RTEMS  5.1
mcfmbus.h
1 /*
2  * MCF5206e MBUS module (I2C bus) driver header file
3  *
4  * Copyright (C) 2000 OKTET Ltd., St.-Petersburg, Russia
5  * Author: Victor V. Vengerov <vvv@oktet.ru>
6  *
7  * The license and distribution terms for this file may be
8  * found in the file LICENSE in this distribution or at
9  * http://www.rtems.org/license/LICENSE.
10  */
11
12 #ifndef __MCFBSP_MCFMBUS_H__
13 #define __MCFBSP_MCFMBUS_H__
14
15 #include "mcf5206e.h"
16 #include "i2c.h"
17
18 /* States of I2C machine */
19 typedef enum mcfmbus_i2c_state {
20  STATE_IDLE,
21  STATE_ADDR_7,
22  STATE_ADDR_1_W,
23  STATE_ADDR_1_R,
24  STATE_SENDING,
25  STATE_RECEIVING
26 } mcfmbus_i2c_state;
27
28 typedef struct mcfmbus {
29  uint32_t base; /* ColdFire internal peripherial base
30  address */
31  enum mcfmbus_i2c_state state;/* State of I2C machine */
32  i2c_message *msg; /* Pointer to the first message in transfer */
33  int nmsg; /* Number of messages in transfer */
34  i2c_message *cmsg; /* Current message */
35  int byte; /* Byte number in current message */
36  rtems_isr_entry oldisr; /* Old interrupt handler */
37  rtems_id sema; /* MBUS semaphore */
38  i2c_transfer_done done; /* Transfer done function */
39  uintptr_t done_arg_ptr; /* Done function argument ptr */
40 } mcfmbus;
41
42 /* mcfmbus_initialize --
43  * Initialize ColdFire MBUS I2C bus controller.
44  *
45  * PARAMETERS:
46  * i2c_bus - pointer to the bus descriptor structure
47  * base - ColdFire internal peripherial base address
48  *
49  * RETURNS:
50  * RTEMS_SUCCESSFUL, or RTEMS error code when initialization failed.
51  */
53 mcfmbus_initialize(mcfmbus *i2c_bus, uint32_t base);
54
55 /* mcfmbus_select_clock_divider --
56  * Select divider for system clock which is used for I2C bus clock
57  * generation. Not each divider can be selected for I2C bus; this
58  * function select nearest larger or equal divider, or maximum
59  * possible divider, if passed value greater.
60  *
61  * PARAMETERS:
62  * i2c_bus - pointer to the bus descriptor structure
63  * divider - system frequency divider for I2C serial clock.
64  *
65  * RETURNS:
66  * RTEMS_SUCCESSFUL, if operation performed successfully, or
67  * RTEMS error code when failed.
68  */
70 mcfmbus_select_clock_divider(mcfmbus *i2c_bus, int divider);
71
72 /* mcfmbus_i2c_transfer --
73  * Initiate multiple-messages transfer over I2C bus via ColdFire MBUS
74  * controller.
75  *
76  * PARAMETERS:
77  * bus - pointer to MBUS controller descriptor
78  * nmsg - number of messages
79  * msg - pointer to messages array
80  * done - function which is called when transfer is finished
81  * done_arg_ptr - arbitrary argument ptr passed to done funciton
82  *
83  * RETURNS:
84  * RTEMS_SUCCESSFUL if transfer initiated successfully, or error
85  * code when failed.
86  */
88 mcfmbus_i2c_transfer(mcfmbus *bus, int nmsg, i2c_message *msg,
89  i2c_transfer_done done, void *done_arg_ptr);
90
91 /* mcfmbus_i2c_done --
92  * Close ColdFire MBUS I2C bus controller and release all resources.
93  *
94  * PARAMETERS:
95  * bus - pointer to MBUS controller descriptor
96  *
97  * RETURNS:
98  * RTEMS_SUCCESSFUL, if transfer initiated successfully, or error
99  * code when failed.
100  */
102 mcfmbus_i2c_done(mcfmbus *i2c_bus);
103
104 /* mcfmbus_i2c_interrupt_handler --
105  * ColdFire MBUS I2C bus controller interrupt handler. This function
106  * called from real interrupt handler, and pointer to MBUS descriptor
107  * structure passed to this function.
108  *
109  * PARAMETERS:
110  * bus - pointert to the bus descriptor structure
111  *
112  * RETURNS:
113  * none
114  */
115 void mcfmbus_i2c_interrupt_handler(mcfmbus *bus);
116
117 /* mcfmbus_poll --
118  * MBUS module poll routine; used to poll events when I2C driver
119  * operates in poll-driven mode.
120  *
121  * PARAMETERS:
122  * none
123  *
124  * RETURNS:
125  * none
126  */
127 void mcfmbus_poll(mcfmbus *bus);
128
129 #endif /* __MCFBSP_MCFMBUS_H__ */
Definition: mcfmbus.h:28
rtems_status_code
Classic API Status.
Definition: status.h:43
I2C bus control.
Definition: i2c.h:110
Definition: b1553brm.c:75
Definition: i2c.h:53
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
