RTEMS  5.1
Data Structures | Macros
struct  Isi
 Isi hardware registers. More...
#define ISI_CFG1_HSYNC_POL   (0x1u << 2)
 (ISI_CFG1) Horizontal Synchronization Polarity
#define ISI_CFG1_VSYNC_POL   (0x1u << 3)
 (ISI_CFG1) Vertical Synchronization Polarity
#define ISI_CFG1_PIXCLK_POL   (0x1u << 4)
 (ISI_CFG1) Pixel Clock Polarity
#define ISI_CFG1_EMB_SYNC   (0x1u << 6)
 (ISI_CFG1) Embedded Synchronization
#define ISI_CFG1_CRC_SYNC   (0x1u << 7)
 (ISI_CFG1) Embedded Synchronization Correction
#define ISI_CFG1_FRATE_Pos   8
#define ISI_CFG1_FRATE_Msk   (0x7u << ISI_CFG1_FRATE_Pos)
 (ISI_CFG1) Frame Rate [0..7]
#define ISI_CFG1_FRATE(value)   ((ISI_CFG1_FRATE_Msk & ((value) << ISI_CFG1_FRATE_Pos)))
#define ISI_CFG1_DISCR   (0x1u << 11)
 (ISI_CFG1) Disable Codec Request
#define ISI_CFG1_FULL   (0x1u << 12)
 (ISI_CFG1) Full Mode is Allowed
#define ISI_CFG1_THMASK_Pos   13
#define ISI_CFG1_THMASK_Msk   (0x3u << ISI_CFG1_THMASK_Pos)
 (ISI_CFG1) Threshold Mask
#define ISI_CFG1_THMASK(value)   ((ISI_CFG1_THMASK_Msk & ((value) << ISI_CFG1_THMASK_Pos)))
#define ISI_CFG1_THMASK_BEATS_4   (0x0u << 13)
 (ISI_CFG1) Only 4 beats AHB burst allowed
#define ISI_CFG1_THMASK_BEATS_8   (0x1u << 13)
 (ISI_CFG1) Only 4 and 8 beats AHB burst allowed
#define ISI_CFG1_THMASK_BEATS_16   (0x2u << 13)
 (ISI_CFG1) 4, 8 and 16 beats AHB burst allowed
#define ISI_CFG1_SLD_Pos   16
#define ISI_CFG1_SLD_Msk   (0xffu << ISI_CFG1_SLD_Pos)
 (ISI_CFG1) Start of Line Delay
#define ISI_CFG1_SLD(value)   ((ISI_CFG1_SLD_Msk & ((value) << ISI_CFG1_SLD_Pos)))
#define ISI_CFG1_SFD_Pos   24
#define ISI_CFG1_SFD_Msk   (0xffu << ISI_CFG1_SFD_Pos)
 (ISI_CFG1) Start of Frame Delay
#define ISI_CFG1_SFD(value)   ((ISI_CFG1_SFD_Msk & ((value) << ISI_CFG1_SFD_Pos)))
#define ISI_CFG2_IM_VSIZE_Pos   0
#define ISI_CFG2_IM_VSIZE_Msk   (0x7ffu << ISI_CFG2_IM_VSIZE_Pos)
 (ISI_CFG2) Vertical Size of the Image Sensor [0..2047]
#define ISI_CFG2_IM_VSIZE(value)   ((ISI_CFG2_IM_VSIZE_Msk & ((value) << ISI_CFG2_IM_VSIZE_Pos)))
#define ISI_CFG2_GS_MODE   (0x1u << 11)
 (ISI_CFG2) Grayscale Pixel Format Mode
#define ISI_CFG2_RGB_MODE   (0x1u << 12)
 (ISI_CFG2) RGB Input Mode
#define ISI_CFG2_GRAYSCALE   (0x1u << 13)
 (ISI_CFG2) Grayscale Mode Format Enable
#define ISI_CFG2_RGB_SWAP   (0x1u << 14)
 (ISI_CFG2) RGB Format Swap Mode
#define ISI_CFG2_COL_SPACE   (0x1u << 15)
 (ISI_CFG2) Color Space for the Image Data
#define ISI_CFG2_IM_HSIZE_Pos   16
#define ISI_CFG2_IM_HSIZE_Msk   (0x7ffu << ISI_CFG2_IM_HSIZE_Pos)
 (ISI_CFG2) Horizontal Size of the Image Sensor [0..2047]
#define ISI_CFG2_IM_HSIZE(value)   ((ISI_CFG2_IM_HSIZE_Msk & ((value) << ISI_CFG2_IM_HSIZE_Pos)))
#define ISI_CFG2_YCC_SWAP_Pos   28
#define ISI_CFG2_YCC_SWAP_Msk   (0x3u << ISI_CFG2_YCC_SWAP_Pos)
 (ISI_CFG2) YCrCb Format Swap Mode
#define ISI_CFG2_YCC_SWAP(value)   ((ISI_CFG2_YCC_SWAP_Msk & ((value) << ISI_CFG2_YCC_SWAP_Pos)))
#define ISI_CFG2_YCC_SWAP_DEFAULT   (0x0u << 28)
 (ISI_CFG2) Byte 0 Cb(i)Byte 1 Y(i)Byte 2 Cr(i)Byte 3 Y(i+1)
#define ISI_CFG2_YCC_SWAP_MODE1   (0x1u << 28)
 (ISI_CFG2) Byte 0 Cr(i)Byte 1 Y(i)Byte 2 Cb(i)Byte 3 Y(i+1)
#define ISI_CFG2_YCC_SWAP_MODE2   (0x2u << 28)
 (ISI_CFG2) Byte 0 Y(i)Byte 1 Cb(i)Byte 2 Y(i+1)Byte 3 Cr(i)
#define ISI_CFG2_YCC_SWAP_MODE3   (0x3u << 28)
 (ISI_CFG2) Byte 0 Y(i)Byte 1 Cr(i)Byte 2 Y(i+1)Byte 3 Cb(i)
#define ISI_CFG2_RGB_CFG_Pos   30
#define ISI_CFG2_RGB_CFG_Msk   (0x3u << ISI_CFG2_RGB_CFG_Pos)
 (ISI_CFG2) RGB Pixel Mapping Configuration
#define ISI_CFG2_RGB_CFG(value)   ((ISI_CFG2_RGB_CFG_Msk & ((value) << ISI_CFG2_RGB_CFG_Pos)))
#define ISI_CFG2_RGB_CFG_DEFAULT   (0x0u << 30)
 (ISI_CFG2) Byte 0 R/G(MSB)Byte 1 G(LSB)/BByte 2 R/G(MSB)Byte 3 G(LSB)/B
#define ISI_CFG2_RGB_CFG_MODE1   (0x1u << 30)
 (ISI_CFG2) Byte 0 B/G(MSB)Byte 1 G(LSB)/RByte 2 B/G(MSB)Byte 3 G(LSB)/R
#define ISI_CFG2_RGB_CFG_MODE2   (0x2u << 30)
 (ISI_CFG2) Byte 0 G(LSB)/RByte 1 B/G(MSB)Byte 2 G(LSB)/RByte 3 B/G(MSB)
#define ISI_CFG2_RGB_CFG_MODE3   (0x3u << 30)
 (ISI_CFG2) Byte 0 G(LSB)/BByte 1 R/G(MSB)Byte 2 G(LSB)/BByte 3 R/G(MSB)
#define ISI_PSIZE_PREV_VSIZE_Pos   0
#define ISI_PSIZE_PREV_VSIZE_Msk   (0x3ffu << ISI_PSIZE_PREV_VSIZE_Pos)
 (ISI_PSIZE) Vertical Size for the Preview Path
#define ISI_PSIZE_PREV_VSIZE(value)   ((ISI_PSIZE_PREV_VSIZE_Msk & ((value) << ISI_PSIZE_PREV_VSIZE_Pos)))
#define ISI_PSIZE_PREV_HSIZE_Pos   16
#define ISI_PSIZE_PREV_HSIZE_Msk   (0x3ffu << ISI_PSIZE_PREV_HSIZE_Pos)
 (ISI_PSIZE) Horizontal Size for the Preview Path
#define ISI_PSIZE_PREV_HSIZE(value)   ((ISI_PSIZE_PREV_HSIZE_Msk & ((value) << ISI_PSIZE_PREV_HSIZE_Pos)))
#define ISI_PDECF_DEC_FACTOR_Pos   0
#define ISI_PDECF_DEC_FACTOR_Msk   (0xffu << ISI_PDECF_DEC_FACTOR_Pos)
 (ISI_PDECF) Decimation Factor
#define ISI_PDECF_DEC_FACTOR(value)   ((ISI_PDECF_DEC_FACTOR_Msk & ((value) << ISI_PDECF_DEC_FACTOR_Pos)))
#define ISI_Y2R_SET0_C0_Pos   0
#define ISI_Y2R_SET0_C0_Msk   (0xffu << ISI_Y2R_SET0_C0_Pos)
 (ISI_Y2R_SET0) Color Space Conversion Matrix Coefficient C0
#define ISI_Y2R_SET0_C0(value)   ((ISI_Y2R_SET0_C0_Msk & ((value) << ISI_Y2R_SET0_C0_Pos)))
#define ISI_Y2R_SET0_C1_Pos   8
#define ISI_Y2R_SET0_C1_Msk   (0xffu << ISI_Y2R_SET0_C1_Pos)
 (ISI_Y2R_SET0) Color Space Conversion Matrix Coefficient C1
#define ISI_Y2R_SET0_C1(value)   ((ISI_Y2R_SET0_C1_Msk & ((value) << ISI_Y2R_SET0_C1_Pos)))
#define ISI_Y2R_SET0_C2_Pos   16
#define ISI_Y2R_SET0_C2_Msk   (0xffu << ISI_Y2R_SET0_C2_Pos)
 (ISI_Y2R_SET0) Color Space Conversion Matrix Coefficient C2
#define ISI_Y2R_SET0_C2(value)   ((ISI_Y2R_SET0_C2_Msk & ((value) << ISI_Y2R_SET0_C2_Pos)))
#define ISI_Y2R_SET0_C3_Pos   24
#define ISI_Y2R_SET0_C3_Msk   (0xffu << ISI_Y2R_SET0_C3_Pos)
 (ISI_Y2R_SET0) Color Space Conversion Matrix Coefficient C3
#define ISI_Y2R_SET0_C3(value)   ((ISI_Y2R_SET0_C3_Msk & ((value) << ISI_Y2R_SET0_C3_Pos)))
#define ISI_Y2R_SET1_C4_Pos   0
#define ISI_Y2R_SET1_C4_Msk   (0x1ffu << ISI_Y2R_SET1_C4_Pos)
 (ISI_Y2R_SET1) Color Space Conversion Matrix Coefficient C4
#define ISI_Y2R_SET1_C4(value)   ((ISI_Y2R_SET1_C4_Msk & ((value) << ISI_Y2R_SET1_C4_Pos)))
#define ISI_Y2R_SET1_Yoff   (0x1u << 12)
 (ISI_Y2R_SET1) Color Space Conversion Luminance Default Offset
#define ISI_Y2R_SET1_Croff   (0x1u << 13)
 (ISI_Y2R_SET1) Color Space Conversion Red Chrominance Default Offset
#define ISI_Y2R_SET1_Cboff   (0x1u << 14)
 (ISI_Y2R_SET1) Color Space Conversion Blue Chrominance Default Offset
#define ISI_R2Y_SET0_C0_Pos   0
#define ISI_R2Y_SET0_C0_Msk   (0x7fu << ISI_R2Y_SET0_C0_Pos)
 (ISI_R2Y_SET0) Color Space Conversion Matrix Coefficient C0
#define ISI_R2Y_SET0_C0(value)   ((ISI_R2Y_SET0_C0_Msk & ((value) << ISI_R2Y_SET0_C0_Pos)))
#define ISI_R2Y_SET0_C1_Pos   8
#define ISI_R2Y_SET0_C1_Msk   (0x7fu << ISI_R2Y_SET0_C1_Pos)
 (ISI_R2Y_SET0) Color Space Conversion Matrix Coefficient C1
#define ISI_R2Y_SET0_C1(value)   ((ISI_R2Y_SET0_C1_Msk & ((value) << ISI_R2Y_SET0_C1_Pos)))
#define ISI_R2Y_SET0_C2_Pos   16
#define ISI_R2Y_SET0_C2_Msk   (0x7fu << ISI_R2Y_SET0_C2_Pos)
 (ISI_R2Y_SET0) Color Space Conversion Matrix Coefficient C2
#define ISI_R2Y_SET0_C2(value)   ((ISI_R2Y_SET0_C2_Msk & ((value) << ISI_R2Y_SET0_C2_Pos)))
#define ISI_R2Y_SET0_Roff   (0x1u << 24)
 (ISI_R2Y_SET0) Color Space Conversion Red Component Offset
#define ISI_R2Y_SET1_C3_Pos   0
#define ISI_R2Y_SET1_C3_Msk   (0x7fu << ISI_R2Y_SET1_C3_Pos)
 (ISI_R2Y_SET1) Color Space Conversion Matrix Coefficient C3
#define ISI_R2Y_SET1_C3(value)   ((ISI_R2Y_SET1_C3_Msk & ((value) << ISI_R2Y_SET1_C3_Pos)))
#define ISI_R2Y_SET1_C4_Pos   8
#define ISI_R2Y_SET1_C4_Msk   (0x7fu << ISI_R2Y_SET1_C4_Pos)
 (ISI_R2Y_SET1) Color Space Conversion Matrix Coefficient C4
#define ISI_R2Y_SET1_C4(value)   ((ISI_R2Y_SET1_C4_Msk & ((value) << ISI_R2Y_SET1_C4_Pos)))
#define ISI_R2Y_SET1_C5_Pos   16
#define ISI_R2Y_SET1_C5_Msk   (0x7fu << ISI_R2Y_SET1_C5_Pos)
 (ISI_R2Y_SET1) Color Space Conversion Matrix Coefficient C5
#define ISI_R2Y_SET1_C5(value)   ((ISI_R2Y_SET1_C5_Msk & ((value) << ISI_R2Y_SET1_C5_Pos)))
#define ISI_R2Y_SET1_Goff   (0x1u << 24)
 (ISI_R2Y_SET1) Color Space Conversion Green Component Offset
#define ISI_R2Y_SET2_C6_Pos   0
#define ISI_R2Y_SET2_C6_Msk   (0x7fu << ISI_R2Y_SET2_C6_Pos)
 (ISI_R2Y_SET2) Color Space Conversion Matrix Coefficient C6
#define ISI_R2Y_SET2_C6(value)   ((ISI_R2Y_SET2_C6_Msk & ((value) << ISI_R2Y_SET2_C6_Pos)))
#define ISI_R2Y_SET2_C7_Pos   8
#define ISI_R2Y_SET2_C7_Msk   (0x7fu << ISI_R2Y_SET2_C7_Pos)
 (ISI_R2Y_SET2) Color Space Conversion Matrix Coefficient C7
#define ISI_R2Y_SET2_C7(value)   ((ISI_R2Y_SET2_C7_Msk & ((value) << ISI_R2Y_SET2_C7_Pos)))
#define ISI_R2Y_SET2_C8_Pos   16
#define ISI_R2Y_SET2_C8_Msk   (0x7fu << ISI_R2Y_SET2_C8_Pos)
 (ISI_R2Y_SET2) Color Space Conversion Matrix Coefficient C8
#define ISI_R2Y_SET2_C8(value)   ((ISI_R2Y_SET2_C8_Msk & ((value) << ISI_R2Y_SET2_C8_Pos)))
#define ISI_R2Y_SET2_Boff   (0x1u << 24)
 (ISI_R2Y_SET2) Color Space Conversion Blue Component Offset
#define ISI_CR_ISI_EN   (0x1u << 0)
 (ISI_CR) ISI Module Enable Request
#define ISI_CR_ISI_DIS   (0x1u << 1)
 (ISI_CR) ISI Module Disable Request
#define ISI_CR_ISI_SRST   (0x1u << 2)
 (ISI_CR) ISI Software Reset Request
#define ISI_CR_ISI_CDC   (0x1u << 8)
 (ISI_CR) ISI Codec Request
#define ISI_SR_ENABLE   (0x1u << 0)
 (ISI_SR) Module Enable
#define ISI_SR_DIS_DONE   (0x1u << 1)
 (ISI_SR) Module Disable Request has Terminated (cleared on read)
#define ISI_SR_SRST   (0x1u << 2)
 (ISI_SR) Module Software Reset Request has Terminated (cleared on read)
#define ISI_SR_CDC_PND   (0x1u << 8)
 (ISI_SR) Pending Codec Request
#define ISI_SR_VSYNC   (0x1u << 10)
 (ISI_SR) Vertical Synchronization (cleared on read)
#define ISI_SR_PXFR_DONE   (0x1u << 16)
 (ISI_SR) Preview DMA Transfer has Terminated (cleared on read)
#define ISI_SR_CXFR_DONE   (0x1u << 17)
 (ISI_SR) Codec DMA Transfer has Terminated (cleared on read)
#define ISI_SR_SIP   (0x1u << 19)
 (ISI_SR) Synchronization in Progress
#define ISI_SR_P_OVR   (0x1u << 24)
 (ISI_SR) Preview Datapath Overflow (cleared on read)
#define ISI_SR_C_OVR   (0x1u << 25)
 (ISI_SR) Codec Datapath Overflow (cleared on read)
#define ISI_SR_CRC_ERR   (0x1u << 26)
 (ISI_SR) CRC Synchronization Error (cleared on read)
#define ISI_SR_FR_OVR   (0x1u << 27)
 (ISI_SR) Frame Rate Overrun (cleared on read)
#define ISI_IER_DIS_DONE   (0x1u << 1)
 (ISI_IER) Disable Done Interrupt Enable
#define ISI_IER_SRST   (0x1u << 2)
 (ISI_IER) Software Reset Interrupt Enable
#define ISI_IER_VSYNC   (0x1u << 10)
 (ISI_IER) Vertical Synchronization Interrupt Enable
#define ISI_IER_PXFR_DONE   (0x1u << 16)
 (ISI_IER) Preview DMA Transfer Done Interrupt Enable
#define ISI_IER_CXFR_DONE   (0x1u << 17)
 (ISI_IER) Codec DMA Transfer Done Interrupt Enable
#define ISI_IER_P_OVR   (0x1u << 24)
 (ISI_IER) Preview Datapath Overflow Interrupt Enable
#define ISI_IER_C_OVR   (0x1u << 25)
 (ISI_IER) Codec Datapath Overflow Interrupt Enable
#define ISI_IER_CRC_ERR   (0x1u << 26)
 (ISI_IER) Embedded Synchronization CRC Error Interrupt Enable
#define ISI_IER_FR_OVR   (0x1u << 27)
 (ISI_IER) Frame Rate Overflow Interrupt Enable
#define ISI_IDR_DIS_DONE   (0x1u << 1)
 (ISI_IDR) Disable Done Interrupt Disable
#define ISI_IDR_SRST   (0x1u << 2)
 (ISI_IDR) Software Reset Interrupt Disable
#define ISI_IDR_VSYNC   (0x1u << 10)
 (ISI_IDR) Vertical Synchronization Interrupt Disable
#define ISI_IDR_PXFR_DONE   (0x1u << 16)
 (ISI_IDR) Preview DMA Transfer Done Interrupt Disable
#define ISI_IDR_CXFR_DONE   (0x1u << 17)
 (ISI_IDR) Codec DMA Transfer Done Interrupt Disable
#define ISI_IDR_P_OVR   (0x1u << 24)
 (ISI_IDR) Preview Datapath Overflow Interrupt Disable
#define ISI_IDR_C_OVR   (0x1u << 25)
 (ISI_IDR) Codec Datapath Overflow Interrupt Disable
#define ISI_IDR_CRC_ERR   (0x1u << 26)
 (ISI_IDR) Embedded Synchronization CRC Error Interrupt Disable
#define ISI_IDR_FR_OVR   (0x1u << 27)
 (ISI_IDR) Frame Rate Overflow Interrupt Disable
#define ISI_IMR_DIS_DONE   (0x1u << 1)
 (ISI_IMR) Module Disable Operation Completed
#define ISI_IMR_SRST   (0x1u << 2)
 (ISI_IMR) Software Reset Completed
#define ISI_IMR_VSYNC   (0x1u << 10)
 (ISI_IMR) Vertical Synchronization
#define ISI_IMR_PXFR_DONE   (0x1u << 16)
 (ISI_IMR) Preview DMA Transfer Completed
#define ISI_IMR_CXFR_DONE   (0x1u << 17)
 (ISI_IMR) Codec DMA Transfer Completed
#define ISI_IMR_P_OVR   (0x1u << 24)
 (ISI_IMR) Preview FIFO Overflow
#define ISI_IMR_C_OVR   (0x1u << 25)
 (ISI_IMR) Codec FIFO Overflow
#define ISI_IMR_CRC_ERR   (0x1u << 26)
 (ISI_IMR) CRC Synchronization Error
#define ISI_IMR_FR_OVR   (0x1u << 27)
 (ISI_IMR) Frame Rate Overrun
#define ISI_DMA_CHER_P_CH_EN   (0x1u << 0)
 (ISI_DMA_CHER) Preview Channel Enable
#define ISI_DMA_CHER_C_CH_EN   (0x1u << 1)
 (ISI_DMA_CHER) Codec Channel Enable
#define ISI_DMA_CHDR_P_CH_DIS   (0x1u << 0)
 (ISI_DMA_CHDR) Preview Channel Disable Request
#define ISI_DMA_CHDR_C_CH_DIS   (0x1u << 1)
 (ISI_DMA_CHDR) Codec Channel Disable Request
#define ISI_DMA_CHSR_P_CH_S   (0x1u << 0)
 (ISI_DMA_CHSR) Preview DMA Channel Status
#define ISI_DMA_CHSR_C_CH_S   (0x1u << 1)
 (ISI_DMA_CHSR) Code DMA Channel Status
#define ISI_DMA_P_ADDR_P_ADDR_Pos   2
#define ISI_DMA_P_ADDR_P_ADDR_Msk   (0x3fffffffu << ISI_DMA_P_ADDR_P_ADDR_Pos)
 (ISI_DMA_P_ADDR) Preview Image Base Address
#define ISI_DMA_P_ADDR_P_ADDR(value)   ((ISI_DMA_P_ADDR_P_ADDR_Msk & ((value) << ISI_DMA_P_ADDR_P_ADDR_Pos)))
#define ISI_DMA_P_CTRL_P_FETCH   (0x1u << 0)
 (ISI_DMA_P_CTRL) Descriptor Fetch Control Bit
#define ISI_DMA_P_CTRL_P_WB   (0x1u << 1)
 (ISI_DMA_P_CTRL) Descriptor Writeback Control Bit
#define ISI_DMA_P_CTRL_P_IEN   (0x1u << 2)
 (ISI_DMA_P_CTRL) Transfer Done Flag Control
#define ISI_DMA_P_CTRL_P_DONE   (0x1u << 3)
 (ISI_DMA_P_CTRL) Preview Transfer Done
#define ISI_DMA_P_DSCR_P_DSCR_Pos   2
#define ISI_DMA_P_DSCR_P_DSCR_Msk   (0x3fffffffu << ISI_DMA_P_DSCR_P_DSCR_Pos)
 (ISI_DMA_P_DSCR) Preview Descriptor Base Address
#define ISI_DMA_P_DSCR_P_DSCR(value)   ((ISI_DMA_P_DSCR_P_DSCR_Msk & ((value) << ISI_DMA_P_DSCR_P_DSCR_Pos)))
#define ISI_DMA_C_ADDR_C_ADDR_Pos   2
#define ISI_DMA_C_ADDR_C_ADDR_Msk   (0x3fffffffu << ISI_DMA_C_ADDR_C_ADDR_Pos)
 (ISI_DMA_C_ADDR) Codec Image Base Address
#define ISI_DMA_C_ADDR_C_ADDR(value)   ((ISI_DMA_C_ADDR_C_ADDR_Msk & ((value) << ISI_DMA_C_ADDR_C_ADDR_Pos)))
#define ISI_DMA_C_CTRL_C_FETCH   (0x1u << 0)
 (ISI_DMA_C_CTRL) Descriptor Fetch Control Bit
#define ISI_DMA_C_CTRL_C_WB   (0x1u << 1)
 (ISI_DMA_C_CTRL) Descriptor Writeback Control Bit
#define ISI_DMA_C_CTRL_C_IEN   (0x1u << 2)
 (ISI_DMA_C_CTRL) Transfer Done Flag Control
#define ISI_DMA_C_CTRL_C_DONE   (0x1u << 3)
 (ISI_DMA_C_CTRL) Codec Transfer Done
#define ISI_DMA_C_DSCR_C_DSCR_Pos   2
#define ISI_DMA_C_DSCR_C_DSCR_Msk   (0x3fffffffu << ISI_DMA_C_DSCR_C_DSCR_Pos)
 (ISI_DMA_C_DSCR) Codec Descriptor Base Address
#define ISI_DMA_C_DSCR_C_DSCR(value)   ((ISI_DMA_C_DSCR_C_DSCR_Msk & ((value) << ISI_DMA_C_DSCR_C_DSCR_Pos)))
#define ISI_WPMR_WPEN   (0x1u << 0)
 (ISI_WPMR) Write Protection Enable
#define ISI_WPMR_WPKEY_Pos   8
#define ISI_WPMR_WPKEY_Msk   (0xffffffu << ISI_WPMR_WPKEY_Pos)
 (ISI_WPMR) Write Protection Key Password
#define ISI_WPMR_WPKEY(value)   ((ISI_WPMR_WPKEY_Msk & ((value) << ISI_WPMR_WPKEY_Pos)))
#define ISI_WPMR_WPKEY_PASSWD   (0x495349u << 8)
 (ISI_WPMR) Writing any other value in this field aborts the write operation of the WPEN bit.Always reads as 0.
#define ISI_WPSR_WPVS   (0x1u << 0)
 (ISI_WPSR) Write Protection Violation Status
#define ISI_WPSR_WPVSRC_Pos   8
#define ISI_WPSR_WPVSRC_Msk   (0xffffu << ISI_WPSR_WPVSRC_Pos)
 (ISI_WPSR) Write Protection Violation Source
#define ISI_VERSION_VERSION_Pos   0
#define ISI_VERSION_VERSION_Msk   (0xfffu << ISI_VERSION_VERSION_Pos)
 (ISI_VERSION) Version of the Hardware Module
#define ISI_VERSION_MFN_Pos   16
#define ISI_VERSION_MFN_Msk   (0x7u << ISI_VERSION_MFN_Pos)
 (ISI_VERSION) Metal Fix Number
SOFTWARE API DEFINITION FOR Image Sensor Interface
