RTEMS  5.1
passwd.h
1 /* Define a default password for telnetd here.
2  * NOTES:
3  * - this can be overridden at run-time by setting
4  * the "TELNETD_PASSWD" environment variable.
5  * As soon as that variable is set, the new password
6  * is effective - no need to restart telnetd.
7  * - this must be set to an _encrypted_ password, NOT
8  * the cleartext. Use the 'genpw' utility to generate
9  * a password string:
10  *
11  * 1) Compile 'genpw.c' for the HOST, i.e.
12  * cc -o genpw genpw.c -lcrypt
13  * 1) delete an old password definition from this file.
14  * 2) run './genpw >> passwd.h'. This will append
15  * a new definition to this file.
16  *
17  * - if no password is defined here, no authentication
18  * is needed, i.e. telnet is open to the world.
19  *
20  * T. Straumann <strauman@slac.stanford.edu>
21  */
22
23 /* #undef TELNETD_DEFAULT_PASSWD */
24 /* Default password: 'rtems' */
25 #define TELNETD_DEFAULT_PASSWD "tduDcyLX12owo"
