RTEMS  5.1
spwtdp.h
1 /* SPWTDP - SpaceWire Time Distribution Protocol. The driver provides
2  * device discovery and interrupt management.
3  *
4  * COPYRIGHT (c) 2017.
5  * Cobham Gaisler AB
6  *
7  * The license and distribution terms for this file may be
8  * found in the file LICENSE in this distribution or at
9  * http://www.rtems.com/license/LICENSE.
10  *
11  */
12
13 #ifndef __SPWTDP_H__
14 #define __SPWTDP_H__
15
16 #ifdef __cplusplus
17 extern "C" {
18 #endif
19
20 #define SPWTDP_ERR_OK 0
21 #define SPWTDP_ERR_EINVAL -1
22 #define SPWTDP_ERR_ERROR -2
23 #define SPWTDP_ERR_NOINIT -3
24
25 /* Maximum number of SPWTDP devices supported by driver */
26 #define SPWTDP_MAX 2
27
28 /* SPWTDP Register layout */
29 struct spwtdp_regs {
30  volatile unsigned int conf[4]; /* 0x000-0x00C */
31  volatile unsigned int stat[4]; /* 0x010-0x01C */
32  volatile unsigned int cmd_ctrl; /* 0x020 */
33  volatile unsigned int cmd_et[5]; /* 0x024-0x034 */
34  volatile unsigned int resv1[2]; /* 0x038-0x03C */
35  volatile unsigned int dat_ctrl; /* 0x040 */
36  volatile unsigned int dat_et[5]; /* 0x044-0x054 */
37  volatile unsigned int resv2[2]; /* 0x058-0x05C */
38  volatile unsigned int ts_rx_ctrl; /* 0x060 */
39  volatile unsigned int ts_rx_et[5]; /* 0x064-0x074 */
40  volatile unsigned int resv3[2]; /* 0x078-0x07C */
41  volatile unsigned int ts_tx_ctrl; /* 0x080 */
42  volatile unsigned int ts_tx_et[5]; /* 0x084-0x094 */
43  volatile unsigned int resv4[2]; /* 0x098 */
44  volatile unsigned int lat_ctrl; /* 0x0A0 */
45  volatile unsigned int lat_et[5]; /* 0x0A4-0x0B4 */
46  volatile unsigned int resv5[2]; /* 0x0B8-0x0BC */
47  volatile unsigned int ien; /* 0x0C0 */
48  volatile unsigned int ists; /* 0x0C4 */
49  volatile unsigned int dlycnt; /* 0x0C8 */
50  volatile unsigned int dissync; /* 0x0CC */
51  volatile unsigned int resv6[12]; /* 0x0D0-0x0FC */
52  volatile unsigned int edmask[4]; /* 0x100-0x10C */
53  struct {
54  volatile unsigned int ctrl; /* 0x110, 0x130, 0x150, 0x170 */
55  volatile unsigned int et[5]; /* 0x114-0x124, 0x134-0x144, 0x154-0x164, 0x174-0x184, */
56  volatile unsigned int resv0[2]; /* 0x128-0x12C, 0x148-0x14C, 0x168-0x16C, 0x188-0x18C, */
57  } edat[4]; /* 0x110-0x18C */
58  volatile unsigned int resv7[4]; /* 0x190-0x19C */
59  volatile unsigned int pulse[8]; /* 0x1A0-0x1BC */
60  volatile unsigned int resv8[16]; /* 0x1C0-0x1FC */
61 };
62
63 /*
64  * Configuration register definitions
65  */
66 #define CONF0_JE (0x1 << CONF0_JE_BIT)
67 #define CONF0_ST (0x1 << CONF0_ST_BIT)
68 #define CONF0_EP (0x1 << CONF0_EP_BIT)
69 #define CONF0_ET (0x1 << CONF0_ET_BIT)
70 #define CONF0_SP (0x1 << CONF0_SP_BIT)
71 #define CONF0_SE (0x1 << CONF0_SE_BIT)
72 #define CONF0_LE (0x1 << CONF0_LE_BIT)
73 #define CONF0_AE (0x1 << CONF0_AE_BIT)
74 #define CONF0_MAP (0x1f << CONF0_MAP_BIT)
75 #define CONF0_TD (0x1 << CONF0_TD_BIT)
76 #define CONF0_MU (0x1 << CONF0_MU_BIT)
77 #define CONF0_SEL (0x3 << CONF0_SEL_BIT)
78 #define CONF0_ME (0x1 << CONF0_ME_BIT)
79 #define CONF0_RE (0x1 << CONF0_RE_BIT)
80 #define CONF0_TE (0x1 << CONF0_TE_BIT)
81 #define CONF0_RS (0x1 << CONF0_RS_BIT)
82
83 #define CONF0_JE_BIT 24
84 #define CONF0_ST_BIT 21
85 #define CONF0_EP_BIT 20
86 #define CONF0_ET_BIT 19
87 #define CONF0_SP_BIT 18
88 #define CONF0_SE_BIT 17
89 #define CONF0_LE_BIT 16
90 #define CONF0_AE_BIT 15
91 #define CONF0_MAP_BIT 8
92 #define CONF0_TD_BIT 7
93 #define CONF0_MU_BIT 6
94 #define CONF0_SEL_BIT 4
95 #define CONF0_ME_BIT 3
96 #define CONF0_RE_BIT 2
97 #define CONF0_TE_BIT 1
98 #define CONF0_RS_BIT 0
99
100 #define CONF1_FSINC (0x3fffffff << CONF1_FSINC_BIT)
101
102 #define CONF1_FSINC_BIT 0
103
104 #define CONF2_CV (0xffffff << CONF2_CV_BIT)
105 #define CONF2_ETINC (0xff << CONF2_ETINC_BIT)
106
107 #define CONF2_CV_BIT 8
108 #define CONF2_ETINC_BIT 0
109
110 #define CONF3_OUTPORT (0xf << CONF3_OUTPORT_BIT)
111 #define CONF3_INPORT (0xf << CONF3_INPORT_BIT)
112 #define CONF3_STM (0x3f << CONF3_STM_BIT)
113 #define CONF3_DI64R (0x1 << CONF3_DI64R_BIT)
114 #define CONF3_DI64T (0x1 << CONF3_DI64T_BIT)
115 #define CONF3_DI64 (0x1 << CONF3_DI64_BIT)
116 #define CONF3_DI (0x1 << CONF3_DI_BIT)
117 #define CONF3_INRX (0x1f << CONF3_INRX_BIT)
118 #define CONF3_INTX (0x1f << CONF3_INTX_BIT)
119
120 #define CONF3_OUTPORT_BIT 28
121 #define CONF3_INPORT_BIT 24
122 #define CONF3_STM_BIT 16
123 #define CONF3_DI64R_BIT 13
124 #define CONF3_DI64T_BIT 12
125 #define CONF3_DI64_BIT 11
126 #define CONF3_DI_BIT 10
127 #define CONF3_INRX_BIT 5
128 #define CONF3_INTX_BIT 0
129
130 /*
131  * Control register definitions
132  */
133 #define CTRL_NC (0x1 << CTRL_NC_BIT)
134 #define CTRL_IS (0x1 << CTRL_IS_BIT)
135 #define CTRL_SPWTC (0xff << CTRL_SPWTC_BIT)
136 #define CTRL_CPF (0xffff << CTRL_CPF_BIT)
137
138 #define CTRL_NC_BIT 31
139 #define CTRL_IS_BIT 30
140 #define CTRL_SPWTC_BIT 16
141 #define CTRL_CPF_BIT 0
142
143 /*
144  * Interrupt register definition
145  */
146 #define SPWTDP_IRQ_S (0x1 << SPWTDP_IRQ_S_BIT)
147 #define SPWTDP_IRQ_TR (0x1 << SPWTDP_IRQ_TR_BIT)
148 #define SPWTDP_IRQ_TM (0x1 << SPWTDP_IRQ_TM_BIT)
149 #define SPWTDP_IRQ_TT (0x1 << SPWTDP_IRQ_TT_BIT)
150 #define SPWTDP_IRQ_DIR (0x1 << SPWTDP_IRQ_DIR_BIT)
151 #define SPWTDP_IRQ_DIT (0x1 << SPWTDP_IRQ_DIT_BIT)
152 #define SPWTDP_IRQ_EDI0 (0x1 << SPWTDP_IRQ_EDI0_BIT)
153 #define SPWTDP_IRQ_EDI1 (0x1 << SPWTDP_IRQ_EDI1_BIT)
154 #define SPWTDP_IRQ_EDI2 (0x1 << SPWTDP_IRQ_EDI2_BIT)
155 #define SPWTDP_IRQ_EDI3 (0x1 << SPWTDP_IRQ_EDI3_BIT)
156 #define SPWTDP_IRQ_SET (0x1 << SPWTDP_IRQ_SET_BIT)
157 #define SPWTDP_IRQ_P0 (0x1 << SPWTDP_IRQ_P0_BIT)
158 #define SPWTDP_IRQ_P1 (0x1 << SPWTDP_IRQ_P1_BIT)
159 #define SPWTDP_IRQ_P2 (0x1 << SPWTDP_IRQ_P2_BIT)
160 #define SPWTDP_IRQ_P3 (0x1 << SPWTDP_IRQ_P3_BIT)
161 #define SPWTDP_IRQ_P4 (0x1 << SPWTDP_IRQ_P4_BIT)
162 #define SPWTDP_IRQ_P5 (0x1 << SPWTDP_IRQ_P5_BIT)
163 #define SPWTDP_IRQ_P6 (0x1 << SPWTDP_IRQ_P6_BIT)
164 #define SPWTDP_IRQ_P7 (0x1 << SPWTDP_IRQ_P7_BIT)
165 #define SPWTDP_IRQ_NCTC (0x1 << SPWTDP_IRQ_NCTC_BIT)
166 #define SPWTDP_IRQ_WCLEAR \
167  (SPWTDP_IRQ_S | SPWTDP_IRQ_TR | SPWTDP_IRQ_TM | \
168  SPWTDP_IRQ_TT | SPWTDP_IRQ_DIR | SPWTDP_IRQ_DIT | SPWTDP_IRQ_EDI0 | \
169  SPWTDP_IRQ_EDI1 | SPWTDP_IRQ_EDI2 | SPWTDP_IRQ_EDI3 | SPWTDP_IRQ_SET |\
170  SPWTDP_IRQ_P0 | SPWTDP_IRQ_P1 | SPWTDP_IRQ_P2 | SPWTDP_IRQ_P3 | \
171  SPWTDP_IRQ_P4 | SPWTDP_IRQ_P5 | SPWTDP_IRQ_P6 | SPWTDP_IRQ_P7 | \
172  SPWTDP_IRQ_NCTC)
173 #define SPWTDP_IRQ_ALL (SPWTDP_IRQ_WCLEAR)
174
175 #define SPWTDP_IRQ_S_BIT 0
176 #define SPWTDP_IRQ_TR_BIT 1
177 #define SPWTDP_IRQ_TM_BIT 2
178 #define SPWTDP_IRQ_TT_BIT 3
179 #define SPWTDP_IRQ_DIR_BIT 4
180 #define SPWTDP_IRQ_DIT_BIT 5
181 #define SPWTDP_IRQ_EDI0_BIT 6
182 #define SPWTDP_IRQ_EDI1_BIT 7
183 #define SPWTDP_IRQ_EDI2_BIT 8
184 #define SPWTDP_IRQ_EDI3_BIT 9
185 #define SPWTDP_IRQ_SET_BIT 10
186 #define SPWTDP_IRQ_P0_BIT 11
187 #define SPWTDP_IRQ_P1_BIT 12
188 #define SPWTDP_IRQ_P2_BIT 13
189 #define SPWTDP_IRQ_P3_BIT 14
190 #define SPWTDP_IRQ_P4_BIT 15
191 #define SPWTDP_IRQ_P5_BIT 16
192 #define SPWTDP_IRQ_P6_BIT 17
193 #define SPWTDP_IRQ_P7_BIT 18
194 #define SPWTDP_IRQ_NCTC_BIT 19
195
196 /* Register the SPWTDP Driver to the Driver Manager */
197 void spwtdp_register_drv(void);
198
199 /* Open a SPWTDP device by registration order index. A SPWTDP device can only by
200  * opened once. The handle returned must be used as the input parameter 'spwtdp'
201  * in the rest of the calls in the function interface.
202  */
203 extern void *spwtdp_open(int dev_no);
204
205 /* Close a previously opened SPWTDP device */
206 extern int spwtdp_close(void *spwtdp);
207
208 /* Reset SPWTDP Core */
209 extern int spwtdp_reset(void *spwtdp);
210
211 /* Setup the frequency configuration registers */
212 extern int spwtdp_freq_setup(void *spwtdp, uint32_t fsinc, uint32_t cv,
213  uint8_t etinc);
214
215 /* Unmask Interrupts at Interrupt controller */
216 extern int spwtdp_interrupt_unmask(void *spwtdp, uint32_t irqmask);
217
218 /* Mask Interrupts at Interrupt controller */
219 extern int spwtdp_interrupt_mask(void *spwtdp, uint32_t irqmask);
220
221 /* Function ISR callback prototype
222  *
223  * ists - Interrupt STatus register of the SPWTDP core read by ISR
224  * data - Custom data provided by user
225  */
226 typedef void (*spwtdp_isr_t)(unsigned int ists, void *data);
227
228 /* Register an Interrupt handler and custom data, the function call is
229  * removed by calling unregister function.
230  */
231 extern int spwtdp_isr_register(void *spwtdp, spwtdp_isr_t isr, void *data);
232
233 /* Unregister an Interrupt handler */
234 extern int spwtdp_isr_unregister(void *spwtdp);
235
236 /* Get and clear interrupt status */
237 extern int spwtdp_interrupt_status(void *spwtdp, uint32_t *sts,
238  uint32_t clrmask);
239
240 /* Setup Initiator and target */
241 #define SPWTDP_TDP_ENABLE CONF0_TD
242 #define SPWTDP_TDP_DISABLE 0
243 #define SPWTDP_LATENCY_ENABLE CONF0_LE
244 #define SPWTDP_LATENCY_DISABLE 0
245 #define SPWTDP_EXTET_INC_POLARITY_RISING CONF0_EP
246 #define SPWTDP_EXTET_INC_POLARITY_FALLING 0
247 #define SPWTDP_EXTET_INC_ENABLE CONF0_ET
248 #define SPWTDP_EXTET_INC_DISABLE 0
249 #define SPWTDP_EXTET_POLARITY_RISING CONF0_SP
250 #define SPWTDP_EXTET_POLARITY_FALLING 0
251 #define SPWTDP_EXTET_ENABLE CONF0_SE
252 #define SPWTDP_EXTET_DISABLE 0
253 #define SPWTDP_TARGET_SPWSYNC_ENABLE CONF0_ST
254 #define SPWTDP_TARGET_SPWSYNC_DISABLE 0
255 #define SPWTDP_TARGET_JITTERC_ENABLE CONF0_JE
256 #define SPWTDP_TARGET_JITTERC_DISABLE 0
257 #define SPWTDP_TARGET_MITIGATION_ENABLE CONF0_ME
258 #define SPWTDP_TARGET_MITIGATION_DISABLE 0
259 extern int spwtdp_initiator_conf(void *spwtdp, uint8_t mapping,
260  uint32_t options);
261 extern int spwtdp_target_conf(void *spwtdp, uint8_t mapping, uint32_t options);
262
263 /* Setup Initiator and target dist interrupts */
264 extern int spwtdp_initiator_int_conf(void *spwtdp, uint8_t stm, uint8_t inrx,
265  uint8_t intx);
266 #define SPWTDP_TARGET_DISTINT_INTACK CONF3_DI
267 #define SPWTDP_TARGET_DISTINT_INT 0
268 extern int spwtdp_target_int_conf(void *spwtdp, uint8_t inrx, uint8_t intx,
269  uint32_t options);
270
271 /* Enable Initiator and target */
272 extern int spwtdp_initiator_enable(void *spwtdp);
273 extern int spwtdp_target_enable(void *spwtdp);
274
275 /* Disable Initiator and target */
276 extern int spwtdp_initiator_disable(void *spwtdp);
277 extern int spwtdp_target_disable(void *spwtdp);
278
279 /* Get and clear status */
280 extern int spwtdp_status(void *spwtdp, uint32_t *sts, uint32_t clrmask);
281
282 /* Define time struct */
283 /* Length of the max data sample (136 bits), aligned to the next 32-bit word
284  * (160 bits=20 byte=5 words)
285  */
286 #define SPWTDP_TIME_DATA_LENGTH 20
288  uint8_t data[SPWTDP_TIME_DATA_LENGTH];
289  uint32_t preamble;
290 };
291 typedef struct spwtdp_time_t spwtdp_time_t;
292
293 /* Get datation elapsed time */
294 extern int spwtdp_dat_et_get(void *spwtdp, spwtdp_time_t * val);
295 extern int spwtdp_tsrx_et_get(void *spwtdp, spwtdp_time_t * val);
296 extern int spwtdp_tstx_et_get(void *spwtdp, spwtdp_time_t * val);
297 extern int spwtdp_lat_et_get(void *spwtdp, spwtdp_time_t * val);
298 extern int spwtdp_cmd_et_get(void *spwtdp, spwtdp_time_t * val);
299
300 /* Configure TSTX */
301 extern int spwtdp_initiator_tstx_conf(void *spwtdp, uint8_t tstc);
302
303 /* Manage control register */
304 extern int spwtdp_initiator_cmd_et_set(void *spwtdp, spwtdp_time_t val);
305 extern int spwtdp_initiator_cmd_spwtc_set(void *spwtdp, uint8_t spwtc);
306 #define SPWTDP_TARGET_CTRL_NEWCOMMAND_ENABLE CTRL_NC
307 #define SPWTDP_TARGET_CTRL_NEWCOMMAND_DISABLE 0
308 #define SPWTDP_TARGET_CTRL_INIT CTRL_IS
309 #define SPWTDP_TARGET_CTRL_SYNC 0
310 extern int spwtdp_target_cmd_conf(void *spwtdp, uint8_t spwtc, uint16_t cpf,
311  uint32_t options);
312
313 /* Get precision */
314 extern int spwtdp_precision_get(void *spwtdp, uint8_t *fine, uint8_t *coarse);
315
316 #ifdef __cplusplus
317 }
318 #endif
319
320 #endif
unsigned cv
Definition: tte.h:88
Definition: spwtdp.h:287
Definition: spwtdp.h:29
