RTEMS
5.1
Classic Event Manager API. More...
#define | RTEMS_ALL_EVENTS 0xFFFFFFFF |
Constant used to send or receive all events. | |
#define | RTEMS_EVENT_0 0x00000001 |
Defines the bit in the event set associated with event 0. | |
#define | RTEMS_EVENT_1 0x00000002 |
Defines the bit in the event set associated with event 1. | |
#define | RTEMS_EVENT_2 0x00000004 |
Defines the bit in the event set associated with event 2. | |
#define | RTEMS_EVENT_3 0x00000008 |
Defines the bit in the event set associated with event 3. | |
#define | RTEMS_EVENT_4 0x00000010 |
Defines the bit in the event set associated with event 4. | |
#define | RTEMS_EVENT_5 0x00000020 |
Defines the bit in the event set associated with event 5. | |
#define | RTEMS_EVENT_6 0x00000040 |
Defines the bit in the event set associated with event 6. | |
#define | RTEMS_EVENT_7 0x00000080 |
Defines the bit in the event set associated with event 7. | |
#define | RTEMS_EVENT_8 0x00000100 |
Defines the bit in the event set associated with event 8. | |
#define | RTEMS_EVENT_9 0x00000200 |
Defines the bit in the event set associated with event 9. | |
#define | RTEMS_EVENT_10 0x00000400 |
Defines the bit in the event set associated with event 10. | |
#define | RTEMS_EVENT_11 0x00000800 |
Defines the bit in the event set associated with event 11. | |
#define | RTEMS_EVENT_12 0x00001000 |
Defines the bit in the event set associated with event 12. | |
#define | RTEMS_EVENT_13 0x00002000 |
Defines the bit in the event set associated with event 13. | |
#define | RTEMS_EVENT_14 0x00004000 |
Defines the bit in the event set associated with event 14. | |
#define | RTEMS_EVENT_15 0x00008000 |
Defines the bit in the event set associated with event 15. | |
#define | RTEMS_EVENT_16 0x00010000 |
Defines the bit in the event set associated with event 16. | |
#define | RTEMS_EVENT_17 0x00020000 |
Defines the bit in the event set associated with event 17. | |
#define | RTEMS_EVENT_18 0x00040000 |
Defines the bit in the event set associated with event 18. | |
#define | RTEMS_EVENT_19 0x00080000 |
Defines the bit in the event set associated with event 19. | |
#define | RTEMS_EVENT_20 0x00100000 |
Defines the bit in the event set associated with event 20. | |
#define | RTEMS_EVENT_21 0x00200000 |
Defines the bit in the event set associated with event 21. | |
#define | RTEMS_EVENT_22 0x00400000 |
Defines the bit in the event set associated with event 22. | |
#define | RTEMS_EVENT_23 0x00800000 |
Defines the bit in the event set associated with event 23. | |
#define | RTEMS_EVENT_24 0x01000000 |
Defines the bit in the event set associated with event 24. | |
#define | RTEMS_EVENT_25 0x02000000 |
Defines the bit in the event set associated with event 25. | |
#define | RTEMS_EVENT_26 0x04000000 |
Defines the bit in the event set associated with event 26. | |
#define | RTEMS_EVENT_27 0x08000000 |
Defines the bit in the event set associated with event 27. | |
#define | RTEMS_EVENT_28 0x10000000 |
Defines the bit in the event set associated with event 29. | |
#define | RTEMS_EVENT_29 0x20000000 |
#define | RTEMS_EVENT_30 0x40000000 |
Defines the bit in the event set associated with event 30. | |
#define | RTEMS_EVENT_31 0x80000000 |
Defines the bit in the event set associated with event 31. | |
#define | RTEMS_PENDING_EVENTS 0 |
Constant used to receive the set of currently pending events in rtems_event_receive(). | |
#define | RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT RTEMS_EVENT_24 |
Reserved system event for network SBWAIT usage. | |
#define | RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP RTEMS_EVENT_25 |
Reserved system event for network SOSLEEP usage. | |
#define | RTEMS_EVENT_SYSTEM_NETWORK_CLOSE RTEMS_EVENT_26 |
Reserved system event for network socket close. | |
#define | RTEMS_EVENT_SYSTEM_SERVER_RESUME RTEMS_EVENT_29 |
Reserved system event to resume server threads, e.g timer or interrupt server. | |
#define | RTEMS_EVENT_SYSTEM_SERVER RTEMS_EVENT_30 |
Reserved system event for the server threads, e.g timer or interrupt server. | |
#define | RTEMS_EVENT_SYSTEM_TRANSIENT RTEMS_EVENT_31 |
Reserved system event for transient usage. | |
Typedefs | |
typedef uint32_t | rtems_event_set |
Integer type to hold an event set of up to 32 events represented as a bit field. | |
rtems_status_code | rtems_event_send (rtems_id id, rtems_event_set event_in) |
Sends an Event Set to the Target Task. More... | |
rtems_status_code | rtems_event_receive (rtems_event_set event_in, rtems_option option_set, rtems_interval ticks, rtems_event_set *event_out) |
Receives pending events. More... | |
rtems_status_code | rtems_event_system_send (rtems_id id, rtems_event_set event_in) |
See rtems_event_send(). | |
rtems_status_code | rtems_event_system_receive (rtems_event_set event_in, rtems_option option_set, rtems_interval ticks, rtems_event_set *event_out) |
See rtems_event_receive(). | |
RTEMS_INLINE_ROUTINE rtems_status_code | rtems_event_transient_send (rtems_id id) |
See rtems_event_system_send(). More... | |
RTEMS_INLINE_ROUTINE rtems_status_code | rtems_event_transient_receive (rtems_option option_set, rtems_interval ticks) |
See rtems_event_system_receive(). More... | |
RTEMS_INLINE_ROUTINE void | rtems_event_transient_clear (void) |
