RTEMS  5.1
mpc8260.h
1 /* buggy version of CPU */
2 #define REV_0_2
3
4 /*
5 **************************************************************************
6 **************************************************************************
7 ** **
8 ** MOTOROLA MPC8260 POWER QUAD INTEGRATED COMMUNICATIONS CONTROLLER **
9 ** POWERQUICC II **
10 ** **
11 ** HARDWARE DECLARATIONS **
12 ** **
13 ** **
14 ** Submitted by: **
15 ** Andy Dachs ** **
16 ** Surrey Satellite Technology Limited ** **
17 ** http://www.sstl.co.uk ** **
18 ** a.dachs@sstl.co.uk ** **
19 ** **
20 ** Based on previous submissions for other PPC variants by: **
21 ** **
22 ** Submitted By: **
23 ** **
24 ** W. Eric Norum **
25 ** Saskatchewan Accelerator Laboratory **
26 ** University of Saskatchewan **
27 ** 107 North Road **
28 ** Saskatoon, Saskatchewan, CANADA **
29 ** S7N 5C6 **
30 ** **
31 ** eric@skatter.usask.ca **
32 ** **
33 ** Modified for use with the MPC860 (original code was for MC68360) **
34 ** by **
35 ** Jay Monkman **
36 ** Frasca International, Inc. **
37 ** 906 E. Airport Rd. **
38 ** Urbana, IL, 61801 **
39 ** **
40 ** jmonkman@frasca.com **
41 ** **
42 ** **
43 **************************************************************************
44 **************************************************************************
45 */
46
47 #ifndef _MPC8260_H
48 #define _MPC8260_H
49
50 #ifndef ASM
51 /*
52  Macros for SPRs
53 */
54
55
56
57
58 /*
59 *************************************************************************
60 * REGISTER SUBBLOCKS *
61 *************************************************************************
62 */
63
64
65 /*
66  * Memory controller registers
67  */
68 typedef struct m8260MEMCRegisters_ {
69  uint32_t br;
70  uint32_t _or; /* or is a C++ keyword :( */
72
73
74 /*
75  * Fast Communication Controller Registers
76 */
77 typedef struct m8260FCCRegisters_ {
78  uint32_t gfmr;
79  uint32_t fpsmr;
80  uint16_t ftodr;
81  uint8_t fcc_pad0[2];
82  uint16_t fdsr;
83  uint8_t fcc_pad1[2];
84  uint32_t fcce;
85  uint32_t fccm;
86  uint8_t fccs;
87  uint8_t fcc_pad2[3];
88  uint8_t ftirr_phy0; /* n/a on FCC3 */
89  uint8_t ftirr_phy1; /* n/a on FCC3 */
90  uint8_t ftirr_phy2; /* n/a on FCC3 */
91  uint8_t ftirr_phy3; /* n/a on FCC3 */
93
94
95 /*
96  * Serial Communications Controller registers
97  */
98 typedef struct m8260SCCRegisters_ {
99  uint32_t gsmr_l;
100  uint32_t gsmr_h;
101  uint16_t psmr;
102  uint8_t scc_pad0[2];
103  uint16_t todr;
104  uint16_t dsr;
105  uint16_t scce;
106  uint8_t scc_pad2[2];
107  uint16_t sccm;
108  uint8_t scc_pad3[1];
109  uint8_t sccs;
110  uint8_t scc_pad1[8];
112
113 /*
114  * Serial Management Controller registers
115  */
116 typedef struct m8260SMCRegisters_ {
117  uint8_t smc_pad0[2];
118  uint16_t smcmr;
119  uint8_t smc_pad2[2];
120  uint8_t smce;
121  uint8_t smc_pad3[3];
122  uint8_t smcm;
123  uint8_t smc_pad1[5];
125
126
127 /*
128  * Serial Interface With Time Slot Assigner Registers
129  */
130 typedef struct m8260SIRegisters_ {
131  uint16_t siamr;
132  uint16_t sibmr;
133  uint16_t sicmr;
134  uint16_t sidmr;
135  uint8_t sigmr;
136  uint8_t si_pad0[1];
137  uint8_t sicmdr;
138  uint8_t si_pad1[1];
139  uint8_t sistr;
140  uint8_t si_pad2[1];
141  uint16_t sirsr;
143
144
145 /*
146  * Multi Channel Controller registers
147  */
148 typedef struct m8260MCCRegisters_ {
149  uint16_t mcce;
150  uint8_t mcc_pad2[2];
151  uint16_t mccm;
152  uint16_t mcc_pad0;
153  uint8_t mccf;
154  uint8_t mcc_pad1[7];
156
157
158 /*
159 *************************************************************************
160 * RISC Timers *
161 *************************************************************************
162 */
163 /*
164 typedef struct m8260TimerParms_ {
165  uint16_t tm_base;
166  uint16_t _tm_ptr;
167  uint16_t _r_tmr;
168  uint16_t _r_tmv;
169  uint32_t tm_cmd;
170  uint32_t tm_cnt;
171 } m8260TimerParms_t;
172 */
173
174 /*
175  * RISC Controller Configuration Register (RCCR)
176  * All other bits in this register are reserved.
177  */
178 #define M8260_RCCR_TIME (1<<31) /* Enable timer */
179 #define M8260_RCCR_TIMEP(x) ((x)<<24) /* Timer period */
180 #define M8260_RCCR_DR1M (1<<23) /* IDMA Rqst 1 Mode */
181 #define M8260_RCCR_DR2M (1<<22) /* IDMA Rqst 2 Mode */
182 #define M8260_RCCR_DR1QP(x) ((x)<<20) /* IDMA1 Rqst Priority */
183 #define M8260_RCCR_EIE (1<<19) /* External Interrupt Enable */
184 #define M8260_RCCR_SCD (1<<18) /* Scheduler Configuration */
185 #define M8260_RCCR_DR2QP(x) ((x)<<16) /* IDMA2 Rqst Priority */
186 #define M8260_RCCR_ERAM(x) ((x)<<13) /* Enable RAM Microcode */
187 #define M8260_RCCR_EDM1 (1<<11) /* DRQ1 Edge detect mode */
188 #define M8260_RCCR_EDM2 (1<<10) /* DRQ2 Edge detect mode */
189 #define M8260_RCCR_EDM3 (1<<9) /* DRQ3 Edge detect mode */
190 #define M8260_RCCR_EDM4 (1<<8) /* DRQ4 Edge detect mode */
191 #define M8260_RCCR_DR3M (1<<7) /* IDMA Rqst 1 Mode */
192 #define M8260_RCCR_DR4M (1<<6) /* IDMA Rqst 2 Mode */
193 #define M8260_RCCR_DR3QP(x) ((x)<<4) /* IDMA3 Rqst Priority */
194 #define M8260_RCCR_DEM12 (1<<3) /* DONE1,2 Edge detect mode */
195 #define M8260_RCCR_DEM34 (1<<2) /* DONE3,4 Edge detect mode */
196 #define M8260_RCCR_DR4QP(x) (x) /* IDMA4 Rqst Priority */
197
198
199
200 /*
201  * Command register
202  * Set up this register before issuing a M8260_CR_OP_SET_TIMER command.
203  */
204 #if 0
205 #define M8260_TM_CMD_V (1<<31) /* Set to enable timer */
206 #define M8260_TM_CMD_R (1<<30) /* Set for automatic restart */
207 #define M8260_TM_CMD_PWM (1<<29) /* Set for PWM operation */
208 #define M8260_TM_CMD_TIMER(x) ((x)<<16) /* Select timer */
209 #define M8260_TM_CMD_PERIOD(x) (x) /* Timer period (16 bits) */
210 #endif
211
212 /*
213 *************************************************************************
214 * DMA Controllers *
215 *************************************************************************
216 */
217 typedef struct m8260IDMAparms_ {
218  uint16_t ibase;
219  uint16_t dcm;
220  uint16_t ibdptr;
221  uint16_t dpr_buf;
222  uint16_t _buf_inv;
223  uint16_t ssmax;
224  uint16_t _dpr_in_ptr;
225  uint16_t sts;
226  uint16_t _dpr_out_ptr;
227  uint16_t seob;
228  uint16_t deob;
229  uint16_t dts;
230  uint16_t _ret_add;
231  uint16_t reserved;
232  uint32_t _bd_cnt;
233  uint32_t _s_ptr;
234  uint32_t _d_ptr;
235  uint32_t istate;
237
238
239 /*
240 *************************************************************************
241 * Serial Communication Controllers *
242 *************************************************************************
243 */
244
245
246 typedef struct m8260SCCparms_ {
247  uint16_t rbase;
248  uint16_t tbase;
249  uint8_t rfcr;
250  uint8_t tfcr;
251  uint16_t mrblr;
252  uint32_t _rstate;
253  uint32_t _pad0;
254  uint16_t _rbptr;
255  uint16_t _pad1;
256  uint32_t _pad2;
257  uint32_t _tstate;
258  uint32_t _pad3;
259  uint16_t _tbptr;
260  uint16_t _pad4;
261  uint32_t _pad5;
262  uint32_t _rcrc;
263  uint32_t _tcrc;
264  union {
265  struct {
266  uint32_t _res0;
267  uint32_t _res1;
268  uint16_t max_idl;
269  uint16_t idlc;
270  uint16_t brkcr;
271  uint16_t parec;
272  uint16_t frmec;
273  uint16_t nosec;
274  uint16_t brkec;
275  uint16_t brklen;
276  uint16_t uaddr[2];
277  uint16_t rtemp;
278  uint16_t toseq;
279  uint16_t character[8];
280  uint16_t rccm;
281  uint16_t rccr;
282  uint16_t rlbc;
283  } uart;
284  struct {
285  uint32_t _pad0;
286  uint32_t c_mask;
287  uint32_t c_pres;
288  uint16_t disfc;
289  uint16_t crcec;
290  uint16_t abtsc;
291  uint16_t nmarc;
292  uint16_t retrc;
293  uint16_t mflr;
294  uint16_t _max_cnt;
295  uint16_t rfthr;
296  uint16_t _rfcnt;
297  uint16_t hmask;
298  uint16_t haddr1;
299  uint16_t haddr2;
300  uint16_t haddr3;
301  uint16_t haddr4;
302  uint16_t _tmp;
303  uint16_t _tmp_mb;
304  } hdlc;
305  struct {
306  uint32_t _pad0;
307  uint32_t crcc;
308  uint16_t prcrc;
309  uint16_t ptcrc;
310  uint16_t parec;
311  uint16_t bsync;
312  uint16_t bdle;
313  uint16_t character[8];
314  uint16_t rccm;
315  } bisync;
316  struct {
317  uint32_t _crc_p;
318  uint32_t _crc_c;
319  } transparent;
320  struct {
321  uint32_t c_pres;
322  uint32_t c_mask;
323  uint32_t crcec;
324  uint32_t alec;
325  uint32_t disfc;
326  uint16_t pads;
327  uint16_t ret_lim;
328  uint16_t _ret_cnt;
329  uint16_t mflr;
330  uint16_t minflr;
331  uint16_t maxd1;
332  uint16_t maxd2;
333  uint16_t _maxd;
334  uint16_t _dma_cnt;
335  uint16_t _max_b;
336  uint16_t gaddr1;
337  uint16_t gaddr2;
338  uint16_t gaddr3;
339  uint16_t gaddr4;
340  uint32_t _tbuf0data0;
341  uint32_t _tbuf0data1;
342  uint32_t _tbuf0rba0;
343  uint32_t _tbuf0crc;
344  uint16_t _tbuf0bcnt;
345  uint16_t paddr_h;
346  uint16_t paddr_m;
347  uint16_t paddr_l;
348  uint16_t p_per;
349  uint16_t _rfbd_ptr;
350  uint16_t _tfbd_ptr;
351  uint16_t _tlbd_ptr;
352  uint32_t _tbuf1data0;
353  uint32_t _tbuf1data1;
354  uint32_t _tbuf1rba0;
355  uint32_t _tbuf1crc;
356  uint16_t _tbuf1bcnt;
357  uint16_t _tx_len;
358  uint16_t iaddr1;
359  uint16_t iaddr2;
360  uint16_t iaddr3;
361  uint16_t iaddr4;
362  uint16_t _boff_cnt;
363  uint16_t taddr_l;
364  uint16_t taddr_m;
365  uint16_t taddr_h;
366  } ethernet;
367  } un;
369
370
371 /*
372  * Event and mask registers (SCCE, SCCM)
373  */
374 #define M8260_SCCE_BRKE (1<<6)
375 #define M8260_SCCE_BRK (1<<5)
376 #define M8260_SCCE_TXE (1<<4)
377 #define M8260_SCCE_RXF (1<<3)
378 #define M8260_SCCE_BSY (1<<2)
379 #define M8260_SCCE_TX (1<<1)
380 #define M8260_SCCE_RX (1<<0)
381
382
383 /*
384 *************************************************************************
385 * Fast Serial Communication Controllers *
386 *************************************************************************
387 */
388
389
390 typedef struct m8260FCCparms_ {
391  uint16_t riptr;
392  uint16_t tiptr;
393  uint16_t _pad0;
394  uint16_t mrblr;
395  uint32_t rstate;
396  uint32_t rbase;
397  uint16_t _rbdstat;
398  uint16_t _rbdlen;
399  uint32_t _rdptr;
400  uint32_t tstate;
401  uint32_t tbase;
402  uint16_t _tbdstat;
403  uint16_t _tbdlen;
404  uint32_t _tdptr;
405  uint32_t _rbptr;
406  uint32_t _tbptr;
407  uint32_t _rcrc;
408  uint32_t _pad1;
409  uint32_t _tcrc;
410
411  union {
412  struct {
413  uint32_t _pad0;
414  uint32_t _pad1;
415  uint32_t c_mask;
416  uint32_t c_pres;
417  uint16_t disfc;
418  uint16_t crcec;
419  uint16_t abtsc;
420  uint16_t nmarc;
421  uint32_t _max_cnt;
422  uint16_t mflr;
423  uint16_t rfthr;
424  uint16_t rfcnt;
425  uint16_t hmask;
426  uint16_t haddr1;
427  uint16_t haddr2;
428  uint16_t haddr3;
429  uint16_t haddr4;
430  uint16_t _ts_tmp;
431  uint16_t _tmp_mb;
432  } hdlc;
433  struct {
434  uint32_t _pad0;
435  uint32_t _pad1;
436  uint32_t c_mask;
437  uint32_t c_pres;
438  uint16_t disfc;
439  uint16_t crcec;
440  uint16_t abtsc;
441  uint16_t nmarc;
442  uint32_t _max_cnt;
443  uint16_t mflr;
444  uint16_t rfthr;
445  uint16_t rfcnt;
446  uint16_t hmask;
447  uint16_t haddr1;
448  uint16_t haddr2;
449  uint16_t haddr3;
450  uint16_t haddr4;
451  uint16_t _ts_tmp;
452  uint16_t _tmp_mb;
453  } transparent;
454  struct {
455  uint32_t _stat_buf;
456  uint32_t cam_ptr;
457  uint32_t c_mask;
458  uint32_t c_pres;
459  uint32_t crcec;
460  uint32_t alec;
461  uint32_t disfc;
462  uint16_t ret_lim;
463  uint16_t _ret_cnt;
464  uint16_t p_per;
465  uint16_t _boff_cnt;
466  uint32_t gaddr_h;
467  uint32_t gaddr_l;
468  uint16_t tfcstat;
469  uint16_t tfclen;
470  uint32_t tfcptr;
471  uint16_t mflr;
472  uint16_t paddr1_h;
473  uint16_t paddr1_m;
474  uint16_t paddr1_l;
475  uint16_t _ibd_cnt;
476  uint16_t _ibd_start;
477  uint16_t _ibd_end;
478  uint16_t _tx_len;
479  uint16_t _ibd_base;
480  uint32_t iaddr_h;
481  uint32_t iaddr_l;
482  uint16_t minflr;
483  uint16_t taddr_h;
484  uint16_t taddr_m;
485  uint16_t taddr_l;
486  uint16_t pad_ptr;
487  uint16_t _pad0;
488  uint16_t _cf_range;
489  uint16_t _max_b;
490  uint16_t maxd1;
491  uint16_t maxd2;
492  uint16_t _maxd;
493  uint16_t _dma_cnt;
494  uint32_t octc;
495  uint32_t colc;
496  uint32_t broc;
497  uint32_t mulc;
498  uint32_t uspc;
499  uint32_t frgc;
500  uint32_t ospc;
501  uint32_t jbrc;
502  uint32_t p64c;
503  uint32_t p65c;
504  uint32_t p128c;
505  uint32_t p256c;
506  uint32_t p512c;
507  uint32_t p1024c;
508  uint32_t _cam_buf;
509  uint32_t _pad1;
510  } ethernet;
511  } un;
513
514
515 /*
516  * Receive and transmit function code register bits
517  * These apply to the function code registers of all devices, not just SCC.
518  */
519 #define M8260_RFCR_BO(x) ((x)<<3)
520 #define M8260_RFCR_MOT (2<<3)
521 #define M8260_RFCR_LOCAL_BUS (2)
522 #define M8260_RFCR_60X_BUS (0)
523 #define M8260_TFCR_BO(x) ((x)<<3)
524 #define M8260_TFCR_MOT (2<<3)
525 #define M8260_TFCR_LOCAL_BUS (2)
526 #define M8260_TFCR_60X_BUS (0)
527
528 /*
529 *************************************************************************
530 * Serial Management Controllers *
531 *************************************************************************
532 */
533 typedef struct m8260SMCparms_ {
534  uint16_t rbase;
535  uint16_t tbase;
536  uint8_t rfcr;
537  uint8_t tfcr;
538  uint16_t mrblr;
539  uint32_t _rstate;
540  uint32_t _pad0;
541  uint16_t _rbptr;
542  uint16_t _pad1;
543  uint32_t _pad2;
544  uint32_t _tstate;
545  uint32_t _pad3;
546  uint16_t _tbptr;
547  uint16_t _pad4;
548  uint32_t _pad5;
549  union {
550  struct {
551  uint16_t max_idl;
552  uint16_t _idlc;
553  uint16_t _brkln;
554  uint16_t brkec;
555  uint16_t brkcr;
556  uint16_t _r_mask;
557  } uart;
558  struct {
559  uint16_t _pad0[6];
560  } transparent;
561  } un;
562  uint32_t _pad6;
564
565 /*
566  * Mode register
567  */
568 #define M8260_SMCMR_CLEN(x) ((x)<<11) /* Character length */
569 #define M8260_SMCMR_2STOP (1<<10) /* 2 stop bits */
570 #define M8260_SMCMR_PARITY (1<<9) /* Enable parity */
571 #define M8260_SMCMR_EVEN (1<<8) /* Even parity */
572 #define M8260_SMCMR_SM_GCI (0<<4) /* GCI Mode */
573 #define M8260_SMCMR_SM_UART (2<<4) /* UART Mode */
574 #define M8260_SMCMR_SM_TRANSPARENT (3<<4) /* Transparent Mode */
575 #define M8260_SMCMR_DM_LOOPBACK (1<<2) /* Local loopback mode */
576 #define M8260_SMCMR_DM_ECHO (2<<2) /* Echo mode */
577 #define M8260_SMCMR_TEN (1<<1) /* Enable transmitter */
578 #define M8260_SMCMR_REN (1<<0) /* Enable receiver */
579
580 /*
581  * Event and mask registers (SMCE, SMCM)
582  */
583 #define M8260_SMCE_TXE (1<<4)
584 #define M8260_SMCE_BSY (1<<2)
585 #define M8260_SMCE_TX (1<<1)
586 #define M8260_SMCE_RX (1<<0)
587
588 /*
589 *************************************************************************
590 * Serial Peripheral Interface *
591 *************************************************************************
592 */
593 typedef struct m8260SPIparms_ {
594  uint16_t rbase;
595  uint16_t tbase;
596  uint8_t rfcr;
597  uint8_t tfcr;
598  uint16_t mrblr;
599  uint32_t _rstate;
600  uint32_t _pad0;
601  uint16_t _rbptr;
602  uint16_t _pad1;
603  uint32_t _pad2;
604  uint32_t _tstate;
605  uint32_t _pad3;
606  uint16_t _tbptr;
607  uint16_t _pad4;
608  uint32_t _pad5;
610
611 /*
612  * Mode register (SPMODE)
613  */
614 #define M8260_SPMODE_LOOP (1<<14) /* Local loopback mode */
615 #define M8260_SPMODE_CI (1<<13) /* Clock invert */
616 #define M8260_SPMODE_CP (1<<12) /* Clock phase */
617 #define M8260_SPMODE_DIV16 (1<<11) /* Divide BRGCLK by 16 */
618 #define M8260_SPMODE_REV (1<<10) /* Reverse data */
619 #define M8260_SPMODE_MASTER (1<<9) /* SPI is master */
620 #define M8260_SPMODE_EN (1<<8) /* Enable SPI */
621 #define M8260_SPMODE_CLEN(x) ((x)<<4) /* Character length */
622 #define M8260_SPMODE_PM(x) (x) /* Prescaler modulus */
623
624 /*
625  * Mode register (SPCOM)
626  */
627 #define M8260_SPCOM_STR (1<<7) /* Start transmit */
628
629 /*
630  * Event and mask registers (SPIE, SPIM)
631  */
632 #define M8260_SPIE_MME (1<<5) /* Multi-master error */
633 #define M8260_SPIE_TXE (1<<4) /* Tx error */
634 #define M8260_SPIE_BSY (1<<2) /* Busy condition*/
635 #define M8260_SPIE_TXB (1<<1) /* Tx buffer */
636 #define M8260_SPIE_RXB (1<<0) /* Rx buffer */
637
638 /*
639 *************************************************************************
640 * SDMA (SCC, SMC, SPI) Buffer Descriptors *
641 *************************************************************************
642 */
643 typedef struct m8260BufferDescriptor_ {
644  uint16_t status;
645  uint16_t length;
646  volatile void *buffer;
648
649 /*
650  * Bits in receive buffer descriptor status word
651  */
652 #define M8260_BD_EMPTY (1<<15) /* Ethernet, SCC UART, SMC UART, SPI */
653 #define M8260_BD_WRAP (1<<13) /* Ethernet, SCC UART, SMC UART, SPI */
654 #define M8260_BD_INTERRUPT (1<<12) /* Ethernet, SCC UART, SMC UART, SPI */
655 #define M8260_BD_LAST (1<<11) /* Ethernet, SPI */
656 #define M8260_BD_CONTROL_CHAR (1<<11) /* SCC UART */
657 #define M8260_BD_FIRST_IN_FRAME (1<<10) /* Ethernet */
658 #define M8260_BD_ADDRESS (1<<10) /* SCC UART */
659 #define M8260_BD_CONTINUOUS (1<<9) /* SCC UART, SMC UART, SPI */
660 #define M8260_BD_MISS (1<<8) /* Ethernet */
661 #define M8260_BD_IDLE (1<<8) /* SCC UART, SMC UART */
662 #define M8260_BD_ADDRSS_MATCH (1<<7) /* SCC UART */
663 #define M8260_BD_LONG (1<<5) /* Ethernet, SCC HDLC */
664 #define M8260_BD_BREAK (1<<5) /* SCC UART, SMC UART */
665 #define M8260_BD_NONALIGNED (1<<4) /* Ethernet, SCC HDLC */
666 #define M8260_BD_FRAMING_ERROR (1<<4) /* SCC UART, SMC UART */
667 #define M8260_BD_SHORT (1<<3) /* Ethernet */
668 #define M8260_BD_PARITY_ERROR (1<<3) /* SCC UART, SMC UART */
669 #define M8260_BD_ABORT (1<<3) /* SCC HDLC */
670 #define M8260_BD_CRC_ERROR (1<<2) /* Ethernet, SCC HDLC */
671 #define M8260_BD_OVERRUN (1<<1) /* Ethernet, SCC UART, SMC UART, SPI */
672 #define M8260_BD_COLLISION (1<<0) /* Ethernet */
673 #define M8260_BD_CARRIER_LOST (1<<0) /* SCC UART, SMC UART */
674 #define M8260_BD_MASTER_ERROR (1<<0) /* SPI */
675
676 #define M8xx_BD_EMPTY (1<<15) /* Ethernet, SCC UART, SMC UART, SPI */
677 #define M8xx_BD_WRAP (1<<13) /* Ethernet, SCC UART, SMC UART, SPI */
678 #define M8xx_BD_INTERRUPT (1<<12) /* Ethernet, SCC UART, SMC UART, SPI */
679 #define M8xx_BD_LAST (1<<11) /* Ethernet, SPI */
680 #define M8xx_BD_CONTROL_CHAR (1<<11) /* SCC UART */
681 #define M8xx_BD_FIRST_IN_FRAME (1<<10) /* Ethernet */
682 #define M8xx_BD_ADDRESS (1<<10) /* SCC UART */
683 #define M8xx_BD_CONTINUOUS (1<<9) /* SCC UART, SMC UART, SPI */
684 #define M8xx_BD_MISS (1<<8) /* Ethernet */
685 #define M8xx_BD_IDLE (1<<8) /* SCC UART, SMC UART */
686 #define M8xx_BD_ADDRSS_MATCH (1<<7) /* SCC UART */
687 #define M8xx_BD_LONG (1<<5) /* Ethernet, SCC HDLC */
688 #define M8xx_BD_BREAK (1<<5) /* SCC UART, SMC UART */
689 #define M8xx_BD_NONALIGNED (1<<4) /* Ethernet, SCC HDLC */
690 #define M8xx_BD_FRAMING_ERROR (1<<4) /* SCC UART, SMC UART */
691 #define M8xx_BD_SHORT (1<<3) /* Ethernet */
692 #define M8xx_BD_PARITY_ERROR (1<<3) /* SCC UART, SMC UART */
693 #define M8xx_BD_ABORT (1<<3) /* SCC HDLC */
694 #define M8xx_BD_CRC_ERROR (1<<2) /* Ethernet, SCC HDLC */
695 #define M8xx_BD_OVERRUN (1<<1) /* Ethernet, SCC UART, SMC UART, SPI */
696 #define M8xx_BD_COLLISION (1<<0) /* Ethernet */
697 #define M8xx_BD_CARRIER_LOST (1<<0) /* SCC UART, SMC UART */
698 #define M8xx_BD_MASTER_ERROR (1<<0) /* SPI */
699
700 /*
701  * Bits in transmit buffer descriptor status word
702  * Many bits have the same meaning as those in receiver buffer descriptors.
703  */
704 #define M8260_BD_READY (1<<15) /* Ethernet, SCC UART, SMC UART, SPI */
705 #define M8260_BD_PAD (1<<14) /* Ethernet */
706 #define M8260_BD_CTS_REPORT (1<<11) /* SCC UART */
707 #define M8260_BD_TX_CRC (1<<10) /* Ethernet */
708 #define M8260_BD_DEFER (1<<9) /* Ethernet */
709 #define M8260_BD_HEARTBEAT (1<<8) /* Ethernet */
710 #define M8260_BD_PREAMBLE (1<<8) /* SCC UART, SMC UART */
711 #define M8260_BD_LATE_COLLISION (1<<7) /* Ethernet */
712 #define M8260_BD_NO_STOP_BIT (1<<7) /* SCC UART */
713 #define M8260_BD_RETRY_LIMIT (1<<6) /* Ethernet */
714 #define M8260_BD_RETRY_COUNT(x) (((x)&0x3C)>>2) /* Ethernet */
715 #define M8260_BD_UNDERRUN (1<<1) /* Ethernet, SPI, SCC HDLC */
716 #define M8260_BD_CARRIER_LOST (1<<0) /* Ethernet */
717 #define M8260_BD_CTS_LOST (1<<0) /* SCC UART, SCC HDLC */
718
719 #define M8xx_BD_READY (1<<15) /* Ethernet, SCC UART, SMC UART, SPI */
720 #define M8xx_BD_PAD (1<<14) /* Ethernet */
721 #define M8xx_BD_CTS_REPORT (1<<11) /* SCC UART */
722 #define M8xx_BD_TX_CRC (1<<10) /* Ethernet */
723 #define M8xx_BD_DEFER (1<<9) /* Ethernet */
724 #define M8xx_BD_HEARTBEAT (1<<8) /* Ethernet */
725 #define M8xx_BD_PREAMBLE (1<<8) /* SCC UART, SMC UART */
726 #define M8xx_BD_LATE_COLLISION (1<<7) /* Ethernet */
727 #define M8xx_BD_NO_STOP_BIT (1<<7) /* SCC UART */
728 #define M8xx_BD_RETRY_LIMIT (1<<6) /* Ethernet */
729 #define M8xx_BD_RETRY_COUNT(x) (((x)&0x3C)>>2) /* Ethernet */
730 #define M8xx_BD_UNDERRUN (1<<1) /* Ethernet, SPI, SCC HDLC */
731 #define M8xx_BD_CARRIER_LOST (1<<0) /* Ethernet */
732 #define M8xx_BD_CTS_LOST (1<<0) /* SCC UART, SCC HDLC */
733
734 /*
735 *************************************************************************
736 * IDMA Buffer Descriptors *
737 *************************************************************************
738 */
740  uint16_t status;
741  uint8_t dfcr;
742  uint8_t sfcr;
743  uint32_t length;
744  void *source;
745  void *destination;
747
748 /*
749 *************************************************************************
750 * RISC Communication Processor Module Command Register (CR) *
751 *************************************************************************
752 */
753 #define M8260_CR_RST (1<<31) /* Reset communication processor */
754
755 #define M8260_CR_FCC1 ((4<<26)|(16<<21)) /* FCC1 page and code */
756 #define M8260_CR_FCC1_ATM ((4<<26)|(14<<21)) /* FCC1 ATM mode page and code */
757 #define M8260_CR_FCC2 ((5<<26)|(17<<21)) /* FCC2 page and code */
758 #define M8260_CR_FCC2_ATM ((5<<26)|(14<<21)) /* FCC2 ATM mode page and code */
759 #define M8260_CR_FCC3 ((6<<26)|(18<<21)) /* FCC3 page and code */
760 #define M8260_CR_SCC1 ((0<<26)|(4<<21)) /* SCC1 page and code */
761 #define M8260_CR_SCC2 ((1<<26)|(5<<21)) /* SCC2 page and code */
762 #define M8260_CR_SCC3 ((2<<26)|(6<<21)) /* SCC3 page and code */
763 #define M8260_CR_SCC4 ((3<<26)|(7<<21)) /* SCC4 page and code */
764 #define M8260_CR_SMC1 ((7<<26)|(8<<21)) /* SMC1 page and code */
765 #define M8260_CR_SMC2 ((8<<26)|(9<<21)) /* SMC2 page and code */
766 #define M8260_CR_RAND ((10<<26)|(14<<21)) /* SMC2 page and code */
767 #define M8260_CR_SPI ((9<<26)|(10<<21)) /* SPI page and code */
768 #define M8260_CR_I2C ((10<<26)|(11<<21)) /* I2C page and code */
769 #define M8260_CR_TMR ((10<<26)|(15<<21)) /* Timer page and code */
770 #define M8260_CR_MCC1 ((7<<26)|(28<<21)) /* MCC1 page and code */
771 #define M8260_CR_MCC2 ((8<<26)|(29<<21)) /* MCC2 page and code */
772 #define M8260_CR_IDMA1 ((7<<26)|(20<<21)) /* IDMA1 page and code */
773 #define M8260_CR_IDMA2 ((8<<26)|(21<<21)) /* IDMA2 page and code */
774 #define M8260_CR_IDMA3 ((9<<26)|(22<<21)) /* IDMA3 page and code */
775 #define M8260_CR_IDMA4 ((10<<26)|(23<<21)) /* IDMA4 page and code */
776
777 #define M8260_CR_FLG (1<<16) /* Command sempahore flag */
778
779 #define M8260_CR_MCC_CHAN(x) ((x)<<6) /* MCC channel number */
780 #define M8260_CR_FCC_HDLC (0<<6) /* FCC HDLC/Transparent protocol code */
781 #define M8260_CR_FCC_ATM (10<<6) /* FCC ATM protocol code */
782 #define M8260_CR_FCC_ETH (12<<6) /* FCC Ethernet protocol code */
783
784 #define M8260_CR_OP_INIT_RX_TX (0) /* FCC, SCC, SMC UART, SMC GCI, SPI, I2C, MCC */
785 #define M8260_CR_OP_INIT_RX (1) /* FCC, SCC, SMC UART, SPI, I2C, MCC */
786 #define M8260_CR_OP_INIT_TX (2) /* FCC, SCC, SMC UART, SPI, I2C, MCC */
787 #define M8260_CR_OP_INIT_HUNT (3) /* FCC, SCC, SMC UART */
788 #define M8260_CR_OP_STOP_TX (4) /* FCC, SCC, SMC UART, MCC */
789 #define M8260_CR_OP_GR_STOP_TX (5) /* FCC, SCC */
790 #define M8260_CR_OP_RESTART_TX (6) /* FCC, SCC, SMC UART */
791 #define M8260_CR_OP_CLOSE_RX_BD (7) /* FCC, SCC, SMC UART, SPI, I2C */
792 #define M8260_CR_OP_SET_GRP_ADDR (8) /* FCC, SCC */
793 #define M8260_CR_OP_SET_TIMER (8) /* Timer */
794 #define M8260_CR_OP_GCI_TIMEOUT (9) /* SMC GCI */
795 #define M8260_CR_OP_START_IDMA (9) /* IDMA */
796 #define M8260_CR_OP_STOP_RX (9) /* MCC */
797 #define M8260_CR_OP_ATM_TX (10) /* FCC */
798 #define M8260_CR_OP_RESET_BCS (10) /* SCC */
799 #define M8260_CR_OP_GCI_ABORT (10) /* SMC GCI */
800 #define M8260_CR_OP_STOP_IDMA (11) /* IDMA */
801 #define M8260_CR_OP_RANDOM (12) /* RAND */
802
803 /*
804 *************************************************************************
805 * System Protection Control Register (SYPCR) *
806 *************************************************************************
807 */
808 #define M8260_SYPCR_SWTC(x) ((x)<<16) /* Software watchdog timer count */
809 #define M8260_SYPCR_BMT(x) ((x)<<8) /* Bus monitor timing */
810 #define M8260_SYPCR_BME (1<<7) /* Bus monitor enable */
811 #define M8260_SYPCR_SWF (1<<3) /* Software watchdog freeze */
812 #define M8260_SYPCR_SWE (1<<2) /* Software watchdog enable */
813 #define M8260_SYPCR_SWRI (1<<1) /* Watchdog reset/interrupt sel. */
814 #define M8260_SYPCR_SWP (1<<0) /* Software watchdog prescale */
815
816 /*
817 *************************************************************************
818 * Memory Control Registers *
819 *************************************************************************
820 */
821 #define M8260_UPM_AMX_8col (0<<20) /* 8 column DRAM */
822 #define M8260_UPM_AMX_9col (1<<20) /* 9 column DRAM */
823 #define M8260_UPM_AMX_10col (2<<20) /* 10 column DRAM */
824 #define M8260_UPM_AMX_11col (3<<20) /* 11 column DRAM */
825 #define M8260_UPM_AMX_12col (4<<20) /* 12 column DRAM */
826 #define M8260_UPM_AMX_13col (5<<20) /* 13 column DRAM */
827 #define M8260_MSR_PER(x) (0x100<<(7-x)) /* Perity error bank (x) */
828 #define M8260_MSR_WPER (1<<7) /* Write protection error */
829 #define M8260_MPTPR_PTP(x) ((x)<<8) /* Periodic timer prescaler */
830 #define M8260_BR_BA(x) ((x)&0xffff8000) /* Base address */
831 #define M8260_BR_AT(x) ((x)<<12) /* Address type */
832 #define M8260_BR_PS8 (1<<10) /* 8 bit port */
833 #define M8260_BR_PS16 (2<<10) /* 16 bit port */
834 #define M8260_BR_PS32 (0<<10) /* 32 bit port */
835 #define M8260_BR_PARE (1<<9) /* Parity checking enable */
836 #define M8260_BR_WP (1<<8) /* Write protect */
837 #define M8260_BR_MS_GPCM (0<<6) /* GPCM */
838 #define M8260_BR_MS_UPMA (2<<6) /* UPM A */
839 #define M8260_BR_MS_UPMB (3<<6) /* UPM B */
840 #define M8260_MEMC_BR_V (1<<0) /* Base/Option register are valid */
841
842 #define M8260_MEMC_OR_32K 0xffff8000 /* Address range */
843 #define M8260_MEMC_OR_64K 0xffff0000
844 #define M8260_MEMC_OR_128K 0xfffe0000
845 #define M8260_MEMC_OR_256K 0xfffc0000
846 #define M8260_MEMC_OR_512K 0xfff80000
847 #define M8260_MEMC_OR_1M 0xfff00000
848 #define M8260_MEMC_OR_2M 0xffe00000
849 #define M8260_MEMC_OR_4M 0xffc00000
850 #define M8260_MEMC_OR_8M 0xff800000
851 #define M8260_MEMC_OR_16M 0xff000000
852 #define M8260_MEMC_OR_32M 0xfe000000
853 #define M8260_MEMC_OR_64M 0xfc000000
854 #define M8260_MEMC_OR_128 0xf8000000
855 #define M8260_MEMC_OR_256M 0xf0000000
856 #define M8260_MEMC_OR_512M 0xe0000000
857 #define M8260_MEMC_OR_1G 0xc0000000
858 #define M8260_MEMC_OR_2G 0x80000000
859 #define M8260_MEMC_OR_4G 0x00000000
860 #define M8260_MEMC_OR_ATM(x) ((x)<<12) /* Address type mask */
861 #define M8260_MEMC_OR_CSNT (1<<11) /* Chip select is negated early */
862 #define M8260_MEMC_OR_SAM (1<<11) /* Address lines are multiplexed */
863 #define M8260_MEMC_OR_ACS_NORM (0<<9) /* *CS asserted with addr lines */
864 #define M8260_MEMC_OR_ACS_QRTR (2<<9) /* *CS asserted 1/4 after addr */
865 #define M8260_MEMC_OR_ACS_HALF (3<<9) /* *CS asserted 1/2 after addr */
866 #define M8260_MEMC_OR_BI (1<8) /* Burst inhibit */
867 #define M8260_MEMC_OR_SCY(x) ((x)<<4) /* Cycle length in clocks */
868 #define M8260_MEMC_OR_SETA (1<<3) /* *TA generated externally */
869 #define M8260_MEMC_OR_TRLX (1<<2) /* Relaxed timing in GPCM */
870 #define M8260_MEMC_OR_EHTR (1<<1) /* Extended hold time on reads */
871
872 /*
873 *************************************************************************
874 * UPM Registers (MxMR) *
875 *************************************************************************
876 */
877 #define M8260_MEMC_MMR_PTP(x) ((x)<<24) /* Periodic timer period */
878 #define M8260_MEMC_MMR_PTE (1<<23) /* Periodic timer enable */
879 #define M8260_MEMC_MMR_DSP(x) ((x)<<17) /* Disable timer period */
880 #define M8260_MEMC_MMR_G0CL(x) ((x)<<13) /* General line 0 control */
881 #define M8260_MEMC_MMR_UPWAIT (1<<12) /* GPL_x4 is UPWAITx */
882 #define M8260_MEMC_MMR_RLF(x) ((x)<<8) /* Read loop field */
883 #define M8260_MEMC_MMR_WLF(x) ((x)<<4) /* Write loop field */
884 #define M8260_MEMC_MMR_TLF(x) ((x)<<0) /* Timer loop field */
885 /*
886 *************************************************************************
887 * Memory Command Register (MCR) *
888 *************************************************************************
889 */
890 #define M8260_MEMC_MCR_WRITE (0<<30) /* WRITE command */
891 #define M8260_MEMC_MCR_READ (1<<30) /* READ command */
892 #define M8260_MEMC_MCR_RUN (2<<30) /* RUN command */
893 #define M8260_MEMC_MCR_UPMA (0<<23) /* Cmd is for UPMA */
894 #define M8260_MEMC_MCR_UPMB (1<<23) /* Cmd is for UPMB */
895 #define M8260_MEMC_MCR_MB(x) ((x)<<13) /* Memory bank when RUN cmd */
896 #define M8260_MEMC_MCR_MCLF(x) ((x)<<8) /* Memory command loop field */
897 #define M8260_MEMC_MCR_MAD(x) (x) /* Machine address */
898
899
900
901 /*
902 *************************************************************************
903 * SI Mode Register (SIMODE) *
904 *************************************************************************
905 */
906 #define M8260_SI_SMC2_BITS 0xFFFF0000 /* All SMC2 bits */
907 #define M8260_SI_SMC2_TDM (1<<31) /* Multiplexed SMC2 */
908 #define M8260_SI_SMC2_BRG1 (0<<28) /* SMC2 clock souce */
909 #define M8260_SI_SMC2_BRG2 (1<<28)
910 #define M8260_SI_SMC2_BRG3 (2<<28)
911 #define M8260_SI_SMC2_BRG4 (3<<28)
912 #define M8260_SI_SMC2_CLK5 (0<<28)
913 #define M8260_SI_SMC2_CLK6 (1<<28)
914 #define M8260_SI_SMC2_CLK7 (2<<28)
915 #define M8260_SI_SMC2_CLK8 (3<<28)
916 #define M8260_SI_SMC1_BITS 0x0000FFFF /* All SMC1 bits */
917 #define M8260_SI_SMC1_TDM (1<<15) /* Multiplexed SMC1 */
918 #define M8260_SI_SMC1_BRG1 (0<<12) /* SMC1 clock souce */
919 #define M8260_SI_SMC1_BRG2 (1<<12)
920 #define M8260_SI_SMC1_BRG3 (2<<12)
921 #define M8260_SI_SMC1_BRG4 (3<<12)
922 #define M8260_SI_SMC1_CLK1 (0<<12)
923 #define M8260_SI_SMC1_CLK2 (1<<12)
924 #define M8260_SI_SMC1_CLK3 (2<<12)
925 #define M8260_SI_SMC1_CLK4 (3<<12)
926
927 /*
928 *************************************************************************
929 * SDMA Configuration Register (SDCR) *
930 *************************************************************************
931 */
932 #define M8260_SDCR_FREEZE (2<<13) /* Freeze on next bus cycle */
933 #define M8260_SDCR_RAID_5 (1<<0) /* Normal arbitration ID */
934
935 /*
936 *************************************************************************
937 * SDMA Status Register (SDSR) *
938 *************************************************************************
939 */
940 #define M8260_SDSR_SBER (1<<7) /* SDMA Channel bus error */
941 #define M8260_SDSR_DSP2 (1<<1) /* DSP Chain 2 interrupt */
942 #define M8260_SDSR_DSP1 (1<<0) /* DSP Chain 1 interrupt */
943
944 /*
945 *************************************************************************
946 * Baud (sic) Rate Generators *
947 *************************************************************************
948 */
949 #define M8260_BRG_RST (1<<17) /* Reset generator */
950 #define M8260_BRG_EN (1<<16) /* Enable generator */
951 #define M8260_BRG_EXTC_BRGCLK (0<<14) /* Source is BRGCLK */
952 #define M8260_BRG_EXTC_CLK2 (1<<14) /* Source is CLK2 pin */
953 #define M8260_BRG_EXTC_CLK6 (2<<14) /* Source is CLK6 pin */
954 #define M8260_BRG_ATB (1<<13) /* Autobaud */
955 #define M8260_BRG_115200 (21<<1) /* Assume 40 MHz clock */
956 #define M8260_BRG_57600 (32<<1)
957 #define M8260_BRG_38400 (64<<1)
958 #define M8260_BRG_19200 (129<<1)
959 #define M8260_BRG_9600 (259<<1)
960 #define M8260_BRG_4800 (520<<1)
961 #define M8260_BRG_2400 (1040<<1)
962 #define M8260_BRG_1200 (2082<<1)
963 #define M8260_BRG_600 ((259<<1) | 1)
964 #define M8260_BRG_300 ((520<<1) | 1)
965 #define M8260_BRG_150 ((1040<<1) | 1)
966 #define M8260_BRG_75 ((2080<<1) | 1)
967
968 #define M8xx_BRG_RST (1<<17) /* Reset generator */
969 #define M8xx_BRG_EN (1<<16) /* Enable generator */
970 #define M8xx_BRG_EXTC_BRGCLK (0<<14) /* Source is BRGCLK */
971
972 #define M8260_BRG1 (1<<7)
973 #define M8260_BRG2 (1<<6)
974 #define M8260_BRG3 (1<<5)
975 #define M8260_BRG4 (1<<4)
976 #define M8260_BRG5 (1<<3)
977 #define M8260_BRG6 (1<<2)
978 #define M8260_BRG7 (1<<1)
979 #define M8260_BRG8 (1<<0)
980
981
982
983 #define M8260_TGCR_CAS4 (1<<15) /* Cascade timers 3 and 4 */
984 #define M8260_TGCR_CAS2 (1<<7) /* Cascade timers 1 and 2 */
985 #define M8260_TGCR_FRZ1 (1<<2) /* Halt timer if FREEZE asserted */
986 #define M8260_TGCR_FRZ2 (1<<6) /* Halt timer if FREEZE asserted */
987 #define M8260_TGCR_FRZ3 (1<<10) /* Halt timer if FREEZE asserted */
988 #define M8260_TGCR_FRZ4 (1<<14) /* Halt timer if FREEZE asserted */
989 #define M8260_TGCR_STP1 (1<<1) /* Stop timer */
990 #define M8260_TGCR_STP2 (1<<5) /* Stop timer */
991 #define M8260_TGCR_STP3 (1<<9) /* Stop timer */
992 #define M8260_TGCR_STP4 (1<<13) /* Stop timer */
993 #define M8260_TGCR_RST1 (1<<0) /* Enable timer */
994 #define M8260_TGCR_RST2 (1<<4) /* Enable timer */
995 #define M8260_TGCR_RST3 (1<<8) /* Enable timer */
996 #define M8260_TGCR_RST4 (1<<12) /* Enable timer */
997 #define M8260_TGCR_GM1 (1<<3) /* Gate Mode 1 for TMR1 or TMR2 */
998 #define M8260_TGCR_GM2 (1<<11) /* Gate Mode 2 for TMR3 or TMR4 */
999
1000 #define M8260_TMR_PS(x) ((x)<<8) /* Timer prescaler */
1001 #define M8260_TMR_CE_RISE (1<<6) /* Capture on rising edge */
1002 #define M8260_TMR_CE_FALL (2<<6) /* Capture on falling edge */
1003 #define M8260_TMR_CE_ANY (3<<6) /* Capture on any edge */
1004 #define M8260_TMR_OM_TOGGLE (1<<5) /* Toggle TOUTx pin */
1005 #define M8260_TMR_ORI (1<<4) /* Interrupt on reaching reference */
1006 #define M8260_TMR_RESTART (1<<3) /* Restart timer after reference */
1007 #define M8260_TMR_ICLK_INT (1<<1) /* Internal clock is timer source */
1008 #define M8260_TMR_ICLK_INT16 (2<<1) /* Internal clock/16 is tmr src */
1009 #define M8260_TMR_ICLK_TIN (3<<1) /* TIN pin is timer source */
1010 #define M8260_TMR_TGATE (1<<0) /* TGATE controls timer */
1011
1012 #ifdef REV_0_2
1013 #define M8260_PISCR_PS (1<<6) /* PIT Interrupt state */
1014 #else
1015 #define M8260_PISCR_PS (1<<7) /* PIT Interrupt state */
1016 #endif
1017 #define M8260_PISCR_PIE (1<<2) /* PIT interrupt enable */
1018 #define M8260_PISCR_PTF (1<<1) /* Stop timer when freeze asserted */
1019 #define M8260_PISCR_PTE (1<<0) /* PIT enable */
1020
1021 #if 0
1022 #define M8260_TBSCR_TBIRQ(x) (1<<(15-x)) /* TB interrupt level */
1023 #define M8260_TBSCR_REFA (1<<7) /* TB matches TBREFF0 */
1024 #define M8260_TBSCR_REFB (1<<6) /* TB matches TBREFF1 */
1025 #define M8260_TBSCR_REFAE (1<<3) /* Enable ints for REFA */
1026 #define M8260_TBSCR_REFBE (1<<2) /* Enable ints for REFB */
1027 #define M8260_TBSCR_TBF (1<<1) /* TB stops on FREEZE */
1028 #define M8260_TBSCR_TBE (1<<0) /* enable TB and decrementer */
1029 #endif
1030
1031 #define M8260_TMCNTSC_SEC (1<<7) /* per second flag */
1032 #define M8260_TMCNTSC_ALR (1<<6) /* Alarm interrupt flag */
1033 #define M8260_TMCNTSC_SIE (1<<3) /* per second interrupt enable */
1034 #define M8260_TMCNTSC_ALE (1<<2) /* Alarm interrupt enable */
1035 #define M8260_TMCNTSC_TCF (1<<1) /* Time count frequency */
1036 #define M8260_TMCNTSC_TCE (1<<0) /* Time count enable */
1037
1038 #define M8260_SIMASK_PC0 (1<<31)
1039 #define M8260_SIMASK_PC1 (1<<30)
1040 #define M8260_SIMASK_PC2 (1<<29)
1041 #define M8260_SIMASK_PC3 (1<<28)
1042 #define M8260_SIMASK_PC4 (1<<27)
1043 #define M8260_SIMASK_PC5 (1<<26)
1044 #define M8260_SIMASK_PC6 (1<<25)
1045 #define M8260_SIMASK_PC7 (1<<24)
1046 #define M8260_SIMASK_PC8 (1<<23)
1047 #define M8260_SIMASK_PC9 (1<<22)
1048 #define M8260_SIMASK_PC10 (1<<21)
1049 #define M8260_SIMASK_PC11 (1<<20)
1050 #define M8260_SIMASK_PC12 (1<<19)
1051 #define M8260_SIMASK_PC13 (1<<18)
1052 #define M8260_SIMASK_PC14 (1<<17)
1053 #define M8260_SIMASK_PC15 (1<<16)
1054 #define M8260_SIMASK_IRQ1 (1<<14)
1055 #define M8260_SIMASK_IRQ2 (1<<13)
1056 #define M8260_SIMASK_IRQ3 (1<<12)
1057 #define M8260_SIMASK_IRQ4 (1<<11)
1058 #define M8260_SIMASK_IRQ5 (1<<10)
1059 #define M8260_SIMASK_IRQ6 (1<<9)
1060 #define M8260_SIMASK_IRQ7 (1<<8)
1061 #define M8260_SIMASK_TMCNT (1<<2)
1062 #define M8260_SIMASK_PIT (1<<1)
1063
1064 #define M8260_SIMASK_FCC1 (1<<31)
1065 #define M8260_SIMASK_FCC2 (1<<30)
1066 #define M8260_SIMASK_FCC3 (1<<29)
1067 #define M8260_SIMASK_MCC1 (1<<27)
1068 #define M8260_SIMASK_MCC2 (1<<26)
1069 #define M8260_SIMASK_SCC1 (1<<23)
1070 #define M8260_SIMASK_SCC2 (1<<22)
1071 #define M8260_SIMASK_SCC3 (1<<21)
1072 #define M8260_SIMASK_SCC4 (1<<20)
1073 #define M8260_SIMASK_I2C (1<<15)
1074 #define M8260_SIMASK_SPI (1<<14)
1075 #define M8260_SIMASK_RTT (1<<13)
1076 #define M8260_SIMASK_SMC1 (1<<12)
1077 #define M8260_SIMASK_SMC2 (1<<11)
1078 #define M8260_SIMASK_IDMA1 (1<<10)
1079 #define M8260_SIMASK_IDMA2 (1<<9)
1080 #define M8260_SIMASK_IDMA3 (1<<8)
1081 #define M8260_SIMASK_IDMA4 (1<<7)
1082 #define M8260_SIMASK_SDMA (1<<6)
1083 #define M8260_SIMASK_TIMER1 (1<<4)
1084 #define M8260_SIMASK_TIMER2 (1<<3)
1085 #define M8260_SIMASK_TIMER3 (1<<2)
1086 #define M8260_SIMASK_TIMER4 (1<<1)
1087
1088 #define M8260_SIUMCR_EARB (1<<31)
1089 #define M8260_SIUMCR_EARP0 (0<<28)
1090 #define M8260_SIUMCR_EARP1 (1<<28)
1091 #define M8260_SIUMCR_EARP2 (2<<28)
1092 #define M8260_SIUMCR_EARP3 (3<<28)
1093 #define M8260_SIUMCR_EARP4 (4<<28)
1094 #define M8260_SIUMCR_EARP5 (5<<28)
1095 #define M8260_SIUMCR_EARP6 (6<<28)
1096 #define M8260_SIUMCR_EARP7 (7<<28)
1097 #define M8260_SIUMCR_DSHW (1<<23)
1098 #define M8260_SIUMCR_DBGC0 (0<<21)
1099 #define M8260_SIUMCR_DBGC1 (1<<21)
1100 #define M8260_SIUMCR_DBGC2 (2<<21)
1101 #define M8260_SIUMCR_DBGC3 (3<<21)
1102 #define M8260_SIUMCR_DBPC0 (0<<19)
1103 #define M8260_SIUMCR_DBPC1 (1<<19)
1104 #define M8260_SIUMCR_DBPC2 (2<<19)
1105 #define M8260_SIUMCR_DBPC3 (3<<19)
1106 #define M8260_SIUMCR_FRC (1<<17)
1107 #define M8260_SIUMCR_DLK (1<<16)
1108 #define M8260_SIUMCR_PNCS (1<<15)
1109 #define M8260_SIUMCR_OPAR (1<<14)
1110 #define M8260_SIUMCR_DPC (1<<13)
1111 #define M8260_SIUMCR_MPRE (1<<12)
1112 #define M8260_SIUMCR_MLRC0 (0<<10)
1113 #define M8260_SIUMCR_MLRC1 (1<<10)
1114 #define M8260_SIUMCR_MLRC2 (2<<10)
1115 #define M8260_SIUMCR_MLRC3 (3<<10)
1116 #define M8260_SIUMCR_AEME (1<<9)
1117 #define M8260_SIUMCR_SEME (1<<8)
1118 #define M8260_SIUMCR_BSC (1<<7)
1119 #define M8260_SIUMCR_GB5E (1<<6)
1120 #define M8260_SIUMCR_B2DD (1<<5)
1121 #define M8260_SIUMCR_B3DD (1<<4)
1122
1123 /*
1124 *************************************************************************
1125 * MPC8260 DUAL-PORT RAM AND REGISTERS *
1126 *************************************************************************
1127 */
1128 typedef struct m8260_ {
1129
1130  /*
1131  * CPM Dual-Port RAM
1132  */
1133  uint8_t dpram1[16384]; /* 0x0000 - 0x3FFF BD/data/ucode */
1134  uint8_t cpm_pad0[16384]; /* 0x4000 - 0x7FFF Reserved */
1135
1136  m8260SCCparms_t scc1p;
1137  uint8_t pad_scc1[256-sizeof(m8260SCCparms_t)];
1138  m8260SCCparms_t scc2p;
1139  uint8_t pad_scc2[256-sizeof(m8260SCCparms_t)];
1140  m8260SCCparms_t scc3p;
1141  uint8_t pad_scc3[256-sizeof(m8260SCCparms_t)];
1142  m8260SCCparms_t scc4p;
1143  uint8_t pad_scc4[256-sizeof(m8260SCCparms_t)];
1144
1145  m8260FCCparms_t fcc1p;
1146  uint8_t pad_fcc1[256-sizeof(m8260FCCparms_t)];
1147  m8260FCCparms_t fcc2p;
1148  uint8_t pad_fcc2[256-sizeof(m8260FCCparms_t)];
1149  m8260FCCparms_t fcc3p;
1150  uint8_t pad_fcc3[256-sizeof(m8260FCCparms_t)];
1151
1152  uint8_t mcc1p[128];
1153  uint8_t pad_mcc1[124];
1154  uint16_t smc1_base;
1155  uint16_t idma1_base;
1156  uint8_t mcc2p[128];
1157  uint8_t pad_mcc2[124];
1158  uint16_t smc2_base;
1159  uint16_t idma2_base;
1160  uint8_t pad_spi[252];
1161  uint16_t spi_base;
1162  uint16_t idma3_base;
1163  uint8_t pad_risc[224];
1164  uint8_t risc_timers[16];
1165  uint16_t rev_num;
1166  uint16_t cpm_pad7;
1167  uint32_t cpm_pad8;
1168  uint16_t rand;
1169  uint16_t i2c_base;
1170  uint16_t idma4_base;
1171  uint8_t cpm_pad9[1282];
1172
1173  uint8_t cpm_pad1[8192]; /* 0x9000 - 0xAFFF Reserved */
1174
1175  m8260SMCparms_t smc1p;
1176  m8260SMCparms_t smc2p;
1177  uint8_t dpram3[4096-2*sizeof(m8260SMCparms_t)];
1178
1179  uint8_t cpm_pad2[16384]; /* 0xC000 - 0xFFFF Reserved */
1180
1181
1182  /*
1183  * General SIU Block
1184  */
1185  uint32_t siumcr;
1186  uint32_t sypcr;
1187  uint8_t siu_pad0[6];
1188  uint16_t swsr;
1189  uint8_t siu_pad1[20];
1190  uint32_t bcr;
1191  uint8_t ppc_acr;
1192  uint8_t siu_pad4[3];
1193  uint32_t ppc_alrh;
1194  uint32_t ppc_alr1;
1195  uint8_t lcl_acr;
1196  uint8_t siu_pad5[3];
1197  uint32_t lcl_alrh;
1198  uint32_t lcl_alr1;
1199  uint32_t tescr1;
1200  uint32_t tescr2;
1201  uint32_t l_tescr1;
1202  uint32_t l_tescr2;
1203  uint32_t pdtea;
1204  uint8_t pdtem;
1205  uint8_t siu_pad2[3];
1206  uint32_t ldtea;
1207  uint8_t ldtem;
1208  uint8_t siu_pad3[163];
1209
1210
1211  /*
1212  * Memory Controller Block
1213  */
1214  m8260MEMCRegisters_t memc[12];
1215  uint8_t mem_pad0[8];
1216  uint32_t mar;
1217  uint8_t mem_pad1[4];
1218  uint32_t mamr;
1219  uint32_t mbmr;
1220  uint32_t mcmr;
1221  uint32_t mdmr;
1222  uint8_t mem_pad2[4];
1223  uint16_t mptpr;
1224  uint8_t mem_pad5[2];
1225  uint32_t mdr;
1226  uint8_t mem_pad3[4];
1227  uint32_t psdmr;
1228  uint32_t lsdmr;
1229  uint8_t purt;
1230  uint8_t mem_pad6[3];
1231  uint8_t psrt;
1232  uint8_t mem_pad7[3];
1233  uint8_t lurt;
1234  uint8_t mem_pad8[3];
1235  uint8_t lsrt;
1236  uint8_t mem_pad9[3];
1237  uint32_t immr;
1238  uint8_t mem_pad4[84];
1239
1240
1241  /*
1242  * System integration timers
1243  */
1244  uint8_t sit_pad0[32];
1245  uint16_t tmcntsc;
1246  uint8_t sit_pad6[2];
1247  uint32_t tmcnt;
1248  uint32_t tmcntsec;
1249  uint32_t tmcntal;
1250  uint8_t sit_pad2[16];
1251  uint16_t piscr;
1252  uint8_t sit_pad5[2];
1253  uint32_t pitc;
1254  uint32_t pitr;
1255  uint8_t sit_pad3[94];
1256  uint8_t sit_pad4[2390];
1257
1258
1259  /*
1260  * Interrupt Controller
1261  */
1262  uint16_t sicr;
1263  uint8_t ict_pad1[2];
1264  uint32_t sivec;
1265  uint32_t sipnr_h;
1266  uint32_t sipnr_l;
1267  uint32_t siprr;
1268  uint32_t scprr_h;
1269  uint32_t scprr_l;
1270  uint32_t simr_h;
1271  uint32_t simr_l;
1272  uint32_t siexr;
1273  uint8_t ict_pad0[88];
1274
1275
1276  /*
1277  * Clocks and Reset
1278  */
1279  uint32_t sccr;
1280  uint8_t clr_pad1[4];
1281  uint32_t scmr;
1282  uint8_t clr_pad2[4];
1283  uint32_t rsr;
1284  uint32_t rmr;
1285  uint8_t clr_pad0[104];
1286
1287
1288  /*
1289  * Input/ Output Port
1290  */
1291  uint32_t pdira;
1292  uint32_t ppara;
1293  uint32_t psora;
1294  uint32_t podra;
1295  uint32_t pdata;
1296  uint8_t iop_pad0[12];
1297  uint32_t pdirb;
1298  uint32_t pparb;
1299  uint32_t psorb;
1300  uint32_t podrb;
1301  uint32_t pdatb;
1302  uint8_t iop_pad1[12];
1303  uint32_t pdirc;
1304  uint32_t pparc;
1305  uint32_t psorc;
1306  uint32_t podrc;
1307  uint32_t pdatc;
1308  uint8_t iop_pad2[12];
1309  uint32_t pdird;
1310  uint32_t ppard;
1311  uint32_t psord;
1312  uint32_t podrd;
1313  uint32_t pdatd;
1314  uint8_t iop_pad3[12];
1315
1316
1317  /*
1318  * CPM Timers
1319  */
1320  uint8_t tgcr1;
1321  uint8_t cpt_pad0[3];
1322  uint8_t tgcr2;
1323  uint8_t cpt_pad1[11];
1324  uint16_t tmr1;
1325  uint16_t tmr2;
1326  uint16_t trr1;
1327  uint16_t trr2;
1328  uint16_t tcr1;
1329  uint16_t tcr2;
1330  uint16_t tcn1;
1331  uint16_t tcn2;
1332  uint16_t tmr3;
1333  uint16_t tmr4;
1334  uint16_t trr3;
1335  uint16_t trr4;
1336  uint16_t tcr3;
1337  uint16_t tcr4;
1338  uint16_t tcn3;
1339  uint16_t tcn4;
1340  uint16_t ter1;
1341  uint16_t ter2;
1342  uint16_t ter3;
1343  uint16_t ter4;
1344  uint8_t cpt_pad2[608];
1345
1346
1347  /*
1348  * DMA Block
1349  */
1350  uint8_t sdsr;
1351  uint8_t dma_pad0[3];
1352  uint8_t sdmr;
1353  uint8_t dma_pad1[3];
1354
1355  uint8_t idsr1;
1356  uint8_t dma_pad2[3];
1357  uint8_t idmr1;
1358  uint8_t dma_pad3[3];
1359  uint8_t idsr2;
1360  uint8_t dma_pad4[3];
1361  uint8_t idmr2;
1362  uint8_t dma_pad5[3];
1363  uint8_t idsr3;
1364  uint8_t dma_pad6[3];
1365  uint8_t idmr3;
1366  uint8_t dma_pad7[3];
1367  uint8_t idsr4;
1368  uint8_t dma_pad8[3];
1369  uint8_t idmr4;
1370  uint8_t dma_pad9[707];
1371
1372
1373  /*
1374  * FCC Block
1375  */
1376  m8260FCCRegisters_t fcc1;
1377  m8260FCCRegisters_t fcc2;
1378  m8260FCCRegisters_t fcc3;
1379
1380  uint8_t fcc_pad0[656];
1381
1382  /*
1383  * BRG 5-8 Block
1384  */
1385  uint32_t brgc5;
1386  uint32_t brgc6;
1387  uint32_t brgc7;
1388  uint32_t brgc8;
1389  uint8_t brg_pad0[608];
1390
1391
1392  /*
1393  * I2C
1394  */
1395  uint8_t i2mod;
1396  uint8_t i2m_pad0[3];
1397  uint8_t i2add;
1398  uint8_t i2m_pad1[3];
1399  uint8_t i2brg;
1400  uint8_t i2m_pad2[3];
1401  uint8_t i2com;
1402  uint8_t i2m_pad3[3];
1403  uint8_t i2cer;
1404  uint8_t i2m_pad4[3];
1405  uint8_t i2cmr;
1406  uint8_t i2m_pad5[331];
1407
1408
1409  /*
1410  * CPM Block
1411  */
1412  uint32_t cpcr;
1413  uint32_t rccr;
1414  uint8_t cpm_pad3[14];
1415  uint16_t rter;
1416  uint8_t cpm_pad[2];
1417  uint16_t rtmr;
1418  uint16_t rtscr;
1419  uint8_t cpm_pad4[2];
1420  uint32_t rtsr;
1421  uint8_t cpm_pad5[12];
1422
1423
1424  /*
1425  * BRG 1-4 Block
1426  */
1427  uint32_t brgc1;
1428  uint32_t brgc2;
1429  uint32_t brgc3;
1430  uint32_t brgc4;
1431
1432
1433  /*
1434  * SCC Block
1435  */
1436  m8260SCCRegisters_t scc1;
1437  m8260SCCRegisters_t scc2;
1438  m8260SCCRegisters_t scc3;
1439  m8260SCCRegisters_t scc4;
1440
1441
1442  /*
1443  * SMC Block
1444  */
1445  m8260SMCRegisters_t smc1;
1446  m8260SMCRegisters_t smc2;
1447
1448
1449  /*
1450  * SPI Block
1451  */
1452  uint16_t spmode;
1453  uint8_t spi_pad0[4];
1454  uint8_t spie;
1455  uint8_t spi_pad1[3];
1456  uint8_t spim;
1457  uint8_t spi_pad2[2];
1458  uint8_t spcom;
1459  uint8_t spi_pad3[82];
1460
1461
1462  /*
1463  * CPM Mux Block
1464  */
1465  uint8_t cmxsi1cr;
1466  uint8_t cmx_pad0[1];
1467  uint8_t cmxsi2cr;
1468  uint8_t cmx_pad1[1];
1469  uint32_t cmxfcr;
1470  uint32_t cmxscr;
1471  uint8_t cmxsmr;
1472  uint8_t cmx_pad2[1];
1473  uint16_t cmxuar;
1474  uint8_t cmx_pad3[16];
1475
1476
1477  /*
1478  * SI & MCC Blocks
1479  */
1480  m8260SIRegisters_t si1;
1481  m8260MCCRegisters_t mcc1;
1482  m8260SIRegisters_t si2;
1483  m8260MCCRegisters_t mcc2;
1484
1485  uint8_t mcc_pad0[1152];
1486
1487  /*
1488  * SI1 RAM
1489  */
1490  uint8_t si1txram[512];
1491  uint8_t ram_pad0[512];
1492  uint8_t si1rxram[512];
1493  uint8_t ram_pad1[512];
1494
1495
1496  /*
1497  * SI2 RAM
1498  */
1499  uint8_t si2txram[512];
1500  uint8_t ram_pad2[512];
1501  uint8_t si2rxram[512];
1502  uint8_t ram_pad3[512];
1503
1504
1505 } m8260_t;
1506
1507 extern volatile m8260_t m8260;
1508 #endif /* ASM */
1509
1510 #endif /* _MPC8260_H */
Definition: mpc8260.h:1128
Definition: mpc8260.h:68
Definition: mpc8260.h:533
Definition: mpc8260.h:246
Definition: mpc8260.h:739
Definition: mpc8260.h:217
Definition: mpc8260.h:77
Definition: mpc8260.h:130
Definition: mpc8260.h:148
Definition: mpc8260.h:643
Definition: mpc8260.h:390
Definition: mpc8260.h:98
Definition: mpc8260.h:593
Definition: mpc8260.h:116
