RTEMS  5.1
Typedefs | Enumerations | Functions
RTEMS File System Link Support. More...
#include <dirent.h>
#include <rtems/rfs/rtems-rfs-inode.h>
typedef enum rtems_rfs_unlink_dir_e rtems_rfs_unlink_dir
enum  rtems_rfs_unlink_dir_e { rtems_rfs_unlink_dir_denied, rtems_rfs_unlink_dir_if_empty, rtems_rfs_unlink_dir_allowed }
int rtems_rfs_link (rtems_rfs_file_system *fs, const char *name, int length, rtems_rfs_ino parent, rtems_rfs_ino target, bool link_dir)
int rtems_rfs_unlink (rtems_rfs_file_system *fs, rtems_rfs_ino parent, rtems_rfs_ino target, uint32_t doff, rtems_rfs_unlink_dir dir_mode)
int rtems_rfs_symlink (rtems_rfs_file_system *fs, const char *name, int length, const char *link, int link_length, uid_t uid, gid_t gid, rtems_rfs_ino parent)
int rtems_rfs_symlink_read (rtems_rfs_file_system *fs, rtems_rfs_ino link, char *path, size_t size, size_t *length)
This file provides the link support functions.
Typedef Documentation
◆ rtems_rfs_unlink_dir
Directory unlink modes.
◆ rtems_rfs_unlink_dir_e
Not allowed to unlink a directory.
Unlink if the directory is empty.
Unlinking of directories is allowed.
◆ rtems_rfs_link()
int rtems_rfs_link ( rtems_rfs_file_system fs,
const char *  name,
int  length,
bool  link_dir
Create a link. Do not link directories unless renaming or you will create loops in the file system.
Parameters
[in]fsis the file system.
[in]nameis a pointer to the name of the link.
[in]lengthis the length of the name.
[in]parentis the inode number of the parent directory.
[in]targetis the inode of the target.
[in]link_dirIf true directories can be linked. Useful when renaming.
Return values
0Successful operation.
error_codeAn error occurred.
◆ rtems_rfs_symlink()
int rtems_rfs_symlink ( rtems_rfs_file_system fs,
const char *  name,
int  length,
const char *  link,
int  link_length,
uid_t  uid,
gid_t  gid,
Symbolic link is an inode that has a path attached.
Parameters
[in]fsis the file system data.
[in]nameis a pointer to the name of the node.
[in]lengthis the length of the name of the node.
[in]linkis a pointer to the link path attached to the symlink inode.
[in]link_lengthis the length of the link path.
[in]parentis the parent inode number.
Return values
◆ rtems_rfs_symlink_read()
int rtems_rfs_symlink_read ( rtems_rfs_file_system fs,
rtems_rfs_ino  link,
char *  path,
size_t  size,
size_t *  length
Read a symbolic link into the provided buffer returning the link of link name.
Parameters
[in]linkis the link inode number to read.
[in]pathis a pointer to the buffer to write the link path into.
[in]sizeis the size of the buffer.
[out]lengthwill contain the length of the link path.
Return values
◆ rtems_rfs_unlink()
int rtems_rfs_unlink ( rtems_rfs_file_system fs,
uint32_t  doff,
Unlink the node from the parent directory. A directory offset for the target entry is required because links cause a number of inode numbers to appear in a single directory so scanning does not work.
Parameters
[in]doffis the parent directory entry offset for the target entry.
[in]dir_modeis the directory unlink mode.
Return values
