RTEMS  5.1
gtpcireg.h
1 /* $NetBSD: gtpcireg.h,v 1.2 2003/03/24 17:03:18 matt Exp $ */
2
3 /*
4  * Copyright (c) 2002 Allegro Networks, Inc., Wasabi Systems, Inc.
5  * All rights reserved.
6  *
7  * Redistribution and use in source and binary forms, with or without
8  * modification, are permitted provided that the following conditions
9  * are met:
10  * 1. Redistributions of source code must retain the above copyright
11  * notice, this list of conditions and the following disclaimer.
12  * 2. Redistributions in binary form must reproduce the above copyright
13  * notice, this list of conditions and the following disclaimer in the
14  * documentation and/or other materials provided with the distribution.
15  * 3. All advertising materials mentioning features or use of this software
16  * must display the following acknowledgement:
17  * This product includes software developed for the NetBSD Project by
18  * Allegro Networks, Inc., and Wasabi Systems, Inc.
19  * 4. The name of Allegro Networks, Inc. may not be used to endorse
20  * or promote products derived from this software without specific prior
21  * written permission.
22  * 5. The name of Wasabi Systems, Inc. may not be used to endorse
23  * or promote products derived from this software without specific prior
24  * written permission.
25  *
26  * THIS SOFTWARE IS PROVIDED BY ALLEGRO NETWORKS, INC. AND
27  * WASABI SYSTEMS, INC. ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES,
28  * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
29  * AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
30  * IN NO EVENT SHALL EITHER ALLEGRO NETWORKS, INC. OR WASABI SYSTEMS, INC.
31  * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37  * POSSIBILITY OF SUCH DAMAGE.
38  */
39 #define PCI_ARBCTL_EN (1<<31)
40
41 #define PCI_COMMAND_SB_DIS 0x2000 /* PCI configuration read will stop
42  * acting as sync barrier transactin
43  */
44
45 #define PCI_MEM_BASE_ADDR PCI_BASE_ADDRESS_4
46
47 #define PCI_IO_BASE_ADDR PCI_BASE_ADDRESS_5
48
49 #define PCI_STATUS_CLRERR_MASK 0xf9000000 /* <SKF> */
50
51 #define PCI_BARE_IntMemEn 0x200
52
53 #define PCI_ACCCTLBASEL_PrefetchEn 0x0001000
54 #define PCI_ACCCTLBASEL_RdPrefetch 0x0010000
55 #define PCI_ACCCTLBASEL_RdLinePrefetch 0x0020000
56 #define PCI_ACCCTLBASEL_RdMulPrefetch 0x0040000
57 #define PCI_ACCCTLBASEL_WBurst_8_QW 0x0100000
58 #define PCI_ACCCTLBASEL_PCISwap_NoSwap 0x1000000
59
60 #define PCI0_P2P_CONFIG 0x1d14
61 #define PCI_SNOOP_BASE0_LOW 0x1f00
62 #define PCI_SNOOP_BASE0_HIGH 0x1f04
63 #define PCI_SNOOP_TOP0 0x1f08
64
65 #define PCI0_SCS0_BAR_SIZE 0x0c08
66 #define PCI0_SCS1_BAR_SIZE 0x0d08
67 #define PCI0_SCS2_BAR_SIZE 0x0c0c
68 #define PCI0_SCS3_BAR_SIZE 0x0d0c
69
70 #define PCI0_BASE_ADDR_REG_ENABLE 0x0c3c
71 #define PCI0_ARBITER_CNTL 0x1d00
72 #define PCI0_ACCESS_CNTL_BASE0_LOW 0x1e00
73 #define PCI0_ACCESS_CNTL_BASE0_HIGH 0x1e04
74 #define PCI0_ACCESS_CNTL_BASE0_TOP 0x1e08
75
76 #define PCI0_ACCESS_CNTL_BASE1_LOW 0x1e10
77 #define PCI0_ACCESS_CNTL_BASE1_HIGH 0x1e14
78 #define PCI0_ACCESS_CNTL_BASE1_TOP 0x1e18
79
80 #define PCI1_BASE_ADDR_REG_ENABLE 0x0cbc
81 #define PCI1_ARBITER_CNTL 0x1d80
82 #define PCI1_ACCESS_CNTL_BASE0_LOW 0x1e80
83 #define PCI1_ACCESS_CNTL_BASE0_HIGH 0x1e84
84 #define PCI1_ACCESS_CNTL_BASE0_TOP 0x1e88
85
86 #define PCI1_ACCESS_CNTL_BASE1_LOW 0x1e90
87 #define PCI1_ACCESS_CNTL_BASE1_HIGH 0x1e94
88 #define PCI1_ACCESS_CNTL_BASE1_TOP 0x1e98
89
90 #define PCI_SNOOP_BASE1_LOW 0x1f10
91 #define PCI_SNOOP_BASE1_HIGH 0x1f14
92 #define PCI_SNOOP_TOP1 0x1f18
93
94 #define PCI0_CMD_CNTL 0xc00
95
96 #define PCI1_P2P_CONFIG 0x1d94
97 #define PCI1_CMD_CNTL 0xc80
98 #define PCI1_CONFIG_ADDR 0xc78
99 #define PCI1_CONFIG_DATA 0xc7c
