e, T_CHECK_STOP)
1766 #define T_quiet_ge_u64(a, e) T_flags_ge_ull(a, e, T_CHECK_QUIET)
1767 #define T_step_ge_u64(s, a, e) T_flags_ge_ull(a, e, T_CHECK_STEP(s))
1768 #define T_step_assert_ge_u64(s, a, e) \
1769  T_flags_ge_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1770
1771 #define T_gt_u64(a, e) T_flags_gt_ull(a, e, 0)
1772 #define T_assert_gt_u64(a, e) T_flags_gt_ull(a, e, T_CHECK_STOP)
1773 #define T_quiet_gt_u64(a, e) T_flags_gt_ull(a, e, T_CHECK_QUIET)
1774 #define T_step_gt_u64(s, a, e) T_flags_gt_ull(a, e, T_CHECK_STEP(s))
1775 #define T_step_assert_gt_u64(s, a, e) \
1776  T_flags_gt_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1777
1778 #define T_le_u64(a, e) T_flags_le_ull(a, e, 0)
1779 #define T_assert_le_u64(a, e) T_flags_le_ull(a, e, T_CHECK_STOP)
1780 #define T_quiet_le_u64(a, e) T_flags_le_ull(a, e, T_CHECK_QUIET)
1781 #define T_step_le_u64(s, a, e) T_flags_le_ull(a, e, T_CHECK_STEP(s))
1782 #define T_step_assert_le_u64(s, a, e) \
1783  T_flags_le_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1784
1785 #define T_lt_u64(a, e) T_flags_lt_ull(a, e, 0)
1786 #define T_assert_lt_u64(a, e) T_flags_lt_ull(a, e, T_CHECK_STOP)
1787 #define T_quiet_lt_u64(a, e) T_flags_lt_ull(a, e, T_CHECK_QUIET)
1788 #define T_step_lt_u64(s, a, e) T_flags_lt_ull(a, e, T_CHECK_STEP(s))
1789 #define T_step_assert_lt_u64(s, a, e) \
1790  T_flags_lt_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1791
1804 #define T_eq_iptr(a, e) T_flags_eq_long(a, e, 0)
1805 #define T_assert_eq_iptr(a, e) T_flags_eq_long(a, e, T_CHECK_STOP)
1806 #define T_quiet_eq_iptr(a, e) T_flags_eq_long(a, e, T_CHECK_QUIET)
1807 #define T_step_eq_iptr(s, a, e) T_flags_eq_long(a, e, T_CHECK_STEP(s))
1808 #define T_step_assert_eq_iptr(s, a, e) \
1809  T_flags_eq_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1810
1811 #define T_ne_iptr(a, e) T_flags_ne_long(a, e, 0)
1812 #define T_assert_ne_iptr(a, e) T_flags_ne_long(a, e, T_CHECK_STOP)
1813 #define T_quiet_ne_iptr(a, e) T_flags_ne_long(a, e, T_CHECK_QUIET)
1814 #define T_step_ne_iptr(s, a, e) T_flags_ne_long(a, e, T_CHECK_STEP(s))
1815 #define T_step_assert_ne_iptr(s, a, e) \
1816  T_flags_ne_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1817
1818 #define T_ge_iptr(a, e) T_flags_ge_long(a, e, 0)
1819 #define T_assert_ge_iptr(a, e) T_flags_ge_long(a, e, T_CHECK_STOP)
1820 #define T_quiet_ge_iptr(a, e) T_flags_ge_long(a, e, T_CHECK_QUIET)
1821 #define T_step_ge_iptr(s, a, e) T_flags_ge_long(a, e, T_CHECK_STEP(s))
1822 #define T_step_assert_ge_iptr(s, a, e) \
1823  T_flags_ge_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1824
1825 #define T_gt_iptr(a, e) T_flags_gt_long(a, e, 0)
1826 #define T_assert_gt_iptr(a, e) T_flags_gt_long(a, e, T_CHECK_STOP)
1827 #define T_quiet_gt_iptr(a, e) T_flags_gt_long(a, e, T_CHECK_QUIET)
1828 #define T_step_gt_iptr(s, a, e) T_flags_gt_long(a, e, T_CHECK_STEP(s))
1829 #define T_step_assert_gt_iptr(s, a, e) \
1830  T_flags_gt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1831
1832 #define T_le_iptr(a, e) T_flags_le_long(a, e, 0)
1833 #define T_assert_le_iptr(a, e) T_flags_le_long(a, e, T_CHECK_STOP)
1834 #define T_quiet_le_iptr(a, e) T_flags_le_long(a, e, T_CHECK_QUIET)
1835 #define T_step_le_iptr(s, a, e) T_flags_le_long(a, e, T_CHECK_STEP(s))
1836 #define T_step_assert_le_iptr(s, a, e) \
1837  T_flags_le_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1838
1839 #define T_lt_iptr(a, e) T_flags_lt_long(a, e, 0)
1840 #define T_assert_lt_iptr(a, e) T_flags_lt_long(a, e, T_CHECK_STOP)
1841 #define T_quiet_lt_iptr(a, e) T_flags_lt_long(a, e, T_CHECK_QUIET)
1842 #define T_step_lt_iptr(s, a, e) T_flags_lt_long(a, e, T_CHECK_STEP(s))
1843 #define T_step_assert_lt_iptr(s, a, e) \
1844  T_flags_lt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1845
1858 #define T_eq_uptr(a, e) T_flags_eq_ulong(a, e, 0)
1859 #define T_assert_eq_uptr(a, e) T_flags_eq_ulong(a, e, T_CHECK_STOP)
1860 #define T_quiet_eq_uptr(a, e) T_flags_eq_ulong(a, e, T_CHECK_QUIET)
1861 #define T_step_eq_uptr(s, a, e) T_flags_eq_ulong(a, e, T_CHECK_STEP(s))
1862 #define T_step_assert_eq_uptr(s, a, e) \
1863  T_flags_eq_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1864
1865 #define T_ne_uptr(a, e) T_flags_ne_ulong(a, e, 0)
1866 #define T_assert_ne_uptr(a, e) T_flags_ne_ulong(a, e, T_CHECK_STOP)
1867 #define T_quiet_ne_uptr(a, e) T_flags_ne_ulong(a, e, T_CHECK_QUIET)
1868 #define T_step_ne_uptr(s, a, e) T_flags_ne_ulong(a, e, T_CHECK_STEP(s))
1869 #define T_step_assert_ne_uptr(s, a, e) \
1870  T_flags_ne_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1871
1872 #define T_ge_uptr(a, e) T_flags_ge_ulong(a, e, 0)
1873 #define T_assert_ge_uptr(a, e) T_flags_ge_ulong(a, e, T_CHECK_STOP)
1874 #define T_quiet_ge_uptr(a, e) T_flags_ge_ulong(a, e, T_CHECK_QUIET)
1875 #define T_step_ge_uptr(s, a, e) T_flags_ge_ulong(a, e, T_CHECK_STEP(s))
1876 #define T_step_assert_ge_uptr(s, a, e) \
1877  T_flags_ge_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1878
1879 #define T_gt_uptr(a, e) T_flags_gt_ulong(a, e, 0)
1880 #define T_assert_gt_uptr(a, e) T_flags_gt_ulong(a, e, T_CHECK_STOP)
1881 #define T_quiet_gt_uptr(a, e) T_flags_gt_ulong(a, e, T_CHECK_QUIET)
1882 #define T_step_gt_uptr(s, a, e) T_flags_gt_ulong(a, e, T_CHECK_STEP(s))
1883 #define T_step_assert_gt_uptr(s, a, e) \
1884  T_flags_gt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1885
1886 #define T_le_uptr(a, e) T_flags_le_ulong(a, e, 0)
1887 #define T_assert_le_uptr(a, e) T_flags_le_ulong(a, e, T_CHECK_STOP)
1888 #define T_quiet_le_uptr(a, e) T_flags_le_ulong(a, e, T_CHECK_QUIET)
1889 #define T_step_le_uptr(s, a, e) T_flags_le_ulong(a, e, T_CHECK_STEP(s))
1890 #define T_step_assert_le_uptr(s, a, e) \
1891  T_flags_le_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1892
1893 #define T_lt_uptr(a, e) T_flags_lt_ulong(a, e, 0)
1894 #define T_assert_lt_uptr(a, e) T_flags_lt_ulong(a, e, T_CHECK_STOP)
1895 #define T_quiet_lt_uptr(a, e) T_flags_lt_ulong(a, e, T_CHECK_QUIET)
1896 #define T_step_lt_uptr(s, a, e) T_flags_lt_ulong(a, e, T_CHECK_STEP(s))
1897 #define T_step_assert_lt_uptr(s, a, e) \
1898  T_flags_lt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1899
1912 #define T_eq_ssz(a, e) T_flags_eq_long(a, e, 0)
1913 #define T_assert_eq_ssz(a, e) T_flags_eq_long(a, e, T_CHECK_STOP)
1914 #define T_quiet_eq_ssz(a, e) T_flags_eq_long(a, e, T_CHECK_QUIET)
1915 #define T_step_eq_ssz(s, a, e) T_flags_eq_long(a, e, T_CHECK_STEP(s))
1916 #define T_step_assert_eq_ssz(s, a, e) \
1917  T_flags_eq_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1918
1919 #define T_ne_ssz(a, e) T_flags_ne_long(a, e, 0)
1920 #define T_assert_ne_ssz(a, e) T_flags_ne_long(a, e, T_CHECK_STOP)
1921 #define T_quiet_ne_ssz(a, e) T_flags_ne_long(a, e, T_CHECK_QUIET)
1922 #define T_step_ne_ssz(s, a, e) T_flags_ne_long(a, e, T_CHECK_STEP(s))
1923 #define T_step_assert_ne_ssz(s, a, e) \
1924  T_flags_ne_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1925
1926 #define T_ge_ssz(a, e) T_flags_ge_long(a, e, 0)
1927 #define T_assert_ge_ssz(a, e) T_flags_ge_long(a, e, T_CHECK_STOP)
1928 #define T_quiet_ge_ssz(a, e) T_flags_ge_long(a, e, T_CHECK_QUIET)
1929 #define T_step_ge_ssz(s, a, e) T_flags_ge_long(a, e, T_CHECK_STEP(s))
1930 #define T_step_assert_ge_ssz(s, a, e) \
1931  T_flags_ge_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1932
1933 #define T_gt_ssz(a, e) T_flags_gt_long(a, e, 0)
1934 #define T_assert_gt_ssz(a, e) T_flags_gt_long(a, e, T_CHECK_STOP)
1935 #define T_quiet_gt_ssz(a, e) T_flags_gt_long(a, e, T_CHECK_QUIET)
1936 #define T_step_gt_ssz(s, a, e) T_flags_gt_long(a, e, T_CHECK_STEP(s))
1937 #define T_step_assert_gt_ssz(s, a, e) \
1938  T_flags_gt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1939
1940 #define T_le_ssz(a, e) T_flags_le_long(a, e, 0)
1941 #define T_assert_le_ssz(a, e) T_flags_le_long(a, e, T_CHECK_STOP)
1942 #define T_quiet_le_ssz(a, e) T_flags_le_long(a, e, T_CHECK_QUIET)
1943 #define T_step_le_ssz(s, a, e) T_flags_le_long(a, e, T_CHECK_STEP(s))
1944 #define T_step_assert_le_ssz(s, a, e) \
1945  T_flags_le_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1946
1947 #define T_lt_ssz(a, e) T_flags_lt_long(a, e, 0)
1948 #define T_assert_lt_ssz(a, e) T_flags_lt_long(a, e, T_CHECK_STOP)
1949 #define T_quiet_lt_ssz(a, e) T_flags_lt_long(a, e, T_CHECK_QUIET)
1950 #define T_step_lt_ssz(s, a, e) T_flags_lt_long(a, e, T_CHECK_STEP(s))
1951 #define T_step_assert_lt_ssz(s, a, e) \
1952  T_flags_lt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1953
1966 #define T_eq_sz(a, e) T_flags_eq_ulong(a, e, 0)
1967 #define T_assert_eq_sz(a, e) T_flags_eq_ulong(a, e, T_CHECK_STOP)
1968 #define T_quiet_eq_sz(a, e) T_flags_eq_ulong(a, e, T_CHECK_QUIET)
1969 #define T_step_eq_sz(s, a, e) T_flags_eq_ulong(a, e, T_CHECK_STEP(s))
1970 #define T_step_assert_eq_sz(s, a, e) \
1971  T_flags_eq_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1972
1973 #define T_ne_sz(a, e) T_flags_ne_ulong(a, e, 0)
1974 #define T_assert_ne_sz(a, e) T_flags_ne_ulong(a, e, T_CHECK_STOP)
1975 #define T_quiet_ne_sz(a, e) T_flags_ne_ulong(a, e, T_CHECK_QUIET)
1976 #define T_step_ne_sz(s, a, e) T_flags_ne_ulong(a, e, T_CHECK_STEP(s))
1977 #define T_step_assert_ne_sz(s, a, e) \
1978  T_flags_ne_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1979
1980 #define T_ge_sz(a, e) T_flags_ge_ulong(a, e, 0)
1981 #define T_assert_ge_sz(a, e) T_flags_ge_ulong(a, e, T_CHECK_STOP)
1982 #define T_quiet_ge_sz(a, e) T_flags_ge_ulong(a, e, T_CHECK_QUIET)
1983 #define T_step_ge_sz(s, a, e) T_flags_ge_ulong(a, e, T_CHECK_STEP(s))
1984 #define T_step_assert_ge_sz(s, a, e) \
1985  T_flags_ge_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1986
1987 #define T_gt_sz(a, e) T_flags_gt_ulong(a, e, 0)
1988 #define T_assert_gt_sz(a, e) T_flags_gt_ulong(a, e, T_CHECK_STOP)
1989 #define T_quiet_gt_sz(a, e) T_flags_gt_ulong(a, e, T_CHECK_QUIET)
1990 #define T_step_gt_sz(s, a, e) T_flags_gt_ulong(a, e, T_CHECK_STEP(s))
1991 #define T_step_assert_gt_sz(s, a, e) \
1992  T_flags_gt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
1993
1994 #define T_le_sz(a, e) T_flags_le_ulong(a, e, 0)
1995 #define T_assert_le_sz(a, e) T_flags_le_ulong(a, e, T_CHECK_STOP)
1996 #define T_quiet_le_sz(a, e) T_flags_le_ulong(a, e, T_CHECK_QUIET)
1997 #define T_step_le_sz(s, a, e) T_flags_le_ulong(a, e, T_CHECK_STEP(s))
1998 #define T_step_assert_le_sz(s, a, e) \
1999  T_flags_le_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
2000
2001 #define T_lt_sz(a, e) T_flags_lt_ulong(a, e, 0)
2002 #define T_assert_lt_sz(a, e) T_flags_lt_ulong(a, e, T_CHECK_STOP)
2003 #define T_quiet_lt_sz(a, e) T_flags_lt_ulong(a, e, T_CHECK_QUIET)
2004 #define T_step_lt_sz(s, a, e) T_flags_lt_ulong(a, e, T_CHECK_STEP(s))
2005 #define T_step_assert_lt_sz(s, a, e) \
2006  T_flags_lt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
2007
2020 const char *T_strerror(int);
2021
2022 #define T_eno(a, e) T_flags_eno(a, e, 0)
2023 #define T_assert_eno(a, e) T_flags_eno(a, e, T_CHECK_STOP)
2024 #define T_quiet_eno(a, e) T_flags_eno(a, e, T_CHECK_QUIET)
2025 #define T_step_eno(s, a, e) T_flags_eno(a, e, T_CHECK_STEP(s))
2026 #define T_step_assert_eno(s, a, e) \
2027  T_flags_eno(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
2028
2029 #define T_eno_success(a) T_flags_eno_success(a, 0)
2030 #define T_assert_eno_success(a) T_flags_eno_success(a, T_CHECK_STOP)
2031 #define T_quiet_eno_success(a) T_flags_eno_success(a, T_CHECK_QUIET)
2032 #define T_step_eno_success(s, a) T_flags_eno_success(a, T_CHECK_STEP(s))
2033 #define T_step_assert_eno_success(s, a) \
2034  T_flags_eno_success(a, T_CHECK_STEP(s) | T_CHECK_STOP)
2035
2036 #define T_psx_error(a, eno) T_flags_psx_error(a, eno, 0)
2037 #define T_assert_psx_error(a, eno) T_flags_psx_error(a, eno, T_CHECK_STOP)
2038 #define T_quiet_psx_error(a, eno) T_flags_psx_error(a, eno, T_CHECK_QUIET)
2039 #define T_step_psx_error(s, a, eno) T_flags_psx_error(a, eno, T_CHECK_STEP(s))
2040 #define T_step_assert_psx_error(s, a, eno) \
2041  T_flags_psx_error(a, eno, T_CHECK_STEP(s) | T_CHECK_STOP)
2042
2043 #define T_psx_success(a) T_flags_psx_success(a, 0)
2044 #define T_assert_psx_success(a) T_flags_psx_success(a, T_CHECK_STOP)
2045 #define T_quiet_psx_success(a) T_flags_psx_success(a, T_CHECK_QUIET)
2046 #define T_step_psx_success(s, a) T_flags_psx_success(a, T_CHECK_STEP(s))
2047 #define T_step_assert_psx_success(s, a) \
2048  T_flags_psx_success(a, T_CHECK_STEP(s) | T_CHECK_STOP)
2049
2052 #ifdef __rtems__
2053 void T_check_rsc(uint32_t, const T_check_context *, uint32_t);
2054
2055 #define T_flags_rsc(a, e, flags) \
2056 { \
2057  static const T_check_context T_check_instance = { \
2058  T_FILE_NAME, __LINE__, flags }; \
2059  T_check_rsc(a, &T_check_instance, e); \
2060 }
2061
2062 void T_check_rsc_success(uint32_t, const T_check_context *);
2063
2064 #define T_flags_rsc_success(a, flags) \
2065 { \
2066  static const T_check_context T_check_instance = { \
2067  T_FILE_NAME, __LINE__, flags }; \
2068  T_check_rsc_success(a, &T_check_instance); \
2069 }
2070
2081 #define T_rsc(a, e) T_flags_rsc(a, e, 0)
2082 #define T_assert_rsc(a, e) T_flags_rsc(a, e, T_CHECK_STOP)
2083 #define T_quiet_rsc(a, e) T_flags_rsc(a, e, T_CHECK_QUIET)
2084 #define T_step_rsc(s, a, e) T_flags_rsc(a, e, T_CHECK_STEP(s))
2085 #define T_step_assert_rsc(s, a, e) \
2086  T_flags_rsc(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
2087
2088 #define T_rsc_success(a) T_flags_rsc_success(a, 0)
2089 #define T_assert_rsc_success(a) T_flags_rsc_success(a, T_CHECK_STOP)
2090 #define T_quiet_rsc_success(a) T_flags_rsc_success(a, T_CHECK_QUIET)
2091 #define T_step_rsc_success(s, a) T_flags_rsc_success(a, T_CHECK_STEP(s))
2092 #define T_step_assert_rsc_success(s, a) \
2093  T_flags_rsc_success(a, T_CHECK_STEP(s) | T_CHECK_STOP)
2094
2096 #endif /* __rtems__ */
2097
2098 void T_plan(unsigned int);
2099
2100 #define T_step(s, ...) T_flags_true(true, T_CHECK_STEP(s), __VA_ARGS__)
2101 #define T_step_assert(s, ...) \
2102  T_flags_true(true, T_CHECK_STEP(s) | T_CHECK_STOP, __VA_ARGS__)
2103
2114 #ifdef __rtems__
2115 typedef CPU_Counter_ticks T_ticks;
2116 #else
2117 typedef unsigned long T_ticks;
2118 #endif
2119
2120 typedef uint64_t T_time;
2121
2122 /* More than enough for sizeof("18446744073.709552765") */
2123 typedef char T_time_string[24];
2124
2125 const char *T_time_to_string_ns(T_time, T_time_string);
2126
2127 const char *T_time_to_string_us(T_time, T_time_string);
2128
2129 const char *T_time_to_string_ms(T_time, T_time_string);
2130
2131 const char *T_time_to_string_s(T_time, T_time_string);
2132
2133 const char *T_ticks_to_string_ns(T_ticks, T_time_string);
2134
2135 const char *T_ticks_to_string_us(T_ticks, T_time_string);
2136
2137 const char *T_ticks_to_string_ms(T_ticks, T_time_string);
2138
2139 const char *T_ticks_to_string_s(T_ticks, T_time_string);
2140
2141 T_time T_ticks_to_time(T_ticks);
2142
2143 T_ticks T_time_to_ticks(T_time);
2144
2145 T_time T_seconds_and_nanoseconds_to_time(uint32_t, uint32_t);
2146
2147 void T_time_to_seconds_and_nanoseconds(T_time, uint32_t *, uint32_t *);
2148
2149 T_time T_now(void);
2150
2151 #ifdef __rtems__
2152 static inline T_ticks
2153 T_tick(void)
2154 {
2155  return _CPU_Counter_read();
2156 }
2157 #else
2158 T_ticks T_tick(void);
2159 #endif
2160
2161 T_time T_now_clock(void);
2162
2163 T_time T_now_dummy(void);
2164
2165 T_time T_now_tick(void);
2166
2167 T_time T_case_begin_time(void);
2168
2171 void *T_malloc(size_t);
2172
2173 void *T_calloc(size_t, size_t);
2174
2175 void *T_zalloc(size_t, void (*)(void *));
2176
2177 void T_free(void *);
2178
2179 void T_register(void);
2180
2181 typedef enum {
2182  T_EVENT_RUN_INITIALIZE_EARLY,
2183  T_EVENT_RUN_INITIALIZE_LATE,
2184  T_EVENT_CASE_EARLY,
2185  T_EVENT_CASE_BEGIN,
2186  T_EVENT_CASE_END,
2187  T_EVENT_CASE_LATE,
2188  T_EVENT_RUN_FINALIZE_EARLY,
2189  T_EVENT_RUN_FINALIZE_LATE
2190 } T_event;
2191
2192 typedef void (*T_action)(T_event, const char *);
2193
2194 typedef void (*T_putchar)(int, void *);
2195
2196 typedef struct {
2197  const char *name;
2198  char *buf;
2199  size_t buf_size;
2200  T_putchar putchar;
2201  void *putchar_arg;
2202  T_verbosity verbosity;
2203  T_time (*now)(void);
2204  size_t action_count;
2205  const T_action *actions;
2206 } T_config;
2207
2208 void T_putchar_default(int, void *);
2209
2210 int T_main(const T_config *);
2211
2212 bool T_is_runner(void);
2213
2214 void T_run_initialize(const T_config *);
2215
2216 void T_run_all(void);
2217
2218 void T_run_by_name(const char *);
2219
2220 void T_case_begin(const char *, const T_fixture *);
2221
2222 void T_case_end(void);
2223
2224 bool T_run_finalize(void);
2225
2226 void T_set_putchar(T_putchar, void *, T_putchar *, void **);
2227
2228 void *T_fixture_context(void);
2229
2230 void T_set_fixture_context(void *);
2231
2232 #ifdef __rtems__
2233 #define T_TEST_CASE_FIXTURE(name, fixture) \
2234 void T_case_body_##name(void); \
2235 T_case_context T_case_instance_##name = { \
2236  #name, \
2237  T_case_body_##name, \
2238  fixture, \
2239  NULL \
2240 }; \
2241 static T_case_context * const T_case_item_##name \
2242 __attribute((__section__(".rtemsroset._T.content.0." #name))) \
2243 __attribute((__used__)) = &T_case_instance_##name; \
2244 void T_case_body_##name(void)
2245 #else /* __rtems__ */
2246 #define T_TEST_CASE_FIXTURE(name, fixture) \
2247 void T_case_body_##name(void); \
2248 T_case_context T_case_instance_##name = { \
2249  #name, \
2250  T_case_body_##name, \
2251  fixture, \
2252  NULL \
2253 }; \
2254 __attribute((__constructor__)) static void \
2255 T_case_register_##name(void) \
2256 { \
2257  T_case_register(&T_case_instance_##name); \
2258 } \
2259 void T_case_body_##name(void)
2260 #endif /* __rtems__ */
2261
2262 #define T_TEST_CASE(name) T_TEST_CASE_FIXTURE(name, NULL)
2263
2264 void T_report_hash_sha256(T_event, const char *);
2265
2266 void T_check_heap(T_event, const char *);
2267
2268 #ifdef __rtems__
2269 void T_check_task_context(T_event, const char *);
2270
2271 void T_check_file_descriptors(T_event, const char *);
2272
2273 void T_check_rtems_barriers(T_event, const char *);
2274
2275 void T_check_rtems_extensions(T_event, const char *);
2276
2277 void T_check_rtems_message_queues(T_event, const char *);
2278
2279 void T_check_rtems_partitions(T_event, const char *);
2280
2281 void T_check_rtems_periods(T_event, const char *);
2282
2283 void T_check_rtems_regions(T_event, const char *);
2284
2285 void T_check_rtems_semaphores(T_event, const char *);
2286
2287 void T_check_rtems_tasks(T_event, const char *);
2288
2289 void T_check_rtems_timers(T_event, const char *);
2290
2291 void T_check_posix_keys(T_event, const char *);
2292
2293 void T_check_posix_message_queues(T_event, const char *);
2294
2295 void T_check_posix_semaphores(T_event, const char *);
2296
2297 void T_check_posix_shms(T_event, const char *);
2298
2299 void T_check_posix_threads(T_event, const char *);
2300
2301 void T_check_posix_timers(T_event, const char *);
2302 #endif /* __rtems__ */
2303
2314 typedef struct T_destructor {
2315  struct {
2316  struct T_destructor *le_next;
2317  struct T_destructor **le_prev;
2318  } node;
2319  void (*destroy)(struct T_destructor *);
2320 } T_destructor;
2321
2322 void T_add_destructor(T_destructor *, void (*)(T_destructor *));
2323
2324 void T_remove_destructor(T_destructor *);
2325
2339
2340 typedef struct {
2341  size_t sample_count;
2343
2344 typedef struct {
2345  const char *name;
2346  int flags;
2347  void (*setup)(void *);
2348  void (*body)(void *);
2349  bool (*teardown)(void *, T_ticks *, uint32_t, uint32_t, unsigned int);
2350  void *arg;
2352
2353 #define T_MEASURE_RUNTIME_ALLOW_CLOCK_ISR 0x1
2354
2355 #define T_MEASURE_RUNTIME_REPORT_SAMPLES 0x2
2356
2357 #define T_MEASURE_RUNTIME_DISABLE_VALID_CACHE 0x10
2358
2359 #define T_MEASURE_RUNTIME_DISABLE_HOT_CACHE 0x20
2360
2361 #define T_MEASURE_RUNTIME_DISABLE_DIRTY_CACHE 0x40
2362
2363 #define T_MEASURE_RUNTIME_DISABLE_MINOR_LOAD 0x80
2364
2365 #define T_MEASURE_RUNTIME_DISABLE_MAX_LOAD 0x100
2366
2367 T_measure_runtime_context *T_measure_runtime_create(
2368  const T_measure_runtime_config *);
2369
2370 void T_measure_runtime(T_measure_runtime_context *,
2371  const T_measure_runtime_request *);
2372
2375 #ifdef __cplusplus
2376 }
2377 #endif /* __cplusplus */
2378
2379 #endif /* THE_T_TEST_FRAMEWORK_H */
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
Definition: t.h:2344
Definition: t.h:2340
Definition: t.h:117
Definition: t.h:61
Definition: t-test-rtems-measure.c:45
Definition: b1553brm.c:75
Definition: t.h:2196
Definition: t.h:111
Definition: t.h:2314
Definition: t.h:90
Definition: mongoose.c:442
