RTEMS  5.1
component_twihs.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAMS70_TWIHS_COMPONENT_
31 #define _SAMS70_TWIHS_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __O uint32_t TWIHS_CR;
43  __IO uint32_t TWIHS_MMR;
44  __IO uint32_t TWIHS_SMR;
45  __IO uint32_t TWIHS_IADR;
46  __IO uint32_t TWIHS_CWGR;
47  __I uint32_t Reserved1[3];
48  __I uint32_t TWIHS_SR;
49  __O uint32_t TWIHS_IER;
50  __O uint32_t TWIHS_IDR;
51  __I uint32_t TWIHS_IMR;
52  __I uint32_t TWIHS_RHR;
53  __O uint32_t TWIHS_THR;
54  __IO uint32_t TWIHS_SMBTR;
55  __I uint32_t Reserved2[2];
56  __IO uint32_t TWIHS_FILTR;
57  __I uint32_t Reserved3[1];
58  __IO uint32_t TWIHS_SWMR;
59  __I uint32_t Reserved4[37];
60  __IO uint32_t TWIHS_WPMR;
61  __I uint32_t TWIHS_WPSR;
62 } Twihs;
63 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
64 /* -------- TWIHS_CR : (TWIHS Offset: 0x00) Control Register -------- */
65 #define TWIHS_CR_START (0x1u << 0)
66 #define TWIHS_CR_STOP (0x1u << 1)
67 #define TWIHS_CR_MSEN (0x1u << 2)
68 #define TWIHS_CR_MSDIS (0x1u << 3)
69 #define TWIHS_CR_SVEN (0x1u << 4)
70 #define TWIHS_CR_SVDIS (0x1u << 5)
71 #define TWIHS_CR_QUICK (0x1u << 6)
72 #define TWIHS_CR_SWRST (0x1u << 7)
73 #define TWIHS_CR_HSEN (0x1u << 8)
74 #define TWIHS_CR_HSDIS (0x1u << 9)
75 #define TWIHS_CR_SMBEN (0x1u << 10)
76 #define TWIHS_CR_SMBDIS (0x1u << 11)
77 #define TWIHS_CR_PECEN (0x1u << 12)
78 #define TWIHS_CR_PECDIS (0x1u << 13)
79 #define TWIHS_CR_PECRQ (0x1u << 14)
80 #define TWIHS_CR_CLEAR (0x1u << 15)
81 /* -------- TWIHS_MMR : (TWIHS Offset: 0x04) Master Mode Register -------- */
82 #define TWIHS_MMR_IADRSZ_Pos 8
83 #define TWIHS_MMR_IADRSZ_Msk (0x3u << TWIHS_MMR_IADRSZ_Pos)
84 #define TWIHS_MMR_IADRSZ(value) ((TWIHS_MMR_IADRSZ_Msk & ((value) << TWIHS_MMR_IADRSZ_Pos)))
85 #define TWIHS_MMR_IADRSZ_NONE (0x0u << 8)
86 #define TWIHS_MMR_IADRSZ_1_BYTE (0x1u << 8)
87 #define TWIHS_MMR_IADRSZ_2_BYTE (0x2u << 8)
88 #define TWIHS_MMR_IADRSZ_3_BYTE (0x3u << 8)
89 #define TWIHS_MMR_MREAD (0x1u << 12)
90 #define TWIHS_MMR_DADR_Pos 16
91 #define TWIHS_MMR_DADR_Msk (0x7fu << TWIHS_MMR_DADR_Pos)
92 #define TWIHS_MMR_DADR(value) ((TWIHS_MMR_DADR_Msk & ((value) << TWIHS_MMR_DADR_Pos)))
93 /* -------- TWIHS_SMR : (TWIHS Offset: 0x08) Slave Mode Register -------- */
94 #define TWIHS_SMR_NACKEN (0x1u << 0)
95 #define TWIHS_SMR_SMDA (0x1u << 2)
96 #define TWIHS_SMR_SMHH (0x1u << 3)
97 #define TWIHS_SMR_SCLWSDIS (0x1u << 6)
98 #define TWIHS_SMR_MASK_Pos 8
99 #define TWIHS_SMR_MASK_Msk (0x7fu << TWIHS_SMR_MASK_Pos)
100 #define TWIHS_SMR_MASK(value) ((TWIHS_SMR_MASK_Msk & ((value) << TWIHS_SMR_MASK_Pos)))
101 #define TWIHS_SMR_SADR_Pos 16
102 #define TWIHS_SMR_SADR_Msk (0x7fu << TWIHS_SMR_SADR_Pos)
103 #define TWIHS_SMR_SADR(value) ((TWIHS_SMR_SADR_Msk & ((value) << TWIHS_SMR_SADR_Pos)))
104 #define TWIHS_SMR_SADR1EN (0x1u << 28)
105 #define TWIHS_SMR_SADR2EN (0x1u << 29)
106 #define TWIHS_SMR_SADR3EN (0x1u << 30)
107 #define TWIHS_SMR_DATAMEN (0x1u << 31)
108 /* -------- TWIHS_IADR : (TWIHS Offset: 0x0C) Internal Address Register -------- */
109 #define TWIHS_IADR_IADR_Pos 0
110 #define TWIHS_IADR_IADR_Msk (0xffffffu << TWIHS_IADR_IADR_Pos)
111 #define TWIHS_IADR_IADR(value) ((TWIHS_IADR_IADR_Msk & ((value) << TWIHS_IADR_IADR_Pos)))
112 /* -------- TWIHS_CWGR : (TWIHS Offset: 0x10) Clock Waveform Generator Register -------- */
113 #define TWIHS_CWGR_CLDIV_Pos 0
114 #define TWIHS_CWGR_CLDIV_Msk (0xffu << TWIHS_CWGR_CLDIV_Pos)
115 #define TWIHS_CWGR_CLDIV(value) ((TWIHS_CWGR_CLDIV_Msk & ((value) << TWIHS_CWGR_CLDIV_Pos)))
116 #define TWIHS_CWGR_CHDIV_Pos 8
117 #define TWIHS_CWGR_CHDIV_Msk (0xffu << TWIHS_CWGR_CHDIV_Pos)
118 #define TWIHS_CWGR_CHDIV(value) ((TWIHS_CWGR_CHDIV_Msk & ((value) << TWIHS_CWGR_CHDIV_Pos)))
119 #define TWIHS_CWGR_CKDIV_Pos 16
120 #define TWIHS_CWGR_CKDIV_Msk (0x7u << TWIHS_CWGR_CKDIV_Pos)
121 #define TWIHS_CWGR_CKDIV(value) ((TWIHS_CWGR_CKDIV_Msk & ((value) << TWIHS_CWGR_CKDIV_Pos)))
122 #define TWIHS_CWGR_HOLD_Pos 24
123 #define TWIHS_CWGR_HOLD_Msk (0x1fu << TWIHS_CWGR_HOLD_Pos)
124 #define TWIHS_CWGR_HOLD(value) ((TWIHS_CWGR_HOLD_Msk & ((value) << TWIHS_CWGR_HOLD_Pos)))
125 /* -------- TWIHS_SR : (TWIHS Offset: 0x20) Status Register -------- */
126 #define TWIHS_SR_TXCOMP (0x1u << 0)
127 #define TWIHS_SR_RXRDY (0x1u << 1)
128 #define TWIHS_SR_TXRDY (0x1u << 2)
129 #define TWIHS_SR_SVREAD (0x1u << 3)
130 #define TWIHS_SR_SVACC (0x1u << 4)
131 #define TWIHS_SR_GACC (0x1u << 5)
132 #define TWIHS_SR_OVRE (0x1u << 6)
133 #define TWIHS_SR_UNRE (0x1u << 7)
134 #define TWIHS_SR_NACK (0x1u << 8)
135 #define TWIHS_SR_ARBLST (0x1u << 9)
136 #define TWIHS_SR_SCLWS (0x1u << 10)
137 #define TWIHS_SR_EOSACC (0x1u << 11)
138 #define TWIHS_SR_MCACK (0x1u << 16)
139 #define TWIHS_SR_TOUT (0x1u << 18)
140 #define TWIHS_SR_PECERR (0x1u << 19)
141 #define TWIHS_SR_SMBDAM (0x1u << 20)
142 #define TWIHS_SR_SMBHHM (0x1u << 21)
143 #define TWIHS_SR_SCL (0x1u << 24)
144 #define TWIHS_SR_SDA (0x1u << 25)
145 /* -------- TWIHS_IER : (TWIHS Offset: 0x24) Interrupt Enable Register -------- */
146 #define TWIHS_IER_TXCOMP (0x1u << 0)
147 #define TWIHS_IER_RXRDY (0x1u << 1)
148 #define TWIHS_IER_TXRDY (0x1u << 2)
149 #define TWIHS_IER_SVACC (0x1u << 4)
150 #define TWIHS_IER_GACC (0x1u << 5)
151 #define TWIHS_IER_OVRE (0x1u << 6)
152 #define TWIHS_IER_UNRE (0x1u << 7)
153 #define TWIHS_IER_NACK (0x1u << 8)
154 #define TWIHS_IER_ARBLST (0x1u << 9)
155 #define TWIHS_IER_SCL_WS (0x1u << 10)
156 #define TWIHS_IER_EOSACC (0x1u << 11)
157 #define TWIHS_IER_MCACK (0x1u << 16)
158 #define TWIHS_IER_TOUT (0x1u << 18)
159 #define TWIHS_IER_PECERR (0x1u << 19)
160 #define TWIHS_IER_SMBDAM (0x1u << 20)
161 #define TWIHS_IER_SMBHHM (0x1u << 21)
162 /* -------- TWIHS_IDR : (TWIHS Offset: 0x28) Interrupt Disable Register -------- */
163 #define TWIHS_IDR_TXCOMP (0x1u << 0)
164 #define TWIHS_IDR_RXRDY (0x1u << 1)
165 #define TWIHS_IDR_TXRDY (0x1u << 2)
166 #define TWIHS_IDR_SVACC (0x1u << 4)
167 #define TWIHS_IDR_GACC (0x1u << 5)
168 #define TWIHS_IDR_OVRE (0x1u << 6)
169 #define TWIHS_IDR_UNRE (0x1u << 7)
170 #define TWIHS_IDR_NACK (0x1u << 8)
171 #define TWIHS_IDR_ARBLST (0x1u << 9)
172 #define TWIHS_IDR_SCL_WS (0x1u << 10)
173 #define TWIHS_IDR_EOSACC (0x1u << 11)
174 #define TWIHS_IDR_MCACK (0x1u << 16)
175 #define TWIHS_IDR_TOUT (0x1u << 18)
176 #define TWIHS_IDR_PECERR (0x1u << 19)
177 #define TWIHS_IDR_SMBDAM (0x1u << 20)
178 #define TWIHS_IDR_SMBHHM (0x1u << 21)
179 /* -------- TWIHS_IMR : (TWIHS Offset: 0x2C) Interrupt Mask Register -------- */
180 #define TWIHS_IMR_TXCOMP (0x1u << 0)
181 #define TWIHS_IMR_RXRDY (0x1u << 1)
182 #define TWIHS_IMR_TXRDY (0x1u << 2)
183 #define TWIHS_IMR_SVACC (0x1u << 4)
184 #define TWIHS_IMR_GACC (0x1u << 5)
185 #define TWIHS_IMR_OVRE (0x1u << 6)
186 #define TWIHS_IMR_UNRE (0x1u << 7)
187 #define TWIHS_IMR_NACK (0x1u << 8)
188 #define TWIHS_IMR_ARBLST (0x1u << 9)
189 #define TWIHS_IMR_SCL_WS (0x1u << 10)
190 #define TWIHS_IMR_EOSACC (0x1u << 11)
191 #define TWIHS_IMR_MCACK (0x1u << 16)
192 #define TWIHS_IMR_TOUT (0x1u << 18)
193 #define TWIHS_IMR_PECERR (0x1u << 19)
194 #define TWIHS_IMR_SMBDAM (0x1u << 20)
195 #define TWIHS_IMR_SMBHHM (0x1u << 21)
196 /* -------- TWIHS_RHR : (TWIHS Offset: 0x30) Receive Holding Register -------- */
197 #define TWIHS_RHR_RXDATA_Pos 0
198 #define TWIHS_RHR_RXDATA_Msk (0xffu << TWIHS_RHR_RXDATA_Pos)
199 /* -------- TWIHS_THR : (TWIHS Offset: 0x34) Transmit Holding Register -------- */
200 #define TWIHS_THR_TXDATA_Pos 0
201 #define TWIHS_THR_TXDATA_Msk (0xffu << TWIHS_THR_TXDATA_Pos)
202 #define TWIHS_THR_TXDATA(value) ((TWIHS_THR_TXDATA_Msk & ((value) << TWIHS_THR_TXDATA_Pos)))
203 /* -------- TWIHS_SMBTR : (TWIHS Offset: 0x38) SMBus Timing Register -------- */
204 #define TWIHS_SMBTR_PRESC_Pos 0
205 #define TWIHS_SMBTR_PRESC_Msk (0xfu << TWIHS_SMBTR_PRESC_Pos)
206 #define TWIHS_SMBTR_PRESC(value) ((TWIHS_SMBTR_PRESC_Msk & ((value) << TWIHS_SMBTR_PRESC_Pos)))
207 #define TWIHS_SMBTR_TLOWS_Pos 8
208 #define TWIHS_SMBTR_TLOWS_Msk (0xffu << TWIHS_SMBTR_TLOWS_Pos)
209 #define TWIHS_SMBTR_TLOWS(value) ((TWIHS_SMBTR_TLOWS_Msk & ((value) << TWIHS_SMBTR_TLOWS_Pos)))
210 #define TWIHS_SMBTR_TLOWM_Pos 16
211 #define TWIHS_SMBTR_TLOWM_Msk (0xffu << TWIHS_SMBTR_TLOWM_Pos)
212 #define TWIHS_SMBTR_TLOWM(value) ((TWIHS_SMBTR_TLOWM_Msk & ((value) << TWIHS_SMBTR_TLOWM_Pos)))
213 #define TWIHS_SMBTR_THMAX_Pos 24
214 #define TWIHS_SMBTR_THMAX_Msk (0xffu << TWIHS_SMBTR_THMAX_Pos)
215 #define TWIHS_SMBTR_THMAX(value) ((TWIHS_SMBTR_THMAX_Msk & ((value) << TWIHS_SMBTR_THMAX_Pos)))
216 /* -------- TWIHS_FILTR : (TWIHS Offset: 0x44) Filter Register -------- */
217 #define TWIHS_FILTR_FILT (0x1u << 0)
218 #define TWIHS_FILTR_PADFEN (0x1u << 1)
219 #define TWIHS_FILTR_PADFCFG (0x1u << 2)
220 #define TWIHS_FILTR_THRES_Pos 8
221 #define TWIHS_FILTR_THRES_Msk (0x7u << TWIHS_FILTR_THRES_Pos)
222 #define TWIHS_FILTR_THRES(value) ((TWIHS_FILTR_THRES_Msk & ((value) << TWIHS_FILTR_THRES_Pos)))
223 /* -------- TWIHS_SWMR : (TWIHS Offset: 0x4C) SleepWalking Matching Register -------- */
224 #define TWIHS_SWMR_SADR1_Pos 0
225 #define TWIHS_SWMR_SADR1_Msk (0x7fu << TWIHS_SWMR_SADR1_Pos)
226 #define TWIHS_SWMR_SADR1(value) ((TWIHS_SWMR_SADR1_Msk & ((value) << TWIHS_SWMR_SADR1_Pos)))
227 #define TWIHS_SWMR_SADR2_Pos 8
228 #define TWIHS_SWMR_SADR2_Msk (0x7fu << TWIHS_SWMR_SADR2_Pos)
229 #define TWIHS_SWMR_SADR2(value) ((TWIHS_SWMR_SADR2_Msk & ((value) << TWIHS_SWMR_SADR2_Pos)))
230 #define TWIHS_SWMR_SADR3_Pos 16
231 #define TWIHS_SWMR_SADR3_Msk (0x7fu << TWIHS_SWMR_SADR3_Pos)
232 #define TWIHS_SWMR_SADR3(value) ((TWIHS_SWMR_SADR3_Msk & ((value) << TWIHS_SWMR_SADR3_Pos)))
233 #define TWIHS_SWMR_DATAM_Pos 24
234 #define TWIHS_SWMR_DATAM_Msk (0xffu << TWIHS_SWMR_DATAM_Pos)
235 #define TWIHS_SWMR_DATAM(value) ((TWIHS_SWMR_DATAM_Msk & ((value) << TWIHS_SWMR_DATAM_Pos)))
236 /* -------- TWIHS_WPMR : (TWIHS Offset: 0xE4) Write Protection Mode Register -------- */
237 #define TWIHS_WPMR_WPEN (0x1u << 0)
238 #define TWIHS_WPMR_WPKEY_Pos 8
239 #define TWIHS_WPMR_WPKEY_Msk (0xffffffu << TWIHS_WPMR_WPKEY_Pos)
240 #define TWIHS_WPMR_WPKEY(value) ((TWIHS_WPMR_WPKEY_Msk & ((value) << TWIHS_WPMR_WPKEY_Pos)))
241 #define TWIHS_WPMR_WPKEY_PASSWD (0x545749u << 8)
242 /* -------- TWIHS_WPSR : (TWIHS Offset: 0xE8) Write Protection Status Register -------- */
243 #define TWIHS_WPSR_WPVS (0x1u << 0)
244 #define TWIHS_WPSR_WPVSRC_Pos 8
245 #define TWIHS_WPSR_WPVSRC_Msk (0xffffffu << TWIHS_WPSR_WPVSRC_Pos)
248
249
250 #endif /* _SAMS70_TWIHS_COMPONENT_ */
#define __IO
Definition: core_cm7.h:287
#define __O
Definition: core_cm7.h:286
Twihs hardware registers.
Definition: component_twihs.h:41
#define __I
Definition: core_cm7.h:284
