RTEMS  5.1
mouse_parser.h
1
9 /*
10  * This file is derived from a UNIX Serial Port Mouse Driver with the
11  * following notice:
12  *
13  * ==================================================================
14  * Copyright (c) 1999 Greg Haerr <greg@censoft.com>
15  * Portions Copyright (c) 1991 David I. Bell
16  * Permission is granted to use, distribute, or modify this source,
17  * provided that this copyright notice remains intact.
18  *
19  * UNIX Serial Port Mouse Driver
20  *
21  * This driver opens a serial port directly, and interprets serial data.
22  * Microsoft, PC, Logitech and PS/2 mice are supported. The PS/2 mouse
23  * is only supported if the OS runs the mouse byte codes through the
24  * serial port.
25  *
26  * Mouse Types Supported: pc ms, logi, ps2
27  * ==================================================================
28  *
29  * It has been modified to support the concept of being just a parser
30  * fed data from an arbitrary source. It is independent of either
31  * a PS/2 driver or a serial port.
32  *
33  * It was moved to cpukit/libmisc/mouse by Joel Sherrill.
34  */
35
36 #ifndef __MOUSE_PARSER_h__
37 #define __MOUSE_PARSER_h__
38
39 #include <rtems/mw_uid.h>
40
47 #ifdef __cplusplus
48 extern "C" {
49 #endif
50
56 #define RBUTTON MV_BUTTON_RIGHT
57
63 #define MBUTTON MV_BUTTON_CENTER
64
70 #define LBUTTON MV_BUTTON_LEFT
71
75 typedef int COORD;
76
80 typedef unsigned int BUTTON;
81
87 typedef void (*mouse_parser_enqueue_handler)(unsigned char *, size_t);
88
100 int mouse_parser_initialize(const char *type);
101
111  unsigned char *buffer,
112  size_t size
113 );
114
115 #ifdef __cplusplus
116 }
117 #endif
118
121 #endif
void mouse_parser_enqueue(unsigned char *buffer, size_t size)
Enqueue input to the mouse parser engine.
Definition: mouse_parser.c:296
Input Devices for MicroWindows.
unsigned int BUTTON
Definition: mouse_parser.h:80
Initialize the mouse parser engine.
Definition: mouse_parser.c:98
int COORD
Definition: mouse_parser.h:75
unsigned size
Definition: tte.h:74
void(* mouse_parser_enqueue_handler)(unsigned char *, size_t)
Definition: mouse_parser.h:87
