RTEMS  5.1
if_em_hw.h
1 /*******************************************************************************
2
3  Copyright (c) 2001-2005, Intel Corporation
4  All rights reserved.
5
6  Redistribution and use in source and binary forms, with or without
7  modification, are permitted provided that the following conditions are met:
8
9  1. Redistributions of source code must retain the above copyright notice,
10  this list of conditions and the following disclaimer.
11
12  2. Redistributions in binary form must reproduce the above copyright
13  notice, this list of conditions and the following disclaimer in the
14  documentation and/or other materials provided with the distribution.
15
16  3. Neither the name of the Intel Corporation nor the names of its
17  contributors may be used to endorse or promote products derived from
18  this software without specific prior written permission.
19
20  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
21  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22  IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23  ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
24  LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25  CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
26  SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
27  INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
28  CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
29  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
30  POSSIBILITY OF SUCH DAMAGE.
31
32 *******************************************************************************/
33
34 /*$FreeBSD: /repoman/r/ncvs/src/sys/dev/em/if_em_hw.h,v 1.15 2005/05/26 23:32:02 tackerman Exp $*/
35 /* if_em_hw.h
36  * Structures, enums, and macros for the MAC
37  */
38
39 #ifndef _EM_HW_H_
40 #define _EM_HW_H_
41
42 #ifndef __rtems__
43 #include <dev/em/if_em_osdep.h>
44 #else
45 #include "if_em_osdep.h"
46 #endif
47
48
49 /* Forward declarations of structures used by the shared code */
50 struct em_hw;
51 struct em_hw_stats;
52
53 /* Enumerated types specific to the e1000 hardware */
54 /* Media Access Controlers */
55 typedef enum {
56  em_undefined = 0,
57  em_82542_rev2_0,
58  em_82542_rev2_1,
59  em_82543,
60  em_82544,
61  em_82540,
62  em_82545,
63  em_82545_rev_3,
64  em_82546,
65  em_82546_rev_3,
66  em_82541,
67  em_82541_rev_2,
68  em_82547,
69  em_82547_rev_2,
70  em_82573,
71  em_num_macs
72 } em_mac_type;
73
74 typedef enum {
75  em_eeprom_uninitialized = 0,
76  em_eeprom_spi,
77  em_eeprom_microwire,
78  em_eeprom_flash,
79  em_num_eeprom_types
80 } em_eeprom_type;
81
82 /* Media Types */
83 typedef enum {
84  em_media_type_copper = 0,
85  em_media_type_fiber = 1,
86  em_media_type_internal_serdes = 2,
87  em_num_media_types
88 } em_media_type;
89
90 typedef enum {
91  em_10_half = 0,
92  em_10_full = 1,
93  em_100_half = 2,
94  em_100_full = 3
95 } em_speed_duplex_type;
96
97 /* Flow Control Settings */
98 typedef enum {
99  em_fc_none = 0,
100  em_fc_rx_pause = 1,
101  em_fc_tx_pause = 2,
102  em_fc_full = 3,
103  em_fc_default = 0xFF
104 } em_fc_type;
105
106 /* PCI bus types */
107 typedef enum {
108  em_bus_type_unknown = 0,
109  em_bus_type_pci,
110  em_bus_type_pcix,
111  em_bus_type_pci_express,
112  em_bus_type_reserved
113 } em_bus_type;
114
115 /* PCI bus speeds */
116 typedef enum {
117  em_bus_speed_unknown = 0,
118  em_bus_speed_33,
119  em_bus_speed_66,
120  em_bus_speed_100,
121  em_bus_speed_120,
122  em_bus_speed_133,
123  em_bus_speed_2500,
124  em_bus_speed_reserved
125 } em_bus_speed;
126
127 /* PCI bus widths */
128 typedef enum {
129  em_bus_width_unknown = 0,
130  em_bus_width_32,
131  em_bus_width_64,
132  em_bus_width_pciex_1,
133  em_bus_width_pciex_4,
134  em_bus_width_reserved
135 } em_bus_width;
136
137 /* PHY status info structure and supporting enums */
138 typedef enum {
139  em_cable_length_50 = 0,
140  em_cable_length_50_80,
141  em_cable_length_80_110,
142  em_cable_length_110_140,
143  em_cable_length_140,
144  em_cable_length_undefined = 0xFF
145 } em_cable_length;
146
147 typedef enum {
148  em_igp_cable_length_10 = 10,
149  em_igp_cable_length_20 = 20,
150  em_igp_cable_length_30 = 30,
151  em_igp_cable_length_40 = 40,
152  em_igp_cable_length_50 = 50,
153  em_igp_cable_length_60 = 60,
154  em_igp_cable_length_70 = 70,
155  em_igp_cable_length_80 = 80,
156  em_igp_cable_length_90 = 90,
157  em_igp_cable_length_100 = 100,
158  em_igp_cable_length_110 = 110,
159  em_igp_cable_length_120 = 120,
160  em_igp_cable_length_130 = 130,
161  em_igp_cable_length_140 = 140,
162  em_igp_cable_length_150 = 150,
163  em_igp_cable_length_160 = 160,
164  em_igp_cable_length_170 = 170,
165  em_igp_cable_length_180 = 180
166 } em_igp_cable_length;
167
168 typedef enum {
169  em_10bt_ext_dist_enable_normal = 0,
170  em_10bt_ext_dist_enable_lower,
171  em_10bt_ext_dist_enable_undefined = 0xFF
172 } em_10bt_ext_dist_enable;
173
174 typedef enum {
175  em_rev_polarity_normal = 0,
176  em_rev_polarity_reversed,
177  em_rev_polarity_undefined = 0xFF
178 } em_rev_polarity;
179
180 typedef enum {
181  em_downshift_normal = 0,
182  em_downshift_activated,
183  em_downshift_undefined = 0xFF
184 } em_downshift;
185
186 typedef enum {
187  em_smart_speed_default = 0,
188  em_smart_speed_on,
189  em_smart_speed_off
190 } em_smart_speed;
191
192 typedef enum {
193  em_polarity_reversal_enabled = 0,
194  em_polarity_reversal_disabled,
195  em_polarity_reversal_undefined = 0xFF
196 } em_polarity_reversal;
197
198 typedef enum {
199  em_auto_x_mode_manual_mdi = 0,
200  em_auto_x_mode_manual_mdix,
201  em_auto_x_mode_auto1,
202  em_auto_x_mode_auto2,
203  em_auto_x_mode_undefined = 0xFF
204 } em_auto_x_mode;
205
206 typedef enum {
207  em_1000t_rx_status_not_ok = 0,
208  em_1000t_rx_status_ok,
209  em_1000t_rx_status_undefined = 0xFF
210 } em_1000t_rx_status;
211
212 typedef enum {
213  em_phy_m88 = 0,
214  em_phy_igp,
215  em_phy_igp_2,
216  em_phy_undefined = 0xFF
217 } em_phy_type;
218
219 typedef enum {
220  em_ms_hw_default = 0,
221  em_ms_force_master,
222  em_ms_force_slave,
223  em_ms_auto
224 } em_ms_type;
225
226 typedef enum {
227  em_ffe_config_enabled = 0,
228  em_ffe_config_active,
229  em_ffe_config_blocked
230 } em_ffe_config;
231
232 typedef enum {
233  em_dsp_config_disabled = 0,
234  em_dsp_config_enabled,
235  em_dsp_config_activated,
236  em_dsp_config_undefined = 0xFF
237 } em_dsp_config;
238
239 struct em_phy_info {
240  em_cable_length cable_length;
241  em_10bt_ext_dist_enable extended_10bt_distance;
242  em_rev_polarity cable_polarity;
243  em_downshift downshift;
244  em_polarity_reversal polarity_correction;
245  em_auto_x_mode mdix_mode;
246  em_1000t_rx_status local_rx;
247  em_1000t_rx_status remote_rx;
248 };
249
250 struct em_phy_stats {
251  uint32_t idle_errors;
252  uint32_t receive_errors;
253 };
254
256  em_eeprom_type type;
257  uint16_t word_size;
258  uint16_t opcode_bits;
259  uint16_t address_bits;
260  uint16_t delay_usec;
261  uint16_t page_size;
262  boolean_t use_eerd;
263  boolean_t use_eewr;
264 };
265
266 /* Flex ASF Information */
267 #define E1000_HOST_IF_MAX_SIZE 2048
268
269 typedef enum {
270  em_byte_align = 0,
271  em_word_align = 1,
272  em_dword_align = 2
273 } em_align_type;
274
275
276
277 /* Error Codes */
278 #define E1000_SUCCESS 0
279 #define E1000_ERR_EEPROM 1
280 #define E1000_ERR_PHY 2
281 #define E1000_ERR_CONFIG 3
282 #define E1000_ERR_PARAM 4
283 #define E1000_ERR_MAC_TYPE 5
284 #define E1000_ERR_PHY_TYPE 6
285 #define E1000_ERR_RESET 9
286 #define E1000_ERR_MASTER_REQUESTS_PENDING 10
287 #define E1000_ERR_HOST_INTERFACE_COMMAND 11
288 #define E1000_BLK_PHY_RESET 12
289
290 /* Function prototypes */
291 /* Initialization */
292 int32_t em_reset_hw(struct em_hw *hw);
293 int32_t em_init_hw(struct em_hw *hw);
294 int32_t em_id_led_init(struct em_hw * hw);
295 int32_t em_set_mac_type(struct em_hw *hw);
296 void em_set_media_type(struct em_hw *hw);
297
298 /* Link Configuration */
299 int32_t em_setup_link(struct em_hw *hw);
300 int32_t em_phy_setup_autoneg(struct em_hw *hw);
301 void em_config_collision_dist(struct em_hw *hw);
302 int32_t em_config_fc_after_link_up(struct em_hw *hw);
303 int32_t em_check_for_link(struct em_hw *hw);
304 int32_t em_get_speed_and_duplex(struct em_hw *hw, uint16_t * speed, uint16_t * duplex);
305 int32_t em_wait_autoneg(struct em_hw *hw);
306 int32_t em_force_mac_fc(struct em_hw *hw);
307
308 /* PHY */
309 int32_t em_read_phy_reg(struct em_hw *hw, uint32_t reg_addr, uint16_t *phy_data);
310 int32_t em_write_phy_reg(struct em_hw *hw, uint32_t reg_addr, uint16_t data);
311 int32_t em_phy_hw_reset(struct em_hw *hw);
312 int32_t em_phy_reset(struct em_hw *hw);
313 int32_t em_detect_gig_phy(struct em_hw *hw);
314 int32_t em_phy_get_info(struct em_hw *hw, struct em_phy_info *phy_info);
315 int32_t em_phy_m88_get_info(struct em_hw *hw, struct em_phy_info *phy_info);
316 int32_t em_phy_igp_get_info(struct em_hw *hw, struct em_phy_info *phy_info);
317 int32_t em_get_cable_length(struct em_hw *hw, uint16_t *min_length, uint16_t *max_length);
318 int32_t em_check_polarity(struct em_hw *hw, uint16_t *polarity);
319 int32_t em_check_downshift(struct em_hw *hw);
320 int32_t em_validate_mdi_setting(struct em_hw *hw);
321
322 /* EEPROM Functions */
323 int32_t em_init_eeprom_params(struct em_hw *hw);
324 boolean_t em_is_onboard_nvm_eeprom(struct em_hw *hw);
325 int32_t em_read_eeprom_eerd(struct em_hw *hw, uint16_t offset, uint16_t words, uint16_t *data);
326 int32_t em_write_eeprom_eewr(struct em_hw *hw, uint16_t offset, uint16_t words, uint16_t *data);
327 int32_t em_poll_eerd_eewr_done(struct em_hw *hw, int eerd);
328
329 /* MNG HOST IF functions */
330 uint32_t em_enable_mng_pass_thru(struct em_hw *hw);
331
332 #define E1000_MNG_DHCP_TX_PAYLOAD_CMD 64
333 #define E1000_HI_MAX_MNG_DATA_LENGTH 0x6F8 /* Host Interface data length */
334
335 #define E1000_MNG_DHCP_COMMAND_TIMEOUT 10 /* Time in ms to process MNG command */
336 #define E1000_MNG_DHCP_COOKIE_OFFSET 0x6F0 /* Cookie offset */
337 #define E1000_MNG_DHCP_COOKIE_LENGTH 0x10 /* Cookie length */
338 #define E1000_MNG_IAMT_MODE 0x3
339 #define E1000_IAMT_SIGNATURE 0x544D4149 /* Intel(R) Active Management Technology signature */
340
341 #define E1000_MNG_DHCP_COOKIE_STATUS_PARSING_SUPPORT 0x1 /* DHCP parsing enabled */
342 #define E1000_MNG_DHCP_COOKIE_STATUS_VLAN_SUPPORT 0x2 /* DHCP parsing enabled */
343 #define E1000_VFTA_ENTRY_SHIFT 0x5
344 #define E1000_VFTA_ENTRY_MASK 0x7F
345 #define E1000_VFTA_ENTRY_BIT_SHIFT_MASK 0x1F
346
348  uint8_t command_id;
349  uint8_t checksum;
350  uint16_t reserved1;
351  uint16_t reserved2;
352  uint16_t command_length;
353 };
354
356  struct em_host_mng_command_header command_header; /* Command Head/Command Result Head has 4 bytes */
357  uint8_t command_data[E1000_HI_MAX_MNG_DATA_LENGTH]; /* Command data can length 0..0x658*/
358 };
359 #ifdef __BIG_ENDIAN
361  uint32_t signature;
362  uint16_t vlan_id;
363  uint8_t reserved0;
364  uint8_t status;
365  uint32_t reserved1;
366  uint8_t checksum;
367  uint8_t reserved3;
368  uint16_t reserved2;
369 };
370 #else
372  uint32_t signature;
373  uint8_t status;
374  uint8_t reserved0;
375  uint16_t vlan_id;
376  uint32_t reserved1;
377  uint16_t reserved2;
378  uint8_t reserved3;
379  uint8_t checksum;
380 };
381 #endif
382
383 int32_t em_mng_write_dhcp_info(struct em_hw *hw, uint8_t *buffer,
384  uint16_t length);
385 boolean_t em_check_mng_mode(struct em_hw *hw);
386 boolean_t em_enable_tx_pkt_filtering(struct em_hw *hw);
387 int32_t em_mng_enable_host_if(struct em_hw *hw);
388 int32_t em_mng_host_if_write(struct em_hw *hw, uint8_t *buffer,
389  uint16_t length, uint16_t offset, uint8_t *sum);
390 int32_t em_mng_write_cmd_header(struct em_hw* hw,
391  struct em_host_mng_command_header* hdr);
392
393 int32_t em_mng_write_commit(struct em_hw *hw);
394
395 int32_t em_read_eeprom(struct em_hw *hw, uint16_t reg, uint16_t words, uint16_t *data);
396 int32_t em_validate_eeprom_checksum(struct em_hw *hw);
397 int32_t em_update_eeprom_checksum(struct em_hw *hw);
398 int32_t em_write_eeprom(struct em_hw *hw, uint16_t reg, uint16_t words, uint16_t *data);
399 int32_t em_read_part_num(struct em_hw *hw, uint32_t * part_num);
400 int32_t em_read_mac_addr(struct em_hw * hw);
401 int32_t em_swfw_sync_acquire(struct em_hw *hw, uint16_t mask);
402 void em_swfw_sync_release(struct em_hw *hw, uint16_t mask);
403
404 /* Filters (multicast, vlan, receive) */
405 void em_init_rx_addrs(struct em_hw *hw);
406 void em_mc_addr_list_update(struct em_hw *hw, uint8_t * mc_addr_list, uint32_t mc_addr_count, uint32_t pad, uint32_t rar_used_count);
407 uint32_t em_hash_mc_addr(struct em_hw *hw, uint8_t * mc_addr);
408 void em_mta_set(struct em_hw *hw, uint32_t hash_value);
409 void em_rar_set(struct em_hw *hw, uint8_t * mc_addr, uint32_t rar_index);
410 void em_write_vfta(struct em_hw *hw, uint32_t offset, uint32_t value);
411 void em_clear_vfta(struct em_hw *hw);
412
413 /* LED functions */
414 int32_t em_setup_led(struct em_hw *hw);
415 int32_t em_cleanup_led(struct em_hw *hw);
416 int32_t em_led_on(struct em_hw *hw);
417 int32_t em_led_off(struct em_hw *hw);
418
419 /* Adaptive IFS Functions */
420
421 /* Everything else */
422 void em_clear_hw_cntrs(struct em_hw *hw);
423 void em_reset_adaptive(struct em_hw *hw);
424 void em_update_adaptive(struct em_hw *hw);
425 void em_tbi_adjust_stats(struct em_hw *hw, struct em_hw_stats *stats, uint32_t frame_len, uint8_t * mac_addr);
426 void em_get_bus_info(struct em_hw *hw);
427 void em_pci_set_mwi(struct em_hw *hw);
428 void em_pci_clear_mwi(struct em_hw *hw);
429 void em_read_pci_cfg(struct em_hw *hw, uint32_t reg, uint16_t * value);
430 void em_write_pci_cfg(struct em_hw *hw, uint32_t reg, uint16_t * value);
431 /* Port I/O is only supported on 82544 and newer */
432 uint32_t em_io_read(struct em_hw *hw, unsigned long port);
433 uint32_t em_read_reg_io(struct em_hw *hw, uint32_t offset);
434 void em_io_write(struct em_hw *hw, unsigned long port, uint32_t value);
435 void em_write_reg_io(struct em_hw *hw, uint32_t offset, uint32_t value);
436 int32_t em_config_dsp_after_link_change(struct em_hw *hw, boolean_t link_up);
437 int32_t em_set_d3_lplu_state(struct em_hw *hw, boolean_t active);
438 int32_t em_set_d0_lplu_state(struct em_hw *hw, boolean_t active);
439 void em_set_pci_express_master_disable(struct em_hw *hw);
440 void em_enable_pciex_master(struct em_hw *hw);
441 int32_t em_disable_pciex_master(struct em_hw *hw);
442 int32_t em_get_auto_rd_done(struct em_hw *hw);
443 int32_t em_get_phy_cfg_done(struct em_hw *hw);
444 int32_t em_get_software_semaphore(struct em_hw *hw);
445 void em_release_software_semaphore(struct em_hw *hw);
446 int32_t em_check_phy_reset_block(struct em_hw *hw);
447 int32_t em_get_hw_eeprom_semaphore(struct em_hw *hw);
448 void em_put_hw_eeprom_semaphore(struct em_hw *hw);
449 int32_t em_commit_shadow_ram(struct em_hw *hw);
450 uint8_t em_arc_subsystem_valid(struct em_hw *hw);
451
452 #define E1000_READ_REG_IO(a, reg) \
453  em_read_reg_io((a), E1000_##reg)
454 #define E1000_WRITE_REG_IO(a, reg, val) \
455  em_write_reg_io((a), E1000_##reg, val)
456
457 /* PCI Device IDs */
458 #define E1000_DEV_ID_82542 0x1000
459 #define E1000_DEV_ID_82543GC_FIBER 0x1001
460 #define E1000_DEV_ID_82543GC_COPPER 0x1004
461 #define E1000_DEV_ID_82544EI_COPPER 0x1008
462 #define E1000_DEV_ID_82544EI_FIBER 0x1009
463 #define E1000_DEV_ID_82544GC_COPPER 0x100C
464 #define E1000_DEV_ID_82544GC_LOM 0x100D
465 #define E1000_DEV_ID_82540EM 0x100E
466 #define E1000_DEV_ID_82541ER_LOM 0x1014
467 #define E1000_DEV_ID_82540EM_LOM 0x1015
468 #define E1000_DEV_ID_82540EP_LOM 0x1016
469 #define E1000_DEV_ID_82540EP 0x1017
470 #define E1000_DEV_ID_82540EP_LP 0x101E
471 #define E1000_DEV_ID_82545EM_COPPER 0x100F
472 #define E1000_DEV_ID_82545EM_FIBER 0x1011
473 #define E1000_DEV_ID_82545GM_COPPER 0x1026
474 #define E1000_DEV_ID_82545GM_FIBER 0x1027
475 #define E1000_DEV_ID_82545GM_SERDES 0x1028
476 #define E1000_DEV_ID_82546EB_COPPER 0x1010
477 #define E1000_DEV_ID_82546EB_FIBER 0x1012
478 #define E1000_DEV_ID_82546EB_QUAD_COPPER 0x101D
479 #define E1000_DEV_ID_82541EI 0x1013
480 #define E1000_DEV_ID_82541EI_MOBILE 0x1018
481 #define E1000_DEV_ID_82541ER 0x1078
482 #define E1000_DEV_ID_82547GI 0x1075
483 #define E1000_DEV_ID_82541GI 0x1076
484 #define E1000_DEV_ID_82541GI_MOBILE 0x1077
485 #define E1000_DEV_ID_82541GI_LF 0x107C
486 #define E1000_DEV_ID_82546GB_COPPER 0x1079
487 #define E1000_DEV_ID_82546GB_FIBER 0x107A
488 #define E1000_DEV_ID_82546GB_SERDES 0x107B
489 #define E1000_DEV_ID_82546GB_PCIE 0x108A
490 #define E1000_DEV_ID_82547EI 0x1019
491 #define E1000_DEV_ID_82547EI_MOBILE 0x101A
492 #define E1000_DEV_ID_82573E 0x108B
493 #define E1000_DEV_ID_82573E_IAMT 0x108C
494
495 #define E1000_DEV_ID_82546GB_QUAD_COPPER 0x1099
496
497 #define NODE_ADDRESS_SIZE 6
498 #define ETH_LENGTH_OF_ADDRESS 6
499
500 /* MAC decode size is 128K - This is the size of BAR0 */
501 #define MAC_DECODE_SIZE (128 * 1024)
502
503 #define E1000_82542_2_0_REV_ID 2
504 #define E1000_82542_2_1_REV_ID 3
505 #define E1000_REVISION_0 0
506 #define E1000_REVISION_1 1
507 #define E1000_REVISION_2 2
508 #define E1000_REVISION_3 3
509
510 #define SPEED_10 10
511 #define SPEED_100 100
512 #define SPEED_1000 1000
513 #define HALF_DUPLEX 1
514 #define FULL_DUPLEX 2
515
516 /* The sizes (in bytes) of a ethernet packet */
517 #define ENET_HEADER_SIZE 14
518 #define MAXIMUM_ETHERNET_FRAME_SIZE 1518 /* With FCS */
519 #define MINIMUM_ETHERNET_FRAME_SIZE 64 /* With FCS */
520 #define ETHERNET_FCS_SIZE 4
521 #define MAXIMUM_ETHERNET_PACKET_SIZE \
522  (MAXIMUM_ETHERNET_FRAME_SIZE - ETHERNET_FCS_SIZE)
523 #define MINIMUM_ETHERNET_PACKET_SIZE \
524  (MINIMUM_ETHERNET_FRAME_SIZE - ETHERNET_FCS_SIZE)
525 #define CRC_LENGTH ETHERNET_FCS_SIZE
526 #define MAX_JUMBO_FRAME_SIZE 0x3F00
527
528
529 /* 802.1q VLAN Packet Sizes */
530 #define VLAN_TAG_SIZE 4 /* 802.3ac tag (not DMAed) */
531
532 /* Ethertype field values */
533 #define ETHERNET_IEEE_VLAN_TYPE 0x8100 /* 802.3ac packet */
534 #define ETHERNET_IP_TYPE 0x0800 /* IP packets */
535 #define ETHERNET_ARP_TYPE 0x0806 /* Address Resolution Protocol (ARP) */
536
537 /* Packet Header defines */
538 #define IP_PROTOCOL_TCP 6
539 #define IP_PROTOCOL_UDP 0x11
540
541 /* This defines the bits that are set in the Interrupt Mask
542  * Set/Read Register. Each bit is documented below:
543  * o RXDMT0 = Receive Descriptor Minimum Threshold hit (ring 0)
544  * o RXSEQ = Receive Sequence Error
545  */
546 #define POLL_IMS_ENABLE_MASK ( \
547  E1000_IMS_RXDMT0 | \
548  E1000_IMS_RXSEQ)
549
550 /* This defines the bits that are set in the Interrupt Mask
551  * Set/Read Register. Each bit is documented below:
552  * o RXT0 = Receiver Timer Interrupt (ring 0)
553  * o TXDW = Transmit Descriptor Written Back
554  * o RXDMT0 = Receive Descriptor Minimum Threshold hit (ring 0)
555  * o RXSEQ = Receive Sequence Error
556  * o LSC = Link Status Change
557  */
558 #define IMS_ENABLE_MASK ( \
559  E1000_IMS_RXT0 | \
560  E1000_IMS_TXDW | \
561  E1000_IMS_RXDMT0 | \
562  E1000_IMS_RXSEQ | \
563  E1000_IMS_LSC)
564
565
566 /* Number of high/low register pairs in the RAR. The RAR (Receive Address
567  * Registers) holds the directed and multicast addresses that we monitor. We
568  * reserve one of these spots for our directed address, allowing us room for
569  * E1000_RAR_ENTRIES - 1 multicast addresses.
570  */
571 #define E1000_RAR_ENTRIES 15
572
573 #define MIN_NUMBER_OF_DESCRIPTORS 8
574 #define MAX_NUMBER_OF_DESCRIPTORS 0xFFF8
575
576 /* Receive Descriptor */
577 struct em_rx_desc {
578  uint64_t buffer_addr; /* Address of the descriptor's data buffer */
579  uint16_t length; /* Length of data DMAed into data buffer */
580  uint16_t csum; /* Packet checksum */
581  uint8_t status; /* Descriptor status */
582  uint8_t errors; /* Descriptor Errors */
583  uint16_t special;
584 };
585
586 /* Receive Descriptor - Extended */
588  struct {
589  uint64_t buffer_addr;
590  uint64_t reserved;
591  } read;
592  struct {
593  struct {
594  uint32_t mrq; /* Multiple Rx Queues */
595  union {
596  uint32_t rss; /* RSS Hash */
597  struct {
598  uint16_t ip_id; /* IP id */
599  uint16_t csum; /* Packet Checksum */
600  } csum_ip;
601  } hi_dword;
602  } lower;
603  struct {
604  uint32_t status_error; /* ext status/error */
605  uint16_t length;
606  uint16_t vlan; /* VLAN tag */
607  } upper;
608  } wb; /* writeback */
609 };
610
611 #define MAX_PS_BUFFERS 4
612 /* Receive Descriptor - Packet Split */
614  struct {
615  /* one buffer for protocol header(s), three data buffers */
616  uint64_t buffer_addr[MAX_PS_BUFFERS];
617  } read;
618  struct {
619  struct {
620  uint32_t mrq; /* Multiple Rx Queues */
621  union {
622  uint32_t rss; /* RSS Hash */
623  struct {
624  uint16_t ip_id; /* IP id */
625  uint16_t csum; /* Packet Checksum */
626  } csum_ip;
627  } hi_dword;
628  } lower;
629  struct {
630  uint32_t status_error; /* ext status/error */
631  uint16_t length0; /* length of buffer 0 */
632  uint16_t vlan; /* VLAN tag */
633  } middle;
634  struct {
635  uint16_t header_status;
636  uint16_t length[3]; /* length of buffers 1-3 */
637  } upper;
638  uint64_t reserved;
639  } wb; /* writeback */
640 };
641
642 /* Receive Decriptor bit definitions */
643 #define E1000_RXD_STAT_DD 0x01 /* Descriptor Done */
644 #define E1000_RXD_STAT_EOP 0x02 /* End of Packet */
645 #define E1000_RXD_STAT_IXSM 0x04 /* Ignore checksum */
646 #define E1000_RXD_STAT_VP 0x08 /* IEEE VLAN Packet */
647 #define E1000_RXD_STAT_UDPCS 0x10 /* UDP xsum caculated */
648 #define E1000_RXD_STAT_TCPCS 0x20 /* TCP xsum calculated */
649 #define E1000_RXD_STAT_IPCS 0x40 /* IP xsum calculated */
650 #define E1000_RXD_STAT_PIF 0x80 /* passed in-exact filter */
651 #define E1000_RXD_STAT_IPIDV 0x200 /* IP identification valid */
652 #define E1000_RXD_STAT_UDPV 0x400 /* Valid UDP checksum */
653 #define E1000_RXD_STAT_ACK 0x8000 /* ACK Packet indication */
654 #define E1000_RXD_ERR_CE 0x01 /* CRC Error */
655 #define E1000_RXD_ERR_SE 0x02 /* Symbol Error */
656 #define E1000_RXD_ERR_SEQ 0x04 /* Sequence Error */
657 #define E1000_RXD_ERR_CXE 0x10 /* Carrier Extension Error */
658 #define E1000_RXD_ERR_TCPE 0x20 /* TCP/UDP Checksum Error */
659 #define E1000_RXD_ERR_IPE 0x40 /* IP Checksum Error */
660 #define E1000_RXD_ERR_RXE 0x80 /* Rx Data Error */
661 #define E1000_RXD_SPC_VLAN_MASK 0x0FFF /* VLAN ID is in lower 12 bits */
662 #define E1000_RXD_SPC_PRI_MASK 0xE000 /* Priority is in upper 3 bits */
663 #define E1000_RXD_SPC_PRI_SHIFT 13
664 #define E1000_RXD_SPC_CFI_MASK 0x1000 /* CFI is bit 12 */
665 #define E1000_RXD_SPC_CFI_SHIFT 12
666
667 #define E1000_RXDEXT_STATERR_CE 0x01000000
668 #define E1000_RXDEXT_STATERR_SE 0x02000000
669 #define E1000_RXDEXT_STATERR_SEQ 0x04000000
670 #define E1000_RXDEXT_STATERR_CXE 0x10000000
671 #define E1000_RXDEXT_STATERR_TCPE 0x20000000
672 #define E1000_RXDEXT_STATERR_IPE 0x40000000
673 #define E1000_RXDEXT_STATERR_RXE 0x80000000
674
675 #define E1000_RXDPS_HDRSTAT_HDRSP 0x00008000
676 #define E1000_RXDPS_HDRSTAT_HDRLEN_MASK 0x000003FF
677
678 /* mask to determine if packets should be dropped due to frame errors */
679 #define E1000_RXD_ERR_FRAME_ERR_MASK ( \
680  E1000_RXD_ERR_CE | \
681  E1000_RXD_ERR_SE | \
682  E1000_RXD_ERR_SEQ | \
683  E1000_RXD_ERR_CXE | \
684  E1000_RXD_ERR_RXE)
685
686
687 /* Same mask, but for extended and packet split descriptors */
688 #define E1000_RXDEXT_ERR_FRAME_ERR_MASK ( \
689  E1000_RXDEXT_STATERR_CE | \
690  E1000_RXDEXT_STATERR_SE | \
691  E1000_RXDEXT_STATERR_SEQ | \
692  E1000_RXDEXT_STATERR_CXE | \
693  E1000_RXDEXT_STATERR_RXE)
694
695 /* Transmit Descriptor */
696 struct em_tx_desc {
697  uint64_t buffer_addr; /* Address of the descriptor's data buffer */
698  union {
699  uint32_t data;
700  struct {
701  uint16_t length; /* Data buffer length */
702  uint8_t cso; /* Checksum offset */
703  uint8_t cmd; /* Descriptor control */
704  } flags;
705  } lower;
706  union {
707  uint32_t data;
708  struct {
709  uint8_t status; /* Descriptor status */
710  uint8_t css; /* Checksum start */
711  uint16_t special;
712  } fields;
713  } upper;
714 };
715
716 /* Transmit Descriptor bit definitions */
717 #define E1000_TXD_DTYP_D 0x00100000 /* Data Descriptor */
718 #define E1000_TXD_DTYP_C 0x00000000 /* Context Descriptor */
719 #define E1000_TXD_POPTS_IXSM 0x01 /* Insert IP checksum */
720 #define E1000_TXD_POPTS_TXSM 0x02 /* Insert TCP/UDP checksum */
721 #define E1000_TXD_CMD_EOP 0x01000000 /* End of Packet */
722 #define E1000_TXD_CMD_IFCS 0x02000000 /* Insert FCS (Ethernet CRC) */
723 #define E1000_TXD_CMD_IC 0x04000000 /* Insert Checksum */
724 #define E1000_TXD_CMD_RS 0x08000000 /* Report Status */
725 #define E1000_TXD_CMD_RPS 0x10000000 /* Report Packet Sent */
726 #define E1000_TXD_CMD_DEXT 0x20000000 /* Descriptor extension (0 = legacy) */
727 #define E1000_TXD_CMD_VLE 0x40000000 /* Add VLAN tag */
728 #define E1000_TXD_CMD_IDE 0x80000000 /* Enable Tidv register */
729 #define E1000_TXD_STAT_DD 0x00000001 /* Descriptor Done */
730 #define E1000_TXD_STAT_EC 0x00000002 /* Excess Collisions */
731 #define E1000_TXD_STAT_LC 0x00000004 /* Late Collisions */
732 #define E1000_TXD_STAT_TU 0x00000008 /* Transmit underrun */
733 #define E1000_TXD_CMD_TCP 0x01000000 /* TCP packet */
734 #define E1000_TXD_CMD_IP 0x02000000 /* IP packet */
735 #define E1000_TXD_CMD_TSE 0x04000000 /* TCP Seg enable */
736 #define E1000_TXD_STAT_TC 0x00000004 /* Tx Underrun */
737
738 /* Offload Context Descriptor */
740  union {
741  uint32_t ip_config;
742  struct {
743  uint8_t ipcss; /* IP checksum start */
744  uint8_t ipcso; /* IP checksum offset */
745  uint16_t ipcse; /* IP checksum end */
746  } ip_fields;
747  } lower_setup;
748  union {
749  uint32_t tcp_config;
750  struct {
751  uint8_t tucss; /* TCP checksum start */
752  uint8_t tucso; /* TCP checksum offset */
753  uint16_t tucse; /* TCP checksum end */
754  } tcp_fields;
755  } upper_setup;
756  uint32_t cmd_and_length; /* */
757  union {
758  uint32_t data;
759  struct {
760  uint8_t status; /* Descriptor status */
761  uint8_t hdr_len; /* Header length */
762  uint16_t mss; /* Maximum segment size */
763  } fields;
764  } tcp_seg_setup;
765 };
766
767 /* Offload data descriptor */
768 struct em_data_desc {
769  uint64_t buffer_addr; /* Address of the descriptor's buffer address */
770  union {
771  uint32_t data;
772  struct {
773  uint16_t length; /* Data buffer length */
774  uint8_t typ_len_ext; /* */
775  uint8_t cmd; /* */
776  } flags;
777  } lower;
778  union {
779  uint32_t data;
780  struct {
781  uint8_t status; /* Descriptor status */
782  uint8_t popts; /* Packet Options */
783  uint16_t special; /* */
784  } fields;
785  } upper;
786 };
787
788 /* Filters */
789 #define E1000_NUM_UNICAST 16 /* Unicast filter entries */
790 #define E1000_MC_TBL_SIZE 128 /* Multicast Filter Table (4096 bits) */
791 #define E1000_VLAN_FILTER_TBL_SIZE 128 /* VLAN Filter Table (4096 bits) */
792
793
794 /* Receive Address Register */
795 struct em_rar {
796  volatile uint32_t low; /* receive address low */
797  volatile uint32_t high; /* receive address high */
798 };
799
800 /* Number of entries in the Multicast Table Array (MTA). */
801 #define E1000_NUM_MTA_REGISTERS 128
802
803 /* IPv4 Address Table Entry */
805  volatile uint32_t ipv4_addr; /* IP Address (RW) */
806  volatile uint32_t reserved;
807 };
808
809 /* Four wakeup IP addresses are supported */
810 #define E1000_WAKEUP_IP_ADDRESS_COUNT_MAX 4
811 #define E1000_IP4AT_SIZE E1000_WAKEUP_IP_ADDRESS_COUNT_MAX
812 #define E1000_IP6AT_SIZE 1
813
814 /* IPv6 Address Table Entry */
816  volatile uint8_t ipv6_addr[16];
817 };
818
819 /* Flexible Filter Length Table Entry */
821  volatile uint32_t length; /* Flexible Filter Length (RW) */
822  volatile uint32_t reserved;
823 };
824
825 /* Flexible Filter Mask Table Entry */
827  volatile uint32_t mask; /* Flexible Filter Mask (RW) */
828  volatile uint32_t reserved;
829 };
830
831 /* Flexible Filter Value Table Entry */
833  volatile uint32_t value; /* Flexible Filter Value (RW) */
834  volatile uint32_t reserved;
835 };
836
837 /* Four Flexible Filters are supported */
838 #define E1000_FLEXIBLE_FILTER_COUNT_MAX 4
839
840 /* Each Flexible Filter is at most 128 (0x80) bytes in length */
841 #define E1000_FLEXIBLE_FILTER_SIZE_MAX 128
842
843 #define E1000_FFLT_SIZE E1000_FLEXIBLE_FILTER_COUNT_MAX
844 #define E1000_FFMT_SIZE E1000_FLEXIBLE_FILTER_SIZE_MAX
845 #define E1000_FFVT_SIZE E1000_FLEXIBLE_FILTER_SIZE_MAX
846
847 /* Register Set. (82543, 82544)
848  *
849  * Registers are defined to be 32 bits and should be accessed as 32 bit values.
850  * These registers are physically located on the NIC, but are mapped into the
851  * host memory address space.
852  *
853  * RW - register is both readable and writable
854  * RO - register is read only
855  * WO - register is write only
856  * R/clr - register is read only and is cleared when read
857  * A - register array
858  */
859 #define E1000_CTRL 0x00000 /* Device Control - RW */
860 #define E1000_CTRL_DUP 0x00004 /* Device Control Duplicate (Shadow) - RW */
861 #define E1000_STATUS 0x00008 /* Device Status - RO */
862 #define E1000_EECD 0x00010 /* EEPROM/Flash Control - RW */
863 #define E1000_EERD 0x00014 /* EEPROM Read - RW */
864 #define E1000_CTRL_EXT 0x00018 /* Extended Device Control - RW */
865 #define E1000_FLA 0x0001C /* Flash Access - RW */
866 #define E1000_MDIC 0x00020 /* MDI Control - RW */
867 #define E1000_FCAL 0x00028 /* Flow Control Address Low - RW */
868 #define E1000_FCAH 0x0002C /* Flow Control Address High -RW */
869 #define E1000_FCT 0x00030 /* Flow Control Type - RW */
870 #define E1000_VET 0x00038 /* VLAN Ether Type - RW */
871 #define E1000_ICR 0x000C0 /* Interrupt Cause Read - R/clr */
872 #define E1000_ITR 0x000C4 /* Interrupt Throttling Rate - RW */
873 #define E1000_ICS 0x000C8 /* Interrupt Cause Set - WO */
874 #define E1000_IMS 0x000D0 /* Interrupt Mask Set - RW */
875 #define E1000_IMC 0x000D8 /* Interrupt Mask Clear - WO */
876 #define E1000_IAM 0x000E0 /* Interrupt Acknowledge Auto Mask */
877 #define E1000_RCTL 0x00100 /* RX Control - RW */
878 #define E1000_FCTTV 0x00170 /* Flow Control Transmit Timer Value - RW */
879 #define E1000_TXCW 0x00178 /* TX Configuration Word - RW */
880 #define E1000_RXCW 0x00180 /* RX Configuration Word - RO */
881 #define E1000_TCTL 0x00400 /* TX Control - RW */
882 #define E1000_TIPG 0x00410 /* TX Inter-packet gap -RW */
883 #define E1000_TBT 0x00448 /* TX Burst Timer - RW */
884 #define E1000_AIT 0x00458 /* Adaptive Interframe Spacing Throttle - RW */
885 #define E1000_LEDCTL 0x00E00 /* LED Control - RW */
886 #define E1000_EXTCNF_CTRL 0x00F00 /* Extended Configuration Control */
887 #define E1000_EXTCNF_SIZE 0x00F08 /* Extended Configuration Size */
888 #define E1000_PBA 0x01000 /* Packet Buffer Allocation - RW */
889 #define E1000_PBS 0x01008 /* Packet Buffer Size */
890 #define E1000_EEMNGCTL 0x01010 /* MNG EEprom Control */
891 #define E1000_FLASH_UPDATES 1000
892 #define E1000_EEARBC 0x01024 /* EEPROM Auto Read Bus Control */
893 #define E1000_FLASHT 0x01028 /* FLASH Timer Register */
894 #define E1000_EEWR 0x0102C /* EEPROM Write Register - RW */
895 #define E1000_FLSWCTL 0x01030 /* FLASH control register */
896 #define E1000_FLSWDATA 0x01034 /* FLASH data register */
897 #define E1000_FLSWCNT 0x01038 /* FLASH Access Counter */
898 #define E1000_FLOP 0x0103C /* FLASH Opcode Register */
899 #define E1000_ERT 0x02008 /* Early Rx Threshold - RW */
900 #define E1000_FCRTL 0x02160 /* Flow Control Receive Threshold Low - RW */
901 #define E1000_FCRTH 0x02168 /* Flow Control Receive Threshold High - RW */
902 #define E1000_PSRCTL 0x02170 /* Packet Split Receive Control - RW */
903 #define E1000_RDBAL 0x02800 /* RX Descriptor Base Address Low - RW */
904 #define E1000_RDBAH 0x02804 /* RX Descriptor Base Address High - RW */
905 #define E1000_RDLEN 0x02808 /* RX Descriptor Length - RW */
906 #define E1000_RDH 0x02810 /* RX Descriptor Head - RW */
907 #define E1000_RDT 0x02818 /* RX Descriptor Tail - RW */
908 #define E1000_RDTR 0x02820 /* RX Delay Timer - RW */
909 #define E1000_RXDCTL 0x02828 /* RX Descriptor Control - RW */
910 #define E1000_RADV 0x0282C /* RX Interrupt Absolute Delay Timer - RW */
911 #define E1000_RSRPD 0x02C00 /* RX Small Packet Detect - RW */
912 #define E1000_RAID 0x02C08 /* Receive Ack Interrupt Delay - RW */
913 #define E1000_TXDMAC 0x03000 /* TX DMA Control - RW */
914 #define E1000_TDFH 0x03410 /* TX Data FIFO Head - RW */
915 #define E1000_TDFT 0x03418 /* TX Data FIFO Tail - RW */
916 #define E1000_TDFHS 0x03420 /* TX Data FIFO Head Saved - RW */
917 #define E1000_TDFTS 0x03428 /* TX Data FIFO Tail Saved - RW */
918 #define E1000_TDFPC 0x03430 /* TX Data FIFO Packet Count - RW */
919 #define E1000_TDBAL 0x03800 /* TX Descriptor Base Address Low - RW */
920 #define E1000_TDBAH 0x03804 /* TX Descriptor Base Address High - RW */
921 #define E1000_TDLEN 0x03808 /* TX Descriptor Length - RW */
922 #define E1000_TDH 0x03810 /* TX Descriptor Head - RW */
923 #define E1000_TDT 0x03818 /* TX Descripotr Tail - RW */
924 #define E1000_TIDV 0x03820 /* TX Interrupt Delay Value - RW */
925 #define E1000_TXDCTL 0x03828 /* TX Descriptor Control - RW */
926 #define E1000_TADV 0x0382C /* TX Interrupt Absolute Delay Val - RW */
927 #define E1000_TSPMT 0x03830 /* TCP Segmentation PAD & Min Threshold - RW */
928 #define E1000_TARC0 0x03840 /* TX Arbitration Count (0) */
929 #define E1000_TDBAL1 0x03900 /* TX Desc Base Address Low (1) - RW */
930 #define E1000_TDBAH1 0x03904 /* TX Desc Base Address High (1) - RW */
931 #define E1000_TDLEN1 0x03908 /* TX Desc Length (1) - RW */
932 #define E1000_TDH1 0x03910 /* TX Desc Head (1) - RW */
933 #define E1000_TDT1 0x03918 /* TX Desc Tail (1) - RW */
934 #define E1000_TXDCTL1 0x03928 /* TX Descriptor Control (1) - RW */
935 #define E1000_TARC1 0x03940 /* TX Arbitration Count (1) */
936 #define E1000_CRCERRS 0x04000 /* CRC Error Count - R/clr */
937 #define E1000_ALGNERRC 0x04004 /* Alignment Error Count - R/clr */
938 #define E1000_SYMERRS 0x04008 /* Symbol Error Count - R/clr */
939 #define E1000_RXERRC 0x0400C /* Receive Error Count - R/clr */
940 #define E1000_MPC 0x04010 /* Missed Packet Count - R/clr */
941 #define E1000_SCC 0x04014 /* Single Collision Count - R/clr */
942 #define E1000_ECOL 0x04018 /* Excessive Collision Count - R/clr */
943 #define E1000_MCC 0x0401C /* Multiple Collision Count - R/clr */
944 #define E1000_LATECOL 0x04020 /* Late Collision Count - R/clr */
945 #define E1000_COLC 0x04028 /* Collision Count - R/clr */
946 #define E1000_DC 0x04030 /* Defer Count - R/clr */
947 #define E1000_TNCRS 0x04034 /* TX-No CRS - R/clr */
948 #define E1000_SEC 0x04038 /* Sequence Error Count - R/clr */
949 #define E1000_CEXTERR 0x0403C /* Carrier Extension Error Count - R/clr */
950 #define E1000_RLEC 0x04040 /* Receive Length Error Count - R/clr */
951 #define E1000_XONRXC 0x04048 /* XON RX Count - R/clr */
952 #define E1000_XONTXC 0x0404C /* XON TX Count - R/clr */
953 #define E1000_XOFFRXC 0x04050 /* XOFF RX Count - R/clr */
954 #define E1000_XOFFTXC 0x04054 /* XOFF TX Count - R/clr */
955 #define E1000_FCRUC 0x04058 /* Flow Control RX Unsupported Count- R/clr */
956 #define E1000_PRC64 0x0405C /* Packets RX (64 bytes) - R/clr */
957 #define E1000_PRC127 0x04060 /* Packets RX (65-127 bytes) - R/clr */
958 #define E1000_PRC255 0x04064 /* Packets RX (128-255 bytes) - R/clr */
959 #define E1000_PRC511 0x04068 /* Packets RX (255-511 bytes) - R/clr */
960 #define E1000_PRC1023 0x0406C /* Packets RX (512-1023 bytes) - R/clr */
961 #define E1000_PRC1522 0x04070 /* Packets RX (1024-1522 bytes) - R/clr */
962 #define E1000_GPRC 0x04074 /* Good Packets RX Count - R/clr */
963 #define E1000_BPRC 0x04078 /* Broadcast Packets RX Count - R/clr */
964 #define E1000_MPRC 0x0407C /* Multicast Packets RX Count - R/clr */
965 #define E1000_GPTC 0x04080 /* Good Packets TX Count - R/clr */
966 #define E1000_GORCL 0x04088 /* Good Octets RX Count Low - R/clr */
967 #define E1000_GORCH 0x0408C /* Good Octets RX Count High - R/clr */
968 #define E1000_GOTCL 0x04090 /* Good Octets TX Count Low - R/clr */
969 #define E1000_GOTCH 0x04094 /* Good Octets TX Count High - R/clr */
970 #define E1000_RNBC 0x040A0 /* RX No Buffers Count - R/clr */
971 #define E1000_RUC 0x040A4 /* RX Undersize Count - R/clr */
972 #define E1000_RFC 0x040A8 /* RX Fragment Count - R/clr */
973 #define E1000_ROC 0x040AC /* RX Oversize Count - R/clr */
974 #define E1000_RJC 0x040B0 /* RX Jabber Count - R/clr */
975 #define E1000_MGTPRC 0x040B4 /* Management Packets RX Count - R/clr */
976 #define E1000_MGTPDC 0x040B8 /* Management Packets Dropped Count - R/clr */
977 #define E1000_MGTPTC 0x040BC /* Management Packets TX Count - R/clr */
978 #define E1000_TORL 0x040C0 /* Total Octets RX Low - R/clr */
979 #define E1000_TORH 0x040C4 /* Total Octets RX High - R/clr */
980 #define E1000_TOTL 0x040C8 /* Total Octets TX Low - R/clr */
981 #define E1000_TOTH 0x040CC /* Total Octets TX High - R/clr */
982 #define E1000_TPR 0x040D0 /* Total Packets RX - R/clr */
983 #define E1000_TPT 0x040D4 /* Total Packets TX - R/clr */
984 #define E1000_PTC64 0x040D8 /* Packets TX (64 bytes) - R/clr */
985 #define E1000_PTC127 0x040DC /* Packets TX (65-127 bytes) - R/clr */
986 #define E1000_PTC255 0x040E0 /* Packets TX (128-255 bytes) - R/clr */
987 #define E1000_PTC511 0x040E4 /* Packets TX (256-511 bytes) - R/clr */
988 #define E1000_PTC1023 0x040E8 /* Packets TX (512-1023 bytes) - R/clr */
989 #define E1000_PTC1522 0x040EC /* Packets TX (1024-1522 Bytes) - R/clr */
990 #define E1000_MPTC 0x040F0 /* Multicast Packets TX Count - R/clr */
991 #define E1000_BPTC 0x040F4 /* Broadcast Packets TX Count - R/clr */
992 #define E1000_TSCTC 0x040F8 /* TCP Segmentation Context TX - R/clr */
993 #define E1000_TSCTFC 0x040FC /* TCP Segmentation Context TX Fail - R/clr */
994 #define E1000_IAC 0x4100 /* Interrupt Assertion Count */
995 #define E1000_ICRXPTC 0x4104 /* Interrupt Cause Rx Packet Timer Expire Count */
996 #define E1000_ICRXATC 0x4108 /* Interrupt Cause Rx Absolute Timer Expire Count */
997 #define E1000_ICTXPTC 0x410C /* Interrupt Cause Tx Packet Timer Expire Count */
998 #define E1000_ICTXATC 0x4110 /* Interrupt Cause Tx Absolute Timer Expire Count */
999 #define E1000_ICTXQEC 0x4118 /* Interrupt Cause Tx Queue Empty Count */
1000 #define E1000_ICTXQMTC 0x411C /* Interrupt Cause Tx Queue Minimum Threshold Count */
1001 #define E1000_ICRXDMTC 0x4120 /* Interrupt Cause Rx Descriptor Minimum Threshold Count */
1002 #define E1000_ICRXOC 0x4124 /* Interrupt Cause Receiver Overrun Count */
1003 #define E1000_RXCSUM 0x05000 /* RX Checksum Control - RW */
1004 #define E1000_RFCTL 0x05008 /* Receive Filter Control*/
1005 #define E1000_MTA 0x05200 /* Multicast Table Array - RW Array */
1006 #define E1000_RA 0x05400 /* Receive Address - RW Array */
1007 #define E1000_VFTA 0x05600 /* VLAN Filter Table Array - RW Array */
1008 #define E1000_WUC 0x05800 /* Wakeup Control - RW */
1009 #define E1000_WUFC 0x05808 /* Wakeup Filter Control - RW */
1010 #define E1000_WUS 0x05810 /* Wakeup Status - RO */
1011 #define E1000_MANC 0x05820 /* Management Control - RW */
1012 #define E1000_IPAV 0x05838 /* IP Address Valid - RW */
1013 #define E1000_IP4AT 0x05840 /* IPv4 Address Table - RW Array */
1014 #define E1000_IP6AT 0x05880 /* IPv6 Address Table - RW Array */
1015 #define E1000_WUPL 0x05900 /* Wakeup Packet Length - RW */
1016 #define E1000_WUPM 0x05A00 /* Wakeup Packet Memory - RO A */
1017 #define E1000_FFLT 0x05F00 /* Flexible Filter Length Table - RW Array */
1018 #define E1000_HOST_IF 0x08800 /* Host Interface */
1019 #define E1000_FFMT 0x09000 /* Flexible Filter Mask Table - RW Array */
1020 #define E1000_FFVT 0x09800 /* Flexible Filter Value Table - RW Array */
1021
1022 #define E1000_GCR 0x05B00 /* PCI-Ex Control */
1023 #define E1000_GSCL_1 0x05B10 /* PCI-Ex Statistic Control #1 */
1024 #define E1000_GSCL_2 0x05B14 /* PCI-Ex Statistic Control #2 */
1025 #define E1000_GSCL_3 0x05B18 /* PCI-Ex Statistic Control #3 */
1026 #define E1000_GSCL_4 0x05B1C /* PCI-Ex Statistic Control #4 */
1027 #define E1000_FACTPS 0x05B30 /* Function Active and Power State to MNG */
1028 #define E1000_SWSM 0x05B50 /* SW Semaphore */
1029 #define E1000_FWSM 0x05B54 /* FW Semaphore */
1030 #define E1000_FFLT_DBG 0x05F04 /* Debug Register */
1031 #define E1000_HICR 0x08F00 /* Host Inteface Control */
1032 /* Register Set (82542)
1033  *
1034  * Some of the 82542 registers are located at different offsets than they are
1035  * in more current versions of the 8254x. Despite the difference in location,
1036  * the registers function in the same manner.
1037  */
1038 #define E1000_82542_CTRL E1000_CTRL
1039 #define E1000_82542_CTRL_DUP E1000_CTRL_DUP
1040 #define E1000_82542_STATUS E1000_STATUS
1041 #define E1000_82542_EECD E1000_EECD
1042 #define E1000_82542_EERD E1000_EERD
1043 #define E1000_82542_CTRL_EXT E1000_CTRL_EXT
1044 #define E1000_82542_FLA E1000_FLA
1045 #define E1000_82542_MDIC E1000_MDIC
1046 #define E1000_82542_FCAL E1000_FCAL
1047 #define E1000_82542_FCAH E1000_FCAH
1048 #define E1000_82542_FCT E1000_FCT
1049 #define E1000_82542_VET E1000_VET
1050 #define E1000_82542_RA 0x00040
1051 #define E1000_82542_ICR E1000_ICR
1052 #define E1000_82542_ITR E1000_ITR
1053 #define E1000_82542_ICS E1000_ICS
1054 #define E1000_82542_IMS E1000_IMS
1055 #define E1000_82542_IMC E1000_IMC
1056 #define E1000_82542_RCTL E1000_RCTL
1057 #define E1000_82542_RDTR 0x00108
1058 #define E1000_82542_RDBAL 0x00110
1059 #define E1000_82542_RDBAH 0x00114
1060 #define E1000_82542_RDLEN 0x00118
1061 #define E1000_82542_RDH 0x00120
1062 #define E1000_82542_RDT 0x00128
1063 #define E1000_82542_FCRTH 0x00160
1064 #define E1000_82542_FCRTL 0x00168
1065 #define E1000_82542_FCTTV E1000_FCTTV
1066 #define E1000_82542_TXCW E1000_TXCW
1067 #define E1000_82542_RXCW E1000_RXCW
1068 #define E1000_82542_MTA 0x00200
1069 #define E1000_82542_TCTL E1000_TCTL
1070 #define E1000_82542_TIPG E1000_TIPG
1071 #define E1000_82542_TDBAL 0x00420
1072 #define E1000_82542_TDBAH 0x00424
1073 #define E1000_82542_TDLEN 0x00428
1074 #define E1000_82542_TDH 0x00430
1075 #define E1000_82542_TDT 0x00438
1076 #define E1000_82542_TIDV 0x00440
1077 #define E1000_82542_TBT E1000_TBT
1078 #define E1000_82542_AIT E1000_AIT
1079 #define E1000_82542_VFTA 0x00600
1080 #define E1000_82542_LEDCTL E1000_LEDCTL
1081 #define E1000_82542_PBA E1000_PBA
1082 #define E1000_82542_PBS E1000_PBS
1083 #define E1000_82542_EEMNGCTL E1000_EEMNGCTL
1084 #define E1000_82542_EEARBC E1000_EEARBC
1085 #define E1000_82542_FLASHT E1000_FLASHT
1086 #define E1000_82542_EEWR E1000_EEWR
1087 #define E1000_82542_FLSWCTL E1000_FLSWCTL
1088 #define E1000_82542_FLSWDATA E1000_FLSWDATA
1089 #define E1000_82542_FLSWCNT E1000_FLSWCNT
1090 #define E1000_82542_FLOP E1000_FLOP
1091 #define E1000_82542_EXTCNF_CTRL E1000_EXTCNF_CTRL
1092 #define E1000_82542_EXTCNF_SIZE E1000_EXTCNF_SIZE
1093 #define E1000_82542_ERT E1000_ERT
1094 #define E1000_82542_RXDCTL E1000_RXDCTL
1095 #define E1000_82542_RADV E1000_RADV
1096 #define E1000_82542_RSRPD E1000_RSRPD
1097 #define E1000_82542_TXDMAC E1000_TXDMAC
1098 #define E1000_82542_TDFHS E1000_TDFHS
1099 #define E1000_82542_TDFTS E1000_TDFTS
1100 #define E1000_82542_TDFPC E1000_TDFPC
1101 #define E1000_82542_TXDCTL E1000_TXDCTL
1102 #define E1000_82542_TADV E1000_TADV
1103 #define E1000_82542_TSPMT E1000_TSPMT
1104 #define E1000_82542_CRCERRS E1000_CRCERRS
1105 #define E1000_82542_ALGNERRC E1000_ALGNERRC
1106 #define E1000_82542_SYMERRS E1000_SYMERRS
1107 #define E1000_82542_RXERRC E1000_RXERRC
1108 #define E1000_82542_MPC E1000_MPC
1109 #define E1000_82542_SCC E1000_SCC
1110 #define E1000_82542_ECOL E1000_ECOL
1111 #define E1000_82542_MCC E1000_MCC
1112 #define E1000_82542_LATECOL E1000_LATECOL
1113 #define E1000_82542_COLC E1000_COLC
1114 #define E1000_82542_DC E1000_DC
1115 #define E1000_82542_TNCRS E1000_TNCRS
1116 #define E1000_82542_SEC E1000_SEC
1117 #define E1000_82542_CEXTERR E1000_CEXTERR
1118 #define E1000_82542_RLEC E1000_RLEC
1119 #define E1000_82542_XONRXC E1000_XONRXC
1120 #define E1000_82542_XONTXC E1000_XONTXC
1121 #define E1000_82542_XOFFRXC E1000_XOFFRXC
1122 #define E1000_82542_XOFFTXC E1000_XOFFTXC
1123 #define E1000_82542_FCRUC E1000_FCRUC
1124 #define E1000_82542_PRC64 E1000_PRC64
1125 #define E1000_82542_PRC127 E1000_PRC127
1126 #define E1000_82542_PRC255 E1000_PRC255
1127 #define E1000_82542_PRC511 E1000_PRC511
1128 #define E1000_82542_PRC1023 E1000_PRC1023
1129 #define E1000_82542_PRC1522 E1000_PRC1522
1130 #define E1000_82542_GPRC E1000_GPRC
1131 #define E1000_82542_BPRC E1000_BPRC
1132 #define E1000_82542_MPRC E1000_MPRC
1133 #define E1000_82542_GPTC E1000_GPTC
1134 #define E1000_82542_GORCL E1000_GORCL
1135 #define E1000_82542_GORCH E1000_GORCH
1136 #define E1000_82542_GOTCL E1000_GOTCL
1137 #define E1000_82542_GOTCH E1000_GOTCH
1138 #define E1000_82542_RNBC E1000_RNBC
1139 #define E1000_82542_RUC E1000_RUC
1140 #define E1000_82542_RFC E1000_RFC
1141 #define E1000_82542_ROC E1000_ROC
1142 #define E1000_82542_RJC E1000_RJC
1143 #define E1000_82542_MGTPRC E1000_MGTPRC
1144 #define E1000_82542_MGTPDC E1000_MGTPDC
1145 #define E1000_82542_MGTPTC E1000_MGTPTC
1146 #define E1000_82542_TORL E1000_TORL
1147 #define E1000_82542_TORH E1000_TORH
1148 #define E1000_82542_TOTL E1000_TOTL
1149 #define E1000_82542_TOTH E1000_TOTH
1150 #define E1000_82542_TPR E1000_TPR
1151 #define E1000_82542_TPT E1000_TPT
1152 #define E1000_82542_PTC64 E1000_PTC64
1153 #define E1000_82542_PTC127 E1000_PTC127
1154 #define E1000_82542_PTC255 E1000_PTC255
1155 #define E1000_82542_PTC511 E1000_PTC511
1156 #define E1000_82542_PTC1023 E1000_PTC1023
1157 #define E1000_82542_PTC1522 E1000_PTC1522
1158 #define E1000_82542_MPTC E1000_MPTC
1159 #define E1000_82542_BPTC E1000_BPTC
1160 #define E1000_82542_TSCTC E1000_TSCTC
1161 #define E1000_82542_TSCTFC E1000_TSCTFC
1162 #define E1000_82542_RXCSUM E1000_RXCSUM
1163 #define E1000_82542_WUC E1000_WUC
1164 #define E1000_82542_WUFC E1000_WUFC
1165 #define E1000_82542_WUS E1000_WUS
1166 #define E1000_82542_MANC E1000_MANC
1167 #define E1000_82542_IPAV E1000_IPAV
1168 #define E1000_82542_IP4AT E1000_IP4AT
1169 #define E1000_82542_IP6AT E1000_IP6AT
1170 #define E1000_82542_WUPL E1000_WUPL
1171 #define E1000_82542_WUPM E1000_WUPM
1172 #define E1000_82542_FFLT E1000_FFLT
1173 #define E1000_82542_TDFH 0x08010
1174 #define E1000_82542_TDFT 0x08018
1175 #define E1000_82542_FFMT E1000_FFMT
1176 #define E1000_82542_FFVT E1000_FFVT
1177 #define E1000_82542_HOST_IF E1000_HOST_IF
1178 #define E1000_82542_IAM E1000_IAM
1179 #define E1000_82542_EEMNGCTL E1000_EEMNGCTL
1180 #define E1000_82542_PSRCTL E1000_PSRCTL
1181 #define E1000_82542_RAID E1000_RAID
1182 #define E1000_82542_TARC0 E1000_TARC0
1183 #define E1000_82542_TDBAL1 E1000_TDBAL1
1184 #define E1000_82542_TDBAH1 E1000_TDBAH1
1185 #define E1000_82542_TDLEN1 E1000_TDLEN1
1186 #define E1000_82542_TDH1 E1000_TDH1
1187 #define E1000_82542_TDT1 E1000_TDT1
1188 #define E1000_82542_TXDCTL1 E1000_TXDCTL1
1189 #define E1000_82542_TARC1 E1000_TARC1
1190 #define E1000_82542_RFCTL E1000_RFCTL
1191 #define E1000_82542_GCR E1000_GCR
1192 #define E1000_82542_GSCL_1 E1000_GSCL_1
1193 #define E1000_82542_GSCL_2 E1000_GSCL_2
1194 #define E1000_82542_GSCL_3 E1000_GSCL_3
1195 #define E1000_82542_GSCL_4 E1000_GSCL_4
1196 #define E1000_82542_FACTPS E1000_FACTPS
1197 #define E1000_82542_SWSM E1000_SWSM
1198 #define E1000_82542_FWSM E1000_FWSM
1199 #define E1000_82542_FFLT_DBG E1000_FFLT_DBG
1200 #define E1000_82542_IAC E1000_IAC
1201 #define E1000_82542_ICRXPTC E1000_ICRXPTC
1202 #define E1000_82542_ICRXATC E1000_ICRXATC
1203 #define E1000_82542_ICTXPTC E1000_ICTXPTC
1204 #define E1000_82542_ICTXATC E1000_ICTXATC
1205 #define E1000_82542_ICTXQEC E1000_ICTXQEC
1206 #define E1000_82542_ICTXQMTC E1000_ICTXQMTC
1207 #define E1000_82542_ICRXDMTC E1000_ICRXDMTC
1208 #define E1000_82542_ICRXOC E1000_ICRXOC
1209 #define E1000_82542_HICR E1000_HICR
1210
1211 /* Statistics counters collected by the MAC */
1212 struct em_hw_stats {
1213  uint64_t crcerrs;
1214  uint64_t algnerrc;
1215  uint64_t symerrs;
1216  uint64_t rxerrc;
1217  uint64_t mpc;
1218  uint64_t scc;
1219  uint64_t ecol;
1220  uint64_t mcc;
1221  uint64_t latecol;
1222  uint64_t colc;
1223  uint64_t dc;
1224  uint64_t tncrs;
1225  uint64_t sec;
1226  uint64_t cexterr;
1227  uint64_t rlec;
1228  uint64_t xonrxc;
1229  uint64_t xontxc;
1230  uint64_t xoffrxc;
1231  uint64_t xofftxc;
1232  uint64_t fcruc;
1233  uint64_t prc64;
1234  uint64_t prc127;
1235  uint64_t prc255;
1236  uint64_t prc511;
1237  uint64_t prc1023;
1238  uint64_t prc1522;
1239  uint64_t gprc;
1240  uint64_t bprc;
1241  uint64_t mprc;
1242  uint64_t gptc;
1243  uint64_t gorcl;
1244  uint64_t gorch;
1245  uint64_t gotcl;
1246  uint64_t gotch;
1247  uint64_t rnbc;
1248  uint64_t ruc;
1249  uint64_t rfc;
1250  uint64_t roc;
1251  uint64_t rjc;
1252  uint64_t mgprc;
1253  uint64_t mgpdc;
1254  uint64_t mgptc;
1255  uint64_t torl;
1256  uint64_t torh;
1257  uint64_t totl;
1258  uint64_t toth;
1259  uint64_t tpr;
1260  uint64_t tpt;
1261  uint64_t ptc64;
1262  uint64_t ptc127;
1263  uint64_t ptc255;
1264  uint64_t ptc511;
1265  uint64_t ptc1023;
1266  uint64_t ptc1522;
1267  uint64_t mptc;
1268  uint64_t bptc;
1269  uint64_t tsctc;
1270  uint64_t tsctfc;
1271  uint64_t iac;
1272  uint64_t icrxptc;
1273  uint64_t icrxatc;
1274  uint64_t ictxptc;
1275  uint64_t ictxatc;
1276  uint64_t ictxqec;
1277  uint64_t ictxqmtc;
1278  uint64_t icrxdmtc;
1279  uint64_t icrxoc;
1280 };
1281
1282 /* Structure containing variables used by the shared code (em_hw.c) */
1283 struct em_hw {
1284  uint8_t *hw_addr;
1285  uint8_t *flash_address;
1286  em_mac_type mac_type;
1287  em_phy_type phy_type;
1288  uint32_t phy_init_script;
1289  em_media_type media_type;
1290  void *back;
1291  em_fc_type fc;
1292  em_bus_speed bus_speed;
1293  em_bus_width bus_width;
1294  em_bus_type bus_type;
1295  struct em_eeprom_info eeprom;
1296  em_ms_type master_slave;
1297  em_ms_type original_master_slave;
1298  em_ffe_config ffe_config_state;
1299  uint32_t asf_firmware_present;
1300  uint32_t eeprom_semaphore_present;
1301  unsigned long io_base;
1302  uint32_t phy_id;
1303  uint32_t phy_revision;
1304  uint32_t phy_addr;
1305  uint32_t original_fc;
1306  uint32_t txcw;
1307  uint32_t autoneg_failed;
1308  uint32_t max_frame_size;
1309  uint32_t min_frame_size;
1310  uint32_t mc_filter_type;
1311  uint32_t num_mc_addrs;
1312  uint32_t collision_delta;
1313  uint32_t tx_packet_delta;
1314  uint32_t ledctl_default;
1315  uint32_t ledctl_mode1;
1316  uint32_t ledctl_mode2;
1317  boolean_t tx_pkt_filtering;
1318  struct em_host_mng_dhcp_cookie mng_cookie;
1319  uint16_t phy_spd_default;
1320  uint16_t autoneg_advertised;
1321  uint16_t pci_cmd_word;
1322  uint16_t fc_high_water;
1323  uint16_t fc_low_water;
1324  uint16_t fc_pause_time;
1325  uint16_t current_ifs_val;
1326  uint16_t ifs_min_val;
1327  uint16_t ifs_max_val;
1328  uint16_t ifs_step_size;
1329  uint16_t ifs_ratio;
1330  uint16_t device_id;
1331  uint16_t vendor_id;
1332  uint16_t subsystem_id;
1333  uint16_t subsystem_vendor_id;
1334  uint8_t revision_id;
1335  uint8_t autoneg;
1336  uint8_t mdix;
1337  uint8_t forced_speed_duplex;
1338  uint8_t wait_autoneg_complete;
1339  uint8_t dma_fairness;
1340  uint8_t mac_addr[NODE_ADDRESS_SIZE];
1341  uint8_t perm_mac_addr[NODE_ADDRESS_SIZE];
1342  boolean_t disable_polarity_correction;
1343  boolean_t speed_downgraded;
1344  em_smart_speed smart_speed;
1345  em_dsp_config dsp_config_state;
1346  boolean_t get_link_status;
1347  boolean_t serdes_link_down;
1348  boolean_t tbi_compatibility_en;
1349  boolean_t tbi_compatibility_on;
1350  boolean_t phy_reset_disable;
1351  boolean_t fc_send_xon;
1352  boolean_t fc_strict_ieee;
1353  boolean_t report_tx_early;
1354  boolean_t adaptive_ifs;
1355  boolean_t ifs_params_forced;
1356  boolean_t in_ifs_mode;
1357  boolean_t mng_reg_access_disabled;
1358 };
1359
1360
1361 #define E1000_EEPROM_SWDPIN0 0x0001 /* SWDPIN 0 EEPROM Value */
1362 #define E1000_EEPROM_LED_LOGIC 0x0020 /* Led Logic Word */
1363 #define E1000_EEPROM_RW_REG_DATA 16 /* Offset to data in EEPROM read/write registers */
1364 #define E1000_EEPROM_RW_REG_DONE 2 /* Offset to READ/WRITE done bit */
1365 #define E1000_EEPROM_RW_REG_START 1 /* First bit for telling part to start operation */
1366 #define E1000_EEPROM_RW_ADDR_SHIFT 2 /* Shift to the address bits */
1367 #define E1000_EEPROM_POLL_WRITE 1 /* Flag for polling for write complete */
1368 #define E1000_EEPROM_POLL_READ 0 /* Flag for polling for read complete */
1369 /* Register Bit Masks */
1370 /* Device Control */
1371 #define E1000_CTRL_FD 0x00000001 /* Full duplex.0=half; 1=full */
1372 #define E1000_CTRL_BEM 0x00000002 /* Endian Mode.0=little,1=big */
1373 #define E1000_CTRL_PRIOR 0x00000004 /* Priority on PCI. 0=rx,1=fair */
1374 #define E1000_CTRL_GIO_MASTER_DISABLE 0x00000004 /*Blocks new Master requests */
1375 #define E1000_CTRL_LRST 0x00000008 /* Link reset. 0=normal,1=reset */
1376 #define E1000_CTRL_TME 0x00000010 /* Test mode. 0=normal,1=test */
1377 #define E1000_CTRL_SLE 0x00000020 /* Serial Link on 0=dis,1=en */
1378 #define E1000_CTRL_ASDE 0x00000020 /* Auto-speed detect enable */
1379 #define E1000_CTRL_SLU 0x00000040 /* Set link up (Force Link) */
1380 #define E1000_CTRL_ILOS 0x00000080 /* Invert Loss-Of Signal */
1381 #define E1000_CTRL_SPD_SEL 0x00000300 /* Speed Select Mask */
1382 #define E1000_CTRL_SPD_10 0x00000000 /* Force 10Mb */
1383 #define E1000_CTRL_SPD_100 0x00000100 /* Force 100Mb */
1384 #define E1000_CTRL_SPD_1000 0x00000200 /* Force 1Gb */
1385 #define E1000_CTRL_BEM32 0x00000400 /* Big Endian 32 mode */
1386 #define E1000_CTRL_FRCSPD 0x00000800 /* Force Speed */
1387 #define E1000_CTRL_FRCDPX 0x00001000 /* Force Duplex */
1388 #define E1000_CTRL_D_UD_POLARITY 0x00004000 /* Defined polarity of Dock/Undock indication in SDP[0] */
1389 #define E1000_CTRL_SWDPIN0 0x00040000 /* SWDPIN 0 value */
1390 #define E1000_CTRL_SWDPIN1 0x00080000 /* SWDPIN 1 value */
1391 #define E1000_CTRL_SWDPIN2 0x00100000 /* SWDPIN 2 value */
1392 #define E1000_CTRL_SWDPIN3 0x00200000 /* SWDPIN 3 value */
1393 #define E1000_CTRL_SWDPIO0 0x00400000 /* SWDPIN 0 Input or output */
1394 #define E1000_CTRL_SWDPIO1 0x00800000 /* SWDPIN 1 input or output */
1395 #define E1000_CTRL_SWDPIO2 0x01000000 /* SWDPIN 2 input or output */
1396 #define E1000_CTRL_SWDPIO3 0x02000000 /* SWDPIN 3 input or output */
1397 #define E1000_CTRL_RST 0x04000000 /* Global reset */
1398 #define E1000_CTRL_RFCE 0x08000000 /* Receive Flow Control enable */
1399 #define E1000_CTRL_TFCE 0x10000000 /* Transmit flow control enable */
1400 #define E1000_CTRL_RTE 0x20000000 /* Routing tag enable */
1401 #define E1000_CTRL_VME 0x40000000 /* IEEE VLAN mode enable */
1402 #define E1000_CTRL_PHY_RST 0x80000000 /* PHY Reset */
1403
1404 /* Device Status */
1405 #define E1000_STATUS_FD 0x00000001 /* Full duplex.0=half,1=full */
1406 #define E1000_STATUS_LU 0x00000002 /* Link up.0=no,1=link */
1407 #define E1000_STATUS_FUNC_MASK 0x0000000C /* PCI Function Mask */
1408 #define E1000_STATUS_FUNC_SHIFT 2
1409 #define E1000_STATUS_FUNC_0 0x00000000 /* Function 0 */
1410 #define E1000_STATUS_FUNC_1 0x00000004 /* Function 1 */
1411 #define E1000_STATUS_TXOFF 0x00000010 /* transmission paused */
1412 #define E1000_STATUS_TBIMODE 0x00000020 /* TBI mode */
1413 #define E1000_STATUS_SPEED_MASK 0x000000C0
1414 #define E1000_STATUS_SPEED_10 0x00000000 /* Speed 10Mb/s */
1415 #define E1000_STATUS_SPEED_100 0x00000040 /* Speed 100Mb/s */
1416 #define E1000_STATUS_SPEED_1000 0x00000080 /* Speed 1000Mb/s */
1417 #define E1000_STATUS_ASDV 0x00000300 /* Auto speed detect value */
1418 #define E1000_STATUS_DOCK_CI 0x00000800 /* Change in Dock/Undock state. Clear on write '0'. */
1419 #define E1000_STATUS_GIO_MASTER_ENABLE 0x00080000 /* Status of Master requests. */
1420 #define E1000_STATUS_MTXCKOK 0x00000400 /* MTX clock running OK */
1421 #define E1000_STATUS_PCI66 0x00000800 /* In 66Mhz slot */
1422 #define E1000_STATUS_BUS64 0x00001000 /* In 64 bit slot */
1423 #define E1000_STATUS_PCIX_MODE 0x00002000 /* PCI-X mode */
1424 #define E1000_STATUS_PCIX_SPEED 0x0000C000 /* PCI-X bus speed */
1425
1426 /* Constants used to intrepret the masked PCI-X bus speed. */
1427 #define E1000_STATUS_PCIX_SPEED_66 0x00000000 /* PCI-X bus speed 50-66 MHz */
1428 #define E1000_STATUS_PCIX_SPEED_100 0x00004000 /* PCI-X bus speed 66-100 MHz */
1429 #define E1000_STATUS_PCIX_SPEED_133 0x00008000 /* PCI-X bus speed 100-133 MHz */
1430
1431 /* EEPROM/Flash Control */
1432 #define E1000_EECD_SK 0x00000001 /* EEPROM Clock */
1433 #define E1000_EECD_CS 0x00000002 /* EEPROM Chip Select */
1434 #define E1000_EECD_DI 0x00000004 /* EEPROM Data In */
1435 #define E1000_EECD_DO 0x00000008 /* EEPROM Data Out */
1436 #define E1000_EECD_FWE_MASK 0x00000030
1437 #define E1000_EECD_FWE_DIS 0x00000010 /* Disable FLASH writes */
1438 #define E1000_EECD_FWE_EN 0x00000020 /* Enable FLASH writes */
1439 #define E1000_EECD_FWE_SHIFT 4
1440 #define E1000_EECD_REQ 0x00000040 /* EEPROM Access Request */
1441 #define E1000_EECD_GNT 0x00000080 /* EEPROM Access Grant */
1442 #define E1000_EECD_PRES 0x00000100 /* EEPROM Present */
1443 #define E1000_EECD_SIZE 0x00000200 /* EEPROM Size (0=64 word 1=256 word) */
1444 #define E1000_EECD_ADDR_BITS 0x00000400 /* EEPROM Addressing bits based on type
1445  * (0-small, 1-large) */
1446 #define E1000_EECD_TYPE 0x00002000 /* EEPROM Type (1-SPI, 0-Microwire) */
1447 #ifndef E1000_EEPROM_GRANT_ATTEMPTS
1448 #define E1000_EEPROM_GRANT_ATTEMPTS 1000 /* EEPROM # attempts to gain grant */
1449 #endif
1450 #define E1000_EECD_AUTO_RD 0x00000200 /* EEPROM Auto Read done */
1451 #define E1000_EECD_SIZE_EX_MASK 0x00007800 /* EEprom Size */
1452 #define E1000_EECD_SIZE_EX_SHIFT 11
1453 #define E1000_EECD_NVADDS 0x00018000 /* NVM Address Size */
1454 #define E1000_EECD_SELSHAD 0x00020000 /* Select Shadow RAM */
1455 #define E1000_EECD_INITSRAM 0x00040000 /* Initialize Shadow RAM */
1456 #define E1000_EECD_FLUPD 0x00080000 /* Update FLASH */
1457 #define E1000_EECD_AUPDEN 0x00100000 /* Enable Autonomous FLASH update */
1458 #define E1000_EECD_SHADV 0x00200000 /* Shadow RAM Data Valid */
1459 #define E1000_EECD_SEC1VAL 0x00400000 /* Sector One Valid */
1460 #define E1000_STM_OPCODE 0xDB00
1461 #define E1000_HICR_FW_RESET 0xC0
1462
1463 /* EEPROM Read */
1464 #define E1000_EERD_START 0x00000001 /* Start Read */
1465 #define E1000_EERD_DONE 0x00000010 /* Read Done */
1466 #define E1000_EERD_ADDR_SHIFT 8
1467 #define E1000_EERD_ADDR_MASK 0x0000FF00 /* Read Address */
1468 #define E1000_EERD_DATA_SHIFT 16
1469 #define E1000_EERD_DATA_MASK 0xFFFF0000 /* Read Data */
1470
1471 /* SPI EEPROM Status Register */
1472 #define EEPROM_STATUS_RDY_SPI 0x01
1473 #define EEPROM_STATUS_WEN_SPI 0x02
1474 #define EEPROM_STATUS_BP0_SPI 0x04
1475 #define EEPROM_STATUS_BP1_SPI 0x08
1476 #define EEPROM_STATUS_WPEN_SPI 0x80
1477
1478 /* Extended Device Control */
1479 #define E1000_CTRL_EXT_GPI0_EN 0x00000001 /* Maps SDP4 to GPI0 */
1480 #define E1000_CTRL_EXT_GPI1_EN 0x00000002 /* Maps SDP5 to GPI1 */
1481 #define E1000_CTRL_EXT_PHYINT_EN E1000_CTRL_EXT_GPI1_EN
1482 #define E1000_CTRL_EXT_GPI2_EN 0x00000004 /* Maps SDP6 to GPI2 */
1483 #define E1000_CTRL_EXT_GPI3_EN 0x00000008 /* Maps SDP7 to GPI3 */
1484 #define E1000_CTRL_EXT_SDP4_DATA 0x00000010 /* Value of SW Defineable Pin 4 */
1485 #define E1000_CTRL_EXT_SDP5_DATA 0x00000020 /* Value of SW Defineable Pin 5 */
1486 #define E1000_CTRL_EXT_PHY_INT E1000_CTRL_EXT_SDP5_DATA
1487 #define E1000_CTRL_EXT_SDP6_DATA 0x00000040 /* Value of SW Defineable Pin 6 */
1488 #define E1000_CTRL_EXT_SDP7_DATA 0x00000080 /* Value of SW Defineable Pin 7 */
1489 #define E1000_CTRL_EXT_SDP4_DIR 0x00000100 /* Direction of SDP4 0=in 1=out */
1490 #define E1000_CTRL_EXT_SDP5_DIR 0x00000200 /* Direction of SDP5 0=in 1=out */
1491 #define E1000_CTRL_EXT_SDP6_DIR 0x00000400 /* Direction of SDP6 0=in 1=out */
1492 #define E1000_CTRL_EXT_SDP7_DIR 0x00000800 /* Direction of SDP7 0=in 1=out */
1493 #define E1000_CTRL_EXT_ASDCHK 0x00001000 /* Initiate an ASD sequence */
1494 #define E1000_CTRL_EXT_EE_RST 0x00002000 /* Reinitialize from EEPROM */
1495 #define E1000_CTRL_EXT_IPS 0x00004000 /* Invert Power State */
1496 #define E1000_CTRL_EXT_SPD_BYPS 0x00008000 /* Speed Select Bypass */
1497 #define E1000_CTRL_EXT_LINK_MODE_MASK 0x00C00000
1498 #define E1000_CTRL_EXT_LINK_MODE_GMII 0x00000000
1499 #define E1000_CTRL_EXT_LINK_MODE_TBI 0x00C00000
1500 #define E1000_CTRL_EXT_WR_WMARK_MASK 0x03000000
1501 #define E1000_CTRL_EXT_WR_WMARK_256 0x00000000
1502 #define E1000_CTRL_EXT_WR_WMARK_320 0x01000000
1503 #define E1000_CTRL_EXT_WR_WMARK_384 0x02000000
1504 #define E1000_CTRL_EXT_WR_WMARK_448 0x03000000
1505 #define E1000_CTRL_EXT_IAME 0x08000000 /* Interrupt acknowledge Auto-mask */
1506 #define E1000_CTRL_EXT_INT_TIMER_CLR 0x20000000 /* Clear Interrupt timers after IMS clear */
1507
1508 /* MDI Control */
1509 #define E1000_MDIC_DATA_MASK 0x0000FFFF
1510 #define E1000_MDIC_REG_MASK 0x001F0000
1511 #define E1000_MDIC_REG_SHIFT 16
1512 #define E1000_MDIC_PHY_MASK 0x03E00000
1513 #define E1000_MDIC_PHY_SHIFT 21
1514 #define E1000_MDIC_OP_WRITE 0x04000000
1515 #define E1000_MDIC_OP_READ 0x08000000
1516 #define E1000_MDIC_READY 0x10000000
1517 #define E1000_MDIC_INT_EN 0x20000000
1518 #define E1000_MDIC_ERROR 0x40000000
1519
1520 /* LED Control */
1521 #define E1000_LEDCTL_LED0_MODE_MASK 0x0000000F
1522 #define E1000_LEDCTL_LED0_MODE_SHIFT 0
1523 #define E1000_LEDCTL_LED0_BLINK_RATE 0x0000020
1524 #define E1000_LEDCTL_LED0_IVRT 0x00000040
1525 #define E1000_LEDCTL_LED0_BLINK 0x00000080
1526 #define E1000_LEDCTL_LED1_MODE_MASK 0x00000F00
1527 #define E1000_LEDCTL_LED1_MODE_SHIFT 8
1528 #define E1000_LEDCTL_LED1_BLINK_RATE 0x0002000
1529 #define E1000_LEDCTL_LED1_IVRT 0x00004000
1530 #define E1000_LEDCTL_LED1_BLINK 0x00008000
1531 #define E1000_LEDCTL_LED2_MODE_MASK 0x000F0000
1532 #define E1000_LEDCTL_LED2_MODE_SHIFT 16
1533 #define E1000_LEDCTL_LED2_BLINK_RATE 0x00200000
1534 #define E1000_LEDCTL_LED2_IVRT 0x00400000
1535 #define E1000_LEDCTL_LED2_BLINK 0x00800000
1536 #define E1000_LEDCTL_LED3_MODE_MASK 0x0F000000
1537 #define E1000_LEDCTL_LED3_MODE_SHIFT 24
1538 #define E1000_LEDCTL_LED3_IVRT 0x40000000
1539 #define E1000_LEDCTL_LED3_BLINK 0x80000000
1540
1541 #define E1000_LEDCTL_MODE_LINK_10_1000 0x0
1542 #define E1000_LEDCTL_MODE_LINK_100_1000 0x1
1543 #define E1000_LEDCTL_MODE_LINK_UP 0x2
1544 #define E1000_LEDCTL_MODE_ACTIVITY 0x3
1545 #define E1000_LEDCTL_MODE_LINK_ACTIVITY 0x4
1546 #define E1000_LEDCTL_MODE_LINK_10 0x5
1547 #define E1000_LEDCTL_MODE_LINK_100 0x6
1548 #define E1000_LEDCTL_MODE_LINK_1000 0x7
1549 #define E1000_LEDCTL_MODE_PCIX_MODE 0x8
1550 #define E1000_LEDCTL_MODE_FULL_DUPLEX 0x9
1551 #define E1000_LEDCTL_MODE_COLLISION 0xA
1552 #define E1000_LEDCTL_MODE_BUS_SPEED 0xB
1553 #define E1000_LEDCTL_MODE_BUS_SIZE 0xC
1554 #define E1000_LEDCTL_MODE_PAUSED 0xD
1555 #define E1000_LEDCTL_MODE_LED_ON 0xE
1556 #define E1000_LEDCTL_MODE_LED_OFF 0xF
1557
1558 /* Receive Address */
1559 #define E1000_RAH_AV 0x80000000 /* Receive descriptor valid */
1560
1561 /* Interrupt Cause Read */
1562 #define E1000_ICR_TXDW 0x00000001 /* Transmit desc written back */
1563 #define E1000_ICR_TXQE 0x00000002 /* Transmit Queue empty */
1564 #define E1000_ICR_LSC 0x00000004 /* Link Status Change */
1565 #define E1000_ICR_RXSEQ 0x00000008 /* rx sequence error */
1566 #define E1000_ICR_RXDMT0 0x00000010 /* rx desc min. threshold (0) */
1567 #define E1000_ICR_RXO 0x00000040 /* rx overrun */
1568 #define E1000_ICR_RXT0 0x00000080 /* rx timer intr (ring 0) */
1569 #define E1000_ICR_MDAC 0x00000200 /* MDIO access complete */
1570 #define E1000_ICR_RXCFG 0x00000400 /* RX /c/ ordered set */
1571 #define E1000_ICR_GPI_EN0 0x00000800 /* GP Int 0 */
1572 #define E1000_ICR_GPI_EN1 0x00001000 /* GP Int 1 */
1573 #define E1000_ICR_GPI_EN2 0x00002000 /* GP Int 2 */
1574 #define E1000_ICR_GPI_EN3 0x00004000 /* GP Int 3 */
1575 #define E1000_ICR_TXD_LOW 0x00008000
1576 #define E1000_ICR_SRPD 0x00010000
1577 #define E1000_ICR_ACK 0x00020000 /* Receive Ack frame */
1578 #define E1000_ICR_MNG 0x00040000 /* Manageability event */
1579 #define E1000_ICR_DOCK 0x00080000 /* Dock/Undock */
1580 #define E1000_ICR_INT_ASSERTED 0x80000000 /* If this bit asserted, the driver should claim the interrupt */
1581
1582 /* Interrupt Cause Set */
1583 #define E1000_ICS_TXDW E1000_ICR_TXDW /* Transmit desc written back */
1584 #define E1000_ICS_TXQE E1000_ICR_TXQE /* Transmit Queue empty */
1585 #define E1000_ICS_LSC E1000_ICR_LSC /* Link Status Change */
1586 #define E1000_ICS_RXSEQ E1000_ICR_RXSEQ /* rx sequence error */
1587 #define E1000_ICS_RXDMT0 E1000_ICR_RXDMT0 /* rx desc min. threshold */
1588 #define E1000_ICS_RXO E1000_ICR_RXO /* rx overrun */
1589 #define E1000_ICS_RXT0 E1000_ICR_RXT0 /* rx timer intr */
1590 #define E1000_ICS_MDAC E1000_ICR_MDAC /* MDIO access complete */
1591 #define E1000_ICS_RXCFG E1000_ICR_RXCFG /* RX /c/ ordered set */
1592 #define E1000_ICS_GPI_EN0 E1000_ICR_GPI_EN0 /* GP Int 0 */
1593 #define E1000_ICS_GPI_EN1 E1000_ICR_GPI_EN1 /* GP Int 1 */
1594 #define E1000_ICS_GPI_EN2 E1000_ICR_GPI_EN2 /* GP Int 2 */
1595 #define E1000_ICS_GPI_EN3 E1000_ICR_GPI_EN3 /* GP Int 3 */
1596 #define E1000_ICS_TXD_LOW E1000_ICR_TXD_LOW
1597 #define E1000_ICS_SRPD E1000_ICR_SRPD
1598 #define E1000_ICS_ACK E1000_ICR_ACK /* Receive Ack frame */
1599 #define E1000_ICS_MNG E1000_ICR_MNG /* Manageability event */
1600 #define E1000_ICS_DOCK E1000_ICR_DOCK /* Dock/Undock */
1601
1602 /* Interrupt Mask Set */
1603 #define E1000_IMS_TXDW E1000_ICR_TXDW /* Transmit desc written back */
1604 #define E1000_IMS_TXQE E1000_ICR_TXQE /* Transmit Queue empty */
1605 #define E1000_IMS_LSC E1000_ICR_LSC /* Link Status Change */
1606 #define E1000_IMS_RXSEQ E1000_ICR_RXSEQ /* rx sequence error */
1607 #define E1000_IMS_RXDMT0 E1000_ICR_RXDMT0 /* rx desc min. threshold */
1608 #define E1000_IMS_RXO E1000_ICR_RXO /* rx overrun */
1609 #define E1000_IMS_RXT0 E1000_ICR_RXT0 /* rx timer intr */
1610 #define E1000_IMS_MDAC E1000_ICR_MDAC /* MDIO access complete */
1611 #define E1000_IMS_RXCFG E1000_ICR_RXCFG /* RX /c/ ordered set */
1612 #define E1000_IMS_GPI_EN0 E1000_ICR_GPI_EN0 /* GP Int 0 */
1613 #define E1000_IMS_GPI_EN1 E1000_ICR_GPI_EN1 /* GP Int 1 */
1614 #define E1000_IMS_GPI_EN2 E1000_ICR_GPI_EN2 /* GP Int 2 */
1615 #define E1000_IMS_GPI_EN3 E1000_ICR_GPI_EN3 /* GP Int 3 */
1616 #define E1000_IMS_TXD_LOW E1000_ICR_TXD_LOW
1617 #define E1000_IMS_SRPD E1000_ICR_SRPD
1618 #define E1000_IMS_ACK E1000_ICR_ACK /* Receive Ack frame */
1619 #define E1000_IMS_MNG E1000_ICR_MNG /* Manageability event */
1620 #define E1000_IMS_DOCK E1000_ICR_DOCK /* Dock/Undock */
1621
1622 /* Interrupt Mask Clear */
1623 #define E1000_IMC_TXDW E1000_ICR_TXDW /* Transmit desc written back */
1624 #define E1000_IMC_TXQE E1000_ICR_TXQE /* Transmit Queue empty */
1625 #define E1000_IMC_LSC E1000_ICR_LSC /* Link Status Change */
1626 #define E1000_IMC_RXSEQ E1000_ICR_RXSEQ /* rx sequence error */
1627 #define E1000_IMC_RXDMT0 E1000_ICR_RXDMT0 /* rx desc min. threshold */
1628 #define E1000_IMC_RXO E1000_ICR_RXO /* rx overrun */
1629 #define E1000_IMC_RXT0 E1000_ICR_RXT0 /* rx timer intr */
1630 #define E1000_IMC_MDAC E1000_ICR_MDAC /* MDIO access complete */
1631 #define E1000_IMC_RXCFG E1000_ICR_RXCFG /* RX /c/ ordered set */
1632 #define E1000_IMC_GPI_EN0 E1000_ICR_GPI_EN0 /* GP Int 0 */
1633 #define E1000_IMC_GPI_EN1 E1000_ICR_GPI_EN1 /* GP Int 1 */
1634 #define E1000_IMC_GPI_EN2 E1000_ICR_GPI_EN2 /* GP Int 2 */
1635 #define E1000_IMC_GPI_EN3 E1000_ICR_GPI_EN3 /* GP Int 3 */
1636 #define E1000_IMC_TXD_LOW E1000_ICR_TXD_LOW
1637 #define E1000_IMC_SRPD E1000_ICR_SRPD
1638 #define E1000_IMC_ACK E1000_ICR_ACK /* Receive Ack frame */
1639 #define E1000_IMC_MNG E1000_ICR_MNG /* Manageability event */
1640 #define E1000_IMC_DOCK E1000_ICR_DOCK /* Dock/Undock */
1641
1642 /* Receive Control */
1643 #define E1000_RCTL_RST 0x00000001 /* Software reset */
1644 #define E1000_RCTL_EN 0x00000002 /* enable */
1645 #define E1000_RCTL_SBP 0x00000004 /* store bad packet */
1646 #define E1000_RCTL_UPE 0x00000008 /* unicast promiscuous enable */
1647 #define E1000_RCTL_MPE 0x00000010 /* multicast promiscuous enab */
1648 #define E1000_RCTL_LPE 0x00000020 /* long packet enable */
1649 #define E1000_RCTL_LBM_NO 0x00000000 /* no loopback mode */
1650 #define E1000_RCTL_LBM_MAC 0x00000040 /* MAC loopback mode */
1651 #define E1000_RCTL_LBM_SLP 0x00000080 /* serial link loopback mode */
1652 #define E1000_RCTL_LBM_TCVR 0x000000C0 /* tcvr loopback mode */
1653 #define E1000_RCTL_DTYP_MASK 0x00000C00 /* Descriptor type mask */
1654 #define E1000_RCTL_DTYP_PS 0x00000400 /* Packet Split descriptor */
1655 #define E1000_RCTL_RDMTS_HALF 0x00000000 /* rx desc min threshold size */
1656 #define E1000_RCTL_RDMTS_QUAT 0x00000100 /* rx desc min threshold size */
1657 #define E1000_RCTL_RDMTS_EIGTH 0x00000200 /* rx desc min threshold size */
1658 #define E1000_RCTL_MO_SHIFT 12 /* multicast offset shift */
1659 #define E1000_RCTL_MO_0 0x00000000 /* multicast offset 11:0 */
1660 #define E1000_RCTL_MO_1 0x00001000 /* multicast offset 12:1 */
1661 #define E1000_RCTL_MO_2 0x00002000 /* multicast offset 13:2 */
1662 #define E1000_RCTL_MO_3 0x00003000 /* multicast offset 15:4 */
1663 #define E1000_RCTL_MDR 0x00004000 /* multicast desc ring 0 */
1664 #define E1000_RCTL_BAM 0x00008000 /* broadcast enable */
1665 /* these buffer sizes are valid if E1000_RCTL_BSEX is 0 */
1666 #define E1000_RCTL_SZ_2048 0x00000000 /* rx buffer size 2048 */
1667 #define E1000_RCTL_SZ_1024 0x00010000 /* rx buffer size 1024 */
1668 #define E1000_RCTL_SZ_512 0x00020000 /* rx buffer size 512 */
1669 #define E1000_RCTL_SZ_256 0x00030000 /* rx buffer size 256 */
1670 /* these buffer sizes are valid if E1000_RCTL_BSEX is 1 */
1671 #define E1000_RCTL_SZ_16384 0x00010000 /* rx buffer size 16384 */
1672 #define E1000_RCTL_SZ_8192 0x00020000 /* rx buffer size 8192 */
1673 #define E1000_RCTL_SZ_4096 0x00030000 /* rx buffer size 4096 */
1674 #define E1000_RCTL_VFE 0x00040000 /* vlan filter enable */
1675 #define E1000_RCTL_CFIEN 0x00080000 /* canonical form enable */
1676 #define E1000_RCTL_CFI 0x00100000 /* canonical form indicator */
1677 #define E1000_RCTL_DPF 0x00400000 /* discard pause frames */
1678 #define E1000_RCTL_PMCF 0x00800000 /* pass MAC control frames */
1679 #define E1000_RCTL_BSEX 0x02000000 /* Buffer size extension */
1680 #define E1000_RCTL_SECRC 0x04000000 /* Strip Ethernet CRC */
1681 #define E1000_RCTL_FLXBUF_MASK 0x78000000 /* Flexible buffer size */
1682 #define E1000_RCTL_FLXBUF_SHIFT 27 /* Flexible buffer shift */
1683
1684 /* Use byte values for the following shift parameters
1685  * Usage:
1686  * psrctl |= (((ROUNDUP(value0, 128) >> E1000_PSRCTL_BSIZE0_SHIFT) &
1687  * E1000_PSRCTL_BSIZE0_MASK) |
1688  * ((ROUNDUP(value1, 1024) >> E1000_PSRCTL_BSIZE1_SHIFT) &
1689  * E1000_PSRCTL_BSIZE1_MASK) |
1690  * ((ROUNDUP(value2, 1024) << E1000_PSRCTL_BSIZE2_SHIFT) &
1691  * E1000_PSRCTL_BSIZE2_MASK) |
1692  * ((ROUNDUP(value3, 1024) << E1000_PSRCTL_BSIZE3_SHIFT) |;
1693  * E1000_PSRCTL_BSIZE3_MASK))
1694  * where value0 = [128..16256], default=256
1695  * value1 = [1024..64512], default=4096
1696  * value2 = [0..64512], default=4096
1697  * value3 = [0..64512], default=0
1698  */
1699
1700 #define E1000_PSRCTL_BSIZE0_MASK 0x0000007F
1701 #define E1000_PSRCTL_BSIZE1_MASK 0x00003F00
1702 #define E1000_PSRCTL_BSIZE2_MASK 0x003F0000
1703 #define E1000_PSRCTL_BSIZE3_MASK 0x3F000000
1704
1705 #define E1000_PSRCTL_BSIZE0_SHIFT 7 /* Shift _right_ 7 */
1706 #define E1000_PSRCTL_BSIZE1_SHIFT 2 /* Shift _right_ 2 */
1707 #define E1000_PSRCTL_BSIZE2_SHIFT 6 /* Shift _left_ 6 */
1708 #define E1000_PSRCTL_BSIZE3_SHIFT 14 /* Shift _left_ 14 */
1709
1710 /* Receive Descriptor */
1711 #define E1000_RDT_DELAY 0x0000ffff /* Delay timer (1=1024us) */
1712 #define E1000_RDT_FPDB 0x80000000 /* Flush descriptor block */
1713 #define E1000_RDLEN_LEN 0x0007ff80 /* descriptor length */
1714 #define E1000_RDH_RDH 0x0000ffff /* receive descriptor head */
1715 #define E1000_RDT_RDT 0x0000ffff /* receive descriptor tail */
1716
1717 /* Flow Control */
1718 #define E1000_FCRTH_RTH 0x0000FFF8 /* Mask Bits[15:3] for RTH */
1719 #define E1000_FCRTH_XFCE 0x80000000 /* External Flow Control Enable */
1720 #define E1000_FCRTL_RTL 0x0000FFF8 /* Mask Bits[15:3] for RTL */
1721 #define E1000_FCRTL_XONE 0x80000000 /* Enable XON frame transmission */
1722
1723 /* Header split receive */
1724 #define E1000_RFCTL_ISCSI_DIS 0x00000001
1725 #define E1000_RFCTL_ISCSI_DWC_MASK 0x0000003E
1726 #define E1000_RFCTL_ISCSI_DWC_SHIFT 1
1727 #define E1000_RFCTL_NFSW_DIS 0x00000040
1728 #define E1000_RFCTL_NFSR_DIS 0x00000080
1729 #define E1000_RFCTL_NFS_VER_MASK 0x00000300
1730 #define E1000_RFCTL_NFS_VER_SHIFT 8
1731 #define E1000_RFCTL_IPV6_DIS 0x00000400
1732 #define E1000_RFCTL_IPV6_XSUM_DIS 0x00000800
1733 #define E1000_RFCTL_ACK_DIS 0x00001000
1734 #define E1000_RFCTL_ACKD_DIS 0x00002000
1735 #define E1000_RFCTL_IPFRSP_DIS 0x00004000
1736 #define E1000_RFCTL_EXTEN 0x00008000
1737 #define E1000_RFCTL_IPV6_EX_DIS 0x00010000
1738 #define E1000_RFCTL_NEW_IPV6_EXT_DIS 0x00020000
1739
1740 /* Receive Descriptor Control */
1741 #define E1000_RXDCTL_PTHRESH 0x0000003F /* RXDCTL Prefetch Threshold */
1742 #define E1000_RXDCTL_HTHRESH 0x00003F00 /* RXDCTL Host Threshold */
1743 #define E1000_RXDCTL_WTHRESH 0x003F0000 /* RXDCTL Writeback Threshold */
1744 #define E1000_RXDCTL_GRAN 0x01000000 /* RXDCTL Granularity */
1745
1746 /* Transmit Descriptor Control */
1747 #define E1000_TXDCTL_PTHRESH 0x000000FF /* TXDCTL Prefetch Threshold */
1748 #define E1000_TXDCTL_HTHRESH 0x0000FF00 /* TXDCTL Host Threshold */
1749 #define E1000_TXDCTL_WTHRESH 0x00FF0000 /* TXDCTL Writeback Threshold */
1750 #define E1000_TXDCTL_GRAN 0x01000000 /* TXDCTL Granularity */
1751 #define E1000_TXDCTL_LWTHRESH 0xFE000000 /* TXDCTL Low Threshold */
1752 #define E1000_TXDCTL_FULL_TX_DESC_WB 0x01010000 /* GRAN=1, WTHRESH=1 */
1753 #define E1000_TXDCTL_COUNT_DESC 0x00400000 /* Enable the counting of desc.
1754  still to be processed. */
1755
1756 /* Transmit Configuration Word */
1757 #define E1000_TXCW_FD 0x00000020 /* TXCW full duplex */
1758 #define E1000_TXCW_HD 0x00000040 /* TXCW half duplex */
1759 #define E1000_TXCW_PAUSE 0x00000080 /* TXCW sym pause request */
1760 #define E1000_TXCW_ASM_DIR 0x00000100 /* TXCW astm pause direction */
1761 #define E1000_TXCW_PAUSE_MASK 0x00000180 /* TXCW pause request mask */
1762 #define E1000_TXCW_RF 0x00003000 /* TXCW remote fault */
1763 #define E1000_TXCW_NP 0x00008000 /* TXCW next page */
1764 #define E1000_TXCW_CW 0x0000ffff /* TxConfigWord mask */
1765 #define E1000_TXCW_TXC 0x40000000 /* Transmit Config control */
1766 #define E1000_TXCW_ANE 0x80000000 /* Auto-neg enable */
1767
1768 /* Receive Configuration Word */
1769 #define E1000_RXCW_CW 0x0000ffff /* RxConfigWord mask */
1770 #define E1000_RXCW_NC 0x04000000 /* Receive config no carrier */
1771 #define E1000_RXCW_IV 0x08000000 /* Receive config invalid */
1772 #define E1000_RXCW_CC 0x10000000 /* Receive config change */
1773 #define E1000_RXCW_C 0x20000000 /* Receive config */
1774 #define E1000_RXCW_SYNCH 0x40000000 /* Receive config synch */
1775 #define E1000_RXCW_ANC 0x80000000 /* Auto-neg complete */
1776
1777 /* Transmit Control */
1778 #define E1000_TCTL_RST 0x00000001 /* software reset */
1779 #define E1000_TCTL_EN 0x00000002 /* enable tx */
1780 #define E1000_TCTL_BCE 0x00000004 /* busy check enable */
1781 #define E1000_TCTL_PSP 0x00000008 /* pad short packets */
1782 #define E1000_TCTL_CT 0x00000ff0 /* collision threshold */
1783 #define E1000_TCTL_COLD 0x003ff000 /* collision distance */
1784 #define E1000_TCTL_SWXOFF 0x00400000 /* SW Xoff transmission */
1785 #define E1000_TCTL_PBE 0x00800000 /* Packet Burst Enable */
1786 #define E1000_TCTL_RTLC 0x01000000 /* Re-transmit on late collision */
1787 #define E1000_TCTL_NRTU 0x02000000 /* No Re-transmit on underrun */
1788 #define E1000_TCTL_MULR 0x10000000 /* Multiple request support */
1789
1790 /* Receive Checksum Control */
1791 #define E1000_RXCSUM_PCSS_MASK 0x000000FF /* Packet Checksum Start */
1792 #define E1000_RXCSUM_IPOFL 0x00000100 /* IPv4 checksum offload */
1793 #define E1000_RXCSUM_TUOFL 0x00000200 /* TCP / UDP checksum offload */
1794 #define E1000_RXCSUM_IPV6OFL 0x00000400 /* IPv6 checksum offload */
1795 #define E1000_RXCSUM_IPPCSE 0x00001000 /* IP payload checksum enable */
1796 #define E1000_RXCSUM_PCSD 0x00002000 /* packet checksum disabled */
1797
1798
1799 /* Definitions for power management and wakeup registers */
1800 /* Wake Up Control */
1801 #define E1000_WUC_APME 0x00000001 /* APM Enable */
1802 #define E1000_WUC_PME_EN 0x00000002 /* PME Enable */
1803 #define E1000_WUC_PME_STATUS 0x00000004 /* PME Status */
1804 #define E1000_WUC_APMPME 0x00000008 /* Assert PME on APM Wakeup */
1805 #define E1000_WUC_SPM 0x80000000 /* Enable SPM */
1806
1807 /* Wake Up Filter Control */
1808 #define E1000_WUFC_LNKC 0x00000001 /* Link Status Change Wakeup Enable */
1809 #define E1000_WUFC_MAG 0x00000002 /* Magic Packet Wakeup Enable */
1810 #define E1000_WUFC_EX 0x00000004 /* Directed Exact Wakeup Enable */
1811 #define E1000_WUFC_MC 0x00000008 /* Directed Multicast Wakeup Enable */
1812 #define E1000_WUFC_BC 0x00000010 /* Broadcast Wakeup Enable */
1813 #define E1000_WUFC_ARP 0x00000020 /* ARP Request Packet Wakeup Enable */
1814 #define E1000_WUFC_IPV4 0x00000040 /* Directed IPv4 Packet Wakeup Enable */
1815 #define E1000_WUFC_IPV6 0x00000080 /* Directed IPv6 Packet Wakeup Enable */
1816 #define E1000_WUFC_IGNORE_TCO 0x00008000 /* Ignore WakeOn TCO packets */
1817 #define E1000_WUFC_FLX0 0x00010000 /* Flexible Filter 0 Enable */
1818 #define E1000_WUFC_FLX1 0x00020000 /* Flexible Filter 1 Enable */
1819 #define E1000_WUFC_FLX2 0x00040000 /* Flexible Filter 2 Enable */
1820 #define E1000_WUFC_FLX3 0x00080000 /* Flexible Filter 3 Enable */
1821 #define E1000_WUFC_ALL_FILTERS 0x000F00FF /* Mask for all wakeup filters */
1822 #define E1000_WUFC_FLX_OFFSET 16 /* Offset to the Flexible Filters bits */
1823 #define E1000_WUFC_FLX_FILTERS 0x000F0000 /* Mask for the 4 flexible filters */
1824
1825 /* Wake Up Status */
1826 #define E1000_WUS_LNKC 0x00000001 /* Link Status Changed */
1827 #define E1000_WUS_MAG 0x00000002 /* Magic Packet Received */
1828 #define E1000_WUS_EX 0x00000004 /* Directed Exact Received */
1829 #define E1000_WUS_MC 0x00000008 /* Directed Multicast Received */
1830 #define E1000_WUS_BC 0x00000010 /* Broadcast Received */
1831 #define E1000_WUS_ARP 0x00000020 /* ARP Request Packet Received */
1832 #define E1000_WUS_IPV4 0x00000040 /* Directed IPv4 Packet Wakeup Received */
1833 #define E1000_WUS_IPV6 0x00000080 /* Directed IPv6 Packet Wakeup Received */
1834 #define E1000_WUS_FLX0 0x00010000 /* Flexible Filter 0 Match */
1835 #define E1000_WUS_FLX1 0x00020000 /* Flexible Filter 1 Match */
1836 #define E1000_WUS_FLX2 0x00040000 /* Flexible Filter 2 Match */
1837 #define E1000_WUS_FLX3 0x00080000 /* Flexible Filter 3 Match */
1838 #define E1000_WUS_FLX_FILTERS 0x000F0000 /* Mask for the 4 flexible filters */
1839
1840 /* Management Control */
1841 #define E1000_MANC_SMBUS_EN 0x00000001 /* SMBus Enabled - RO */
1842 #define E1000_MANC_ASF_EN 0x00000002 /* ASF Enabled - RO */
1843 #define E1000_MANC_R_ON_FORCE 0x00000004 /* Reset on Force TCO - RO */
1844 #define E1000_MANC_RMCP_EN 0x00000100 /* Enable RCMP 026Fh Filtering */
1845 #define E1000_MANC_0298_EN 0x00000200 /* Enable RCMP 0298h Filtering */
1846 #define E1000_MANC_IPV4_EN 0x00000400 /* Enable IPv4 */
1847 #define E1000_MANC_IPV6_EN 0x00000800 /* Enable IPv6 */
1848 #define E1000_MANC_SNAP_EN 0x00001000 /* Accept LLC/SNAP */
1849 #define E1000_MANC_ARP_EN 0x00002000 /* Enable ARP Request Filtering */
1850 #define E1000_MANC_NEIGHBOR_EN 0x00004000 /* Enable Neighbor Discovery
1851  * Filtering */
1852 #define E1000_MANC_ARP_RES_EN 0x00008000 /* Enable ARP response Filtering */
1853 #define E1000_MANC_TCO_RESET 0x00010000 /* TCO Reset Occurred */
1854 #define E1000_MANC_RCV_TCO_EN 0x00020000 /* Receive TCO Packets Enabled */
1855 #define E1000_MANC_REPORT_STATUS 0x00040000 /* Status Reporting Enabled */
1856 #define E1000_MANC_BLK_PHY_RST_ON_IDE 0x00040000 /* Block phy resets */
1857 #define E1000_MANC_EN_MAC_ADDR_FILTER 0x00100000 /* Enable MAC address
1858  * filtering */
1859 #define E1000_MANC_EN_MNG2HOST 0x00200000 /* Enable MNG packets to host
1860  * memory */
1861 #define E1000_MANC_EN_IP_ADDR_FILTER 0x00400000 /* Enable IP address
1862  * filtering */
1863 #define E1000_MANC_EN_XSUM_FILTER 0x00800000 /* Enable checksum filtering */
1864 #define E1000_MANC_BR_EN 0x01000000 /* Enable broadcast filtering */
1865 #define E1000_MANC_SMB_REQ 0x01000000 /* SMBus Request */
1866 #define E1000_MANC_SMB_GNT 0x02000000 /* SMBus Grant */
1867 #define E1000_MANC_SMB_CLK_IN 0x04000000 /* SMBus Clock In */
1868 #define E1000_MANC_SMB_DATA_IN 0x08000000 /* SMBus Data In */
1869 #define E1000_MANC_SMB_DATA_OUT 0x10000000 /* SMBus Data Out */
1870 #define E1000_MANC_SMB_CLK_OUT 0x20000000 /* SMBus Clock Out */
1871
1872 #define E1000_MANC_SMB_DATA_OUT_SHIFT 28 /* SMBus Data Out Shift */
1873 #define E1000_MANC_SMB_CLK_OUT_SHIFT 29 /* SMBus Clock Out Shift */
1874
1875 /* SW Semaphore Register */
1876 #define E1000_SWSM_SMBI 0x00000001 /* Driver Semaphore bit */
1877 #define E1000_SWSM_SWESMBI 0x00000002 /* FW Semaphore bit */
1878 #define E1000_SWSM_WMNG 0x00000004 /* Wake MNG Clock */
1879 #define E1000_SWSM_DRV_LOAD 0x00000008 /* Driver Loaded Bit */
1880
1881 /* FW Semaphore Register */
1882 #define E1000_FWSM_MODE_MASK 0x0000000E /* FW mode */
1883 #define E1000_FWSM_MODE_SHIFT 1
1884 #define E1000_FWSM_FW_VALID 0x00008000 /* FW established a valid mode */
1885
1886 /* FFLT Debug Register */
1887 #define E1000_FFLT_DBG_INVC 0x00100000 /* Invalid /C/ code handling */
1888
1889 typedef enum {
1890  em_mng_mode_none = 0,
1891  em_mng_mode_asf,
1892  em_mng_mode_pt,
1893  em_mng_mode_ipmi,
1894  em_mng_mode_host_interface_only
1895 } em_mng_mode;
1896
1897 /* Host Inteface Control Register */
1898 #define E1000_HICR_EN 0x00000001 /* Enable Bit - RO */
1899 #define E1000_HICR_C 0x00000002 /* Driver sets this bit when done
1900  * to put command in RAM */
1901 #define E1000_HICR_SV 0x00000004 /* Status Validity */
1902 #define E1000_HICR_FWR 0x00000080 /* FW reset. Set by the Host */
1903
1904 /* Host Interface Command Interface - Address range 0x8800-0x8EFF */
1905 #define E1000_HI_MAX_DATA_LENGTH 252 /* Host Interface data length */
1906 #define E1000_HI_MAX_BLOCK_BYTE_LENGTH 1792 /* Number of bytes in range */
1907 #define E1000_HI_MAX_BLOCK_DWORD_LENGTH 448 /* Number of dwords in range */
1908 #define E1000_HI_COMMAND_TIMEOUT 500 /* Time in ms to process HI command */
1909
1911  uint8_t command_id;
1912  uint8_t command_length;
1913  uint8_t command_options; /* I/F bits for command, status for return */
1914  uint8_t checksum;
1915 };
1917  struct em_host_command_header command_header; /* Command Head/Command Result Head has 4 bytes */
1918  uint8_t command_data[E1000_HI_MAX_DATA_LENGTH]; /* Command data can length 0..252 */
1919 };
1920
1921 /* Host SMB register #0 */
1922 #define E1000_HSMC0R_CLKIN 0x00000001 /* SMB Clock in */
1923 #define E1000_HSMC0R_DATAIN 0x00000002 /* SMB Data in */
1924 #define E1000_HSMC0R_DATAOUT 0x00000004 /* SMB Data out */
1925 #define E1000_HSMC0R_CLKOUT 0x00000008 /* SMB Clock out */
1926
1927 /* Host SMB register #1 */
1928 #define E1000_HSMC1R_CLKIN E1000_HSMC0R_CLKIN
1929 #define E1000_HSMC1R_DATAIN E1000_HSMC0R_DATAIN
1930 #define E1000_HSMC1R_DATAOUT E1000_HSMC0R_DATAOUT
1931 #define E1000_HSMC1R_CLKOUT E1000_HSMC0R_CLKOUT
1932
1933 /* FW Status Register */
1934 #define E1000_FWSTS_FWS_MASK 0x000000FF /* FW Status */
1935
1936 /* Wake Up Packet Length */
1937 #define E1000_WUPL_LENGTH_MASK 0x0FFF /* Only the lower 12 bits are valid */
1938
1939 #define E1000_MDALIGN 4096
1940
1941 #define E1000_GCR_BEM32 0x00400000
1942 /* Function Active and Power State to MNG */
1943 #define E1000_FACTPS_FUNC0_POWER_STATE_MASK 0x00000003
1944 #define E1000_FACTPS_LAN0_VALID 0x00000004
1945 #define E1000_FACTPS_FUNC0_AUX_EN 0x00000008
1946 #define E1000_FACTPS_FUNC1_POWER_STATE_MASK 0x000000C0
1947 #define E1000_FACTPS_FUNC1_POWER_STATE_SHIFT 6
1948 #define E1000_FACTPS_LAN1_VALID 0x00000100
1949 #define E1000_FACTPS_FUNC1_AUX_EN 0x00000200
1950 #define E1000_FACTPS_FUNC2_POWER_STATE_MASK 0x00003000
1951 #define E1000_FACTPS_FUNC2_POWER_STATE_SHIFT 12
1952 #define E1000_FACTPS_IDE_ENABLE 0x00004000
1953 #define E1000_FACTPS_FUNC2_AUX_EN 0x00008000
1954 #define E1000_FACTPS_FUNC3_POWER_STATE_MASK 0x000C0000
1955 #define E1000_FACTPS_FUNC3_POWER_STATE_SHIFT 18
1956 #define E1000_FACTPS_SP_ENABLE 0x00100000
1957 #define E1000_FACTPS_FUNC3_AUX_EN 0x00200000
1958 #define E1000_FACTPS_FUNC4_POWER_STATE_MASK 0x03000000
1959 #define E1000_FACTPS_FUNC4_POWER_STATE_SHIFT 24
1960 #define E1000_FACTPS_IPMI_ENABLE 0x04000000
1961 #define E1000_FACTPS_FUNC4_AUX_EN 0x08000000
1962 #define E1000_FACTPS_MNGCG 0x20000000
1963 #define E1000_FACTPS_LAN_FUNC_SEL 0x40000000
1964 #define E1000_FACTPS_PM_STATE_CHANGED 0x80000000
1965
1966 /* EEPROM Commands - Microwire */
1967 #define EEPROM_READ_OPCODE_MICROWIRE 0x6 /* EEPROM read opcode */
1968 #define EEPROM_WRITE_OPCODE_MICROWIRE 0x5 /* EEPROM write opcode */
1969 #define EEPROM_ERASE_OPCODE_MICROWIRE 0x7 /* EEPROM erase opcode */
1970 #define EEPROM_EWEN_OPCODE_MICROWIRE 0x13 /* EEPROM erase/write enable */
1971 #define EEPROM_EWDS_OPCODE_MICROWIRE 0x10 /* EEPROM erast/write disable */
1972
1973 /* EEPROM Commands - SPI */
1974 #define EEPROM_MAX_RETRY_SPI 5000 /* Max wait of 5ms, for RDY signal */
1975 #define EEPROM_READ_OPCODE_SPI 0x03 /* EEPROM read opcode */
1976 #define EEPROM_WRITE_OPCODE_SPI 0x02 /* EEPROM write opcode */
1977 #define EEPROM_A8_OPCODE_SPI 0x08 /* opcode bit-3 = address bit-8 */
1978 #define EEPROM_WREN_OPCODE_SPI 0x06 /* EEPROM set Write Enable latch */
1979 #define EEPROM_WRDI_OPCODE_SPI 0x04 /* EEPROM reset Write Enable latch */
1980 #define EEPROM_RDSR_OPCODE_SPI 0x05 /* EEPROM read Status register */
1981 #define EEPROM_WRSR_OPCODE_SPI 0x01 /* EEPROM write Status register */
1982 #define EEPROM_ERASE4K_OPCODE_SPI 0x20 /* EEPROM ERASE 4KB */
1983 #define EEPROM_ERASE64K_OPCODE_SPI 0xD8 /* EEPROM ERASE 64KB */
1984 #define EEPROM_ERASE256_OPCODE_SPI 0xDB /* EEPROM ERASE 256B */
1985
1986 /* EEPROM Size definitions */
1987 #define EEPROM_WORD_SIZE_SHIFT 6
1988 #define EEPROM_SIZE_SHIFT 10
1989 #define EEPROM_SIZE_MASK 0x1C00
1990
1991 /* EEPROM Word Offsets */
1992 #define EEPROM_COMPAT 0x0003
1993 #define EEPROM_ID_LED_SETTINGS 0x0004
1994 #define EEPROM_SERDES_AMPLITUDE 0x0006 /* For SERDES output amplitude adjustment. */
1995 #define EEPROM_PHY_CLASS_WORD 0x0007
1996 #define EEPROM_INIT_CONTROL1_REG 0x000A
1997 #define EEPROM_INIT_CONTROL2_REG 0x000F
1998 #define EEPROM_INIT_CONTROL3_PORT_B 0x0014
1999 #define EEPROM_INIT_CONTROL3_PORT_A 0x0024
2000 #define EEPROM_CFG 0x0012
2001 #define EEPROM_FLASH_VERSION 0x0032
2002 #define EEPROM_CHECKSUM_REG 0x003F
2003
2004 /* Word definitions for ID LED Settings */
2005 #define ID_LED_RESERVED_0000 0x0000
2006 #define ID_LED_RESERVED_FFFF 0xFFFF
2007 #define ID_LED_DEFAULT ((ID_LED_OFF1_ON2 << 12) | \
2008  (ID_LED_OFF1_OFF2 << 8) | \
2009  (ID_LED_DEF1_DEF2 << 4) | \
2010  (ID_LED_DEF1_DEF2))
2011 #define ID_LED_DEF1_DEF2 0x1
2012 #define ID_LED_DEF1_ON2 0x2
2013 #define ID_LED_DEF1_OFF2 0x3
2014 #define ID_LED_ON1_DEF2 0x4
2015 #define ID_LED_ON1_ON2 0x5
2016 #define ID_LED_ON1_OFF2 0x6
2017 #define ID_LED_OFF1_DEF2 0x7
2018 #define ID_LED_OFF1_ON2 0x8
2019 #define ID_LED_OFF1_OFF2 0x9
2020
2021 #define IGP_ACTIVITY_LED_MASK 0xFFFFF0FF
2022 #define IGP_ACTIVITY_LED_ENABLE 0x0300
2023 #define IGP_LED3_MODE 0x07000000
2024
2025
2026 /* Mask bits for SERDES amplitude adjustment in Word 6 of the EEPROM */
2027 #define EEPROM_SERDES_AMPLITUDE_MASK 0x000F
2028
2029 /* Mask bit for PHY class in Word 7 of the EEPROM */
2030 #define EEPROM_PHY_CLASS_A 0x8000
2031
2032 /* Mask bits for fields in Word 0x0a of the EEPROM */
2033 #define EEPROM_WORD0A_ILOS 0x0010
2034 #define EEPROM_WORD0A_SWDPIO 0x01E0
2035 #define EEPROM_WORD0A_LRST 0x0200
2036 #define EEPROM_WORD0A_FD 0x0400
2037 #define EEPROM_WORD0A_66MHZ 0x0800
2038
2039 /* Mask bits for fields in Word 0x0f of the EEPROM */
2040 #define EEPROM_WORD0F_PAUSE_MASK 0x3000
2041 #define EEPROM_WORD0F_PAUSE 0x1000
2042 #define EEPROM_WORD0F_ASM_DIR 0x2000
2043 #define EEPROM_WORD0F_ANE 0x0800
2044 #define EEPROM_WORD0F_SWPDIO_EXT 0x00F0
2045
2046 /* For checksumming, the sum of all words in the EEPROM should equal 0xBABA. */
2047 #define EEPROM_SUM 0xBABA
2048
2049 /* EEPROM Map defines (WORD OFFSETS)*/
2050 #define EEPROM_NODE_ADDRESS_BYTE_0 0
2051 #define EEPROM_PBA_BYTE_1 8
2052
2053 #define EEPROM_RESERVED_WORD 0xFFFF
2054
2055 /* EEPROM Map Sizes (Byte Counts) */
2056 #define PBA_SIZE 4
2057
2058 /* Collision related configuration parameters */
2059 #define E1000_COLLISION_THRESHOLD 15
2060 #define E1000_CT_SHIFT 4
2061 #define E1000_COLLISION_DISTANCE 64
2062 #define E1000_FDX_COLLISION_DISTANCE E1000_COLLISION_DISTANCE
2063 #define E1000_HDX_COLLISION_DISTANCE E1000_COLLISION_DISTANCE
2064 #define E1000_COLD_SHIFT 12
2065
2066 /* Number of Transmit and Receive Descriptors must be a multiple of 8 */
2067 #define REQ_TX_DESCRIPTOR_MULTIPLE 8
2068 #define REQ_RX_DESCRIPTOR_MULTIPLE 8
2069
2070 /* Default values for the transmit IPG register */
2071 #define DEFAULT_82542_TIPG_IPGT 10
2072 #define DEFAULT_82543_TIPG_IPGT_FIBER 9
2073 #define DEFAULT_82543_TIPG_IPGT_COPPER 8
2074
2075 #define E1000_TIPG_IPGT_MASK 0x000003FF
2076 #define E1000_TIPG_IPGR1_MASK 0x000FFC00
2077 #define E1000_TIPG_IPGR2_MASK 0x3FF00000
2078
2079 #define DEFAULT_82542_TIPG_IPGR1 2
2080 #define DEFAULT_82543_TIPG_IPGR1 8
2081 #define E1000_TIPG_IPGR1_SHIFT 10
2082
2083 #define DEFAULT_82542_TIPG_IPGR2 10
2084 #define DEFAULT_82543_TIPG_IPGR2 6
2085 #define E1000_TIPG_IPGR2_SHIFT 20
2086
2087 #define E1000_TXDMAC_DPP 0x00000001
2088
2089 /* Adaptive IFS defines */
2090 #define TX_THRESHOLD_START 8
2091 #define TX_THRESHOLD_INCREMENT 10
2092 #define TX_THRESHOLD_DECREMENT 1
2093 #define TX_THRESHOLD_STOP 190
2094 #define TX_THRESHOLD_DISABLE 0
2095 #define TX_THRESHOLD_TIMER_MS 10000
2096 #define MIN_NUM_XMITS 1000
2097 #define IFS_MAX 80
2098 #define IFS_STEP 10
2099 #define IFS_MIN 40
2100 #define IFS_RATIO 4
2101
2102 /* Extended Configuration Control and Size */
2103 #define E1000_EXTCNF_CTRL_PCIE_WRITE_ENABLE 0x00000001
2104 #define E1000_EXTCNF_CTRL_PHY_WRITE_ENABLE 0x00000002
2105 #define E1000_EXTCNF_CTRL_D_UD_ENABLE 0x00000004
2106 #define E1000_EXTCNF_CTRL_D_UD_LATENCY 0x00000008
2107 #define E1000_EXTCNF_CTRL_D_UD_OWNER 0x00000010
2108 #define E1000_EXTCNF_CTRL_MDIO_SW_OWNERSHIP 0x00000020
2109 #define E1000_EXTCNF_CTRL_MDIO_HW_OWNERSHIP 0x00000040
2110 #define E1000_EXTCNF_CTRL_EXT_CNF_POINTER 0x1FFF0000
2111
2112 #define E1000_EXTCNF_SIZE_EXT_PHY_LENGTH 0x000000FF
2113 #define E1000_EXTCNF_SIZE_EXT_DOCK_LENGTH 0x0000FF00
2114 #define E1000_EXTCNF_SIZE_EXT_PCIE_LENGTH 0x00FF0000
2115
2116 /* PBA constants */
2117 #define E1000_PBA_12K 0x000C /* 12KB, default Rx allocation */
2118 #define E1000_PBA_16K 0x0010 /* 16KB, default TX allocation */
2119 #define E1000_PBA_22K 0x0016
2120 #define E1000_PBA_24K 0x0018
2121 #define E1000_PBA_30K 0x001E
2122 #define E1000_PBA_40K 0x0028
2123 #define E1000_PBA_48K 0x0030 /* 48KB, default RX allocation */
2124
2125 /* Flow Control Constants */
2126 #define FLOW_CONTROL_ADDRESS_LOW 0x00C28001
2127 #define FLOW_CONTROL_ADDRESS_HIGH 0x00000100
2128 #define FLOW_CONTROL_TYPE 0x8808
2129
2130 /* The historical defaults for the flow control values are given below. */
2131 #define FC_DEFAULT_HI_THRESH (0x8000) /* 32KB */
2132 #define FC_DEFAULT_LO_THRESH (0x4000) /* 16KB */
2133 #define FC_DEFAULT_TX_TIMER (0x100) /* ~130 us */
2134
2135 /* PCIX Config space */
2136 #define PCIX_COMMAND_REGISTER 0xE6
2137 #define PCIX_STATUS_REGISTER_LO 0xE8
2138 #define PCIX_STATUS_REGISTER_HI 0xEA
2139
2140 #define PCIX_COMMAND_MMRBC_MASK 0x000C
2141 #define PCIX_COMMAND_MMRBC_SHIFT 0x2
2142 #define PCIX_STATUS_HI_MMRBC_MASK 0x0060
2143 #define PCIX_STATUS_HI_MMRBC_SHIFT 0x5
2144 #define PCIX_STATUS_HI_MMRBC_4K 0x3
2145 #define PCIX_STATUS_HI_MMRBC_2K 0x2
2146
2147
2148 /* Number of bits required to shift right the "pause" bits from the
2149  * EEPROM (bits 13:12) to the "pause" (bits 8:7) field in the TXCW register.
2150  */
2151 #define PAUSE_SHIFT 5
2152
2153 /* Number of bits required to shift left the "SWDPIO" bits from the
2154  * EEPROM (bits 8:5) to the "SWDPIO" (bits 25:22) field in the CTRL register.
2155  */
2156 #define SWDPIO_SHIFT 17
2157
2158 /* Number of bits required to shift left the "SWDPIO_EXT" bits from the
2159  * EEPROM word F (bits 7:4) to the bits 11:8 of The Extended CTRL register.
2160  */
2161 #define SWDPIO__EXT_SHIFT 4
2162
2163 /* Number of bits required to shift left the "ILOS" bit from the EEPROM
2164  * (bit 4) to the "ILOS" (bit 7) field in the CTRL register.
2165  */
2166 #define ILOS_SHIFT 3
2167
2168
2169 #define RECEIVE_BUFFER_ALIGN_SIZE (256)
2170
2171 /* Number of milliseconds we wait for auto-negotiation to complete */
2172 #define LINK_UP_TIMEOUT 500
2173
2174 /* Number of 100 microseconds we wait for PCI Express master disable */
2175 #define MASTER_DISABLE_TIMEOUT 800
2176 /* Number of milliseconds we wait for Eeprom auto read bit done after MAC reset */
2177 #define AUTO_READ_DONE_TIMEOUT 10
2178 /* Number of milliseconds we wait for PHY configuration done after MAC reset */
2179 #define PHY_CFG_TIMEOUT 40
2180
2181 #define E1000_TX_BUFFER_SIZE ((uint32_t)1514)
2182
2183 /* The carrier extension symbol, as received by the NIC. */
2184 #define CARRIER_EXTENSION 0x0F
2185
2186 /* TBI_ACCEPT macro definition:
2187  *
2188  * This macro requires:
2189  * adapter = a pointer to struct em_hw
2190  * status = the 8 bit status field of the RX descriptor with EOP set
2191  * error = the 8 bit error field of the RX descriptor with EOP set
2192  * length = the sum of all the length fields of the RX descriptors that
2193  * make up the current frame
2194  * last_byte = the last byte of the frame DMAed by the hardware
2195  * max_frame_length = the maximum frame length we want to accept.
2196  * min_frame_length = the minimum frame length we want to accept.
2197  *
2198  * This macro is a conditional that should be used in the interrupt
2199  * handler's Rx processing routine when RxErrors have been detected.
2200  *
2201  * Typical use:
2202  * ...
2203  * if (TBI_ACCEPT) {
2204  * accept_frame = TRUE;
2205  * em_tbi_adjust_stats(adapter, MacAddress);
2206  * frame_length--;
2207  * } else {
2208  * accept_frame = FALSE;
2209  * }
2210  * ...
2211  */
2212
2213 #define TBI_ACCEPT(adapter, status, errors, length, last_byte) \
2214  ((adapter)->tbi_compatibility_on && \
2215  (((errors) & E1000_RXD_ERR_FRAME_ERR_MASK) == E1000_RXD_ERR_CE) && \
2216  ((last_byte) == CARRIER_EXTENSION) && \
2217  (((status) & E1000_RXD_STAT_VP) ? \
2218  (((length) > ((adapter)->min_frame_size - VLAN_TAG_SIZE)) && \
2219  ((length) <= ((adapter)->max_frame_size + 1))) : \
2220  (((length) > (adapter)->min_frame_size) && \
2221  ((length) <= ((adapter)->max_frame_size + VLAN_TAG_SIZE + 1)))))
2222
2223
2224 /* Structures, enums, and macros for the PHY */
2225
2226 /* Bit definitions for the Management Data IO (MDIO) and Management Data
2227  * Clock (MDC) pins in the Device Control Register.
2228  */
2229 #define E1000_CTRL_PHY_RESET_DIR E1000_CTRL_SWDPIO0
2230 #define E1000_CTRL_PHY_RESET E1000_CTRL_SWDPIN0
2231 #define E1000_CTRL_MDIO_DIR E1000_CTRL_SWDPIO2
2232 #define E1000_CTRL_MDIO E1000_CTRL_SWDPIN2
2233 #define E1000_CTRL_MDC_DIR E1000_CTRL_SWDPIO3
2234 #define E1000_CTRL_MDC E1000_CTRL_SWDPIN3
2235 #define E1000_CTRL_PHY_RESET_DIR4 E1000_CTRL_EXT_SDP4_DIR
2236 #define E1000_CTRL_PHY_RESET4 E1000_CTRL_EXT_SDP4_DATA
2237
2238 /* PHY 1000 MII Register/Bit Definitions */
2239 /* PHY Registers defined by IEEE */
2240 #define PHY_CTRL 0x00 /* Control Register */
2241 #define PHY_STATUS 0x01 /* Status Regiser */
2242 #define PHY_ID1 0x02 /* Phy Id Reg (word 1) */
2243 #define PHY_ID2 0x03 /* Phy Id Reg (word 2) */
2244 #define PHY_AUTONEG_ADV 0x04 /* Autoneg Advertisement */
2245 #define PHY_LP_ABILITY 0x05 /* Link Partner Ability (Base Page) */
2246 #define PHY_AUTONEG_EXP 0x06 /* Autoneg Expansion Reg */
2247 #define PHY_NEXT_PAGE_TX 0x07 /* Next Page TX */
2248 #define PHY_LP_NEXT_PAGE 0x08 /* Link Partner Next Page */
2249 #define PHY_1000T_CTRL 0x09 /* 1000Base-T Control Reg */
2250 #define PHY_1000T_STATUS 0x0A /* 1000Base-T Status Reg */
2251 #define PHY_EXT_STATUS 0x0F /* Extended Status Reg */
2252
2253 /* M88E1000 Specific Registers */
2254 #define M88E1000_PHY_SPEC_CTRL 0x10 /* PHY Specific Control Register */
2255 #define M88E1000_PHY_SPEC_STATUS 0x11 /* PHY Specific Status Register */
2256 #define M88E1000_INT_ENABLE 0x12 /* Interrupt Enable Register */
2257 #define M88E1000_INT_STATUS 0x13 /* Interrupt Status Register */
2258 #define M88E1000_EXT_PHY_SPEC_CTRL 0x14 /* Extended PHY Specific Control */
2259 #define M88E1000_RX_ERR_CNTR 0x15 /* Receive Error Counter */
2260
2261 #define M88E1000_PHY_EXT_CTRL 0x1A /* PHY extend control register */
2262 #define M88E1000_PHY_PAGE_SELECT 0x1D /* Reg 29 for page number setting */
2263 #define M88E1000_PHY_GEN_CONTROL 0x1E /* Its meaning depends on reg 29 */
2264 #define M88E1000_PHY_VCO_REG_BIT8 0x100 /* Bits 8 & 11 are adjusted for */
2265 #define M88E1000_PHY_VCO_REG_BIT11 0x800 /* improved BER performance */
2266
2267 #define IGP01E1000_IEEE_REGS_PAGE 0x0000
2268 #define IGP01E1000_IEEE_RESTART_AUTONEG 0x3300
2269 #define IGP01E1000_IEEE_FORCE_GIGA 0x0140
2270
2271 /* IGP01E1000 Specific Registers */
2272 #define IGP01E1000_PHY_PORT_CONFIG 0x10 /* PHY Specific Port Config Register */
2273 #define IGP01E1000_PHY_PORT_STATUS 0x11 /* PHY Specific Status Register */
2274 #define IGP01E1000_PHY_PORT_CTRL 0x12 /* PHY Specific Control Register */
2275 #define IGP01E1000_PHY_LINK_HEALTH 0x13 /* PHY Link Health Register */
2276 #define IGP01E1000_GMII_FIFO 0x14 /* GMII FIFO Register */
2277 #define IGP01E1000_PHY_CHANNEL_QUALITY 0x15 /* PHY Channel Quality Register */
2278 #define IGP02E1000_PHY_POWER_MGMT 0x19
2279 #define IGP01E1000_PHY_PAGE_SELECT 0x1F /* PHY Page Select Core Register */
2280
2281 /* IGP01E1000 AGC Registers - stores the cable length values*/
2282 #define IGP01E1000_PHY_AGC_A 0x1172
2283 #define IGP01E1000_PHY_AGC_B 0x1272
2284 #define IGP01E1000_PHY_AGC_C 0x1472
2285 #define IGP01E1000_PHY_AGC_D 0x1872
2286
2287 /* IGP02E1000 AGC Registers for cable length values */
2288 #define IGP02E1000_PHY_AGC_A 0x11B1
2289 #define IGP02E1000_PHY_AGC_B 0x12B1
2290 #define IGP02E1000_PHY_AGC_C 0x14B1
2291 #define IGP02E1000_PHY_AGC_D 0x18B1
2292
2293 /* IGP01E1000 DSP Reset Register */
2294 #define IGP01E1000_PHY_DSP_RESET 0x1F33
2295 #define IGP01E1000_PHY_DSP_SET 0x1F71
2296 #define IGP01E1000_PHY_DSP_FFE 0x1F35
2297
2298 #define IGP01E1000_PHY_CHANNEL_NUM 4
2299 #define IGP02E1000_PHY_CHANNEL_NUM 4
2300
2301 #define IGP01E1000_PHY_AGC_PARAM_A 0x1171
2302 #define IGP01E1000_PHY_AGC_PARAM_B 0x1271
2303 #define IGP01E1000_PHY_AGC_PARAM_C 0x1471
2304 #define IGP01E1000_PHY_AGC_PARAM_D 0x1871
2305
2306 #define IGP01E1000_PHY_EDAC_MU_INDEX 0xC000
2307 #define IGP01E1000_PHY_EDAC_SIGN_EXT_9_BITS 0x8000
2308
2309 #define IGP01E1000_PHY_ANALOG_TX_STATE 0x2890
2310 #define IGP01E1000_PHY_ANALOG_CLASS_A 0x2000
2311 #define IGP01E1000_PHY_FORCE_ANALOG_ENABLE 0x0004
2312 #define IGP01E1000_PHY_DSP_FFE_CM_CP 0x0069
2313
2314 #define IGP01E1000_PHY_DSP_FFE_DEFAULT 0x002A
2315 /* IGP01E1000 PCS Initialization register - stores the polarity status when
2316  * speed = 1000 Mbps. */
2317 #define IGP01E1000_PHY_PCS_INIT_REG 0x00B4
2318 #define IGP01E1000_PHY_PCS_CTRL_REG 0x00B5
2319
2320 #define IGP01E1000_ANALOG_REGS_PAGE 0x20C0
2321
2322 #define MAX_PHY_REG_ADDRESS 0x1F /* 5 bit address bus (0-0x1F) */
2323 #define MAX_PHY_MULTI_PAGE_REG 0xF /*Registers that are equal on all pages*/
2324 /* PHY Control Register */
2325 #define MII_CR_SPEED_SELECT_MSB 0x0040 /* bits 6,13: 10=1000, 01=100, 00=10 */
2326 #define MII_CR_COLL_TEST_ENABLE 0x0080 /* Collision test enable */
2327 #define MII_CR_FULL_DUPLEX 0x0100 /* FDX =1, half duplex =0 */
2328 #define MII_CR_RESTART_AUTO_NEG 0x0200 /* Restart auto negotiation */
2329 #define MII_CR_ISOLATE 0x0400 /* Isolate PHY from MII */
2330 #define MII_CR_POWER_DOWN 0x0800 /* Power down */
2331 #define MII_CR_AUTO_NEG_EN 0x1000 /* Auto Neg Enable */
2332 #define MII_CR_SPEED_SELECT_LSB 0x2000 /* bits 6,13: 10=1000, 01=100, 00=10 */
2333 #define MII_CR_LOOPBACK 0x4000 /* 0 = normal, 1 = loopback */
2334 #define MII_CR_RESET 0x8000 /* 0 = normal, 1 = PHY reset */
2335
2336 /* PHY Status Register */
2337 #define MII_SR_EXTENDED_CAPS 0x0001 /* Extended register capabilities */
2338 #define MII_SR_JABBER_DETECT 0x0002 /* Jabber Detected */
2339 #define MII_SR_LINK_STATUS 0x0004 /* Link Status 1 = link */
2340 #define MII_SR_AUTONEG_CAPS 0x0008 /* Auto Neg Capable */
2341 #define MII_SR_REMOTE_FAULT 0x0010 /* Remote Fault Detect */
2342 #define MII_SR_AUTONEG_COMPLETE 0x0020 /* Auto Neg Complete */
2343 #define MII_SR_PREAMBLE_SUPPRESS 0x0040 /* Preamble may be suppressed */
2344 #define MII_SR_EXTENDED_STATUS 0x0100 /* Ext. status info in Reg 0x0F */
2345 #define MII_SR_100T2_HD_CAPS 0x0200 /* 100T2 Half Duplex Capable */
2346 #define MII_SR_100T2_FD_CAPS 0x0400 /* 100T2 Full Duplex Capable */
2347 #define MII_SR_10T_HD_CAPS 0x0800 /* 10T Half Duplex Capable */
2348 #define MII_SR_10T_FD_CAPS 0x1000 /* 10T Full Duplex Capable */
2349 #define MII_SR_100X_HD_CAPS 0x2000 /* 100X Half Duplex Capable */
2350 #define MII_SR_100X_FD_CAPS 0x4000 /* 100X Full Duplex Capable */
2351 #define MII_SR_100T4_CAPS 0x8000 /* 100T4 Capable */
2352
2353 /* Autoneg Advertisement Register */
2354 #define NWAY_AR_SELECTOR_FIELD 0x0001 /* indicates IEEE 802.3 CSMA/CD */
2355 #define NWAY_AR_10T_HD_CAPS 0x0020 /* 10T Half Duplex Capable */
2356 #define NWAY_AR_10T_FD_CAPS 0x0040 /* 10T Full Duplex Capable */
2357 #define NWAY_AR_100TX_HD_CAPS 0x0080 /* 100TX Half Duplex Capable */
2358 #define NWAY_AR_100TX_FD_CAPS 0x0100 /* 100TX Full Duplex Capable */
2359 #define NWAY_AR_100T4_CAPS 0x0200 /* 100T4 Capable */
2360 #define NWAY_AR_PAUSE 0x0400 /* Pause operation desired */
2361 #define NWAY_AR_ASM_DIR 0x0800 /* Asymmetric Pause Direction bit */
2362 #define NWAY_AR_REMOTE_FAULT 0x2000 /* Remote Fault detected */
2363 #define NWAY_AR_NEXT_PAGE 0x8000 /* Next Page ability supported */
2364
2365 /* Link Partner Ability Register (Base Page) */
2366 #define NWAY_LPAR_SELECTOR_FIELD 0x0000 /* LP protocol selector field */
2367 #define NWAY_LPAR_10T_HD_CAPS 0x0020 /* LP is 10T Half Duplex Capable */
2368 #define NWAY_LPAR_10T_FD_CAPS 0x0040 /* LP is 10T Full Duplex Capable */
2369 #define NWAY_LPAR_100TX_HD_CAPS 0x0080 /* LP is 100TX Half Duplex Capable */
2370 #define NWAY_LPAR_100TX_FD_CAPS 0x0100 /* LP is 100TX Full Duplex Capable */
2371 #define NWAY_LPAR_100T4_CAPS 0x0200 /* LP is 100T4 Capable */
2372 #define NWAY_LPAR_PAUSE 0x0400 /* LP Pause operation desired */
2373 #define NWAY_LPAR_ASM_DIR 0x0800 /* LP Asymmetric Pause Direction bit */
2374 #define NWAY_LPAR_REMOTE_FAULT 0x2000 /* LP has detected Remote Fault */
2375 #define NWAY_LPAR_ACKNOWLEDGE 0x4000 /* LP has rx'd link code word */
2376 #define NWAY_LPAR_NEXT_PAGE 0x8000 /* Next Page ability supported */
2377
2378 /* Autoneg Expansion Register */
2379 #define NWAY_ER_LP_NWAY_CAPS 0x0001 /* LP has Auto Neg Capability */
2380 #define NWAY_ER_PAGE_RXD 0x0002 /* LP is 10T Half Duplex Capable */
2381 #define NWAY_ER_NEXT_PAGE_CAPS 0x0004 /* LP is 10T Full Duplex Capable */
2382 #define NWAY_ER_LP_NEXT_PAGE_CAPS 0x0008 /* LP is 100TX Half Duplex Capable */
2383 #define NWAY_ER_PAR_DETECT_FAULT 0x0010 /* LP is 100TX Full Duplex Capable */
2384
2385 /* Next Page TX Register */
2386 #define NPTX_MSG_CODE_FIELD 0x0001 /* NP msg code or unformatted data */
2387 #define NPTX_TOGGLE 0x0800 /* Toggles between exchanges
2388  * of different NP
2389  */
2390 #define NPTX_ACKNOWLDGE2 0x1000 /* 1 = will comply with msg
2391  * 0 = cannot comply with msg
2392  */
2393 #define NPTX_MSG_PAGE 0x2000 /* formatted(1)/unformatted(0) pg */
2394 #define NPTX_NEXT_PAGE 0x8000 /* 1 = addition NP will follow
2395  * 0 = sending last NP
2396  */
2397
2398 /* Link Partner Next Page Register */
2399 #define LP_RNPR_MSG_CODE_FIELD 0x0001 /* NP msg code or unformatted data */
2400 #define LP_RNPR_TOGGLE 0x0800 /* Toggles between exchanges
2401  * of different NP
2402  */
2403 #define LP_RNPR_ACKNOWLDGE2 0x1000 /* 1 = will comply with msg
2404  * 0 = cannot comply with msg
2405  */
2406 #define LP_RNPR_MSG_PAGE 0x2000 /* formatted(1)/unformatted(0) pg */
2407 #define LP_RNPR_ACKNOWLDGE 0x4000 /* 1 = ACK / 0 = NO ACK */
2408 #define LP_RNPR_NEXT_PAGE 0x8000 /* 1 = addition NP will follow
2409  * 0 = sending last NP
2410  */
2411
2412 /* 1000BASE-T Control Register */
2413 #define CR_1000T_ASYM_PAUSE 0x0080 /* Advertise asymmetric pause bit */
2414 #define CR_1000T_HD_CAPS 0x0100 /* Advertise 1000T HD capability */
2415 #define CR_1000T_FD_CAPS 0x0200 /* Advertise 1000T FD capability */
2416 #define CR_1000T_REPEATER_DTE 0x0400 /* 1=Repeater/switch device port */
2417  /* 0=DTE device */
2418 #define CR_1000T_MS_VALUE 0x0800 /* 1=Configure PHY as Master */
2419  /* 0=Configure PHY as Slave */
2420 #define CR_1000T_MS_ENABLE 0x1000 /* 1=Master/Slave manual config value */
2421  /* 0=Automatic Master/Slave config */
2422 #define CR_1000T_TEST_MODE_NORMAL 0x0000 /* Normal Operation */
2423 #define CR_1000T_TEST_MODE_1 0x2000 /* Transmit Waveform test */
2424 #define CR_1000T_TEST_MODE_2 0x4000 /* Master Transmit Jitter test */
2425 #define CR_1000T_TEST_MODE_3 0x6000 /* Slave Transmit Jitter test */
2426 #define CR_1000T_TEST_MODE_4 0x8000 /* Transmitter Distortion test */
2427
2428 /* 1000BASE-T Status Register */
2429 #define SR_1000T_IDLE_ERROR_CNT 0x00FF /* Num idle errors since last read */
2430 #define SR_1000T_ASYM_PAUSE_DIR 0x0100 /* LP asymmetric pause direction bit */
2431 #define SR_1000T_LP_HD_CAPS 0x0400 /* LP is 1000T HD capable */
2432 #define SR_1000T_LP_FD_CAPS 0x0800 /* LP is 1000T FD capable */
2433 #define SR_1000T_REMOTE_RX_STATUS 0x1000 /* Remote receiver OK */
2434 #define SR_1000T_LOCAL_RX_STATUS 0x2000 /* Local receiver OK */
2435 #define SR_1000T_MS_CONFIG_RES 0x4000 /* 1=Local TX is Master, 0=Slave */
2436 #define SR_1000T_MS_CONFIG_FAULT 0x8000 /* Master/Slave config fault */
2437 #define SR_1000T_REMOTE_RX_STATUS_SHIFT 12
2438 #define SR_1000T_LOCAL_RX_STATUS_SHIFT 13
2439 #define SR_1000T_PHY_EXCESSIVE_IDLE_ERR_COUNT 5
2440 #define FFE_IDLE_ERR_COUNT_TIMEOUT_20 20
2441 #define FFE_IDLE_ERR_COUNT_TIMEOUT_100 100
2442
2443 /* Extended Status Register */
2444 #define IEEE_ESR_1000T_HD_CAPS 0x1000 /* 1000T HD capable */
2445 #define IEEE_ESR_1000T_FD_CAPS 0x2000 /* 1000T FD capable */
2446 #define IEEE_ESR_1000X_HD_CAPS 0x4000 /* 1000X HD capable */
2447 #define IEEE_ESR_1000X_FD_CAPS 0x8000 /* 1000X FD capable */
2448
2449 #define PHY_TX_POLARITY_MASK 0x0100 /* register 10h bit 8 (polarity bit) */
2450 #define PHY_TX_NORMAL_POLARITY 0 /* register 10h bit 8 (normal polarity) */
2451
2452 #define AUTO_POLARITY_DISABLE 0x0010 /* register 11h bit 4 */
2453  /* (0=enable, 1=disable) */
2454
2455 /* M88E1000 PHY Specific Control Register */
2456 #define M88E1000_PSCR_JABBER_DISABLE 0x0001 /* 1=Jabber Function disabled */
2457 #define M88E1000_PSCR_POLARITY_REVERSAL 0x0002 /* 1=Polarity Reversal enabled */
2458 #define M88E1000_PSCR_SQE_TEST 0x0004 /* 1=SQE Test enabled */
2459 #define M88E1000_PSCR_CLK125_DISABLE 0x0010 /* 1=CLK125 low,
2460  * 0=CLK125 toggling
2461  */
2462 #define M88E1000_PSCR_MDI_MANUAL_MODE 0x0000 /* MDI Crossover Mode bits 6:5 */
2463  /* Manual MDI configuration */
2464 #define M88E1000_PSCR_MDIX_MANUAL_MODE 0x0020 /* Manual MDIX configuration */
2465 #define M88E1000_PSCR_AUTO_X_1000T 0x0040 /* 1000BASE-T: Auto crossover,
2466  * 100BASE-TX/10BASE-T:
2467  * MDI Mode
2468  */
2469 #define M88E1000_PSCR_AUTO_X_MODE 0x0060 /* Auto crossover enabled
2470  * all speeds.
2471  */
2472 #define M88E1000_PSCR_10BT_EXT_DIST_ENABLE 0x0080
2473  /* 1=Enable Extended 10BASE-T distance
2474  * (Lower 10BASE-T RX Threshold)
2475  * 0=Normal 10BASE-T RX Threshold */
2476 #define M88E1000_PSCR_MII_5BIT_ENABLE 0x0100
2477  /* 1=5-Bit interface in 100BASE-TX
2478  * 0=MII interface in 100BASE-TX */
2479 #define M88E1000_PSCR_SCRAMBLER_DISABLE 0x0200 /* 1=Scrambler disable */
2480 #define M88E1000_PSCR_FORCE_LINK_GOOD 0x0400 /* 1=Force link good */
2481 #define M88E1000_PSCR_ASSERT_CRS_ON_TX 0x0800 /* 1=Assert CRS on Transmit */
2482
2483 #define M88E1000_PSCR_POLARITY_REVERSAL_SHIFT 1
2484 #define M88E1000_PSCR_AUTO_X_MODE_SHIFT 5
2485 #define M88E1000_PSCR_10BT_EXT_DIST_ENABLE_SHIFT 7
2486
2487 /* M88E1000 PHY Specific Status Register */
2488 #define M88E1000_PSSR_JABBER 0x0001 /* 1=Jabber */
2489 #define M88E1000_PSSR_REV_POLARITY 0x0002 /* 1=Polarity reversed */
2490 #define M88E1000_PSSR_DOWNSHIFT 0x0020 /* 1=Downshifted */
2491 #define M88E1000_PSSR_MDIX 0x0040 /* 1=MDIX; 0=MDI */
2492 #define M88E1000_PSSR_CABLE_LENGTH 0x0380 /* 0=<50M;1=50-80M;2=80-110M;
2493  * 3=110-140M;4=>140M */
2494 #define M88E1000_PSSR_LINK 0x0400 /* 1=Link up, 0=Link down */
2495 #define M88E1000_PSSR_SPD_DPLX_RESOLVED 0x0800 /* 1=Speed & Duplex resolved */
2496 #define M88E1000_PSSR_PAGE_RCVD 0x1000 /* 1=Page received */
2497 #define M88E1000_PSSR_DPLX 0x2000 /* 1=Duplex 0=Half Duplex */
2498 #define M88E1000_PSSR_SPEED 0xC000 /* Speed, bits 14:15 */
2499 #define M88E1000_PSSR_10MBS 0x0000 /* 00=10Mbs */
2500 #define M88E1000_PSSR_100MBS 0x4000 /* 01=100Mbs */
2501 #define M88E1000_PSSR_1000MBS 0x8000 /* 10=1000Mbs */
2502
2503 #define M88E1000_PSSR_REV_POLARITY_SHIFT 1
2504 #define M88E1000_PSSR_DOWNSHIFT_SHIFT 5
2505 #define M88E1000_PSSR_MDIX_SHIFT 6
2506 #define M88E1000_PSSR_CABLE_LENGTH_SHIFT 7
2507
2508 /* M88E1000 Extended PHY Specific Control Register */
2509 #define M88E1000_EPSCR_FIBER_LOOPBACK 0x4000 /* 1=Fiber loopback */
2510 #define M88E1000_EPSCR_DOWN_NO_IDLE 0x8000 /* 1=Lost lock detect enabled.
2511  * Will assert lost lock and bring
2512  * link down if idle not seen
2513  * within 1ms in 1000BASE-T
2514  */
2515 /* Number of times we will attempt to autonegotiate before downshifting if we
2516  * are the master */
2517 #define M88E1000_EPSCR_MASTER_DOWNSHIFT_MASK 0x0C00
2518 #define M88E1000_EPSCR_MASTER_DOWNSHIFT_1X 0x0000
2519 #define M88E1000_EPSCR_MASTER_DOWNSHIFT_2X 0x0400
2520 #define M88E1000_EPSCR_MASTER_DOWNSHIFT_3X 0x0800
2521 #define M88E1000_EPSCR_MASTER_DOWNSHIFT_4X 0x0C00
2522 /* Number of times we will attempt to autonegotiate before downshifting if we
2523  * are the slave */
2524 #define M88E1000_EPSCR_SLAVE_DOWNSHIFT_MASK 0x0300
2525 #define M88E1000_EPSCR_SLAVE_DOWNSHIFT_DIS 0x0000
2526 #define M88E1000_EPSCR_SLAVE_DOWNSHIFT_1X 0x0100
2527 #define M88E1000_EPSCR_SLAVE_DOWNSHIFT_2X 0x0200
2528 #define M88E1000_EPSCR_SLAVE_DOWNSHIFT_3X 0x0300
2529 #define M88E1000_EPSCR_TX_CLK_2_5 0x0060 /* 2.5 MHz TX_CLK */
2530 #define M88E1000_EPSCR_TX_CLK_25 0x0070 /* 25 MHz TX_CLK */
2531 #define M88E1000_EPSCR_TX_CLK_0 0x0000 /* NO TX_CLK */
2532
2533 /* IGP01E1000 Specific Port Config Register - R/W */
2534 #define IGP01E1000_PSCFR_AUTO_MDIX_PAR_DETECT 0x0010
2535 #define IGP01E1000_PSCFR_PRE_EN 0x0020
2536 #define IGP01E1000_PSCFR_SMART_SPEED 0x0080
2537 #define IGP01E1000_PSCFR_DISABLE_TPLOOPBACK 0x0100
2538 #define IGP01E1000_PSCFR_DISABLE_JABBER 0x0400
2539 #define IGP01E1000_PSCFR_DISABLE_TRANSMIT 0x2000
2540
2541 /* IGP01E1000 Specific Port Status Register - R/O */
2542 #define IGP01E1000_PSSR_AUTONEG_FAILED 0x0001 /* RO LH SC */
2543 #define IGP01E1000_PSSR_POLARITY_REVERSED 0x0002
2544 #define IGP01E1000_PSSR_CABLE_LENGTH 0x007C
2545 #define IGP01E1000_PSSR_FULL_DUPLEX 0x0200
2546 #define IGP01E1000_PSSR_LINK_UP 0x0400
2547 #define IGP01E1000_PSSR_MDIX 0x0800
2548 #define IGP01E1000_PSSR_SPEED_MASK 0xC000 /* speed bits mask */
2549 #define IGP01E1000_PSSR_SPEED_10MBPS 0x4000
2550 #define IGP01E1000_PSSR_SPEED_100MBPS 0x8000
2551 #define IGP01E1000_PSSR_SPEED_1000MBPS 0xC000
2552 #define IGP01E1000_PSSR_CABLE_LENGTH_SHIFT 0x0002 /* shift right 2 */
2553 #define IGP01E1000_PSSR_MDIX_SHIFT 0x000B /* shift right 11 */
2554
2555 /* IGP01E1000 Specific Port Control Register - R/W */
2556 #define IGP01E1000_PSCR_TP_LOOPBACK 0x0010
2557 #define IGP01E1000_PSCR_CORRECT_NC_SCMBLR 0x0200
2558 #define IGP01E1000_PSCR_TEN_CRS_SELECT 0x0400
2559 #define IGP01E1000_PSCR_FLIP_CHIP 0x0800
2560 #define IGP01E1000_PSCR_AUTO_MDIX 0x1000
2561 #define IGP01E1000_PSCR_FORCE_MDI_MDIX 0x2000 /* 0-MDI, 1-MDIX */
2562
2563 /* IGP01E1000 Specific Port Link Health Register */
2564 #define IGP01E1000_PLHR_SS_DOWNGRADE 0x8000
2565 #define IGP01E1000_PLHR_GIG_SCRAMBLER_ERROR 0x4000
2566 #define IGP01E1000_PLHR_MASTER_FAULT 0x2000
2567 #define IGP01E1000_PLHR_MASTER_RESOLUTION 0x1000
2568 #define IGP01E1000_PLHR_GIG_REM_RCVR_NOK 0x0800 /* LH */
2569 #define IGP01E1000_PLHR_IDLE_ERROR_CNT_OFLOW 0x0400 /* LH */
2570 #define IGP01E1000_PLHR_DATA_ERR_1 0x0200 /* LH */
2571 #define IGP01E1000_PLHR_DATA_ERR_0 0x0100
2572 #define IGP01E1000_PLHR_AUTONEG_FAULT 0x0040
2573 #define IGP01E1000_PLHR_AUTONEG_ACTIVE 0x0010
2574 #define IGP01E1000_PLHR_VALID_CHANNEL_D 0x0008
2575 #define IGP01E1000_PLHR_VALID_CHANNEL_C 0x0004
2576 #define IGP01E1000_PLHR_VALID_CHANNEL_B 0x0002
2577 #define IGP01E1000_PLHR_VALID_CHANNEL_A 0x0001
2578
2579 /* IGP01E1000 Channel Quality Register */
2580 #define IGP01E1000_MSE_CHANNEL_D 0x000F
2581 #define IGP01E1000_MSE_CHANNEL_C 0x00F0
2582 #define IGP01E1000_MSE_CHANNEL_B 0x0F00
2583 #define IGP01E1000_MSE_CHANNEL_A 0xF000
2584
2585 #define IGP02E1000_PM_SPD 0x0001 /* Smart Power Down */
2586 #define IGP02E1000_PM_D3_LPLU 0x0004 /* Enable LPLU in non-D0a modes */
2587 #define IGP02E1000_PM_D0_LPLU 0x0002 /* Enable LPLU in D0a mode */
2588
2589 /* IGP01E1000 DSP reset macros */
2590 #define DSP_RESET_ENABLE 0x0
2591 #define DSP_RESET_DISABLE 0x2
2592 #define E1000_MAX_DSP_RESETS 10
2593
2594 /* IGP01E1000 & IGP02E1000 AGC Registers */
2595
2596 #define IGP01E1000_AGC_LENGTH_SHIFT 7 /* Coarse - 13:11, Fine - 10:7 */
2597 #define IGP02E1000_AGC_LENGTH_SHIFT 9 /* Coarse - 15:13, Fine - 12:9 */
2598
2599 /* IGP02E1000 AGC Register Length 9-bit mask */
2600 #define IGP02E1000_AGC_LENGTH_MASK 0x7F
2601
2602 /* 7 bits (3 Coarse + 4 Fine) --> 128 optional values */
2603 #define IGP01E1000_AGC_LENGTH_TABLE_SIZE 128
2604 #define IGP02E1000_AGC_LENGTH_TABLE_SIZE 128
2605
2606 /* The precision error of the cable length is +/- 10 meters */
2607 #define IGP01E1000_AGC_RANGE 10
2608 #define IGP02E1000_AGC_RANGE 10
2609
2610 /* IGP01E1000 PCS Initialization register */
2611 /* bits 3:6 in the PCS registers stores the channels polarity */
2612 #define IGP01E1000_PHY_POLARITY_MASK 0x0078
2613
2614 /* IGP01E1000 GMII FIFO Register */
2615 #define IGP01E1000_GMII_FLEX_SPD 0x10 /* Enable flexible speed
2616  * on Link-Up */
2617 #define IGP01E1000_GMII_SPD 0x20 /* Enable SPD */
2618
2619 /* IGP01E1000 Analog Register */
2620 #define IGP01E1000_ANALOG_SPARE_FUSE_STATUS 0x20D1
2621 #define IGP01E1000_ANALOG_FUSE_STATUS 0x20D0
2622 #define IGP01E1000_ANALOG_FUSE_CONTROL 0x20DC
2623 #define IGP01E1000_ANALOG_FUSE_BYPASS 0x20DE
2624
2625 #define IGP01E1000_ANALOG_FUSE_POLY_MASK 0xF000
2626 #define IGP01E1000_ANALOG_FUSE_FINE_MASK 0x0F80
2627 #define IGP01E1000_ANALOG_FUSE_COARSE_MASK 0x0070
2628 #define IGP01E1000_ANALOG_SPARE_FUSE_ENABLED 0x0100
2629 #define IGP01E1000_ANALOG_FUSE_ENABLE_SW_CONTROL 0x0002
2630
2631 #define IGP01E1000_ANALOG_FUSE_COARSE_THRESH 0x0040
2632 #define IGP01E1000_ANALOG_FUSE_COARSE_10 0x0010
2633 #define IGP01E1000_ANALOG_FUSE_FINE_1 0x0080
2634 #define IGP01E1000_ANALOG_FUSE_FINE_10 0x0500
2635
2636
2637 /* Bit definitions for valid PHY IDs. */
2638 /* I = Integrated
2639  * E = External
2640  */
2641 #define M88E1000_E_PHY_ID 0x01410C50
2642 #define M88E1000_I_PHY_ID 0x01410C30
2643 #define M88E1011_I_PHY_ID 0x01410C20
2644 #define IGP01E1000_I_PHY_ID 0x02A80380
2645 #define M88E1000_12_PHY_ID M88E1000_E_PHY_ID
2646 #define M88E1000_14_PHY_ID M88E1000_E_PHY_ID
2647 #define M88E1011_I_REV_4 0x04
2648 #define M88E1111_I_PHY_ID 0x01410CC0
2649 #define L1LXT971A_PHY_ID 0x001378E0
2650
2651 /* Miscellaneous PHY bit definitions. */
2652 #define PHY_PREAMBLE 0xFFFFFFFF
2653 #define PHY_SOF 0x01
2654 #define PHY_OP_READ 0x02
2655 #define PHY_OP_WRITE 0x01
2656 #define PHY_TURNAROUND 0x02
2657 #define PHY_PREAMBLE_SIZE 32
2658 #define MII_CR_SPEED_1000 0x0040
2659 #define MII_CR_SPEED_100 0x2000
2660 #define MII_CR_SPEED_10 0x0000
2661 #define E1000_PHY_ADDRESS 0x01
2662 #define PHY_AUTO_NEG_TIME 45 /* 4.5 Seconds */
2663 #define PHY_FORCE_TIME 20 /* 2.0 Seconds */
2664 #define PHY_REVISION_MASK 0xFFFFFFF0
2665 #define DEVICE_SPEED_MASK 0x00000300 /* Device Ctrl Reg Speed Mask */
2666 #define REG4_SPEED_MASK 0x01E0
2667 #define REG9_SPEED_MASK 0x0300
2668 #define ADVERTISE_10_HALF 0x0001
2669 #define ADVERTISE_10_FULL 0x0002
2670 #define ADVERTISE_100_HALF 0x0004
2671 #define ADVERTISE_100_FULL 0x0008
2672 #define ADVERTISE_1000_HALF 0x0010
2673 #define ADVERTISE_1000_FULL 0x0020
2674 #define AUTONEG_ADVERTISE_SPEED_DEFAULT 0x002F /* Everything but 1000-Half */
2675 #define AUTONEG_ADVERTISE_10_100_ALL 0x000F /* All 10/100 speeds*/
2676 #define AUTONEG_ADVERTISE_10_ALL 0x0003 /* 10Mbps Full & Half speeds*/
2677
2678 #endif /* _EM_HW_H_ */
Definition: if_em_hw.h:1910
Definition: eeprom.c:35
Definition: if_em_hw.h:613
Definition: if_em_hw.h:1916
Definition: if_em_hw.h:739
Definition: if_em_hw.h:795
Definition: if_em_hw.h:820
Definition: if_em_hw.h:347
Definition: if_em_hw.h:826
Definition: nislib.h:49
Definition: if_em_hw.h:250
Definition: if_em_hw.h:1212
Definition: if_em_hw.h:355
Definition: if_em_hw.h:815
Definition: if_em_hw.h:832
Definition: if_em_hw.h:1283
Definition: if_em_hw.h:804
Definition: if_em_hw.h:239
Definition: 8xx_immap.h:312
Definition: if_em_hw.h:255
Definition: if_em_hw.h:768
Definition: if_em_hw.h:696
Definition: if_em_hw.h:577
Definition: if_em_hw.h:587
