RTEMS  5.1
component_matrix.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAMS70_MATRIX_COMPONENT_
31 #define _SAMS70_MATRIX_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __IO uint32_t MATRIX_MCFG0;
43  __IO uint32_t MATRIX_MCFG1;
44  __IO uint32_t MATRIX_MCFG2;
45  __IO uint32_t MATRIX_MCFG3;
46  __IO uint32_t MATRIX_MCFG4;
47  __IO uint32_t MATRIX_MCFG5;
48  __IO uint32_t MATRIX_MCFG6;
49  __I uint32_t Reserved1[1];
50  __IO uint32_t MATRIX_MCFG8;
51  __I uint32_t Reserved2[7];
52  __IO uint32_t MATRIX_SCFG[9];
53  __I uint32_t Reserved3[7];
54  __IO uint32_t MATRIX_PRAS0;
55  __IO uint32_t MATRIX_PRBS0;
56  __IO uint32_t MATRIX_PRAS1;
57  __IO uint32_t MATRIX_PRBS1;
58  __IO uint32_t MATRIX_PRAS2;
59  __IO uint32_t MATRIX_PRBS2;
60  __IO uint32_t MATRIX_PRAS3;
61  __IO uint32_t MATRIX_PRBS3;
62  __IO uint32_t MATRIX_PRAS4;
63  __IO uint32_t MATRIX_PRBS4;
64  __IO uint32_t MATRIX_PRAS5;
65  __IO uint32_t MATRIX_PRBS5;
66  __IO uint32_t MATRIX_PRAS6;
67  __IO uint32_t MATRIX_PRBS6;
68  __IO uint32_t MATRIX_PRAS7;
69  __IO uint32_t MATRIX_PRBS7;
70  __IO uint32_t MATRIX_PRAS8;
71  __IO uint32_t MATRIX_PRBS8;
72  __I uint32_t Reserved4[14];
73  __IO uint32_t MATRIX_MRCR;
74  __I uint32_t Reserved5[4];
75  __IO uint32_t CCFG_SYSIO;
76  __I uint32_t Reserved6[3];
77  __IO uint32_t CCFG_SMCNFCS;
78  __I uint32_t Reserved7[47];
79  __IO uint32_t MATRIX_WPMR;
80  __I uint32_t MATRIX_WPSR;
81 } Matrix;
82 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
83 /* -------- MATRIX_MCFG0 : (MATRIX Offset: 0x0000) Master Configuration Register 0 -------- */
84 #define MATRIX_MCFG0_ULBT_Pos 0
85 #define MATRIX_MCFG0_ULBT_Msk (0x7u << MATRIX_MCFG0_ULBT_Pos)
86 #define MATRIX_MCFG0_ULBT(value) ((MATRIX_MCFG0_ULBT_Msk & ((value) << MATRIX_MCFG0_ULBT_Pos)))
87 #define MATRIX_MCFG0_ULBT_UNLTD_LENGTH (0x0u << 0)
88 #define MATRIX_MCFG0_ULBT_SINGLE_ACCESS (0x1u << 0)
89 #define MATRIX_MCFG0_ULBT_4BEAT_BURST (0x2u << 0)
90 #define MATRIX_MCFG0_ULBT_8BEAT_BURST (0x3u << 0)
91 #define MATRIX_MCFG0_ULBT_16BEAT_BURST (0x4u << 0)
92 #define MATRIX_MCFG0_ULBT_32BEAT_BURST (0x5u << 0)
93 #define MATRIX_MCFG0_ULBT_64BEAT_BURST (0x6u << 0)
94 #define MATRIX_MCFG0_ULBT_128BEAT_BURST (0x7u << 0)
95 /* -------- MATRIX_MCFG1 : (MATRIX Offset: 0x0004) Master Configuration Register 1 -------- */
96 #define MATRIX_MCFG1_ULBT_Pos 0
97 #define MATRIX_MCFG1_ULBT_Msk (0x7u << MATRIX_MCFG1_ULBT_Pos)
98 #define MATRIX_MCFG1_ULBT(value) ((MATRIX_MCFG1_ULBT_Msk & ((value) << MATRIX_MCFG1_ULBT_Pos)))
99 #define MATRIX_MCFG1_ULBT_UNLTD_LENGTH (0x0u << 0)
100 #define MATRIX_MCFG1_ULBT_SINGLE_ACCESS (0x1u << 0)
101 #define MATRIX_MCFG1_ULBT_4BEAT_BURST (0x2u << 0)
102 #define MATRIX_MCFG1_ULBT_8BEAT_BURST (0x3u << 0)
103 #define MATRIX_MCFG1_ULBT_16BEAT_BURST (0x4u << 0)
104 #define MATRIX_MCFG1_ULBT_32BEAT_BURST (0x5u << 0)
105 #define MATRIX_MCFG1_ULBT_64BEAT_BURST (0x6u << 0)
106 #define MATRIX_MCFG1_ULBT_128BEAT_BURST (0x7u << 0)
107 /* -------- MATRIX_MCFG2 : (MATRIX Offset: 0x0008) Master Configuration Register 2 -------- */
108 #define MATRIX_MCFG2_ULBT_Pos 0
109 #define MATRIX_MCFG2_ULBT_Msk (0x7u << MATRIX_MCFG2_ULBT_Pos)
110 #define MATRIX_MCFG2_ULBT(value) ((MATRIX_MCFG2_ULBT_Msk & ((value) << MATRIX_MCFG2_ULBT_Pos)))
111 #define MATRIX_MCFG2_ULBT_UNLTD_LENGTH (0x0u << 0)
112 #define MATRIX_MCFG2_ULBT_SINGLE_ACCESS (0x1u << 0)
113 #define MATRIX_MCFG2_ULBT_4BEAT_BURST (0x2u << 0)
114 #define MATRIX_MCFG2_ULBT_8BEAT_BURST (0x3u << 0)
115 #define MATRIX_MCFG2_ULBT_16BEAT_BURST (0x4u << 0)
116 #define MATRIX_MCFG2_ULBT_32BEAT_BURST (0x5u << 0)
117 #define MATRIX_MCFG2_ULBT_64BEAT_BURST (0x6u << 0)
118 #define MATRIX_MCFG2_ULBT_128BEAT_BURST (0x7u << 0)
119 /* -------- MATRIX_MCFG3 : (MATRIX Offset: 0x000C) Master Configuration Register 3 -------- */
120 #define MATRIX_MCFG3_ULBT_Pos 0
121 #define MATRIX_MCFG3_ULBT_Msk (0x7u << MATRIX_MCFG3_ULBT_Pos)
122 #define MATRIX_MCFG3_ULBT(value) ((MATRIX_MCFG3_ULBT_Msk & ((value) << MATRIX_MCFG3_ULBT_Pos)))
123 #define MATRIX_MCFG3_ULBT_UNLTD_LENGTH (0x0u << 0)
124 #define MATRIX_MCFG3_ULBT_SINGLE_ACCESS (0x1u << 0)
125 #define MATRIX_MCFG3_ULBT_4BEAT_BURST (0x2u << 0)
126 #define MATRIX_MCFG3_ULBT_8BEAT_BURST (0x3u << 0)
127 #define MATRIX_MCFG3_ULBT_16BEAT_BURST (0x4u << 0)
128 #define MATRIX_MCFG3_ULBT_32BEAT_BURST (0x5u << 0)
129 #define MATRIX_MCFG3_ULBT_64BEAT_BURST (0x6u << 0)
130 #define MATRIX_MCFG3_ULBT_128BEAT_BURST (0x7u << 0)
131 /* -------- MATRIX_MCFG4 : (MATRIX Offset: 0x0010) Master Configuration Register 4 -------- */
132 #define MATRIX_MCFG4_ULBT_Pos 0
133 #define MATRIX_MCFG4_ULBT_Msk (0x7u << MATRIX_MCFG4_ULBT_Pos)
134 #define MATRIX_MCFG4_ULBT(value) ((MATRIX_MCFG4_ULBT_Msk & ((value) << MATRIX_MCFG4_ULBT_Pos)))
135 #define MATRIX_MCFG4_ULBT_UNLTD_LENGTH (0x0u << 0)
136 #define MATRIX_MCFG4_ULBT_SINGLE_ACCESS (0x1u << 0)
137 #define MATRIX_MCFG4_ULBT_4BEAT_BURST (0x2u << 0)
138 #define MATRIX_MCFG4_ULBT_8BEAT_BURST (0x3u << 0)
139 #define MATRIX_MCFG4_ULBT_16BEAT_BURST (0x4u << 0)
140 #define MATRIX_MCFG4_ULBT_32BEAT_BURST (0x5u << 0)
141 #define MATRIX_MCFG4_ULBT_64BEAT_BURST (0x6u << 0)
142 #define MATRIX_MCFG4_ULBT_128BEAT_BURST (0x7u << 0)
143 /* -------- MATRIX_MCFG5 : (MATRIX Offset: 0x0014) Master Configuration Register 5 -------- */
144 #define MATRIX_MCFG5_ULBT_Pos 0
145 #define MATRIX_MCFG5_ULBT_Msk (0x7u << MATRIX_MCFG5_ULBT_Pos)
146 #define MATRIX_MCFG5_ULBT(value) ((MATRIX_MCFG5_ULBT_Msk & ((value) << MATRIX_MCFG5_ULBT_Pos)))
147 #define MATRIX_MCFG5_ULBT_UNLTD_LENGTH (0x0u << 0)
148 #define MATRIX_MCFG5_ULBT_SINGLE_ACCESS (0x1u << 0)
149 #define MATRIX_MCFG5_ULBT_4BEAT_BURST (0x2u << 0)
150 #define MATRIX_MCFG5_ULBT_8BEAT_BURST (0x3u << 0)
151 #define MATRIX_MCFG5_ULBT_16BEAT_BURST (0x4u << 0)
152 #define MATRIX_MCFG5_ULBT_32BEAT_BURST (0x5u << 0)
153 #define MATRIX_MCFG5_ULBT_64BEAT_BURST (0x6u << 0)
154 #define MATRIX_MCFG5_ULBT_128BEAT_BURST (0x7u << 0)
155 /* -------- MATRIX_MCFG6 : (MATRIX Offset: 0x0018) Master Configuration Register 6 -------- */
156 #define MATRIX_MCFG6_ULBT_Pos 0
157 #define MATRIX_MCFG6_ULBT_Msk (0x7u << MATRIX_MCFG6_ULBT_Pos)
158 #define MATRIX_MCFG6_ULBT(value) ((MATRIX_MCFG6_ULBT_Msk & ((value) << MATRIX_MCFG6_ULBT_Pos)))
159 #define MATRIX_MCFG6_ULBT_UNLTD_LENGTH (0x0u << 0)
160 #define MATRIX_MCFG6_ULBT_SINGLE_ACCESS (0x1u << 0)
161 #define MATRIX_MCFG6_ULBT_4BEAT_BURST (0x2u << 0)
162 #define MATRIX_MCFG6_ULBT_8BEAT_BURST (0x3u << 0)
163 #define MATRIX_MCFG6_ULBT_16BEAT_BURST (0x4u << 0)
164 #define MATRIX_MCFG6_ULBT_32BEAT_BURST (0x5u << 0)
165 #define MATRIX_MCFG6_ULBT_64BEAT_BURST (0x6u << 0)
166 #define MATRIX_MCFG6_ULBT_128BEAT_BURST (0x7u << 0)
167 /* -------- MATRIX_MCFG8 : (MATRIX Offset: 0x0020) Master Configuration Register 8 -------- */
168 #define MATRIX_MCFG8_ULBT_Pos 0
169 #define MATRIX_MCFG8_ULBT_Msk (0x7u << MATRIX_MCFG8_ULBT_Pos)
170 #define MATRIX_MCFG8_ULBT(value) ((MATRIX_MCFG8_ULBT_Msk & ((value) << MATRIX_MCFG8_ULBT_Pos)))
171 #define MATRIX_MCFG8_ULBT_UNLTD_LENGTH (0x0u << 0)
172 #define MATRIX_MCFG8_ULBT_SINGLE_ACCESS (0x1u << 0)
173 #define MATRIX_MCFG8_ULBT_4BEAT_BURST (0x2u << 0)
174 #define MATRIX_MCFG8_ULBT_8BEAT_BURST (0x3u << 0)
175 #define MATRIX_MCFG8_ULBT_16BEAT_BURST (0x4u << 0)
176 #define MATRIX_MCFG8_ULBT_32BEAT_BURST (0x5u << 0)
177 #define MATRIX_MCFG8_ULBT_64BEAT_BURST (0x6u << 0)
178 #define MATRIX_MCFG8_ULBT_128BEAT_BURST (0x7u << 0)
179 /* -------- MATRIX_SCFG[9] : (MATRIX Offset: 0x0040) Slave Configuration Register -------- */
180 #define MATRIX_SCFG_SLOT_CYCLE_Pos 0
181 #define MATRIX_SCFG_SLOT_CYCLE_Msk (0x1ffu << MATRIX_SCFG_SLOT_CYCLE_Pos)
182 #define MATRIX_SCFG_SLOT_CYCLE(value) ((MATRIX_SCFG_SLOT_CYCLE_Msk & ((value) << MATRIX_SCFG_SLOT_CYCLE_Pos)))
183 #define MATRIX_SCFG_DEFMSTR_TYPE_Pos 16
184 #define MATRIX_SCFG_DEFMSTR_TYPE_Msk (0x3u << MATRIX_SCFG_DEFMSTR_TYPE_Pos)
185 #define MATRIX_SCFG_DEFMSTR_TYPE(value) ((MATRIX_SCFG_DEFMSTR_TYPE_Msk & ((value) << MATRIX_SCFG_DEFMSTR_TYPE_Pos)))
186 #define MATRIX_SCFG_DEFMSTR_TYPE_NONE (0x0u << 16)
187 #define MATRIX_SCFG_DEFMSTR_TYPE_LAST (0x1u << 16)
188 #define MATRIX_SCFG_DEFMSTR_TYPE_FIXED (0x2u << 16)
189 #define MATRIX_SCFG_FIXED_DEFMSTR_Pos 18
190 #define MATRIX_SCFG_FIXED_DEFMSTR_Msk (0xfu << MATRIX_SCFG_FIXED_DEFMSTR_Pos)
191 #define MATRIX_SCFG_FIXED_DEFMSTR(value) ((MATRIX_SCFG_FIXED_DEFMSTR_Msk & ((value) << MATRIX_SCFG_FIXED_DEFMSTR_Pos)))
192 /* -------- MATRIX_PRAS0 : (MATRIX Offset: 0x0080) Priority Register A for Slave 0 -------- */
193 #define MATRIX_PRAS0_M0PR_Pos 0
194 #define MATRIX_PRAS0_M0PR_Msk (0x3u << MATRIX_PRAS0_M0PR_Pos)
195 #define MATRIX_PRAS0_M0PR(value) ((MATRIX_PRAS0_M0PR_Msk & ((value) << MATRIX_PRAS0_M0PR_Pos)))
196 #define MATRIX_PRAS0_M1PR_Pos 4
197 #define MATRIX_PRAS0_M1PR_Msk (0x3u << MATRIX_PRAS0_M1PR_Pos)
198 #define MATRIX_PRAS0_M1PR(value) ((MATRIX_PRAS0_M1PR_Msk & ((value) << MATRIX_PRAS0_M1PR_Pos)))
199 #define MATRIX_PRAS0_M2PR_Pos 8
200 #define MATRIX_PRAS0_M2PR_Msk (0x3u << MATRIX_PRAS0_M2PR_Pos)
201 #define MATRIX_PRAS0_M2PR(value) ((MATRIX_PRAS0_M2PR_Msk & ((value) << MATRIX_PRAS0_M2PR_Pos)))
202 #define MATRIX_PRAS0_M3PR_Pos 12
203 #define MATRIX_PRAS0_M3PR_Msk (0x3u << MATRIX_PRAS0_M3PR_Pos)
204 #define MATRIX_PRAS0_M3PR(value) ((MATRIX_PRAS0_M3PR_Msk & ((value) << MATRIX_PRAS0_M3PR_Pos)))
205 #define MATRIX_PRAS0_M4PR_Pos 16
206 #define MATRIX_PRAS0_M4PR_Msk (0x3u << MATRIX_PRAS0_M4PR_Pos)
207 #define MATRIX_PRAS0_M4PR(value) ((MATRIX_PRAS0_M4PR_Msk & ((value) << MATRIX_PRAS0_M4PR_Pos)))
208 #define MATRIX_PRAS0_M5PR_Pos 20
209 #define MATRIX_PRAS0_M5PR_Msk (0x3u << MATRIX_PRAS0_M5PR_Pos)
210 #define MATRIX_PRAS0_M5PR(value) ((MATRIX_PRAS0_M5PR_Msk & ((value) << MATRIX_PRAS0_M5PR_Pos)))
211 #define MATRIX_PRAS0_M6PR_Pos 24
212 #define MATRIX_PRAS0_M6PR_Msk (0x3u << MATRIX_PRAS0_M6PR_Pos)
213 #define MATRIX_PRAS0_M6PR(value) ((MATRIX_PRAS0_M6PR_Msk & ((value) << MATRIX_PRAS0_M6PR_Pos)))
214 /* -------- MATRIX_PRBS0 : (MATRIX Offset: 0x0084) Priority Register B for Slave 0 -------- */
215 #define MATRIX_PRBS0_M8PR_Pos 0
216 #define MATRIX_PRBS0_M8PR_Msk (0x3u << MATRIX_PRBS0_M8PR_Pos)
217 #define MATRIX_PRBS0_M8PR(value) ((MATRIX_PRBS0_M8PR_Msk & ((value) << MATRIX_PRBS0_M8PR_Pos)))
218 /* -------- MATRIX_PRAS1 : (MATRIX Offset: 0x0088) Priority Register A for Slave 1 -------- */
219 #define MATRIX_PRAS1_M0PR_Pos 0
220 #define MATRIX_PRAS1_M0PR_Msk (0x3u << MATRIX_PRAS1_M0PR_Pos)
221 #define MATRIX_PRAS1_M0PR(value) ((MATRIX_PRAS1_M0PR_Msk & ((value) << MATRIX_PRAS1_M0PR_Pos)))
222 #define MATRIX_PRAS1_M1PR_Pos 4
223 #define MATRIX_PRAS1_M1PR_Msk (0x3u << MATRIX_PRAS1_M1PR_Pos)
224 #define MATRIX_PRAS1_M1PR(value) ((MATRIX_PRAS1_M1PR_Msk & ((value) << MATRIX_PRAS1_M1PR_Pos)))
225 #define MATRIX_PRAS1_M2PR_Pos 8
226 #define MATRIX_PRAS1_M2PR_Msk (0x3u << MATRIX_PRAS1_M2PR_Pos)
227 #define MATRIX_PRAS1_M2PR(value) ((MATRIX_PRAS1_M2PR_Msk & ((value) << MATRIX_PRAS1_M2PR_Pos)))
228 #define MATRIX_PRAS1_M3PR_Pos 12
229 #define MATRIX_PRAS1_M3PR_Msk (0x3u << MATRIX_PRAS1_M3PR_Pos)
230 #define MATRIX_PRAS1_M3PR(value) ((MATRIX_PRAS1_M3PR_Msk & ((value) << MATRIX_PRAS1_M3PR_Pos)))
231 #define MATRIX_PRAS1_M4PR_Pos 16
232 #define MATRIX_PRAS1_M4PR_Msk (0x3u << MATRIX_PRAS1_M4PR_Pos)
233 #define MATRIX_PRAS1_M4PR(value) ((MATRIX_PRAS1_M4PR_Msk & ((value) << MATRIX_PRAS1_M4PR_Pos)))
234 #define MATRIX_PRAS1_M5PR_Pos 20
235 #define MATRIX_PRAS1_M5PR_Msk (0x3u << MATRIX_PRAS1_M5PR_Pos)
236 #define MATRIX_PRAS1_M5PR(value) ((MATRIX_PRAS1_M5PR_Msk & ((value) << MATRIX_PRAS1_M5PR_Pos)))
237 #define MATRIX_PRAS1_M6PR_Pos 24
238 #define MATRIX_PRAS1_M6PR_Msk (0x3u << MATRIX_PRAS1_M6PR_Pos)
239 #define MATRIX_PRAS1_M6PR(value) ((MATRIX_PRAS1_M6PR_Msk & ((value) << MATRIX_PRAS1_M6PR_Pos)))
240 /* -------- MATRIX_PRBS1 : (MATRIX Offset: 0x008C) Priority Register B for Slave 1 -------- */
241 #define MATRIX_PRBS1_M8PR_Pos 0
242 #define MATRIX_PRBS1_M8PR_Msk (0x3u << MATRIX_PRBS1_M8PR_Pos)
243 #define MATRIX_PRBS1_M8PR(value) ((MATRIX_PRBS1_M8PR_Msk & ((value) << MATRIX_PRBS1_M8PR_Pos)))
244 /* -------- MATRIX_PRAS2 : (MATRIX Offset: 0x0090) Priority Register A for Slave 2 -------- */
245 #define MATRIX_PRAS2_M0PR_Pos 0
246 #define MATRIX_PRAS2_M0PR_Msk (0x3u << MATRIX_PRAS2_M0PR_Pos)
247 #define MATRIX_PRAS2_M0PR(value) ((MATRIX_PRAS2_M0PR_Msk & ((value) << MATRIX_PRAS2_M0PR_Pos)))
248 #define MATRIX_PRAS2_M1PR_Pos 4
249 #define MATRIX_PRAS2_M1PR_Msk (0x3u << MATRIX_PRAS2_M1PR_Pos)
250 #define MATRIX_PRAS2_M1PR(value) ((MATRIX_PRAS2_M1PR_Msk & ((value) << MATRIX_PRAS2_M1PR_Pos)))
251 #define MATRIX_PRAS2_M2PR_Pos 8
252 #define MATRIX_PRAS2_M2PR_Msk (0x3u << MATRIX_PRAS2_M2PR_Pos)
253 #define MATRIX_PRAS2_M2PR(value) ((MATRIX_PRAS2_M2PR_Msk & ((value) << MATRIX_PRAS2_M2PR_Pos)))
254 #define MATRIX_PRAS2_M3PR_Pos 12
255 #define MATRIX_PRAS2_M3PR_Msk (0x3u << MATRIX_PRAS2_M3PR_Pos)
256 #define MATRIX_PRAS2_M3PR(value) ((MATRIX_PRAS2_M3PR_Msk & ((value) << MATRIX_PRAS2_M3PR_Pos)))
257 #define MATRIX_PRAS2_M4PR_Pos 16
258 #define MATRIX_PRAS2_M4PR_Msk (0x3u << MATRIX_PRAS2_M4PR_Pos)
259 #define MATRIX_PRAS2_M4PR(value) ((MATRIX_PRAS2_M4PR_Msk & ((value) << MATRIX_PRAS2_M4PR_Pos)))
260 #define MATRIX_PRAS2_M5PR_Pos 20
261 #define MATRIX_PRAS2_M5PR_Msk (0x3u << MATRIX_PRAS2_M5PR_Pos)
262 #define MATRIX_PRAS2_M5PR(value) ((MATRIX_PRAS2_M5PR_Msk & ((value) << MATRIX_PRAS2_M5PR_Pos)))
263 #define MATRIX_PRAS2_M6PR_Pos 24
264 #define MATRIX_PRAS2_M6PR_Msk (0x3u << MATRIX_PRAS2_M6PR_Pos)
265 #define MATRIX_PRAS2_M6PR(value) ((MATRIX_PRAS2_M6PR_Msk & ((value) << MATRIX_PRAS2_M6PR_Pos)))
266 /* -------- MATRIX_PRBS2 : (MATRIX Offset: 0x0094) Priority Register B for Slave 2 -------- */
267 #define MATRIX_PRBS2_M8PR_Pos 0
268 #define MATRIX_PRBS2_M8PR_Msk (0x3u << MATRIX_PRBS2_M8PR_Pos)
269 #define MATRIX_PRBS2_M8PR(value) ((MATRIX_PRBS2_M8PR_Msk & ((value) << MATRIX_PRBS2_M8PR_Pos)))
270 /* -------- MATRIX_PRAS3 : (MATRIX Offset: 0x0098) Priority Register A for Slave 3 -------- */
271 #define MATRIX_PRAS3_M0PR_Pos 0
272 #define MATRIX_PRAS3_M0PR_Msk (0x3u << MATRIX_PRAS3_M0PR_Pos)
273 #define MATRIX_PRAS3_M0PR(value) ((MATRIX_PRAS3_M0PR_Msk & ((value) << MATRIX_PRAS3_M0PR_Pos)))
274 #define MATRIX_PRAS3_M1PR_Pos 4
275 #define MATRIX_PRAS3_M1PR_Msk (0x3u << MATRIX_PRAS3_M1PR_Pos)
276 #define MATRIX_PRAS3_M1PR(value) ((MATRIX_PRAS3_M1PR_Msk & ((value) << MATRIX_PRAS3_M1PR_Pos)))
277 #define MATRIX_PRAS3_M2PR_Pos 8
278 #define MATRIX_PRAS3_M2PR_Msk (0x3u << MATRIX_PRAS3_M2PR_Pos)
279 #define MATRIX_PRAS3_M2PR(value) ((MATRIX_PRAS3_M2PR_Msk & ((value) << MATRIX_PRAS3_M2PR_Pos)))
280 #define MATRIX_PRAS3_M3PR_Pos 12
281 #define MATRIX_PRAS3_M3PR_Msk (0x3u << MATRIX_PRAS3_M3PR_Pos)
282 #define MATRIX_PRAS3_M3PR(value) ((MATRIX_PRAS3_M3PR_Msk & ((value) << MATRIX_PRAS3_M3PR_Pos)))
283 #define MATRIX_PRAS3_M4PR_Pos 16
284 #define MATRIX_PRAS3_M4PR_Msk (0x3u << MATRIX_PRAS3_M4PR_Pos)
285 #define MATRIX_PRAS3_M4PR(value) ((MATRIX_PRAS3_M4PR_Msk & ((value) << MATRIX_PRAS3_M4PR_Pos)))
286 #define MATRIX_PRAS3_M5PR_Pos 20
287 #define MATRIX_PRAS3_M5PR_Msk (0x3u << MATRIX_PRAS3_M5PR_Pos)
288 #define MATRIX_PRAS3_M5PR(value) ((MATRIX_PRAS3_M5PR_Msk & ((value) << MATRIX_PRAS3_M5PR_Pos)))
289 #define MATRIX_PRAS3_M6PR_Pos 24
290 #define MATRIX_PRAS3_M6PR_Msk (0x3u << MATRIX_PRAS3_M6PR_Pos)
291 #define MATRIX_PRAS3_M6PR(value) ((MATRIX_PRAS3_M6PR_Msk & ((value) << MATRIX_PRAS3_M6PR_Pos)))
292 /* -------- MATRIX_PRBS3 : (MATRIX Offset: 0x009C) Priority Register B for Slave 3 -------- */
293 #define MATRIX_PRBS3_M8PR_Pos 0
294 #define MATRIX_PRBS3_M8PR_Msk (0x3u << MATRIX_PRBS3_M8PR_Pos)
295 #define MATRIX_PRBS3_M8PR(value) ((MATRIX_PRBS3_M8PR_Msk & ((value) << MATRIX_PRBS3_M8PR_Pos)))
296 /* -------- MATRIX_PRAS4 : (MATRIX Offset: 0x00A0) Priority Register A for Slave 4 -------- */
297 #define MATRIX_PRAS4_M0PR_Pos 0
298 #define MATRIX_PRAS4_M0PR_Msk (0x3u << MATRIX_PRAS4_M0PR_Pos)
299 #define MATRIX_PRAS4_M0PR(value) ((MATRIX_PRAS4_M0PR_Msk & ((value) << MATRIX_PRAS4_M0PR_Pos)))
300 #define MATRIX_PRAS4_M1PR_Pos 4
301 #define MATRIX_PRAS4_M1PR_Msk (0x3u << MATRIX_PRAS4_M1PR_Pos)
302 #define MATRIX_PRAS4_M1PR(value) ((MATRIX_PRAS4_M1PR_Msk & ((value) << MATRIX_PRAS4_M1PR_Pos)))
303 #define MATRIX_PRAS4_M2PR_Pos 8
304 #define MATRIX_PRAS4_M2PR_Msk (0x3u << MATRIX_PRAS4_M2PR_Pos)
305 #define MATRIX_PRAS4_M2PR(value) ((MATRIX_PRAS4_M2PR_Msk & ((value) << MATRIX_PRAS4_M2PR_Pos)))
306 #define MATRIX_PRAS4_M3PR_Pos 12
307 #define MATRIX_PRAS4_M3PR_Msk (0x3u << MATRIX_PRAS4_M3PR_Pos)
308 #define MATRIX_PRAS4_M3PR(value) ((MATRIX_PRAS4_M3PR_Msk & ((value) << MATRIX_PRAS4_M3PR_Pos)))
309 #define MATRIX_PRAS4_M4PR_Pos 16
310 #define MATRIX_PRAS4_M4PR_Msk (0x3u << MATRIX_PRAS4_M4PR_Pos)
311 #define MATRIX_PRAS4_M4PR(value) ((MATRIX_PRAS4_M4PR_Msk & ((value) << MATRIX_PRAS4_M4PR_Pos)))
312 #define MATRIX_PRAS4_M5PR_Pos 20
313 #define MATRIX_PRAS4_M5PR_Msk (0x3u << MATRIX_PRAS4_M5PR_Pos)
314 #define MATRIX_PRAS4_M5PR(value) ((MATRIX_PRAS4_M5PR_Msk & ((value) << MATRIX_PRAS4_M5PR_Pos)))
315 #define MATRIX_PRAS4_M6PR_Pos 24
316 #define MATRIX_PRAS4_M6PR_Msk (0x3u << MATRIX_PRAS4_M6PR_Pos)
317 #define MATRIX_PRAS4_M6PR(value) ((MATRIX_PRAS4_M6PR_Msk & ((value) << MATRIX_PRAS4_M6PR_Pos)))
318 /* -------- MATRIX_PRBS4 : (MATRIX Offset: 0x00A4) Priority Register B for Slave 4 -------- */
319 #define MATRIX_PRBS4_M8PR_Pos 0
320 #define MATRIX_PRBS4_M8PR_Msk (0x3u << MATRIX_PRBS4_M8PR_Pos)
321 #define MATRIX_PRBS4_M8PR(value) ((MATRIX_PRBS4_M8PR_Msk & ((value) << MATRIX_PRBS4_M8PR_Pos)))
322 /* -------- MATRIX_PRAS5 : (MATRIX Offset: 0x00A8) Priority Register A for Slave 5 -------- */
323 #define MATRIX_PRAS5_M0PR_Pos 0
324 #define MATRIX_PRAS5_M0PR_Msk (0x3u << MATRIX_PRAS5_M0PR_Pos)
325 #define MATRIX_PRAS5_M0PR(value) ((MATRIX_PRAS5_M0PR_Msk & ((value) << MATRIX_PRAS5_M0PR_Pos)))
326 #define MATRIX_PRAS5_M1PR_Pos 4
327 #define MATRIX_PRAS5_M1PR_Msk (0x3u << MATRIX_PRAS5_M1PR_Pos)
328 #define MATRIX_PRAS5_M1PR(value) ((MATRIX_PRAS5_M1PR_Msk & ((value) << MATRIX_PRAS5_M1PR_Pos)))
329 #define MATRIX_PRAS5_M2PR_Pos 8
330 #define MATRIX_PRAS5_M2PR_Msk (0x3u << MATRIX_PRAS5_M2PR_Pos)
331 #define MATRIX_PRAS5_M2PR(value) ((MATRIX_PRAS5_M2PR_Msk & ((value) << MATRIX_PRAS5_M2PR_Pos)))
332 #define MATRIX_PRAS5_M3PR_Pos 12
333 #define MATRIX_PRAS5_M3PR_Msk (0x3u << MATRIX_PRAS5_M3PR_Pos)
334 #define MATRIX_PRAS5_M3PR(value) ((MATRIX_PRAS5_M3PR_Msk & ((value) << MATRIX_PRAS5_M3PR_Pos)))
335 #define MATRIX_PRAS5_M4PR_Pos 16
336 #define MATRIX_PRAS5_M4PR_Msk (0x3u << MATRIX_PRAS5_M4PR_Pos)
337 #define MATRIX_PRAS5_M4PR(value) ((MATRIX_PRAS5_M4PR_Msk & ((value) << MATRIX_PRAS5_M4PR_Pos)))
338 #define MATRIX_PRAS5_M5PR_Pos 20
339 #define MATRIX_PRAS5_M5PR_Msk (0x3u << MATRIX_PRAS5_M5PR_Pos)
340 #define MATRIX_PRAS5_M5PR(value) ((MATRIX_PRAS5_M5PR_Msk & ((value) << MATRIX_PRAS5_M5PR_Pos)))
341 #define MATRIX_PRAS5_M6PR_Pos 24
342 #define MATRIX_PRAS5_M6PR_Msk (0x3u << MATRIX_PRAS5_M6PR_Pos)
343 #define MATRIX_PRAS5_M6PR(value) ((MATRIX_PRAS5_M6PR_Msk & ((value) << MATRIX_PRAS5_M6PR_Pos)))
344 /* -------- MATRIX_PRBS5 : (MATRIX Offset: 0x00AC) Priority Register B for Slave 5 -------- */
345 #define MATRIX_PRBS5_M8PR_Pos 0
346 #define MATRIX_PRBS5_M8PR_Msk (0x3u << MATRIX_PRBS5_M8PR_Pos)
347 #define MATRIX_PRBS5_M8PR(value) ((MATRIX_PRBS5_M8PR_Msk & ((value) << MATRIX_PRBS5_M8PR_Pos)))
348 /* -------- MATRIX_PRAS6 : (MATRIX Offset: 0x00B0) Priority Register A for Slave 6 -------- */
349 #define MATRIX_PRAS6_M0PR_Pos 0
350 #define MATRIX_PRAS6_M0PR_Msk (0x3u << MATRIX_PRAS6_M0PR_Pos)
351 #define MATRIX_PRAS6_M0PR(value) ((MATRIX_PRAS6_M0PR_Msk & ((value) << MATRIX_PRAS6_M0PR_Pos)))
352 #define MATRIX_PRAS6_M1PR_Pos 4
353 #define MATRIX_PRAS6_M1PR_Msk (0x3u << MATRIX_PRAS6_M1PR_Pos)
354 #define MATRIX_PRAS6_M1PR(value) ((MATRIX_PRAS6_M1PR_Msk & ((value) << MATRIX_PRAS6_M1PR_Pos)))
355 #define MATRIX_PRAS6_M2PR_Pos 8
356 #define MATRIX_PRAS6_M2PR_Msk (0x3u << MATRIX_PRAS6_M2PR_Pos)
357 #define MATRIX_PRAS6_M2PR(value) ((MATRIX_PRAS6_M2PR_Msk & ((value) << MATRIX_PRAS6_M2PR_Pos)))
358 #define MATRIX_PRAS6_M3PR_Pos 12
359 #define MATRIX_PRAS6_M3PR_Msk (0x3u << MATRIX_PRAS6_M3PR_Pos)
360 #define MATRIX_PRAS6_M3PR(value) ((MATRIX_PRAS6_M3PR_Msk & ((value) << MATRIX_PRAS6_M3PR_Pos)))
361 #define MATRIX_PRAS6_M4PR_Pos 16
362 #define MATRIX_PRAS6_M4PR_Msk (0x3u << MATRIX_PRAS6_M4PR_Pos)
363 #define MATRIX_PRAS6_M4PR(value) ((MATRIX_PRAS6_M4PR_Msk & ((value) << MATRIX_PRAS6_M4PR_Pos)))
364 #define MATRIX_PRAS6_M5PR_Pos 20
365 #define MATRIX_PRAS6_M5PR_Msk (0x3u << MATRIX_PRAS6_M5PR_Pos)
366 #define MATRIX_PRAS6_M5PR(value) ((MATRIX_PRAS6_M5PR_Msk & ((value) << MATRIX_PRAS6_M5PR_Pos)))
367 #define MATRIX_PRAS6_M6PR_Pos 24
368 #define MATRIX_PRAS6_M6PR_Msk (0x3u << MATRIX_PRAS6_M6PR_Pos)
369 #define MATRIX_PRAS6_M6PR(value) ((MATRIX_PRAS6_M6PR_Msk & ((value) << MATRIX_PRAS6_M6PR_Pos)))
370 /* -------- MATRIX_PRBS6 : (MATRIX Offset: 0x00B4) Priority Register B for Slave 6 -------- */
371 #define MATRIX_PRBS6_M8PR_Pos 0
372 #define MATRIX_PRBS6_M8PR_Msk (0x3u << MATRIX_PRBS6_M8PR_Pos)
373 #define MATRIX_PRBS6_M8PR(value) ((MATRIX_PRBS6_M8PR_Msk & ((value) << MATRIX_PRBS6_M8PR_Pos)))
374 /* -------- MATRIX_PRAS7 : (MATRIX Offset: 0x00B8) Priority Register A for Slave 7 -------- */
375 #define MATRIX_PRAS7_M0PR_Pos 0
376 #define MATRIX_PRAS7_M0PR_Msk (0x3u << MATRIX_PRAS7_M0PR_Pos)
377 #define MATRIX_PRAS7_M0PR(value) ((MATRIX_PRAS7_M0PR_Msk & ((value) << MATRIX_PRAS7_M0PR_Pos)))
378 #define MATRIX_PRAS7_M1PR_Pos 4
379 #define MATRIX_PRAS7_M1PR_Msk (0x3u << MATRIX_PRAS7_M1PR_Pos)
380 #define MATRIX_PRAS7_M1PR(value) ((MATRIX_PRAS7_M1PR_Msk & ((value) << MATRIX_PRAS7_M1PR_Pos)))
381 #define MATRIX_PRAS7_M2PR_Pos 8
382 #define MATRIX_PRAS7_M2PR_Msk (0x3u << MATRIX_PRAS7_M2PR_Pos)
383 #define MATRIX_PRAS7_M2PR(value) ((MATRIX_PRAS7_M2PR_Msk & ((value) << MATRIX_PRAS7_M2PR_Pos)))
384 #define MATRIX_PRAS7_M3PR_Pos 12
385 #define MATRIX_PRAS7_M3PR_Msk (0x3u << MATRIX_PRAS7_M3PR_Pos)
386 #define MATRIX_PRAS7_M3PR(value) ((MATRIX_PRAS7_M3PR_Msk & ((value) << MATRIX_PRAS7_M3PR_Pos)))
387 #define MATRIX_PRAS7_M4PR_Pos 16
388 #define MATRIX_PRAS7_M4PR_Msk (0x3u << MATRIX_PRAS7_M4PR_Pos)
389 #define MATRIX_PRAS7_M4PR(value) ((MATRIX_PRAS7_M4PR_Msk & ((value) << MATRIX_PRAS7_M4PR_Pos)))
390 #define MATRIX_PRAS7_M5PR_Pos 20
391 #define MATRIX_PRAS7_M5PR_Msk (0x3u << MATRIX_PRAS7_M5PR_Pos)
392 #define MATRIX_PRAS7_M5PR(value) ((MATRIX_PRAS7_M5PR_Msk & ((value) << MATRIX_PRAS7_M5PR_Pos)))
393 #define MATRIX_PRAS7_M6PR_Pos 24
394 #define MATRIX_PRAS7_M6PR_Msk (0x3u << MATRIX_PRAS7_M6PR_Pos)
395 #define MATRIX_PRAS7_M6PR(value) ((MATRIX_PRAS7_M6PR_Msk & ((value) << MATRIX_PRAS7_M6PR_Pos)))
396 /* -------- MATRIX_PRBS7 : (MATRIX Offset: 0x00BC) Priority Register B for Slave 7 -------- */
397 #define MATRIX_PRBS7_M8PR_Pos 0
398 #define MATRIX_PRBS7_M8PR_Msk (0x3u << MATRIX_PRBS7_M8PR_Pos)
399 #define MATRIX_PRBS7_M8PR(value) ((MATRIX_PRBS7_M8PR_Msk & ((value) << MATRIX_PRBS7_M8PR_Pos)))
400 /* -------- MATRIX_PRAS8 : (MATRIX Offset: 0x00C0) Priority Register A for Slave 8 -------- */
401 #define MATRIX_PRAS8_M0PR_Pos 0
402 #define MATRIX_PRAS8_M0PR_Msk (0x3u << MATRIX_PRAS8_M0PR_Pos)
403 #define MATRIX_PRAS8_M0PR(value) ((MATRIX_PRAS8_M0PR_Msk & ((value) << MATRIX_PRAS8_M0PR_Pos)))
404 #define MATRIX_PRAS8_M1PR_Pos 4
405 #define MATRIX_PRAS8_M1PR_Msk (0x3u << MATRIX_PRAS8_M1PR_Pos)
406 #define MATRIX_PRAS8_M1PR(value) ((MATRIX_PRAS8_M1PR_Msk & ((value) << MATRIX_PRAS8_M1PR_Pos)))
407 #define MATRIX_PRAS8_M2PR_Pos 8
408 #define MATRIX_PRAS8_M2PR_Msk (0x3u << MATRIX_PRAS8_M2PR_Pos)
409 #define MATRIX_PRAS8_M2PR(value) ((MATRIX_PRAS8_M2PR_Msk & ((value) << MATRIX_PRAS8_M2PR_Pos)))
410 #define MATRIX_PRAS8_M3PR_Pos 12
411 #define MATRIX_PRAS8_M3PR_Msk (0x3u << MATRIX_PRAS8_M3PR_Pos)
412 #define MATRIX_PRAS8_M3PR(value) ((MATRIX_PRAS8_M3PR_Msk & ((value) << MATRIX_PRAS8_M3PR_Pos)))
413 #define MATRIX_PRAS8_M4PR_Pos 16
414 #define MATRIX_PRAS8_M4PR_Msk (0x3u << MATRIX_PRAS8_M4PR_Pos)
415 #define MATRIX_PRAS8_M4PR(value) ((MATRIX_PRAS8_M4PR_Msk & ((value) << MATRIX_PRAS8_M4PR_Pos)))
416 #define MATRIX_PRAS8_M5PR_Pos 20
417 #define MATRIX_PRAS8_M5PR_Msk (0x3u << MATRIX_PRAS8_M5PR_Pos)
418 #define MATRIX_PRAS8_M5PR(value) ((MATRIX_PRAS8_M5PR_Msk & ((value) << MATRIX_PRAS8_M5PR_Pos)))
419 #define MATRIX_PRAS8_M6PR_Pos 24
420 #define MATRIX_PRAS8_M6PR_Msk (0x3u << MATRIX_PRAS8_M6PR_Pos)
421 #define MATRIX_PRAS8_M6PR(value) ((MATRIX_PRAS8_M6PR_Msk & ((value) << MATRIX_PRAS8_M6PR_Pos)))
422 /* -------- MATRIX_PRBS8 : (MATRIX Offset: 0x00C4) Priority Register B for Slave 8 -------- */
423 #define MATRIX_PRBS8_M8PR_Pos 0
424 #define MATRIX_PRBS8_M8PR_Msk (0x3u << MATRIX_PRBS8_M8PR_Pos)
425 #define MATRIX_PRBS8_M8PR(value) ((MATRIX_PRBS8_M8PR_Msk & ((value) << MATRIX_PRBS8_M8PR_Pos)))
426 /* -------- MATRIX_MRCR : (MATRIX Offset: 0x0100) Master Remap Control Register -------- */
427 #define MATRIX_MRCR_RCB0 (0x1u << 0)
428 #define MATRIX_MRCR_RCB1 (0x1u << 1)
429 #define MATRIX_MRCR_RCB2 (0x1u << 2)
430 #define MATRIX_MRCR_RCB3 (0x1u << 3)
431 #define MATRIX_MRCR_RCB4 (0x1u << 4)
432 #define MATRIX_MRCR_RCB5 (0x1u << 5)
433 #define MATRIX_MRCR_RCB6 (0x1u << 6)
434 #define MATRIX_MRCR_RCB8 (0x1u << 8)
435 /* -------- CCFG_SYSIO : (MATRIX Offset: 0x0114) System I/O Configuration Register -------- */
436 #define CCFG_SYSIO_SYSIO4 (0x1u << 4)
437 #define CCFG_SYSIO_SYSIO5 (0x1u << 5)
438 #define CCFG_SYSIO_SYSIO6 (0x1u << 6)
439 #define CCFG_SYSIO_SYSIO7 (0x1u << 7)
440 #define CCFG_SYSIO_SYSIO12 (0x1u << 12)
441 /* -------- CCFG_SMCNFCS : (MATRIX Offset: 0x0124) SMC NAND Flash Chip Select Configuration Register -------- */
442 #define CCFG_SMCNFCS_SMC_NFCS0 (0x1u << 0)
443 #define CCFG_SMCNFCS_SMC_NFCS1 (0x1u << 1)
444 #define CCFG_SMCNFCS_SMC_NFCS2 (0x1u << 2)
445 #define CCFG_SMCNFCS_SMC_NFCS3 (0x1u << 3)
446 #define CCFG_SMCNFCS_SDRAMEN (0x1u << 4)
447 /* -------- MATRIX_WPMR : (MATRIX Offset: 0x01E4) Write Protection Mode Register -------- */
448 #define MATRIX_WPMR_WPEN (0x1u << 0)
449 #define MATRIX_WPMR_WPKEY_Pos 8
450 #define MATRIX_WPMR_WPKEY_Msk (0xffffffu << MATRIX_WPMR_WPKEY_Pos)
451 #define MATRIX_WPMR_WPKEY(value) ((MATRIX_WPMR_WPKEY_Msk & ((value) << MATRIX_WPMR_WPKEY_Pos)))
452 #define MATRIX_WPMR_WPKEY_PASSWD (0x4D4154u << 8)
453 /* -------- MATRIX_WPSR : (MATRIX Offset: 0x01E8) Write Protection Status Register -------- */
454 #define MATRIX_WPSR_WPVS (0x1u << 0)
455 #define MATRIX_WPSR_WPVSRC_Pos 8
456 #define MATRIX_WPSR_WPVSRC_Msk (0xffffu << MATRIX_WPSR_WPVSRC_Pos)
459
460
461 #endif /* _SAMS70_MATRIX_COMPONENT_ */
(Matrix Offset: 0x0090) Priority Register A for Slave 2
Definition: component_matrix.h:58
(Matrix Offset: 0x0094) Priority Register B for Slave 2
Definition: component_matrix.h:59
(Matrix Offset: 0x00A4) Priority Register B for Slave 4
Definition: component_matrix.h:63
(Matrix Offset: 0x00A8) Priority Register A for Slave 5
Definition: component_matrix.h:64
(Matrix Offset: 0x0098) Priority Register A for Slave 3
Definition: component_matrix.h:60
(Matrix Offset: 0x00C0) Priority Register A for Slave 8
Definition: component_matrix.h:70
#define __IO
Definition: core_cm7.h:287
(Matrix Offset: 0x00B4) Priority Register B for Slave 6
Definition: component_matrix.h:67
(Matrix Offset: 0x009C) Priority Register B for Slave 3
Definition: component_matrix.h:61
(Matrix Offset: 0x00B0) Priority Register A for Slave 6
Definition: component_matrix.h:66
(Matrix Offset: 0x0084) Priority Register B for Slave 0
Definition: component_matrix.h:55
(Matrix Offset: 0x008C) Priority Register B for Slave 1
Definition: component_matrix.h:57
(Matrix Offset: 0x00C4) Priority Register B for Slave 8
Definition: component_matrix.h:71
(Matrix Offset: 0x00B8) Priority Register A for Slave 7
Definition: component_matrix.h:68
(Matrix Offset: 0x0088) Priority Register A for Slave 1
Definition: component_matrix.h:56
Matrix hardware registers.
Definition: component_matrix.h:47
(Matrix Offset: 0x00AC) Priority Register B for Slave 5
Definition: component_matrix.h:65
(Matrix Offset: 0x0080) Priority Register A for Slave 0
Definition: component_matrix.h:54
(Matrix Offset: 0x00BC) Priority Register B for Slave 7
Definition: component_matrix.h:69
(Matrix Offset: 0x00A0) Priority Register A for Slave 4
Definition: component_matrix.h:62
#define __I
Definition: core_cm7.h:284
