RTEMS  5.1
rbheap.h
1
7 /*
8  * Copyright (c) 2012 embedded brains GmbH. All rights reserved.
9  *
10  * embedded brains GmbH
11  * Obere Lagerstr. 30
12  * 82178 Puchheim
13  * Germany
14  * <rtems@embedded-brains.de>
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  */
20
21 #ifndef _RTEMS_RBHEAP_H
22 #define _RTEMS_RBHEAP_H
23
24 #include <rtems.h>
25 #include <rtems/chain.h>
26 #include <rtems/rbtree.h>
27
28 #ifdef __cplusplus
29 extern "C" {
30 #endif
31
54 typedef struct {
64
70
75  uintptr_t begin;
76
80  uintptr_t size;
82
84
106
115
123
128
132  uintptr_t alignment;
133
138
142  void *handler_arg;
143 };
144
162  void *area_begin,
163  uintptr_t area_size,
164  uintptr_t alignment,
165  rtems_rbheap_extend_descriptors extend_descriptors,
166  void *handler_arg
167 );
168
183
197
198 static inline rtems_chain_control *rtems_rbheap_get_spare_descriptor_chain(
200 )
201 {
202  return &control->spare_descriptor_chain;
203 }
204
205 static inline void rtems_rbheap_add_to_spare_descriptor_chain(
207  rtems_rbheap_chunk *chunk
208 )
209 {
210  rtems_chain_control *chain =
211  rtems_rbheap_get_spare_descriptor_chain(control);
212
215 }
216
217 static inline void rtems_rbheap_set_extend_descriptors(
219  rtems_rbheap_extend_descriptors extend_descriptors
220 )
221 {
222  control->extend_descriptors = extend_descriptors;
223 }
224
225 static inline void *rtems_rbheap_get_handler_arg(
227 )
228 {
229  return control->handler_arg;
230 }
231
232 static inline void rtems_rbheap_set_handler_arg(
234  void *handler_arg
235 )
236 {
237  control->handler_arg = handler_arg;
238 }
239
244
250 );
251
254 /* Private API */
255
256 #define rtems_rbheap_chunk_of_node(node) \
257  RTEMS_CONTAINER_OF(node, rtems_rbheap_chunk, tree_node)
258
259 static inline bool rtems_rbheap_is_chunk_free(const rtems_rbheap_chunk *chunk)
260 {
261  return !rtems_chain_is_node_off_chain(&chunk->chain_node);
262 }
263
264 #ifdef __cplusplus
265 }
266 #endif
267
268 #endif /* _RTEMS_RBHEAP_H */
RTEMS_INLINE_ROUTINE void rtems_chain_initialize_node(rtems_chain_node *node)
Initializes a chain node.
Definition: chain.h:198
rtems_chain_control spare_descriptor_chain
Definition: rbheap.h:122
Definition: chain.h:68
Constants and Structures Associated with the RBTree API in RTEMS.
uintptr_t begin
Definition: rbheap.h:75
rtems_rbtree_control chunk_tree
Definition: rbheap.h:127
Red-black heap control.
Definition: rbheap.h:110
Definition: chain.h:86
Red-black tree node.
Definition: rbtree.h:55
Red-black heap chunk descriptor.
Definition: rbheap.h:54
void rtems_rbheap_extend_descriptors_never(rtems_rbheap_control *control)
Chunk descriptor extend handler that does nothing.
Definition: rbheap.c:270
rtems_chain_node chain_node
Definition: rbheap.h:63
RBTree_Control rtems_rbtree_control
rtems_status_code rtems_rbheap_initialize(rtems_rbheap_control *control, void *area_begin, uintptr_t area_size, uintptr_t alignment, rtems_rbheap_extend_descriptors extend_descriptors, void *handler_arg)
Initializes the red-black tree heap control.
Definition: rbheap.c:91
rtems_rbtree_node tree_node
Definition: rbheap.h:69
RTEMS_INLINE_ROUTINE void rtems_chain_prepend_unprotected(rtems_chain_control *the_chain, rtems_chain_node *the_node)
Prepend a node (unprotected).
Definition: chain.h:714
uintptr_t size
Definition: rbheap.h:80
rtems_status_code
Classic API Status.
Definition: status.h:43
RTEMS_INLINE_ROUTINE bool rtems_chain_is_node_off_chain(const rtems_chain_node *node)
Is the node off chain.
Definition: chain.h:216
void(* rtems_rbheap_extend_descriptors)(rtems_rbheap_control *control)
Handler to extend the available chunk descriptors.
Definition: rbheap.h:105
void * rtems_rbheap_allocate(rtems_rbheap_control *control, size_t size)
Allocates a chunk of memory of at least size bytes from the red-black tree heap control.
Definition: rbheap.c:165
Definition: intercom.c:74
Chain API.
Definition: rbheap.h:137
void * handler_arg
Definition: rbheap.h:142
void rtems_rbheap_extend_descriptors_with_malloc(rtems_rbheap_control *control)
Chunk descriptor extend handler that uses malloc().
Definition: rbheap.c:275
rtems_status_code rtems_rbheap_free(rtems_rbheap_control *control, void *ptr)
Frees a chunk of memory ptr allocated from the red-black tree heap control.
Definition: rbheap.c:243
unsigned size
Definition: tte.h:74
rtems_chain_control free_chunk_chain
Definition: rbheap.h:114
uintptr_t alignment
Definition: rbheap.h:132
