RTEMS  5.1
mpc5200mbus.h
1 /*===============================================================*\
2 | Project: RTEMS generic MPC5200 BSP |
3 +-----------------------------------------------------------------+
4 | Copyright (c) 2005 |
5 | Embedded Brains GmbH |
6 | Obere Lagerstr. 30 |
7 | D-82178 Puchheim |
8 | Germany |
9 | rtems@embedded-brains.de |
10 +-----------------------------------------------------------------+
11 | The license and distribution terms for this file may be |
12 | found in the file LICENSE in this distribution or at |
13 | |
14 | http://www.rtems.org/license/LICENSE. |
15 | |
16 +-----------------------------------------------------------------+
17 | MBUS module (I2C bus) definitions |
18 +-----------------------------------------------------------------+
19 | This file has been adapted from an existing source code file, |
20 | see the original file header below for reference |
21 \*===============================================================*/
22 /*
23  * MCF5206e MBUS module (I2C bus) driver header file
24  *
25  * Copyright (C) 2000 OKTET Ltd., St.-Petersburg, Russia
26  * Author: Victor V. Vengerov <vvv@oktet.ru>
27  *
28  * The license and distribution terms for this file may be
29  * found in the file LICENSE in this distribution or at
30  *
31  * http://www.rtems.org/license/LICENSE.
32  */
33
34 #ifndef __MPC5200BSP_MPC5200MBUS_H__
35 #define __MPC5200BSP_MPC5200MBUS_H__
36
37 #include <bsp/mpc5200.h>
38 #include <bsp/i2c.h>
39
40
41 /* States of I2C machine */
42 typedef enum mpc5200mbus_i2c_state {
43  STATE_UNINITIALIZED,
44  STATE_IDLE,
45  STATE_ADDR_7,
46  STATE_ADDR_1_W,
47  STATE_ADDR_1_R,
48  STATE_SENDING,
49  STATE_RECEIVING
50 } mpc5200mbus_i2c_state;
51
52 typedef struct mpc5200_mbus {
53  enum mpc5200mbus_i2c_state state;/* State of I2C machine */
54  i2c_message *msg; /* Pointer to the first message in transfer */
55  int nmsg; /* Number of messages in transfer */
56  i2c_message *cmsg; /* Current message */
57  int byte; /* Byte number in current message */
58  rtems_id sema; /* MBUS semaphore */
59  i2c_transfer_done done; /* Transfer done function */
60  void * done_arg_ptr; /* Done function argument pointer */
61  int bus_idx; /* bus index: 0 or 1 */
62 } mpc5200mbus;
63
64 /* mpc5200mbus_initialize --
65  * Initialize ColdFire MBUS I2C bus controller.
66  *
67  * PARAMETERS:
68  * i2c_bus - pointer to the bus descriptor structure
69  *
70  * RETURNS:
71  * RTEMS_SUCCESSFUL, or RTEMS error code when initialization failed.
72  */
74 mpc5200mbus_initialize(mpc5200mbus *i2c_bus);
75
76 /* mpc5200mbus_select_clock_divider --
77  * Select divider for system clock which is used for I2C bus clock
78  * generation. Not each divider can be selected for I2C bus; this
79  * function select nearest larger or equal divider, or maximum
80  * possible divider, if passed value greater.
81  *
82  * PARAMETERS:
83  * i2c_bus - pointer to the bus descriptor structure
84  * divider - system frequency divider for I2C serial clock.
85  *
86  * RETURNS:
87  * RTEMS_SUCCESSFUL, if operation performed successfully, or
88  * RTEMS error code when failed.
89  */
91 mpc5200mbus_select_clock_divider(mpc5200mbus *i2c_bus, int divider);
92
93 /* mpc5200mbus_i2c_transfer --
94  * Initiate multiple-messages transfer over I2C bus via ColdFire MBUS
95  * controller.
96  *
97  * PARAMETERS:
98  * bus - pointer to MBUS controller descriptor
99  * nmsg - number of messages
100  * msg - pointer to messages array
101  * done - function which is called when transfer is finished
102  * done_arg_ptr - arbitrary argument ptr passed to done funciton
103  *
104  * RETURNS:
105  * RTEMS_SUCCESSFUL if transfer initiated successfully, or error
106  * code when failed.
107  */
109 mpc5200mbus_i2c_transfer(mpc5200mbus *bus, int nmsg, i2c_message *msg,
110  i2c_transfer_done done, void * done_arg_ptr);
111
112 /* mpc5200mbus_i2c_done --
113  * Close ColdFire MBUS I2C bus controller and release all resources.
114  *
115  * PARAMETERS:
116  * bus - pointer to MBUS controller descriptor
117  *
118  * RETURNS:
119  * RTEMS_SUCCESSFUL, if transfer initiated successfully, or error
120  * code when failed.
121  */
123 mpc5200mbus_i2c_done(mpc5200mbus *i2c_bus);
124
125 /* mpc5200mbus_i2c_interrupt_handler --
126  * ColdFire MBUS I2C bus controller interrupt handler. This function
127  * called from real interrupt handler, and pointer to MBUS descriptor
128  * structure passed to this function.
129  *
130  * PARAMETERS:
131  * bus - pointert to the bus descriptor structure
132  *
133  * RETURNS:
134  * none
135  */
136 void mpc5200mbus_i2c_interrupt_handler(mpc5200mbus *bus);
137
138 /* mpc5200mbus_poll --
139  * MBUS module poll routine; used to poll events when I2C driver
140  * operates in poll-driven mode.
141  *
142  * PARAMETERS:
143  * none
144  *
145  * RETURNS:
146  * none
147  */
148 void mpc5200mbus_poll(mpc5200mbus *bus);
149
150 #endif /* __MPC5200BSP_MPC5200MBUS_H__ */
rtems_status_code
Classic API Status.
Definition: status.h:43
I2C bus control.
Definition: i2c.h:110
Definition: mpc5200mbus.h:52
Definition: b1553brm.c:75
Definition: i2c.h:53
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
