RTEMS  5.1
component_isi.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAMV71_ISI_COMPONENT_
31 #define _SAMV71_ISI_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __IO uint32_t ISI_CFG1;
43  __IO uint32_t ISI_CFG2;
44  __IO uint32_t ISI_PSIZE;
45  __IO uint32_t ISI_PDECF;
46  __IO uint32_t ISI_Y2R_SET0;
47  __IO uint32_t ISI_Y2R_SET1;
48  __IO uint32_t ISI_R2Y_SET0;
49  __IO uint32_t ISI_R2Y_SET1;
50  __IO uint32_t ISI_R2Y_SET2;
51  __O uint32_t ISI_CR;
52  __I uint32_t ISI_SR;
53  __O uint32_t ISI_IER;
54  __O uint32_t ISI_IDR;
55  __I uint32_t ISI_IMR;
56  __O uint32_t ISI_DMA_CHER;
57  __O uint32_t ISI_DMA_CHDR;
58  __I uint32_t ISI_DMA_CHSR;
59  __IO uint32_t ISI_DMA_P_ADDR;
60  __IO uint32_t ISI_DMA_P_CTRL;
61  __IO uint32_t ISI_DMA_P_DSCR;
62  __IO uint32_t ISI_DMA_C_ADDR;
63  __IO uint32_t ISI_DMA_C_CTRL;
64  __IO uint32_t ISI_DMA_C_DSCR;
65  __I uint32_t Reserved1[34];
66  __IO uint32_t ISI_WPMR;
67  __I uint32_t ISI_WPSR;
68  __I uint32_t Reserved2[4];
69  __I uint32_t ISI_VERSION;
70 } Isi;
71 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
72 /* -------- ISI_CFG1 : (ISI Offset: 0x00) ISI Configuration 1 Register -------- */
73 #define ISI_CFG1_HSYNC_POL (0x1u << 2)
74 #define ISI_CFG1_VSYNC_POL (0x1u << 3)
75 #define ISI_CFG1_PIXCLK_POL (0x1u << 4)
76 #define ISI_CFG1_EMB_SYNC (0x1u << 6)
77 #define ISI_CFG1_CRC_SYNC (0x1u << 7)
78 #define ISI_CFG1_FRATE_Pos 8
79 #define ISI_CFG1_FRATE_Msk (0x7u << ISI_CFG1_FRATE_Pos)
80 #define ISI_CFG1_FRATE(value) ((ISI_CFG1_FRATE_Msk & ((value) << ISI_CFG1_FRATE_Pos)))
81 #define ISI_CFG1_DISCR (0x1u << 11)
82 #define ISI_CFG1_FULL (0x1u << 12)
83 #define ISI_CFG1_THMASK_Pos 13
84 #define ISI_CFG1_THMASK_Msk (0x3u << ISI_CFG1_THMASK_Pos)
85 #define ISI_CFG1_THMASK(value) ((ISI_CFG1_THMASK_Msk & ((value) << ISI_CFG1_THMASK_Pos)))
86 #define ISI_CFG1_THMASK_BEATS_4 (0x0u << 13)
87 #define ISI_CFG1_THMASK_BEATS_8 (0x1u << 13)
88 #define ISI_CFG1_THMASK_BEATS_16 (0x2u << 13)
89 #define ISI_CFG1_SLD_Pos 16
90 #define ISI_CFG1_SLD_Msk (0xffu << ISI_CFG1_SLD_Pos)
91 #define ISI_CFG1_SLD(value) ((ISI_CFG1_SLD_Msk & ((value) << ISI_CFG1_SLD_Pos)))
92 #define ISI_CFG1_SFD_Pos 24
93 #define ISI_CFG1_SFD_Msk (0xffu << ISI_CFG1_SFD_Pos)
94 #define ISI_CFG1_SFD(value) ((ISI_CFG1_SFD_Msk & ((value) << ISI_CFG1_SFD_Pos)))
95 /* -------- ISI_CFG2 : (ISI Offset: 0x04) ISI Configuration 2 Register -------- */
96 #define ISI_CFG2_IM_VSIZE_Pos 0
97 #define ISI_CFG2_IM_VSIZE_Msk (0x7ffu << ISI_CFG2_IM_VSIZE_Pos)
98 #define ISI_CFG2_IM_VSIZE(value) ((ISI_CFG2_IM_VSIZE_Msk & ((value) << ISI_CFG2_IM_VSIZE_Pos)))
99 #define ISI_CFG2_GS_MODE (0x1u << 11)
100 #define ISI_CFG2_RGB_MODE (0x1u << 12)
101 #define ISI_CFG2_GRAYSCALE (0x1u << 13)
102 #define ISI_CFG2_RGB_SWAP (0x1u << 14)
103 #define ISI_CFG2_COL_SPACE (0x1u << 15)
104 #define ISI_CFG2_IM_HSIZE_Pos 16
105 #define ISI_CFG2_IM_HSIZE_Msk (0x7ffu << ISI_CFG2_IM_HSIZE_Pos)
106 #define ISI_CFG2_IM_HSIZE(value) ((ISI_CFG2_IM_HSIZE_Msk & ((value) << ISI_CFG2_IM_HSIZE_Pos)))
107 #define ISI_CFG2_YCC_SWAP_Pos 28
108 #define ISI_CFG2_YCC_SWAP_Msk (0x3u << ISI_CFG2_YCC_SWAP_Pos)
109 #define ISI_CFG2_YCC_SWAP(value) ((ISI_CFG2_YCC_SWAP_Msk & ((value) << ISI_CFG2_YCC_SWAP_Pos)))
110 #define ISI_CFG2_YCC_SWAP_DEFAULT (0x0u << 28)
111 #define ISI_CFG2_YCC_SWAP_MODE1 (0x1u << 28)
112 #define ISI_CFG2_YCC_SWAP_MODE2 (0x2u << 28)
113 #define ISI_CFG2_YCC_SWAP_MODE3 (0x3u << 28)
114 #define ISI_CFG2_RGB_CFG_Pos 30
115 #define ISI_CFG2_RGB_CFG_Msk (0x3u << ISI_CFG2_RGB_CFG_Pos)
116 #define ISI_CFG2_RGB_CFG(value) ((ISI_CFG2_RGB_CFG_Msk & ((value) << ISI_CFG2_RGB_CFG_Pos)))
117 #define ISI_CFG2_RGB_CFG_DEFAULT (0x0u << 30)
118 #define ISI_CFG2_RGB_CFG_MODE1 (0x1u << 30)
119 #define ISI_CFG2_RGB_CFG_MODE2 (0x2u << 30)
120 #define ISI_CFG2_RGB_CFG_MODE3 (0x3u << 30)
121 /* -------- ISI_PSIZE : (ISI Offset: 0x08) ISI Preview Size Register -------- */
122 #define ISI_PSIZE_PREV_VSIZE_Pos 0
123 #define ISI_PSIZE_PREV_VSIZE_Msk (0x3ffu << ISI_PSIZE_PREV_VSIZE_Pos)
124 #define ISI_PSIZE_PREV_VSIZE(value) ((ISI_PSIZE_PREV_VSIZE_Msk & ((value) << ISI_PSIZE_PREV_VSIZE_Pos)))
125 #define ISI_PSIZE_PREV_HSIZE_Pos 16
126 #define ISI_PSIZE_PREV_HSIZE_Msk (0x3ffu << ISI_PSIZE_PREV_HSIZE_Pos)
127 #define ISI_PSIZE_PREV_HSIZE(value) ((ISI_PSIZE_PREV_HSIZE_Msk & ((value) << ISI_PSIZE_PREV_HSIZE_Pos)))
128 /* -------- ISI_PDECF : (ISI Offset: 0x0C) ISI Preview Decimation Factor Register -------- */
129 #define ISI_PDECF_DEC_FACTOR_Pos 0
130 #define ISI_PDECF_DEC_FACTOR_Msk (0xffu << ISI_PDECF_DEC_FACTOR_Pos)
131 #define ISI_PDECF_DEC_FACTOR(value) ((ISI_PDECF_DEC_FACTOR_Msk & ((value) << ISI_PDECF_DEC_FACTOR_Pos)))
132 /* -------- ISI_Y2R_SET0 : (ISI Offset: 0x10) ISI Color Space Conversion YCrCb To RGB Set 0 Register -------- */
133 #define ISI_Y2R_SET0_C0_Pos 0
134 #define ISI_Y2R_SET0_C0_Msk (0xffu << ISI_Y2R_SET0_C0_Pos)
135 #define ISI_Y2R_SET0_C0(value) ((ISI_Y2R_SET0_C0_Msk & ((value) << ISI_Y2R_SET0_C0_Pos)))
136 #define ISI_Y2R_SET0_C1_Pos 8
137 #define ISI_Y2R_SET0_C1_Msk (0xffu << ISI_Y2R_SET0_C1_Pos)
138 #define ISI_Y2R_SET0_C1(value) ((ISI_Y2R_SET0_C1_Msk & ((value) << ISI_Y2R_SET0_C1_Pos)))
139 #define ISI_Y2R_SET0_C2_Pos 16
140 #define ISI_Y2R_SET0_C2_Msk (0xffu << ISI_Y2R_SET0_C2_Pos)
141 #define ISI_Y2R_SET0_C2(value) ((ISI_Y2R_SET0_C2_Msk & ((value) << ISI_Y2R_SET0_C2_Pos)))
142 #define ISI_Y2R_SET0_C3_Pos 24
143 #define ISI_Y2R_SET0_C3_Msk (0xffu << ISI_Y2R_SET0_C3_Pos)
144 #define ISI_Y2R_SET0_C3(value) ((ISI_Y2R_SET0_C3_Msk & ((value) << ISI_Y2R_SET0_C3_Pos)))
145 /* -------- ISI_Y2R_SET1 : (ISI Offset: 0x14) ISI Color Space Conversion YCrCb To RGB Set 1 Register -------- */
146 #define ISI_Y2R_SET1_C4_Pos 0
147 #define ISI_Y2R_SET1_C4_Msk (0x1ffu << ISI_Y2R_SET1_C4_Pos)
148 #define ISI_Y2R_SET1_C4(value) ((ISI_Y2R_SET1_C4_Msk & ((value) << ISI_Y2R_SET1_C4_Pos)))
149 #define ISI_Y2R_SET1_Yoff (0x1u << 12)
150 #define ISI_Y2R_SET1_Croff (0x1u << 13)
151 #define ISI_Y2R_SET1_Cboff (0x1u << 14)
152 /* -------- ISI_R2Y_SET0 : (ISI Offset: 0x18) ISI Color Space Conversion RGB To YCrCb Set 0 Register -------- */
153 #define ISI_R2Y_SET0_C0_Pos 0
154 #define ISI_R2Y_SET0_C0_Msk (0x7fu << ISI_R2Y_SET0_C0_Pos)
155 #define ISI_R2Y_SET0_C0(value) ((ISI_R2Y_SET0_C0_Msk & ((value) << ISI_R2Y_SET0_C0_Pos)))
156 #define ISI_R2Y_SET0_C1_Pos 8
157 #define ISI_R2Y_SET0_C1_Msk (0x7fu << ISI_R2Y_SET0_C1_Pos)
158 #define ISI_R2Y_SET0_C1(value) ((ISI_R2Y_SET0_C1_Msk & ((value) << ISI_R2Y_SET0_C1_Pos)))
159 #define ISI_R2Y_SET0_C2_Pos 16
160 #define ISI_R2Y_SET0_C2_Msk (0x7fu << ISI_R2Y_SET0_C2_Pos)
161 #define ISI_R2Y_SET0_C2(value) ((ISI_R2Y_SET0_C2_Msk & ((value) << ISI_R2Y_SET0_C2_Pos)))
162 #define ISI_R2Y_SET0_Roff (0x1u << 24)
163 /* -------- ISI_R2Y_SET1 : (ISI Offset: 0x1C) ISI Color Space Conversion RGB To YCrCb Set 1 Register -------- */
164 #define ISI_R2Y_SET1_C3_Pos 0
165 #define ISI_R2Y_SET1_C3_Msk (0x7fu << ISI_R2Y_SET1_C3_Pos)
166 #define ISI_R2Y_SET1_C3(value) ((ISI_R2Y_SET1_C3_Msk & ((value) << ISI_R2Y_SET1_C3_Pos)))
167 #define ISI_R2Y_SET1_C4_Pos 8
168 #define ISI_R2Y_SET1_C4_Msk (0x7fu << ISI_R2Y_SET1_C4_Pos)
169 #define ISI_R2Y_SET1_C4(value) ((ISI_R2Y_SET1_C4_Msk & ((value) << ISI_R2Y_SET1_C4_Pos)))
170 #define ISI_R2Y_SET1_C5_Pos 16
171 #define ISI_R2Y_SET1_C5_Msk (0x7fu << ISI_R2Y_SET1_C5_Pos)
172 #define ISI_R2Y_SET1_C5(value) ((ISI_R2Y_SET1_C5_Msk & ((value) << ISI_R2Y_SET1_C5_Pos)))
173 #define ISI_R2Y_SET1_Goff (0x1u << 24)
174 /* -------- ISI_R2Y_SET2 : (ISI Offset: 0x20) ISI Color Space Conversion RGB To YCrCb Set 2 Register -------- */
175 #define ISI_R2Y_SET2_C6_Pos 0
176 #define ISI_R2Y_SET2_C6_Msk (0x7fu << ISI_R2Y_SET2_C6_Pos)
177 #define ISI_R2Y_SET2_C6(value) ((ISI_R2Y_SET2_C6_Msk & ((value) << ISI_R2Y_SET2_C6_Pos)))
178 #define ISI_R2Y_SET2_C7_Pos 8
179 #define ISI_R2Y_SET2_C7_Msk (0x7fu << ISI_R2Y_SET2_C7_Pos)
180 #define ISI_R2Y_SET2_C7(value) ((ISI_R2Y_SET2_C7_Msk & ((value) << ISI_R2Y_SET2_C7_Pos)))
181 #define ISI_R2Y_SET2_C8_Pos 16
182 #define ISI_R2Y_SET2_C8_Msk (0x7fu << ISI_R2Y_SET2_C8_Pos)
183 #define ISI_R2Y_SET2_C8(value) ((ISI_R2Y_SET2_C8_Msk & ((value) << ISI_R2Y_SET2_C8_Pos)))
184 #define ISI_R2Y_SET2_Boff (0x1u << 24)
185 /* -------- ISI_CR : (ISI Offset: 0x24) ISI Control Register -------- */
186 #define ISI_CR_ISI_EN (0x1u << 0)
187 #define ISI_CR_ISI_DIS (0x1u << 1)
188 #define ISI_CR_ISI_SRST (0x1u << 2)
189 #define ISI_CR_ISI_CDC (0x1u << 8)
190 /* -------- ISI_SR : (ISI Offset: 0x28) ISI Status Register -------- */
191 #define ISI_SR_ENABLE (0x1u << 0)
192 #define ISI_SR_DIS_DONE (0x1u << 1)
193 #define ISI_SR_SRST (0x1u << 2)
194 #define ISI_SR_CDC_PND (0x1u << 8)
195 #define ISI_SR_VSYNC (0x1u << 10)
196 #define ISI_SR_PXFR_DONE (0x1u << 16)
197 #define ISI_SR_CXFR_DONE (0x1u << 17)
198 #define ISI_SR_SIP (0x1u << 19)
199 #define ISI_SR_P_OVR (0x1u << 24)
200 #define ISI_SR_C_OVR (0x1u << 25)
201 #define ISI_SR_CRC_ERR (0x1u << 26)
202 #define ISI_SR_FR_OVR (0x1u << 27)
203 /* -------- ISI_IER : (ISI Offset: 0x2C) ISI Interrupt Enable Register -------- */
204 #define ISI_IER_DIS_DONE (0x1u << 1)
205 #define ISI_IER_SRST (0x1u << 2)
206 #define ISI_IER_VSYNC (0x1u << 10)
207 #define ISI_IER_PXFR_DONE (0x1u << 16)
208 #define ISI_IER_CXFR_DONE (0x1u << 17)
209 #define ISI_IER_P_OVR (0x1u << 24)
210 #define ISI_IER_C_OVR (0x1u << 25)
211 #define ISI_IER_CRC_ERR (0x1u << 26)
212 #define ISI_IER_FR_OVR (0x1u << 27)
213 /* -------- ISI_IDR : (ISI Offset: 0x30) ISI Interrupt Disable Register -------- */
214 #define ISI_IDR_DIS_DONE (0x1u << 1)
215 #define ISI_IDR_SRST (0x1u << 2)
216 #define ISI_IDR_VSYNC (0x1u << 10)
217 #define ISI_IDR_PXFR_DONE (0x1u << 16)
218 #define ISI_IDR_CXFR_DONE (0x1u << 17)
219 #define ISI_IDR_P_OVR (0x1u << 24)
220 #define ISI_IDR_C_OVR (0x1u << 25)
221 #define ISI_IDR_CRC_ERR (0x1u << 26)
222 #define ISI_IDR_FR_OVR (0x1u << 27)
223 /* -------- ISI_IMR : (ISI Offset: 0x34) ISI Interrupt Mask Register -------- */
224 #define ISI_IMR_DIS_DONE (0x1u << 1)
225 #define ISI_IMR_SRST (0x1u << 2)
226 #define ISI_IMR_VSYNC (0x1u << 10)
227 #define ISI_IMR_PXFR_DONE (0x1u << 16)
228 #define ISI_IMR_CXFR_DONE (0x1u << 17)
229 #define ISI_IMR_P_OVR (0x1u << 24)
230 #define ISI_IMR_C_OVR (0x1u << 25)
231 #define ISI_IMR_CRC_ERR (0x1u << 26)
232 #define ISI_IMR_FR_OVR (0x1u << 27)
233 /* -------- ISI_DMA_CHER : (ISI Offset: 0x38) DMA Channel Enable Register -------- */
234 #define ISI_DMA_CHER_P_CH_EN (0x1u << 0)
235 #define ISI_DMA_CHER_C_CH_EN (0x1u << 1)
236 /* -------- ISI_DMA_CHDR : (ISI Offset: 0x3C) DMA Channel Disable Register -------- */
237 #define ISI_DMA_CHDR_P_CH_DIS (0x1u << 0)
238 #define ISI_DMA_CHDR_C_CH_DIS (0x1u << 1)
239 /* -------- ISI_DMA_CHSR : (ISI Offset: 0x40) DMA Channel Status Register -------- */
240 #define ISI_DMA_CHSR_P_CH_S (0x1u << 0)
241 #define ISI_DMA_CHSR_C_CH_S (0x1u << 1)
242 /* -------- ISI_DMA_P_ADDR : (ISI Offset: 0x44) DMA Preview Base Address Register -------- */
243 #define ISI_DMA_P_ADDR_P_ADDR_Pos 2
244 #define ISI_DMA_P_ADDR_P_ADDR_Msk (0x3fffffffu << ISI_DMA_P_ADDR_P_ADDR_Pos)
245 #define ISI_DMA_P_ADDR_P_ADDR(value) ((ISI_DMA_P_ADDR_P_ADDR_Msk & ((value) << ISI_DMA_P_ADDR_P_ADDR_Pos)))
246 /* -------- ISI_DMA_P_CTRL : (ISI Offset: 0x48) DMA Preview Control Register -------- */
247 #define ISI_DMA_P_CTRL_P_FETCH (0x1u << 0)
248 #define ISI_DMA_P_CTRL_P_WB (0x1u << 1)
249 #define ISI_DMA_P_CTRL_P_IEN (0x1u << 2)
250 #define ISI_DMA_P_CTRL_P_DONE (0x1u << 3)
251 /* -------- ISI_DMA_P_DSCR : (ISI Offset: 0x4C) DMA Preview Descriptor Address Register -------- */
252 #define ISI_DMA_P_DSCR_P_DSCR_Pos 2
253 #define ISI_DMA_P_DSCR_P_DSCR_Msk (0x3fffffffu << ISI_DMA_P_DSCR_P_DSCR_Pos)
254 #define ISI_DMA_P_DSCR_P_DSCR(value) ((ISI_DMA_P_DSCR_P_DSCR_Msk & ((value) << ISI_DMA_P_DSCR_P_DSCR_Pos)))
255 /* -------- ISI_DMA_C_ADDR : (ISI Offset: 0x50) DMA Codec Base Address Register -------- */
256 #define ISI_DMA_C_ADDR_C_ADDR_Pos 2
257 #define ISI_DMA_C_ADDR_C_ADDR_Msk (0x3fffffffu << ISI_DMA_C_ADDR_C_ADDR_Pos)
258 #define ISI_DMA_C_ADDR_C_ADDR(value) ((ISI_DMA_C_ADDR_C_ADDR_Msk & ((value) << ISI_DMA_C_ADDR_C_ADDR_Pos)))
259 /* -------- ISI_DMA_C_CTRL : (ISI Offset: 0x54) DMA Codec Control Register -------- */
260 #define ISI_DMA_C_CTRL_C_FETCH (0x1u << 0)
261 #define ISI_DMA_C_CTRL_C_WB (0x1u << 1)
262 #define ISI_DMA_C_CTRL_C_IEN (0x1u << 2)
263 #define ISI_DMA_C_CTRL_C_DONE (0x1u << 3)
264 /* -------- ISI_DMA_C_DSCR : (ISI Offset: 0x58) DMA Codec Descriptor Address Register -------- */
265 #define ISI_DMA_C_DSCR_C_DSCR_Pos 2
266 #define ISI_DMA_C_DSCR_C_DSCR_Msk (0x3fffffffu << ISI_DMA_C_DSCR_C_DSCR_Pos)
267 #define ISI_DMA_C_DSCR_C_DSCR(value) ((ISI_DMA_C_DSCR_C_DSCR_Msk & ((value) << ISI_DMA_C_DSCR_C_DSCR_Pos)))
268 /* -------- ISI_WPMR : (ISI Offset: 0xE4) Write Protection Mode Register -------- */
269 #define ISI_WPMR_WPEN (0x1u << 0)
270 #define ISI_WPMR_WPKEY_Pos 8
271 #define ISI_WPMR_WPKEY_Msk (0xffffffu << ISI_WPMR_WPKEY_Pos)
272 #define ISI_WPMR_WPKEY(value) ((ISI_WPMR_WPKEY_Msk & ((value) << ISI_WPMR_WPKEY_Pos)))
273 #define ISI_WPMR_WPKEY_PASSWD (0x495349u << 8)
274 /* -------- ISI_WPSR : (ISI Offset: 0xE8) Write Protection Status Register -------- */
275 #define ISI_WPSR_WPVS (0x1u << 0)
276 #define ISI_WPSR_WPVSRC_Pos 8
277 #define ISI_WPSR_WPVSRC_Msk (0xffffu << ISI_WPSR_WPVSRC_Pos)
278 /* -------- ISI_VERSION : (ISI Offset: 0xFC) Version Register -------- */
279 #define ISI_VERSION_VERSION_Pos 0
280 #define ISI_VERSION_VERSION_Msk (0xfffu << ISI_VERSION_VERSION_Pos)
281 #define ISI_VERSION_MFN_Pos 16
282 #define ISI_VERSION_MFN_Msk (0x7u << ISI_VERSION_MFN_Pos)
285
286
287 #endif /* _SAMV71_ISI_COMPONENT_ */
#define __IO
Definition: core_cm7.h:287
(Isi Offset: 0xFC) Version Register
Definition: component_isi.h:69
#define __O
Definition: core_cm7.h:286
#define __I
Definition: core_cm7.h:284
Isi hardware registers.
Definition: component_isi.h:41
