RTEMS  5.1
component_aes.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAMV71_AES_COMPONENT_
31 #define _SAMV71_AES_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __O uint32_t AES_CR;
43  __IO uint32_t AES_MR;
44  __I uint32_t Reserved1[2];
45  __O uint32_t AES_IER;
46  __O uint32_t AES_IDR;
47  __I uint32_t AES_IMR;
48  __I uint32_t AES_ISR;
49  __O uint32_t AES_KEYWR[8];
50  __O uint32_t AES_IDATAR[4];
51  __I uint32_t AES_ODATAR[4];
52  __O uint32_t AES_IVR[4];
53  __IO uint32_t AES_AADLENR;
54  __IO uint32_t AES_CLENR;
55  __IO uint32_t AES_GHASHR[4];
56  __I uint32_t AES_TAGR[4];
57  __I uint32_t AES_CTRR;
58  __IO uint32_t AES_GCMHR[4];
59  __I uint32_t Reserved2[20];
60  __I uint32_t AES_VERSION;
61 } Aes;
62 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
63 /* -------- AES_CR : (AES Offset: 0x00) Control Register -------- */
64 #define AES_CR_START (0x1u << 0)
65 #define AES_CR_SWRST (0x1u << 8)
66 #define AES_CR_LOADSEED (0x1u << 16)
67 /* -------- AES_MR : (AES Offset: 0x04) Mode Register -------- */
68 #define AES_MR_CIPHER (0x1u << 0)
69 #define AES_MR_GTAGEN (0x1u << 1)
70 #define AES_MR_DUALBUFF (0x1u << 3)
71 #define AES_MR_DUALBUFF_INACTIVE (0x0u << 3)
72 #define AES_MR_DUALBUFF_ACTIVE (0x1u << 3)
73 #define AES_MR_PROCDLY_Pos 4
74 #define AES_MR_PROCDLY_Msk (0xfu << AES_MR_PROCDLY_Pos)
75 #define AES_MR_PROCDLY(value) ((AES_MR_PROCDLY_Msk & ((value) << AES_MR_PROCDLY_Pos)))
76 #define AES_MR_SMOD_Pos 8
77 #define AES_MR_SMOD_Msk (0x3u << AES_MR_SMOD_Pos)
78 #define AES_MR_SMOD(value) ((AES_MR_SMOD_Msk & ((value) << AES_MR_SMOD_Pos)))
79 #define AES_MR_SMOD_MANUAL_START (0x0u << 8)
80 #define AES_MR_SMOD_AUTO_START (0x1u << 8)
81 #define AES_MR_SMOD_IDATAR0_START (0x2u << 8)
82 #define AES_MR_KEYSIZE_Pos 10
83 #define AES_MR_KEYSIZE_Msk (0x3u << AES_MR_KEYSIZE_Pos)
84 #define AES_MR_KEYSIZE(value) ((AES_MR_KEYSIZE_Msk & ((value) << AES_MR_KEYSIZE_Pos)))
85 #define AES_MR_KEYSIZE_AES128 (0x0u << 10)
86 #define AES_MR_KEYSIZE_AES192 (0x1u << 10)
87 #define AES_MR_KEYSIZE_AES256 (0x2u << 10)
88 #define AES_MR_OPMOD_Pos 12
89 #define AES_MR_OPMOD_Msk (0x7u << AES_MR_OPMOD_Pos)
90 #define AES_MR_OPMOD(value) ((AES_MR_OPMOD_Msk & ((value) << AES_MR_OPMOD_Pos)))
91 #define AES_MR_OPMOD_ECB (0x0u << 12)
92 #define AES_MR_OPMOD_CBC (0x1u << 12)
93 #define AES_MR_OPMOD_OFB (0x2u << 12)
94 #define AES_MR_OPMOD_CFB (0x3u << 12)
95 #define AES_MR_OPMOD_CTR (0x4u << 12)
96 #define AES_MR_OPMOD_GCM (0x5u << 12)
97 #define AES_MR_LOD (0x1u << 15)
98 #define AES_MR_CFBS_Pos 16
99 #define AES_MR_CFBS_Msk (0x7u << AES_MR_CFBS_Pos)
100 #define AES_MR_CFBS(value) ((AES_MR_CFBS_Msk & ((value) << AES_MR_CFBS_Pos)))
101 #define AES_MR_CFBS_SIZE_128BIT (0x0u << 16)
102 #define AES_MR_CFBS_SIZE_64BIT (0x1u << 16)
103 #define AES_MR_CFBS_SIZE_32BIT (0x2u << 16)
104 #define AES_MR_CFBS_SIZE_16BIT (0x3u << 16)
105 #define AES_MR_CFBS_SIZE_8BIT (0x4u << 16)
106 #define AES_MR_CKEY_Pos 20
107 #define AES_MR_CKEY_Msk (0xfu << AES_MR_CKEY_Pos)
108 #define AES_MR_CKEY(value) ((AES_MR_CKEY_Msk & ((value) << AES_MR_CKEY_Pos)))
109 #define AES_MR_CKEY_PASSWD (0xEu << 20)
110 #define AES_MR_CMTYP1 (0x1u << 24)
111 #define AES_MR_CMTYP1_NOPROT_EXTKEY (0x0u << 24)
112 #define AES_MR_CMTYP1_PROT_EXTKEY (0x1u << 24)
113 #define AES_MR_CMTYP2 (0x1u << 25)
114 #define AES_MR_CMTYP2_NO_PAUSE (0x0u << 25)
115 #define AES_MR_CMTYP2_PAUSE (0x1u << 25)
116 #define AES_MR_CMTYP3 (0x1u << 26)
117 #define AES_MR_CMTYP3_NO_DUMMY (0x0u << 26)
118 #define AES_MR_CMTYP3_DUMMY (0x1u << 26)
119 #define AES_MR_CMTYP4 (0x1u << 27)
120 #define AES_MR_CMTYP4_NO_RESTART (0x0u << 27)
121 #define AES_MR_CMTYP4_RESTART (0x1u << 27)
122 #define AES_MR_CMTYP5 (0x1u << 28)
123 #define AES_MR_CMTYP5_NO_ADDACCESS (0x0u << 28)
124 #define AES_MR_CMTYP5_ADDACCESS (0x1u << 28)
125 #define AES_MR_CMTYP6 (0x1u << 29)
126 #define AES_MR_CMTYP6_NO_IDLECURRENT (0x0u << 29)
127 #define AES_MR_CMTYP6_IDLECURRENT (0x1u << 29)
128 /* -------- AES_IER : (AES Offset: 0x10) Interrupt Enable Register -------- */
129 #define AES_IER_DATRDY (0x1u << 0)
130 #define AES_IER_URAD (0x1u << 8)
131 #define AES_IER_TAGRDY (0x1u << 16)
132 /* -------- AES_IDR : (AES Offset: 0x14) Interrupt Disable Register -------- */
133 #define AES_IDR_DATRDY (0x1u << 0)
134 #define AES_IDR_URAD (0x1u << 8)
135 #define AES_IDR_TAGRDY (0x1u << 16)
136 /* -------- AES_IMR : (AES Offset: 0x18) Interrupt Mask Register -------- */
137 #define AES_IMR_DATRDY (0x1u << 0)
138 #define AES_IMR_URAD (0x1u << 8)
139 #define AES_IMR_TAGRDY (0x1u << 16)
140 /* -------- AES_ISR : (AES Offset: 0x1C) Interrupt Status Register -------- */
141 #define AES_ISR_DATRDY (0x1u << 0)
142 #define AES_ISR_URAD (0x1u << 8)
143 #define AES_ISR_URAT_Pos 12
144 #define AES_ISR_URAT_Msk (0xfu << AES_ISR_URAT_Pos)
145 #define AES_ISR_URAT_IDR_WR_PROCESSING (0x0u << 12)
146 #define AES_ISR_URAT_ODR_RD_PROCESSING (0x1u << 12)
147 #define AES_ISR_URAT_MR_WR_PROCESSING (0x2u << 12)
148 #define AES_ISR_URAT_ODR_RD_SUBKGEN (0x3u << 12)
149 #define AES_ISR_URAT_MR_WR_SUBKGEN (0x4u << 12)
150 #define AES_ISR_URAT_WOR_RD_ACCESS (0x5u << 12)
151 #define AES_ISR_TAGRDY (0x1u << 16)
152 /* -------- AES_KEYWR[8] : (AES Offset: 0x20) Key Word Register -------- */
153 #define AES_KEYWR_KEYW_Pos 0
154 #define AES_KEYWR_KEYW_Msk (0xffffffffu << AES_KEYWR_KEYW_Pos)
155 #define AES_KEYWR_KEYW(value) ((AES_KEYWR_KEYW_Msk & ((value) << AES_KEYWR_KEYW_Pos)))
156 /* -------- AES_IDATAR[4] : (AES Offset: 0x40) Input Data Register -------- */
157 #define AES_IDATAR_IDATA_Pos 0
158 #define AES_IDATAR_IDATA_Msk (0xffffffffu << AES_IDATAR_IDATA_Pos)
159 #define AES_IDATAR_IDATA(value) ((AES_IDATAR_IDATA_Msk & ((value) << AES_IDATAR_IDATA_Pos)))
160 /* -------- AES_ODATAR[4] : (AES Offset: 0x50) Output Data Register -------- */
161 #define AES_ODATAR_ODATA_Pos 0
162 #define AES_ODATAR_ODATA_Msk (0xffffffffu << AES_ODATAR_ODATA_Pos)
163 /* -------- AES_IVR[4] : (AES Offset: 0x60) Initialization Vector Register -------- */
164 #define AES_IVR_IV_Pos 0
165 #define AES_IVR_IV_Msk (0xffffffffu << AES_IVR_IV_Pos)
166 #define AES_IVR_IV(value) ((AES_IVR_IV_Msk & ((value) << AES_IVR_IV_Pos)))
167 /* -------- AES_AADLENR : (AES Offset: 0x70) Additional Authenticated Data Length Register -------- */
168 #define AES_AADLENR_AADLEN_Pos 0
169 #define AES_AADLENR_AADLEN_Msk (0xffffffffu << AES_AADLENR_AADLEN_Pos)
170 #define AES_AADLENR_AADLEN(value) ((AES_AADLENR_AADLEN_Msk & ((value) << AES_AADLENR_AADLEN_Pos)))
171 /* -------- AES_CLENR : (AES Offset: 0x74) Plaintext/Ciphertext Length Register -------- */
172 #define AES_CLENR_CLEN_Pos 0
173 #define AES_CLENR_CLEN_Msk (0xffffffffu << AES_CLENR_CLEN_Pos)
174 #define AES_CLENR_CLEN(value) ((AES_CLENR_CLEN_Msk & ((value) << AES_CLENR_CLEN_Pos)))
175 /* -------- AES_GHASHR[4] : (AES Offset: 0x78) GCM Intermediate Hash Word Register -------- */
176 #define AES_GHASHR_GHASH_Pos 0
177 #define AES_GHASHR_GHASH_Msk (0xffffffffu << AES_GHASHR_GHASH_Pos)
178 #define AES_GHASHR_GHASH(value) ((AES_GHASHR_GHASH_Msk & ((value) << AES_GHASHR_GHASH_Pos)))
179 /* -------- AES_TAGR[4] : (AES Offset: 0x88) GCM Authentication Tag Word Register -------- */
180 #define AES_TAGR_TAG_Pos 0
181 #define AES_TAGR_TAG_Msk (0xffffffffu << AES_TAGR_TAG_Pos)
182 /* -------- AES_CTRR : (AES Offset: 0x98) GCM Encryption Counter Value Register -------- */
183 #define AES_CTRR_CTR_Pos 0
184 #define AES_CTRR_CTR_Msk (0xffffffffu << AES_CTRR_CTR_Pos)
185 /* -------- AES_GCMHR[4] : (AES Offset: 0x9C) GCM H Word Register -------- */
186 #define AES_GCMHR_H_Pos 0
187 #define AES_GCMHR_H_Msk (0xffffffffu << AES_GCMHR_H_Pos)
188 #define AES_GCMHR_H(value) ((AES_GCMHR_H_Msk & ((value) << AES_GCMHR_H_Pos)))
189 /* -------- AES_VERSION : (AES Offset: 0xFC) Version Register -------- */
190 #define AES_VERSION_VERSION_Pos 0
191 #define AES_VERSION_VERSION_Msk (0xfffu << AES_VERSION_VERSION_Pos)
192 #define AES_VERSION_MFN_Pos 16
193 #define AES_VERSION_MFN_Msk (0x7u << AES_VERSION_MFN_Pos)
196
197
198 #endif /* _SAMV71_AES_COMPONENT_ */
#define __IO
Definition: core_cm7.h:287
#define __O
Definition: core_cm7.h:286
Aes hardware registers.
Definition: component_aes.h:41
(Aes Offset: 0xFC) Version Register
Definition: component_aes.h:60
#define __I
Definition: core_cm7.h:284
