RTEMS  5.1
modesimpl.h File Reference
Classic Modes Implementation. More...
#include <rtems/rtems/modes.h>
#include <rtems/score/isrlevel.h>
RTEMS_INLINE_ROUTINE bool _Modes_Mask_changed (rtems_mode mode_set, rtems_mode masks)
 Checks if any of the mode flags in mask are set in mode_set. More...
RTEMS_INLINE_ROUTINE bool _Modes_Is_asr_disabled (rtems_mode mode_set)
 Checks if mode_set says that Asynchronous Signal Processing is disabled. More...
RTEMS_INLINE_ROUTINE bool _Modes_Is_preempt (rtems_mode mode_set)
 Checks if mode_set indicates that preemption is enabled. More...
RTEMS_INLINE_ROUTINE bool _Modes_Is_timeslice (rtems_mode mode_set)
 Checks if mode_set indicates that timeslicing is enabled. More...
RTEMS_INLINE_ROUTINE ISR_Level _Modes_Get_interrupt_level (rtems_mode mode_set)
 Gets the interrupt level portion of the mode_set. More...
RTEMS_INLINE_ROUTINE void _Modes_Set_interrupt_level (rtems_mode mode_set)
 Sets the current interrupt level to that specified in the mode_set. More...
RTEMS_INLINE_ROUTINE void _Modes_Change (rtems_mode old_mode_set, rtems_mode new_mode_set, rtems_mode mask, rtems_mode *out_mode_set, rtems_mode *changed)
 Changes the modes in old_mode_set indicated by mask to the requested values in new_mode_set. More...
