RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
score
cpu
sh
include
score
sh.h
1
10
11
* Authors: Ralf Corsepius (corsepiu@faw.uni-ulm.de) and
12
* Bernd Becker (becker@faw.uni-ulm.de)
13
14
* COPYRIGHT (c) 1997-1998, FAW Ulm, Germany
15
16
* This program is distributed in the hope that it will be useful,
17
* but WITHOUT ANY WARRANTY; without even the implied warranty of
18
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE
19
20
21
* COPYRIGHT (c) 1998-2001.
22
* On-Line Applications Research Corporation (OAR).
23
24
* The license and distribution terms for this file may be
25
* found in the file LICENSE in this distribution or at
26
* http://www.rtems.org/license/LICENSE.
27
28
29
#ifndef _RTEMS_SCORE_SH_H
30
#define _RTEMS_SCORE_SH_H
31
32
#ifdef __cplusplus
33
extern
"C"
34
#endif
35
36
37
* This file contains the information required to build
38
* RTEMS for a particular member of the "SH" family.
39
40
* It does this by setting variables to indicate which implementation
41
* dependent features are present in a particular member of the family.
42
43
44
45
* Figure out all CPU Model Feature Flags based upon compiler
46
* predefines.
47
48
49
#if defined(__SH2E__) || defined(__SH3E__)
50
51
/* FIXME: SH-DSP context not currently supported */
52
#define SH_HAS_FPU 0
53
54
#elif defined(__SH4__) || defined(__SH4_SINGLE_ONLY__)
55
56
57
* Define this if you want to use XD-registers.
58
* Then this registers will be saved/restored on context switch.
59
* ! They will not be saved/restored on interrupts!
60
61
#define SH4_USE_X_REGISTERS 0
62
63
#if defined(__LITTLE_ENDIAN__)
64
#define SH_HAS_FPU 1
65
#else
66
/* FIXME: Context_Control_fp does not support big endian */
67
#warning FPU not supported
68
69
#endif
70
71
#elif defined(__sh1__) || defined(__sh2__) || defined(__sh3__)
72
73
#else
74
#warning Cannot detect FPU support, assuming no FPU
75
76
#endif
77
78
/* this should not be here */
79
#ifndef CPU_MODEL_NAME
80
#define CPU_MODEL_NAME "SH-Multilib"
81
#endif
82
83
84
* If the following macro is set to 0 there will be no software irq stack
85
86
87
#ifndef SH_HAS_SEPARATE_STACKS
88
#define SH_HAS_SEPARATE_STACKS 1
89
#endif
90
91
92
* Define the name of the CPU family.
93
94
95
#define CPU_NAME "Hitachi SH"
96
97
#ifndef ASM
98
99
#if defined(__sh1__) || defined(__sh2__)
100
101
102
* Mask for disabling interrupts
103
104
#define SH_IRQDIS_VALUE 0xf0
105
106
#define sh_disable_interrupts( _level ) \
107
__asm__ volatile ( \
108
"stc sr,%0\n\t" \
109
"ldc %1,sr\n\t"\
110
: "=&r" (_level ) \
111
: "r" (SH_IRQDIS_VALUE) );
112
113
#define sh_enable_interrupts( _level ) \
114
__asm__ volatile( "ldc %0,sr\n\t" \
115
"nop\n\t" \
116
:: "r" (_level) );
117
118
119
* This temporarily restores the interrupt to _level before immediately
120
* disabling them again. This is used to divide long RTEMS critical
121
* sections into two or more parts. The parameter _level is not
122
* modified.
123
124
125
#define sh_flash_interrupts( _level ) \
126
__asm__ volatile( \
127
"ldc %1,sr\n\t" \
128
"nop\n\t" \
129
"ldc %0,sr\n\t" \
130
"nop\n\t" \
131
: : "r" (SH_IRQDIS_VALUE), "r" (_level) );
132
133
#else
134
135
#define SH_IRQDIS_MASK 0xf0
136
137
138
139
"stc sr,%0\n\t" \
140
"mov %0,r5\n\t" \
141
"or %1,r5\n\t" \
142
"ldc r5,sr\n\t"\
143
: "=&r" (_level ) \
144
: "r" (SH_IRQDIS_MASK) \
145
: "r5" );
146
147
148
149
"nop\n\t" \
150
:: "r" (_level) );
151
152
153
154
155
156
* modified.
157
158
159
160
__asm__ volatile( \
161
"stc sr,r5\n\t" \
162
"ldc %1,sr\n\t" \
163
"nop\n\t" \
164
"or %0,r5\n\t" \
165
"ldc r5,sr\n\t" \
166
"nop\n\t" \
167
: : "r" (SH_IRQDIS_MASK), "r" (_level) : "r5");
168
169
#endif
170
171
#define sh_get_interrupt_level( _level ) \
172
173
uint32_t _tmpsr ; \
174
175
__asm__ volatile( "stc sr, %0" : "=r" (_tmpsr) ); \
176
_level = (_tmpsr & 0xf0) >> 4 ; \
177
178
179
#define sh_set_interrupt_level( _newlevel ) \
180
181
uint32_t _tmpsr; \
182
183
__asm__ volatile ( "stc sr, %0" : "=r" (_tmpsr) ); \
184
_tmpsr = ( _tmpsr & ~0xf0 ) | ((_newlevel) << 4) ; \
185
__asm__ volatile( "ldc %0,sr" :: "r" (_tmpsr) ); \
186
187
188
189
* The following routine swaps the endian format of an unsigned int.
190
* It must be static because it is referenced indirectly.
191
192
193
static
inline
uint32_t sh_swap_u32(
194
uint32_t value
195
196
197
uint32_t swapped;
198
199
__asm__
volatile
200
"swap.b %1,%0; "
201
"swap.w %0,%0; "
202
"swap.b %0,%0"
203
"=r"
(swapped)
204
"r"
(value) );
205
206
return
( swapped );
207
208
209
static
inline
uint16_t sh_swap_u16(
210
uint16_t value
211
212
213
uint16_t swapped ;
214
215
__asm__
volatile
"swap.b %1,%0"
"=r"
(swapped) :
"r"
(value) );
216
217
return
( swapped );
218
219
220
#define CPU_swap_u32( value ) sh_swap_u32( value )
221
#define CPU_swap_u16( value ) sh_swap_u16( value )
222
223
extern
unsigned
int
sh_set_irq_priority(
224
unsigned
int
irq,
225
unsigned
int
prio );
226
227
#endif
/* !ASM */
228
229
230
* Bits on SH-4 registers.
231
* See SH-4 Programming manual for more details.
232
233
* Added by Alexandra Kossovsky <sasha@oktet.ru>
234
235
236
#if defined(__SH4__)
237
#define SH4_SR_MD 0x40000000
/* Priveleged mode */
238
#define SH4_SR_RB 0x20000000
/* General register bank specifier */
239
#define SH4_SR_BL 0x10000000
/* Exeption/interrupt masking bit */
240
#define SH4_SR_FD 0x00008000
/* FPU disable bit */
241
#define SH4_SR_M 0x00000200
/* For signed division:
242
divisor (module) is negative */
243
#define SH4_SR_Q 0x00000100
244
dividend (and quotient) is negative */
245
#define SH4_SR_IMASK 0x000000f0
/* Interrupt mask level */
246
#define SH4_SR_IMASK_S 4
247
#define SH4_SR_S 0x00000002
/* Saturation for MAC instruction:
248
if set, data in MACH/L register
249
is restricted to 48/32 bits
250
for MAC.W/L instructions */
251
#define SH4_SR_T 0x00000001
/* 1 if last condiyion was true */
252
#define SH4_SR_RESERV 0x8fff7d0d
/* Reserved bits, read/write as 0 */
253
254
/* FPSCR -- FPU Status/Control Register */
255
#define SH4_FPSCR_FR 0x00200000
/* FPU register bank specifier */
256
#define SH4_FPSCR_SZ 0x00100000
/* FMOV 64-bit transfer mode */
257
#define SH4_FPSCR_PR 0x00080000
/* Double-percision floating-point
258
operations flag */
259
/* SH4_FPSCR_SZ & SH4_FPSCR_PR != 1 */
260
#define SH4_FPSCR_DN 0x00040000
/* Treat denormalized number as zero */
261
#define SH4_FPSCR_CAUSE 0x0003f000
/* FPU exeption cause field */
262
#define SH4_FPSCR_CAUSE_S 12
263
#define SH4_FPSCR_ENABLE 0x00000f80
/* FPU exeption enable field */
264
#define SH4_FPSCR_ENABLE_s 7
265
#define SH4_FPSCR_FLAG 0x0000007d
/* FPU exeption flag field */
266
#define SH4_FPSCR_FLAG_S 2
267
#define SH4_FPSCR_RM 0x00000001
/* Rounding mode:
268
1/0 -- round to zero/nearest */
269
#define SH4_FPSCR_RESERV 0xffd00000
270
271
#endif
272
273
#ifdef __cplusplus
274
275
#endif
276
277
#endif
__asm__
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
