RTEMS  5.1
component_matrix.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAMV71_MATRIX_COMPONENT_
31 #define _SAMV71_MATRIX_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __IO uint32_t MATRIX_PRAS;
43  __IO uint32_t MATRIX_PRBS;
44 } MatrixPr;
46 #define MATRIXPR_NUMBER 9
47 typedef struct {
48  __IO uint32_t MATRIX_MCFG[12];
49  __I uint32_t Reserved1[4];
50  __IO uint32_t MATRIX_SCFG[9];
51  __I uint32_t Reserved2[7];
52  MatrixPr MATRIX_PR[MATRIXPR_NUMBER];
53  __I uint32_t Reserved3[14];
54  __IO uint32_t MATRIX_MRCR;
55  __I uint32_t Reserved4[3];
56  __IO uint32_t CCFG_CAN0;
57  __IO uint32_t CCFG_SYSIO;
58  __I uint32_t Reserved5[3];
59  __IO uint32_t CCFG_SMCNFCS;
60  __I uint32_t Reserved6[47];
61  __IO uint32_t MATRIX_WPMR;
62  __I uint32_t MATRIX_WPSR;
63  __I uint32_t Reserved7[4];
64  __I uint32_t MATRIX_VERSION;
65 } Matrix;
66 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
67 /* -------- MATRIX_MCFG[12] : (MATRIX Offset: 0x0000) Master Configuration Register -------- */
68 #define MATRIX_MCFG_ULBT_Pos 0
69 #define MATRIX_MCFG_ULBT_Msk (0x7u << MATRIX_MCFG_ULBT_Pos)
70 #define MATRIX_MCFG_ULBT(value) ((MATRIX_MCFG_ULBT_Msk & ((value) << MATRIX_MCFG_ULBT_Pos)))
71 #define MATRIX_MCFG_ULBT_UNLTD_LENGTH (0x0u << 0)
72 #define MATRIX_MCFG_ULBT_SINGLE_ACCESS (0x1u << 0)
73 #define MATRIX_MCFG_ULBT_4BEAT_BURST (0x2u << 0)
74 #define MATRIX_MCFG_ULBT_8BEAT_BURST (0x3u << 0)
75 #define MATRIX_MCFG_ULBT_16BEAT_BURST (0x4u << 0)
76 #define MATRIX_MCFG_ULBT_32BEAT_BURST (0x5u << 0)
77 #define MATRIX_MCFG_ULBT_64BEAT_BURST (0x6u << 0)
78 #define MATRIX_MCFG_ULBT_128BEAT_BURST (0x7u << 0)
79 /* -------- MATRIX_SCFG[9] : (MATRIX Offset: 0x0040) Slave Configuration Register -------- */
80 #define MATRIX_SCFG_SLOT_CYCLE_Pos 0
81 #define MATRIX_SCFG_SLOT_CYCLE_Msk (0x1ffu << MATRIX_SCFG_SLOT_CYCLE_Pos)
82 #define MATRIX_SCFG_SLOT_CYCLE(value) ((MATRIX_SCFG_SLOT_CYCLE_Msk & ((value) << MATRIX_SCFG_SLOT_CYCLE_Pos)))
83 #define MATRIX_SCFG_DEFMSTR_TYPE_Pos 16
84 #define MATRIX_SCFG_DEFMSTR_TYPE_Msk (0x3u << MATRIX_SCFG_DEFMSTR_TYPE_Pos)
85 #define MATRIX_SCFG_DEFMSTR_TYPE(value) ((MATRIX_SCFG_DEFMSTR_TYPE_Msk & ((value) << MATRIX_SCFG_DEFMSTR_TYPE_Pos)))
86 #define MATRIX_SCFG_DEFMSTR_TYPE_NONE (0x0u << 16)
87 #define MATRIX_SCFG_DEFMSTR_TYPE_LAST (0x1u << 16)
88 #define MATRIX_SCFG_DEFMSTR_TYPE_FIXED (0x2u << 16)
89 #define MATRIX_SCFG_FIXED_DEFMSTR_Pos 18
90 #define MATRIX_SCFG_FIXED_DEFMSTR_Msk (0xfu << MATRIX_SCFG_FIXED_DEFMSTR_Pos)
91 #define MATRIX_SCFG_FIXED_DEFMSTR(value) ((MATRIX_SCFG_FIXED_DEFMSTR_Msk & ((value) << MATRIX_SCFG_FIXED_DEFMSTR_Pos)))
92 /* -------- MATRIX_PRAS : (MATRIX Offset: N/A) Priority Register A for Slave 0 -------- */
93 #define MATRIX_PRAS_M0PR_Pos 0
94 #define MATRIX_PRAS_M0PR_Msk (0x3u << MATRIX_PRAS_M0PR_Pos)
95 #define MATRIX_PRAS_M0PR(value) ((MATRIX_PRAS_M0PR_Msk & ((value) << MATRIX_PRAS_M0PR_Pos)))
96 #define MATRIX_PRAS_M1PR_Pos 4
97 #define MATRIX_PRAS_M1PR_Msk (0x3u << MATRIX_PRAS_M1PR_Pos)
98 #define MATRIX_PRAS_M1PR(value) ((MATRIX_PRAS_M1PR_Msk & ((value) << MATRIX_PRAS_M1PR_Pos)))
99 #define MATRIX_PRAS_M2PR_Pos 8
100 #define MATRIX_PRAS_M2PR_Msk (0x3u << MATRIX_PRAS_M2PR_Pos)
101 #define MATRIX_PRAS_M2PR(value) ((MATRIX_PRAS_M2PR_Msk & ((value) << MATRIX_PRAS_M2PR_Pos)))
102 #define MATRIX_PRAS_M3PR_Pos 12
103 #define MATRIX_PRAS_M3PR_Msk (0x3u << MATRIX_PRAS_M3PR_Pos)
104 #define MATRIX_PRAS_M3PR(value) ((MATRIX_PRAS_M3PR_Msk & ((value) << MATRIX_PRAS_M3PR_Pos)))
105 #define MATRIX_PRAS_M4PR_Pos 16
106 #define MATRIX_PRAS_M4PR_Msk (0x3u << MATRIX_PRAS_M4PR_Pos)
107 #define MATRIX_PRAS_M4PR(value) ((MATRIX_PRAS_M4PR_Msk & ((value) << MATRIX_PRAS_M4PR_Pos)))
108 #define MATRIX_PRAS_M5PR_Pos 20
109 #define MATRIX_PRAS_M5PR_Msk (0x3u << MATRIX_PRAS_M5PR_Pos)
110 #define MATRIX_PRAS_M5PR(value) ((MATRIX_PRAS_M5PR_Msk & ((value) << MATRIX_PRAS_M5PR_Pos)))
111 #define MATRIX_PRAS_M6PR_Pos 24
112 #define MATRIX_PRAS_M6PR_Msk (0x3u << MATRIX_PRAS_M6PR_Pos)
113 #define MATRIX_PRAS_M6PR(value) ((MATRIX_PRAS_M6PR_Msk & ((value) << MATRIX_PRAS_M6PR_Pos)))
114 #define MATRIX_PRAS_M7PR_Pos 28
115 #define MATRIX_PRAS_M7PR_Msk (0x3u << MATRIX_PRAS_M7PR_Pos)
116 #define MATRIX_PRAS_M7PR(value) ((MATRIX_PRAS_M7PR_Msk & ((value) << MATRIX_PRAS_M7PR_Pos)))
117 /* -------- MATRIX_PRBS : (MATRIX Offset: N/A) Priority Register B for Slave 0 -------- */
118 #define MATRIX_PRBS_M8PR_Pos 0
119 #define MATRIX_PRBS_M8PR_Msk (0x3u << MATRIX_PRBS_M8PR_Pos)
120 #define MATRIX_PRBS_M8PR(value) ((MATRIX_PRBS_M8PR_Msk & ((value) << MATRIX_PRBS_M8PR_Pos)))
121 #define MATRIX_PRBS_M9PR_Pos 4
122 #define MATRIX_PRBS_M9PR_Msk (0x3u << MATRIX_PRBS_M9PR_Pos)
123 #define MATRIX_PRBS_M9PR(value) ((MATRIX_PRBS_M9PR_Msk & ((value) << MATRIX_PRBS_M9PR_Pos)))
124 #define MATRIX_PRBS_M10PR_Pos 8
125 #define MATRIX_PRBS_M10PR_Msk (0x3u << MATRIX_PRBS_M10PR_Pos)
126 #define MATRIX_PRBS_M10PR(value) ((MATRIX_PRBS_M10PR_Msk & ((value) << MATRIX_PRBS_M10PR_Pos)))
127 #define MATRIX_PRBS_M11PR_Pos 12
128 #define MATRIX_PRBS_M11PR_Msk (0x3u << MATRIX_PRBS_M11PR_Pos)
129 #define MATRIX_PRBS_M11PR(value) ((MATRIX_PRBS_M11PR_Msk & ((value) << MATRIX_PRBS_M11PR_Pos)))
130 /* -------- MATRIX_MRCR : (MATRIX Offset: 0x0100) Master Remap Control Register -------- */
131 #define MATRIX_MRCR_RCB0 (0x1u << 0)
132 #define MATRIX_MRCR_RCB1 (0x1u << 1)
133 #define MATRIX_MRCR_RCB2 (0x1u << 2)
134 #define MATRIX_MRCR_RCB3 (0x1u << 3)
135 #define MATRIX_MRCR_RCB4 (0x1u << 4)
136 #define MATRIX_MRCR_RCB5 (0x1u << 5)
137 #define MATRIX_MRCR_RCB6 (0x1u << 6)
138 #define MATRIX_MRCR_RCB7 (0x1u << 7)
139 #define MATRIX_MRCR_RCB8 (0x1u << 8)
140 #define MATRIX_MRCR_RCB9 (0x1u << 9)
141 #define MATRIX_MRCR_RCB10 (0x1u << 10)
142 #define MATRIX_MRCR_RCB11 (0x1u << 11)
143 /* -------- CCFG_CAN0 : (MATRIX Offset: 0x0110) CAN0 Configuration Register -------- */
144 #define CCFG_CAN0_CAN0DMABA_Pos 16
145 #define CCFG_CAN0_CAN0DMABA_Msk (0xffffu << CCFG_CAN0_CAN0DMABA_Pos)
146 #define CCFG_CAN0_CAN0DMABA(value) ((CCFG_CAN0_CAN0DMABA_Msk & ((value) << CCFG_CAN0_CAN0DMABA_Pos)))
147 /* -------- CCFG_SYSIO : (MATRIX Offset: 0x0114) System I/O and CAN1 Configuration Register -------- */
148 #define CCFG_SYSIO_SYSIO4 (0x1u << 4)
149 #define CCFG_SYSIO_SYSIO5 (0x1u << 5)
150 #define CCFG_SYSIO_SYSIO6 (0x1u << 6)
151 #define CCFG_SYSIO_SYSIO7 (0x1u << 7)
152 #define CCFG_SYSIO_SYSIO12 (0x1u << 12)
153 #define CCFG_SYSIO_CAN1DMABA_Pos 16
154 #define CCFG_SYSIO_CAN1DMABA_Msk (0xffffu << CCFG_SYSIO_CAN1DMABA_Pos)
155 #define CCFG_SYSIO_CAN1DMABA(value) ((CCFG_SYSIO_CAN1DMABA_Msk & ((value) << CCFG_SYSIO_CAN1DMABA_Pos)))
156 /* -------- CCFG_SMCNFCS : (MATRIX Offset: 0x0124) SMC NAND Flash Chip Select Configuration Register -------- */
157 #define CCFG_SMCNFCS_SMC_NFCS0 (0x1u << 0)
158 #define CCFG_SMCNFCS_SMC_NFCS1 (0x1u << 1)
159 #define CCFG_SMCNFCS_SMC_NFCS2 (0x1u << 2)
160 #define CCFG_SMCNFCS_SMC_NFCS3 (0x1u << 3)
161 #define CCFG_SMCNFCS_SDRAMEN (0x1u << 4)
162 /* -------- MATRIX_WPMR : (MATRIX Offset: 0x01E4) Write Protection Mode Register -------- */
163 #define MATRIX_WPMR_WPEN (0x1u << 0)
164 #define MATRIX_WPMR_WPKEY_Pos 8
165 #define MATRIX_WPMR_WPKEY_Msk (0xffffffu << MATRIX_WPMR_WPKEY_Pos)
166 #define MATRIX_WPMR_WPKEY(value) ((MATRIX_WPMR_WPKEY_Msk & ((value) << MATRIX_WPMR_WPKEY_Pos)))
167 #define MATRIX_WPMR_WPKEY_PASSWD (0x4D4154u << 8)
168 /* -------- MATRIX_WPSR : (MATRIX Offset: 0x01E8) Write Protection Status Register -------- */
169 #define MATRIX_WPSR_WPVS (0x1u << 0)
170 #define MATRIX_WPSR_WPVSRC_Pos 8
171 #define MATRIX_WPSR_WPVSRC_Msk (0xffffu << MATRIX_WPSR_WPVSRC_Pos)
172 /* -------- MATRIX_VERSION : (MATRIX Offset: 0x01FC) Version Register -------- */
173 #define MATRIX_VERSION_VERSION_Pos 0
174 #define MATRIX_VERSION_VERSION_Msk (0xfffu << MATRIX_VERSION_VERSION_Pos)
175 #define MATRIX_VERSION_MFN_Pos 16
176 #define MATRIX_VERSION_MFN_Msk (0x7u << MATRIX_VERSION_MFN_Pos)
179
180
181 #endif /* _SAMV71_MATRIX_COMPONENT_ */
MatrixPr hardware registers.
Definition: component_matrix.h:41
#define __IO
Definition: core_cm7.h:287
(Matrix Offset: 0x01FC) Version Register
Definition: component_matrix.h:64
Matrix hardware registers.
Definition: component_matrix.h:46
Definition: component_matrix.h:47
#define __I
Definition: core_cm7.h:284
