RTEMS  5.1
s25fl1.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
37 #ifndef S25FL1_H
38 #define S25FL1_H
39 #define USE_QSPI_DMA
40 /*----------------------------------------------------------------------------
41  * Macros
42  *----------------------------------------------------------------------------*/
43
44 #define Size(pAt25) ((pAt25)->pDesc->size)
45 #define PageSize(pAt25) ((pAt25)->pDesc->pageSize)
46 #define BlockSize(pAt25) ((pAt25)->pDesc->blockSize)
47 #define Name(pAt25) ((pAt25)->pDesc->name)
48 #define ManId(pAt25) (((pAt25)->pDesc->jedecId) & 0xFF)
49 #define PageNumber(pAt25) (Size(pAt25) / PageSize(pAt25))
50 #define BlockNumber(pAt25) (Size(pAt25) / BlockSize(pAt25))
51 #define PagePerBlock(pAt25) (BlockSize(pAt25) / PageSize(pAt25))
52 #define BlockEraseCmd(pAt25) ((pAt25)->pDesc->blockEraseCmd)
53
54 /*----------------------------------------------------------------------------
55  * Local definitions
56  *----------------------------------------------------------------------------*/
57
59 #define ERROR_PROTECTED 1
60
61 #define ERROR_BUSY 2
62
63 #define ERROR_PROGRAM 3
64
65 #define ERROR_SPI 4
66
68 #define STATUS_RDYBSY (1 << 0)
69
70 #define STATUS_RDYBSY_READY (0 << 0)
71
72 #define STATUS_RDYBSY_BUSY (1 << 0)
73
74 #define STATUS_WEL (1 << 1)
75
76 #define STATUS_WEL_DISABLED (0 << 1)
77
78 #define STATUS_WEL_ENABLED (1 << 1)
79
80 #define STATUS_SWP (3 << 2)
81
82 #define STATUS_SWP_PROTALL (3 << 2)
83
84 #define STATUS_SWP_PROTSOME (1 << 2)
85
86 #define STATUS_SWP_PROTNONE (0 << 2)
87
88 #define STATUS_WPP (1 << 4)
89
90 #define STATUS_WPP_NOTASSERTED (0 << 4)
91
92 #define STATUS_WPP_ASSERTED (1 << 4)
93
94 #define STATUS_EPE (1 << 5)
95
96 #define STATUS_EPE_SUCCESS (0 << 5)
97
98 #define STATUS_EPE_ERROR (1 << 5)
99
100 #define STATUS_SPRL (1 << 7)
101
102 #define STATUS_SPRL_UNLOCKED (0 << 7)
103
104 #define STATUS_SPRL_LOCKED (1 << 7)
105
107 #define STATUS_QUAD_ENABLE (1 << 1)
108
109 #define STATUS_WRAP_ENABLE (0 << 4)
110
112 #define STATUS_LATENCY_CTRL (0xF << 0)
113
114 #define STATUS_WRAP_BYTE (1 << 5)
115
116 #define BLOCK_PROTECT_Msk (7 << 2)
117
118 #define TOP_BTM_PROTECT_Msk (1 << 5)
119
120 #define SEC_PROTECT_Msk (1 << 6)
121
122 #define CHIP_PROTECT_Msk (0x1F << 2)
123
125 #define READ_ARRAY 0x0B
126
127 #define READ_ARRAY_LF 0x03
128
129 #define READ_ARRAY_DUAL 0x3B
130
131 #define READ_ARRAY_QUAD 0x6B
132
133 #define READ_ARRAY_DUAL_IO 0xBB
134
135 #define READ_ARRAY_QUAD_IO 0xEB
136
137 #define BLOCK_ERASE_4K 0x20
138
139 #define BLOCK_ERASE_32K 0x52
140
141 #define BLOCK_ERASE_64K 0xD8
142
143 #define CHIP_ERASE_1 0x60
144
145 #define CHIP_ERASE_2 0xC7
146
147 #define BYTE_PAGE_PROGRAM 0x02
148
149 #define SEQUENTIAL_PROGRAM_1 0xAD
150
151 #define SEQUENTIAL_PROGRAM_2 0xAF
152
153 #define WRITE_ENABLE 0x06
154
155 #define WRITE_DISABLE 0x04
156
157 #define PROTECT_SECTOR 0x36
158
159 #define UNPROTECT_SECTOR 0x39
160
161 #define READ_SECTOR_PROT 0x3C
162
163 #define READ_STATUS_1 0x05
164
165 #define READ_STATUS_2 0x35
166
167 #define READ_STATUS_3 0x33
168
169 #define WRITE_STATUS 0x01
170
171 #define READ_JEDEC_ID 0x9F
172
173 #define DEEP_PDOWN 0xB9
174
175 #define RES_DEEP_PDOWN 0xAB
176
177 #define SOFT_RESET_ENABLE 0x66
178
179 #define SOFT_RESET 0x99
180
181 #define WRAP_ENABLE 0x77
182
183 #define CONT_MODE_RESET 0xFF
184
186 #define ATMEL_SPI_FLASH 0x1F
187 #define ST_SPI_FLASH 0x20
188 #define WINBOND_SPI_FLASH 0xEF
189 #define MACRONIX_SPI_FLASH 0xC2
190 #define SST_SPI_FLASH 0xBF
191
192 /*----------------------------------------------------------------------------
193  * Exported functions
194  *----------------------------------------------------------------------------*/
195
196 uint32_t S25FL1D_ReadJedecId(void);
197
198 void S25FL1D_InitFlashInterface(uint8_t Mode);
199
200 void S25FL1D_SoftReset(void);
201
202 void S25FL1D_ContReadModeReset(void);
203 unsigned char S25FL1D_Unprotect(void);
204
205 unsigned char S25FL1D_Protect(uint32_t StartAddr, uint32_t Size);
206
207 void S25FL1D_QuadMode(uint8_t Enable);
208
209 void S25FL1D_EnableWrap(uint8_t ByetAlign);
210
211 void S25FL1D_SetReadLatencyControl(uint8_t Latency);
212
213 unsigned char S25FL1D_EraseChip(void);
214
215 unsigned char S25FL1D_EraseSector(unsigned int address);
216
217 unsigned char S25FL1D_Erase64KBlock(unsigned int address);
218
219 unsigned char S25FL1D_Write(
220  uint32_t *pData,
221  uint32_t size,
222  uint32_t address,
223  uint8_t Secure);
224
225 extern unsigned char S25FL1D_Read(
226  uint32_t *pData,
227  uint32_t size,
228  uint32_t address);
229
230 extern unsigned char S25FL1D_ReadDual(
231  uint32_t *pData,
232  uint32_t size,
233  uint32_t address);
234
235 extern unsigned char S25FL1D_ReadQuad(
236  uint32_t *pData,
237  uint32_t size,
238  uint32_t address);
239
240 extern unsigned char S25FL1D_ReadDualIO(
241  uint32_t *pData,
242  uint32_t size,
243  uint32_t address,
244  uint8_t ContMode,
245  uint8_t Secure);
246
247 extern unsigned char S25FL1D_ReadQuadIO(
248  uint32_t *pData,
249  uint32_t size,
250  uint32_t address,
251  uint8_t ContMode,
252  uint8_t Secure);
253
254 #endif // #ifndef S25FL1_H
255
unsigned size
Definition: tte.h:74
