RTEMS
5.1
NFS Client Implementation for RTEMS. More...
#include <rtems/libio.h>
#include <rtems/libio_.h>
#include <rtems/seterr.h>
#include <rtems/thread.h>
#include <stdint.h>
#include <assert.h>
#include <sys/stat.h>
#include <dirent.h>
#include <netdb.h>
#include <ctype.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include "../proto/nfs_prot.h"
#include "../proto/mount_prot.h"
#include "rpcio.h"
#include "librtemsNfs.h"
struct | strbuf |
struct | readlinkres_strbuf |
struct | DirInfoRec_ |
struct | serporidok |
struct | serporid |
struct | NfsRec_ |
struct | NfsNodeRec_ |
struct | nfsstats |
struct | ResolvePathArgRec_ |
#define | CONFIG_AVG_NAMLEN 10 |
#define | CONFIG_NFS_SMALL_XACT_SIZE 800 /* size of RPC arguments for non-write ops */ |
#define | CONFIG_ATTR_LIFETIME 10/*secs*/ |
#define | DEFAULT_NFS_ST_BLKSIZE NFS_MAXDATA |
#define | CONFIG_NFS_BIG_XACT_SIZE UDPMSGSIZE /* dont change this */ |
#define | NFSCALL_TIMEOUT (&_nfscalltimeout) |
#define | MNTCALL_TIMEOUT (&_nfscalltimeout) |
#define | DELIM '/' |
#define | HOSTDELIM ':' |
#define | UPDIR ".." |
#define | UIDSEP '@' |
#define | NFS_VERSION_2 NFS_VERSION |
#define | NFS_MAJOR (nfsGlob.nfs_major) |
#define | NFS_MAKE_DEV_T_INO_HACK(node) |
#define | NFS_MAKE_DEV_T(node) |
#define | DIRENT_HEADER_SIZE |
#define | DEBUG_COUNT_NODES (1<<0) |
#define | DEBUG_TRACK_NODES (1<<1) |
#define | DEBUG_EVALPATH (1<<2) |
#define | DEBUG_READDIR (1<<3) |
#define | DEBUG_SYSCALLS (1<<4) |
#define | STATIC static |
#define | LOCK(s) rtems_recursive_mutex_lock(&(s)) |
#define | UNLOCK(s) rtems_recursive_mutex_unlock(&(s)) |
#define | NFS_GLOBAL_ACQUIRE(lock_context) rtems_interrupt_lock_acquire(&nfs_global_lock, lock_context) |
#define | NFS_GLOBAL_RELEASE(lock_context) rtems_interrupt_lock_release(&nfs_global_lock, lock_context) |
#define | SERP_ARGS(node) ((node)->serporid.serporid_u.serporid.arg_u) |
#define | SERP_ATTR(node) ((node)->serporid.serporid_u.serporid.attributes) |
#define | SERP_FILE(node) ((node)->serporid.serporid_u.serporid.file) |
#define | READ_LONG_IS_ATOMIC |
#define | SATTR_MODE (1<<0) |
#define | SATTR_UID (1<<1) |
#define | SATTR_GID (1<<2) |
#define | SATTR_SIZE (1<<3) |
#define | SATTR_ATIME (1<<4) |
#define | SATTR_TOUCHA (1<<5) |
#define | SATTR_MTIME (1<<6) |
#define | SATTR_TOUCHM (1<<7) |
#define | SATTR_TOUCH (SATTR_TOUCHM | SATTR_TOUCHA) |
Typedefs | |
typedef struct strbuf | strbuf |
typedef struct readlinkres_strbuf | readlinkres_strbuf |
typedef struct DirInfoRec_ | DirInfoRec |
typedef struct DirInfoRec_ * | DirInfo |
typedef struct serporidok | serporidok |
typedef struct serporid | serporid |
typedef uint32_t | TimeStamp |
typedef struct NfsRec_ | NfsRec |
typedef struct NfsRec_ * | Nfs |
typedef struct NfsNodeRec_ | NfsNodeRec |
typedef struct NfsNodeRec_ * | NfsNode |
typedef struct ResolvePathArgRec_ | ResolvePathArgRec |
typedef struct ResolvePathArgRec_ * | ResolvePathArg |
int | nfsMountsShow (FILE *) |
rtems_status_code | rtems_filesystem_resolve_location (char *buf, int len, rtems_filesystem_location_info_t *loc) |
int | nfsInit (int smallPoolDepth, int bigPoolDepth) |
int | nfsCleanup (void) |
STATIC int | nfscall (RpcUdpServer srvr, int proc, xdrproc_t xargs, void *pargs, xdrproc_t xres, void *pres) |
int | rtems_nfs_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data) |
STATIC void | nfs_fsunmount_me (rtems_filesystem_mount_table_entry_t *mt_entry) |
int | nfsSetTimeout (uint32_t timeout_ms) |
uint32_t | nfsGetTimeout (void) |
const struct _rtems_filesystem_operations_table | nfs_fs_ops |
int | nfsStBlksize = DEFAULT_NFS_ST_BLKSIZE |
Hooks Into the RTEMS NFS Filesystem
#define DIRENT_HEADER_SIZE |
#define NFS_MAKE_DEV_T | ( | node | ) |
#define NFS_MAKE_DEV_T_INO_HACK | ( | node | ) |
const struct _rtems_filesystem_operations_table nfs_fs_ops |
