#define | KBD_REPORT_UNKN /* Report unknown scan codes */ |
#define | KBD_REPORT_TIMEOUTS /* Report keyboard timeouts */ |
#define | KBD_INIT_TIMEOUT 1000 /* Timeout in ms for initializing the keyboard */ |
#define | KBC_TIMEOUT 250 /* Timeout in ms for sending to keyboard controller */ |
#define | KBD_TIMEOUT 1000 /* Timeout in ms for keyboard command acknowledge */ |
#define | KBD_STATUS_REG 0x64 /* Status register (R) */ |
#define | KBD_CNTL_REG 0x64 /* Controller command register (W) */ |
#define | KBD_DATA_REG 0x60 /* Keyboard data register (R/W) */ |
#define | KBD_CCMD_READ_MODE 0x20 /* Read mode bits */ |
#define | KBD_CCMD_WRITE_MODE 0x60 /* Write mode bits */ |
#define | KBD_CCMD_GET_VERSION 0xA1 /* Get controller version */ |
#define | KBD_CCMD_MOUSE_DISABLE 0xA7 /* Disable mouse interface */ |
#define | KBD_CCMD_MOUSE_ENABLE 0xA8 /* Enable mouse interface */ |
#define | KBD_CCMD_TEST_MOUSE 0xA9 /* Mouse interface test */ |
#define | KBD_CCMD_SELF_TEST 0xAA /* Controller self test */ |
#define | KBD_CCMD_KBD_TEST 0xAB /* Keyboard interface test */ |
#define | KBD_CCMD_KBD_DISABLE 0xAD /* Keyboard interface disable */ |
#define | KBD_CCMD_KBD_ENABLE 0xAE /* Keyboard interface enable */ |
#define | KBD_CCMD_WRITE_AUX_OBUF |
#define | KBD_CCMD_WRITE_MOUSE 0xD4 /* Write the following byte to the mouse */ |
#define | KBD_CMD_SET_LEDS 0xED /* Set keyboard leds */ |
#define | KBD_CMD_SET_RATE 0xF3 /* Set typematic rate */ |
#define | KBD_CMD_ENABLE 0xF4 /* Enable scanning */ |
#define | KBD_CMD_DISABLE 0xF5 /* Disable scanning */ |
#define | KBD_CMD_RESET 0xFF /* Reset */ |
#define | KBD_REPLY_POR 0xAA /* Power on reset */ |
#define | KBD_REPLY_ACK 0xFA /* Command ACK */ |
#define | KBD_REPLY_RESEND 0xFE /* Command NACK, send the cmd again */ |
#define | KBD_STAT_OBF 0x01 /* Keyboard output buffer full */ |
#define | KBD_STAT_IBF 0x02 /* Keyboard input buffer full */ |
#define | KBD_STAT_SELFTEST 0x04 /* Self test successful */ |
#define | KBD_STAT_CMD 0x08 /* Last write was a command write (0=data) */ |
#define | KBD_STAT_UNLOCKED 0x10 /* Zero if keyboard locked */ |
#define | KBD_STAT_MOUSE_OBF 0x20 /* Mouse output buffer full */ |
#define | KBD_STAT_GTO 0x40 /* General receive/xmit timeout */ |
#define | KBD_STAT_PERR 0x80 /* Parity error */ |
#define | AUX_STAT_OBF (KBD_STAT_OBF | KBD_STAT_MOUSE_OBF) |
#define | KBD_MODE_KBD_INT 0x01 /* Keyboard data generate IRQ1 */ |
#define | KBD_MODE_MOUSE_INT 0x02 /* Mouse data generate IRQ12 */ |
#define | KBD_MODE_SYS 0x04 /* The system flag (?) */ |
#define | KBD_MODE_NO_KEYLOCK 0x08 /* The keylock doesn't affect the keyboard if set */ |
#define | KBD_MODE_DISABLE_KBD 0x10 /* Disable keyboard interface */ |
#define | KBD_MODE_DISABLE_MOUSE 0x20 /* Disable mouse interface */ |
#define | KBD_MODE_KCC 0x40 /* Scan code conversion to PC format */ |
#define | KBD_MODE_RFU 0x80 |
#define | AUX_SET_RES 0xE8 /* Set resolution */ |
#define | AUX_SET_SCALE11 0xE6 /* Set 1:1 scaling */ |
#define | AUX_SET_SCALE21 0xE7 /* Set 2:1 scaling */ |
#define | AUX_GET_SCALE 0xE9 /* Get scaling factor */ |
#define | AUX_SET_STREAM 0xEA /* Set stream mode */ |
#define | AUX_SET_SAMPLE 0xF3 /* Set sample rate */ |
#define | AUX_ENABLE_DEV 0xF4 /* Enable aux device */ |
#define | AUX_DISABLE_DEV 0xF5 /* Disable aux device */ |
#define | AUX_RESET 0xFF /* Reset aux device */ |
#define | AUX_ACK 0xFA /* Command byte ACK. */ |
#define | AUX_BUF_SIZE |
#define | kbd_read_input() inb(KBD_DATA_REG) |
#define | kbd_read_status() inb(KBD_STATUS_REG) |
#define | kbd_write_output(val) outb(val, KBD_DATA_REG) |
#define | kbd_write_command(val) outb(val, KBD_CNTL_REG) |
#define | AUX_IRQ 12 |
