RTEMS  5.1
recorddump.h
1 /* SPDX-License-Identifier: BSD-2-Clause */
2
3 /*
4  * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
5  *
6  * Redistribution and use in source and binary forms, with or without
7  * modification, are permitted provided that the following conditions
8  * are met:
9  * 1. Redistributions of source code must retain the above copyright
10  * notice, this list of conditions and the following disclaimer.
11  * 2. Redistributions in binary form must reproduce the above copyright
12  * notice, this list of conditions and the following disclaimer in the
13  * documentation and/or other materials provided with the distribution.
14  *
15  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25  * POSSIBILITY OF SUCH DAMAGE.
26  */
27
28 #ifndef _RTEMS_RECORDDUMP_H
29 #define _RTEMS_RECORDDUMP_H
30
31 #include <rtems/record.h>
32
33 #include <zlib.h>
34
35 #ifdef __cplusplus
36 extern "C" {
37 #endif /* __cplusplus */
38
52 typedef void ( *rtems_record_dump_chunk )(
53  void *arg,
54  const void *data,
55  size_t length
56 );
57
68  void *arg
69 );
70
79 void rtems_record_dump_base64( void ( *put_char )( int, void * ), void *arg );
80
85 typedef struct {
86  void ( *put_char )( int, void * );
87  void *arg;
88  int out;
89  unsigned char buf[ 57 ];
90  z_stream stream;
91  char *mem_begin;
92  size_t mem_available;
93  char mem[ 0x80000 ];
95
108  void ( *put_char )( int, void * ),
109  void *arg
110 );
111
114 #ifdef __cplusplus
115 }
116 #endif /* __cplusplus */
117
118 #endif /* _RTEMS_RECORDDUMP_H */
void rtems_record_dump_base64(void(*put_char)(int, void *), void *arg)
Dumps the event records in base64 encoding.
void rtems_record_dump(rtems_record_dump_chunk chunk, void *arg)
Dumps the record header, the thread names, and all items of all processors.
Definition: record-dump.c:92
The context for record dumps with zlib compression and base64 encoding.
Definition: recorddump.h:85
void rtems_record_dump_zlib_base64(rtems_record_dump_base64_zlib_context *ctx, void(*put_char)(int, void *), void *arg)
Dumps the event records compressed with zlib in base64 encoding.
Definition: record-dump-zbase64.c:132
void(* rtems_record_dump_chunk)(void *arg, const void *data, size_t length)
Handler for record dumps to output a chunk of data.
Definition: recorddump.h:52
Definition: zlib.h:170
