RTEMS  5.1
sonic.h
1 /*
2  * RTEMS NETWORK DRIVER FOR NATIONAL DP83932 `SONIC'
3  * SYSTEMS-ORIENTED NETWORK INTERFACE CONTROLLER
4  *
5  * REUSABLE CHIP DRIVER CONFIGURATION
6  *
7  * References:
8  *
9  * 1) DP83932C-20/25/33 MHz SONIC(TM) Systems-Oriented Network Interface
10  * Controller data sheet. TL/F/10492, RRD-B30M105, National Semiconductor,
11  * 1995.
12  *
13  * 2) Software Driver Programmer's Guide for the DP83932 SONIC(TM),
14  * Application Note 746, Wesley Lee and Mike Lui, TL/F/11140,
15  * RRD-B30M75, National Semiconductor, March, 1991.
16  *
17  * COPYRIGHT (c) 1989-1997.
18  * On-Line Applications Research Corporation (OAR).
19  *
20  * The license and distribution terms for this file may be
21  * found in the file LICENSE in this distribution or at
22  * http://www.rtems.org/license/LICENSE.
23  */
24
25 #ifndef _SONIC_DP83932_
26 #define _SONIC_DP83932_
27
28
29  /*
30  * Debug levels
31  *
32  */
33
34 #define SONIC_DEBUG_NONE 0x0000
35 #define SONIC_DEBUG_ALL 0xFFFF
36 #define SONIC_DEBUG_PRINT_REGISTERS 0x0001
37 #define SONIC_DEBUG_MEMORY 0x0002
38 #define SONIC_DEBUG_MEMORY_ALLOCATE 0x0004
39 #define SONIC_DEBUG_MEMORY_DESCRIPTORS 0x0008
40 #define SONIC_DEBUG_FRAGMENTS 0x0008
41 #define SONIC_DEBUG_CAM 0x0010
42 #define SONIC_DEBUG_DESCRIPTORS 0x0020
43 #define SONIC_DEBUG_ERRORS 0x0040
44 #define SONIC_DEBUG_DUMP_TX_MBUFS 0x0080
45 #define SONIC_DEBUG_DUMP_RX_MBUFS 0x0100
46
47 #define SONIC_DEBUG_DUMP_MBUFS \
48  (SONIC_DEBUG_DUMP_TX_MBUFS|SONIC_DEBUG_DUMP_RX_MBUFS)
49
50 #define SONIC_DEBUG (SONIC_DEBUG_NONE)
51 /*
52 #define SONIC_DEBUG (SONIC_DEBUG_ERRORS | SONIC_DEBUG_PRINT_REGISTERS |\
53  SONIC_DEBUG_DESCRIPTORS)
54 */
55
56 /*
57  ((SONIC_DEBUG_ALL) & ~(SONIC_DEBUG_PRINT_REGISTERS|SONIC_DEBUG_DUMP_MBUFS))
58  ((SONIC_DEBUG_ALL) & ~(SONIC_DEBUG_DUMP_MBUFS))
59 */
60
61 #if (SONIC_DEBUG & SONIC_DEBUG_PRINT_REGISTERS)
62 extern char SONIC_Reg_name[64][6];
63 #endif
64
65
66 /*
67  * Configuration Information
68  */
69
70 typedef void (*sonic_write_register_t)(
71  void *base,
72  uint32_t regno,
73  uint32_t value
74 );
75
76 typedef uint32_t (*sonic_read_register_t)(
77  void *base,
78  uint32_t regno
79 );
80
81 typedef struct {
82  void *base_address;
83  uint32_t vector;
84  uint32_t dcr_value;
85  uint32_t dc2_value;
86  uint32_t tda_count;
87  uint32_t rda_count;
88  sonic_write_register_t write_register;
89  sonic_read_register_t read_register;
91
92 /*
93  ******************************************************************
94  * *
95  * Device Registers *
96  * *
97  ******************************************************************
98  */
99 #define SONIC_REG_CR 0x00 /* Command */
100 #define SONIC_REG_DCR 0x01 /* Data configuration */
101 #define SONIC_REG_RCR 0x02 /* Receive control */
102 #define SONIC_REG_TCR 0x03 /* Transmit control */
103 #define SONIC_REG_IMR 0x04 /* Interrupt mask */
104 #define SONIC_REG_ISR 0x05 /* Interrupt status */
105 #define SONIC_REG_UTDA 0x06 /* Upper transmit descriptor address */
106 #define SONIC_REG_CTDA 0x07 /* Current transmit descriptor address */
107 #define SONIC_REG_URDA 0x0D /* Upper receive descriptor address */
108 #define SONIC_REG_CRDA 0x0E /* Current receive descriptor address */
109 #define SONIC_REG_EOBC 0x13 /* End of buffer word count */
110 #define SONIC_REG_URRA 0x14 /* Upper receive resource */
111 #define SONIC_REG_RSA 0x15 /* Resource start address */
112 #define SONIC_REG_REA 0x16 /* Resource end address */
113 #define SONIC_REG_RRP 0x17 /* Resouce read pointer */
114 #define SONIC_REG_RWP 0x18 /* Resouce write pointer */
115 #define SONIC_REG_CEP 0x21 /* CAM entry pointer */
116 #define SONIC_REG_CAP2 0x22 /* CAM address port 2 */
117 #define SONIC_REG_CAP1 0x23 /* CAM address port 1 */
118 #define SONIC_REG_CAP0 0x24 /* CAM address port 0 */
119 #define SONIC_REG_CE 0x25 /* CAM enable */
120 #define SONIC_REG_CDP 0x26 /* CAM descriptor pointer */
121 #define SONIC_REG_CDC 0x27 /* CAM descriptor count */
122 #define SONIC_REG_SR 0x28 /* Silicon revision */
123 #define SONIC_REG_WT0 0x29 /* Watchdog timer 0 */
124 #define SONIC_REG_WT1 0x2A /* Watchdog timer 1 */
125 #define SONIC_REG_RSC 0x2B /* Receive sequence counter */
126 #define SONIC_REG_CRCT 0x2C /* CRC error tally */
127 #define SONIC_REG_FAET 0x2D /* FAE tally */
128 #define SONIC_REG_MPT 0x2E /* Missed packet tally */
129 #define SONIC_REG_MDT 0x2F /* TX Maximum Deferral */
130 #define SONIC_REG_DCR2 0x3F /* Data configuration 2 */
131
132 /*
133  * Command register
134  */
135 #define CR_LCAM 0x0200
136 #define CR_RRRA 0x0100
137 #define CR_RST 0x0080
138 #define CR_ST 0x0020
139 #define CR_STP 0x0010
140 #define CR_RXEN 0x0008
141 #define CR_RXDIS 0x0004
142 #define CR_TXP 0x0002
143 #define CR_HTX 0x0001
144
145 /*
146  * Data configuration register
147  */
148 #define DCR_EXBUS 0x8000
149 #define DCR_LBR 0x2000
150 #define DCR_PO1 0x1000
151 #define DCR_PO0 0x0800
152 #define DCR_SBUS 0x0400
153 #define DCR_USR1 0x0200
154 #define DCR_USR0 0x0100
155 #define DCR_WC1 0x0080
156 #define DCR_WC0 0x0040
157 #define DCR_DW 0x0020
158 #define DCR_BMS 0x0010
159 #define DCR_RFT1 0x0008
160 #define DCR_RFT0 0x0004
161 #define DCR_TFT1 0x0002
162 #define DCR_TFT0 0x0001
163
164 /* data configuration register aliases */
165 #define DCR_SYNC DCR_SBUS /* synchronous (memory cycle 2 clocks) */
166 #define DCR_ASYNC 0 /* asynchronous (memory cycle 3 clocks) */
167
168 #define DCR_WAIT0 0 /* 0 wait states added */
169 #define DCR_WAIT1 DCR_WC0 /* 1 wait state added */
170 #define DCR_WAIT2 DCR_WC1 /* 2 wait states added */
171 #define DCR_WAIT3 (DCR_WC1|DCR_WC0) /* 3 wait states added */
172
173 #define DCR_DW16 0 /* use 16-bit DMA accesses */
174 #define DCR_DW32 DCR_DW /* use 32-bit DMA accesses */
175
176 #define DCR_DMAEF 0 /* DMA until TX/RX FIFO has emptied/filled */
177 #define DCR_DMABLOCK DCR_BMS /* DMA until RX/TX threshold crossed */
178
179 #define DCR_RFT4 0 /* receive threshold 4 bytes */
180 #define DCR_RFT8 DCR_RFT0 /* receive threshold 8 bytes */
181 #define DCR_RFT16 DCR_RFT1 /* receive threshold 16 bytes */
182 #define DCR_RFT24 (DCR_RFT1|DCR_RFT0) /* receive threshold 24 bytes */
183
184 #define DCR_TFT8 0 /* transmit threshold 8 bytes */
185 #define DCR_TFT16 DCR_TFT0 /* transmit threshold 16 bytes */
186 #define DCR_TFT24 DCR_TFT1 /* transmit threshold 24 bytes */
187 #define DCR_TFT28 (DCR_TFT1|DCR_TFT0) /* transmit threshold 28 bytes */
188
189 /*
190  * Receive control register
191  */
192 #define RCR_ERR 0x8000
193 #define RCR_RNT 0x4000
194 #define RCR_BRD 0x2000
195 #define RCR_PRO 0x1000
196 #define RCR_AMC 0x0800
197 #define RCR_LB1 0x0400
198 #define RCR_LB0 0x0200
199 #define RCR_MC 0x0100
200 #define RCR_BC 0x0080
201 #define RCR_LPKT 0x0040
202 #define RCR_CRS 0x0020
203 #define RCR_COL 0x0010
204 #define RCR_CRCR 0x0008
205 #define RCR_FAER 0x0004
206 #define RCR_LBK 0x0002
207 #define RCR_PRX 0x0001
208
209 /*
210  * Transmit control register
211  */
212 #define TCR_PINT 0x8000
213 #define TCR_POWC 0x4000
214 #define TCR_CRCI 0x2000
215 #define TCR_EXDIS 0x1000
216 #define TCR_EXD 0x0400
217 #define TCR_DEF 0x0200
218 #define TCR_NCRS 0x0100
219 #define TCR_CRSL 0x0080
220 #define TCR_EXC 0x0040
221 #define TCR_OWC 0x0020
222 #define TCR_PMB 0x0008
223 #define TCR_FU 0x0004
224 #define TCR_BCM 0x0002
225 #define TCR_PTX 0x0001
226
227 /*
228  * Interrupt mask register
229  */
230 #define IMR_BREN 0x4000
231 #define IMR_HBLEN 0x2000
232 #define IMR_LCDEN 0x1000
233 #define IMR_PINTEN 0x0800
234 #define IMR_PRXEN 0x0400
235 #define IMR_PTXEN 0x0200
236 #define IMR_TXEREN 0x0100
237 #define IMR_TCEN 0x0080
238 #define IMR_RDEEN 0x0040
239 #define IMR_RBEEN 0x0020
240 #define IMR_RBAEEN 0x0010
241 #define IMR_CRCEN 0x0008
242 #define IMR_FAEEN 0x0004
243 #define IMR_MPEN 0x0002
244 #define IMR_RFOEN 0x0001
245
246 /*
247  * Interrupt status register
248  */
249 #define ISR_BR 0x4000
250 #define ISR_HBL 0x2000
251 #define ISR_LCD 0x1000
252 #define ISR_PINT 0x0800
253 #define ISR_PKTRX 0x0400
254 #define ISR_TXDN 0x0200
255 #define ISR_TXER 0x0100
256 #define ISR_TC 0x0080
257 #define ISR_RDE 0x0040
258 #define ISR_RBE 0x0020
259 #define ISR_RBAE 0x0010
260 #define ISR_CRC 0x0008
261 #define ISR_FAE 0x0004
262 #define ISR_MP 0x0002
263 #define ISR_RFO 0x0001
264
265 /*
266  * Data configuration register 2
267  */
268 #define DCR2_EXPO3 0x8000
269 #define DCR2_EXPO2 0x4000
270 #define DCR2_EXPO1 0x2000
271 #define DCR2_EXPO0 0x1000
272 #define DCR2_HBDIS 0x0800
273 #define DCR2_PH 0x0010
274 #define DCR2_PCM 0x0004
275 #define DCR2_PCNM 0x0002
276 #define DCR2_RJCM 0x0001
277
278 /*
279  * Known values for the Silicon Revision Register.
280  * Note that DP83934 has revision 5 and seems to work.
281  */
282
283 #define SONIC_REVISION_B 4
284 #define SONIC_REVISION_DP83934 5
285 #define SONIC_REVISION_C 6
286
287 /*
288  ******************************************************************
289  * *
290  * Transmit Buffer Management *
291  * *
292  ******************************************************************
293  */
294
295 /*
296  * Transmit descriptor area entry.
297  * There is one transmit descriptor for each packet to be transmitted.
298  * Statically reserve space for up to MAXIMUM_FRAGS_PER_PACKET fragments
299  * per descriptor.
300  */
301 #define MAXIMUM_FRAGS_PER_DESCRIPTOR 6
303  uint32_t status;
304  uint32_t pkt_config;
305  uint32_t pkt_size;
306  uint32_t frag_count;
307
308  /*
309  * Packet fragment pointers
310  */
312  uint32_t frag_lsw; /* LSW of fragment address */
313 #define frag_link frag_lsw
314  uint32_t frag_msw; /* MSW of fragment address */
315  uint32_t frag_size;
316  } frag[MAXIMUM_FRAGS_PER_DESCRIPTOR];
317
318  /*
319  * Space for link if all fragment pointers are used.
320  */
321  uint32_t link_pad;
322
323  /*
324  * Extra RTEMS stuff
325  */
326  struct TransmitDescriptor *next; /* Circularly-linked list */
327  struct mbuf *mbufp; /* First mbuf in packet */
328  volatile uint32_t *linkp; /* Pointer to un[xxx].link */
329 };
331 typedef volatile TransmitDescriptor_t *TransmitDescriptorPointer_t;
332
333 /*
334  * Transmit Configuration.
335  * For standard Ethernet transmission, all bits in the transmit
336  * configuration field are set to 0.
337  */
338 #define TDA_CONFIG_PINT 0x8000
339 #define TDA_CONFIG_POWC 0x4000
340 #define TDA_CONFIG_CRCI 0x2000
341 #define TDA_CONFIG_EXDIS 0x1000
342
343 /*
344  * Transmit status
345  */
346 #define TDA_STATUS_COLLISION_MASK 0xF800
347 #define TDA_STATUS_COLLISION_SHIFT 11
348 #define TDA_STATUS_EXD 0x0400
349 #define TDA_STATUS_DEF 0x0200
350 #define TDA_STATUS_NCRS 0x0100
351 #define TDA_STATUS_CRSL 0x0080
352 #define TDA_STATUS_EXC 0x0040
353 #define TDA_STATUS_OWC 0x0020
354 #define TDA_STATUS_PMB 0x0008
355 #define TDA_STATUS_FU 0x0004
356 #define TDA_STATUS_BCM 0x0002
357 #define TDA_STATUS_PTX 0x0001
358
359 #define TDA_LINK_EOL 0x0001
360 #define TDA_LINK_EOL_MASK 0xFFFE
361
362
363
364 /*
365  ******************************************************************
366  * *
367  * Receive Buffer Management *
368  * *
369  ******************************************************************
370  */
371
372 /*
373  * Receive resource area entry.
374  * There is one receive resource entry for each receive buffer area (RBA).
375  * This driver allows only one packet per receive buffer area, so one
376  * receive resource entry corresponds to one correctly-received packet.
377  */
379  uint32_t buff_ptr_lsw; /* LSW of RBA address */
380  uint32_t buff_ptr_msw; /* MSW of RBA address */
381  uint32_t buff_wc_lsw; /* LSW of RBA size (16-bit words) */
382  uint32_t buff_wc_msw; /* MSW of RBA size (16-bit words) */
383 };
384 typedef struct ReceiveResource ReceiveResource_t;
385 typedef volatile ReceiveResource_t *ReceiveResourcePointer_t;
386
387 /*
388  * Receive descriptor area entry.
389  * There is one receive descriptor for each packet received.
390  */
392  uint32_t status;
393  uint32_t byte_count;
394  uint32_t pkt_lsw; /* LSW of packet address */
395  uint32_t pkt_msw; /* MSW of packet address */
396  uint32_t seq_no;
397  uint32_t link;
398  uint32_t in_use;
399
400  /*
401  * Extra RTEMS stuff
402  */
403  volatile struct ReceiveDescriptor *next; /* Circularly-linked list */
404  struct mbuf *mbufp; /* First mbuf in packet */
405 };
407 typedef volatile ReceiveDescriptor_t *ReceiveDescriptorPointer_t;
408
409 typedef struct {
410  uint32_t cep; /* CAM Entry Pointer */
411  uint32_t cap0; /* CAM Address Port 0 xx-xx-xx-xx-YY-YY */
412  uint32_t cap1; /* CAM Address Port 1 xx-xx-YY-YY-xxxx */
413  uint32_t cap2; /* CAM Address Port 2 YY-YY-xx-xx-xx-xx */
414  uint32_t ce;
416
417 typedef volatile CamDescriptor_t *CamDescriptorPointer_t;
418
419 /*
420  * Receive status
421  */
422 #define RDA_STATUS_ERR 0x8800
423 #define RDA_STATUS_RNT 0x4000
424 #define RDA_STATUS_BRD 0x2000
425 #define RDA_STATUS_PRO 0x1000
426 #define RDA_STATUS_AMC 0x0800
427 #define RDA_STATUS_LB1 0x0400
428 #define RDA_STATUS_LB0 0x0200
429 #define RDA_STATUS_MC 0x0100
430 #define RDA_STATUS_BC 0x0080
431 #define RDA_STATUS_LPKT 0x0040
432 #define RDA_STATUS_CRS 0x0020
433 #define RDA_STATUS_COL 0x0010
434 #define RDA_STATUS_CRCR 0x0008
435 #define RDA_STATUS_FAER 0x0004
436 #define RDA_STATUS_LBK 0x0002
437 #define RDA_STATUS_PRX 0x0001
438
439 #define RDA_LINK_EOL 0x0001
440 #define RDA_LINK_EOL_MASK 0xFFFE
441 #define RDA_IN_USE 0x0000 /* SONIC has finished with the packet */
442  /* and the driver can process it */
443 #define RDA_FREE 0xFFFF /* SONIC can use it */
444
445 /*
446  * Attach routine
447  */
448
449 int rtems_sonic_driver_attach (
450  struct rtems_bsdnet_ifconfig *config,
452 );
453
454 #ifdef CPU_U32_FIX
455 void ipalign(struct mbuf *m);
456 #endif
457
458 #endif /* _SONIC_DP83932_ */
Definition: deflate.c:115
Definition: sonic.h:302
Definition: sonic.h:391
Definition: sonic.h:81
Definition: sonic.h:409
Definition: sonic.h:378
