RTEMS  5.1
rtems_object_api_class_information Struct Reference
#include <object.h>
rtems_id minimum_id
rtems_id maximum_id
uint32_t maximum
bool auto_extend
uint32_t unallocated
This structure is used to return information to the application about the objects configured for a specific API/Class combination.
Field Documentation
◆ auto_extend
bool rtems_object_api_class_information::auto_extend
This field indicates if the class is configured for auto-extend.
◆ maximum
uint32_t rtems_object_api_class_information::maximum
This field is the number of object instances configured for this class.
◆ maximum_id
rtems_id rtems_object_api_class_information::maximum_id
This field is the maximum valid object Id for this class.
◆ minimum_id
rtems_id rtems_object_api_class_information::minimum_id
This field is the minimum valid object Id for this class.
◆ unallocated
uint32_t rtems_object_api_class_information::unallocated
This field is the number of currently unallocated objects.
