RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
sh
gensh4
include
sh
sh4uart.h
1
2
* Generic UART Serial driver for SH-4 processors definitions
3
4
* Copyright (C) 2000 OKTET Ltd., St.-Petersburg, Russian Fed.
5
* Author: Alexandra Kossovsky <sasha@oktet.ru>
6
7
* The license and distribution terms for this file may be
8
* found in the file LICENSE in this distribution or at
9
* http://www.rtems.org/license/LICENSE.
10
11
12
#ifndef __SH4UART_H__
13
#define __SH4UART_H__
14
15
#include <rtems/score/sh7750_regs.h>
16
17
18
19
* Define this to work from gdb stub
20
21
22
/* FIXME: This is BSP-specific */
23
#define SH4_WITH_IPL
24
25
#define SH4_SCI 1
/* Serial Communication Interface - SCI */
26
#define SH4_SCIF 2
/* Serial Communication Interface with FIFO - SCIF */
27
#define TRANSMIT_TRIGGER_VALUE(ttrg) ((ttrg) == SH7750_SCFCR2_RTRG_1 ? 1 : \
28
(ttrg) == SH7750_SCFCR2_RTRG_4 ? 4 : \
29
(ttrg) == SH7750_SCFCR2_RTRG_8 ? 8 : 14)
30
31
32
* Macros to call UART registers
33
34
#define SCRDR(n) (*(volatile uint8_t*)SH7750_SCRDR(n))
35
#define SCRDR1 SCRDR(1)
36
#define SCRDR2 SCRDR(2)
37
#define SCTDR(n) (*(volatile uint8_t*)SH7750_SCTDR(n))
38
#define SCTDR1 SCTDR(1)
39
#define SCTDR2 SCTDR(2)
40
#define SCSMR(n) ((n) == 1 ? *(volatile uint8_t*)SH7750_SCSMR1 : \
41
*(volatile uint16_t*)SH7750_SCSMR2)
42
#define SCSMR1 SCSMR(1)
43
#define SCSMR2 SCSMR(2)
44
#define SCSCR(n) ((n) == 1 ? *(volatile uint8_t*)SH7750_SCSCR1 : \
45
*(volatile uint16_t*)SH7750_SCSCR2)
46
#define SCSCR1 SCSCR(1)
47
#define SCSCR2 SCSCR(2)
48
#define SCSSR(n) ((n) == 1 ? *(volatile uint8_t*)SH7750_SCSSR1 : \
49
*(volatile uint16_t*)SH7750_SCSSR2)
50
#define SCSSR1 SCSSR(1)
51
#define SCSSR2 SCSSR(2)
52
#define SCSPTR1 (*(volatile uint8_t*)SH7750_SCSPTR1)
53
#define SCSPTR2 (*(volatile uint16_t*)SH7750_SCSPTR2)
54
#define SCBRR(n) (*(volatile uint8_t*)SH7750_SCBRR(n))
55
#define SCBRR1 SCBRR(1)
56
#define SCBRR2 SCBRR(2)
57
#define SCFCR2 (*(volatile uint16_t*)SH7750_SCFCR2)
58
#define SCFDR2 (*(volatile uint16_t*)SH7750_SCFDR2)
59
#define SCLSR2 (*(volatile uint16_t*)SH7750_SCLSR2)
60
61
#define IPRB (*(volatile uint16_t*)SH7750_IPRB)
62
#define IPRC (*(volatile uint16_t*)SH7750_IPRC)
63
64
65
* The following structure is a descriptor of single UART channel.
66
* It contains the initialization information about channel and
67
* current operating values
68
69
typedef
struct
sh4uart
70
uint8_t chn;
/* UART channel number */
71
uint8_t int_driven;
/* UART interrupt vector number, or
72
0 if polled I/O */
73
void
*tty;
/* termios channel descriptor */
74
75
volatile
const
char
*tx_buf;
/* Transmit buffer from termios */
76
volatile
uint32_t tx_buf_len;
/* Transmit buffer length */
77
volatile
uint32_t tx_ptr;
/* Index of next char to transmit*/
78
79
rtems_isr_entry old_handler_transmit;
/* Saved interrupt handlers */
80
rtems_isr_entry old_handler_receive;
81
82
tcflag_t c_iflag;
/* termios input mode flags */
83
bool
parerr_mark_flag;
/* Parity error processing state */
84
sh4uart
85
86
87
* Functions from sh4uart.c
88
89
90
/* sh4uart_init --
91
* This function verifies the input parameters and perform initialization
92
* of the Motorola Coldfire on-chip UART descriptor structure.
93
94
95
rtems_status_code
96
sh4uart_init(
sh4uart
*uart,
void
*tty,
int
chn,
int
int_driven);
97
98
/* sh4uart_reset --
99
* This function perform the hardware initialization of Motorola
100
* Coldfire processor on-chip UART controller using parameters
101
* filled by the sh4uart_init function.
102
103
rtems_status_code
104
sh4uart_reset(
sh4uart
*uart);
105
106
/* sh4uart_disable --
107
* This function disable the operations on Motorola Coldfire UART
108
* controller
109
110
rtems_status_code
111
sh4uart_disable(
sh4uart
*uart,
int
disable_port);
112
113
/* sh4uart_set_attributes --
114
* This function parse the termios attributes structure and perform
115
* the appropriate settings in hardware.
116
117
rtems_status_code
118
sh4uart_set_attributes(
sh4uart
*mcf,
const
struct
termios *t);
119
120
/* sh4uart_poll_read --
121
* This function tried to read character from MCF UART and perform
122
* error handling.
123
124
int
125
sh4uart_poll_read(
sh4uart
*uart);
126
127
#ifdef SH4_WITH_IPL
128
/* ipl_console_poll_read --
129
* This function tried to read character from MCF UART over SH-IPL.
130
131
int
132
ipl_console_poll_read(
int
minor);
133
134
/* sh4uart_interrupt_write --
135
* This function initiate transmitting of the buffer in interrupt mode.
136
137
rtems_status_code
138
sh4uart_interrupt_write(
sh4uart
*uart,
const
char
*buf,
int
len);
139
140
/* sh4uart_poll_write --
141
* This function transmit buffer byte-by-byte in polling mode.
142
143
int
144
sh4uart_poll_write(
sh4uart
*uart,
const
char
*buf,
int
len);
145
146
/* ipl_console_poll_write --
147
* This function transmit buffer byte-by-byte in polling mode over SH-IPL.
148
149
int
150
ipl_console_poll_write(
int
minor,
const
char
*buf,
int
len);
151
152
153
* ipl_finish --
154
* Says gdb that program finished to get out from it.
155
156
extern
void
ipl_finish(
void
157
#endif
158
159
/* sh4uart_stop_remote_tx --
160
* This function stop data flow from remote device.
161
162
rtems_status_code
163
sh4uart_stop_remote_tx(
sh4uart
*uart);
164
165
/* sh4uart_start_remote_tx --
166
* This function resume data flow from remote device.
167
168
rtems_status_code
169
sh4uart_start_remote_tx(
sh4uart
*uart);
170
171
/* Descriptor structures for two on-chip UART channels */
172
extern
sh4uart
sh4_uarts[2];
173
174
#endif
rtems_status_code
rtems_status_code
Classic API Status.
Definition:
status.h:43
sh4uart
Definition:
sh4uart.h:69
