RTEMS  5.1
em_hw Struct Reference
uint8_t * hw_addr
uint8_t * flash_address
em_mac_type mac_type
em_phy_type phy_type
uint32_t phy_init_script
em_media_type media_type
void * back
em_fc_type fc
em_bus_speed bus_speed
em_bus_width bus_width
em_bus_type bus_type
struct em_eeprom_info eeprom
em_ms_type master_slave
em_ms_type original_master_slave
em_ffe_config ffe_config_state
uint32_t asf_firmware_present
uint32_t eeprom_semaphore_present
unsigned long io_base
uint32_t phy_id
uint32_t phy_revision
uint32_t phy_addr
uint32_t original_fc
uint32_t txcw
uint32_t autoneg_failed
uint32_t max_frame_size
uint32_t min_frame_size
uint32_t mc_filter_type
uint32_t num_mc_addrs
uint32_t collision_delta
uint32_t tx_packet_delta
uint32_t ledctl_default
uint32_t ledctl_mode1
uint32_t ledctl_mode2
boolean_t tx_pkt_filtering
struct em_host_mng_dhcp_cookie mng_cookie
uint16_t phy_spd_default
uint16_t autoneg_advertised
uint16_t pci_cmd_word
uint16_t fc_high_water
uint16_t fc_low_water
uint16_t fc_pause_time
uint16_t current_ifs_val
uint16_t ifs_min_val
uint16_t ifs_max_val
uint16_t ifs_step_size
uint16_t ifs_ratio
uint16_t device_id
uint16_t vendor_id
uint16_t subsystem_id
uint16_t subsystem_vendor_id
uint8_t revision_id
uint8_t autoneg
uint8_t mdix
uint8_t forced_speed_duplex
uint8_t wait_autoneg_complete
uint8_t dma_fairness
uint8_t mac_addr [NODE_ADDRESS_SIZE]
uint8_t perm_mac_addr [NODE_ADDRESS_SIZE]
boolean_t disable_polarity_correction
boolean_t speed_downgraded
em_smart_speed smart_speed
em_dsp_config dsp_config_state
boolean_t get_link_status
boolean_t serdes_link_down
boolean_t tbi_compatibility_en
boolean_t tbi_compatibility_on
boolean_t phy_reset_disable
boolean_t fc_send_xon
boolean_t fc_strict_ieee
boolean_t report_tx_early
boolean_t adaptive_ifs
boolean_t ifs_params_forced
boolean_t in_ifs_mode
boolean_t mng_reg_access_disabled
