RTEMS  5.1
mpc83xx.h
1 #ifndef _MPC83XX_MPC83XX_H
2 #define _MPC83XX_MPC83XX_H
3
4 #include <bspopts.h>
5
6 #if MPC83XX_CHIP_TYPE == 8343
7 #define M83xx_HAS_PCI TRUE
8 #define M83xx_HAS_USB1 TRUE
9 #elif MPC83XX_CHIP_TYPE == 8347
10 #define M83xx_HAS_PCI TRUE
11 #define M83xx_HAS_USB1 TRUE
12 #define M83xx_HAS_USB2 TRUE
13 #elif MPC83XX_CHIP_TYPE == 8349
14 #define M83xx_HAS_PCI TRUE
15 #define M83xx_HAS_WIDE_PCI TRUE
16 #define M83xx_HAS_USB1 TRUE
17 #define M83xx_HAS_USB2 TRUE
18 #elif MPC83XX_CHIP_TYPE == 8360
19 #define M83xx_HAS_PCI TRUE
20 #define M83xx_HAS_QE TRUE
21 #endif
22
23 #if !defined(ASM)
24
25 #include <rtems.h>
26 #include <bsp/tsec.h>
27
28 /* Offset Register Access Reset Section/Page */
29 /* System Configuration Registers */
30 typedef struct m83xxSysConRegisters_ {
31  volatile uint32_t immrbar; /* 0x0_00000 Internal memory map base address register R/W 0xFF40_0000 5.2.4.1/5-5 */
32  uint8_t reserved0_0004[0x00008-0x00004];/* 0x0_0004 Reserved, should be cleared */
33  volatile uint32_t altcbar; /* 0x0_0008 Alternate configuration base address register R/W 0x0000_0000 5.2.4.2/5-7 */
34  uint8_t reserved0_000C[0x00020-0x0000C];/* 0x0_000C--0x0_001C Reserved, should be cleared */
35  volatile uint32_t lblawbar0; /* 0x0_0020 LBC local access window 0 base address register R/W 0x0000_00001 5.2.4.3/5-7 */
36  volatile uint32_t lblawar0; /* 0x0_0024 LBC local access window 0 attribute register R/W 0x0000_00002 5.2.4.4/5-8 */
37  volatile uint32_t lblawbar1; /* 0x0_0028 LBC local access window 1 base address register R/W 0x0000_0000 5.2.4.3/5-7 */
38  volatile uint32_t lblawar1; /* 0x0_002C LBC local access window 1 attribute register R/W 0x0000_0000 5.2.4.4/5-8 */
39  volatile uint32_t lblawbar2; /* 0x0_0030 LBC local access window 2 base address register R/W 0x0000_0000 5.2.4.3/5-7 */
40  volatile uint32_t lblawar2; /* 0x0_0034 LBC local access window 2 attribute register R/W 0x0000_0000 5.2.4.4/5-8 */
41  volatile uint32_t lblawbar3; /* 0x0_0038 LBC local access window 3 base address register R/W 0x0000_0000 5.2.4.3/5-7 */
42  volatile uint32_t lblawar3; /* 0x0_003C LBC local access window 3 attribute register R/W 0x0000_0000 5.2.4.4/5-8 */
43  uint8_t reserved0_0040[0x00060-0x00040];/* 0x0_0040--0x0_005C Reserved, should be cleared */
44  volatile uint32_t pcilawbar0; /* 0x0_0060 PCI local access window0 base address register R/W 0x0000_00003 5.2.4.5/5-9 */
45  volatile uint32_t pcilawar0; /* 0x0_0064 PCI local access window0 attribute register R/W 0x0000_00004 5.2.4.6/5-10 */
46  volatile uint32_t pcilawbar1; /* 0x0_0068 PCI local access window1 base address register R/W 0x0000_0000 5.2.4.5/5-9 */
47  volatile uint32_t pcilawar1; /* 0x0_006C PCI local access window1 attribute register R/W 0x0000_0000 5.2.4.6/5-10 */
48  uint8_t reserved0_0070[0x000A0-0x00070];/* 0x0_0070--0x0_009C Reserved, should be cleared */
49  volatile uint32_t ddrlawbar0; /* 0x0_00A0 DDR local access window0 base address register R/W 0x0000_00005 5.2.4.7/5-12 */
50  volatile uint32_t ddrlawar0; /* 0x0_00A4 DDR local access window0 attribute register R/W 0x0000_00006 5.2.4.8/5-13 */
51  volatile uint32_t ddrlawbar1; /* 0x0_00A8 DDR local access window1 base address register R/W 0x0000_0000 5.2.4.7/5-12 */
52  volatile uint32_t ddrlawar1; /* 0x0_00AC DDR local access window1 attribute register R/W 0x0000_0000 5.2.4.8/5-13 */
53  uint8_t reserved0_00B0[0x00100-0x000B0];/* 0x0_00B0--0x0_0100 Reserved, should be cleared */
54  volatile uint32_t sgprl; /* 0x0_0100 general purpose register low (SGPRL) R/W 0x0000_0000 5.3.2.1/5-17 */
55  volatile uint32_t sgprh; /* 0x0_0104 general purpose register high (SGPRH) R/W 0x0000_0000 5.3.2.2/5-17 */
56  volatile uint32_t spridr; /* 0x0_0108 part and revision ID register (SPRIDR) R 0x0000_0000 5.3.2.3/5-18 */
57  uint8_t reserved0_010C[0x00110-0x0010C];/* 0x0_010C--0x0_0110 Reserved, should be cleared */
58  volatile uint32_t spcr; /* 0x0_0110 priority configuration register (SPCR) R/W 0x0000_0000 5.3.2.4/5-19 */
59  volatile uint32_t sicrl; /* 0x0_0114 I/O configuration register low (SICRL) R/W 0x0000_0000 5.3.2.5/5-21 */
60  volatile uint32_t sicrh; /* 0x0_0118 I/O configuration register high (SICRH) R/W 0x0000_00007 5.3.2.6/5-24 */
61  uint8_t reserved0_011C[0x00128-0x0011C];/* 0x0_011C--0x0_0128 Reserved */
62  volatile uint32_t ddrcdr; /* 0x0_0128 control driver register (DDRCDR) R/W 0x7304_0001 5.3.2.8/5-28 */
63  volatile uint32_t ddrdsr; /* 0x0_012C debug status register (DDRDSR) R 0x3300_0000 5.3.2.9/5-30 */
64  uint8_t reserved0_0130[0x00150-0x00130];/* 0x0_0130--0x0_015C Reserved */
65  volatile uint32_t gpr_1; /* 0x0_0150 General Purpose Register 1 (GPR_1) */
66  uint8_t reserved0_0154[0x00200-0x00154];/* 0x0_0154--0x0_01FC Reserved */
68 #define M83xx_SYSCON_SPCR_TBEN (1 << (31-9))
69
70 /* Watchdog Timer (WDT) Registers */
71 typedef struct m83xxWDTRegisters_ {
72  uint8_t reserved0_0200[0x00204-0x00200];/* 0x0_0200 Reserved, should be cleared */
73  volatile uint32_t swcrr; /* 0x0_0204 System watchdog control register R/W 0x0000_0007 5.4.4.1/5-33 */
74  volatile uint32_t swcnr; /* 0x0_0208 System watchdog count register R 0x0000_FFFF 5.4.4.2/5-34 */
75  uint8_t reserved0_020C[(0x0020E)-0x0020C];/* 0x0_020C Reserved, should be cleared */
76  volatile uint16_t swsrr; /* 0x0_020E System watchdog service register R/W 0x0000_0000 5.4.4.3/5-34 */
78
79 /* Real Time Clock Module Registers (RTC) */
80 typedef struct m83xxRTCRegisters_ {
81  volatile uint32_t rtcnr; /* 0x0_0300 Real time counter control register R/W 0x0000_0000 5.5.5.1/5-40 */
82  volatile uint32_t rtldr; /* 0x0_0304 Real time counter load register R/W 0x0000_0000 5.5.5.2/5-41 */
83  volatile uint32_t rtpsr; /* 0x0_0308 Real time counter prescale register R/W 0x0000_0000 5.5.5.3/5-41 */
84  volatile uint32_t rtctr; /* 0x0_030C Real time counter register R 0x0000_0000 5.5.5.4/5-42 */
85  volatile uint32_t rtevr; /* 0x0_0310 Real time counter event register R/W 0x0000_0000 5.5.5.5/5-42 */
86  volatile uint32_t rtalr; /* 0x0_0314 Real time counter alarm register R/W 0xFFFF_FFFF 5.5.5.6/5-43 */
87  uint8_t reserved0_0314[0x00320-0x00318];/* 0x0_0318--0x0_031F Reserved; should be cleared */
89
90  /* Periodic Interval Timer (PIT) Registers */
91 typedef struct m83xxPITRegisters_ {
92  volatile uint32_t ptcnr; /* 0x0_0400 Periodic interval timer control register R/W 0x0000_0000 5.6.5.1/5-47 */
93  volatile uint32_t ptldr; /* 0x0_0404 Periodic interval timer load register R/W 0x0000_0000 5.6.5.2/5-48 */
94  volatile uint32_t ptpsr; /* 0x0_0408 Periodic interval timer prescale register R/W 0x0000_0000 5.6.5.3/5-49 */
95  volatile uint32_t ptctr; /* 0x0_040C Periodic interval timer counter register R 0x0000_0000 5.6.5.4/5-49 */
96  volatile uint32_t ptevr; /* 0x0_0410 Periodic interval timer event register R/W 0x0000_0000 5.6.5.5/5-50 */
97  uint8_t reserved0_0414[0x00500-0x00414]; /* 0x0_0414--0x0_041F Reserved, should be cleared */
99
100  /* Global Timers Module 1/2 */
101 #define M83xxGTIdx(n) (n&3)
102 #define M83xxGTLowIdx(n) (n&1)
103 #define M83xxGTHighIdx(n) (((n)>>1)&1)
104 #define M83xxGTModIdx(n) (((n)>>2)&1)
105
106 #define M83xxGTIdxCnt (4)
107 #define M83xxGTLowCnt (2)
108 #define M83xxGTHighCnt (2)
109 #define M83xxGTModCnt (2)
110
111 typedef struct m83xxGTMRegisters_ {
112  struct {
113  volatile uint8_t reg; /* 0x0_0500 Timer 1+2/3+4 global timers configuration register R/W 0x00 5.7.5.1/5-57 */
114  uint8_t reserved0_0501[0x00504-0x00501]; /* 0x0_0501--0x0_0503 Reserved, should be cleared */
115  } gtcfr[M83xxGTHighCnt];
116  uint8_t reserved0_0508[0x00510-0x00508]; /* 0x0_0508--0x0_050f Reserved, should be cleared */
117  struct {
118  volatile uint16_t gtmdr[M83xxGTLowCnt]; /* 0x0_0510 Timer 1/2 global timers mode register R/W 0x0000 5.7.5.2/5-60 */
119  volatile uint16_t gtrfr[M83xxGTLowCnt]; /* 0x0_0514 Timer 1/2 global timers reference register R/W 0x0000 5.7.5.3/5-62 */
120  volatile uint16_t gtcpr[M83xxGTLowCnt]; /* 0x0_0518 Timer 1/2 global timers capture register R/W 0x0000 5.7.5.4/5-62 */
121  volatile uint16_t gtcnr[M83xxGTLowCnt]; /* 0x0_051C Timer 1/2 global timers counter register R/W 0x0000 5.7.5.5/5-63 */
122  } gt_tim_regs[M83xxGTHighCnt];
123  volatile uint16_t gtevr[M83xxGTIdxCnt]; /* 0x0_0530 Timer 1-4 global timers event register Special 0x0000 5.7.5.6/5-63 */
124  volatile uint16_t gtpsr[M83xxGTIdxCnt]; /* 0x0_0538 Timer 1-4 global timers prescale register R/W 0x0003 5.7.5.7/5-64 */
125  uint8_t reserved0_0540[0x00600-0x00540]; /* 0x0_0540--0x0_05fc Reserved */
127
128  /* Integrated Programmable Interrupt Controller (IPIC) */
129 typedef struct m83xxIPICRegisters_ {
130  volatile uint32_t sicfr; /* 0x0_0700 System global interrupt configuration register R/W 0x0000_0000 8.5.1/8-8 */
131  volatile uint32_t sivcr; /* 0x0_0704 System global interrupt vector register R 0x0000_0000 8.5.2/8-9 */
132  volatile uint32_t sipnr[2]; /* 0x0_0708 System internal interrupt pending register H/L R 0x0000_0000 8.5.3/8-11 */
133  volatile uint32_t siprr[4]; /* 0x0_0710 System internal interrupt group A-D priority register R/W 0x0530_9770 8.5.4/8-14 */
134  volatile uint32_t simsr[2]; /* 0x0_0720 System internal interrupt mask register H/L R/W 0x0000_0000 8.5.6/8-15 */
135  uint8_t reserved0_0728[0x0072C-0x00728]; /* 0x0_072C--0x0_0728 Reserved, should be cleared */
136  volatile uint32_t sepnr; /* 0x0_072C System external interrupt pending register R/W Special 8.5.8/8-18 */
137  volatile uint32_t smprr[2]; /* 0x0_0730 System mixed interrupt group A/B priority register R/W 0x0530_9770 8.5.9/8-18 */
138  volatile uint32_t semsr; /* 0x0_0738 System external interrupt mask register R/W 0x0000_0000 8.5.11/8-20 */
139  volatile uint32_t secnr; /* 0x0_073C System external interrupt control register R/W 0x0000_0000 8.5.12/8-21 */
140  volatile uint32_t sersr; /* 0x0_0740 System error status register R/W 0x0000_0000 8.5.13/8-22 */
141  volatile uint32_t sermr; /* 0x0_0744 System error mask register R/W $ 8.5.14/8-23 */
142  volatile uint32_t sercr; /* 0x0_0748 System error control register R/W 0x0000_0000 8.5.15/8-24 */
143  uint8_t reserved0_074C[0x00750-0x0074C]; /* 0x0_074C--0x0_074F Reserved, should be cleared */
144  volatile uint32_t sifcr[2]; /* 0x0_0750 System internal interrupt force register H/L R/W 0x0000_0000 8.5.16/8-25 */
145  volatile uint32_t sefcr; /* 0x0_0758 System external interrupt force register R/W 0x0000_0000 8.5.17/8-26 */
146  volatile uint32_t serfr; /* 0x0_075C System error force register R/W 0x0000_0000 8.5.18/8-26 */
147  volatile uint32_t scvcr; /* 0x0_0760 System critical interrupt vector register R 0x0000_0000 8.5.19/8-27 */
148  volatile uint32_t smvcr; /* 0x0_0764 System management interrupt vector register R 0x0000_0000 8.5.20/8-27 */
149  uint8_t reserved0_0760[0x00800-0x00768]; /* 0x0_0768--0x0_07FF Reserved, should be cleared */
151
152 /* get vector number from vector register content */
153 #define MPC83xx_VCR_TO_VEC(regval) ((regval) & 0x7f)
154
155
156  /* System Arbiter Registers */
157 typedef struct m83xxARBRegisters_ {
158  volatile uint32_t acr; /* 0x0_0800 Arbiter configuration register R/W 0x0000_0000 6.2.1/6-2 */
159  volatile uint32_t atr; /* 0x0_0804 Arbiter timers register R/W 0x00FF_00FF 6.2.2/6-4 */
160  uint8_t reserved0_0808[0x0080C-0x00808]; /* 0x0_0808 Reserved, should be cleared R 0x0000_0000 */
161  volatile uint32_t aer; /* 0x0_080C Arbiter event register R/W 0x0000_0000 6.2.3/6-5 */
162  volatile uint32_t aidr; /* 0x0_0810 Arbiter interrupt definition register R/W 0x0000_0000 6.2.4/6-6 */
163  volatile uint32_t amr; /* 0x0_0814 Arbiter mask register R/W 0x0000_0000 6.2.5/6-7 */
164  volatile uint32_t aeatr; /* 0x0_0818 Arbiter event attributes register R 0x0000_0000 6.2.6/6-7 */
165  volatile uint32_t aeadr; /* 0x0_081C Arbiter event address register R 0x0000_0000 6.2.7/6-9 */
166  volatile uint32_t aerr; /* 0x0_0820 Arbiter event response register R/W 0x0000_0000 6.2.8/6-10 */
167  uint8_t reserved0_0824[0x00900-0x00824]; /* 0x0_0824--0x0_08FF Reserved, should be cleared */
169
170  /* Reset Module */
171 typedef struct m83xxRESRegisters_ {
172  volatile uint32_t rcwlr; /* 0x0_0900 Reset configuration word low register R 0x0000_0000 4.5.1.1/4-32 */
173  volatile uint32_t rcwhr; /* 0x0_0904 Reset configuration word high register R 0x0000_0000 4.5.1.2/4-32 */
174  uint8_t reserved0_0908[0x00910-0x00908]; /* 0x0_0908--0x0_090C Reserved, should be cleared */
175  volatile uint32_t rsr; /* 0x0_0910 Reset status register R/W 0x0000_0000 4.5.1.3/4-33 */
176  volatile uint32_t rmr; /* 0x0_0914 Reset mode register R/W 0x0000_0000 4.5.1.4/4-34 */
177  volatile uint32_t rpr; /* 0x0_0918 Reset protection register R/W 0x0000_0000 4.5.1.5/4-35 */
178  volatile uint32_t rcr; /* 0x0_091C Reset control register R/W 0x0000_0000 4.5.1.6/4-36 */
179  volatile uint32_t rcer; /* 0x0_0920 Reset control enable register R/W 0x0000_0000 4.5.1.7/4-36 */
180  uint8_t reserved0_0924[0x00A00-0x00924]; /* 0x0_0924--0x0_09FC Reserved, should be cleared */
182
183  /* Clock Module */
184 typedef struct m83xxCLKRegisters_ {
185  volatile uint32_t spmr; /* 0x0_0A00 System PLL mode register R 0x0000_0000 4.5.2.1/4-37 */
186  volatile uint32_t occr; /* 0x0_0A04 Output clock control register R/W 0x0000_0000 4.5.2.2/4-38 */
187  volatile uint32_t sccr; /* 0x0_0A08 System clock control register R/W 0xFFFF_FFFF 4.5.2.3/4-40 */
188  uint8_t reserved0_0A08[0x00B00-0x00A0C]; /* 0x0_0A0C--0x0_0AFC Reserved, should be cleared */
190  /* Power Management Control Module */
191 typedef struct m83xxPMCRegisters_ {
192  volatile uint32_t pmccr; /* 0x0_0B00 Power management controller configuration register R/W 0x0000_0000 5.8.3.1/5-69 */
193  volatile uint32_t pmcer; /* 0x0_0B04 Power management controller event register R/W 0x0000_0000 5.8.3.2/5-70 */
194  volatile uint32_t pmcmr; /* 0x0_0B08 Power management controller mask register R/W 0x0000_0000 5.8.3.3/5-71 */
195  uint8_t reserved0_0B10[0x00C00-0x00B0C]; /* 0x0_0B0C--0x0_0BFC Reserved, should be cleared */
197  /* GPIO1 Registers */
198 typedef struct m83xxGPIORegisters_ {
199  volatile uint32_t gpdir; /* 0x0_0C00 GPIO1/2 direction register R/W 0x0000_0000 21.3.1/21-3 */
200  volatile uint32_t gpdr; /* 0x0_0C04 GPIO1/2 open drain register R/W 0x0000_0000 21.3.2/21-4 */
201  volatile uint32_t gpdat; /* 0x0_0C08 GPIO1/2 data register R/W 0x0000_0000 21.3.3/21-4 */
202  volatile uint32_t gpier; /* 0x0_0C0C GPIO1/2 interrupt event register R/W Undefined 21.3.4/21-5 */
203  volatile uint32_t gpimr; /* 0x0_0C10 GPIO1/2 interrupt mask register R/W 0x0000_0000 21.3.5/21-5 */
204  volatile uint32_t gpicr; /* 0x0_0C14 GPIO1/2 external interrupt control register R/W 0x0000_0000 21.3.6/21-6 */
205  uint8_t reserved0_0C1C[0x00D00-0x00C18]; /* 0x0_0C18--0x0_0CFF Reserved, should be cleared */
207
208  /* DLL */
209 typedef struct m83xxDLLRegisters_ {
210  uint8_t reserved0_1000[0x01010-0x01000]; /* 0x0_1000--0x0_100F Reserved, should be cleared */
211  volatile uint32_t mckenr; /* 0x0_1010 MCK enable register (MCKENR) R/W 0xFC00_0000 4.5.3/4-41 */
212  uint8_t reserved0_1014[0x01100-0x01014]; /* 0x0_1014--0x0_10FF Reserved, should be cleared */
213  volatile uint32_t reserved0_1100; /* 0x0_1100 Reserved. Reset value should be preserved. R/W 0x0500_0280 */
214  volatile uint32_t reserved0_1104; /* 0x0_1104 Reserved. Reset value should be preserved. R/W 0x8004_0810 */
215  volatile uint32_t dllovr; /* 0x0_1108 DLL override register (DLLOVR) R/W 0x0000_0000 22.4.1/22-4 */
216  volatile uint32_t dllsr; /* 0x0_110C DLL status register (DLLSR) R 0x0000_0000 22.4.2/22-4 */
217  volatile uint32_t dllck; /* 0x0_1110 DLL clock register (DLLCK) R/W 0xFC00_0000 22.4.3/22-5 */
218  uint8_t reserved0_1110[0x01200-0x01114]; /* 0x0_1114--0x0_11FF Reserved, should be cleared */
220
221  /* DDR Memory Controller Memory Map */
222 typedef struct m83xxDDRRegisters_ {
223  volatile uint32_t cs0_bnds; /* 0x0_2000 Chip select 0 memory bounds R/W 0x0000_0000 9.4.1.1/9-10 */
224  uint8_t reserved0_2004[0x02008-0x02004]; /* 0x0_2004--0x0_2008 Reserved, should be cleared */
225  volatile uint32_t cs1_bnds; /* 0x0_2008 Chip select 1 memory bounds R/W 0x0000_0000 */
226  uint8_t reserved0_200C[0x02010-0x0200C]; /* 0x0_200C--0x0_2010 Reserved, should be cleared */
227  volatile uint32_t cs2_bnds; /* 0x0_2010 Chip select 2 memory bounds R/W 0x0000_0000 */
228  uint8_t reserved0_2014[0x02018-0x02014]; /* 0x0_2014--0x0_2018 Reserved, should be cleared */
229  volatile uint32_t cs3_bnds; /* 0x0_2018 Chip select 3 memory bounds R/W 0x0000_0000 */
230  uint8_t reserved0_201C[0x02080-0x0201C]; /* 0x0_201C--0x0_207F Reserved, should be cleared */
231  volatile uint32_t cs0_config; /* 0x0_2080 Chip select 0 configuration R/W 0x0000_0000 9.4.1.2/9-11 */
232  volatile uint32_t cs1_config; /* 0x0_2084 Chip select 1 configuration R/W 0x0000_0000 */
233  volatile uint32_t cs2_config; /* 0x0_2088 Chip select 2 configuration R/W 0x0000_0000 */
234  volatile uint32_t cs3_config; /* 0x0_208C Chip select 3 configuration R/W 0x0000_0000 */
235  uint8_t reserved0_2090[0x02100-0x02090]; /* 0x0_2090--0x0_2100 Reserved, should be cleared */
236  volatile uint32_t timing_cfg_3; /* 0x0_2100 DDR SDRAM timing configuration 3 R/W 0x0000_0000 9.4.1.3/9-13 */
237  volatile uint32_t timing_cfg_0; /* 0x0_2104 DDR SDRAM timing configuration 0 R/W 0x0011_0105 9.4.1.4/9-14 */
238  volatile uint32_t timing_cfg_1; /* 0x0_2108 DDR SDRAM timing configuration 1 R/W 0x0000_0000 9.4.1.5/9-16 */
239  volatile uint32_t timing_cfg_2; /* 0x0_210C DDR SDRAM timing configuration 2 R/W 0x0000_0000 9.4.1.6/9-18 */
240  volatile uint32_t ddr_sdram_cfg; /* 0x0_2110 DDR SDRAM control configuration R/W 0x0200_0000 9.4.1.7/9-20 */
241  volatile uint32_t ddr_sdram_cfg_2; /* 0x0_2114 DDR SDRAM control configuration 2 R/W 0x0000_0000 9.4.1.8/9-22 */
242  volatile uint32_t ddr_sdram_mode; /* 0x0;_2118 DDR SDRAM mode configuration R/W 0x0000_0000 9.4.1.9/9-24 */
243  volatile uint32_t ddr_sdram_mode_2; /* 0x0_211C DDR SDRAM mode configuration 2 R/W 0x0000_0000 9.4.1.10/9-24 */
244  volatile uint32_t ddr_sdram_md_cntl; /* 0x0_2120 DDR SDRAM mode control R/W 0x0000_0000 9.4.1.11/9-25 */
245  volatile uint32_t ddr_sdram_interval; /* 0x0_2124 DDR SDRAM interval configuration R/W 0x0000_0000 9.4.1.12/9-27 */
246  volatile uint32_t ddr_data_init; /* 0x0_2128 DDR SDRAM data initialization R/W 0x0000_0000 9.4.1.13/9-28 */
247  uint8_t reserved0_212C[0x02130-0x0212C]; /* 0x0_212C Reserved $ $ */
248  volatile uint32_t ddr_sdram_clk_cntl; /* 0x0_2130 DDR SDRAM clock control R/W 0x0200_0000 9.4.1.14/9-28 */
249  uint8_t reserved0_2134[0x02148-0x02134]; /* 0x0_2140 Reserved $ $ */
250  volatile uint32_t ddr_init_address; /* 0x0_2148 DDR training initialization address R/W 0x0000_0000 9.4.1.15/9-29 */
251  uint8_t reserved0_214C[0x02BF8-0x0214C]; /* 0x0_214C Reserved $ $ */
252  volatile uint32_t ddr_ip_rev1; /* 0x0_2BF8 DDR IP block revision 1 R 0x0002_0200 9.4.1.16/9-30 */
253  volatile uint32_t ddr_ip_rev2; /* 0x0_2BFC DDR IP block revision 2 R 0x0000_0000 9.4.1.17/9-30 */
254  uint8_t reserved0_2C00[0x02E00-0x02C00]; /* 0x0_2C00 Reserved $ $ */
255  volatile uint32_t data_err_inject_hi; /* 0x0_2E00 Memory data path error injection mask high R/W 0x0000_0000 9.4.1.18/9-31 */
256  volatile uint32_t data_err_inject_lo; /* 0x0_2E04 Memory data path error injection mask low R/W 0x0000_0000 9.4.1.19/9-31 */
257  volatile uint32_t ecc_err_inject; /* 0x0_2E08 Memory data path error injection mask ECC R/W 0x0000_0000 9.4.1.20/9-32 */
258  uint8_t reserved0_2E0C[0x02E20-0x02E0C]; /* 0x0_2E0C Reserved $ $ */
259  volatile uint32_t capture_data_hi; /* 0x0_2E20 Memory data path read capture high R/W 0x0000_0000 9.4.1.21/9-32 */
260  volatile uint32_t capture_data_lo; /* 0x0_2E24 Memory data path read capture low R/W 0x0000_0000 9.4.1.22/9-33 */
261  volatile uint32_t capture_ecc; /* 0x0_2E28 Memory data path read capture ECC R/W 0x0000_0000 9.4.1.23/9-33 */
262  uint8_t reserved0_2E2C[0x02E40-0x02E2C]; /* 0x0_2E2C Reserved $ $ */
263  volatile uint32_t err_detect; /* 0x0_2E40 Memory error detect w1c 0x0000_0000 9.4.1.24/9-33 */
264  volatile uint32_t err_disable; /* 0x0_2E44 Memory error disable R/W 0x0000_0000 9.4.1.25/9-34 */
265  volatile uint32_t err_int_en; /* 0x0_2E48 Memory error interrupt enable R/W 0x0000_0000 9.4.1.26/9-35 */
266  volatile uint32_t capture_attributes; /* 0x0_2E4C Memory error attributes capture R/W 0x0000_0000 9.4.1.27/9-36 */
267  volatile uint32_t capture_address; /* 0x0_2E50 Memory error address capture R/W 0x0000_0000 9.4.1.28/9-37 */
268  uint8_t reserved0_2E54[0x02E58-0x02E54]; /* 0x0_2E54 Reserved $ $ */
269  volatile uint32_t err_sbe; /* 0x0_2E58 Single-Bit ECC memory error management R/W 0x0000_0000 9.4.1.29/9-37 */
270  uint8_t reserved0_2E5C[0x2F00-0x2E5C];
272
273  /* I2C Controller */
274 typedef struct m83xxI2CRegisters_ {
275  volatile uint8_t i2cadr; /* 0x0_3000 I2C1 address register R/W 0x00 17.3.1.1/17-5 */
276  uint8_t reserved0_3001[0x03004-0x03001];
277  volatile uint8_t i2cfdr; /* 0x0_3004 I2C1 frequency divider register R/W 0x00 17.3.1.2/17-5 */
278  uint8_t reserved0_3005[0x03008-0x03005];
279  volatile uint8_t i2ccr; /* 0x0_3008 I2C1 control register R/W 0x00 17.3.1.3/17-6 */
280  uint8_t reserved0_3009[0x0300C-0x03009];
281  volatile uint8_t i2csr; /* 0x0_300C I2C1 status register R/W 0x81 17.3.1.4/17-8 */
282  uint8_t reserved0_300D[0x03010-0x0300D];
283  volatile uint8_t i2cdr; /* 0x0_3010 I2C1 data register R/W 0x00 17.3.1.5/17-9 */
284  uint8_t reserved0_3011[0x03014-0x03011];
285  volatile uint8_t i2cdfsrr; /* 0x0_3014 I2C1 digital filter sampling rate register R/W 0x0001_0000 17.3.1.6/17-10 */
286  uint8_t reserved0_3015[0x03018-0x03015];
287  uint8_t reserved0_3018[0x03100-0x03018]; /* 0x0_3018-30FF Reserved, should be cleared */
289
290  /* DUART */
291 typedef struct m83xxDUARTRegisters_ {
292  union {
293  volatile uint8_t urbr; /* 0x0_4500 ULCR[DLAB] = 0 UART1 receiver buffer register R 0x00 18.3.1.1/18-6 */
294  volatile uint8_t uthr; /* 0x0_4500 ULCR[DLAB] = 0 UART1 transmitter holding register W 0x00 18.3.1.2/18-6 */
295  volatile uint8_t udlb; /* 0x0_4500 ULCR[DLAB] = 1 UART1 divisor least significant byte register R/W 0x00 18.3.1.3/18-7 */
296  } urbr_uthr_udlb;
297  union {
298  volatile uint8_t uier; /* 0x0_4501 ULCR[DLAB] = 0 UART1 interrupt enable register R/W 0x00 18.3.1.4/18-8 */
299  volatile uint8_t udmb; /* 0x0_4501 ULCR[DLAB] = 1 UART1 divisor most significant byte register R/W 0x00 18.3.1.3/18-7 */
300  } uier_udmb;
301  union {
302  volatile uint8_t uiir; /* 0x0_4502 ULCR[DLAB] = 0 UART1 interrupt ID register R 0x01 18.3.1.5/18-9 */
303  volatile uint8_t ufcr; /* 0x0_4502 ULCR[DLAB] = 0 UART1 FIFO control register W 0x00 18.3.1.6/18-10 */
304  volatile uint8_t uafr; /* 0x0_4502 ULCR[DLAB] = 1 UART1 alternate function register R/W 0x00 18.3.1.12/18-16 */
305  } uiir_ufcr_uafr;
306  volatile uint8_t ulcr; /* 0x0_4503 ULCR[DLAB] = x UART1 line control register R/W 0x00 18.3.1.7/18-11 */
307  volatile uint8_t umcr; /* 0x0_4504 ULCR[DLAB] = x UART1 MODEM control register R/W 0x00 18.3.1.8/18-13 */
308  volatile uint8_t ulsr; /* 0x0_4505 ULCR[DLAB] = x UART1 line status register R 0x60 18.3.1.9/18-14 */
309  volatile uint8_t umsr; /* 0x0_4506 ULCR[DLAB] = x UART1 MODEM status register R 0x00 18.3.1.10/18-15 */
310  volatile uint8_t uscr; /* 0x0_4507 ULCR[DLAB] = x UART1 scratch register R/W 0x00 18.3.1.11/18-16 */
311  uint8_t reserved0_4508[0x04510-0x04508];/* 0x0_4508-450F Reserved */
312  volatile uint8_t udsr; /* 0x0_4510 ULCR[DLAB] = x UART1 DMA status register R 0x01 18.3.1.13/18-17 */
313  uint8_t reserved0_4511[0x04600-0x04511];/* 0x0_4511-45FF Reserved */
315
316  /* Local Bus Controller (LBC) Registers */
317 typedef struct m83xxLBCRegisters_ {
318  struct {
319  volatile uint32_t br; /* 0x0_5000 Base register 0 ,R/W 0x0000_RR01 10.3.1.1/10-11 */
320  volatile uint32_t optionsr; /* 0x0_5004 Options register 0 R/W 0x0000_0FF7 10.3.1.2/10-12 */
321  } bor[8];
322  uint8_t reserved0_5040[0x05068-0x05040];/* 0x0_5040-5067 Reserved */
323  volatile uint32_t mar; /* 0x0_5068 UPM address register R/W 0x0000_0000 10.3.1.3/10-18 */
324  uint8_t reserved0_506C[0x05070-0x0506C];/* 0x0_506C-506F Reserved */
325  volatile uint32_t mamr; /* 0x0_5070 UPMA mode register R/W 0x0000_0000 10.3.1.4/10-19 */
326  volatile uint32_t mbmr; /* 0x0_5074 UPMB mode register R/W 0x0000_0000 10.3.1.4/10-19 */
327  volatile uint32_t mcmr; /* 0x0_5078 UPMC mode register R/W 0x0000_0000 10.3.1.4/10-19 */
328  uint8_t reserved0_507C[0x05084-0x0507C];/* 0x0_507C-5083 Reserved */
329  volatile uint32_t mrtpr; /* 0x0_5084 Memory refresh timer prescaler register R/W 0x0000_0000 10.3.1.5/10-21 */
330  volatile uint32_t mdr; /* 0x0_5088 UPM data register R/W 0x0000_0000 10.3.1.6/10-22 */
331  uint8_t reserved0_508C[0x05094-0x0508C];/* 0x0_508C-5093 Reserved */
332  volatile uint32_t lsdmr; /* 0x0_5094 SDRAM mode register R/W 0x0000_0000 10.3.1.7/10-22 */
333  uint8_t reserved0_5098[0x050A0-0x05098];/* 0x0_5098-509F Reserved */
334  volatile uint32_t lurt; /* 0x0_50A0 UPM refresh timer R/W 0x0000_0000 10.3.1.8/10-24 */
335  volatile uint32_t lsrt; /* 0x0_50A4 SDRAM refresh timer R/W 0x0000_0000 10.3.1.9/10-25 */
336  uint8_t reserved0_50A8[0x050B0-0x050A8];/* 0x0_50A8-50AF Reserved */
337  volatile uint32_t ltesr; /* 0x0_50B0 Transfer error status register Read/ bit-reset 0x0000_0000 10.3.1.10/10-26 */
338  volatile uint32_t ltedr; /* 0x0_50B4 Transfer error check disable register R/W 0x0000_0000 10.3.1.11/10-27 */
339  volatile uint32_t lteir; /* 0x0_50B8 Transfer error interrupt enable register R/W 0x0000_0000 10.3.1.12/10-27 */
340  volatile uint32_t lteatr; /* 0x0_50BC Transfer error attributes register R/W 0x0000_0000 10.3.1.13/10-28 */
341  volatile uint32_t ltear; /* 0x0_50C0 Transfer error address register R/W 0x0000_0000 10.3.1.14/10-29 */
342  uint8_t reserved0_50C4[0x050D0-0x050C4];/* 0x0_50C4-50CF Reserved */
343  volatile uint32_t lbcr; /* 0x0_50D0 Local bus configuration register R/W 0x0000_0000 10.3.1.15/10-29 */
344  volatile uint32_t lcrr; /* 0x0_50D4 Clock ratio register R/W 0x8000_0008 10.3.1.16/10-30 */
345  uint8_t reserved0_50D8[0x05100-0x050D8];/* 0x0_50D8-50FF Reserved */
347
348  /* Serial Peripheral Interface (SPI) */
349 typedef struct m83xxSPIRegisters_ {
350  uint8_t reserved0_7000[0x07020-0x07000];/* 0x0_7000-7020 Reserved, should be cleared */
351  volatile uint32_t spmode; /* 0x0_7020 SPI mode register R/W 0x0000_0000 19.4.1.1/19-9 */
352  volatile uint32_t spie; /* 0x0_7024 SPI event register R/W 0x0000_0000 19.4.1.2/19-11 */
353  volatile uint32_t spim; /* 0x0_7028 SPI mask register R/W 0x0000_0000 19.4.1.3/19-13 */
354  volatile uint32_t spcom; /* 0x0_702C SPI command register R/W 0x0000_0000 19.4.1.4/19-14 */
355  volatile uint32_t spitd; /* 0x0_7030 SPI transmit register R/W 0x0000_0000 19.4.1.5/19-14 */
356  volatile uint32_t spird; /* 0x0_7034 SPI receive register R 0xFFFF_FFFF 19.4.1.6/19-15 */
357  uint8_t reserved0_7038[0x07100-0x07038];/* 0x0_7038-70FF Reserved */
359  /* SPIMODE register fields */
360 #define MPC83XX_SPIMODE_LOOP (1 << (31- 1)) /* loopback */
361 #define MPC83XX_SPIMODE_CI (1 << (31- 2)) /* clock invert */
362 #define MPC83XX_SPIMODE_CP (1 << (31- 3)) /* clock phase */
363 #define MPC83XX_SPIMODE_DIV16 (1 << (31- 4)) /* divide by 16 */
364 #define MPC83XX_SPIMODE_REV (1 << (31- 5)) /* LSB first */
365 #define MPC83XX_SPIMODE_M_S (1 << (31- 6)) /* master/slave */
366 #define MPC83XX_SPIMODE_EN (1 << (31- 7)) /* enable */
367 #define MPC83XX_SPIMODE_LEN(n) ((n) << (31-11)) /* length code */
368 #define MPC83XX_SPIMODE_PM(n) ((n) << (31-15)) /* prescaler */
369 #define MPC83XX_SPIMODE_OD (1 << (31-19)) /* open drain */
370
371  /* SPCOM register fields */
372 #define MPC83XX_SPCOM_LST (1 << (31- 9)) /* last transfer */
373
374  /* SPIE/M register fields */
375 #define MPC83XX_SPIE_LT (1 << (31-17)) /* last character transmitted */
376 #define MPC83XX_SPIE_DNR (1 << (31-18)) /* data not ready */
377 #define MPC83XX_SPIE_OV (1 << (31-19)) /* overrun */
378 #define MPC83XX_SPIE_UN (1 << (31-20)) /* unterrun */
379 #define MPC83XX_SPIE_MME (1 << (31-21)) /* multi-master error */
380 #define MPC83XX_SPIE_NE (1 << (31-22)) /* not empty */
381 #define MPC83XX_SPIE_NF (1 << (31-23)) /* not full */
382
383 typedef struct m83xxDMARegisters_ {
384  /* DMA Registers */
385  uint8_t reserved0_8000[0x08030-0x08000];/* 0x0_8000-0x0_802f Reserved */
386  volatile uint32_t omisr; /* 0x0_8030 Outbound message interrupt status register Special 0x0000_0000 12.4.1/12-4 */
387  volatile uint32_t omimr; /* 0x0_8034 Outbound message interrupt mask register R/W 0x0000_0000 12.4.2/12-6 */
388  uint8_t reserved0_8038[0x08050-0x08038];/* 0x0_8038-0x0_804f Reserved */
389  volatile uint32_t imr0; /* 0x0_8050 Inbound message register 0 R/W 0x0000_0000 12.4.3/12-7 */
390  volatile uint32_t imr1; /* 0x0_8054 Inbound message register 1 R/W 0x0000_0000 12.4.3/12-7 */
391  volatile uint32_t omr0; /* 0x0_8058 Outbound message register 0 R/W 0x0000_0000 12.4.4/12-7 */
392  volatile uint32_t omr1; /* 0x0_805C Outbound message register 1 R/W 0x0000_0000 12.4.4/12-7 */
393  volatile uint32_t odr; /* 0x0_8060 Outbound doorbell register R/W 0x0000_0000 12.4.5/12-8 */
394  uint8_t reserved0_8064[0x08068-0x08064];/* 0x0_8064-0x0_8067 Reserved */
395  volatile uint32_t idr; /* 0x0_8068 Inbound doorbell register R/W 0x0000_0000 12.4.5/12-8 */
396  uint8_t reserved0_806C[0x08080-0x0806C];/* 0x0_806C-0x0_807F Reserved */
397  volatile uint32_t imisr; /* 0x0_8080 Inbound message interrupt status register R/W 0x0000_0000 12.4.6/12-9 */
398  volatile uint32_t imimr; /* 0x0_8084 Inbound message interrupt mask register R/W 0x0000_0000 12.4.7/12-11 */
399  uint8_t reserved0_8088[0x080A8-0x08088];/* 0x0_8088-0x0_80A7 Reserved */
401  uint8_t reserved0_80A8[0x08100-0x080A8];/* 0x0_80A8-0x0_80FF Reserved */
402  volatile uint32_t dmamr0; /* 0x0_8100 DMA 0 mode register R/W 0x0000_0000 12.4.8.1/12-12 */
403  volatile uint32_t dmasr0; /* 0x0_8104 DMA 0 status register R/W 0x0000_0000 12.4.8.2/12-14 */
404  volatile uint32_t dmacdar0; /* 0x0_8108 DMA 0 current descriptor address register R/W 0x0000_0000 12.4.8.3/12-15 */
405  uint8_t reserved0_810C[0x08110-0x0810C];/* 0x0_810C-0x0_810F Reserved */
406  volatile uint32_t dmasar0; /* 0x0_8110 DMA 0 source address register R/W 0x0000_0000 12.4.8.4/12-16 */
407  uint8_t reserved0_8114[0x08118-0x08114];/* 0x0_8114-0x0_8117 Reserved */
408  volatile uint32_t dmadar0; /* 0x0_8118 DMA 0 destination address register R/W 0x0000_0000 12.4.8.5/12-16 */
409  uint8_t reserved0_811C[0x08120-0x0811C];/* 0x0_8120-0x0_811C Reserved */
410  volatile uint32_t dmabcr0; /* 0x0_8120 DMA 0 byte count register R/W 0x0000_0000 12.4.8.6/12-17 */
411  volatile uint32_t dmandar0; /* 0x0_8124 DMA 0 next descriptor address register R/W 0x0000_0000 12.4.8.7/12-17 */
412  }chan[4];
413  volatile uint32_t dmagsr; /* 0x0_82A8 DMA general status register R 0x0000_0000 12.4.8.8/12-18 */
414  uint8_t reserved0_82AC[0x082FF-0x082AC]; /* 0x0_82AC-0x0_82FF Reserved, should be cleared */
416
417 /* Registers in DMA section use little-endian byte order */
418
419 /* DMA mode register */
420 #define MPC83XX_DMAMR_DRCNT_1 (5 << 24)
421 #define MPC83XX_DMAMR_DRCNT_2 (6 << 24)
422 #define MPC83XX_DMAMR_DRCNT_4 (7 << 24)
423 #define MPC83XX_DMAMR_DRCNT_8 (8 << 24)
424 #define MPC83XX_DMAMR_DRCNT_16 (9 << 24)
425 #define MPC83XX_DMAMR_DRCNT_32 (0xA << 24)
426
427 #define MPC83XX_DMAMR_BWC_1 (0 << 21)
428 #define MPC83XX_DMAMR_BWC_2 (1 << 21)
429 #define MPC83XX_DMAMR_BWC_4 (2 << 21)
430 #define MPC83XX_DMAMR_BWC_8 (3 << 21)
431 #define MPC83XX_DMAMR_BWC_16 (4 << 21)
432
433 #define MPC83XX_DMAMR_DMSEN (1 << 20)
434 #define MPC83XX_DMAMR_IRQS (1 << 19)
435 #define MPC83XX_DMAMR_EMSEN (1 << 18)
436
437 #define MPC83XX_DMAMR_DAHTS_1 (0 << 16)
438 #define MPC83XX_DMAMR_DAHTS_2 (1 << 16)
439 #define MPC83XX_DMAMR_DAHTS_4 (2 << 16)
440 #define MPC83XX_DMAMR_DAHTS_8 (3 << 16)
441
442 #define MPC83XX_DMAMR_SAHTS_1 (0 << 14)
443 #define MPC83XX_DMAMR_SAHTS_2 (1 << 14)
444 #define MPC83XX_DMAMR_SAHTS_4 (2 << 14)
445 #define MPC83XX_DMAMR_SAHTS_8 (3 << 14)
446
447 #define MPC83XX_DMAMR_DAHE (1 << 13)
448 #define MPC83XX_DMAMR_SAHE (1 << 12)
449
450 #define MPC83XX_DMAMR_PRC_PCI_READ (0 << 10)
451 #define MPC83XX_DMAMR_PRC_PCI_READ_LINE (1 << 10)
452 #define MPC83XX_DMAMR_PRC_PCI_READ_MULTIPLE (2 << 10)
453
454 #define MPC83XX_DMAMR_EOIIE (1 << 7)
455 #define MPC83XX_DMAMR_TEM (1 << 3)
456 #define MPC83XX_DMAMR_CTM (1 << 2)
457 #define MPC83XX_DMAMR_CC (1 << 1)
458 #define MPC83XX_DMAMR_CS (1 << 0)
459
460 /* DMA status register */
461 #define MPC83XX_DMASR_TE (1 << 7)
462 #define MPC83XX_DMASR_CB (1 << 2)
463 #define MPC83XX_DMASR_EOSI (1 << 1)
464 #define MPC83XX_DMASR_EOCDI (1 << 0)
465
466 /* DMA current descriptor address register */
467 #define MPC83XX_DMACDAR_SNEN (1 << 4)
468 #define MPC83XX_DMACDAR_EOSIE (1 << 3)
469
470 /* DMA next descriptor address register */
471 #define MPC83XX_DMANDAR_NSNEN (1 << 4)
472 #define MPC83XX_DMANDAR_NEOSIE (1 << 3)
473 #define MPC83XX_DMANDAR_EOTD (1 << 0)
474
475
476 typedef struct m83xxPCICfgRegisters_ {
477  /* PCI1 Software Configuration Registers */
478  volatile uint32_t config_address; /* 0x0_8300 PCI1 CONFIG_ADDRESS W 13.3.1.1/13-16 */
479  volatile uint32_t config_data; /* 0x0_8304 PCI1 CONFIG_DATA R/W 13.3.1.2/13-18 */
480  volatile uint32_t int_ack; /* 0x0_8308 PCI1 INT_ACK R 13.3.1.3/13-18 */
481  uint8_t reserved0_830C[0x08380-0x0830C]; /* 0x0_830C-0x0_837F Reserved */
483
484 typedef struct m83xxPCIIosRegisters_ {
485  /* Sequencer (IOS) */
486  volatile uint32_t potar0; /* 0x0_8400 PCI outbound translation address register 0 R/W 0x0000_0000 11.4.1/11-3 */
487  uint8_t reserved0_8404[0x08408-0x08404];/* 0x0_8404 Reserved */
488  volatile uint32_t pobar0; /* 0x0_8408 PCI outbound base address register 0 R/W 0x0000_0000 11.4.2/11-3 */
489  uint8_t reserved0_840C[0x08410-0x0840C];/* 0x0_840C Reserved */
490  volatile uint32_t pocmr0; /* 0x0_8410 PCI outbound comparison mask register 0 R/W 0x0000_0000 11.4.3/11-4 */
491  uint8_t reserved0_8414[0x08418-0x08414];/* 0x0_8414 Reserved */
492  volatile uint32_t potar1; /* 0x0_8418 PCI outbound translation address register 1 R/W 0x0000_0000 11.4.1/11-3 */
493  uint8_t reserved0_841C[0x08420-0x0841C];/* 0x0_841C Reserved */
494  volatile uint32_t pobar1; /* 0x0_8420 PCI outbound base address register 1 R/W 0x0000_0000 11.4.2/11-3 */
495  uint8_t reserved0_8424[0x08428-0x08424];/* 0x0_8424 Reserved */
496  volatile uint32_t pocmr1; /* 0x0_8428 PCI outbound comparison mask register 1 R/W 0x0000_0000 11.4.3/11-4 */
497  uint8_t reserved0_842C[0x08430-0x0842C];/* 0x0_842C Reserved */
498  volatile uint32_t potar2; /* 0x0_8430 PCI outbound translation address register 2 R/W 0x0000_0000 11.4.1/11-3 */
499  uint8_t reserved0_8434[0x08438-0x08434];/* 0x0_8434 Reserved */
500  volatile uint32_t pobar2; /* 0x0_8438 PCI outbound base address register 2 R/W 0x0000_0000 11.4.2/11-3 */
501  uint8_t reserved0_843C[0x08440-0x0843C];/* 0x0_843C Reserved */
502  volatile uint32_t pocmr2; /* 0x0_8440 PCI outbound comparison mask register 2 R/W 0x0000_0000 11.4.3/11-4 */
503  uint8_t reserved0_8444[0x08448-0x08444];/* 0x0_8444 Reserved */
504  volatile uint32_t potar3; /* 0x0_8448 PCI outbound translation address register 3 R/W 0x0000_0000 11.4.1/11-3 */
505  uint8_t reserved0_844C[0x08450-0x0844C];/* 0x0_844C Reserved */
506  volatile uint32_t pobar3; /* 0x0_8450 PCI outbound base address register 3 R/W 0x0000_0000 11.4.2/11-3 */
507  uint8_t reserved0_8454[0x08458-0x08454];/* 0x0_8454 Reserved */
508  volatile uint32_t pocmr3; /* 0x0_8458 PCI outbound comparison mask register 3 R/W 0x0000_0000 11.4.3/11-4 */
509  uint8_t reserved0_845C[0x08460-0x0845C];/* 0x0_845C Reserved */
510  volatile uint32_t potar4; /* 0x0_8460 PCI outbound translation address register 4 R/W 0x0000_0000 11.4.1/11-3 */
511  uint8_t reserved0_8464[0x08468-0x08464];/* 0x0_8464 Reserved */
512  volatile uint32_t pobar4; /* 0x0_8468 PCI outbound base address register 4 R/W 0x0000_0000 11.4.2/11-3 */
513  uint8_t reserved0_846C[0x08470-0x0846C];/* 0x0_846C Reserved */
514  volatile uint32_t pocmr4; /* 0x0_8470 PCI outbound comparison mask register 4 R/W 0x0000_0000 11.4.3/11-4 */
515  uint8_t reserved0_8474[0x08478-0x08474];/* 0x0_8474 Reserved */
516  volatile uint32_t potar5; /* 0x0_8478 PCI outbound translation address register 5 R/W 0x0000_0000 11.4.1/11-3 */
517  uint8_t reserved0_847C[0x08480-0x0847C];/* 0x0_847C Reserved */
518  volatile uint32_t pobar5; /* 0x0_8480 PCI outbound base address register 5 R/W 0x0000_0000 11.4.2/11-3 */
519  uint8_t reserved0_8484[0x08488-0x08484];/* 0x0_8484 Reserved */
520  volatile uint32_t pocmr5; /* 0x0_8488 PCI outbound comparison mask register 5 R/W 0x0000_0000 11.4.3/11-4 */
521  uint8_t reserved0_848C[0x084F0-0x0848C];/* 0x0_848C Reserved */
522  volatile uint32_t pmcr; /* 0x0_84F0 Power management control register R/W 0x0000_0000 11.4.4/11-5 */
523  uint8_t reserved0_84F4[0x084F8-0x084F4];/* 0x0_84F4 Reserved */
524  volatile uint32_t dtcr; /* 0x0_84F8 Discard timer control register R/W 0x0000_0000 11.4.5/11-6 */
525  uint8_t reserved0_84FC[0x08500-0x084FC];/* 0x0_84FC Reserved */
527
528 typedef struct m83xxPCICtrlRegisters_ {
529  /* PCI1 Error Management Registers */
530  volatile uint32_t pci_esr; /* 0x0_8500 PCI error status register R / w1c 0x0000_0000 13.3.2.1/13-18 */
531  volatile uint32_t pci_ecdr; /* 0x0_8504 PCI error capture disable register R/W 0x0000_0000 13.3.2.2/13-19 */
532  volatile uint32_t pci_eer; /* 0x0_8508 PCI error enable register R/W 0x0000_0000 13.3.2.3/13-20 */
533  volatile uint32_t pci_eatcr; /* 0x0_850C PCI error attributes capture register R/W 0x0000_0000 13.3.2.4/13-21 */
534  volatile uint32_t pci_eacr; /* 0x0_8510 PCI error address capture register R 0x0000_0000 13.3.2.5/13-23 */
535  volatile uint32_t pci_eeacr; /* 0x0_8514 PCI error extended address capture register R 0x0000_0000 13.3.2.6/13-23 */
536  volatile uint32_t pci_edlcr; /* 0x0_8518 PCI error data low capture register R 0x0000_0000 13.3.2.7/13-24 */
537  volatile uint32_t pci_edhcr; /* 0x0_851C PCI error data high capture register R 0x0000_0000 13.3.2.8/13-24 */
538  /* PCI1 Control and Status Registers */
539  volatile uint32_t pci_gcr; /* 0x0_8520 PCI general control register R/W 0x0000_0000 13.3.2.9/13-24 */
540  volatile uint32_t pci_ecr; /* 0x0_8524 PCI error control register R/W 0x0000_0000 13.3.2.10/13-25 */
541  volatile uint32_t pci_gsr; /* 0x0_8528 PCI general status register R 0x0000_0000 13.3.2.11/13-26 */
542  uint8_t reserved0_852C[0x08538-0x0852C];/* 0x0_852C Reserved */
543  /* PCI1 Inbound ATU Registers */
544  volatile uint32_t pitar2; /* 0x0_8538 PCI inbound translation address register 2 R/W 0x0000_0000 13.3.2.12/13-26 */
545  uint8_t reserved0_853C[0x08540-0x0853C];/* 0x0_853C Reserved, should be cleared $ $ */
546  volatile uint32_t pibar2; /* 0x0_8540 PCI inbound base address register 2 R/W 0x0000_0000 13.3.2.13/13-27 */
547  volatile uint32_t piebar2; /* 0x0_8544 PCI inbound extended base address register 2 R/W 0x0000_0000 13.3.2.14/13-27 */
548  volatile uint32_t piwar2; /* 0x0_8548 PCI inbound window attributes register 2 R/W 0x0000_0000 13.3.2.15/13-28 */
549  uint8_t reserved0_854C[0x08550-0x0854C];/* 0x0_854C Reserved */
550  volatile uint32_t pitar1; /* 0x0_8550 PCI inbound translation address register 1 R/W 0x0000_0000 13.3.2.12/13-26 */
551  uint8_t reserved0_8550[0x08558-0x08554];/* 0x0_8554 Reserved, should be cleared $ $ */
552  volatile uint32_t pibar1; /* 0x0_8558 PCI inbound base address register 1 R/W 0x0000_0000 13.3.2.13/13-27 */
553  volatile uint32_t piebar1; /* 0x0_855C PCI inbound extended base address register 1 R/W 0x0000_0000 13.3.2.14/13-27 */
554  volatile uint32_t piwar1; /* 0x0_8560 PCI inbound window attributes register 1 R/W 0x0000_0000 13.3.2.15/13-28 */
555  uint8_t reserved0_8564[0x08568-0x08564];/* 0x0_8564 Reserved */
556  volatile uint32_t pitar0; /* 0x0_8568 PCI inbound translation address register 0 R/W 0x0000_0000 13.3.2.12/13-26 */
557  uint8_t reserved0_856c[0x08570-0x0856c];/* 0x0_856C Reserved, should be cleared $ $ */
558  volatile uint32_t pibar0; /* 0x0_8570 PCI inbound base address register 0 R/W 0x0000_0000 13.3.2.13/13-27 */
559  uint8_t reserved0_8574[0x08578-0x08574];/* 0x0_8574 Reserved */
560  volatile uint32_t piwar0; /* 0x0_8578 PCI inbound window attributes register 0 R/W 0x0000_0000 13.3.2.14/13-27 */
561  uint8_t reserved0_857c[0x08580-0x0857c];/* 0x0_857C Reserved, should be cleared $ $ */
562  uint8_t reserved0_8580[0x08600-0x08580];/* 0x0_8580 Reserved */
564
565 typedef struct m83xxUSB_MPHRegisters_ {
566  /* USB MPH Controller Registers */
567  uint8_t reserved0x2_2000[0x22100-0x22000]; /* 0x2_2000--0x2_20FF Reserved, should be cleared */
568  volatile uint16_t caplength; /* 0x2_2100 Capability register length R 0x40 16.3.1.1/16-19 */
569  volatile uint16_t hciversion; /* 0x2_2102 Host interface version number R 0x0100 16.3.1.2/16-19 */
570  volatile uint32_t hcsparams; /* 0x2_2104 Host crtl. structural parameters R 0x0121_0012 16.3.1.3/16-20 */
571  volatile uint32_t hccparams; /* 0x2_2108 Host crtl. capability parameters R 0x0000_0006 16.3.1.4/16-21 */
572  uint8_t reserved0x2_210C[0x22140-0x2210C]; /* Reserved */
573  volatile uint32_t usbcmd; /* 0x2_2140 USB command R/W 0x0008_nBn0 16.3.2.1/16-23 */
574  volatile uint32_t usbsts; /* 0x2_2144 USB status R/W 0x0000_0000 16.3.2.2/16-26 */
575  volatile uint32_t usbintr; /* 0x2_2148 USB interrupt enable R/W 0x0000_0000 16.3.2.3/16-28 */
576  volatile uint32_t frindex; /* 0x2_214C USB frame index R/W 0x0000_nnnn 16.3.2.4/16-30 */
577  uint8_t reserved0x2_2150[0x22154-0x22150]; /* Reserved */
578  volatile uint32_t periodiclistbase; /* 0x2_2154 Frame list base address R/W 0xnnnn_0000 16.3.2.6/16-31 */
579  volatile uint32_t asynclistaddr; /* 0x2_2158 Next asynchronous list addr R/W 0x0000_0000 16.3.2.8/16-32 */
580  volatile uint32_t asyncttsts; /* 0x2_215C Asynchronous buffer status for embedded TT TBD 0x0000_0000 16.3.2.10/16-34 */
581  volatile uint32_t burstsize; /* 0x2_2160 Programmable burst size R/W 0x000_1010 16.3.2.11/16-34 */
582  volatile uint32_t txfilltuning; /* 0x2_2164 Host TT transmit pre-buffer packet tuning R/W 0x0002_0000 16.3.2.12/16-35 */
583  volatile uint32_t txttfilltuning; /* 0x2_2168 Host TT transmit pre-buffer packet tuning R/W 0x0000_0000 16.3.2.13/16-37 */
584  uint8_t reserved0x2_216c[0x22170-0x2216c]; /* Reserved */
585  volatile uint32_t viewport; /* 0x2_2170 ULPI ULPI Register Access R/W 0x0000_0000 16.3.2.14/16-37 */
586  uint8_t reserved0x2_2174[0x22180-0x22174]; /* Reserved */
587  volatile uint32_t configflag; /* 0x2_2180 Configured flag register R 0x0000_0001 16.3.2.15/16-39 */
588  volatile uint32_t portsc1; /* 0x2_2184 Port status/control 1 R/W 0x8C00_0001 16.3.2.16/16-39 */
589  volatile uint32_t portsc2; /* 0x2_2188 Port status/control 2 R/W 0x8C00_0001 16.3.2.16/16-39 */
590  uint8_t reserved0x2_218c[0x221A8-0x2218c]; /* Reserved */
591  volatile uint32_t usbmode; /* 0x2_21A8 USB device mode R/W 0x0000_0003 16.3.2.18/16-47 */
592  uint8_t reserved0x2_21AC[0x22400-0x221AC]; /* Reserved */
593  volatile uint32_t snoop1; /* 0x2_2400 Snoop 1 R/W 0x0000_0000 16.3.2.26/16-53 */
594  volatile uint32_t snoop2; /* 0x2_2404 Snoop 2 R/W 0x0000_0000 16.3.2.26/16-53 */
595  volatile uint32_t age_cnt_thresh; /* 0x2_2408 Age count threshold R/W 0x0000_0000 16.3.2.27/16-54 */
596  volatile uint32_t si_ctrl; /* 0x2_240C System interface control R/W 0x0000_0000 16.3.2.28/16-56 */
597  volatile uint32_t pri_ctrl; /* 0x2_2410 Priority control R/W 0x0000_0000 16.3.2.29/16-56 */
598  uint8_t reserved0x2_2414[0x22500-0x22414]; /* Reserved */
599  volatile uint32_t control; /* 0x2_2500 Control R/W 0x0000_0000 16.3.2.30/16-57 */
600  uint8_t reserved0x2_2504[0x23000-0x22504]; /* 0x2_2504--0x2_2FFF Reserved, should be cleared */
602
603 typedef struct m83xxUSB_DRRegisters_ {
604  /* USB DR Controller Registers */
605  uint8_t reserved0x2_3000[0x23100-0x23000]; /* 0x2_3000--0x2_30FF Reserved, should be cleared */
606  volatile uint16_t caplength; /* 0x2_3100 Capability register length R 0x40 16.3.1.1/16-19 */
607  volatile uint16_t hciversion; /* 0x2_3102 Host interface version number R 0x0100 16.3.1.2/16-19 */
608  volatile uint32_t hcsparams; /* 0x2_3104 Host crtl. structural parameters R 0x0111_0011 16.3.1.3/16-20 */
609  volatile uint32_t hccparams; /* 0x2_3108 Host crtl. capability parameters R 0x0000_0006 16.3.1.4/16-21 */
610  uint8_t reserved0x2_310c[0x23120-0x2310C]; /* 0x2_310c--0x2_311f Reserved */
611  volatile uint32_t dciversion; /* 0x2_3120 Device interface version number R 0x0001 16.3.1.5/16-22 */
612  volatile uint32_t dccparams; /* 0x2_3124 Device controller parameters R 0x0000_0186 16.3.1.6/16-22 */
613  uint8_t reserved0x2_3128[0x23140-0x23128]; /* 0x2_3128--0x2_313f Reserved */
614  volatile uint32_t usbcmd; /* 0x2_3140 USB command R/W 0x0008_nBn0 16.3.2.1/16-23 */
615  volatile uint32_t usbsts; /* 0x2_3144 USB status R/W 0x0000_0000 16.3.2.2/16-26 */
616  volatile uint32_t usbintr; /* 0x2_3148 USB interrupt enable R/W 0x0000_0000 16.3.2.3/16-28 */
617  volatile uint32_t frindex; /* 0x2_314C USB frame index R/W 0x0000_nnnn 16.3.2.4/16-30 */
618  uint8_t reserved0x2_3150[0x23154-0x23150]; /* 0x2_3150--0x2_3153 Reserved */
619  union {
620  volatile uint32_t periodiclistbase; /* 0x2_3154 Frame list base address R/W 0xnnnn_0000 16.3.2.6/16-31 */
621  volatile uint32_t deviceaddr; /* 0x2_3154 USB device address R/W 0x0000_0000 16.3.2.7/16-32 */
622  } perbase_devaddr;
623  union {
624  volatile uint32_t asynclistaddr; /* 0x2_3158 Next asynchronous list addr (host mode) R/W 0x0000_0000 16.3.2.8/16-32 */
625  volatile uint32_t addr; /* 0x2_3158 ENDPOINT Address at endpoint list (device mode) R/W 0x0000_0000 16.3.2.9/16-33 */
626  } async_addr;
627  uint8_t reserved0x2_315c[0x23160-0x2315c]; /* 0x2_315c--0x2_315f Reserved */
628  volatile uint32_t burstsize; /* 0x2_3160 Programmable burst size R/W 0x0000_1010 16.3.2.11/16-34 */
629  volatile uint32_t txfilltuning; /* 0x2_3164 Host TT transmit pre-buffer packet tuning R/W 0x0002_0000 16.3.2.12/16-35 */
630  uint8_t reserved0x2_3168[0x23170-0x23168]; /* 0x2_3168--0x2_316f Reserved */
631  volatile uint32_t viewport; /* 0x2_3170 ULPI ULPI Register Access R/W 0x0000_0000 16.3.2.14/16-37 */
632  uint8_t reserved0x2_3174[0x23180-0x23174]; /* 0x2_3174--0x2_317F Reserved */
633  volatile uint32_t configflag; /* 0x2_3180 Configured flag register R 0x0000_0001 16.3.2.15/16-39 */
634  volatile uint32_t portsc1; /* 0x2_3184 Port status/control R/W 0x9C00_0000 16.3.2.16/16-39 */
635  uint8_t reserved0x2_3188[0x231A4-0x23188]; /* 0x2_3188--0x2_31A3 Reserved */
636  volatile uint32_t otgsc; /* 0x2_31A4 On-the-Go status and control R/W 0x0000_0001 16.3.2.17/16-44 */
637  volatile uint32_t usbmode; /* 0x2_31A8 USB device mode R/W 0x0000_0000 16.3.2.18/16-47 */
638  volatile uint32_t endptsetupstat; /* 0x2_31AC Endpoint setup status R/W 0x0000_0000 16.3.2.19/16-48 */
639  volatile uint32_t endpointprime; /* 0x2_31B0 Endpoint initialization R/W 0x0000_0000 16.3.2.20/16-48 */
640  volatile uint32_t endptflush; /* 0x2_31B4 Endpoint de-initialize R/W 0x0000_0000 16.3.2.21/16-49 */
641  volatile uint32_t endptstatus; /* 0x2_31B8 Endpoint status R 0x0000_0000 16.3.2.22/16-50 */
642  volatile uint32_t endptcomplete; /* 0x2_31BC Endpoint complete R/W 0x0000_0000 16.3.2.23/16-50 */
643  volatile uint32_t endptctrl[6]; /* 0x2_31C0 Endpoint control 0 R/W 0x0080_0080 16.3.2.24/16-51 */
644  uint8_t reserved0x2_31D8[0x23400-0x231D8]; /* 0x2_31D8--0x2_33ff Reserved */
645  volatile uint32_t snoop1; /* 0x2_3400 Snoop 1 R/W 0x0000_0000 16.3.2.26/16-53 */
646  volatile uint32_t snoop2; /* 0x2_3404 Snoop 2 R/W 0x0000_0000 16.3.2.26/16-53 */
647  volatile uint32_t age_cnt_thresh; /* 0x2_3408 Age count threshold R/W 0x0000_0000 16.3.2.27/16-54 */
648  volatile uint32_t pri_ctrl; /* 0x2_340C Priority control R/W 0x0000_0000 16.3.2.29/16-56 */
649  volatile uint32_t si_ctrl; /* 0x2_3410 System interface control R/W 0x0000_0000 16.3.2.28/16-56 */
650  uint8_t reserved0x2_3414[0x23500-0x23414]; /* 0x2_3414--0x2_34ff Reserved */
651  volatile uint32_t control; /* 0x2_3500 Control R/W 0x0000_0000 16.3.2.30/16-57 */
652  uint8_t reserved0x2_3504[0x24000-0x23504]; /* 0x2_3504--0x2_3FFF Reserved, should be cleared */
654
655 #if 0 /* FIXME: to be formatted soon */
656  /* Security Engine Address Map Registers */
657  /* Controller Registers */
658  volatile uint32_t reserved;## /* 0x3_0000--0x3_0FFF Reserved, should be cleared */
659  volatile uint32_t imr; /* 0x3_1008 Interrupt mask register R/W 0x0000_0000_0000_0000 14.7.2.1/14-94 */
660  volatile uint32_t isr; /* 0x3_1010 Interrupt status register R 0x0000_0000_0000_0000 14.7.2.2/14-96 */
661  volatile uint32_t icr; /* 0x3_1018 Interrupt clear register W 0x0000_0000_0000_0000 14.7.2.3/14-96 */
662  volatile uint32_t id; /* 0x3_1020 Identification register R 0x0000_0000_0000_00400x 14.7.2.4/14-98 */
663  volatile uint32_t euasr; /* 0x3_1028 EU assignment status register R 0xF0F0_F0F0_00FF_F0F0 14.7.2/14-93 */
664  volatile uint32_t mcr; /* 0x3_1030 Master control register R/W 0000_0000_0000_0000 14.7.2.5/14-98 */
665  /* Channel 1 */
666  volatile uint32_t cccr1; /* 0x3_1108 Crypto-channel 1 configuration register R/W 0x0000_0000_0000_0000 14.6.1.1/14-82 */
667  volatile uint32_t ccpsr1; /* 0x3_1110 Crypto-channel 1 pointer status register R 0x0000_0000_0000_0007 14.6.1.2/14-85 */
668  volatile uint32_t cdpr1; /* 0x3_1140 Crypto-channel 1 current descriptor pointer register R 0x0000_0000_0000_0000 14.6.1.3/14-90 */
669  volatile uint32_t */
670 0x3_1180--0x3_11BF
671  DBn /* volatile; uint32_t ff1, */ /* 0x3_1148 Crypto-channel 1 fetch FIFO address register W 0x0000_0000_0000_0000 14.6.1.4/14-90 Crypto-channel 1 descriptor buffers [0�7] R 0x0000_0000_0000_0000 14.6.1.5/14-91 */
672  /* Channel 2-4: FIXME: same layout as channel 1*/
673  /* Data Encryption Standard Execution Unit (DEU) */
674  volatile uint32_t deumr; /* 0x3_2000 DEU mode register R/W 0x0000_0000_0000_0000 14.5.2.1/14-35 */
675  volatile uint32_t deuksr; /* 0x3_2008 DEU key size register R/W 0x0000_0000_0000_0000 14.5.2.2/14-36 */
676  volatile uint32_t deudsr; /* 0x3_2010 DEU data size register R/W 0x0000_0000_0000_0000 14.5.2.3/14-36 */
677  volatile uint32_t deurcr; /* 0x3_2018 DEU reset control register R/W 0x0000_0000_0000_0000 14.5.2.4/14-37 */
678  volatile uint32_t deusr; /* 0x3_2028 DEU status register R 0x0000_0000_0000_0000 14.5.2.5/14-37 */
679  volatile uint32_t deuisr; /* 0x3_2030 DEU interrupt status register R 0x0000_0000_0000_0000 14.5.2.6/14-38 */
680  volatile uint32_t deuicr; /* 0x3_2038 DEU interrupt control register R/W 0x0000_0000_0000_3000 14.5.2.7/14-40 */
681  volatile uint32_t deueug; /* 0x3_2050 DEU EU-Go register W 0x0000_0000_0000_0000 14.5.2.8/14-41 */
682  volatile uint32_t deuiv; /* 0x3_2100 DEU initialization vector register R/W 0x0000_0000_0000_0000 14.5.2.9/14-42 */
683  volatile uint32_t deuk1; /* 0x3_2400 DEU key 1 register W $ 14.5.2.10/14-42 */
684  volatile uint32_t deuk2; /* 0x3_2408 DEU key 2 register W $ 14.5.2.10/14-42 */
685  volatile uint32_t deuk3; /* 0x3_2410 DEU key 3 register W $ 14.5.2.10/14-42 */
686 0x3_2800--0x3_2FFF
687 DEU FIFO R/W 0x0000_0000_0000_0000 14.5.2.11/14-42
688  /* Advanced Encryption Standard Execution Unit (AESU) */
689  volatile uint32_t aesumr; /* 0x3_4000 AESU mode register R/W 0x0000_0000_0000_0000 14.5.6.1/14-68 */
690  volatile uint32_t aesuksr; /* 0x3_4008 AESU key size register R/W 0x0000_0000_0000_0000 14.5.6.2/14-71 */
691  volatile uint32_t aesudsr; /* 0x3_4010 AESU data size register R/W 0x0000_0000_0000_0000 14.5.6.3/14-71 */
692  volatile uint32_t aesurcr; /* 0x3_4018 AESU reset control register R/W 0x0000_0000_0000_0000 14.5.6.4/14-72 */
693  volatile uint32_t aesusr; /* 0x3_4028 AESU status register R 0x0000_0000_0000_0000 14.5.6.5/14-73 */
694  volatile uint32_t aesuisr; /* 0x3_4030 AESU interrupt status register R 0x0000_0000_0000_0000 14.5.6.6/14-74 */
695  volatile uint32_t aesuicr; /* 0x3_4038 AESU interrupt control register R/W 0x0000_0000_0000_1000 14.5.6.7/14-75 */
696  volatile uint32_t aesuemr; /* 0x3_4050 AESU end-of-message register W 0x0000_0000_0000_0000 14.5.6.8/14-76 */
697 0x3_4100 AESU context memory registers R/W 0x0000_0000_0000_0000 14.5.6.9/14-77
698 0x3_4400--0x3_4408
699 AESU key memory R/W 0x0000_0000_0000_0000 14.5.6.9.5/14-81
700 0x3_4800--0x3_4FFF
701 AESU FIFO R/W 0x0000_0000_0000_0000 14.5.6.9.6/14-81
702  /* Message Digest Execution Unit (MDEU) */
703  volatile uint32_t mdeumr; /* 0x3_6000 MDEU mode register R/W 0x0000_0000_0000_0000 14.5.4.1/14-51 */
704  volatile uint32_t mdeuksr; /* 0x3_6008 MDEU key size register R/W 0x0000_0000_0000_0000 14.5.4.3/14-55 */
705  volatile uint32_t mdeudsr; /* 0x3_6010 MDEU data size register R/W 0x0000_0000_0000_0000 14.5.4.4/14-56 */
706  volatile uint32_t mdeurcr; /* 0x3_6018 MDEU reset control register R/W 0x0000_0000_0000_0000 14.5.4.5/14-56 */
707  volatile uint32_t mdeusr; /* 0x3_6028 MDEU status register R 0x0000_0000_0000_0000 14.5.4.6/14-57 */
708  volatile uint32_t mdeuisr; /* 0x3_6030 MDEU interrupt status register R 0x0000_0000_0000_0000 14.5.4.7/14-58 */
709  volatile uint32_t mdeuicr; /* 0x3_6038 MDEU interrupt control register R/W 0x0000_0000_0000_1000 14.5.4.8/14-59 */
710  volatile uint32_t mdeueug; /* 0x3_6050 MDEU EU-Go register W 0x0000_0000_0000_0000 14.5.4.10/14-61 */
711 0x3_6100--0x3_6120
712 MDEU context memory registers R/W 0x0000_0000_0000_0000 14.5.4.11/14-61
713 0x3_6400--0x3_647F
714 MDEU key memory W 0x0000_0000_0000_0000 14.5.4.12/14-62
715 0x3_6800--0x3_6FFF
716 MDEU FIFO W 0x0000_0000_0000_0000 14.5.4.13/14-63
717  /* ARC Four Execution Unit (AFEU) */
718  volatile uint32_t afeumr; /* 0x3_8000 AFEU mode register R/W 0x0000_0000_0000_0000 14.5.3.1/14-43 */
719  volatile uint32_t afeuksr; /* 0x3_8008 AFEU key size register R/W 0x0000_0000_0000_0000 14.5.3.3/14-44 */
720  volatile uint32_t afeudsr; /* 0x3_8010 AFEU data size register R/W 0x0000_0000_0000_0000 14.5.3.4/14-45 */
721  volatile uint32_t afeurcr; /* 0x3_8018 AFEU reset control register R/W 0x0000_0000_0000_0000 14.5.3.5/14-46 */
722  volatile uint32_t afeusr; /* 0x3_8028 AFEU status register R 0x0000_0000_0000_0000 14.5.3.6/14-46 */
723  volatile uint32_t afeuisr; /* 0x3_8030 AFEU interrupt status register R 0x0000_0000_0000_0000 14.5.3.7/14-47 */
724  volatile uint32_t afeuicr; /* 0x3_8038 AFEU interrupt control register R/W 0x0000_0000_0000_1000 14.5.3.8/14-49 */
725  volatile uint32_t afeuemr; /* 0x3_8050 AFEU end of message register W 0x0000_0000_0000_0000 14.5.3.9/14-50 */
726 0x3_8100--0x3_81FF
727 AFEU context memory registers R/W 0x0000_0000_0000_0000 14.5.3.10.1/14-50
728 0x3_8200 AFEU context memory pointers R/W 0x0000_0000_0000_0000 14.5.3.10.2/14-51
729  volatile uint32_t afeuk0; /* 0x3_8400 AFEU key register 0 W $ 14.5.3.11/14-51 */
730  volatile uint32_t afeuk1; /* 0x3_848 AFEU key register 1 W $ 14.5.3.11/14-51 */
731 0x3_8800--0x3_8FFF
732 AFEU FIFO R/W 0x0000_0000_0000_0000 14.5.3.11.1/14-51
733  /* Random Number Generator (RNG) */
734  volatile uint32_t rngmr; /* 0x3_A000 RNG mode register R/W 0x0000_0000_0000_0000 14.5.5.1/14-63 */
735  volatile uint32_t rngdsr; /* 0x3_A010 RNG data size register R/W 0x0000_0000_0000_0000 14.5.5.2/14-64 */
736  volatile uint32_t rngrcr; /* 0x3_A018 RNG reset control register R/W 0x0000_0000_0000_0000 14.5.5.3/14-65 */
737  volatile uint32_t rngsr; /* 0x3_A028 RNG status register R 0x0000_0000_0000_0000 14.5.5.4/14-65 */
738  volatile uint32_t rngisr; /* 0x3_A030 RNG interrupt status register R 0x0000_0000 */
739 _0000_0000
740 14.5.5.5/14-66
741  volatile uint32_t rngicr; /* 0x3_A038 RNG interrupt control register R/W 0x0000_0000 */
742 _0000_1000
743 14.5.5.6/14-67
744  volatile uint32_t rngeug; /* 0x3_A050 RNG EU-Go register W 0x0000_0000 */
745 _0000_0000
746 14.5.5.7/14-68
747 0x3_A800--0x3_AFFF
748 RNG FIFO R 0x0000_0000
749 _0000_0000
750 14.5.5.8/14-68
751  /* Public Key Execution Unit (PKEU) */
752  volatile uint32_t pkeumr; /* 0x3_C000 PKEU mode register R/W 0x0000_0000_0000_0000 14.5.1.1/14-26 */
753  volatile uint32_t pkeuksr; /* 0x3_C008 PKEU key size register R/W 0x0000_0000_0000_0000 14.5.1.2/14-28 */
754  volatile uint32_t pkeudsr; /* 0x3_C010 PKEU data size register R/W 0x0000_0000_0000_0000 14.5.1.3/14-28 */
755  volatile uint32_t pkeurcr; /* 0x3_C018 PKEU reset control register R/W 0x0000_0000_0000_0000 14.5.1.5/14-29 */
756  volatile uint32_t pkeusr; /* 0x3_C028 PKEU status register R 0x0000_0000_0000_0000 14.5.1.6/14-30 */
757  volatile uint32_t pkeuisr; /* 0x3_C030 PKEU interrupt status register R 0x0000_0000_0000_0000 14.5.1.7/14-31 */
758  volatile uint32_t pkeuicr; /* 0x3_C038 PKEU interrupt control register R/W 0x0000_0000_0000_1000 14.5.1.8/14-32 */
759  volatile uint32_t pkeuabs; /* 0x3_C040 PKEU AB size register R/W 0x0000_0000_0000_0000 14.5.1.3/14-28 */
760  volatile uint32_t pkeueug; /* 0x3_C050 PKEU EU-Go W 0x0000_0000_0000_0000 14.5.1.9/14-33 */
761 0x3_C200--0x3_C23F
762 PKEU parameter memory A0 R/W 0x0000_0000_0000_0000 14.5.1.10/14-34
763 0x3_C240--0x3_C27F
764 PKEU parameter memory A1 R/W 0x0000_0000_0000_0000
765 0x3_C280--0x3_C2BF
766 PKEU parameter memory A2 R/W 0x0000_0000_0000_0000
767 0x3_C2C0--0x3_C2FF
768 PKEU parameter memory A3 R/W 0x0000_0000_0000_0000
769 0x3_C300--0x3_C33F
770 PKEU parameter memory B0 R/W 0x0000_0000_0000_0000
771 0x3_C340--0x3_C37F
772 PKEU parameter memory B1 R/W 0x0000_0000_0000_0000
773 0x3_C380--0x3_C3BF
774 PKEU parameter memory B2 R/W 0x0000_0000_0000_0000
775 0x3_C3C0--0x3_C3FF
776 PKEU parameter memory B3 R/W 0x0000_0000_0000_0000
777 0x3_C400--0x3_C4FF
778 PKEU parameter memory E W 0x0000_0000_0000_0000
779 0x3_C800--0x3_C8FF
780 PKEU parameter memory N R/W 0x0000_0000_0000_0000
781 #endif
782
783 typedef struct m83xxRegisters_ {
784  m83xxSysConRegisters_t syscon;
786  uint8_t reserved0_0210[0x0300-0x0210];
788  uint8_t reserved0_0320[0x0400-0x0320];
790  m83xxGTMRegisters_t gtm[M83xxGTModCnt];
796  m83xxGPIORegisters_t gpio[2];
797  uint8_t reserved0_0E00[0x1000-0x0E00];
799  uint8_t reserved0_1200[0x2000-0x1200];
801  uint8_t reserved0_2F00[0x3000-0x2F00];
803  uint8_t reserved0_3200[0x4000-0x3200];
804  uint8_t reserved0_4000[0x4500-0x4000];
805  m83xxDUARTRegisters_t duart[2];
806  uint8_t reserved0_4700[0x5000-0x4700];
808  uint8_t reserved0_5100[0x7000-0x5100];
810  uint8_t reserved0_7100[0x8000-0x7100];
812  m83xxPCICfgRegisters_t pcicfg[2];
813  m83xxPCIIosRegisters_t pciios;
814  m83xxPCICtrlRegisters_t pcictrl[2];
815  uint8_t reserved0_8700[0x22000-0x8700];
816  m83xxUSB_MPHRegisters_t usb_mph;
817  m83xxUSB_DRRegisters_t usb_dr;
818  volatile tsec_registers tsec[TSEC_COUNT];
820
821 extern m83xxRegisters_t mpc83xx;
822
823 static inline void mpc83xx_reset(void)
824 {
825  _ISR_Set_level( 0 );
826
827  /* Set Reset Protection Register (RPR) to "RSTE" */
828  mpc83xx.res.rpr = 0x52535445;
829
830  /*
831  * Wait for Control Register Enabled in the
832  * Reset Control Enable Register (RCER).
833  */
834  while (mpc83xx.res.rcer != 0x00000001) {
835  /* Wait */
836  }
837
838  /* Set Software Hard Reset in the Reset Control Register (RCR) */
839  mpc83xx.res.rcr = 0x00000002;
840 }
841
842 #endif /* !defined ASM */
843 /*
844  * some definitions used in assembler startup
845  */
846 /*
847  * default address of IMMRBAR
848  */
849 #define IMMRBAR_DEFAULT 0xFF400000
850 /*
851  * offsets of some registers
852  */
853 #define LBLAWBAR0_OFF 0x00020
854 #define LBLAWAR0_OFF 0x00024
855 #define LBLAWBAR1_OFF 0x00028
856 #define LBLAWAR1_OFF 0x0002C
857 #define LBLAWBAR2_OFF 0x00030
858 #define LBLAWAR2_OFF 0x00034
859 #define LBLAWBAR3_OFF 0x00038
860 #define LBLAWAR3_OFF 0x0003C
861 #define PCILAWBAR0_OFF 0x00060
862 #define PCILAWAR0_OFF 0x00064
863 #define PCILAWBAR1_OFF 0x00068
864 #define PCILAWAR1_OFF 0x0006C
865 #define DDRLAWBAR0_OFF 0x000A0
866 #define DDRLAWAR0_OFF 0x000A4
867 #define DDRLAWBAR1_OFF 0x000A8
868 #define DDRLAWAR1_OFF 0x000AC
869
870 #define BR0_OFF 0x05000
871 #define OR0_OFF 0x05004
872 #define BR1_OFF 0x05008
873 #define OR1_OFF 0x0500C
874 #define BR2_OFF 0x05010
875 #define OR2_OFF 0x05014
876 #define BR3_OFF 0x05018
877 #define OR3_OFF 0x0501C
878 #define BR4_OFF 0x05020
879 #define OR4_OFF 0x05024
880 #define BR5_OFF 0x05028
881 #define OR5_OFF 0x0502C
882 #define BR6_OFF 0x05030
883 #define OR6_OFF 0x05034
884 #define BR7_OFF 0x05038
885 #define OR7_OFF 0x0503C
886
887 #define MRPTR_OFF 0x05084
888 #define LSDMR_OFF 0x05094
889 #define LSRT_OFF 0x050A4
890 #define LCRR_OFF 0x050d4
891
892
893 #define CS0_BNDS_OFF 0x02000
894 #define CS1_BNDS_OFF 0x02008
895 #define CS2_BNDS_OFF 0x02010
896 #define CS3_BNDS_OFF 0x02018
897 #define CS0_CONFIG_OFF 0x02080
898 #define CS1_CONFIG_OFF 0x02084
899 #define CS2_CONFIG_OFF 0x02088
900 #define CS3_CONFIG_OFF 0x0208C
901 #define TIMING_CFG_3_OFF 0x02100
902 #define TIMING_CFG_0_OFF 0x02104
903 #define TIMING_CFG_1_OFF 0x02108
904 #define TIMING_CFG_2_OFF 0x0210C
905 #define DDR_SDRAM_CFG_OFF 0x02110
906 #define DDR_SDRAM_CFG_2_OFF 0x02114
907 #define DDR_SDRAM_MODE_OFF 0x02118
908 #define DDR_SDRAM_MODE_2_OFF 0x0211C
909 #define DDR_SDRAM_MD_CNTL_OFF 0x02120
910 #define DDR_SDRAM_INTERVAL_OFF 0x02124
911 #define DDR_SDRAM_DATA_INIT_OFF 0x02128
912 #define DDRCDR_OFF 0x0012C
913 #define DDR_SDRAM_CLK_CNTL_OFF 0x02130
914 #define DDR_SDRAM_INIT_ADDR_OFF 0x02148
915 #define DDR_ERR_DISABLE_OFF 0x02E44
916
917 /*
918  * some bits in DDR_SDRAM_CFG register
919  */
920 #define DDR_SDRAM_CFG_MEM_EN (1 << (31- 0)) /* enable memory */
921 /*
922  * bits in DDR_SDRAM_CFG_2 register
923  */
924 #define DDR_SDRAM_CFG_2_D_FRC_SR (1 << (31- 0)) /* force self refresh */
925 #define DDR_SDRAM_CFG_2_D_SR_IE (1 << (31- 1)) /* self refresh interrupt en */
926 #define DDR_SDRAM_CFG_2_D_DLL_RST_DIS (1 << (31- 2)) /* DLL reset disable */
927 #define DDR_SDRAM_CFG_2_D_DQS_CFG_DIF (1 << (31- 5)) /* use diff. DQS */
928 #define DDR_SDRAM_CFG_2_D_INIT (1 << (31-27)) /* Init DRAM with pattern */
929
930 /*
931  * bits in reset configuration words/registers
932  */
933  /* Local bus clocking mode */
934 #define RCWLR_LBIUCM_1_1 (0 << (31- 0)) /* 1:1 */
935 #define RCWLR_LBIUCM_2_1 (1 << (31- 0)) /* 2:1 */
936  /* DDR clocking mode */
937 #define RCWLR_DDRCM_1_1 (0 << (31- 1)) /* 1:1 */
938 #define RCWLR_DDRCM_2_1 (1 << (31- 1)) /* 2:1 */
939  /* System PLL mult. factor */
940 #define RCWLR_SPMF(n) (((n)&0xf)<<(31- 7))
941  /* Core PLL mult. factor */
942 #define RCWLR_COREPLL(n) (((n)&0xff)<<(31-15))
943
944 /* for MPC8309: */
945 #define RCWLR_CEVCOD_1_8 (2<<(31-25)) /* QUICC internal PLL divider 1:8 */
946 #define RCWLR_CEVCOD_1_4 (1<<(31-25)) /* QUICC internal PLL divider 1:4 */
947 #define RCWLR_CEVCOD_1_2 (0<<(31-25)) /* QUICC internal PLL divider 1:2 */
948  /* QUICC Engine PLL mult. factor */
949 #define RCWLR_CEPDF_2 (1<<(31-26)) /* QUICC Engine divide PLL out by 2*/
950  /* QUICC Engine PLL mult. factor */
951 #define RCWLR_CEPMF(n) (((n)&0x1f)<<(31-31))
952
953  /* PCI host mode */
954 #define RCWHR_PCI_AGENT (0 << (31- 0)) /* agent mode */
955 #define RCWHR_PCI_HOST (1 << (31- 0)) /* host mode */
956
957 #define RCWHR_PCI_32 (0 << (31- 1)) /* PCI bus width 32 bit */
958 #define RCWHR_PCI_64 (1 << (31- 1)) /* PCI bus width 64 bit */
959
960 #define RCWHR_PCI1ARB_DIS (0 << (31- 2)) /* PCI1 arbiter disabled */
961 #define RCWHR_PCI1ARB_EN (1 << (31- 2)) /* PCI1 arbiter enabled */
962 #define RCWHR_PCI2ARB_DIS (0 << (31- 3)) /* PCI2 arbiter disabled */
963 #define RCWHR_PCI2ARB_EN (1 << (31- 3)) /* PCI2 arbiter enabled */
964
965 #define RCWHR_CORE_DIS (1 << (31- 4)) /* CPU core disabled */
966 #define RCWHR_CORE_EN (0 << (31- 4)) /* CPU core enabled */
967
968 #define RCWHR_BMS_LOW (0 << (31- 5)) /* Boot from low addr 0x00000100 */
969 #define RCWHR_BMS_HIGH (1 << (31- 5)) /* Boot from high addr 0xFFF00100 */
970
971 #define RCWHR_BOOTSEQ_NONE (0 <<(31- 7)) /* Bootsequencer off */
972 #define RCWHR_BOOTSEQ_NORM (1 <<(31- 7)) /* Bootsequencer normal I2C */
973 #define RCWHR_BOOTSEQ_EXTD (2 <<(31- 7)) /* Bootsequencer extended I2C */
974 #define RCWHR_BOOTSEQ_RSRV (3 <<(31- 7)) /* Bootsequencer reserved */
975
976 #define RCWHR_SW_DIS (0 << (31- 8)) /* Watchdog disabled */
977 #define RCWHR_SW_EN (1 << (31- 8)) /* Watchdog enabled */
978
979 #define RCWHR_ROMLOC_DDR (0 << (31-11)) /* Initial ROM location:DDR Ram */
980 #define RCWHR_ROMLOC_PCI1 (1 << (31-11)) /* Initial ROM location:PCI 1 */
981 #define RCWHR_ROMLOC_PCI2 (2 << (31-11)) /* Initial ROM location:PCI 2 */
982 #define RCWHR_ROMLOC_RSV1 (3 << (31-11)) /* Initial ROM location:Reserved */
983 #define RCWHR_ROMLOC_RSV2 (4 << (31-11)) /* Initial ROM location:Reserved */
984 #define RCWHR_ROMLOC_LB08 (5 << (31-11)) /* Initial ROM location:LBus 8bit*/
985 #define RCWHR_ROMLOC_LB16 (6 << (31-11)) /* Initial ROM location:LBus 16bit*/
986 #define RCWHR_ROMLOC_LB32 (7 << (31-11)) /* Initial ROM location:LBus 32bit*/
987
988 #define RCWHR_TSEC1M_RGMII (0 << (31-17)) /* TSEC1 Mode: RGMII */
989 #define RCWHR_TSEC1M_RTBI (1 << (31-17)) /* TSEC1 Mode: RTBI */
990 #define RCWHR_TSEC1M_GMII (2 << (31-17)) /* TSEC1 Mode: GMII */
991 #define RCWHR_TSEC1M_TBI (3 << (31-17)) /* TSEC1 Mode: TBI */
992
993 #define RCWHR_TSEC2M_RGMII (0 << (31-19)) /* TSEC2 Mode: RGMII */
994 #define RCWHR_TSEC2M_RTBI (1 << (31-19)) /* TSEC2 Mode: RTBI */
995 #define RCWHR_TSEC2M_GMII (2 << (31-19)) /* TSEC2 Mode: GMII */
996 #define RCWHR_TSEC2M_TBI (3 << (31-19)) /* TSEC2 Mode: TBI */
997
998 #define RCWHR_ENDIAN_BIG (0 << (31-28)) /* Big Endian Mode */
999 #define RCWHR_ENDIAN_LIT (1 << (31-28)) /* True Little Endian Mode */
1000
1001 #define RCWHR_LALE_NORM (0 << (31-29)) /* normal LALE timing */
1002 #define RCWHR_LALE_EARLY (1 << (31-29)) /* early LALE negation */
1003
1004 #define RCWHR_LDP_PAR (0 << (31-30)) /* LDP0-3 are parity pins */
1005 #define RCWHR_LDP_SPC (1 << (31-30)) /* LDP0-3 are special pins */
1006
1007 /*
1008  * For MPC8309:
1009  */
1010 #define RCWHR_RLEXT_LGCY (0 << (31-13)) /* Boot ROM loc. extension: Legacy */
1011 #define RCWHR_RLEXT_NAND (1 << (31-13)) /* Boot ROM loc. extension: NAND Fl.*/
1012 #define RCWHR_RLEXT_RSV2 (2 << (31-13)) /* Boot ROM loc. extension: resrvd */
1013 #define RCWHR_RLEXT_RSV3 (3 << (31-13)) /* Boot ROM loc. extension: resrvd */
1014 #endif /* _MPC83XX_MPC83XX_H */
Definition: mpc83xx.h:30
Definition: mpc83xx.h:603
Definition: mpc83xx.h:291
Definition: 8xx_immap.h:216
Definition: mpc83xx.h:191
Definition: mpc83xx.h:209
Definition: mpc83xx.h:484
Definition: mpc83xx.h:528
Definition: mpc83xx.h:80
Definition: mpc83xx.h:171
Definition: mpc83xx.h:565
#define _ISR_Set_level(_new_level)
Set current interrupt level.
Definition: isrlevel.h:140
Definition: mpc83xx.h:383
Definition: mpc83xx.h:476
Definition: mpc83xx.h:157
Definition: mpc83xx.h:783
Definition: mpc83xx.h:111
Definition: mpc83xx.h:349
Definition: mpc83xx.h:222
Definition: tsec.h:89
Definition: intercom.c:74
Definition: mpc83xx.h:274
Definition: mpc83xx.h:198
unsigned context
Definition: tlb.h:108
Definition: mpc83xx.h:91
Definition: mpc83xx.h:184
Definition: mpc83xx.h:317
Definition: mpc83xx.h:129
#define FIFO
Definition: wd80x3.h:55
Definition: mpc83xx.h:71
