RTEMS  5.1
component_acc.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAMS70_ACC_COMPONENT_
31 #define _SAMS70_ACC_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __O uint32_t ACC_CR;
43  __IO uint32_t ACC_MR;
44  __I uint32_t Reserved1[7];
45  __O uint32_t ACC_IER;
46  __O uint32_t ACC_IDR;
47  __I uint32_t ACC_IMR;
48  __I uint32_t ACC_ISR;
49  __I uint32_t Reserved2[24];
50  __IO uint32_t ACC_ACR;
51  __I uint32_t Reserved3[19];
52  __IO uint32_t ACC_WPMR;
53  __I uint32_t ACC_WPSR;
54 } Acc;
55 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
56 /* -------- ACC_CR : (ACC Offset: 0x00) Control Register -------- */
57 #define ACC_CR_SWRST (0x1u << 0)
58 /* -------- ACC_MR : (ACC Offset: 0x04) Mode Register -------- */
59 #define ACC_MR_SELMINUS_Pos 0
60 #define ACC_MR_SELMINUS_Msk (0x7u << ACC_MR_SELMINUS_Pos)
61 #define ACC_MR_SELMINUS(value) ((ACC_MR_SELMINUS_Msk & ((value) << ACC_MR_SELMINUS_Pos)))
62 #define ACC_MR_SELMINUS_TS (0x0u << 0)
63 #define ACC_MR_SELMINUS_VREFP (0x1u << 0)
64 #define ACC_MR_SELMINUS_DAC0 (0x2u << 0)
65 #define ACC_MR_SELMINUS_DAC1 (0x3u << 0)
66 #define ACC_MR_SELMINUS_AFE0_AD0 (0x4u << 0)
67 #define ACC_MR_SELMINUS_AFE0_AD1 (0x5u << 0)
68 #define ACC_MR_SELMINUS_AFE0_AD2 (0x6u << 0)
69 #define ACC_MR_SELMINUS_AFE0_AD3 (0x7u << 0)
70 #define ACC_MR_SELPLUS_Pos 4
71 #define ACC_MR_SELPLUS_Msk (0x7u << ACC_MR_SELPLUS_Pos)
72 #define ACC_MR_SELPLUS(value) ((ACC_MR_SELPLUS_Msk & ((value) << ACC_MR_SELPLUS_Pos)))
73 #define ACC_MR_SELPLUS_AFE0_AD0 (0x0u << 4)
74 #define ACC_MR_SELPLUS_AFE0_AD1 (0x1u << 4)
75 #define ACC_MR_SELPLUS_AFE0_AD2 (0x2u << 4)
76 #define ACC_MR_SELPLUS_AFE0_AD3 (0x3u << 4)
77 #define ACC_MR_SELPLUS_AFE0_AD4 (0x4u << 4)
78 #define ACC_MR_SELPLUS_AFE0_AD5 (0x5u << 4)
79 #define ACC_MR_SELPLUS_AFE1_AD0 (0x6u << 4)
80 #define ACC_MR_SELPLUS_AFE1_AD1 (0x7u << 4)
81 #define ACC_MR_ACEN (0x1u << 8)
82 #define ACC_MR_ACEN_DIS (0x0u << 8)
83 #define ACC_MR_ACEN_EN (0x1u << 8)
84 #define ACC_MR_EDGETYP_Pos 9
85 #define ACC_MR_EDGETYP_Msk (0x3u << ACC_MR_EDGETYP_Pos)
86 #define ACC_MR_EDGETYP(value) ((ACC_MR_EDGETYP_Msk & ((value) << ACC_MR_EDGETYP_Pos)))
87 #define ACC_MR_EDGETYP_RISING (0x0u << 9)
88 #define ACC_MR_EDGETYP_FALLING (0x1u << 9)
89 #define ACC_MR_EDGETYP_ANY (0x2u << 9)
90 #define ACC_MR_INV (0x1u << 12)
91 #define ACC_MR_INV_DIS (0x0u << 12)
92 #define ACC_MR_INV_EN (0x1u << 12)
93 #define ACC_MR_SELFS (0x1u << 13)
94 #define ACC_MR_SELFS_CE (0x0u << 13)
95 #define ACC_MR_SELFS_OUTPUT (0x1u << 13)
96 #define ACC_MR_FE (0x1u << 14)
97 #define ACC_MR_FE_DIS (0x0u << 14)
98 #define ACC_MR_FE_EN (0x1u << 14)
99 /* -------- ACC_IER : (ACC Offset: 0x24) Interrupt Enable Register -------- */
100 #define ACC_IER_CE (0x1u << 0)
101 /* -------- ACC_IDR : (ACC Offset: 0x28) Interrupt Disable Register -------- */
102 #define ACC_IDR_CE (0x1u << 0)
103 /* -------- ACC_IMR : (ACC Offset: 0x2C) Interrupt Mask Register -------- */
104 #define ACC_IMR_CE (0x1u << 0)
105 /* -------- ACC_ISR : (ACC Offset: 0x30) Interrupt Status Register -------- */
106 #define ACC_ISR_CE (0x1u << 0)
107 #define ACC_ISR_SCO (0x1u << 1)
108 #define ACC_ISR_MASK (0x1u << 31)
109 /* -------- ACC_ACR : (ACC Offset: 0x94) Analog Control Register -------- */
110 #define ACC_ACR_ISEL (0x1u << 0)
111 #define ACC_ACR_ISEL_LOPW (0x0u << 0)
112 #define ACC_ACR_ISEL_HISP (0x1u << 0)
113 #define ACC_ACR_HYST_Pos 1
114 #define ACC_ACR_HYST_Msk (0x3u << ACC_ACR_HYST_Pos)
115 #define ACC_ACR_HYST(value) ((ACC_ACR_HYST_Msk & ((value) << ACC_ACR_HYST_Pos)))
116 /* -------- ACC_WPMR : (ACC Offset: 0xE4) Write Protection Mode Register -------- */
117 #define ACC_WPMR_WPEN (0x1u << 0)
118 #define ACC_WPMR_WPKEY_Pos 8
119 #define ACC_WPMR_WPKEY_Msk (0xffffffu << ACC_WPMR_WPKEY_Pos)
120 #define ACC_WPMR_WPKEY(value) ((ACC_WPMR_WPKEY_Msk & ((value) << ACC_WPMR_WPKEY_Pos)))
121 #define ACC_WPMR_WPKEY_PASSWD (0x414343u << 8)
122 /* -------- ACC_WPSR : (ACC Offset: 0xE8) Write Protection Status Register -------- */
123 #define ACC_WPSR_WPVS (0x1u << 0)
126
127
128 #endif /* _SAMS70_ACC_COMPONENT_ */
#define __IO
Definition: core_cm7.h:287
#define __O
Definition: core_cm7.h:286
Acc hardware registers.
Definition: component_acc.h:41
#define __I
Definition: core_cm7.h:284
