RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
powerpc
virtex
include
bsp
opbintctrl.h
1
/* opbintctrl.h
2
3
* This file contains definitions and declarations for the
4
* Xilinx Off Processor Bus (OPB) Interrupt Controller
5
6
* Author: Keith Robertson <kjrobert@alumni.uwaterloo.ca>
7
* COPYRIGHT (c) 2005 by Linn Products Ltd, Scotland
8
9
* The license and distribution terms for this file may be
10
* found in the file LICENSE in this distribution or at
11
* http://www.rtems.org/license/LICENSE.
12
13
14
#ifndef _INCLUDE_OPBINTCTRL_H
15
#define _INCLUDE_OPBINTCTRL_H
16
17
rtems.h
18
rtems/score/isr.h
19
rtems/irq.h
20
#include <bspopts.h>
21
#include RTEMS_XPARAMETERS_H
22
23
#define USE_GREG_INTERRUPTS
24
25
#ifdef __cplusplus
26
extern
"C"
27
#endif
28
29
30
/* extern XIntc InterruptController;
31
32
33
34
/* Maximum number of IRQs. Defined in vhdl model */
35
#define OPB_INTC_IRQ_MAX XPAR_INTC_MAX_NUM_INTR_INPUTS
36
37
/* Width of INTC registers. Defined in vhdl model */
38
#define OPB_INTC_REGISTER_WIDTH 32
39
40
/* Base Register address and register offsets. Defined in vhdl model */
41
#define OPB_INTC_BASE XPAR_INTC_SINGLE_BASEADDR
42
43
44
45
46
47
/* Interrupt Status Register */
48
#define OPB_INTC_ISR 0x0
49
/* Interrupt Pending Register (ISR && IER) */
50
#define OPB_INTC_IPR 0x4
51
/* Interrupt Enable Register */
52
#define OPB_INTC_IER 0x8
53
/* Interrupt Acknowledge Register */
54
#define OPB_INTC_IAR 0xC
55
/* Set Interrupt Enable (same as read/mask/write to IER) */
56
#define OPB_INTC_SIE 0x10
57
/* Clear Interrupt Enable (same as read/mask/write to IER) */
58
#define OPB_INTC_CIE 0x14
59
/* Interrupt Vector Address (highest priority vector number from IPR) */
60
#define OPB_INTC_IVR 0x18
61
/* Master Enable Register */
62
#define OPB_INTC_MER 0x1C
63
64
/* Master Enable Register: Hardware Interrupt Enable */
65
#define OPB_INTC_MER_HIE 0x2
66
67
/* Master Enable Register: Master IRQ Enable */
68
#define OPB_INTC_MER_ME 0x1
69
70
#ifdef __cplusplus
71
72
#endif
73
74
#endif
/* _INCLUDE_OPBINTCTRL_H */
isr.h
Data Related to the Management of Processor Interrupt Levels.
rtems.h
irq.h
