RTEMS  5.1
component_xdmac.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAME70_XDMAC_COMPONENT_
31 #define _SAME70_XDMAC_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __O uint32_t XDMAC_CIE;
43  __O uint32_t XDMAC_CID;
44  __O uint32_t XDMAC_CIM;
45  __I uint32_t XDMAC_CIS;
46  __IO uint32_t XDMAC_CSA;
47  __IO uint32_t XDMAC_CDA;
48  __IO uint32_t XDMAC_CNDA;
49  __IO uint32_t XDMAC_CNDC;
50  __IO uint32_t XDMAC_CUBC;
51  __IO uint32_t XDMAC_CBC;
52  __IO uint32_t XDMAC_CC;
53  __IO uint32_t XDMAC_CDS_MSP;
54  __IO uint32_t XDMAC_CSUS;
55  __IO uint32_t XDMAC_CDUS;
56  __I uint32_t Reserved1[2];
57 } XdmacChid;
59 #define XDMACCHID_NUMBER 24
60 typedef struct {
61  __IO uint32_t XDMAC_GTYPE;
62  __I uint32_t XDMAC_GCFG;
63  __IO uint32_t XDMAC_GWAC;
64  __O uint32_t XDMAC_GIE;
65  __O uint32_t XDMAC_GID;
66  __I uint32_t XDMAC_GIM;
67  __I uint32_t XDMAC_GIS;
68  __O uint32_t XDMAC_GE;
69  __O uint32_t XDMAC_GD;
70  __I uint32_t XDMAC_GS;
71  __IO uint32_t XDMAC_GRS;
72  __IO uint32_t XDMAC_GWS;
73  __O uint32_t XDMAC_GRWS;
74  __O uint32_t XDMAC_GRWR;
75  __O uint32_t XDMAC_GSWR;
76  __I uint32_t XDMAC_GSWS;
77  __O uint32_t XDMAC_GSWF;
78  __I uint32_t Reserved1[3];
80 } Xdmac;
81 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
82 /* -------- XDMAC_GTYPE : (XDMAC Offset: 0x00) Global Type Register -------- */
83 #define XDMAC_GTYPE_NB_CH_Pos 0
84 #define XDMAC_GTYPE_NB_CH_Msk (0x1fu << XDMAC_GTYPE_NB_CH_Pos)
85 #define XDMAC_GTYPE_NB_CH(value) ((XDMAC_GTYPE_NB_CH_Msk & ((value) << XDMAC_GTYPE_NB_CH_Pos)))
86 #define XDMAC_GTYPE_FIFO_SZ_Pos 5
87 #define XDMAC_GTYPE_FIFO_SZ_Msk (0x7ffu << XDMAC_GTYPE_FIFO_SZ_Pos)
88 #define XDMAC_GTYPE_FIFO_SZ(value) ((XDMAC_GTYPE_FIFO_SZ_Msk & ((value) << XDMAC_GTYPE_FIFO_SZ_Pos)))
89 #define XDMAC_GTYPE_NB_REQ_Pos 16
90 #define XDMAC_GTYPE_NB_REQ_Msk (0x7fu << XDMAC_GTYPE_NB_REQ_Pos)
91 #define XDMAC_GTYPE_NB_REQ(value) ((XDMAC_GTYPE_NB_REQ_Msk & ((value) << XDMAC_GTYPE_NB_REQ_Pos)))
92 /* -------- XDMAC_GCFG : (XDMAC Offset: 0x04) Global Configuration Register -------- */
93 #define XDMAC_GCFG_CGDISREG (0x1u << 0)
94 #define XDMAC_GCFG_CGDISPIPE (0x1u << 1)
95 #define XDMAC_GCFG_CGDISFIFO (0x1u << 2)
96 #define XDMAC_GCFG_CGDISIF (0x1u << 3)
97 #define XDMAC_GCFG_BXKBEN (0x1u << 8)
98 /* -------- XDMAC_GWAC : (XDMAC Offset: 0x08) Global Weighted Arbiter Configuration Register -------- */
99 #define XDMAC_GWAC_PW0_Pos 0
100 #define XDMAC_GWAC_PW0_Msk (0xfu << XDMAC_GWAC_PW0_Pos)
101 #define XDMAC_GWAC_PW0(value) ((XDMAC_GWAC_PW0_Msk & ((value) << XDMAC_GWAC_PW0_Pos)))
102 #define XDMAC_GWAC_PW1_Pos 4
103 #define XDMAC_GWAC_PW1_Msk (0xfu << XDMAC_GWAC_PW1_Pos)
104 #define XDMAC_GWAC_PW1(value) ((XDMAC_GWAC_PW1_Msk & ((value) << XDMAC_GWAC_PW1_Pos)))
105 #define XDMAC_GWAC_PW2_Pos 8
106 #define XDMAC_GWAC_PW2_Msk (0xfu << XDMAC_GWAC_PW2_Pos)
107 #define XDMAC_GWAC_PW2(value) ((XDMAC_GWAC_PW2_Msk & ((value) << XDMAC_GWAC_PW2_Pos)))
108 #define XDMAC_GWAC_PW3_Pos 12
109 #define XDMAC_GWAC_PW3_Msk (0xfu << XDMAC_GWAC_PW3_Pos)
110 #define XDMAC_GWAC_PW3(value) ((XDMAC_GWAC_PW3_Msk & ((value) << XDMAC_GWAC_PW3_Pos)))
111 /* -------- XDMAC_GIE : (XDMAC Offset: 0x0C) Global Interrupt Enable Register -------- */
112 #define XDMAC_GIE_IE0 (0x1u << 0)
113 #define XDMAC_GIE_IE1 (0x1u << 1)
114 #define XDMAC_GIE_IE2 (0x1u << 2)
115 #define XDMAC_GIE_IE3 (0x1u << 3)
116 #define XDMAC_GIE_IE4 (0x1u << 4)
117 #define XDMAC_GIE_IE5 (0x1u << 5)
118 #define XDMAC_GIE_IE6 (0x1u << 6)
119 #define XDMAC_GIE_IE7 (0x1u << 7)
120 #define XDMAC_GIE_IE8 (0x1u << 8)
121 #define XDMAC_GIE_IE9 (0x1u << 9)
122 #define XDMAC_GIE_IE10 (0x1u << 10)
123 #define XDMAC_GIE_IE11 (0x1u << 11)
124 #define XDMAC_GIE_IE12 (0x1u << 12)
125 #define XDMAC_GIE_IE13 (0x1u << 13)
126 #define XDMAC_GIE_IE14 (0x1u << 14)
127 #define XDMAC_GIE_IE15 (0x1u << 15)
128 #define XDMAC_GIE_IE16 (0x1u << 16)
129 #define XDMAC_GIE_IE17 (0x1u << 17)
130 #define XDMAC_GIE_IE18 (0x1u << 18)
131 #define XDMAC_GIE_IE19 (0x1u << 19)
132 #define XDMAC_GIE_IE20 (0x1u << 20)
133 #define XDMAC_GIE_IE21 (0x1u << 21)
134 #define XDMAC_GIE_IE22 (0x1u << 22)
135 #define XDMAC_GIE_IE23 (0x1u << 23)
136 /* -------- XDMAC_GID : (XDMAC Offset: 0x10) Global Interrupt Disable Register -------- */
137 #define XDMAC_GID_ID0 (0x1u << 0)
138 #define XDMAC_GID_ID1 (0x1u << 1)
139 #define XDMAC_GID_ID2 (0x1u << 2)
140 #define XDMAC_GID_ID3 (0x1u << 3)
141 #define XDMAC_GID_ID4 (0x1u << 4)
142 #define XDMAC_GID_ID5 (0x1u << 5)
143 #define XDMAC_GID_ID6 (0x1u << 6)
144 #define XDMAC_GID_ID7 (0x1u << 7)
145 #define XDMAC_GID_ID8 (0x1u << 8)
146 #define XDMAC_GID_ID9 (0x1u << 9)
147 #define XDMAC_GID_ID10 (0x1u << 10)
148 #define XDMAC_GID_ID11 (0x1u << 11)
149 #define XDMAC_GID_ID12 (0x1u << 12)
150 #define XDMAC_GID_ID13 (0x1u << 13)
151 #define XDMAC_GID_ID14 (0x1u << 14)
152 #define XDMAC_GID_ID15 (0x1u << 15)
153 #define XDMAC_GID_ID16 (0x1u << 16)
154 #define XDMAC_GID_ID17 (0x1u << 17)
155 #define XDMAC_GID_ID18 (0x1u << 18)
156 #define XDMAC_GID_ID19 (0x1u << 19)
157 #define XDMAC_GID_ID20 (0x1u << 20)
158 #define XDMAC_GID_ID21 (0x1u << 21)
159 #define XDMAC_GID_ID22 (0x1u << 22)
160 #define XDMAC_GID_ID23 (0x1u << 23)
161 /* -------- XDMAC_GIM : (XDMAC Offset: 0x14) Global Interrupt Mask Register -------- */
162 #define XDMAC_GIM_IM0 (0x1u << 0)
163 #define XDMAC_GIM_IM1 (0x1u << 1)
164 #define XDMAC_GIM_IM2 (0x1u << 2)
165 #define XDMAC_GIM_IM3 (0x1u << 3)
166 #define XDMAC_GIM_IM4 (0x1u << 4)
167 #define XDMAC_GIM_IM5 (0x1u << 5)
168 #define XDMAC_GIM_IM6 (0x1u << 6)
169 #define XDMAC_GIM_IM7 (0x1u << 7)
170 #define XDMAC_GIM_IM8 (0x1u << 8)
171 #define XDMAC_GIM_IM9 (0x1u << 9)
172 #define XDMAC_GIM_IM10 (0x1u << 10)
173 #define XDMAC_GIM_IM11 (0x1u << 11)
174 #define XDMAC_GIM_IM12 (0x1u << 12)
175 #define XDMAC_GIM_IM13 (0x1u << 13)
176 #define XDMAC_GIM_IM14 (0x1u << 14)
177 #define XDMAC_GIM_IM15 (0x1u << 15)
178 #define XDMAC_GIM_IM16 (0x1u << 16)
179 #define XDMAC_GIM_IM17 (0x1u << 17)
180 #define XDMAC_GIM_IM18 (0x1u << 18)
181 #define XDMAC_GIM_IM19 (0x1u << 19)
182 #define XDMAC_GIM_IM20 (0x1u << 20)
183 #define XDMAC_GIM_IM21 (0x1u << 21)
184 #define XDMAC_GIM_IM22 (0x1u << 22)
185 #define XDMAC_GIM_IM23 (0x1u << 23)
186 /* -------- XDMAC_GIS : (XDMAC Offset: 0x18) Global Interrupt Status Register -------- */
187 #define XDMAC_GIS_IS0 (0x1u << 0)
188 #define XDMAC_GIS_IS1 (0x1u << 1)
189 #define XDMAC_GIS_IS2 (0x1u << 2)
190 #define XDMAC_GIS_IS3 (0x1u << 3)
191 #define XDMAC_GIS_IS4 (0x1u << 4)
192 #define XDMAC_GIS_IS5 (0x1u << 5)
193 #define XDMAC_GIS_IS6 (0x1u << 6)
194 #define XDMAC_GIS_IS7 (0x1u << 7)
195 #define XDMAC_GIS_IS8 (0x1u << 8)
196 #define XDMAC_GIS_IS9 (0x1u << 9)
197 #define XDMAC_GIS_IS10 (0x1u << 10)
198 #define XDMAC_GIS_IS11 (0x1u << 11)
199 #define XDMAC_GIS_IS12 (0x1u << 12)
200 #define XDMAC_GIS_IS13 (0x1u << 13)
201 #define XDMAC_GIS_IS14 (0x1u << 14)
202 #define XDMAC_GIS_IS15 (0x1u << 15)
203 #define XDMAC_GIS_IS16 (0x1u << 16)
204 #define XDMAC_GIS_IS17 (0x1u << 17)
205 #define XDMAC_GIS_IS18 (0x1u << 18)
206 #define XDMAC_GIS_IS19 (0x1u << 19)
207 #define XDMAC_GIS_IS20 (0x1u << 20)
208 #define XDMAC_GIS_IS21 (0x1u << 21)
209 #define XDMAC_GIS_IS22 (0x1u << 22)
210 #define XDMAC_GIS_IS23 (0x1u << 23)
211 /* -------- XDMAC_GE : (XDMAC Offset: 0x1C) Global Channel Enable Register -------- */
212 #define XDMAC_GE_EN0 (0x1u << 0)
213 #define XDMAC_GE_EN1 (0x1u << 1)
214 #define XDMAC_GE_EN2 (0x1u << 2)
215 #define XDMAC_GE_EN3 (0x1u << 3)
216 #define XDMAC_GE_EN4 (0x1u << 4)
217 #define XDMAC_GE_EN5 (0x1u << 5)
218 #define XDMAC_GE_EN6 (0x1u << 6)
219 #define XDMAC_GE_EN7 (0x1u << 7)
220 #define XDMAC_GE_EN8 (0x1u << 8)
221 #define XDMAC_GE_EN9 (0x1u << 9)
222 #define XDMAC_GE_EN10 (0x1u << 10)
223 #define XDMAC_GE_EN11 (0x1u << 11)
224 #define XDMAC_GE_EN12 (0x1u << 12)
225 #define XDMAC_GE_EN13 (0x1u << 13)
226 #define XDMAC_GE_EN14 (0x1u << 14)
227 #define XDMAC_GE_EN15 (0x1u << 15)
228 #define XDMAC_GE_EN16 (0x1u << 16)
229 #define XDMAC_GE_EN17 (0x1u << 17)
230 #define XDMAC_GE_EN18 (0x1u << 18)
231 #define XDMAC_GE_EN19 (0x1u << 19)
232 #define XDMAC_GE_EN20 (0x1u << 20)
233 #define XDMAC_GE_EN21 (0x1u << 21)
234 #define XDMAC_GE_EN22 (0x1u << 22)
235 #define XDMAC_GE_EN23 (0x1u << 23)
236 /* -------- XDMAC_GD : (XDMAC Offset: 0x20) Global Channel Disable Register -------- */
237 #define XDMAC_GD_DI0 (0x1u << 0)
238 #define XDMAC_GD_DI1 (0x1u << 1)
239 #define XDMAC_GD_DI2 (0x1u << 2)
240 #define XDMAC_GD_DI3 (0x1u << 3)
241 #define XDMAC_GD_DI4 (0x1u << 4)
242 #define XDMAC_GD_DI5 (0x1u << 5)
243 #define XDMAC_GD_DI6 (0x1u << 6)
244 #define XDMAC_GD_DI7 (0x1u << 7)
245 #define XDMAC_GD_DI8 (0x1u << 8)
246 #define XDMAC_GD_DI9 (0x1u << 9)
247 #define XDMAC_GD_DI10 (0x1u << 10)
248 #define XDMAC_GD_DI11 (0x1u << 11)
249 #define XDMAC_GD_DI12 (0x1u << 12)
250 #define XDMAC_GD_DI13 (0x1u << 13)
251 #define XDMAC_GD_DI14 (0x1u << 14)
252 #define XDMAC_GD_DI15 (0x1u << 15)
253 #define XDMAC_GD_DI16 (0x1u << 16)
254 #define XDMAC_GD_DI17 (0x1u << 17)
255 #define XDMAC_GD_DI18 (0x1u << 18)
256 #define XDMAC_GD_DI19 (0x1u << 19)
257 #define XDMAC_GD_DI20 (0x1u << 20)
258 #define XDMAC_GD_DI21 (0x1u << 21)
259 #define XDMAC_GD_DI22 (0x1u << 22)
260 #define XDMAC_GD_DI23 (0x1u << 23)
261 /* -------- XDMAC_GS : (XDMAC Offset: 0x24) Global Channel Status Register -------- */
262 #define XDMAC_GS_ST0 (0x1u << 0)
263 #define XDMAC_GS_ST1 (0x1u << 1)
264 #define XDMAC_GS_ST2 (0x1u << 2)
265 #define XDMAC_GS_ST3 (0x1u << 3)
266 #define XDMAC_GS_ST4 (0x1u << 4)
267 #define XDMAC_GS_ST5 (0x1u << 5)
268 #define XDMAC_GS_ST6 (0x1u << 6)
269 #define XDMAC_GS_ST7 (0x1u << 7)
270 #define XDMAC_GS_ST8 (0x1u << 8)
271 #define XDMAC_GS_ST9 (0x1u << 9)
272 #define XDMAC_GS_ST10 (0x1u << 10)
273 #define XDMAC_GS_ST11 (0x1u << 11)
274 #define XDMAC_GS_ST12 (0x1u << 12)
275 #define XDMAC_GS_ST13 (0x1u << 13)
276 #define XDMAC_GS_ST14 (0x1u << 14)
277 #define XDMAC_GS_ST15 (0x1u << 15)
278 #define XDMAC_GS_ST16 (0x1u << 16)
279 #define XDMAC_GS_ST17 (0x1u << 17)
280 #define XDMAC_GS_ST18 (0x1u << 18)
281 #define XDMAC_GS_ST19 (0x1u << 19)
282 #define XDMAC_GS_ST20 (0x1u << 20)
283 #define XDMAC_GS_ST21 (0x1u << 21)
284 #define XDMAC_GS_ST22 (0x1u << 22)
285 #define XDMAC_GS_ST23 (0x1u << 23)
286 /* -------- XDMAC_GRS : (XDMAC Offset: 0x28) Global Channel Read Suspend Register -------- */
287 #define XDMAC_GRS_RS0 (0x1u << 0)
288 #define XDMAC_GRS_RS1 (0x1u << 1)
289 #define XDMAC_GRS_RS2 (0x1u << 2)
290 #define XDMAC_GRS_RS3 (0x1u << 3)
291 #define XDMAC_GRS_RS4 (0x1u << 4)
292 #define XDMAC_GRS_RS5 (0x1u << 5)
293 #define XDMAC_GRS_RS6 (0x1u << 6)
294 #define XDMAC_GRS_RS7 (0x1u << 7)
295 #define XDMAC_GRS_RS8 (0x1u << 8)
296 #define XDMAC_GRS_RS9 (0x1u << 9)
297 #define XDMAC_GRS_RS10 (0x1u << 10)
298 #define XDMAC_GRS_RS11 (0x1u << 11)
299 #define XDMAC_GRS_RS12 (0x1u << 12)
300 #define XDMAC_GRS_RS13 (0x1u << 13)
301 #define XDMAC_GRS_RS14 (0x1u << 14)
302 #define XDMAC_GRS_RS15 (0x1u << 15)
303 #define XDMAC_GRS_RS16 (0x1u << 16)
304 #define XDMAC_GRS_RS17 (0x1u << 17)
305 #define XDMAC_GRS_RS18 (0x1u << 18)
306 #define XDMAC_GRS_RS19 (0x1u << 19)
307 #define XDMAC_GRS_RS20 (0x1u << 20)
308 #define XDMAC_GRS_RS21 (0x1u << 21)
309 #define XDMAC_GRS_RS22 (0x1u << 22)
310 #define XDMAC_GRS_RS23 (0x1u << 23)
311 /* -------- XDMAC_GWS : (XDMAC Offset: 0x2C) Global Channel Write Suspend Register -------- */
312 #define XDMAC_GWS_WS0 (0x1u << 0)
313 #define XDMAC_GWS_WS1 (0x1u << 1)
314 #define XDMAC_GWS_WS2 (0x1u << 2)
315 #define XDMAC_GWS_WS3 (0x1u << 3)
316 #define XDMAC_GWS_WS4 (0x1u << 4)
317 #define XDMAC_GWS_WS5 (0x1u << 5)
318 #define XDMAC_GWS_WS6 (0x1u << 6)
319 #define XDMAC_GWS_WS7 (0x1u << 7)
320 #define XDMAC_GWS_WS8 (0x1u << 8)
321 #define XDMAC_GWS_WS9 (0x1u << 9)
322 #define XDMAC_GWS_WS10 (0x1u << 10)
323 #define XDMAC_GWS_WS11 (0x1u << 11)
324 #define XDMAC_GWS_WS12 (0x1u << 12)
325 #define XDMAC_GWS_WS13 (0x1u << 13)
326 #define XDMAC_GWS_WS14 (0x1u << 14)
327 #define XDMAC_GWS_WS15 (0x1u << 15)
328 #define XDMAC_GWS_WS16 (0x1u << 16)
329 #define XDMAC_GWS_WS17 (0x1u << 17)
330 #define XDMAC_GWS_WS18 (0x1u << 18)
331 #define XDMAC_GWS_WS19 (0x1u << 19)
332 #define XDMAC_GWS_WS20 (0x1u << 20)
333 #define XDMAC_GWS_WS21 (0x1u << 21)
334 #define XDMAC_GWS_WS22 (0x1u << 22)
335 #define XDMAC_GWS_WS23 (0x1u << 23)
336 /* -------- XDMAC_GRWS : (XDMAC Offset: 0x30) Global Channel Read Write Suspend Register -------- */
337 #define XDMAC_GRWS_RWS0 (0x1u << 0)
338 #define XDMAC_GRWS_RWS1 (0x1u << 1)
339 #define XDMAC_GRWS_RWS2 (0x1u << 2)
340 #define XDMAC_GRWS_RWS3 (0x1u << 3)
341 #define XDMAC_GRWS_RWS4 (0x1u << 4)
342 #define XDMAC_GRWS_RWS5 (0x1u << 5)
343 #define XDMAC_GRWS_RWS6 (0x1u << 6)
344 #define XDMAC_GRWS_RWS7 (0x1u << 7)
345 #define XDMAC_GRWS_RWS8 (0x1u << 8)
346 #define XDMAC_GRWS_RWS9 (0x1u << 9)
347 #define XDMAC_GRWS_RWS10 (0x1u << 10)
348 #define XDMAC_GRWS_RWS11 (0x1u << 11)
349 #define XDMAC_GRWS_RWS12 (0x1u << 12)
350 #define XDMAC_GRWS_RWS13 (0x1u << 13)
351 #define XDMAC_GRWS_RWS14 (0x1u << 14)
352 #define XDMAC_GRWS_RWS15 (0x1u << 15)
353 #define XDMAC_GRWS_RWS16 (0x1u << 16)
354 #define XDMAC_GRWS_RWS17 (0x1u << 17)
355 #define XDMAC_GRWS_RWS18 (0x1u << 18)
356 #define XDMAC_GRWS_RWS19 (0x1u << 19)
357 #define XDMAC_GRWS_RWS20 (0x1u << 20)
358 #define XDMAC_GRWS_RWS21 (0x1u << 21)
359 #define XDMAC_GRWS_RWS22 (0x1u << 22)
360 #define XDMAC_GRWS_RWS23 (0x1u << 23)
361 /* -------- XDMAC_GRWR : (XDMAC Offset: 0x34) Global Channel Read Write Resume Register -------- */
362 #define XDMAC_GRWR_RWR0 (0x1u << 0)
363 #define XDMAC_GRWR_RWR1 (0x1u << 1)
364 #define XDMAC_GRWR_RWR2 (0x1u << 2)
365 #define XDMAC_GRWR_RWR3 (0x1u << 3)
366 #define XDMAC_GRWR_RWR4 (0x1u << 4)
367 #define XDMAC_GRWR_RWR5 (0x1u << 5)
368 #define XDMAC_GRWR_RWR6 (0x1u << 6)
369 #define XDMAC_GRWR_RWR7 (0x1u << 7)
370 #define XDMAC_GRWR_RWR8 (0x1u << 8)
371 #define XDMAC_GRWR_RWR9 (0x1u << 9)
372 #define XDMAC_GRWR_RWR10 (0x1u << 10)
373 #define XDMAC_GRWR_RWR11 (0x1u << 11)
374 #define XDMAC_GRWR_RWR12 (0x1u << 12)
375 #define XDMAC_GRWR_RWR13 (0x1u << 13)
376 #define XDMAC_GRWR_RWR14 (0x1u << 14)
377 #define XDMAC_GRWR_RWR15 (0x1u << 15)
378 #define XDMAC_GRWR_RWR16 (0x1u << 16)
379 #define XDMAC_GRWR_RWR17 (0x1u << 17)
380 #define XDMAC_GRWR_RWR18 (0x1u << 18)
381 #define XDMAC_GRWR_RWR19 (0x1u << 19)
382 #define XDMAC_GRWR_RWR20 (0x1u << 20)
383 #define XDMAC_GRWR_RWR21 (0x1u << 21)
384 #define XDMAC_GRWR_RWR22 (0x1u << 22)
385 #define XDMAC_GRWR_RWR23 (0x1u << 23)
386 /* -------- XDMAC_GSWR : (XDMAC Offset: 0x38) Global Channel Software Request Register -------- */
387 #define XDMAC_GSWR_SWREQ0 (0x1u << 0)
388 #define XDMAC_GSWR_SWREQ1 (0x1u << 1)
389 #define XDMAC_GSWR_SWREQ2 (0x1u << 2)
390 #define XDMAC_GSWR_SWREQ3 (0x1u << 3)
391 #define XDMAC_GSWR_SWREQ4 (0x1u << 4)
392 #define XDMAC_GSWR_SWREQ5 (0x1u << 5)
393 #define XDMAC_GSWR_SWREQ6 (0x1u << 6)
394 #define XDMAC_GSWR_SWREQ7 (0x1u << 7)
395 #define XDMAC_GSWR_SWREQ8 (0x1u << 8)
396 #define XDMAC_GSWR_SWREQ9 (0x1u << 9)
397 #define XDMAC_GSWR_SWREQ10 (0x1u << 10)
398 #define XDMAC_GSWR_SWREQ11 (0x1u << 11)
399 #define XDMAC_GSWR_SWREQ12 (0x1u << 12)
400 #define XDMAC_GSWR_SWREQ13 (0x1u << 13)
401 #define XDMAC_GSWR_SWREQ14 (0x1u << 14)
402 #define XDMAC_GSWR_SWREQ15 (0x1u << 15)
403 #define XDMAC_GSWR_SWREQ16 (0x1u << 16)
404 #define XDMAC_GSWR_SWREQ17 (0x1u << 17)
405 #define XDMAC_GSWR_SWREQ18 (0x1u << 18)
406 #define XDMAC_GSWR_SWREQ19 (0x1u << 19)
407 #define XDMAC_GSWR_SWREQ20 (0x1u << 20)
408 #define XDMAC_GSWR_SWREQ21 (0x1u << 21)
409 #define XDMAC_GSWR_SWREQ22 (0x1u << 22)
410 #define XDMAC_GSWR_SWREQ23 (0x1u << 23)
411 /* -------- XDMAC_GSWS : (XDMAC Offset: 0x3C) Global Channel Software Request Status Register -------- */
412 #define XDMAC_GSWS_SWRS0 (0x1u << 0)
413 #define XDMAC_GSWS_SWRS1 (0x1u << 1)
414 #define XDMAC_GSWS_SWRS2 (0x1u << 2)
415 #define XDMAC_GSWS_SWRS3 (0x1u << 3)
416 #define XDMAC_GSWS_SWRS4 (0x1u << 4)
417 #define XDMAC_GSWS_SWRS5 (0x1u << 5)
418 #define XDMAC_GSWS_SWRS6 (0x1u << 6)
419 #define XDMAC_GSWS_SWRS7 (0x1u << 7)
420 #define XDMAC_GSWS_SWRS8 (0x1u << 8)
421 #define XDMAC_GSWS_SWRS9 (0x1u << 9)
422 #define XDMAC_GSWS_SWRS10 (0x1u << 10)
423 #define XDMAC_GSWS_SWRS11 (0x1u << 11)
424 #define XDMAC_GSWS_SWRS12 (0x1u << 12)
425 #define XDMAC_GSWS_SWRS13 (0x1u << 13)
426 #define XDMAC_GSWS_SWRS14 (0x1u << 14)
427 #define XDMAC_GSWS_SWRS15 (0x1u << 15)
428 #define XDMAC_GSWS_SWRS16 (0x1u << 16)
429 #define XDMAC_GSWS_SWRS17 (0x1u << 17)
430 #define XDMAC_GSWS_SWRS18 (0x1u << 18)
431 #define XDMAC_GSWS_SWRS19 (0x1u << 19)
432 #define XDMAC_GSWS_SWRS20 (0x1u << 20)
433 #define XDMAC_GSWS_SWRS21 (0x1u << 21)
434 #define XDMAC_GSWS_SWRS22 (0x1u << 22)
435 #define XDMAC_GSWS_SWRS23 (0x1u << 23)
436 /* -------- XDMAC_GSWF : (XDMAC Offset: 0x40) Global Channel Software Flush Request Register -------- */
437 #define XDMAC_GSWF_SWF0 (0x1u << 0)
438 #define XDMAC_GSWF_SWF1 (0x1u << 1)
439 #define XDMAC_GSWF_SWF2 (0x1u << 2)
440 #define XDMAC_GSWF_SWF3 (0x1u << 3)
441 #define XDMAC_GSWF_SWF4 (0x1u << 4)
442 #define XDMAC_GSWF_SWF5 (0x1u << 5)
443 #define XDMAC_GSWF_SWF6 (0x1u << 6)
444 #define XDMAC_GSWF_SWF7 (0x1u << 7)
445 #define XDMAC_GSWF_SWF8 (0x1u << 8)
446 #define XDMAC_GSWF_SWF9 (0x1u << 9)
447 #define XDMAC_GSWF_SWF10 (0x1u << 10)
448 #define XDMAC_GSWF_SWF11 (0x1u << 11)
449 #define XDMAC_GSWF_SWF12 (0x1u << 12)
450 #define XDMAC_GSWF_SWF13 (0x1u << 13)
451 #define XDMAC_GSWF_SWF14 (0x1u << 14)
452 #define XDMAC_GSWF_SWF15 (0x1u << 15)
453 #define XDMAC_GSWF_SWF16 (0x1u << 16)
454 #define XDMAC_GSWF_SWF17 (0x1u << 17)
455 #define XDMAC_GSWF_SWF18 (0x1u << 18)
456 #define XDMAC_GSWF_SWF19 (0x1u << 19)
457 #define XDMAC_GSWF_SWF20 (0x1u << 20)
458 #define XDMAC_GSWF_SWF21 (0x1u << 21)
459 #define XDMAC_GSWF_SWF22 (0x1u << 22)
460 #define XDMAC_GSWF_SWF23 (0x1u << 23)
461 /* -------- XDMAC_CIE : (XDMAC Offset: N/A) Channel Interrupt Enable Register -------- */
462 #define XDMAC_CIE_BIE (0x1u << 0)
463 #define XDMAC_CIE_LIE (0x1u << 1)
464 #define XDMAC_CIE_DIE (0x1u << 2)
465 #define XDMAC_CIE_FIE (0x1u << 3)
466 #define XDMAC_CIE_RBIE (0x1u << 4)
467 #define XDMAC_CIE_WBIE (0x1u << 5)
468 #define XDMAC_CIE_ROIE (0x1u << 6)
469 /* -------- XDMAC_CID : (XDMAC Offset: N/A) Channel Interrupt Disable Register -------- */
470 #define XDMAC_CID_BID (0x1u << 0)
471 #define XDMAC_CID_LID (0x1u << 1)
472 #define XDMAC_CID_DID (0x1u << 2)
473 #define XDMAC_CID_FID (0x1u << 3)
474 #define XDMAC_CID_RBEID (0x1u << 4)
475 #define XDMAC_CID_WBEID (0x1u << 5)
476 #define XDMAC_CID_ROID (0x1u << 6)
477 /* -------- XDMAC_CIM : (XDMAC Offset: N/A) Channel Interrupt Mask Register -------- */
478 #define XDMAC_CIM_BIM (0x1u << 0)
479 #define XDMAC_CIM_LIM (0x1u << 1)
480 #define XDMAC_CIM_DIM (0x1u << 2)
481 #define XDMAC_CIM_FIM (0x1u << 3)
482 #define XDMAC_CIM_RBEIM (0x1u << 4)
483 #define XDMAC_CIM_WBEIM (0x1u << 5)
484 #define XDMAC_CIM_ROIM (0x1u << 6)
485 /* -------- XDMAC_CIS : (XDMAC Offset: N/A) Channel Interrupt Status Register -------- */
486 #define XDMAC_CIS_BIS (0x1u << 0)
487 #define XDMAC_CIS_LIS (0x1u << 1)
488 #define XDMAC_CIS_DIS (0x1u << 2)
489 #define XDMAC_CIS_FIS (0x1u << 3)
490 #define XDMAC_CIS_RBEIS (0x1u << 4)
491 #define XDMAC_CIS_WBEIS (0x1u << 5)
492 #define XDMAC_CIS_ROIS (0x1u << 6)
493 /* -------- XDMAC_CSA : (XDMAC Offset: N/A) Channel Source Address Register -------- */
494 #define XDMAC_CSA_SA_Pos 0
495 #define XDMAC_CSA_SA_Msk (0xffffffffu << XDMAC_CSA_SA_Pos)
496 #define XDMAC_CSA_SA(value) ((XDMAC_CSA_SA_Msk & ((value) << XDMAC_CSA_SA_Pos)))
497 /* -------- XDMAC_CDA : (XDMAC Offset: N/A) Channel Destination Address Register -------- */
498 #define XDMAC_CDA_DA_Pos 0
499 #define XDMAC_CDA_DA_Msk (0xffffffffu << XDMAC_CDA_DA_Pos)
500 #define XDMAC_CDA_DA(value) ((XDMAC_CDA_DA_Msk & ((value) << XDMAC_CDA_DA_Pos)))
501 /* -------- XDMAC_CNDA : (XDMAC Offset: N/A) Channel Next Descriptor Address Register -------- */
502 #define XDMAC_CNDA_NDAIF (0x1u << 0)
503 #define XDMAC_CNDA_NDA_Pos 2
504 #define XDMAC_CNDA_NDA_Msk (0x3fffffffu << XDMAC_CNDA_NDA_Pos)
505 #define XDMAC_CNDA_NDA(value) ((XDMAC_CNDA_NDA_Msk & ((value) << XDMAC_CNDA_NDA_Pos)))
506 /* -------- XDMAC_CNDC : (XDMAC Offset: N/A) Channel Next Descriptor Control Register -------- */
507 #define XDMAC_CNDC_NDE (0x1u << 0)
508 #define XDMAC_CNDC_NDE_DSCR_FETCH_DIS (0x0u << 0)
509 #define XDMAC_CNDC_NDE_DSCR_FETCH_EN (0x1u << 0)
510 #define XDMAC_CNDC_NDSUP (0x1u << 1)
511 #define XDMAC_CNDC_NDSUP_SRC_PARAMS_UNCHANGED (0x0u << 1)
512 #define XDMAC_CNDC_NDSUP_SRC_PARAMS_UPDATED (0x1u << 1)
513 #define XDMAC_CNDC_NDDUP (0x1u << 2)
514 #define XDMAC_CNDC_NDDUP_DST_PARAMS_UNCHANGED (0x0u << 2)
515 #define XDMAC_CNDC_NDDUP_DST_PARAMS_UPDATED (0x1u << 2)
516 #define XDMAC_CNDC_NDVIEW_Pos 3
517 #define XDMAC_CNDC_NDVIEW_Msk (0x3u << XDMAC_CNDC_NDVIEW_Pos)
518 #define XDMAC_CNDC_NDVIEW(value) ((XDMAC_CNDC_NDVIEW_Msk & ((value) << XDMAC_CNDC_NDVIEW_Pos)))
519 #define XDMAC_CNDC_NDVIEW_NDV0 (0x0u << 3)
520 #define XDMAC_CNDC_NDVIEW_NDV1 (0x1u << 3)
521 #define XDMAC_CNDC_NDVIEW_NDV2 (0x2u << 3)
522 #define XDMAC_CNDC_NDVIEW_NDV3 (0x3u << 3)
523 /* -------- XDMAC_CUBC : (XDMAC Offset: N/A) Channel Microblock Control Register -------- */
524 #define XDMAC_CUBC_UBLEN_Pos 0
525 #define XDMAC_CUBC_UBLEN_Msk (0xffffffu << XDMAC_CUBC_UBLEN_Pos)
526 #define XDMAC_CUBC_UBLEN(value) ((XDMAC_CUBC_UBLEN_Msk & ((value) << XDMAC_CUBC_UBLEN_Pos)))
527 /* -------- XDMAC_CBC : (XDMAC Offset: N/A) Channel Block Control Register -------- */
528 #define XDMAC_CBC_BLEN_Pos 0
529 #define XDMAC_CBC_BLEN_Msk (0xfffu << XDMAC_CBC_BLEN_Pos)
530 #define XDMAC_CBC_BLEN(value) ((XDMAC_CBC_BLEN_Msk & ((value) << XDMAC_CBC_BLEN_Pos)))
531 /* -------- XDMAC_CC : (XDMAC Offset: N/A) Channel Configuration Register -------- */
532 #define XDMAC_CC_TYPE (0x1u << 0)
533 #define XDMAC_CC_TYPE_MEM_TRAN (0x0u << 0)
534 #define XDMAC_CC_TYPE_PER_TRAN (0x1u << 0)
535 #define XDMAC_CC_MBSIZE_Pos 1
536 #define XDMAC_CC_MBSIZE_Msk (0x3u << XDMAC_CC_MBSIZE_Pos)
537 #define XDMAC_CC_MBSIZE(value) ((XDMAC_CC_MBSIZE_Msk & ((value) << XDMAC_CC_MBSIZE_Pos)))
538 #define XDMAC_CC_MBSIZE_SINGLE (0x0u << 1)
539 #define XDMAC_CC_MBSIZE_FOUR (0x1u << 1)
540 #define XDMAC_CC_MBSIZE_EIGHT (0x2u << 1)
541 #define XDMAC_CC_MBSIZE_SIXTEEN (0x3u << 1)
542 #define XDMAC_CC_DSYNC (0x1u << 4)
543 #define XDMAC_CC_DSYNC_PER2MEM (0x0u << 4)
544 #define XDMAC_CC_DSYNC_MEM2PER (0x1u << 4)
545 #define XDMAC_CC_SWREQ (0x1u << 6)
546 #define XDMAC_CC_SWREQ_HWR_CONNECTED (0x0u << 6)
547 #define XDMAC_CC_SWREQ_SWR_CONNECTED (0x1u << 6)
548 #define XDMAC_CC_MEMSET (0x1u << 7)
549 #define XDMAC_CC_MEMSET_NORMAL_MODE (0x0u << 7)
550 #define XDMAC_CC_MEMSET_HW_MODE (0x1u << 7)
551 #define XDMAC_CC_CSIZE_Pos 8
552 #define XDMAC_CC_CSIZE_Msk (0x7u << XDMAC_CC_CSIZE_Pos)
553 #define XDMAC_CC_CSIZE(value) ((XDMAC_CC_CSIZE_Msk & ((value) << XDMAC_CC_CSIZE_Pos)))
554 #define XDMAC_CC_CSIZE_CHK_1 (0x0u << 8)
555 #define XDMAC_CC_CSIZE_CHK_2 (0x1u << 8)
556 #define XDMAC_CC_CSIZE_CHK_4 (0x2u << 8)
557 #define XDMAC_CC_CSIZE_CHK_8 (0x3u << 8)
558 #define XDMAC_CC_CSIZE_CHK_16 (0x4u << 8)
559 #define XDMAC_CC_DWIDTH_Pos 11
560 #define XDMAC_CC_DWIDTH_Msk (0x3u << XDMAC_CC_DWIDTH_Pos)
561 #define XDMAC_CC_DWIDTH(value) ((XDMAC_CC_DWIDTH_Msk & ((value) << XDMAC_CC_DWIDTH_Pos)))
562 #define XDMAC_CC_DWIDTH_BYTE (0x0u << 11)
563 #define XDMAC_CC_DWIDTH_HALFWORD (0x1u << 11)
564 #define XDMAC_CC_DWIDTH_WORD (0x2u << 11)
565 #define XDMAC_CC_SIF (0x1u << 13)
566 #define XDMAC_CC_SIF_AHB_IF0 (0x0u << 13)
567 #define XDMAC_CC_SIF_AHB_IF1 (0x1u << 13)
568 #define XDMAC_CC_DIF (0x1u << 14)
569 #define XDMAC_CC_DIF_AHB_IF0 (0x0u << 14)
570 #define XDMAC_CC_DIF_AHB_IF1 (0x1u << 14)
571 #define XDMAC_CC_SAM_Pos 16
572 #define XDMAC_CC_SAM_Msk (0x3u << XDMAC_CC_SAM_Pos)
573 #define XDMAC_CC_SAM(value) ((XDMAC_CC_SAM_Msk & ((value) << XDMAC_CC_SAM_Pos)))
574 #define XDMAC_CC_SAM_FIXED_AM (0x0u << 16)
575 #define XDMAC_CC_SAM_INCREMENTED_AM (0x1u << 16)
576 #define XDMAC_CC_SAM_UBS_AM (0x2u << 16)
577 #define XDMAC_CC_SAM_UBS_DS_AM (0x3u << 16)
578 #define XDMAC_CC_DAM_Pos 18
579 #define XDMAC_CC_DAM_Msk (0x3u << XDMAC_CC_DAM_Pos)
580 #define XDMAC_CC_DAM(value) ((XDMAC_CC_DAM_Msk & ((value) << XDMAC_CC_DAM_Pos)))
581 #define XDMAC_CC_DAM_FIXED_AM (0x0u << 18)
582 #define XDMAC_CC_DAM_INCREMENTED_AM (0x1u << 18)
583 #define XDMAC_CC_DAM_UBS_AM (0x2u << 18)
584 #define XDMAC_CC_DAM_UBS_DS_AM (0x3u << 18)
585 #define XDMAC_CC_INITD (0x1u << 21)
586 #define XDMAC_CC_INITD_TERMINATED (0x0u << 21)
587 #define XDMAC_CC_INITD_IN_PROGRESS (0x1u << 21)
588 #define XDMAC_CC_RDIP (0x1u << 22)
589 #define XDMAC_CC_RDIP_DONE (0x0u << 22)
590 #define XDMAC_CC_RDIP_IN_PROGRESS (0x1u << 22)
591 #define XDMAC_CC_WRIP (0x1u << 23)
592 #define XDMAC_CC_WRIP_DONE (0x0u << 23)
593 #define XDMAC_CC_WRIP_IN_PROGRESS (0x1u << 23)
594 #define XDMAC_CC_PERID_Pos 24
595 #define XDMAC_CC_PERID_Msk (0x7fu << XDMAC_CC_PERID_Pos)
596 #define XDMAC_CC_PERID(value) ((XDMAC_CC_PERID_Msk & ((value) << XDMAC_CC_PERID_Pos)))
597 /* -------- XDMAC_CDS_MSP : (XDMAC Offset: N/A) Channel Data Stride Memory Set Pattern -------- */
598 #define XDMAC_CDS_MSP_SDS_MSP_Pos 0
599 #define XDMAC_CDS_MSP_SDS_MSP_Msk (0xffffu << XDMAC_CDS_MSP_SDS_MSP_Pos)
600 #define XDMAC_CDS_MSP_SDS_MSP(value) ((XDMAC_CDS_MSP_SDS_MSP_Msk & ((value) << XDMAC_CDS_MSP_SDS_MSP_Pos)))
601 #define XDMAC_CDS_MSP_DDS_MSP_Pos 16
602 #define XDMAC_CDS_MSP_DDS_MSP_Msk (0xffffu << XDMAC_CDS_MSP_DDS_MSP_Pos)
603 #define XDMAC_CDS_MSP_DDS_MSP(value) ((XDMAC_CDS_MSP_DDS_MSP_Msk & ((value) << XDMAC_CDS_MSP_DDS_MSP_Pos)))
604 /* -------- XDMAC_CSUS : (XDMAC Offset: N/A) Channel Source Microblock Stride -------- */
605 #define XDMAC_CSUS_SUBS_Pos 0
606 #define XDMAC_CSUS_SUBS_Msk (0xffffffu << XDMAC_CSUS_SUBS_Pos)
607 #define XDMAC_CSUS_SUBS(value) ((XDMAC_CSUS_SUBS_Msk & ((value) << XDMAC_CSUS_SUBS_Pos)))
608 /* -------- XDMAC_CDUS : (XDMAC Offset: N/A) Channel Destination Microblock Stride -------- */
609 #define XDMAC_CDUS_DUBS_Pos 0
610 #define XDMAC_CDUS_DUBS_Msk (0xffffffu << XDMAC_CDUS_DUBS_Pos)
611 #define XDMAC_CDUS_DUBS(value) ((XDMAC_CDUS_DUBS_Msk & ((value) << XDMAC_CDUS_DUBS_Pos)))
612
616 #endif /* _SAME70_XDMAC_COMPONENT_ */
(XdmacChid Offset: 0x0) Channel Interrupt Enable Register
Definition: component_xdmac.h:42
(XdmacChid Offset: 0x1C) Channel Next Descriptor Control Register
Definition: component_xdmac.h:49
(XdmacChid Offset: 0xC) Channel Interrupt Status Register
Definition: component_xdmac.h:45
(XdmacChid Offset: 0x4) Channel Interrupt Disable Register
Definition: component_xdmac.h:43
(XdmacChid Offset: 0x2C) Channel Data Stride Memory Set Pattern
Definition: component_xdmac.h:53
(Xdmac Offset: 0x40) Global Channel Software Flush Request Register
Definition: component_xdmac.h:77
(Xdmac Offset: 0x08) Global Weighted Arbiter Configuration Register
Definition: component_xdmac.h:63
(Xdmac Offset: 0x00) Global Type Register
Definition: component_xdmac.h:61
#define __IO
Definition: core_cm7.h:287
#define __O
Definition: core_cm7.h:286
(Xdmac Offset: 0x28) Global Channel Read Suspend Register
Definition: component_xdmac.h:71
(Xdmac Offset: 0x30) Global Channel Read Write Suspend Register
Definition: component_xdmac.h:73
(Xdmac Offset: 0x38) Global Channel Software Request Register
Definition: component_xdmac.h:75
(Xdmac Offset: 0x14) Global Interrupt Mask Register
Definition: component_xdmac.h:66
(Xdmac Offset: 0x10) Global Interrupt Disable Register
Definition: component_xdmac.h:65
XdmacChid hardware registers.
Definition: component_xdmac.h:41
(Xdmac Offset: 0x20) Global Channel Disable Register
Definition: component_xdmac.h:69
(XdmacChid Offset: 0x20) Channel Microblock Control Register
Definition: component_xdmac.h:50
(Xdmac Offset: 0x3C) Global Channel Software Request Status Register
Definition: component_xdmac.h:76
(XdmacChid Offset: 0x14) Channel Destination Address Register
Definition: component_xdmac.h:47
(XdmacChid Offset: 0x10) Channel Source Address Register
Definition: component_xdmac.h:46
(Xdmac Offset: 0x2C) Global Channel Write Suspend Register
Definition: component_xdmac.h:72
(Xdmac Offset: 0x24) Global Channel Status Register
Definition: component_xdmac.h:70
(Xdmac Offset: 0x1C) Global Channel Enable Register
Definition: component_xdmac.h:68
(XdmacChid Offset: 0x30) Channel Source Microblock Stride
Definition: component_xdmac.h:54
(Xdmac Offset: 0x0C) Global Interrupt Enable Register
Definition: component_xdmac.h:64
Definition: component_xdmac.h:60
(XdmacChid Offset: 0x28) Channel Configuration Register
Definition: component_xdmac.h:52
Xdmac hardware registers.
Definition: component_xdmac.h:59
(XdmacChid Offset: 0x24) Channel Block Control Register
Definition: component_xdmac.h:51
(Xdmac Offset: 0x18) Global Interrupt Status Register
Definition: component_xdmac.h:67
(XdmacChid Offset: 0x34) Channel Destination Microblock Stride
Definition: component_xdmac.h:55
(Xdmac Offset: 0x34) Global Channel Read Write Resume Register
Definition: component_xdmac.h:74
(Xdmac Offset: 0x04) Global Configuration Register
Definition: component_xdmac.h:62
(XdmacChid Offset: 0x8) Channel Interrupt Mask Register
Definition: component_xdmac.h:44
(XdmacChid Offset: 0x18) Channel Next Descriptor Address Register
Definition: component_xdmac.h:48
#define __I
Definition: core_cm7.h:284
