RTEMS  5.1
mpc55xx-config.h
1
9 /*
10  * Copyright (c) 2008-2012 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Obere Lagerstr. 30
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LIBBSP_POWERPC_MPC55XXEVB_MPC55XX_CONFIG_H
24 #define LIBBSP_POWERPC_MPC55XXEVB_MPC55XX_CONFIG_H
25
26 #include <stddef.h>
27
28 #include <libcpu/powerpc-utility.h>
29
30 #include <bsp/start.h>
31
32 #include <mpc55xx/regs.h>
33 #include <mpc55xx/regs-mmu.h>
34 #include <mpc55xx/siu.h>
35
36 #ifdef __cplusplus
37 extern "C" {
38 #endif /* __cplusplus */
39
40 typedef struct {
41  uint32_t index : 10;
42  uint32_t count : 10;
43  uint32_t output : 1;
44  union SIU_PCR_tag pcr;
46
47 extern BSP_START_DATA_SECTION const mpc55xx_siu_pcr_config
48  mpc55xx_start_config_siu_pcr [];
49
50 extern BSP_START_DATA_SECTION const size_t
51  mpc55xx_start_config_siu_pcr_count [];
52
53 extern BSP_START_DATA_SECTION const struct
54  MMU_tag mpc55xx_start_config_mmu_early [];
55
56 extern BSP_START_DATA_SECTION const size_t
57  mpc55xx_start_config_mmu_early_count [];
58
59 extern BSP_START_DATA_SECTION const struct
60  MMU_tag mpc55xx_start_config_mmu [];
61
62 extern BSP_START_DATA_SECTION const size_t
63  mpc55xx_start_config_mmu_count [];
64
65 #ifdef MPC55XX_HAS_FMPLL
66  typedef struct {
67  union FMPLL_SYNCR_tag syncr_tmp;
68  union FMPLL_SYNCR_tag syncr_final;
69  } mpc55xx_clock_config;
70 #endif
71
72 #ifdef MPC55XX_HAS_FMPLL_ENHANCED
73  typedef struct {
74  union FMPLL_ESYNCR2_tag esyncr2_tmp;
75  union FMPLL_ESYNCR2_tag esyncr2_final;
76  union FMPLL_ESYNCR1_tag esyncr1_final;
77  } mpc55xx_clock_config;
78 #endif
79
80 #ifdef MPC55XX_HAS_MODE_CONTROL
81  typedef struct {
82  struct {
83  PLLD_CR_32B_tag cr;
84  PLLD_MR_32B_tag mr;
85  } fmpll [2];
86  CGM_OC_EN_32B_tag oc_en;
87  CGM_OCDS_SC_32B_tag ocds_sc;
88  CGM_SC_DC0_3_32B_tag sc_dc0_3;
89  CGM_AUXCLK_tag auxclk [5];
90  } mpc55xx_clock_config;
91 #endif
92
93 extern BSP_START_DATA_SECTION const mpc55xx_clock_config
94  mpc55xx_start_config_clock [];
95
96 #ifdef MPC55XX_HAS_EBI
97  typedef struct {
98  union EBI_MCR_tag ebi_mcr;
99  uint32_t siu_eccr_ebdf;
100  } mpc55xx_ebi_config;
101
102  extern BSP_START_DATA_SECTION const mpc55xx_ebi_config
103  mpc55xx_start_config_ebi [];
104
105  extern BSP_START_DATA_SECTION const size_t
106  mpc55xx_start_config_ebi_count [];
107
108  extern BSP_START_DATA_SECTION const struct EBI_CS_tag
109  mpc55xx_start_config_ebi_cs [];
110
111  extern BSP_START_DATA_SECTION const size_t
112  mpc55xx_start_config_ebi_cs_count [];
113
114  extern BSP_START_DATA_SECTION const struct EBI_CAL_CS_tag
115  mpc55xx_start_config_ebi_cal_cs [];
116
117  extern BSP_START_DATA_SECTION const size_t
118  mpc55xx_start_config_ebi_cal_cs_count [];
119 #endif
120
134 void mpc55xx_start_prologue(void);
135
136 void mpc55xx_start_early(void);
137
138 void mpc55xx_start_flash(void);
139
140 void mpc55xx_start_cache(void);
141
142 void mpc55xx_start_clock(void);
143
144 void mpc55xx_start_watchdog(void);
145
146 void mpc55xx_start_mmu_apply_config(const struct MMU_tag *config, size_t count);
147
148 uint32_t mpc55xx_get_system_clock(void);
149
150 LINKER_SYMBOL(bsp_ram_start)
151 LINKER_SYMBOL(bsp_ram_end)
152 LINKER_SYMBOL(bsp_ram_size)
153
154 LINKER_SYMBOL(bsp_ram_1_start)
155 LINKER_SYMBOL(bsp_ram_1_end)
156 LINKER_SYMBOL(bsp_ram_1_size)
157
158 LINKER_SYMBOL(bsp_rom_start)
159 LINKER_SYMBOL(bsp_rom_end)
160 LINKER_SYMBOL(bsp_rom_size)
161
162 #ifdef MPC55XX_BOOTFLAGS
163  extern uint32_t mpc55xx_bootflag_0 [];
164 #endif
165
166 #ifdef __cplusplus
167 }
168 #endif /* __cplusplus */
169
170 #endif /* LIBBSP_POWERPC_MPC55XXEVB_MPC55XX_CONFIG_H */
Definition: fsl-mpc564xL.h:4823
Definition: mpc55xx-config.h:40
Definition: deflate.c:115
Definition: regs-mmu.h:66
Definition: fsl-mpc551x.h:447
Start prologue.
Definition: start-prologue.c:25
Definition: fsl-mpc564xL.h:966
Definition: fsl-mpc564xL.h:4834
Definition: fsl-mpc564xL.h:4684
General purpose assembler macros, linker command file support and some inline functions for direct re...
Definition: fsl-mpc564xL.h:4859
Register definitions for the MPC55xx and MPC56xx microcontroller family.
Definition: fsl-mpc564xL.h:4663
System Integration Unit Access (SIU).
Definition: fsl-mpc564xL.h:4916
Definition: fsl-mpc551x.h:479
