RTEMS  5.1
Macros | Variables
sed1356_16bit.h File Reference
SED1356 LCD/CRT Controllers for KIT637_V6 (CSB637) 16-Bit access mode. More...
#include "bits.h"
#define SED1356_REG_REV_and_MISC   SED_REG16(0x00)
#define SED1356_REG_GPIO_CFG   SED_REG16(0x04)
#define SED1356_REG_GPIO_CTL   SED_REG16(0x08)
#define SED1356_REG_MD_CFG_RD_LO_and_HI   SED_REG16(0x0c)
#define SED1356_REG_MCLK_CFG   SED_REG16(0x10)
#define SED1356_REG_LCD_PCLK_CFG   SED_REG16(0x14)
#define SED1356_REG_CRT_PCLK_CFG   SED_REG16(0x18)
#define SED1356_REG_MEDIA_PCLK_CFG   SED_REG16(0x1c)
#define SED1356_REG_WAIT_STATE   SED_REG16(0x1e)
#define SED1356_REG_MEM_CFG_and_REF_RATE   SED_REG16(0x20)
#define SED1356_REG_MEM_TMG0_and_1   SED_REG16(0x2a)
#define SED1356_REG_PANEL_TYPE_and_MOD_RATE   SED_REG16(0x30)
#define SED1356_REG_LCD_HOR_DISP   SED_REG16(0x32)
#define SED1356_REG_LCD_HOR_NONDISP_and_START   SED_REG16(0x34)
#define SED1356_REG_LCD_HOR_PULSE   SED_REG16(0x36)
#define SED1356_REG_LCD_VER_DISP_HT_LO_and_HI   SED_REG16(0x38)
#define SED1356_REG_LCD_VER_NONDISP_and_START   SED_REG16(0x3a)
#define SED1356_REG_LCD_VER_PULSE   SED_REG16(0x3c)
#define SED1356_REG_LCD_DISP_MODE_and_MISC   SED_REG16(0x40)
#define SED1356_REG_LCD_DISP_START_LO_and_MID   SED_REG16(0x42)
#define SED1356_REG_LCD_DISP_START_HI   SED_REG16(0x44)
#define SED1356_REG_LCD_ADD_OFFSET_LO_and_HI   SED_REG16(0x46)
#define SED1356_REG_LCD_PIXEL_PAN   SED_REG16(0x48)
#define SED1356_REG_LCD_FIFO_THRESH_LO_and_HI   SED_REG16(0x4a)
#define SED1356_REG_CRT_HOR_DISP   SED_REG16(0x50)
#define SED1356_REG_CRT_HOR_NONDISP_and_START   SED_REG16(0x52)
#define SED1356_REG_CRT_HOR_PULSE   SED_REG16(0x54)
#define SED1356_REG_CRT_VER_DISP_HT_LO_and_HI   SED_REG16(0x56)
#define SED1356_REG_CRT_VER_NONDISP_and_START   SED_REG16(0x58)
#define SED1356_REG_CRT_VER_PULSE_and_OUT_CTL   SED_REG16(0x5a)
#define SED1356_REG_CRT_DISP_MODE   SED_REG16(0x60)
#define SED1356_REG_CRT_DISP_START_LO_and_MID   SED_REG16(0x62)
#define SED1356_REG_CRT_DISP_START_HI   SED_REG16(0x64)
#define SED1356_REG_CRT_ADD_OFFSET_LO_and_HI   SED_REG16(0x66)
#define SED1356_REG_CRT_PIXEL_PAN   SED_REG16(0x68)
#define SED1356_REG_CRT_FIFO_THRESH_LO_and_HI   SED_REG16(0x6a)
#define SED1356_REG_LCD_CURSOR_CTL_and_START_ADD   SED_REG16(0x70)
#define SED1356_REG_LCD_CURSOR_X_POS_LO_and_HI   SED_REG16(0x72)
#define SED1356_REG_LCD_CURSOR_Y_POS_LO_and_HI   SED_REG16(0x74)
#define SED1356_REG_LCD_CURSOR_BLUE_and_GREEN_CLR_0   SED_REG16(0x76)
#define SED1356_REG_LCD_CURSOR_RED_CLR_0   SED_REG16(0x78)
#define SED1356_REG_LCD_CURSOR_BLUE_and_GREEN_CLR_1   SED_REG16(0x7a)
#define SED1356_REG_LCD_CURSOR_RED_CLR_1   SED_REG16(0x7c)
#define SED1356_REG_LCD_CURSOR_FIFO_THRESH   SED_REG16(0x7e)
#define SED1356_REG_CRT_CURSOR_CTL_and_START_ADD   SED_REG16(0x80)
#define SED1356_REG_CRT_CURSOR_X_POS_LO_and_HI   SED_REG16(0x82)
#define SED1356_REG_CRT_CURSOR_Y_POS_LO_and_HI   SED_REG16(0x84)
#define SED1356_REG_CRT_CURSOR_BLUE_and_GREEN_CLR_0   SED_REG16(0x86)
#define SED1356_REG_CRT_CURSOR_RED_CLR_0   SED_REG16(0x88)
#define SED1356_REG_CRT_CURSOR_BLUE_and_GREEN_CLR_1   SED_REG16(0x8a)
#define SED1356_REG_CRT_CURSOR_RED_CLR_1   SED_REG16(0x8c)
#define SED1356_REG_CRT_CURSOR_FIFO_THRESH   SED_REG16(0x8e)
#define SED1356_REG_BLT_CTL_0_and_1   SED_REG16(0x100)
#define SED1356_REG_BLT_ROP_CODE_and_BLT_OP   SED_REG16(0x102)
#define SED1356_REG_BLT_SRC_START_LO_and_MID   SED_REG16(0x104)
#define SED1356_REG_BLT_SRC_START_HI   SED_REG16(0x106)
#define SED1356_REG_BLT_DEST_START_LO_and_MID   SED_REG16(0x108)
#define SED1356_REG_BLT_DEST_START_HI   SED_REG16(0x10a)
#define SED1356_REG_BLT_ADD_OFFSET_LO_and_HI   SED_REG16(0x10c)
#define SED1356_REG_BLT_WID_LO_and_HI   SED_REG16(0x110)
#define SED1356_REG_BLT_HGT_LO_and_HI   SED_REG16(0x112)
#define SED1356_REG_BLT_BG_CLR_LO_and_HI   SED_REG16(0x114)
#define SED1356_REG_BLT_FG_CLR_LO_and_HI   SED_REG16(0x118)
#define SED1356_REG_LUT_MODE   SED_REG16(0x1e0)
#define SED1356_REG_LUT_ADD   SED_REG16(0x1e2)
#define SED1356_REG_LUT_DATA   SED_REG16(0x1e4)
#define SED1356_REG_PWR_CFG_and_STAT   SED_REG16(0x1f0)
#define SED1356_REG_WATCHDOG_CTL   SED_REG16(0x1f4)
#define SED1356_REG_DISP_MODE   SED_REG16(0x1fc)
#define SED1356_REV_ID_MASK   0xfc /* ID bits - masks off the rev bits */
#define SED1356_REV_ID_1356   BIT4
#define SED1356_REV_ID_1355   BIT3
#define SED1356_MISC_HOST_DIS   BIT7 << 8 /* 0 = enable host access, 1 = disable */
#define SED1356_GPIO_GPIO3   BIT3 /* 0 = input, 1 = output, if configured as GPIO */
#define SED1356_GPIO_GPIO2   BIT2
#define SED1356_GPIO_GPIO1   BIT1
#define SED1356_MCLK_DIV2   BIT4
#define SED1356_MCLK_SRC_BCLK   BIT0
#define SED1356_MCLK_SRC_CLKI   0x00
#define SED1356_PCLK_X2   BIT7 /* SED1356_REG_CRT_PCLK_CFG only */
#define SED1356_PCLK_DIV1   0x00 << 4
#define SED1356_PCLK_DIV2   0x01 << 4
#define SED1356_PCLK_DIV3   0x02 << 4
#define SED1356_PCLK_DIV4   0x03 << 4
#define SED1356_PCLK_SRC_CLKI   0x00
#define SED1356_PCLK_SRC_BCLK   0x01
#define SED1356_PCLK_SRC_CLKI2   0x02
#define SED1356_PCLK_SRC_MCLK   0x03
#define SED1356_MEM_CFG_2CAS_EDO   0x00
#define SED1356_MEM_CFG_2CAS_FPM   0x01
#define SED1356_MEM_CFG_2WE_EDO   0x02
#define SED1356_MEM_CFG_2WE_FPM   0x03
#define SED1356_MEM_CFG_MASK   0x03
#define SED1356_REF_TYPE_CBR   0x00 << 6 << 8
#define SED1356_REF_TYPE_SELF   0x01 << 6 << 8
#define SED1356_REF_TYPE_NONE   0x02 << 6 << 8
#define SED1356_REF_TYPE_MASK   0x03 << 6 << 8
#define SED1356_REF_RATE_64   0x00 << 0 << 8 /* MCLK / 64 */
#define SED1356_REF_RATE_128   0x01 << 0 << 8 /* MCLK / 128 */
#define SED1356_REF_RATE_256   0x02 << 0 << 8 /* MCLK / 256 */
#define SED1356_REF_RATE_512   0x03 << 0 << 8 /* MCLK / 512 */
#define SED1356_REF_RATE_1024   0x04 << 0 << 8 /* MCLK / 1024 */
#define SED1356_REF_RATE_2048   0x05 << 0 << 8 /* MCLK / 2048 */
#define SED1356_REF_RATE_4096   0x06 << 0 << 8 /* MCLK / 4096 */
#define SED1356_REF_RATE_8192   0x07 << 0 << 8 /* MCLK / 8192 */
#define SED1356_REF_RATE_MASK   0x07 << 0 << 8 /* MCLK / 8192 */
#define SED1356_MEM_TMG0_EDO50_MCLK40   0x01
#define SED1356_MEM_TMG0_EDO50_MCLK33   0x01
#define SED1356_MEM_TMG0_EDO60_MCLK33   0x01
#define SED1356_MEM_TMG0_EDO50_MCLK30   0x12
#define SED1356_MEM_TMG0_EDO60_MCLK30   0x01
#define SED1356_MEM_TMG0_EDO70_MCLK30   0x00
#define SED1356_MEM_TMG0_EDO50_MCLK25   0x12
#define SED1356_MEM_TMG0_EDO60_MCLK25   0x12
#define SED1356_MEM_TMG0_EDO70_MCLK25   0x01
#define SED1356_MEM_TMG0_EDO80_MCLK25   0x00
#define SED1356_MEM_TMG0_EDO50_MCLK20   0x12
#define SED1356_MEM_TMG0_EDO60_MCLK20   0x12
#define SED1356_MEM_TMG0_EDO70_MCLK20   0x12
#define SED1356_MEM_TMG0_EDO80_MCLK20   0x01
#define SED1356_MEM_TMG0_FPM50_MCLK25   0x12
#define SED1356_MEM_TMG0_FPM60_MCLK25   0x01
#define SED1356_MEM_TMG0_FPM50_MCLK20   0x12
#define SED1356_MEM_TMG0_FPM60_MCLK20   0x12
#define SED1356_MEM_TMG0_FPM70_MCLK20   0x11
#define SED1356_MEM_TMG0_FPM80_MCLK20   0x01
#define SED1356_MEM_TMG1_EDO50_MCLK40   0x01 << 8
#define SED1356_MEM_TMG1_EDO50_MCLK33   0x01 << 8
#define SED1356_MEM_TMG1_EDO60_MCLK33   0x01 << 8
#define SED1356_MEM_TMG1_EDO50_MCLK30   0x02 << 8
#define SED1356_MEM_TMG1_EDO60_MCLK30   0x01 << 8
#define SED1356_MEM_TMG1_EDO70_MCLK30   0x00 << 8
#define SED1356_MEM_TMG1_EDO50_MCLK25   0x02 << 8
#define SED1356_MEM_TMG1_EDO60_MCLK25   0x02 << 8
#define SED1356_MEM_TMG1_EDO70_MCLK25   0x01 << 8
#define SED1356_MEM_TMG1_EDO80_MCLK25   0x01 << 8
#define SED1356_MEM_TMG1_EDO50_MCLK20   0x02 << 8
#define SED1356_MEM_TMG1_EDO60_MCLK20   0x02 << 8
#define SED1356_MEM_TMG1_EDO70_MCLK20   0x02 << 8
#define SED1356_MEM_TMG1_EDO80_MCLK20   0x01 << 8
#define SED1356_MEM_TMG1_FPM50_MCLK25   0x02 << 8
#define SED1356_MEM_TMG1_FPM60_MCLK25   0x01 << 8
#define SED1356_MEM_TMG1_FPM50_MCLK20   0x02 << 8
#define SED1356_MEM_TMG1_FPM60_MCLK20   0x02 << 8
#define SED1356_MEM_TMG1_FPM70_MCLK20   0x02 << 8
#define SED1356_MEM_TMG1_FPM80_MCLK20   0x01 << 8
#define SED1356_PANEL_TYPE_EL   BIT7
#define SED1356_PANEL_TYPE_4_9   (0x00 << 4) /* Passive 4-Bit, TFT 9-Bit */
#define SED1356_PANEL_TYPE_8_12   (0x01 << 4) /* Passive 8-Bit, TFT 12-Bit */
#define SED1356_PANEL_TYPE_16   (0x02 << 4) /* Passive 16-Bit, or TFT 18-Bit */
#define SED1356_PANEL_TYPE_MASK   (0x03 << 4)
#define SED1356_PANEL_TYPE_FMT   BIT3 /* 0 = Passive Format 1, 1 = Passive Format 2 */
#define SED1356_PANEL_TYPE_CLR   BIT2 /* 0 = Passive Mono, 1 = Passive Color */
#define SED1356_PANEL_TYPE_DUAL   BIT1 /* 0 = Passive Single, 1 = Passive Dual */
#define SED1356_PANEL_TYPE_TFT   BIT0 /* 0 = Passive, 1 = TFT (DUAL, FMT & CLR are don't cares) */
#define SED1356_PULSE_POL_HIGH   BIT7 /* 0 = CRT/TFT Pulse is Low, Passive is High, 1 = CRT/TFT Pulse is High, Passive is Low */
#define SED1356_PULSE_POL_LOW   0x00 /* 0 = CRT/TFT Pulse is Low, Passive is High, 1 = CRT/TFT Pulse is High, Passive is Low */
#define SED1356_PULSE_WID(_x_)   (_x_ & 0x0f) /* Pulse Width in Pixels */
#define SED1356_LCD_DISP_BLANK   BIT7 /* 1 = Blank LCD Display */
#define SED1356_LCD_DISP_SWIV_NORM   (0x00 << 4) /* Used with SED1356_REG_DISP_MODE Bit 6 */
#define SED1356_LCD_DISP_SWIV_90   (0x00 << 4)
#define SED1356_LCD_DISP_SWIV_180   (0x01 << 4)
#define SED1356_LCD_DISP_SWIV_270   (0x01 << 4)
#define SED1356_LCD_DISP_SWIV_MASK   (0x01 << 4)
#define SED1356_LCD_DISP_16BPP   0x05 /* Bit Per Pixel Selection */
#define SED1356_LCD_DISP_15BPP   0x04
#define SED1356_LCD_DISP_8BPP   0x03
#define SED1356_LCD_DISP_4BPP   0x02
#define SED1356_LCD_DISP_BPP_MASK   0x07
#define SED1356_LCD_MISC_DITH   BIT1 << 8 /* 1 = Dither Disable, Passive Panel Only */
#define SED1356_LCD_MISC_DUAL   BIT0 << 8 /* 1 = Dual Panel Disable, Passive Panel Only */
#define SED1356_CRT_OUT_CHROM   BIT5 << 8 /* 1 = TV Chrominance Filter Enable */
#define SED1356_CRT_OUT_LUM   BIT4 << 8 /* 1 = TV Luminance Filter Enable */
#define SED1356_CRT_OUT_DAC_LVL   BIT3 << 8 /* 1 = 4.6ma IREF, 0 = 9.2 IREF */
#define SED1356_CRT_OUT_SVIDEO   BIT1 << 8 /* 1 = S-Video Output, 0 = Composite Video Output */
#define SED1356_CRT_OUT_PAL   BIT0 << 8 /* 1 = PAL Format Output, 0 = NTSC Format Output */
#define SED1356_CRT_DISP_BLANK   BIT7 /* 1 = Blank CRT Display */
#define SED1356_CRT_DISP_16BPP   0x05 /* Bit Per Pixel Selection */
#define SED1356_CRT_DISP_15BPP   0x04
#define SED1356_CRT_DISP_8BPP   0x03
#define SED1356_CRT_DISP_4BPP   0x02
#define SED1356_CRT_DISP_BPP_MASK   0x07
#define SED1356_DISP_SWIV_NORM   (0x00 << 6) /* Used with SED1356_LCD_DISP_MODE Bit 4 */
#define SED1356_DISP_SWIV_90   (0x01 << 6)
#define SED1356_DISP_SWIV_180   (0x00 << 6)
#define SED1356_DISP_SWIV_270   (0x01 << 6)
#define SED1356_DISP_MODE_OFF   0x00 /* All Displays Off */
#define SED1356_DISP_MODE_LCD   0x01 /* LCD Only */
#define SED1356_DISP_MODE_CRT   0x02 /* CRT Only */
#define SED1356_DISP_MODE_LCD_CRT   0x03 /* Simultaneous LCD and CRT */
#define SED1356_DISP_MODE_TV   0x04 /* TV Only, Flicker Filter Off */
#define SED1356_DISP_MODE_TV_LCD   0x05 /* Simultaneous LCD and TV, Flicker Filter Off */
#define SED1356_DISP_MODE_TV_FLICK   0x06 /* TV Only, Flicker Filter On */
#define SED1356_DISP_MODE_TV_LCD_FLICK   0x07 /* Simultaneous LCD and TV, Flicker Filter On */
#define SED1356_PWR_PCLK   BIT1 /* SED1356_REG_PWR_STAT only */
#define SED1356_PWR_MCLK   BIT0
#define SED1356_VER_NONDISP   BIT7 /* vertical retrace status 1 = in retrace */
#define BYTES_PER_PIXEL   2
#define RED_SUBPIXEL(n)   ((n & 0x1f) << 11)
#define GREEN_SUBPIXEL(n)   ((n & 0x1f) << 5)
#define BLUE_SUBPIXEL(n)   ((n & 0x1f) << 0)
#define BLUE   (0x14 << 0)
#define GREEN   (0x14 << 6)
#define RED   (0x14 << 11)
#define HALF_BLUE   (0x0a << 0)
#define HALF_GREEN   (0x0a << 6)
#define HALF_RED   (0x0a << 11)
#define BRT_BLUE   (0x1e << 0)
#define BRT_GREEN   (0x1e << 6)
#define BRT_RED   (0x1e << 11)
#define LU_BLACK   0
#define LU_BLUE   (BLUE)
#define LU_GREEN   (GREEN)
#define LU_CYAN   (GREEN | BLUE)
#define LU_RED   (RED)
#define LU_VIOLET   (RED | BLUE)
#define LU_YELLOW   (RED | GREEN)
#define LU_WHITE   (RED | GREEN | BLUE)
#define LU_GREY   (HALF_RED | HALF_GREEN | HALF_BLUE)
#define LU_BRT_BLUE   (HALF_RED | HALF_GREEN | BRT_BLUE)
#define LU_BRT_GREEN   (HALF_RED | BRT_GREEN | HALF_BLUE)
#define LU_BRT_CYAN   (HALF_RED | BRT_GREEN | BRT_BLUE)
#define LU_BRT_RED   (BRT_RED | HALF_GREEN | HALF_BLUE)
#define LU_BRT_VIOLET   (BRT_RED | HALF_GREEN | BRT_BLUE)
#define LU_BRT_YELLOW   (BRT_RED | BRT_GREEN | HALF_BLUE)
#define LU_BRT_WHITE   (BRT_RED | BRT_GREEN | BRT_BLUE)
#define SED_BG_DEF   1
#define SED_FG_DEF   14
#define TOP   0
#define BOTTOM   (PIXELS_PER_COL-1)
#define LEFT   0
#define RIGHT   (PIXELS_PER_ROW-1)
#define CENTER_X   (PIXELS_PER_ROW/2)
#define CENTER_Y   (PIXELS_PER_COL/2)
#define SED_HOR_PULSE_WIDTH_CRT   0x07 /* Horizontal Pulse Width Register = (Thp/8) - 1 */
#define SED_HOR_PULSE_START_CRT   0x02 /* Horizontal Pulse Start Position Register = ((Thfp + 2)/8) - 1 */
#define SED_HOR_NONDISP_CRT   0x17 /* Horizontal Non-Display Period Register = ((Thp + Thfp + Thbp)/8) - 1 */
#define SED_VER_PULSE_WIDTH_CRT   0x02
#define SED_VER_PULSE_START_CRT   0x08
#define SED_VER_NONDISP_CRT   0x27
long PIXELS_PER_ROW
long PIXELS_PER_COL
long COLS_PER_SCREEN
long ROWS_PER_SCREEN
const ushort vga_lookup []
long SED_HOR_PULSE_WIDTH_LCD
long SED_HOR_PULSE_START_LCD
long SED_HOR_NONDISP_LCD
long SED_VER_PULSE_WIDTH_LCD
long SED_VER_PULSE_START_LCD
long SED_VER_NONDISP_LCD
Variable Documentation
◆ vga_lookup
const ushort vga_lookup[]
Initial value:
LU_BLACK,
LU_BLUE,
LU_GREEN,
LU_CYAN,
LU_RED,
LU_VIOLET,
LU_YELLOW,
LU_WHITE,
LU_GREY,
LU_BRT_BLUE,
LU_BRT_GREEN,
LU_BRT_CYAN,
LU_BRT_RED,
LU_BRT_VIOLET,
LU_BRT_YELLOW,
LU_BRT_WHITE
