RTEMS  5.1
pci_io_remap.h
1 #ifndef RTEMS_PCI_IO_REMAP_H
2 #define RTEMS_PCI_IO_REMAP_H
3 /* Reconfigure all I/O base address registers for a range of PCI busses
4  * (from and including 'bus_from' up to and not including 'bus_to').
5  * adding an offset. This involves adjusting the base and limit registers
6  * of PCI-PCI bridges, too.
7  *
8  * RESTRICTIONS: 'offset' must be 4k aligned (PCI req.); no argument check
9  * on the bus numbers is done.
10  *
11  * RETURNS: 0 on success and a number > 0 indicating the number of
12  * non-32bit bridges found where the offset couldn't be added.
13  * Devices behind such a bridge are not accessible through I/O
14  * and should probably be switched off (not done by this code).
15  */
16
17 int
18 rtems_pci_io_remap(int bus_from, int bus_to, uint32_t offset);
19
20 /*
21  * Authorship
22  * ----------
23  * This software ('beatnik' RTEMS BSP for MVME6100 and MVME5500) was
24  * created by Till Straumann <strauman@slac.stanford.edu>, 2005-2007,
25  * Stanford Linear Accelerator Center, Stanford University.
26  *
27  * Acknowledgement of sponsorship
28  * ------------------------------
29  * The 'beatnik' BSP was produced by
30  * the Stanford Linear Accelerator Center, Stanford University,
31  * under Contract DE-AC03-76SFO0515 with the Department of Energy.
32  *
33  * Government disclaimer of liability
34  * ----------------------------------
35  * Neither the United States nor the United States Department of Energy,
36  * nor any of their employees, makes any warranty, express or implied, or
37  * assumes any legal liability or responsibility for the accuracy,
38  * completeness, or usefulness of any data, apparatus, product, or process
39  * disclosed, or represents that its use would not infringe privately owned
40  * rights.
41  *
42  * Stanford disclaimer of liability
43  * --------------------------------
44  * Stanford University makes no representations or warranties, express or
45  * implied, nor assumes any liability for the use of this software.
46  *
47  * Stanford disclaimer of copyright
48  * --------------------------------
49  * Stanford University, owner of the copyright, hereby disclaims its
50  * copyright and all other rights in this software. Hence, anyone may
51  * freely use it for any purpose without restriction.
52  *
53  * Maintenance of notices
54  * ----------------------
55  * In the interest of clarity regarding the origin and status of this
56  * SLAC software, this and all the preceding Stanford University notices
57  * are to remain affixed to any copy or derivative of this software made
58  * or distributed by the recipient and are to be affixed to any copy of
59  * software made or distributed by the recipient that contains a copy or
60  * derivative of this software.
61  *
62  * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
63  */
64
65 #endif
66
