RTEMS  5.1
Macros | Functions
RTEMS File Systems Bitmap Routines. More...
#include <rtems/rfs/rtems-rfs-bitmaps.h>
#define RTEMS_RFS_BITMAP_WARNINGS   0
rtems_rfs_bitmap_element rtems_rfs_bitmap_mask (unsigned int size)
rtems_rfs_bitmap_element rtems_rfs_bitmap_mask_section (unsigned int start, unsigned int end)
int rtems_rfs_bitmap_map_set (rtems_rfs_bitmap_control *control, rtems_rfs_bitmap_bit bit)
int rtems_rfs_bitmap_map_clear (rtems_rfs_bitmap_control *control, rtems_rfs_bitmap_bit bit)
int rtems_rfs_bitmap_map_test (rtems_rfs_bitmap_control *control, rtems_rfs_bitmap_bit bit, bool *state)
int rtems_rfs_bitmap_map_set_all (rtems_rfs_bitmap_control *control)
int rtems_rfs_bitmap_map_clear_all (rtems_rfs_bitmap_control *control)
int rtems_rfs_bitmap_map_alloc (rtems_rfs_bitmap_control *control, rtems_rfs_bitmap_bit seed, bool *allocated, rtems_rfs_bitmap_bit *bit)
int rtems_rfs_bitmap_create_search (rtems_rfs_bitmap_control *control)
int rtems_rfs_bitmap_open (rtems_rfs_bitmap_control *control, rtems_rfs_file_system *fs, rtems_rfs_buffer_handle *buffer, size_t size, rtems_rfs_buffer_block block)
int rtems_rfs_bitmap_close (rtems_rfs_bitmap_control *control)
These functions manage bit maps. A bit map consists of the map of bit allocated in a block and a search map where a bit represents 32 actual bits. The search map allows for a faster search for an available bit as 32 search bits can checked in a test.
◆ RTEMS_RFS_BITMAP_WARNINGS
Set to 1 to enable warnings when developing.
◆ rtems_rfs_bitmap_close()
int rtems_rfs_bitmap_close ( rtems_rfs_bitmap_control control)
Close a bitmap.
Parameters
[in]controlis the bit map control.
Return values
0Successful operation.
error_codeAn error occurred.
◆ rtems_rfs_bitmap_create_search()
int rtems_rfs_bitmap_create_search ( rtems_rfs_bitmap_control control)
Create a search bit map from the actual bit map.
Parameters
[in]controlis the map control.
Return values
◆ rtems_rfs_bitmap_map_alloc()
int rtems_rfs_bitmap_map_alloc ( rtems_rfs_bitmap_control control,
bool *  allocate,
Find a free bit searching from the seed up and down until found. The search is performing by moving up from the seed for the window distance then to search down from the seed for the window distance. This is repeated out from the seed for each window until a free bit is found. The search is performed by checking the search map to see if the map has a free bit.
Parameters
[in]seedis the bit to search out from.
[out]allocateA bit was allocated.
[out]bitwill contain the bit found free if true is returned.
Return values
◆ rtems_rfs_bitmap_map_clear()
int rtems_rfs_bitmap_map_clear ( rtems_rfs_bitmap_control control,
Clear a bit in a map and make sure the search map bit is clear so a search will find this bit available.
Parameters
[in]controlis the control for the map.
[in]bitis the bit in the map to clear.
Return values
◆ rtems_rfs_bitmap_map_clear_all()
int rtems_rfs_bitmap_map_clear_all ( rtems_rfs_bitmap_control control)
Clear all bits in the bitmap and set the dirty bit.
Parameters
[in]controlis the bitmap control.
Return values
◆ rtems_rfs_bitmap_map_set()
int rtems_rfs_bitmap_map_set ( rtems_rfs_bitmap_control control,
Set a bit in a map and if all the bits are set, set the search map bit as well.
Parameters
[in]bitis the bit in the map to set.
Return values
◆ rtems_rfs_bitmap_map_set_all()
int rtems_rfs_bitmap_map_set_all ( rtems_rfs_bitmap_control control)
Set all bits in the bitmap and set the dirty bit.
Parameters
Return values
◆ rtems_rfs_bitmap_map_test()
int rtems_rfs_bitmap_map_test ( rtems_rfs_bitmap_control control,
bool *  state
Test a bit in the map.
Parameters
[in]bitis the bit to test.
[in]stateis the state of the bit if no error is returned.
Return values
◆ rtems_rfs_bitmap_mask()
rtems_rfs_bitmap_element rtems_rfs_bitmap_mask ( unsigned int  size)
Create a bit mask with the specified number of bits up to an element's size. The mask is aligned to bit 0 of the element.
Parameters
[in]sizeis the number of bits in the mask.
Returns
The mask of the argument size number of bits.
◆ rtems_rfs_bitmap_mask_section()
rtems_rfs_bitmap_element rtems_rfs_bitmap_mask_section ( unsigned int  start,
unsigned int  end
Create a bit mask section. A mask section is a mask that is not aligned to an end of the element.
Parameters
[in]startis the first bit of the mask numbered from 0.
[in]endis the end bit of the mask numbered from 0.
Returns
Mask section as defined by the start and end arguments.
◆ rtems_rfs_bitmap_open()
int rtems_rfs_bitmap_open ( rtems_rfs_bitmap_control control,
rtems_rfs_file_system fs,
rtems_rfs_buffer_handle buffer,
size_t  size,
Open a bitmap control with a map and search map.
Parameters
[in]fsis the file system data.
[in]bufferis a pointer to the buffer handle the map is stored in.
[in]sizeis the number of bits in the map.
Return values
