RTEMS  5.1
component_smc.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _SAME70_SMC_COMPONENT_
31 #define _SAME70_SMC_COMPONENT_
32
33 /* ============================================================================= */
35 /* ============================================================================= */
38
39 #if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
40
41 typedef struct {
42  __IO uint32_t SMC_SETUP;
43  __IO uint32_t SMC_PULSE;
44  __IO uint32_t SMC_CYCLE;
45  __IO uint32_t SMC_MODE;
46 } SmcCs_number;
48 #define SMCCS_NUMBER_NUMBER 4
49 typedef struct {
51  __I uint32_t Reserved1[16];
52  __IO uint32_t SMC_OCMS;
53  __O uint32_t SMC_KEY1;
54  __O uint32_t SMC_KEY2;
55  __I uint32_t Reserved2[22];
56  __IO uint32_t SMC_WPMR;
57  __I uint32_t SMC_WPSR;
58 } Smc;
59 #endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
60 /* -------- SMC_SETUP : (SMC Offset: N/A) SMC Setup Register -------- */
61 #define SMC_SETUP_NWE_SETUP_Pos 0
62 #define SMC_SETUP_NWE_SETUP_Msk (0x3fu << SMC_SETUP_NWE_SETUP_Pos)
63 #define SMC_SETUP_NWE_SETUP(value) ((SMC_SETUP_NWE_SETUP_Msk & ((value) << SMC_SETUP_NWE_SETUP_Pos)))
64 #define SMC_SETUP_NCS_WR_SETUP_Pos 8
65 #define SMC_SETUP_NCS_WR_SETUP_Msk (0x3fu << SMC_SETUP_NCS_WR_SETUP_Pos)
66 #define SMC_SETUP_NCS_WR_SETUP(value) ((SMC_SETUP_NCS_WR_SETUP_Msk & ((value) << SMC_SETUP_NCS_WR_SETUP_Pos)))
67 #define SMC_SETUP_NRD_SETUP_Pos 16
68 #define SMC_SETUP_NRD_SETUP_Msk (0x3fu << SMC_SETUP_NRD_SETUP_Pos)
69 #define SMC_SETUP_NRD_SETUP(value) ((SMC_SETUP_NRD_SETUP_Msk & ((value) << SMC_SETUP_NRD_SETUP_Pos)))
70 #define SMC_SETUP_NCS_RD_SETUP_Pos 24
71 #define SMC_SETUP_NCS_RD_SETUP_Msk (0x3fu << SMC_SETUP_NCS_RD_SETUP_Pos)
72 #define SMC_SETUP_NCS_RD_SETUP(value) ((SMC_SETUP_NCS_RD_SETUP_Msk & ((value) << SMC_SETUP_NCS_RD_SETUP_Pos)))
73 /* -------- SMC_PULSE : (SMC Offset: N/A) SMC Pulse Register -------- */
74 #define SMC_PULSE_NWE_PULSE_Pos 0
75 #define SMC_PULSE_NWE_PULSE_Msk (0x7fu << SMC_PULSE_NWE_PULSE_Pos)
76 #define SMC_PULSE_NWE_PULSE(value) ((SMC_PULSE_NWE_PULSE_Msk & ((value) << SMC_PULSE_NWE_PULSE_Pos)))
77 #define SMC_PULSE_NCS_WR_PULSE_Pos 8
78 #define SMC_PULSE_NCS_WR_PULSE_Msk (0x7fu << SMC_PULSE_NCS_WR_PULSE_Pos)
79 #define SMC_PULSE_NCS_WR_PULSE(value) ((SMC_PULSE_NCS_WR_PULSE_Msk & ((value) << SMC_PULSE_NCS_WR_PULSE_Pos)))
80 #define SMC_PULSE_NRD_PULSE_Pos 16
81 #define SMC_PULSE_NRD_PULSE_Msk (0x7fu << SMC_PULSE_NRD_PULSE_Pos)
82 #define SMC_PULSE_NRD_PULSE(value) ((SMC_PULSE_NRD_PULSE_Msk & ((value) << SMC_PULSE_NRD_PULSE_Pos)))
83 #define SMC_PULSE_NCS_RD_PULSE_Pos 24
84 #define SMC_PULSE_NCS_RD_PULSE_Msk (0x7fu << SMC_PULSE_NCS_RD_PULSE_Pos)
85 #define SMC_PULSE_NCS_RD_PULSE(value) ((SMC_PULSE_NCS_RD_PULSE_Msk & ((value) << SMC_PULSE_NCS_RD_PULSE_Pos)))
86 /* -------- SMC_CYCLE : (SMC Offset: N/A) SMC Cycle Register -------- */
87 #define SMC_CYCLE_NWE_CYCLE_Pos 0
88 #define SMC_CYCLE_NWE_CYCLE_Msk (0x1ffu << SMC_CYCLE_NWE_CYCLE_Pos)
89 #define SMC_CYCLE_NWE_CYCLE(value) ((SMC_CYCLE_NWE_CYCLE_Msk & ((value) << SMC_CYCLE_NWE_CYCLE_Pos)))
90 #define SMC_CYCLE_NRD_CYCLE_Pos 16
91 #define SMC_CYCLE_NRD_CYCLE_Msk (0x1ffu << SMC_CYCLE_NRD_CYCLE_Pos)
92 #define SMC_CYCLE_NRD_CYCLE(value) ((SMC_CYCLE_NRD_CYCLE_Msk & ((value) << SMC_CYCLE_NRD_CYCLE_Pos)))
93 /* -------- SMC_MODE : (SMC Offset: N/A) SMC MODE Register -------- */
94 #define SMC_MODE_READ_MODE (0x1u << 0)
95 #define SMC_MODE_WRITE_MODE (0x1u << 1)
96 #define SMC_MODE_EXNW_MODE_Pos 4
97 #define SMC_MODE_EXNW_MODE_Msk (0x3u << SMC_MODE_EXNW_MODE_Pos)
98 #define SMC_MODE_EXNW_MODE(value) ((SMC_MODE_EXNW_MODE_Msk & ((value) << SMC_MODE_EXNW_MODE_Pos)))
99 #define SMC_MODE_EXNW_MODE_DISABLED (0x0u << 4)
100 #define SMC_MODE_EXNW_MODE_FROZEN (0x2u << 4)
101 #define SMC_MODE_EXNW_MODE_READY (0x3u << 4)
102 #define SMC_MODE_BAT (0x1u << 8)
103 #define SMC_MODE_BAT_BYTE_SELECT (0x0u << 8)
104 #define SMC_MODE_BAT_BYTE_WRITE (0x1u << 8)
105 #define SMC_MODE_DBW (0x1u << 12)
106 #define SMC_MODE_DBW_8_BIT (0x0u << 12)
107 #define SMC_MODE_DBW_16_BIT (0x1u << 12)
108 #define SMC_MODE_TDF_CYCLES_Pos 16
109 #define SMC_MODE_TDF_CYCLES_Msk (0xfu << SMC_MODE_TDF_CYCLES_Pos)
110 #define SMC_MODE_TDF_CYCLES(value) ((SMC_MODE_TDF_CYCLES_Msk & ((value) << SMC_MODE_TDF_CYCLES_Pos)))
111 #define SMC_MODE_TDF_MODE (0x1u << 20)
112 #define SMC_MODE_PMEN (0x1u << 24)
113 #define SMC_MODE_PS_Pos 28
114 #define SMC_MODE_PS_Msk (0x3u << SMC_MODE_PS_Pos)
115 #define SMC_MODE_PS(value) ((SMC_MODE_PS_Msk & ((value) << SMC_MODE_PS_Pos)))
116 #define SMC_MODE_PS_4_BYTE (0x0u << 28)
117 #define SMC_MODE_PS_8_BYTE (0x1u << 28)
118 #define SMC_MODE_PS_16_BYTE (0x2u << 28)
119 #define SMC_MODE_PS_32_BYTE (0x3u << 28)
120 /* -------- SMC_OCMS : (SMC Offset: 0x80) SMC OCMS MODE Register -------- */
121 #define SMC_OCMS_SMSE (0x1u << 0)
122 /* -------- SMC_KEY1 : (SMC Offset: 0x84) SMC OCMS KEY1 Register -------- */
123 #define SMC_KEY1_KEY1_Pos 0
124 #define SMC_KEY1_KEY1_Msk (0xffffffffu << SMC_KEY1_KEY1_Pos)
125 #define SMC_KEY1_KEY1(value) ((SMC_KEY1_KEY1_Msk & ((value) << SMC_KEY1_KEY1_Pos)))
126 /* -------- SMC_KEY2 : (SMC Offset: 0x88) SMC OCMS KEY2 Register -------- */
127 #define SMC_KEY2_KEY2_Pos 0
128 #define SMC_KEY2_KEY2_Msk (0xffffffffu << SMC_KEY2_KEY2_Pos)
129 #define SMC_KEY2_KEY2(value) ((SMC_KEY2_KEY2_Msk & ((value) << SMC_KEY2_KEY2_Pos)))
130 /* -------- SMC_WPMR : (SMC Offset: 0xE4) SMC Write Protection Mode Register -------- */
131 #define SMC_WPMR_WPEN (0x1u << 0)
132 #define SMC_WPMR_WPKEY_Pos 8
133 #define SMC_WPMR_WPKEY_Msk (0xffffffu << SMC_WPMR_WPKEY_Pos)
134 #define SMC_WPMR_WPKEY(value) ((SMC_WPMR_WPKEY_Msk & ((value) << SMC_WPMR_WPKEY_Pos)))
135 #define SMC_WPMR_WPKEY_PASSWD (0x534D43u << 8)
136 /* -------- SMC_WPSR : (SMC Offset: 0xE8) SMC Write Protection Status Register -------- */
137 #define SMC_WPSR_WPVS (0x1u << 0)
138 #define SMC_WPSR_WPVSRC_Pos 8
139 #define SMC_WPSR_WPVSRC_Msk (0xffffu << SMC_WPSR_WPVSRC_Pos)
142
143
144 #endif /* _SAME70_SMC_COMPONENT_ */
(Smc Offset: 0x88) SMC OCMS KEY2 Register
Definition: component_smc.h:54
#define __IO
Definition: core_cm7.h:287
#define __O
Definition: core_cm7.h:286
(SmcCs_number Offset: 0x8) SMC Cycle Register
Definition: component_smc.h:44
(SmcCs_number Offset: 0x0) SMC Setup Register
Definition: component_smc.h:42
(Smc Offset: 0x80) SMC OCMS MODE Register
Definition: component_smc.h:52
(Smc Offset: 0xE8) SMC Write Protection Status Register
Definition: component_smc.h:57
(SmcCs_number Offset: 0x4) SMC Pulse Register
Definition: component_smc.h:43
Smc hardware registers.
Definition: component_smc.h:48
Definition: component_smc.h:49
SmcCs_number hardware registers.
Definition: component_smc.h:41
(Smc Offset: 0xE4) SMC Write Protection Mode Register
Definition: component_smc.h:56
(SmcCs_number Offset: 0xC) SMC MODE Register
Definition: component_smc.h:45
(Smc Offset: 0x84) SMC OCMS KEY1 Register
Definition: component_smc.h:53
#define __I
Definition: core_cm7.h:284
