RTEMS  5.1
Data Structures | Macros
struct  Aes
 Aes hardware registers. More...
#define AES_CR_START   (0x1u << 0)
 (AES_CR) Start Processing
#define AES_CR_SWRST   (0x1u << 8)
 (AES_CR) Software Reset
#define AES_CR_LOADSEED   (0x1u << 16)
 (AES_CR) Random Number Generator Seed Loading
#define AES_MR_CIPHER   (0x1u << 0)
 (AES_MR) Processing Mode
#define AES_MR_GTAGEN   (0x1u << 1)
 (AES_MR) GCM Automatic Tag Generation Enable
#define AES_MR_DUALBUFF   (0x1u << 3)
 (AES_MR) Dual Input Buffer
#define AES_MR_DUALBUFF_INACTIVE   (0x0u << 3)
 (AES_MR) AES_IDATARx cannot be written during processing of previous block.
#define AES_MR_DUALBUFF_ACTIVE   (0x1u << 3)
 (AES_MR) AES_IDATARx can be written during processing of previous block when SMOD = 2. It speeds up the overall runtime of large files.
#define AES_MR_PROCDLY_Pos   4
#define AES_MR_PROCDLY_Msk   (0xfu << AES_MR_PROCDLY_Pos)
 (AES_MR) Processing Delay
#define AES_MR_PROCDLY(value)   ((AES_MR_PROCDLY_Msk & ((value) << AES_MR_PROCDLY_Pos)))
#define AES_MR_SMOD_Pos   8
#define AES_MR_SMOD_Msk   (0x3u << AES_MR_SMOD_Pos)
 (AES_MR) Start Mode
#define AES_MR_SMOD(value)   ((AES_MR_SMOD_Msk & ((value) << AES_MR_SMOD_Pos)))
#define AES_MR_SMOD_MANUAL_START   (0x0u << 8)
 (AES_MR) Manual Mode
#define AES_MR_SMOD_AUTO_START   (0x1u << 8)
 (AES_MR) Auto Mode
#define AES_MR_SMOD_IDATAR0_START   (0x2u << 8)
 (AES_MR) AES_IDATAR0 access only Auto Mode (DMA)
#define AES_MR_KEYSIZE_Pos   10
#define AES_MR_KEYSIZE_Msk   (0x3u << AES_MR_KEYSIZE_Pos)
 (AES_MR) Key Size
#define AES_MR_KEYSIZE(value)   ((AES_MR_KEYSIZE_Msk & ((value) << AES_MR_KEYSIZE_Pos)))
#define AES_MR_KEYSIZE_AES128   (0x0u << 10)
 (AES_MR) AES Key Size is 128 bits
#define AES_MR_KEYSIZE_AES192   (0x1u << 10)
 (AES_MR) AES Key Size is 192 bits
#define AES_MR_KEYSIZE_AES256   (0x2u << 10)
 (AES_MR) AES Key Size is 256 bits
#define AES_MR_OPMOD_Pos   12
#define AES_MR_OPMOD_Msk   (0x7u << AES_MR_OPMOD_Pos)
 (AES_MR) Operation Mode
#define AES_MR_OPMOD(value)   ((AES_MR_OPMOD_Msk & ((value) << AES_MR_OPMOD_Pos)))
#define AES_MR_OPMOD_ECB   (0x0u << 12)
 (AES_MR) ECB: Electronic Code Book mode
#define AES_MR_OPMOD_CBC   (0x1u << 12)
 (AES_MR) CBC: Cipher Block Chaining mode
#define AES_MR_OPMOD_OFB   (0x2u << 12)
 (AES_MR) OFB: Output Feedback mode
#define AES_MR_OPMOD_CFB   (0x3u << 12)
 (AES_MR) CFB: Cipher Feedback mode
#define AES_MR_OPMOD_CTR   (0x4u << 12)
 (AES_MR) CTR: Counter mode (16-bit internal counter)
#define AES_MR_OPMOD_GCM   (0x5u << 12)
 (AES_MR) GCM: Galois/Counter mode
#define AES_MR_LOD   (0x1u << 15)
 (AES_MR) Last Output Data Mode
#define AES_MR_CFBS_Pos   16
#define AES_MR_CFBS_Msk   (0x7u << AES_MR_CFBS_Pos)
 (AES_MR) Cipher Feedback Data Size
#define AES_MR_CFBS(value)   ((AES_MR_CFBS_Msk & ((value) << AES_MR_CFBS_Pos)))
#define AES_MR_CFBS_SIZE_128BIT   (0x0u << 16)
 (AES_MR) 128-bit
#define AES_MR_CFBS_SIZE_64BIT   (0x1u << 16)
 (AES_MR) 64-bit
#define AES_MR_CFBS_SIZE_32BIT   (0x2u << 16)
 (AES_MR) 32-bit
#define AES_MR_CFBS_SIZE_16BIT   (0x3u << 16)
 (AES_MR) 16-bit
#define AES_MR_CFBS_SIZE_8BIT   (0x4u << 16)
 (AES_MR) 8-bit
#define AES_MR_CKEY_Pos   20
#define AES_MR_CKEY_Msk   (0xfu << AES_MR_CKEY_Pos)
 (AES_MR) Countermeasure Key
#define AES_MR_CKEY(value)   ((AES_MR_CKEY_Msk & ((value) << AES_MR_CKEY_Pos)))
#define AES_MR_CKEY_PASSWD   (0xEu << 20)
 (AES_MR) This field must be written with 0xE to allow CMTYPx bit configuration changes. Any other values will abort the write operation in CMTYPx bits.Always reads as 0.
#define AES_MR_CMTYP1   (0x1u << 24)
 (AES_MR) Countermeasure Type 1
#define AES_MR_CMTYP1_NOPROT_EXTKEY   (0x0u << 24)
 (AES_MR) Countermeasure type 1 is disabled.
#define AES_MR_CMTYP1_PROT_EXTKEY   (0x1u << 24)
 (AES_MR) Countermeasure type 1 is enabled.
#define AES_MR_CMTYP2   (0x1u << 25)
 (AES_MR) Countermeasure Type 2
#define AES_MR_CMTYP2_NO_PAUSE   (0x0u << 25)
 (AES_MR) Countermeasure type 2 is disabled.
#define AES_MR_CMTYP2_PAUSE   (0x1u << 25)
 (AES_MR) Countermeasure type 2 is enabled.
#define AES_MR_CMTYP3   (0x1u << 26)
 (AES_MR) Countermeasure Type 3
#define AES_MR_CMTYP3_NO_DUMMY   (0x0u << 26)
 (AES_MR) Countermeasure type 3 is disabled.
#define AES_MR_CMTYP3_DUMMY   (0x1u << 26)
 (AES_MR) Countermeasure type 3 is enabled.
#define AES_MR_CMTYP4   (0x1u << 27)
 (AES_MR) Countermeasure Type 4
#define AES_MR_CMTYP4_NO_RESTART   (0x0u << 27)
 (AES_MR) Countermeasure type 4 is disabled.
#define AES_MR_CMTYP4_RESTART   (0x1u << 27)
 (AES_MR) Countermeasure type 4 is enabled.
#define AES_MR_CMTYP5   (0x1u << 28)
 (AES_MR) Countermeasure Type 5
#define AES_MR_CMTYP5_NO_ADDACCESS   (0x0u << 28)
 (AES_MR) Countermeasure type 5 is disabled.
#define AES_MR_CMTYP5_ADDACCESS   (0x1u << 28)
 (AES_MR) Countermeasure type 5 is enabled.
#define AES_MR_CMTYP6   (0x1u << 29)
 (AES_MR) Countermeasure Type 6
#define AES_MR_CMTYP6_NO_IDLECURRENT   (0x0u << 29)
 (AES_MR) Countermeasure type 6 is disabled.
#define AES_MR_CMTYP6_IDLECURRENT   (0x1u << 29)
 (AES_MR) Countermeasure type 6 is enabled.
#define AES_IER_DATRDY   (0x1u << 0)
 (AES_IER) Data Ready Interrupt Enable
#define AES_IER_URAD   (0x1u << 8)
 (AES_IER) Unspecified Register Access Detection Interrupt Enable
#define AES_IER_TAGRDY   (0x1u << 16)
 (AES_IER) GCM Tag Ready Interrupt Enable
#define AES_IDR_DATRDY   (0x1u << 0)
 (AES_IDR) Data Ready Interrupt Disable
#define AES_IDR_URAD   (0x1u << 8)
 (AES_IDR) Unspecified Register Access Detection Interrupt Disable
#define AES_IDR_TAGRDY   (0x1u << 16)
 (AES_IDR) GCM Tag Ready Interrupt Disable
#define AES_IMR_DATRDY   (0x1u << 0)
 (AES_IMR) Data Ready Interrupt Mask
#define AES_IMR_URAD   (0x1u << 8)
 (AES_IMR) Unspecified Register Access Detection Interrupt Mask
#define AES_IMR_TAGRDY   (0x1u << 16)
 (AES_IMR) GCM Tag Ready Interrupt Mask
#define AES_ISR_DATRDY   (0x1u << 0)
 (AES_ISR) Data Ready (cleared by setting bit START or bit SWRST in AES_CR or by reading AES_ODATARx)
#define AES_ISR_URAD   (0x1u << 8)
 (AES_ISR) Unspecified Register Access Detection Status (cleared by writing SWRST in AES_CR)
#define AES_ISR_URAT_Pos   12
#define AES_ISR_URAT_Msk   (0xfu << AES_ISR_URAT_Pos)
 (AES_ISR) Unspecified Register Access (cleared by writing SWRST in AES_CR)
#define AES_ISR_URAT_IDR_WR_PROCESSING   (0x0u << 12)
 (AES_ISR) Input Data Register written during the data processing when SMOD = 0x2 mode.
#define AES_ISR_URAT_ODR_RD_PROCESSING   (0x1u << 12)
 (AES_ISR) Output Data Register read during the data processing.
#define AES_ISR_URAT_MR_WR_PROCESSING   (0x2u << 12)
 (AES_ISR) Mode Register written during the data processing.
#define AES_ISR_URAT_ODR_RD_SUBKGEN   (0x3u << 12)
 (AES_ISR) Output Data Register read during the sub-keys generation.
#define AES_ISR_URAT_MR_WR_SUBKGEN   (0x4u << 12)
 (AES_ISR) Mode Register written during the sub-keys generation.
#define AES_ISR_URAT_WOR_RD_ACCESS   (0x5u << 12)
 (AES_ISR) Write-only register read access.
#define AES_ISR_TAGRDY   (0x1u << 16)
 (AES_ISR) GCM Tag Ready
#define AES_KEYWR_KEYW_Pos   0
#define AES_KEYWR_KEYW_Msk   (0xffffffffu << AES_KEYWR_KEYW_Pos)
 (AES_KEYWR[8]) Key Word
#define AES_KEYWR_KEYW(value)   ((AES_KEYWR_KEYW_Msk & ((value) << AES_KEYWR_KEYW_Pos)))
#define AES_IDATAR_IDATA_Pos   0
#define AES_IDATAR_IDATA_Msk   (0xffffffffu << AES_IDATAR_IDATA_Pos)
 (AES_IDATAR[4]) Input Data Word
#define AES_IDATAR_IDATA(value)   ((AES_IDATAR_IDATA_Msk & ((value) << AES_IDATAR_IDATA_Pos)))
#define AES_ODATAR_ODATA_Pos   0
#define AES_ODATAR_ODATA_Msk   (0xffffffffu << AES_ODATAR_ODATA_Pos)
 (AES_ODATAR[4]) Output Data
#define AES_IVR_IV_Pos   0
#define AES_IVR_IV_Msk   (0xffffffffu << AES_IVR_IV_Pos)
 (AES_IVR[4]) Initialization Vector
#define AES_IVR_IV(value)   ((AES_IVR_IV_Msk & ((value) << AES_IVR_IV_Pos)))
#define AES_AADLENR_AADLEN_Pos   0
#define AES_AADLENR_AADLEN_Msk   (0xffffffffu << AES_AADLENR_AADLEN_Pos)
 (AES_AADLENR) Additional Authenticated Data Length
#define AES_AADLENR_AADLEN(value)   ((AES_AADLENR_AADLEN_Msk & ((value) << AES_AADLENR_AADLEN_Pos)))
#define AES_CLENR_CLEN_Pos   0
#define AES_CLENR_CLEN_Msk   (0xffffffffu << AES_CLENR_CLEN_Pos)
 (AES_CLENR) Plaintext/Ciphertext Length
#define AES_CLENR_CLEN(value)   ((AES_CLENR_CLEN_Msk & ((value) << AES_CLENR_CLEN_Pos)))
#define AES_GHASHR_GHASH_Pos   0
#define AES_GHASHR_GHASH_Msk   (0xffffffffu << AES_GHASHR_GHASH_Pos)
 (AES_GHASHR[4]) Intermediate GCM Hash Word x
#define AES_GHASHR_GHASH(value)   ((AES_GHASHR_GHASH_Msk & ((value) << AES_GHASHR_GHASH_Pos)))
#define AES_TAGR_TAG_Pos   0
#define AES_TAGR_TAG_Msk   (0xffffffffu << AES_TAGR_TAG_Pos)
 (AES_TAGR[4]) GCM Authentication Tag x
#define AES_CTRR_CTR_Pos   0
#define AES_CTRR_CTR_Msk   (0xffffffffu << AES_CTRR_CTR_Pos)
 (AES_CTRR) GCM Encryption Counter
#define AES_GCMHR_H_Pos   0
#define AES_GCMHR_H_Msk   (0xffffffffu << AES_GCMHR_H_Pos)
 (AES_GCMHR[4]) GCM H Word x
#define AES_GCMHR_H(value)   ((AES_GCMHR_H_Msk & ((value) << AES_GCMHR_H_Pos)))
#define AES_VERSION_VERSION_Pos   0
#define AES_VERSION_VERSION_Msk   (0xfffu << AES_VERSION_VERSION_Pos)
 (AES_VERSION) Version of the Hardware Module
#define AES_VERSION_MFN_Pos   16
#define AES_VERSION_MFN_Msk   (0x7u << AES_VERSION_MFN_Pos)
 (AES_VERSION) Metal Fix Number
SOFTWARE API DEFINITION FOR Advanced Encryption Standard
