RTEMS  5.1
mpc55xx.h
1
9 /*
10  * Copyright (c) 2008-2012 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Obere Lagerstr. 30
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
38 #ifndef LIBCPU_POWERPC_MPC55XX_H
39 #define LIBCPU_POWERPC_MPC55XX_H
40
41 #include <mpc55xx/regs.h>
42 #include <mpc55xx/regs-mmu.h>
43
44 #include <libcpu/powerpc-utility.h>
45
46 #ifdef __cplusplus
47 extern "C" {
48 #endif /* __cplusplus */
49
50 int mpc55xx_flash_copy(void *dest, const void *src, size_t nbytes);
51 int mpc55xx_flash_copy_op(void *rdest, const void *src, size_t nbytes,
52  uint32_t opmask, uint32_t *p_fail_addr);
53 int mpc55xx_flash_size(uint32_t *p_size);
54 int mpc55xx_flash_writable(void);
55 uint32_t mpc55xx_flash_address(void);
56 void mpc55xx_flash_set_read_only(void);
57 void mpc55xx_flash_set_read_write(void);
58
59 int mpc55xx_physical_address(const void *addr, uint32_t *p_result);
60 int mpc55xx_mapped_address(const void *addr, uint32_t *p_result);
61
62 /* Bits for opmask. */
63 #define MPC55XX_FLASH_BLANK_CHECK 0x01
64 #define MPC55XX_FLASH_UNLOCK 0x02
65 #define MPC55XX_FLASH_ERASE 0x04
66 #define MPC55XX_FLASH_PROGRAM 0x08
67 #define MPC55XX_FLASH_VERIFY 0x10
68
69 /* Error returns. CONFIG or SIZE might mean you just
70  * need to check for new configuration bits.
71  * SIZE and RANGE mean you are outside of a known flash region.
72  * ERASE means the erase failed,
73  * PROGRAM means the program failed,
74  * BLANK means it wasn't blank and BLANK_CHECK was specified,
75  * VERIFY means VERIFY was set and it didn't match the source,
76  * and LOCK means either the locking failed or you needed to
77  * specify MPC55XX_FLASH_UNLOCK and didn't.
78  */
79 #define MPC55XX_FLASH_CONFIG_ERR (-1)
80 #define MPC55XX_FLASH_SIZE_ERR (-2)
81 #define MPC55XX_FLASH_RANGE_ERR (-3)
82 #define MPC55XX_FLASH_ERASE_ERR (-4)
83 #define MPC55XX_FLASH_PROGRAM_ERR (-5)
84 #define MPC55XX_FLASH_NOT_BLANK_ERR (-6)
85 #define MPC55XX_FLASH_VERIFY_ERR (-7)
86 #define MPC55XX_FLASH_LOCK_ERR (-8)
87
88 #define MPC55XX_CACHE_ALIGNED_MASK ((uintptr_t) 0x1f)
89
90 #define MPC55XX_CACHE_LINE_SIZE 32
91
95 static inline int mpc55xx_is_cache_aligned( const void *s, size_t n)
96 {
97  return !(((uintptr_t) s & MPC55XX_CACHE_ALIGNED_MASK) || (n & MPC55XX_CACHE_ALIGNED_MASK));
98 }
99
100 static inline uintptr_t mpc55xx_cache_aligned_start( const void *s)
101 {
102  return ((uintptr_t) s & MPC55XX_CACHE_ALIGNED_MASK) ? (((uintptr_t) s & ~MPC55XX_CACHE_ALIGNED_MASK) + MPC55XX_CACHE_LINE_SIZE) : (uintptr_t)s;
103 }
104
105 static inline size_t mpc55xx_non_cache_aligned_size( const void *s)
106 {
107  return (uintptr_t) mpc55xx_cache_aligned_start( s) - (uintptr_t) s;
108 }
109
110 static inline size_t mpc55xx_cache_aligned_size( const void *s, size_t n)
111 {
112  return (n - mpc55xx_non_cache_aligned_size( s)) & ~MPC55XX_CACHE_ALIGNED_MASK;
113 }
114
118 static inline uint32_t mpc55xx_count_leading_zeros( uint32_t value)
119 {
120  uint32_t count;
121  __asm__ (
122  "cntlzw %0, %1;"
123  : "=r" (count)
124  : "r" (value)
125  );
126  return count;
127 }
128
129 static inline void mpc55xx_wait_for_interrupt(void)
130 {
131  #ifdef MPC55XX_HAS_WAIT_INSTRUCTION
132  __asm__ volatile ("wait");
133  #else
134  __asm__ volatile ("");
135  #endif
136 }
137
138 static inline void mpc55xx_mmu_apply_config(const struct MMU_tag *config)
139 {
140  PPC_SET_SPECIAL_PURPOSE_REGISTER(FSL_EIS_MAS0, config->MAS0.R);
141  PPC_SET_SPECIAL_PURPOSE_REGISTER(FSL_EIS_MAS1, config->MAS1.R);
142  PPC_SET_SPECIAL_PURPOSE_REGISTER(FSL_EIS_MAS2, config->MAS2.R);
143  PPC_SET_SPECIAL_PURPOSE_REGISTER(FSL_EIS_MAS3, config->MAS3.R);
144  __asm__ volatile ("tlbwe");
145 }
146
147 #ifdef __cplusplus
148 }
149 #endif /* __cplusplus */
150
151 #endif /* LIBCPU_POWERPC_MPC55XX_H */
Definition: deflate.c:115
Definition: regs-mmu.h:66
#define PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val)
Sets the Special Purpose Register with number spr to the value in val.
Definition: powerpc-utility.h:576
General purpose assembler macros, linker command file support and some inline functions for direct re...
Register definitions for the MPC55xx and MPC56xx microcontroller family.
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
