RTEMS  5.1
slicetimer.h
1 /*===============================================================*\
2 | Project: RTEMS generic MPC5200 BSP |
3 +-----------------------------------------------------------------+
4 | Partially based on the code references which are named below. |
5 | Adaptions, modifications, enhancements and any recent parts of |
6 | the code are: |
7 | Copyright (c) 2005 |
8 | Embedded Brains GmbH |
9 | Obere Lagerstr. 30 |
10 | D-82178 Puchheim |
11 | Germany |
12 | rtems@embedded-brains.de |
13 +-----------------------------------------------------------------+
14 | The license and distribution terms for this file may be |
15 | found in the file LICENSE in this distribution or at |
16 | |
17 | http://www.rtems.org/license/LICENSE. |
18 | |
19 +-----------------------------------------------------------------+
20 | this file declares functions to use the slice timer module
21 \*===============================================================*/
22 #ifndef __SLICETIMER_H__
23 #define __SLICETIMER_H__
24
25 #ifdef __cplusplus
26 extern "C" {
27 #endif
28
29 #define SLT0 0
30 #define SLT1 1
31
32 #define SLT0_INT_FREQUENCY 10000
33 #define SLT1_INT_FREQUENCY 0
34
35 #define SLT_CNTRL_RW (1 << 26)
36 #define SLT_CNTRL_INTEN (1 << 25)
37 #define SLT_CNTRL_TIMEN (1 << 24)
38
39 #define SLT_TSR_ST (1 << 24)
40
41 #define SLT_TSR_COUNT(freq) ((freq) ? ((IPB_CLOCK)/(freq)) : (0xFFFFFF))
42
43 rtems_device_driver slt_initialize( rtems_device_major_number,
44  rtems_device_minor_number,
45  void *
46  );
47
48 #define SLTIME_DRIVER_TABLE_ENTRY \
49  { slt_initialize, NULL, NULL, \
50  NULL, NULL, NULL }
51
52 void mpc5200_slt_isr(uint32_t);
53 rtems_isr mpc5200_slt0_isr(rtems_irq_hdl_param);
54 rtems_isr mpc5200_slt1_isr(rtems_irq_hdl_param);
55 void mpc5200_init_slt(uint32_t);
56 void mpc5200_set_slt_count(uint32_t);
57 void mpc5200_enable_slt_int(uint32_t);
58 void mpc5200_disable_slt_int(uint32_t);
59 uint32_t mpc5200_check_slt_status(uint32_t);
60 /*void sltOn(const rtems_irq_connect_data *);
61 void sltOff(const rtems_irq_connect_data *);
62 int sltIsOn(const rtems_irq_connect_data *);*/
63 void Install_slt(rtems_device_minor_number);
64
65 #ifdef __cplusplus
66 }
67 #endif
68
69 #endif /* __SLICETIMER_H__ */
ISR_Handler rtems_isr
Return type for interrupt handler.
Definition: intr.h:52
rtems_status_code
Classic API Status.
Definition: status.h:43
