RTEMS
5.1
Data Fields | |
uint32_t | flags |
uint32_t | block_size |
uint32_t | block_count |
rtems_nvdisk_device_ctl * | devices |
uint32_t | device_count |
uint32_t | cs_pages |
rtems_mutex | lock |
uint32_t | info_level |
The NV disk control structure for a single disk. There is one for each minor disk in the system.
uint32_t rtems_nvdisk::block_count |
The number of available blocks.
uint32_t rtems_nvdisk::block_size |
The block size for this disk.
uint32_t rtems_nvdisk::cs_pages |
The num of pages of checksums.
uint32_t rtems_nvdisk::device_count |
The number of NV devices.
rtems_nvdisk_device_ctl* rtems_nvdisk::devices |
The NV devices for this disk.
uint32_t rtems_nvdisk::flags |
configuration flags.
uint32_t rtems_nvdisk::info_level |
The info trace level.
rtems_mutex rtems_nvdisk::lock |
Mutex for threading protection.
