RTEMS  5.1
ps2_mouse.h
1
9 /*
10  * include/linux/pc_keyb.h
11  * PC Keyboard And Keyboard Controller
12  * (c) 1997 Martin Mares <mj@atrey.karlin.mff.cuni.cz>
13  *
14  * RTEMS port: by Rosimildo da Silva.
15  *
16  * This module was ported from Linux.
17  *
18  */
19
20 /*
21  * Configuration Switches
22  */
23
24 #undef KBD_REPORT_ERR /* Report keyboard errors */
25 #define KBD_REPORT_UNKN /* Report unknown scan codes */
26 #define KBD_REPORT_TIMEOUTS /* Report keyboard timeouts */
27 #undef KBD_IS_FOCUS_9000 /* We have the brain-damaged FOCUS-9000 keyboard */
28 #undef INITIALIZE_MOUSE /* Define if your PS/2 mouse needs initialization. */
29
30 #define KBD_INIT_TIMEOUT 1000 /* Timeout in ms for initializing the keyboard */
31 #define KBC_TIMEOUT 250 /* Timeout in ms for sending to keyboard controller */
32 #define KBD_TIMEOUT 1000 /* Timeout in ms for keyboard command acknowledge */
33
34 /*
35  * Internal variables of the driver
36  */
37
38 extern unsigned char pckbd_read_mask;
39 extern unsigned char aux_device_present;
40
41 /*
42  * Keyboard Controller Registers on normal PCs.
43  */
44
45 #define KBD_STATUS_REG 0x64 /* Status register (R) */
46 #define KBD_CNTL_REG 0x64 /* Controller command register (W) */
47 #define KBD_DATA_REG 0x60 /* Keyboard data register (R/W) */
48
49 /*
50  * Keyboard Controller Commands
51  */
52
53 #define KBD_CCMD_READ_MODE 0x20 /* Read mode bits */
54 #define KBD_CCMD_WRITE_MODE 0x60 /* Write mode bits */
55 #define KBD_CCMD_GET_VERSION 0xA1 /* Get controller version */
56 #define KBD_CCMD_MOUSE_DISABLE 0xA7 /* Disable mouse interface */
57 #define KBD_CCMD_MOUSE_ENABLE 0xA8 /* Enable mouse interface */
58 #define KBD_CCMD_TEST_MOUSE 0xA9 /* Mouse interface test */
59 #define KBD_CCMD_SELF_TEST 0xAA /* Controller self test */
60 #define KBD_CCMD_KBD_TEST 0xAB /* Keyboard interface test */
61 #define KBD_CCMD_KBD_DISABLE 0xAD /* Keyboard interface disable */
62 #define KBD_CCMD_KBD_ENABLE 0xAE /* Keyboard interface enable */
63 #define KBD_CCMD_WRITE_AUX_OBUF 0xD3 /* Write to output buffer as if
64  initiated by the auxiliary device */
65 #define KBD_CCMD_WRITE_MOUSE 0xD4 /* Write the following byte to the mouse */
66
67 /*
68  * Keyboard Commands
69  */
70
71 #define KBD_CMD_SET_LEDS 0xED /* Set keyboard leds */
72 #define KBD_CMD_SET_RATE 0xF3 /* Set typematic rate */
73 #define KBD_CMD_ENABLE 0xF4 /* Enable scanning */
74 #define KBD_CMD_DISABLE 0xF5 /* Disable scanning */
75 #define KBD_CMD_RESET 0xFF /* Reset */
76
77 /*
78  * Keyboard Replies
79  */
80
81 #define KBD_REPLY_POR 0xAA /* Power on reset */
82 #define KBD_REPLY_ACK 0xFA /* Command ACK */
83 #define KBD_REPLY_RESEND 0xFE /* Command NACK, send the cmd again */
84
85 /*
86  * Status Register Bits
87  */
88
89 #define KBD_STAT_OBF 0x01 /* Keyboard output buffer full */
90 #define KBD_STAT_IBF 0x02 /* Keyboard input buffer full */
91 #define KBD_STAT_SELFTEST 0x04 /* Self test successful */
92 #define KBD_STAT_CMD 0x08 /* Last write was a command write (0=data) */
93 #define KBD_STAT_UNLOCKED 0x10 /* Zero if keyboard locked */
94 #define KBD_STAT_MOUSE_OBF 0x20 /* Mouse output buffer full */
95 #define KBD_STAT_GTO 0x40 /* General receive/xmit timeout */
96 #define KBD_STAT_PERR 0x80 /* Parity error */
97
98 #define AUX_STAT_OBF (KBD_STAT_OBF | KBD_STAT_MOUSE_OBF)
99
100 /*
101  * Controller Mode Register Bits
102  */
103
104 #define KBD_MODE_KBD_INT 0x01 /* Keyboard data generate IRQ1 */
105 #define KBD_MODE_MOUSE_INT 0x02 /* Mouse data generate IRQ12 */
106 #define KBD_MODE_SYS 0x04 /* The system flag (?) */
107 #define KBD_MODE_NO_KEYLOCK 0x08 /* The keylock doesn't affect the keyboard if set */
108 #define KBD_MODE_DISABLE_KBD 0x10 /* Disable keyboard interface */
109 #define KBD_MODE_DISABLE_MOUSE 0x20 /* Disable mouse interface */
110 #define KBD_MODE_KCC 0x40 /* Scan code conversion to PC format */
111 #define KBD_MODE_RFU 0x80
112
113 /*
114  * Mouse Commands
115  */
116
117 #define AUX_SET_RES 0xE8 /* Set resolution */
118 #define AUX_SET_SCALE11 0xE6 /* Set 1:1 scaling */
119 #define AUX_SET_SCALE21 0xE7 /* Set 2:1 scaling */
120 #define AUX_GET_SCALE 0xE9 /* Get scaling factor */
121 #define AUX_SET_STREAM 0xEA /* Set stream mode */
122 #define AUX_SET_SAMPLE 0xF3 /* Set sample rate */
123 #define AUX_ENABLE_DEV 0xF4 /* Enable aux device */
124 #define AUX_DISABLE_DEV 0xF5 /* Disable aux device */
125 #define AUX_RESET 0xFF /* Reset aux device */
126 #define AUX_ACK 0xFA /* Command byte ACK. */
127
128 #define AUX_BUF_SIZE 512 /* This might be better divisible by
129  three to make overruns stay in sync
130  but then the read function would need
131  a lock etc - ick */
132
133 struct aux_queue {
134  unsigned long head;
135  unsigned long tail;
136  struct wait_queue *proc_list;
137  struct fasync_struct *fasync;
138  unsigned char buf[AUX_BUF_SIZE];
139 };
140
141 /* How to access the keyboard macros on this platform. */
142 #define kbd_read_input() inb(KBD_DATA_REG)
143 #define kbd_read_status() inb(KBD_STATUS_REG)
144 #define kbd_write_output(val) outb(val, KBD_DATA_REG)
145 #define kbd_write_command(val) outb(val, KBD_CNTL_REG)
146
147 /*
148  * Machine specific bits for the PS/2 driver
149  */
150
151 #define AUX_IRQ 12
Definition: ps2_mouse.h:133
