RTEMS  5.1
schedulersimple.h
1
12 /*
13  * Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
14  *
15  * The license and distribution terms for this file may be
16  * found in the file LICENSE in this distribution or at
17  * http://www.rtems.org/license/LICENSE.
18  */
19
20 #ifndef _RTEMS_SCORE_SCHEDULERSIMPLE_H
21 #define _RTEMS_SCORE_SCHEDULERSIMPLE_H
22
23 #include <rtems/score/scheduler.h>
25
26 #ifdef __cplusplus
27 extern "C" {
28 #endif
29
40 #define SCHEDULER_SIMPLE_MAXIMUM_PRIORITY 255
41
45 #define SCHEDULER_SIMPLE_ENTRY_POINTS \
46  { \
47  _Scheduler_simple_Initialize, /* initialize entry point */ \
48  _Scheduler_simple_Schedule, /* schedule entry point */ \
49  _Scheduler_simple_Yield, /* yield entry point */ \
50  _Scheduler_simple_Block, /* block entry point */ \
51  _Scheduler_simple_Unblock, /* unblock entry point */ \
52  _Scheduler_simple_Update_priority, /* update priority entry point */ \
53  _Scheduler_default_Map_priority, /* map priority entry point */ \
54  _Scheduler_default_Unmap_priority, /* unmap priority entry point */ \
55  SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP \
56  _Scheduler_default_Node_initialize, /* node initialize entry point */ \
57  _Scheduler_default_Node_destroy, /* node destroy entry point */ \
58  _Scheduler_default_Release_job, /* new period of task */ \
59  _Scheduler_default_Cancel_job, /* cancel period of task */ \
60  _Scheduler_default_Tick, /* tick entry point */ \
61  _Scheduler_default_Start_idle /* start idle entry point */ \
62  SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
63  }
64
68 typedef struct {
73
79
87 void _Scheduler_simple_Initialize( const Scheduler_Control *scheduler );
88
100  const Scheduler_Control *scheduler,
101  Thread_Control *the_thread
102 );
103
112  const Scheduler_Control *scheduler,
113  Thread_Control *the_thread,
114  Scheduler_Node *node
115 );
116
125  const Scheduler_Control *scheduler,
126  Thread_Control *the_thread,
127  Scheduler_Node *node
128 );
129
138  const Scheduler_Control *scheduler,
139  Thread_Control *the_thread,
140  Scheduler_Node *node
141 );
142
151  const Scheduler_Control *scheduler,
152  Thread_Control *the_thread,
153  Scheduler_Node *node
154 );
155
158 #ifdef __cplusplus
159 }
160 #endif
161
162 #endif
163 /* end of include file */
Scheduler_Context Base
Basic scheduler context.
Definition: schedulersimple.h:72
Scheduler context.
Definition: scheduler.h:252
Chain_Control Ready
One ready queue for all ready threads.
Definition: schedulersimple.h:77
Definition: chain.h:86
Thread Manipulation with the Priority-Based Scheduler.
Simple scheduler context.
Definition: schedulersimple.h:68
void _Scheduler_simple_Schedule(const Scheduler_Control *scheduler, Thread_Control *the_thread)
Schedules threads.
Definition: schedulersimpleschedule.c:24
Definition: thread.h:732
void _Scheduler_simple_Block(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Blocks the thread.
Definition: schedulersimpleblock.c:24
void _Scheduler_simple_Yield(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Performs the yield of a thread.
Definition: schedulersimpleyield.c:24
Scheduler control.
Definition: scheduler.h:269
Scheduler node for per-thread data.
Definition: schedulernode.h:79
void _Scheduler_simple_Unblock(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Unblocks the thread.
Definition: schedulersimpleunblock.c:25
Constants and Structures Associated with the Scheduler.
void _Scheduler_simple_Initialize(const Scheduler_Control *scheduler)
Initializes simple scheduler.
Definition: schedulersimple.c:25
void _Scheduler_simple_Update_priority(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Updates the priority of the node.
Definition: schedulersimplechangepriority.c:24
