RTEMS  5.1
rtems-debugger-target.h
1 /*
2  * Copyright (c) 2016-2017 Chris Johns <chrisj@rtems.org>.
3  * All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  *
14  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
15  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
18  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
19  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
20  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
21  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
22  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
23  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
24  * SUCH DAMAGE.
25  */
26
27 /*
28  * Debugger for RTEMS.
29  */
30
31 #ifndef _RTEMS_DEBUGGER_TARGET_h
32 #define _RTEMS_DEBUGGER_TARGET_h
33
34 #include <setjmp.h>
35
36 #include <rtems/rtems-debugger.h>
37
38 #include "rtems-debugger-threads.h"
39
40 #ifdef __cplusplus
41 extern "C" {
42 #endif /* __cplusplus */
43
44 /*
45  * Software breakpoint block size.
46  */
47 #define RTEMS_DEBUGGER_TARGET_SWBREAK_NUM 64
48
52 #define RTEMS_DEBUGGER_TARGET_CAP_SWBREAK (1 << 0)
53 #define RTEMS_DEBUGGER_TARGET_CAP_HWBREAK (1 << 1)
54 #define RTEMS_DEBUGGER_TARGET_CAP_HWWATCH (1 << 2)
55
59 typedef enum rtems_debugger_target_watchpoint
60 {
61  rtems_debugger_target_hw_read,
62  rtems_debugger_target_hw_write,
63  rtems_debugger_target_hw_read_write,
64  rtems_debugger_target_hw_execute
65 } rtems_debugger_target_watchpoint;
66
70 typedef enum rtems_debugger_target_exc_action
71 {
72  rtems_debugger_target_exc_consumed, /*<< The exception has been consumed. */
73  rtems_debugger_target_exc_cascade, /*<< Cascade to a previous handler. */
74  rtems_debugger_target_exc_step, /*<< Step an instruction. */
75 } rtems_debugger_target_exc_action;
76
80 #define RTEMS_DEBUGGER_TARGET_SWBREAK_MAX_SIZE (4)
82  void* address;
83  uint8_t contents[RTEMS_DEBUGGER_TARGET_SWBREAK_MAX_SIZE];
85
93 typedef struct rtems_debugger_target {
94  int capabilities; /*<< The capabilities to report. */
95  size_t reg_num; /*<< The number of registers. */
96  const size_t* reg_offset; /*<< The reg offsettable, len = reg_num + 1. */
97  const uint8_t* breakpoint; /*<< The breakpoint instruction(s). */
98  size_t breakpoint_size; /*<< The breakpoint size. */
99  rtems_debugger_block swbreaks; /*<< The software breakpoint block. */
100  bool memory_access; /*<< Accessing target memory. */
101  jmp_buf access_return; /*<< Return from an access fault. */
103
107 extern int rtems_debugger_target_create(void);
108
112 extern int rtems_debugger_target_destroy(void);
113
117 extern int rtems_debugger_target_configure(rtems_debugger_target* target);
118
122 extern int rtems_debugger_target_enable(void);
123
127 extern int rtems_debugger_target_disable(void);
128
132 extern uint32_t rtems_debugger_target_capabilities(void);
133
137 extern size_t rtems_debugger_target_reg_num(void);
138
142 extern size_t rtems_debugger_target_reg_size(size_t reg);
143
147 extern size_t rtems_debugger_target_reg_offset(size_t reg);
148
152 extern size_t rtems_debugger_target_reg_table_size(void);
153
157 extern int rtems_debugger_target_read_regs(rtems_debugger_thread* thread);
158
162 extern int rtems_debugger_target_write_regs(rtems_debugger_thread* thread);
163
167 extern DB_UINT rtems_debugger_target_reg_pc(rtems_debugger_thread* thread);
168
172 extern DB_UINT rtems_debugger_target_frame_pc(CPU_Exception_frame* frame);
173
177 extern DB_UINT rtems_debugger_target_reg_sp(rtems_debugger_thread* thread);
178
182 extern DB_UINT rtems_debugger_target_tcb_sp(rtems_debugger_thread* thread);
183
187 extern int rtems_debugger_target_thread_stepping(rtems_debugger_thread* thread);
188
192 extern int rtems_debugger_target_exception_to_signal(CPU_Exception_frame* frame);
193
197 extern void rtems_debugger_target_exception_print(CPU_Exception_frame* frame);
198
202 extern int rtems_debugger_target_swbreak_control(bool insert,
203  DB_UINT addr,
204  DB_UINT kind);
205
209 extern int rtems_debugger_target_swbreak_insert(void);
210
214 extern int rtems_debugger_target_swbreak_remove(void);
215
219 extern int rtems_debugger_target_hwbreak_insert(void);
220
224 extern int rtems_debugger_target_hwbreak_remove(void);
225
229 extern int rtems_debugger_target_hwbreak_control(rtems_debugger_target_watchpoint type,
230  bool insert,
231  DB_UINT addr,
232  DB_UINT kind);
233
237 extern rtems_debugger_target_exc_action
238 rtems_debugger_target_exception(CPU_Exception_frame* frame);
239
243 extern void rtems_debugger_target_exception_thread(rtems_debugger_thread* thread);
244
248 extern void rtems_debugger_target_exception_thread_resume(rtems_debugger_thread* thread);
249
254 extern int rtems_debugger_target_cache_sync(rtems_debugger_target_swbreak* swbreak);
255
260 extern int rtems_debugger_target_start_memory_access(void);
261
265 extern void rtems_debugger_target_end_memory_access(void);
266
270 extern bool rtems_debugger_target_is_memory_access(void);
271
272 #ifdef __cplusplus
273 }
274 #endif /* __cplusplus */
275
276
277 #endif
Definition: rtems-debugger-threads.h:86
Definition: rtems-debugger-target.h:93
Definition: rtems-debugger-block.h:45
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
Definition: rtems-debugger-target.h:81
