RTEMS  5.1
component_hsmci.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAMS70_HSMCI_COMPONENT_
31 #define _SAMS70_HSMCI_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __O uint32_t HSMCI_CR;
43  __IO uint32_t HSMCI_MR;
44  __IO uint32_t HSMCI_DTOR;
45  __IO uint32_t HSMCI_SDCR;
46  __IO uint32_t HSMCI_ARGR;
47  __O uint32_t HSMCI_CMDR;
48  __IO uint32_t HSMCI_BLKR;
49  __IO uint32_t HSMCI_CSTOR;
50  __I uint32_t HSMCI_RSPR[4];
51  __I uint32_t HSMCI_RDR;
52  __O uint32_t HSMCI_TDR;
53  __I uint32_t Reserved1[2];
54  __I uint32_t HSMCI_SR;
55  __O uint32_t HSMCI_IER;
56  __O uint32_t HSMCI_IDR;
57  __I uint32_t HSMCI_IMR;
58  __IO uint32_t HSMCI_DMA;
59  __IO uint32_t HSMCI_CFG;
60  __I uint32_t Reserved2[35];
61  __IO uint32_t HSMCI_WPMR;
62  __I uint32_t HSMCI_WPSR;
63  __I uint32_t Reserved3[69];
64  __IO uint32_t HSMCI_FIFO[256];
65 } Hsmci;
66 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
67 /* -------- HSMCI_CR : (HSMCI Offset: 0x00) Control Register -------- */
68 #define HSMCI_CR_MCIEN (0x1u << 0)
69 #define HSMCI_CR_MCIDIS (0x1u << 1)
70 #define HSMCI_CR_PWSEN (0x1u << 2)
71 #define HSMCI_CR_PWSDIS (0x1u << 3)
72 #define HSMCI_CR_SWRST (0x1u << 7)
73 /* -------- HSMCI_MR : (HSMCI Offset: 0x04) Mode Register -------- */
74 #define HSMCI_MR_CLKDIV_Pos 0
75 #define HSMCI_MR_CLKDIV_Msk (0xffu << HSMCI_MR_CLKDIV_Pos)
76 #define HSMCI_MR_CLKDIV(value) ((HSMCI_MR_CLKDIV_Msk & ((value) << HSMCI_MR_CLKDIV_Pos)))
77 #define HSMCI_MR_PWSDIV_Pos 8
78 #define HSMCI_MR_PWSDIV_Msk (0x7u << HSMCI_MR_PWSDIV_Pos)
79 #define HSMCI_MR_PWSDIV(value) ((HSMCI_MR_PWSDIV_Msk & ((value) << HSMCI_MR_PWSDIV_Pos)))
80 #define HSMCI_MR_RDPROOF (0x1u << 11)
81 #define HSMCI_MR_WRPROOF (0x1u << 12)
82 #define HSMCI_MR_FBYTE (0x1u << 13)
83 #define HSMCI_MR_PADV (0x1u << 14)
84 #define HSMCI_MR_CLKODD (0x1u << 16)
85 /* -------- HSMCI_DTOR : (HSMCI Offset: 0x08) Data Timeout Register -------- */
86 #define HSMCI_DTOR_DTOCYC_Pos 0
87 #define HSMCI_DTOR_DTOCYC_Msk (0xfu << HSMCI_DTOR_DTOCYC_Pos)
88 #define HSMCI_DTOR_DTOCYC(value) ((HSMCI_DTOR_DTOCYC_Msk & ((value) << HSMCI_DTOR_DTOCYC_Pos)))
89 #define HSMCI_DTOR_DTOMUL_Pos 4
90 #define HSMCI_DTOR_DTOMUL_Msk (0x7u << HSMCI_DTOR_DTOMUL_Pos)
91 #define HSMCI_DTOR_DTOMUL(value) ((HSMCI_DTOR_DTOMUL_Msk & ((value) << HSMCI_DTOR_DTOMUL_Pos)))
92 #define HSMCI_DTOR_DTOMUL_1 (0x0u << 4)
93 #define HSMCI_DTOR_DTOMUL_16 (0x1u << 4)
94 #define HSMCI_DTOR_DTOMUL_128 (0x2u << 4)
95 #define HSMCI_DTOR_DTOMUL_256 (0x3u << 4)
96 #define HSMCI_DTOR_DTOMUL_1024 (0x4u << 4)
97 #define HSMCI_DTOR_DTOMUL_4096 (0x5u << 4)
98 #define HSMCI_DTOR_DTOMUL_65536 (0x6u << 4)
99 #define HSMCI_DTOR_DTOMUL_1048576 (0x7u << 4)
100 /* -------- HSMCI_SDCR : (HSMCI Offset: 0x0C) SD/SDIO Card Register -------- */
101 #define HSMCI_SDCR_SDCSEL_Pos 0
102 #define HSMCI_SDCR_SDCSEL_Msk (0x3u << HSMCI_SDCR_SDCSEL_Pos)
103 #define HSMCI_SDCR_SDCSEL(value) ((HSMCI_SDCR_SDCSEL_Msk & ((value) << HSMCI_SDCR_SDCSEL_Pos)))
104 #define HSMCI_SDCR_SDCSEL_SLOTA (0x0u << 0)
105 #define HSMCI_SDCR_SDCBUS_Pos 6
106 #define HSMCI_SDCR_SDCBUS_Msk (0x3u << HSMCI_SDCR_SDCBUS_Pos)
107 #define HSMCI_SDCR_SDCBUS(value) ((HSMCI_SDCR_SDCBUS_Msk & ((value) << HSMCI_SDCR_SDCBUS_Pos)))
108 #define HSMCI_SDCR_SDCBUS_1 (0x0u << 6)
109 #define HSMCI_SDCR_SDCBUS_4 (0x2u << 6)
110 #define HSMCI_SDCR_SDCBUS_8 (0x3u << 6)
111 /* -------- HSMCI_ARGR : (HSMCI Offset: 0x10) Argument Register -------- */
112 #define HSMCI_ARGR_ARG_Pos 0
113 #define HSMCI_ARGR_ARG_Msk (0xffffffffu << HSMCI_ARGR_ARG_Pos)
114 #define HSMCI_ARGR_ARG(value) ((HSMCI_ARGR_ARG_Msk & ((value) << HSMCI_ARGR_ARG_Pos)))
115 /* -------- HSMCI_CMDR : (HSMCI Offset: 0x14) Command Register -------- */
116 #define HSMCI_CMDR_CMDNB_Pos 0
117 #define HSMCI_CMDR_CMDNB_Msk (0x3fu << HSMCI_CMDR_CMDNB_Pos)
118 #define HSMCI_CMDR_CMDNB(value) ((HSMCI_CMDR_CMDNB_Msk & ((value) << HSMCI_CMDR_CMDNB_Pos)))
119 #define HSMCI_CMDR_RSPTYP_Pos 6
120 #define HSMCI_CMDR_RSPTYP_Msk (0x3u << HSMCI_CMDR_RSPTYP_Pos)
121 #define HSMCI_CMDR_RSPTYP(value) ((HSMCI_CMDR_RSPTYP_Msk & ((value) << HSMCI_CMDR_RSPTYP_Pos)))
122 #define HSMCI_CMDR_RSPTYP_NORESP (0x0u << 6)
123 #define HSMCI_CMDR_RSPTYP_48_BIT (0x1u << 6)
124 #define HSMCI_CMDR_RSPTYP_136_BIT (0x2u << 6)
125 #define HSMCI_CMDR_RSPTYP_R1B (0x3u << 6)
126 #define HSMCI_CMDR_SPCMD_Pos 8
127 #define HSMCI_CMDR_SPCMD_Msk (0x7u << HSMCI_CMDR_SPCMD_Pos)
128 #define HSMCI_CMDR_SPCMD(value) ((HSMCI_CMDR_SPCMD_Msk & ((value) << HSMCI_CMDR_SPCMD_Pos)))
129 #define HSMCI_CMDR_SPCMD_STD (0x0u << 8)
130 #define HSMCI_CMDR_SPCMD_INIT (0x1u << 8)
131 #define HSMCI_CMDR_SPCMD_SYNC (0x2u << 8)
132 #define HSMCI_CMDR_SPCMD_CE_ATA (0x3u << 8)
133 #define HSMCI_CMDR_SPCMD_IT_CMD (0x4u << 8)
134 #define HSMCI_CMDR_SPCMD_IT_RESP (0x5u << 8)
135 #define HSMCI_CMDR_SPCMD_BOR (0x6u << 8)
136 #define HSMCI_CMDR_SPCMD_EBO (0x7u << 8)
137 #define HSMCI_CMDR_OPDCMD (0x1u << 11)
138 #define HSMCI_CMDR_OPDCMD_PUSHPULL (0x0u << 11)
139 #define HSMCI_CMDR_OPDCMD_OPENDRAIN (0x1u << 11)
140 #define HSMCI_CMDR_MAXLAT (0x1u << 12)
141 #define HSMCI_CMDR_MAXLAT_5 (0x0u << 12)
142 #define HSMCI_CMDR_MAXLAT_64 (0x1u << 12)
143 #define HSMCI_CMDR_TRCMD_Pos 16
144 #define HSMCI_CMDR_TRCMD_Msk (0x3u << HSMCI_CMDR_TRCMD_Pos)
145 #define HSMCI_CMDR_TRCMD(value) ((HSMCI_CMDR_TRCMD_Msk & ((value) << HSMCI_CMDR_TRCMD_Pos)))
146 #define HSMCI_CMDR_TRCMD_NO_DATA (0x0u << 16)
147 #define HSMCI_CMDR_TRCMD_START_DATA (0x1u << 16)
148 #define HSMCI_CMDR_TRCMD_STOP_DATA (0x2u << 16)
149 #define HSMCI_CMDR_TRDIR (0x1u << 18)
150 #define HSMCI_CMDR_TRDIR_WRITE (0x0u << 18)
151 #define HSMCI_CMDR_TRDIR_READ (0x1u << 18)
152 #define HSMCI_CMDR_TRTYP_Pos 19
153 #define HSMCI_CMDR_TRTYP_Msk (0x7u << HSMCI_CMDR_TRTYP_Pos)
154 #define HSMCI_CMDR_TRTYP(value) ((HSMCI_CMDR_TRTYP_Msk & ((value) << HSMCI_CMDR_TRTYP_Pos)))
155 #define HSMCI_CMDR_TRTYP_SINGLE (0x0u << 19)
156 #define HSMCI_CMDR_TRTYP_MULTIPLE (0x1u << 19)
157 #define HSMCI_CMDR_TRTYP_STREAM (0x2u << 19)
158 #define HSMCI_CMDR_TRTYP_BYTE (0x4u << 19)
159 #define HSMCI_CMDR_TRTYP_BLOCK (0x5u << 19)
160 #define HSMCI_CMDR_IOSPCMD_Pos 24
161 #define HSMCI_CMDR_IOSPCMD_Msk (0x3u << HSMCI_CMDR_IOSPCMD_Pos)
162 #define HSMCI_CMDR_IOSPCMD(value) ((HSMCI_CMDR_IOSPCMD_Msk & ((value) << HSMCI_CMDR_IOSPCMD_Pos)))
163 #define HSMCI_CMDR_IOSPCMD_STD (0x0u << 24)
164 #define HSMCI_CMDR_IOSPCMD_SUSPEND (0x1u << 24)
165 #define HSMCI_CMDR_IOSPCMD_RESUME (0x2u << 24)
166 #define HSMCI_CMDR_ATACS (0x1u << 26)
167 #define HSMCI_CMDR_ATACS_NORMAL (0x0u << 26)
168 #define HSMCI_CMDR_ATACS_COMPLETION (0x1u << 26)
169 #define HSMCI_CMDR_BOOT_ACK (0x1u << 27)
170 /* -------- HSMCI_BLKR : (HSMCI Offset: 0x18) Block Register -------- */
171 #define HSMCI_BLKR_BCNT_Pos 0
172 #define HSMCI_BLKR_BCNT_Msk (0xffffu << HSMCI_BLKR_BCNT_Pos)
173 #define HSMCI_BLKR_BCNT(value) ((HSMCI_BLKR_BCNT_Msk & ((value) << HSMCI_BLKR_BCNT_Pos)))
174 #define HSMCI_BLKR_BLKLEN_Pos 16
175 #define HSMCI_BLKR_BLKLEN_Msk (0xffffu << HSMCI_BLKR_BLKLEN_Pos)
176 #define HSMCI_BLKR_BLKLEN(value) ((HSMCI_BLKR_BLKLEN_Msk & ((value) << HSMCI_BLKR_BLKLEN_Pos)))
177 /* -------- HSMCI_CSTOR : (HSMCI Offset: 0x1C) Completion Signal Timeout Register -------- */
178 #define HSMCI_CSTOR_CSTOCYC_Pos 0
179 #define HSMCI_CSTOR_CSTOCYC_Msk (0xfu << HSMCI_CSTOR_CSTOCYC_Pos)
180 #define HSMCI_CSTOR_CSTOCYC(value) ((HSMCI_CSTOR_CSTOCYC_Msk & ((value) << HSMCI_CSTOR_CSTOCYC_Pos)))
181 #define HSMCI_CSTOR_CSTOMUL_Pos 4
182 #define HSMCI_CSTOR_CSTOMUL_Msk (0x7u << HSMCI_CSTOR_CSTOMUL_Pos)
183 #define HSMCI_CSTOR_CSTOMUL(value) ((HSMCI_CSTOR_CSTOMUL_Msk & ((value) << HSMCI_CSTOR_CSTOMUL_Pos)))
184 #define HSMCI_CSTOR_CSTOMUL_1 (0x0u << 4)
185 #define HSMCI_CSTOR_CSTOMUL_16 (0x1u << 4)
186 #define HSMCI_CSTOR_CSTOMUL_128 (0x2u << 4)
187 #define HSMCI_CSTOR_CSTOMUL_256 (0x3u << 4)
188 #define HSMCI_CSTOR_CSTOMUL_1024 (0x4u << 4)
189 #define HSMCI_CSTOR_CSTOMUL_4096 (0x5u << 4)
190 #define HSMCI_CSTOR_CSTOMUL_65536 (0x6u << 4)
191 #define HSMCI_CSTOR_CSTOMUL_1048576 (0x7u << 4)
192 /* -------- HSMCI_RSPR[4] : (HSMCI Offset: 0x20) Response Register -------- */
193 #define HSMCI_RSPR_RSP_Pos 0
194 #define HSMCI_RSPR_RSP_Msk (0xffffffffu << HSMCI_RSPR_RSP_Pos)
195 /* -------- HSMCI_RDR : (HSMCI Offset: 0x30) Receive Data Register -------- */
196 #define HSMCI_RDR_DATA_Pos 0
197 #define HSMCI_RDR_DATA_Msk (0xffffffffu << HSMCI_RDR_DATA_Pos)
198 /* -------- HSMCI_TDR : (HSMCI Offset: 0x34) Transmit Data Register -------- */
199 #define HSMCI_TDR_DATA_Pos 0
200 #define HSMCI_TDR_DATA_Msk (0xffffffffu << HSMCI_TDR_DATA_Pos)
201 #define HSMCI_TDR_DATA(value) ((HSMCI_TDR_DATA_Msk & ((value) << HSMCI_TDR_DATA_Pos)))
202 /* -------- HSMCI_SR : (HSMCI Offset: 0x40) Status Register -------- */
203 #define HSMCI_SR_CMDRDY (0x1u << 0)
204 #define HSMCI_SR_RXRDY (0x1u << 1)
205 #define HSMCI_SR_TXRDY (0x1u << 2)
206 #define HSMCI_SR_BLKE (0x1u << 3)
207 #define HSMCI_SR_DTIP (0x1u << 4)
208 #define HSMCI_SR_NOTBUSY (0x1u << 5)
209 #define HSMCI_SR_SDIOIRQA (0x1u << 8)
210 #define HSMCI_SR_SDIOWAIT (0x1u << 12)
211 #define HSMCI_SR_CSRCV (0x1u << 13)
212 #define HSMCI_SR_RINDE (0x1u << 16)
213 #define HSMCI_SR_RDIRE (0x1u << 17)
214 #define HSMCI_SR_RCRCE (0x1u << 18)
215 #define HSMCI_SR_RENDE (0x1u << 19)
216 #define HSMCI_SR_RTOE (0x1u << 20)
217 #define HSMCI_SR_DCRCE (0x1u << 21)
218 #define HSMCI_SR_DTOE (0x1u << 22)
219 #define HSMCI_SR_CSTOE (0x1u << 23)
220 #define HSMCI_SR_BLKOVRE (0x1u << 24)
221 #define HSMCI_SR_FIFOEMPTY (0x1u << 26)
222 #define HSMCI_SR_XFRDONE (0x1u << 27)
223 #define HSMCI_SR_ACKRCV (0x1u << 28)
224 #define HSMCI_SR_ACKRCVE (0x1u << 29)
225 #define HSMCI_SR_OVRE (0x1u << 30)
226 #define HSMCI_SR_UNRE (0x1u << 31)
227 /* -------- HSMCI_IER : (HSMCI Offset: 0x44) Interrupt Enable Register -------- */
228 #define HSMCI_IER_CMDRDY (0x1u << 0)
229 #define HSMCI_IER_RXRDY (0x1u << 1)
230 #define HSMCI_IER_TXRDY (0x1u << 2)
231 #define HSMCI_IER_BLKE (0x1u << 3)
232 #define HSMCI_IER_DTIP (0x1u << 4)
233 #define HSMCI_IER_NOTBUSY (0x1u << 5)
234 #define HSMCI_IER_SDIOIRQA (0x1u << 8)
235 #define HSMCI_IER_SDIOWAIT (0x1u << 12)
236 #define HSMCI_IER_CSRCV (0x1u << 13)
237 #define HSMCI_IER_RINDE (0x1u << 16)
238 #define HSMCI_IER_RDIRE (0x1u << 17)
239 #define HSMCI_IER_RCRCE (0x1u << 18)
240 #define HSMCI_IER_RENDE (0x1u << 19)
241 #define HSMCI_IER_RTOE (0x1u << 20)
242 #define HSMCI_IER_DCRCE (0x1u << 21)
243 #define HSMCI_IER_DTOE (0x1u << 22)
244 #define HSMCI_IER_CSTOE (0x1u << 23)
245 #define HSMCI_IER_BLKOVRE (0x1u << 24)
246 #define HSMCI_IER_FIFOEMPTY (0x1u << 26)
247 #define HSMCI_IER_XFRDONE (0x1u << 27)
248 #define HSMCI_IER_ACKRCV (0x1u << 28)
249 #define HSMCI_IER_ACKRCVE (0x1u << 29)
250 #define HSMCI_IER_OVRE (0x1u << 30)
251 #define HSMCI_IER_UNRE (0x1u << 31)
252 /* -------- HSMCI_IDR : (HSMCI Offset: 0x48) Interrupt Disable Register -------- */
253 #define HSMCI_IDR_CMDRDY (0x1u << 0)
254 #define HSMCI_IDR_RXRDY (0x1u << 1)
255 #define HSMCI_IDR_TXRDY (0x1u << 2)
256 #define HSMCI_IDR_BLKE (0x1u << 3)
257 #define HSMCI_IDR_DTIP (0x1u << 4)
258 #define HSMCI_IDR_NOTBUSY (0x1u << 5)
259 #define HSMCI_IDR_SDIOIRQA (0x1u << 8)
260 #define HSMCI_IDR_SDIOWAIT (0x1u << 12)
261 #define HSMCI_IDR_CSRCV (0x1u << 13)
262 #define HSMCI_IDR_RINDE (0x1u << 16)
263 #define HSMCI_IDR_RDIRE (0x1u << 17)
264 #define HSMCI_IDR_RCRCE (0x1u << 18)
265 #define HSMCI_IDR_RENDE (0x1u << 19)
266 #define HSMCI_IDR_RTOE (0x1u << 20)
267 #define HSMCI_IDR_DCRCE (0x1u << 21)
268 #define HSMCI_IDR_DTOE (0x1u << 22)
269 #define HSMCI_IDR_CSTOE (0x1u << 23)
270 #define HSMCI_IDR_BLKOVRE (0x1u << 24)
271 #define HSMCI_IDR_FIFOEMPTY (0x1u << 26)
272 #define HSMCI_IDR_XFRDONE (0x1u << 27)
273 #define HSMCI_IDR_ACKRCV (0x1u << 28)
274 #define HSMCI_IDR_ACKRCVE (0x1u << 29)
275 #define HSMCI_IDR_OVRE (0x1u << 30)
276 #define HSMCI_IDR_UNRE (0x1u << 31)
277 /* -------- HSMCI_IMR : (HSMCI Offset: 0x4C) Interrupt Mask Register -------- */
278 #define HSMCI_IMR_CMDRDY (0x1u << 0)
279 #define HSMCI_IMR_RXRDY (0x1u << 1)
280 #define HSMCI_IMR_TXRDY (0x1u << 2)
281 #define HSMCI_IMR_BLKE (0x1u << 3)
282 #define HSMCI_IMR_DTIP (0x1u << 4)
283 #define HSMCI_IMR_NOTBUSY (0x1u << 5)
284 #define HSMCI_IMR_SDIOIRQA (0x1u << 8)
285 #define HSMCI_IMR_SDIOWAIT (0x1u << 12)
286 #define HSMCI_IMR_CSRCV (0x1u << 13)
287 #define HSMCI_IMR_RINDE (0x1u << 16)
288 #define HSMCI_IMR_RDIRE (0x1u << 17)
289 #define HSMCI_IMR_RCRCE (0x1u << 18)
290 #define HSMCI_IMR_RENDE (0x1u << 19)
291 #define HSMCI_IMR_RTOE (0x1u << 20)
292 #define HSMCI_IMR_DCRCE (0x1u << 21)
293 #define HSMCI_IMR_DTOE (0x1u << 22)
294 #define HSMCI_IMR_CSTOE (0x1u << 23)
295 #define HSMCI_IMR_BLKOVRE (0x1u << 24)
296 #define HSMCI_IMR_FIFOEMPTY (0x1u << 26)
297 #define HSMCI_IMR_XFRDONE (0x1u << 27)
298 #define HSMCI_IMR_ACKRCV (0x1u << 28)
299 #define HSMCI_IMR_ACKRCVE (0x1u << 29)
300 #define HSMCI_IMR_OVRE (0x1u << 30)
301 #define HSMCI_IMR_UNRE (0x1u << 31)
302 /* -------- HSMCI_DMA : (HSMCI Offset: 0x50) DMA Configuration Register -------- */
303 #define HSMCI_DMA_CHKSIZE_Pos 4
304 #define HSMCI_DMA_CHKSIZE_Msk (0x7u << HSMCI_DMA_CHKSIZE_Pos)
305 #define HSMCI_DMA_CHKSIZE(value) ((HSMCI_DMA_CHKSIZE_Msk & ((value) << HSMCI_DMA_CHKSIZE_Pos)))
306 #define HSMCI_DMA_CHKSIZE_1 (0x0u << 4)
307 #define HSMCI_DMA_CHKSIZE_2 (0x1u << 4)
308 #define HSMCI_DMA_CHKSIZE_4 (0x2u << 4)
309 #define HSMCI_DMA_CHKSIZE_8 (0x3u << 4)
310 #define HSMCI_DMA_CHKSIZE_16 (0x4u << 4)
311 #define HSMCI_DMA_DMAEN (0x1u << 8)
312 /* -------- HSMCI_CFG : (HSMCI Offset: 0x54) Configuration Register -------- */
313 #define HSMCI_CFG_FIFOMODE (0x1u << 0)
314 #define HSMCI_CFG_FERRCTRL (0x1u << 4)
315 #define HSMCI_CFG_HSMODE (0x1u << 8)
316 #define HSMCI_CFG_LSYNC (0x1u << 12)
317 /* -------- HSMCI_WPMR : (HSMCI Offset: 0xE4) Write Protection Mode Register -------- */
318 #define HSMCI_WPMR_WPEN (0x1u << 0)
319 #define HSMCI_WPMR_WPKEY_Pos 8
320 #define HSMCI_WPMR_WPKEY_Msk (0xffffffu << HSMCI_WPMR_WPKEY_Pos)
321 #define HSMCI_WPMR_WPKEY(value) ((HSMCI_WPMR_WPKEY_Msk & ((value) << HSMCI_WPMR_WPKEY_Pos)))
322 #define HSMCI_WPMR_WPKEY_PASSWD (0x4D4349u << 8)
323 /* -------- HSMCI_WPSR : (HSMCI Offset: 0xE8) Write Protection Status Register -------- */
324 #define HSMCI_WPSR_WPVS (0x1u << 0)
325 #define HSMCI_WPSR_WPVSRC_Pos 8
326 #define HSMCI_WPSR_WPVSRC_Msk (0xffffu << HSMCI_WPSR_WPVSRC_Pos)
327 /* -------- HSMCI_FIFO[256] : (HSMCI Offset: 0x200) FIFO Memory Aperture0 -------- */
328 #define HSMCI_FIFO_DATA_Pos 0
329 #define HSMCI_FIFO_DATA_Msk (0xffffffffu << HSMCI_FIFO_DATA_Pos)
330 #define HSMCI_FIFO_DATA(value) ((HSMCI_FIFO_DATA_Msk & ((value) << HSMCI_FIFO_DATA_Pos)))
331
335 #endif /* _SAMS70_HSMCI_COMPONENT_ */
#define __IO
Definition: core_cm7.h:287
#define __O
Definition: core_cm7.h:286
Hsmci hardware registers.
Definition: component_hsmci.h:41
#define __I
Definition: core_cm7.h:284
