RTEMS
5.1
#include <drvmgr.h>
Data Fields | |
int(* | init [DRVMGR_LEVEL_MAX])(struct drvmgr_bus *) |
int(* | remove )(struct drvmgr_bus *) |
int(* | unite )(struct drvmgr_drv *, struct drvmgr_dev *) |
int(* | int_register )(struct drvmgr_dev *, int index, const char *info, drvmgr_isr isr, void *arg) |
int(* | int_unregister )(struct drvmgr_dev *, int index, drvmgr_isr isr, void *arg) |
int(* | int_clear )(struct drvmgr_dev *, int index) |
int(* | int_mask )(struct drvmgr_dev *, int index) |
int(* | int_unmask )(struct drvmgr_dev *, int index) |
int(* | get_params )(struct drvmgr_dev *, struct drvmgr_bus_params *) |
int(* | get_freq )(struct drvmgr_dev *, int, unsigned int *) |
void(* | get_info_dev )(struct drvmgr_dev *, void(*print)(void *p, char *str), void *p) |
Bus operations
void(* drvmgr_bus_ops::get_info_dev) (struct drvmgr_dev *, void(*print)(void *p, char *str), void *p) |
Function called to request information about a device. The bus driver interpret the bus-specific information about the device.
int(* drvmgr_bus_ops::unite) (struct drvmgr_drv *, struct drvmgr_dev *) |
Unite Hardware Device with Driver
