RTEMS  5.1
ALT_I2C_SLAVE_CONFIG_s Struct Reference
#include <alt_i2c.h>
ALT_I2C_ADDR_MODE_t addr_mode
uint32_t addr
bool nack_enable
This type defines a structure for configuration of the I2C controller when it is operating in slave mode.
Field Documentation
◆ addr
uint32_t ALT_I2C_SLAVE_CONFIG_s::addr
The slave address to which the I2C controller responds when acting as a slave.
◆ addr_mode
ALT_I2C_ADDR_MODE_t ALT_I2C_SLAVE_CONFIG_s::addr_mode
The address mode (7 or 10 bit) when acting as a slave.
◆ nack_enable
bool ALT_I2C_SLAVE_CONFIG_s::nack_enable
Enable generation of a NACK. when the I2C controller is a slave-receiver. If true, it can only generate a NACK after a data byte is received; hence, the data transfer is aborted and the data received is not pushed onto the receive buffer. When false, it generates NACK/ACK, depending on normal criteria.
  • true = generate NACK after data byte received
  • false = generate NACK/ACK normally
