RTEMS
5.1
Data Fields | |
i2c_bus | base |
volatile bbb_i2c_regs * | regs |
struct { | |
volatile uint32_t * ctrl_clkctrl | |
volatile uint32_t * i2c_clkctrl | |
volatile uint32_t * clkstctrl | |
} | clkregs |
struct { | |
volatile uint32_t * conf_sda | |
uint32_t mmode_sda | |
volatile uint32_t * conf_scl | |
uint32_t mmode_scl | |
} | pinregs |
rtems_id | task_id |
rtems_vector_number | irq |
i2c_msg * | buffer |
size_t | buffer_pos |
int | error |
uint32_t | con_reg |
