RTEMS  5.1
spwcuc.h
1 /* SPWCUC - SpaceWire - CCSDS unsegmented Code Transfer Protocol GRLIB core
2  * register driver interface.
3  *
4  * COPYRIGHT (c) 2009.
5  * Cobham Gaisler AB.
6  *
7  * The license and distribution terms for this file may be
8  * found in the file LICENSE in this distribution or at
9  * http://www.rtems.org/license/LICENSE.
10  */
11
12 #ifndef __SPWCUC_H__
13 #define __SPWCUC_H__
14
15 #define PKT_INIT_IRQ 0x1
16 #define PKT_ERR_IRQ 0x2
17 #define PKT_RX_IRQ 0x4
18 #define WRAP_ERR_IRQ 0x8
19 #define WRAP_IRQ 0x10
20 #define SYNC_ERR_IRQ 0x20
21 #define SYNC_IRQ 0x40
22 #define TOL_ERR_IRQ 0x80
23 #define TICK_RX_ERR_IRQ 0x100
24 #define TICK_RX_WRAP_IRQ 0x200
25 #define TICK_RX_IRQ 0x400
26 #define TICK_TX_WRAP_IRQ 0x800
27 #define TICK_TX_IRQ 0x1000
28
29 /* SPWCUC Register layout */
30 struct spwcuc_regs {
31  volatile unsigned int config; /* 00 */
32  volatile unsigned int status; /* 04 */
33  volatile unsigned int control; /* 08 */
34  volatile unsigned int unused0; /* 0c */
35  volatile unsigned int dla; /* 10 */
36  volatile unsigned int pid; /* 14 */
37  volatile unsigned int offset; /* 18 */
38  volatile unsigned int unused1; /* 1c */
39  volatile unsigned int pkt_ct; /* 20 */
40  volatile unsigned int pkt_ft; /* 24 */
41  volatile unsigned int pkt_pf_crc; /* 28 */
42  volatile unsigned int unused2; /* 2c */
43  volatile unsigned int etct; /* 30 */
44  volatile unsigned int etft; /* 34 */
45  volatile unsigned int etct_next; /* 38 */
46  volatile unsigned int etft_next; /* 3c */
47  volatile unsigned int unused3[8]; /* 40-5c */
48  volatile unsigned int pimsr; /* 60 */
49  volatile unsigned int pimr; /* 64 */
50  volatile unsigned int pisr; /* 68 */
51  volatile unsigned int pir; /* 6c */
52  volatile unsigned int imr; /* 70 */
53  volatile unsigned int picr; /* 74 */
54 };
55
56 struct spwcuc_cfg {
57  unsigned char sel_out; /* Bits 3-0 enable time code transmission on respective output */
58  unsigned char sel_in; /* Select SpW to receive time codes on, 0-3 */
59  unsigned char mapping; /* Define mapping of time code time info into T-field, 0-31 */
60  unsigned char tolerance; /* Define SpaceWire time code reception tolerance, 0-31 */
61  unsigned char tid; /* Define CUC P-Field time code identification, 1 = Level 1, 2 = Level 2 */
62  unsigned char ctf; /* If 1 check time code flags to be all zero */
63  unsigned char cp; /* If 1 check P-Field time code id against tid */
64
65  unsigned char txen; /* Enable SpaceWire time code transmission */
66  unsigned char rxen; /* Enable SpaceWire time code reception */
67  unsigned char pktsyncen; /* Enable SpaceWire time CUC packet sync */
68  unsigned char pktiniten; /* Enable SpaceWire time CUC packet init */
69  unsigned char pktrxen; /* Enable SpaceWire time CUC packet reception */
70
71  unsigned char dla; /* SpaceWire destination logical address */
72  unsigned char dla_mask; /* SpaceWire destination logical address mask */
73  unsigned char pid; /* SpaceWire protocol ID */
74
75  unsigned int offset; /* Packet reception offset */
76 };
77
78 /* SPWCUC Statistics gathered by driver */
79 struct spwcuc_stats {
80
81  /* IRQ Stats */
82  unsigned int nirqs;
83  unsigned int tick_tx;
84  unsigned int tick_tx_wrap;
85  unsigned int tick_rx;
86  unsigned int tick_rx_wrap;
87  unsigned int tick_rx_error;
88  unsigned int tolerr;
89  unsigned int sync;
90  unsigned int syncerr;
91  unsigned int wrap;
92  unsigned int wraperr;
93  unsigned int pkt_rx;
94  unsigned int pkt_err;
95  unsigned int pkt_init;
96 };
97
98 /* Function ISR callback prototype
99  *
100  * pimr - PIMR/PIR register of the SPWCUC core read by ISR
101  * data - Custom data provided by user
102  */
103 typedef void (*spwcuc_isr_t)(unsigned int pimr, void *data);
104
105 /* Open a SPWCUC device by minor number. A SPWCUC device can only by opened
106  * once. The handle returned must be used as the input parameter 'spwcuc' in
107  * the rest of the calls in the function interface.
108  */
109 extern void *spwcuc_open(int minor);
110
111 /* Close a previously opened SPWCUC device */
112 extern void spwcuc_close(void *spwcuc);
113
114 /* Reset SPWCUC Core */
115 extern int spwcuc_reset(void *spwcuc);
116
117 /* Enable Interrupts at Interrupt controller */
118 extern void spwcuc_int_enable(void *spwcuc);
119
120 /* Disable Interrupts at Interrupt controller */
121 extern void spwcuc_int_disable(void *spwcuc);
122
123 /* Clear Statistics gathered by the driver */
124 extern void spwcuc_clr_stats(void *spwcuc);
125
126 /* Get Statistics gathered by the driver. The statistics are stored into
127  * the location pointed to by 'stats'.
128  */
129 extern void spwcuc_get_stats(void *spwcuc, struct spwcuc_stats *stats);
130
131 /* Register an Interrupt handler and custom data, the function call is
132  * removed by setting func to NULL.
133  *
134  * The driver's interrupt handler is installed on open(), however the user
135  * callback called from the driver's ISR is installed using this function.
136  */
137 extern void spwcuc_int_register(void *spwcuc, spwcuc_isr_t func, void *data);
138
139 /* Configure the spwcuc core. The configuration is taken from the data
140  * structure pointed to by 'cfg'. See data structure spwcuc_cfg fields.
141  */
142 extern void spwcuc_config(void *spwcuc, struct spwcuc_cfg *cfg);
143
144 /* Return elapsed coarse time */
145 extern unsigned int spwcuc_get_et_coarse(void *spwcuc);
146
147 /* Return elapsed fine time */
148 extern unsigned int spwcuc_get_et_fine(void *spwcuc);
149
150 /* Return elapsed time (coarse and fine) 64-bit value */
151 extern unsigned long long spwcuc_get_et(void *spwcuc);
152
153 /* Return next elapsed coarse time (for use when sending SpW time packet) */
154 extern unsigned int spwcuc_get_next_et_coarse(void *spwcuc);
155
156 /* Return next elapsed fine time (for use when sending SpW time packet) */
157 extern unsigned int spwcuc_get_next_et_fine(void *spwcuc);
158
159 /* Return next elapsed time (for use when sending SpW time packet) */
160 extern unsigned long long spwcuc_get_next_et(void *spwcuc);
161
162 /* Force/Set the elapsed time (coarse 32-bit and fine 24-bit) by writing the
163  * T-Field Time Packet Registers then the FORCE bit.
164  */
165 extern void spwcuc_force_et(void *spwcuc, unsigned long long time);
166
167 /* Return received (from time packet) elapsed coarse time */
168 extern unsigned int spwcuc_get_tp_et_coarse(void *spwcuc);
169
170 /* Return received (from time packet) elapsed fine time */
171 extern unsigned int spwcuc_get_tp_et_fine(void *spwcuc);
172
173 /* Return received (from time packet) elapsed time (coarse and fine) */
174 extern unsigned long long spwcuc_get_tp_et(void *spwcuc);
175
176 /* Clear interrupts */
177 extern void spwcuc_clear_irqs(void *spwcuc, int irqs);
178
179 /* Enable interrupts */
180 extern void spwcuc_enable_irqs(void *spwcuc, int irqs);
181
182 /* Get Register */
183 extern struct spwcuc_regs *spwcuc_get_regs(void *spwcuc);
184
185 /* Register the SPWCUC Driver to the Driver Manager */
186 extern void spwcuc_register(void);
187
188 #endif
Definition: deflate.c:115
Definition: spwcuc.h:56
Definition: spwcuc.h:79
Definition: spwcuc.h:30
Definition: intercom.c:74
